Hello!
~ # wlconf -b /usr/share/wlconf/struct.bin -i /lib/firmware/ti-connectivity/wl18xx-conf.bin -g ................ core.recovery.no_recovery = 0x00 wl18xx.ht.mode = 0x01 wl18xx.phy.phy_standalone = 0x00 ~ # /etc/init.d/network.sh start [ 153.118953] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ9) [ 153.585037] wlcore: PHY firmware version: Rev 8.2.0.0.236 [ 153.779677] wlcore: firmware booted (Rev 8.9.0.0.69) [ 153.808253] device eth0 entered promiscuous mode [ 153.817041] device wlan0 entered promiscuous mode random: Trying to read entropy from /dev/random Configuration file: /etc/hostapd.conf ctrl_interface_group=0 eapol_version=1 [ 153.852946] wlcore: down nl80211: Supported cipher 00-0f-ac:1 nl80211: Supported cipher 00-0f-ac:5 nl80211: Supported cipher 00-0f-ac:2 nl80211: Supported cipher 00-0f-ac:4 nl80211: Supported cipher 00-14-72:1 nl80211: Supports Probe Response offload in AP mode nl80211: Using driver-based off-channel TX nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 040 nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=80 nl80211: Supported vendor command: vendor_id=0x80028 subcmd=0 nl80211: Supported vendor command: vendor_id=0x80028 subcmd=1 nl80211: Supported vendor command: vendor_id=0x80028 subcmd=2 nl80211: Supported vendor event: vendor_id=0x80028 subcmd=0 nl80211: Supported vendor event: vendor_id=0x80028 subcmd=1 nl80211: Use separate P2P group interface (driver advertised support) nl80211: Enable multi-channel concurrent (driver advertised support) nl80211: interface wlan0 in phy phy0 nl80211: Set mode ifindex 3 iftype 3 (AP) nl80211: Setup AP(wlan0) - device_ap_sme=0 use_monitor=0 nl80211: Subscribe to mgmt frames with AP handle 0xba93b8 nl80211: Register frame type=0xb0 (WLAN_FC_STYPE_AUTH) nl_handle=0xba93b8 match= nl80211: Register frame type=0x0 (WLAN_FC_STYPE_ASSOC_REQ) nl_handle=0xba93b8 m= nl80211: Register frame type=0x20 (WLAN_FC_STYPE_REASSOC_REQ) nl_handle=0xba93b= nl80211: Register frame type=0xa0 (WLAN_FC_STYPE_DISASSOC) nl_handle=0xba93b8 m= nl80211: Register frame type=0xc0 (WLAN_FC_STYPE_DEAUTH) nl_handle=0xba93b8 mat= nl80211: Register frame type=0x40 (WLAN_FC_STYPE_PROBE_REQ) nl_handle=0xba93b8 = nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mat4 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mat1 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mat4 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mat6 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mat8 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mat9 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mata nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 mat1 nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xba93b8 matf rfkill: initial event: idx=0 type=1 op=0 soft=0 hard=0 nl80211: Interface wlan0 is in bridge br0 nl80211: Add own interface ifindex 5 (ifidx_reason 3) nl80211: if_indices[16]: 5(3) nl80211: Add own interface ifindex 3 (ifidx_reason -1) nl80211: if_indices[16]: 5(3) 3(-1) phy: phy0 BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits) wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE Previous country code RU, new country code RU nl80211: Regulatory information - country=RU (DFS-ETSI) nl80211: 2402-2482 @ 40 MHz 20 mBm nl80211: 5170-5250 @ 80 MHz 20 mBm nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) nl80211: 5650-5730 @ 80 MHz 30 mBm (DFS) nl80211: 5735-5835 @ 80 MHz 30 mBm nl80211: 57000-66000 @ 2160 MHz 40 mBm nl80211: Added 802.11b mode based on 802.11g information Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=12 freq=2467 MHz max_tx_power=20 dBm Allowed channel: mode=1 chan=13 freq=2472 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=36 freq=5180 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=38 freq=5190 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=40 freq=5200 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=42 freq=5210 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=44 freq=5220 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=46 freq=5230 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=48 freq=5240 MHz max_tx_power=20 dBm Allowed channel: mode=2 chan=149 freq=5745 MHz max_tx_power=30 dBm Allowed channel: mode=2 chan=153 freq=5765 MHz max_tx_power=30 dBm Allowed channel: mode=2 chan=157 freq=5785 MHz max_tx_power=30 dBm Allowed channel: mode=2 chan=161 freq=5805 MHz max_tx_power=30 dBm Allowed channel: mode=2 chan=165 freq=5825 MHz max_tx_power=30 dBm Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=12 freq=2467 MHz max_tx_power=20 dBm Allowed channel: mode=0 chan=13 freq=2472 MHz max_tx_power=20 dBm hw vht capab: 0x0, conf vht capab: 0x0 wlan0: interface state COUNTRY_UPDATE->HT_SCAN Scan for neighboring BSSes prior to enabling 40 MHz channel 40 MHz affected channel range: [2412,2492] MHz wlan0: nl80211: scan request nl80211: Passive scan requested nl80211: Scan frequency 2412 MHz nl80211: Scan frequency 2417 MHz nl80211: Scan frequency 2422 MHz nl80211: Scan frequency 2427 MHz nl80211: Scan frequency 2432 MHz nl80211: Scan frequency 2437 MHz nl80211: Scan frequency 2442 MHz nl80211: Scan frequency 2447 MHz nl80211: Scan frequency 2452 MHz nl80211: Scan frequency 2457 MHz nl80211: Scan frequency 2462 MHz nl80211: Scan frequency 2467 MHz nl80211: Scan frequency 2472 MHz Scan requested (ret=0) - scan timeout 10 seconds Interface initialization will be completed in a callback ctrl_iface not configured! ~ # iw dev wlan0 info Interface wlan0 ifindex 3 wdev 0x1 addr 54:4a:16:12:d0:64 ssid STC-MT_TestWLAN type AP wiphy 0 channel 11 (2462 MHz), width: 20 MHz, center1: 2462 MHz ~ # cat /etc/hostapd.conf interface=wlan0 driver=nl80211 ctrl_interface=/var/run/hostapd ctrl_interface_group=0 country_code=RU macaddr_acl=0 auth_algs=3 ignore_broadcast_ssid=0 ieee80211n=1 ieee80211ac=1 eapol_version=1 wpa=3 wpa_key_mgmt=WPA-PSK WPA-EAP wpa_pairwise=TKIP CCMP ht_capab=[HT40-][SHORT-GI-20][SHORT-GI-40] bridge=br0 ssid=STC-MT_TestWLAN channel=11 wpa_passphrase=RnD777777 hw_mode=g
Information about system:
~ # cat /proc/version Linux version 4.1.15+ (root@ee719119bb37) (gcc version 5.2.0 (GCC) ) ~ # dmesg ............ [ 3.159244] wlcore: PHY firmware version: Rev 8.2.0.0.236 [ 3.269685] wlcore: firmware booted (Rev 8.9.0.0.69) [ 3.296673] device eth0 entered promiscuous mode [ 3.305321] device wlan0 entered promiscuous mode [ 3.342680] wlcore: down [ 3.466085] cfg80211: Regulatory domain changed to country: RU [ 3.471961] cfg80211: DFS Master region: ETSI [ 3.476277] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_ga) [ 3.486082] cfg80211: (2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 ) [ 3.494100] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz A) [ 3.503607] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz A) [ 3.513123] cfg80211: (5650000 KHz - 5730000 KHz @ 80000 KHz), (N/A, 3000 ) [ 3.521153] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 3000 ) [ 3.529184] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4) [ 3.595261] random: hostapd urandom read with 38 bits of entropy available ~ # hostapd -v hostapd v2.6-devel-hostap_2_5-1449-gf5728d0 User space daemon for IEEE 802.11 AP management, IEEE 802.1X/WPA/WPA2/EAP/RADIUS Authenticator Copyright (c) 2002-2016, Jouni Malinen <j@w1.fi> and contributors
Why hostapd return hw vht capab: 0x0, conf vht capab: 0x0 if firmware contained wl18xx.ht.mode = 0x01 and hostapd.conf contained ieee80211n=1 and ht_capab=[HT40-][SHORT-GI-20][SHORT-GI-40]?
How can I enable 40MHz channel width?
Thank you and excuse my bad english.
