CCS/CC3200AUDBOOST: Using UDP to transfer audio
Part Number: CC3200AUDBOOST
I am using "wifi_audio_app" provided with SDK1.3.0.But I have only 1 board.I want to transfer audio data to PC using udp.My question is how to modify the demo to achieve it.
Any help is really appreciated.
Thanks.
Eason Zhong
    The Wifi Audio Demo is designed to work with two CC3200 Launch XL Boards and respective audio booster packs. 16 bit linear PCM audio is streamed between the devices over WiFi via UDP.
    To stream the audio to a mobile app or a PC, you would need to implement a receive/transmit and playback/record 16 bit linear PCM audio via UDP.
    Shlomi
