Part Number: CC3100
I'm trying to get the HTTPS example going on my CC3100, using a EK_TM4C1294XL board.
The TI-RTOS version for Tiva-C is 2.16.00.08 and in that I'm using <ti/net/http/httpcli.h> v1.11.00.10:
After adding what I'm certain is the correct Digicert root ca as per instructions (for www.example.com:443), I'm still getting an error -102 when the call to HTTPCli_connect is made.
Here is the exact and only code I have changed in the example:
* USER STEP: Copy the lines in the root CA certificate between
* -----BEGIN CERTIFICATE-----
* -----END CERTIFICATE-----
uint8_t ca[] =
"MIIF8jCCBNqgAwIBAgIQDmTF+8I2reFLFyrrQceMsDANBgkqhkiG9w0BAQsFADBw\
MQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3\
d3cuZGlnaWNlcnQuY29tMS8wLQYDVQQDEyZEaWdpQ2VydCBTSEEyIEhpZ2ggQXNz\
dXJhbmNlIFNlcnZlciBDQTAeFw0xNTExMDMwMDAwMDBaFw0xODExMjgxMjAwMDBa\
MIGlMQswCQYDVQQGEwJVUzETMBEGA1UECBMKQ2FsaWZvcm5pYTEUMBIGA1UEBxML\
TG9zIEFuZ2VsZXMxPDA6BgNVBAoTM0ludGVybmV0IENvcnBvcmF0aW9uIGZvciBB\
c3NpZ25lZCBOYW1lcyBhbmQgTnVtYmVyczETMBEGA1UECxMKVGVjaG5vbG9neTEY\
MBYGA1UEAxMPd3d3LmV4YW1wbGUub3JnMIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8A\
MIIBCgKCAQEAs0CWL2FjPiXBl61lRfvvE0KzLJmG9LWAC3bcBjgsH6NiVVo2dt6u\
Xfzi5bTm7F3K7srfUBYkLO78mraM9qizrHoIeyofrV/n+pZZJauQsPjCPxMEJnRo\
D8Z4KpWKX0LyDu1SputoI4nlQ/htEhtiQnuoBfNZxF7WxcxGwEsZuS1KcXIkHl5V\
RJOreKFHTaXcB1qcZ/QRaBIv0yhxvK1yBTwWddT4cli6GfHcCe3xGMaSL328Fgs3\
jYrvG29PueB6VJi/tbbPu6qTfwp/H1brqdjh29U52Bhb0fJkM9DWxCP/Cattcc7a\
z8EXnCO+LK8vkhw/kAiJWPKx4RBvgy73nwIDAQABo4ICUDCCAkwwHwYDVR0jBBgw\
FoAUUWj/kK8CB3U8zNllZGKiErhZcjswHQYDVR0OBBYEFKZPYB4fLdHn8SOgKpUW\
5Oia6m5IMIGBBgNVHREEejB4gg93d3cuZXhhbXBsZS5vcmeCC2V4YW1wbGUuY29t\
ggtleGFtcGxlLmVkdYILZXhhbXBsZS5uZXSCC2V4YW1wbGUub3Jngg93d3cuZXhh\
bXBsZS5jb22CD3d3dy5leGFtcGxlLmVkdYIPd3d3LmV4YW1wbGUubmV0MA4GA1Ud\
DwEB/wQEAwIFoDAdBgNVHSUEFjAUBggrBgEFBQcDAQYIKwYBBQUHAwIwdQYDVR0f\
BG4wbDA0oDKgMIYuaHR0cDovL2NybDMuZGlnaWNlcnQuY29tL3NoYTItaGEtc2Vy\
dmVyLWc0LmNybDA0oDKgMIYuaHR0cDovL2NybDQuZGlnaWNlcnQuY29tL3NoYTIt\
aGEtc2VydmVyLWc0LmNybDBMBgNVHSAERTBDMDcGCWCGSAGG/WwBATAqMCgGCCsG\
AQUFBwIBFhxodHRwczovL3d3dy5kaWdpY2VydC5jb20vQ1BTMAgGBmeBDAECAjCB\
gwYIKwYBBQUHAQEEdzB1MCQGCCsGAQUFBzABhhhodHRwOi8vb2NzcC5kaWdpY2Vy\
dC5jb20wTQYIKwYBBQUHMAKGQWh0dHA6Ly9jYWNlcnRzLmRpZ2ljZXJ0LmNvbS9E\
aWdpQ2VydFNIQTJIaWdoQXNzdXJhbmNlU2VydmVyQ0EuY3J0MAwGA1UdEwEB/wQC\
MAAwDQYJKoZIhvcNAQELBQADggEBAISomhGn2L0LJn5SJHuyVZ3qMIlRCIdvqe0Q\
6ls+C8ctRwRO3UU3x8q8OH+2ahxlQmpzdC5al4XQzJLiLjiJ2Q1p+hub8MFiMmVP\
PZjb2tZm2ipWVuMRM+zgpRVM6nVJ9F3vFfUSHOb4/JsEIUvPY+d8/Krc+kPQwLvy\
ieqRbcuFjmqfyPmUv1U9QoI4TQikpw7TZU0zYZANP4C/gj4Ry48/znmUaRvy2kvI\
l7gRQ21qJTK5suoiYoYNo3J9T+pXPGU7Lydz/HwW+w0DpArtAaukI8aNX4ohFUKS\
wDSiIIWIWJiJGbEeIO0TIFwEVWTOnbNl/faPXpk5IRXicapqiII=";
uint32_t calen = sizeof(ca);
I haven't changed the sample code besides the ca root cert above, so the call I'm using is exactly HTTPCli_connect(&cli, (struct sockaddr *)&addr, 0, ¶ms);
My questions are as follows:
- How do I ensure the correct cipher is used? I need to use ECDHE-RSA-AES128-GCM-SHA256 as per the root ca.
- Should I be using TLS_Params_init as per the sample code, or HTTPCli_SecureParams like this post suggests?
- Can you think of any other reasons for this error and suggest a fix?
To show that I have done some due diligence, I can verify that the certificate I'm using is 100% correct using the following command:
openssl s_client -state -CAfile d2.pem -connect www.example.com:443
I've included to complete output below in case it helps.
Thanks in advance for your assistance!
Cheers
----------- output from open ssl -CAfile test --------------
CONNECTED(00000005)
SSL_connect:before/connect initialization
SSL_connect:unknown state
SSL_connect:SSLv3 read server hello A
depth=2 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert High Assurance EV Root CA
verify return:1
depth=1 C = US, O = DigiCert Inc, OU = www.digicert.com, CN = DigiCert SHA2 High Assurance Server CA
verify return:1
depth=0 C = US, ST = California, L = Los Angeles, O = Internet Corporation for Assigned Names and Numbers, OU = Technology, CN = www.example.org
verify return:1
SSL_connect:SSLv3 read server certificate A
SSL_connect:SSLv3 read server key exchange A
SSL_connect:SSLv3 read server done A
SSL_connect:SSLv3 write client key exchange A
SSL_connect:SSLv3 write change cipher spec A
SSL_connect:SSLv3 write finished A
SSL_connect:SSLv3 flush data
SSL_connect:SSLv3 read server session ticket A
SSL_connect:SSLv3 read finished A
Certificate chain
0 s:/C=US/ST=California/L=Los Angeles/O=Internet Corporation for Assigned Names and Numbers/OU=Technology/CN=www.example.org
i:/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert SHA2 High Assurance Server CA
1 s:/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert SHA2 High Assurance Server CA
i:/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert High Assurance EV Root CA
Server certificate
subject=/C=US/ST=California/L=Los Angeles/O=Internet Corporation for Assigned Names and Numbers/OU=Technology/CN=www.example.org
issuer=/C=US/O=DigiCert Inc/OU=www.digicert.com/CN=DigiCert SHA2 High Assurance Server CA
No client certificate CA names sent
SSL handshake has read 3388 bytes and written 444 bytes
New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES128-GCM-SHA256
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES128-GCM-SHA256
Session-ID: D518BE928503113335A6EFB9EB0CC9FC4C81EAFC769D69D2ACBE5970D544509F
Session-ID-ctx:
Master-Key: A05DA123D88A1E45268B7DF6BB70697A1F8E412D8F55244CF276807E528A9D119A348E5CC27F64DE5197C4CC233728F4
TLS session ticket lifetime hint: 7200 (seconds)
TLS session ticket:
0000 - 9a e1 0e d6 ff cc 59 84-41 fe 9c 56 c2 95 12 2a ......Y.A..V...*
0010 - 1b 52 10 03 1e eb 39 d4-cf 79 94 3f 07 d4 7c 74 .R....9..y.?..|t
0020 - 35 98 c9 a0 6b a2 26 95-79 d8 f0 68 f3 4d fe c7 5...k.&.y..h.M..
0030 - ee 1e 9e 70 ce 70 af 25-c9 0c fa dd c6 4b 34 48 ...p.p.%.....K4H
0040 - 9b de 35 99 32 71 59 5e-6e 94 be 43 0a e5 df e9 ..5.2qY^n..C....
0050 - 0a 78 a5 37 a0 2f 02 d3-7d 0d bd 68 13 d9 cb 03 .x.7./..}..h....
0060 - 51 41 65 98 76 ed 1c 08-f8 bf 95 2f 41 66 2f 95 QAe.v....../Af/.
0070 - 3a e9 34 9c d8 ac f6 ad-ba c2 bc 03 45 4e 5d f6 :.4.........EN].
0080 - 24 de 98 1a 14 36 e1 b6-d7 a9 9a b1 f6 aa 1e b5 $....6..........
0090 - 94 5e 7e 40 3b 34 d9 86-03 d8 b6 50 f7 2a 39 35 .^~@;4.....P.*95
Start Time: 1517828428
Timeout : 300 (sec)
Verify return code: 0 (ok)
read:errno=0
