Other Parts Discussed in Thread: CC3220S
There is a file netwifi.c that is in the aws samples
./shadow_sample_CC3220S_LAUNCHXL_tirtos_ccs/netwifi.c
./shadow_sample_console_echo_CC3220S_LAUNCHXL_tirtos_ccs/netwifi.c
./subscribe_publish_sample_CC3220S_LAUNCHXL_tirtos_ccs/netwifi.c
It has a small bug in that wlanConnect() always uses SL_WLAN_SEC_TYPE_WPA instead of the SECURITY_TYPE setting from wificonfig.h, so for open networks it always fails until you track down the issue.
The code should be :
/* * ======== wlanConnect ======= * Secure connection parameters */ static int wlanConnect() { SlWlanSecParams_t secParams = {0}; int ret = 0; secParams.Key = (signed char *)SECURITY_KEY; secParams.KeyLen = strlen((const char *)secParams.Key); secParams.Type = SECURITY_TYPE; ret = sl_WlanConnect((signed char*)SSID, strlen((const char*)SSID), NULL, &secParams, NULL); return (ret); }
