CC3220: Android app SimpleLink Starter Pro will not build with the new version of Android Studio 3.0.1
Part Number: CC3220
I upgraded to the latest version of Android Studio 3.0.1
I downloaded the source code from TI, and then tried to build and got the following error:
Error:android-apt plugin is incompatible with the Android Gradle plugin.  Please use 'annotationProcessor' configuration instead.
I found this stackoverflow article which stated:
  The android-apt plugin has been deprecated.
  • Hi Nader,
    Thanks for bringing this to our attention. I'll have to check with our tools team about addressing this in our next release. I should have an answer by the end of the week.
    Ben M
  • Hi nader,
    Even though this will not be addressed until another official release is made, our tools lead found a solution for compiling based on the new Android Studio + new gradle. Note this has not been formally tested, but it should get you going -
    Please try the following:
    1. File:  starter_pro_android\SmartConfigBitBite\app\build.gradle  new content (many changes)
    apply plugin: 'com.android.application'
    //apply plugin: 'android-apt'
    android {
    //    signingConfigs {
    //       config {
    //            storeFile file(System.getenv("RELEASE_STORE_FILE"))
    //            storePassword System.getenv("RELEASE_STORE_PASSWORD")
    //            keyAlias System.getenv("RELEASE_KEY_ALIAS")
    //            keyPassword System.getenv("RELEASE_KEY_PASSWORD")
       compileSdkVersion 21
       buildToolsVersion '26.0.2'
       defaultConfig {
           applicationId "com.ti.smartconfig"
           minSdkVersion 14
           targetSdkVersion 21
           javaCompileOptions {
               annotationProcessorOptions {
                   arguments = ['resourcePackageName': android.defaultConfig.applicationId]
       buildTypes {
    //        release {
    //            minifyEnabled false
    //            proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.txt'
    //            signingConfig signingConfigs.config
    //            pseudoLocalesEnabled false
    dependencies {
       compile 'com.android.support:support-v4:21.0.3'
       annotationProcessor "org.androidannotations:androidannotations:4.3.1"
       compile 'org.androidannotations:androidannotations-api:4.3.1'
       compile 'fr.avianey.com.viewpagerindicator:library:2.4.1@aar'
       compile files('libs/android-logging-log4j-1.0.3.jar')
       compile files('libs/jmdns-3.4.2-r353-1.jar')
       compile files('libs/jsoup-1.8.1.jar')
       compile files('libs/log4j-1.2.17.jar')
       compile files('libs/smartconfiglib2.jar')
    2. File: starter_pro_android\SmartConfigBitBite\build.gradle
    Before:
      classpath 'com.neenbedankt.gradle.plugins:android-apt:1.4'
    After:
     //classpath 'com.neenbedankt.gradle.plugins:android-apt:1.4'
    3. File: starter_pro_android\SmartConfigBitBite\gradle.properties
    Add:
    android.enableAapt2=false
    Ben M
  • thanks, I gave it a try - however those changes seemed to have spawned errors in other areas, now I am getting the following error:
    C:\Users\nader\Desktop\android_textmewes-t1\android_textmewes-t1\app\build\intermediates\manifests\instant-run\debug\AndroidManifest.xml
    Error:(24) error: unknown element <action> found.
    Error:(24) unknown element <action> found.
    any solutions on this?
  • Hi Nader,
    You may want to run through the gradle plug-in migration here:
    https://developer.android.com/studio/build/gradle-plugin-3-0-0-migration.html
    Since this is not addressed in a formal release yet, you may have to take some additional steps to migrate. I recommend checking for a misplaced tag which could be causing an error as described in this discussion:
    https://stackoverflow.com/questions/46948498/android-studio-3-0-manifest-error-unknown-element-action-found
    Ben M
