RTOS/CC3220SF-LAUNCHXL: No .CFG file within demo projects
Part Number: CC3220SF-LAUNCHXL
Other Parts Discussed in Thread: CC3220SF
Tool/software: TI-RTOS
Hi guys,
I'm used to having a .CFG file inside my TI RTOS projects. I imported the out of box project into my workspace and then saw that the .CFG file was missing. Obviously it is not used, instead there is c code for setting up stacksize, threads and so on inside main_tirtos.c. Is there any documentation on replacing the .CFG file through c code or how to use SYS/BIOS without a .CFG file?
Thanks in advance.
Markus
    In older SDK, the TIRTOS project was part of the example and now it has been to decided to separate the TIRTOS (which is common to few examples) into a separate one.
    As you can see, importing the example project should also import the TIRTOS project which has the .cfg file inside.
    Shlomi
  • Thanks, your post helped me. I looked into tirtos_builds_CC3220SF_LAUNCHXL_release_ccs, where I found README.html and release.cfg. the README.html led me to the SimpleLink MCU SDK User's Guide where I found all the information I needed.
