CC3200-LAUNCHXL: Can't read file from flash after hibernate system
Part Number: CC3200-LAUNCHXL
Other Parts Discussed in Thread: CC3200
  Recently our product need to include file operation base on Mqtt_Client example code.
  Procedure as below,
  Starting system -> Start SimpleLink task -> FsOpen(Create file) -> FsClose -> Push button -> PushButtonIntHandler
            -> signal a queue and MsgQWrite -> MsgQRead in a task, and FsOpen & FsWrite. And then, do the hibernate command to restart system
            -> FsOpen & FsRead after start SimpleLink task
  It can't success to read data as I write in before hibernate system.
  Could anyone help?
  Thanks!
  Part of code is attached.
/*File opertation variables*/
unsigned char readbuffer[BUF_SIZE];
SlFsFileInfo_t FileInfo;
long lFileHandle;
unsigned long ulToken;
/*Write file into flash*/
long WriteFileToDevice(unsigned long *ulToken, long *lFileHandle)
    long lRetVal = -1;
    //  open a user file for writing
    lRetVal = sl_FsOpen((unsigned char *)USER_FILE_NAME,
                        FS_MODE_OPEN_WRITE,
                        ulToken,
                        lFileHandle);
    if(lRetVal < 0)
        lRetVal = sl_FsClose(*lFileHandle, 0, 0, 0);
		return FAILURE;
	lRetVal = sl_FsGetInfo(USER_FILE_NAME, 0, &FileInfo);
	if(lRetVal < 0)
        GPIO_IF_LedOn(MCU_RED_LED_GPIO);
        LOOP_FOREVER();
	UART_PRINT("Get file information:\n");
	UART_PRINT("FileLen: [%d]\n", FileInfo.FileLen);
	UART_PRINT("AllocatedLen: [%d]\n", FileInfo.AllocatedLen);
	UART_PRINT("File token: [%d]\n", FileInfo.Token);
	UART_PRINT("File flags: [%d]\n", FileInfo.flags);
	char ssid_name[] = "Lex_Hsiao";
	char *writebuffer=(char*)malloc(1024);
  memset(writebuffer,'\0',sizeof(writebuffer));
	memcpy(writebuffer, (char*)ssid_name, sizeof(ssid_name)-1);
    // write new ssid, password and secure type into file
    lRetVal = sl_FsWrite(*lFileHandle, 0, (unsigned char *)writebuffer, sizeof(ssid_name)-1);
    if (lRetVal < 0)
				return FAILURE;
    // close the user file
		UART_PRINT("Write file success\n\n");
    return SUCCESS;
/*Read file from flash*/
long ReadFileFromDevice(unsigned long ulToken, long lFileHandle)
    long lRetVal = -1;
    // open a user file for reading
                        FS_MODE_OPEN_READ,
                        &ulToken,
                        &lFileHandle);
	if(lRetVal < 0)
	  	lRetVal = sl_FsClose(lFileHandle, 0, 0, 0);
	  	return FAILURE;
  // read the data, lRetVal returns the number of read bytes
  lRetVal = sl_FsRead(lFileHandle, 0, readbuffer, sizeof(readbuffer));
	UART_PRINT("Readbuffer length: %d\n", lRetVal);
    if(lRetVal < 0)
	  	UART_PRINT("Use default wifi setting.\n");
		return SUCCESS;
	else
		for (int i = 0; i < lRetVal; i++)
			UART_PRINT("%c", readbuffer[i]);
		UART_PRINT("\n");
    return SUCCESS;
/*File operation*/
void FileOperation(void)
  	long lRetVal;
  	lRetVal = sl_Start(NULL, NULL, NULL);
    if(lRetVal < 0)
        LOOP_FOREVER();
    //  create a user file
                FS_MODE_OPEN_CREATE(65536,
                          _FS_FILE_OPEN_FLAG_COMMIT|_FS_FILE_PUBLIC_WRITE|_FS_FILE_PUBLIC_READ),
                        &ulToken,
                        &lFileHandle);
    if(lRetVal < 0)
	  	UART_PRINT("File %s already exist.\n", USER_FILE_NAME);
        // File may already be created
    else
	if(lRetVal < 0)
        LOOP_FOREVER();
	if(ReadFileFromDevice(ulToken, lFileHandle) < 0)
			UART_PRINT("Read file fail\n\n");
	//lRetVal = sl_Stop(SL_STOP_TIMEOUT);
/*Push button interrupt handler*/
void pushButtonInterruptHandler2()
  event_msg msg;
	msg.event = PUSH_BUTTON_SW2_PRESSED;
  msg.hndl = NULL;
  // write message indicating exit from sending loop
  osi_MsgQWrite(&g_PBQueue,&msg,OSI_NO_WAIT);
	Button_IF_EnableInterrupt(SW2);
/*Task for setting wifi direct information flag*/
void WifiDirectFlagSetting(void *pvParameters)
	event_msg RecvQue;
	for(;;)
		osi_MsgQRead( &g_PBQueue, &RecvQue, OSI_WAIT_FOREVER);
		if(PUSH_BUTTON_SW2_PRESSED == RecvQue.event)
			if(WriteFileToDevice(&ulToken, &lFileHandle) < 0)
					LOOP_FOREVER();
			// Restart system
			MAP_PRCMHibernateIntervalSet(330);
			MAP_PRCMHibernateWakeupSourceEnable(PRCM_HIB_SLOW_CLK_CTR);
			MAP_PRCMHibernateEnter();
/*MqttClient task*/
void MqttClient(void *pvParameters)
	FileOperation();
  And print some log below.
CC3200 MQTT_Client Application
[WLAN EVENT] STA Connected to the AP: iTeam , BSSID: 6c:b0:ce:14:6d:bc
Create file: /usr/wificonfigfile.txt.
FileLen: [0]
AllocatedLen: [69192]
File token: [536999368]
File flags: [0]
Open file for read: /usr/wificonfigfile.txt.
Readbuffer length: -15
FileLen: [0]
File flags: [0]
Write file success
Token [0]
File handle [1210682119]
FileLen: [0]
File flags: [0]
Lex
