Part Number: CC3220MOD
Other Parts Discussed in Thread: CC3200, , CC3200MOD, CC3220SF
We are starting a new Wi-Fi based design and since we want to avoid the certification process we are thinking or using a module. Our current product already has the CC3200 as a discrete solution.
- What are the main differences between the CC3200MOD and CC3220MOD?
- What is the recommended module for new designs and why (CC3200MOD/CC3220MOD)? From the price point there seems to be a difference of tens of percents.
- Our current design we are using the CC3200 (none module) and have the FW written for it. I understood that the FW porting is supposed to be simple. Is it the same process for both modules?
- Does the CC3220MOD has an internal antenna? I understand that the CC3200MOD doesn't have an external antenna. How can we add an antenna without losing hte module certifification?
- Our power consumption budget is very low. Our main use case is waking up the Wi-Fi device every 15 seconds, loading from the flask, transmit and go back to hibernate mode. If we could have shorten the period of loading the flash, we could have save power. Does the CC3220MOD with the internally flash has a considerably faster access to the memory that will enable us to wake-up and go back to sleep faster and by that save battery?
Thanks in advance,
Avi.
