Other Parts Discussed in Thread: SEGGER,
Is it possible to use the Segger J-link I to program the external flash chip (MX25R3235FM1IL0) on the CC3220S-LAUNCHXL? If so, is there an off-the-shelf adapter I can purchase to connect the J-Link to the board with the right pin out? I was looking at the Tag-Connect, TC2050-ARM2010 but it seems the pins don't match.
If the Segger J-Link cannot program the external flash, can you recommend a device that can be used to program the external flash?
Thank you!
best,
Akbar
