Other Parts Discussed in Thread: CC3220SF
In the CC3220SF_LAUNCHXL.c we can define the Paking state of GPIO during LPDS:
/* * =============================== Power =============================== */ /* * This table defines the parking state to be set for each parkable pin * during LPDS. (Device pins must be parked during LPDS to achieve maximum * power savings.) If the pin should be left unparked, specify the state * PowerCC32XX_DONT_PARK. For example, for a UART TX pin, the device * will automatically park the pin in a high state during transition to LPDS, * so the Power Manager does not need to explictly park the pin. So the * corresponding entries in this table should indicate PowerCC32XX_DONT_PARK. */ PowerCC32XX_ParkInfo parkInfo[] = { /* PIN PARK STATE PIN ALIAS (FUNCTION) ----------------- ------------------------------ -------------------- */ {PowerCC32XX_PIN01, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO10 */ {PowerCC32XX_PIN02, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO11 */ {PowerCC32XX_PIN03, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO12 */ {PowerCC32XX_PIN04, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO13 */ {PowerCC32XX_PIN05, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO14 */ {PowerCC32XX_PIN06, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO15 */ {PowerCC32XX_PIN07, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO16 */ {PowerCC32XX_PIN08, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO17 */ {PowerCC32XX_PIN13, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* FLASH_SPI_DIN */ {PowerCC32XX_PIN15, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO22 */ {PowerCC32XX_PIN16, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* TDI (JTAG DEBUG) */ {PowerCC32XX_PIN17, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* TDO (JTAG DEBUG) */ {PowerCC32XX_PIN19, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* TCK (JTAG DEBUG) */ {PowerCC32XX_PIN20, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* TMS (JTAG DEBUG) */ {PowerCC32XX_PIN18, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO28 */ {PowerCC32XX_PIN21, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* SOP2 */ {PowerCC32XX_PIN29, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* ANTSEL1 */ {PowerCC32XX_PIN30, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* ANTSEL2 */ {PowerCC32XX_PIN45, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* DCDC_ANA2_SW_P */ {PowerCC32XX_PIN50, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO0 */ {PowerCC32XX_PIN52, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* RTC_XTAL_N */ {PowerCC32XX_PIN53, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO30 */ {PowerCC32XX_PIN55, PowerCC32XX_WEAK_PULL_UP_STD}, /* GPIO1 (XDS_UART_RX) */ {PowerCC32XX_PIN57, PowerCC32XX_WEAK_PULL_UP_STD}, /* GPIO2 (XDS_UART_TX) */ {PowerCC32XX_PIN58, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO3 */ {PowerCC32XX_PIN59, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO4 */ {PowerCC32XX_PIN60, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO5 */ {PowerCC32XX_PIN61, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO6 */ {PowerCC32XX_PIN62, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO7 */ {PowerCC32XX_PIN63, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO8 */ {PowerCC32XX_PIN64, PowerCC32XX_WEAK_PULL_DOWN_STD}, /* GPIO9 */ };
Where I can find the detailed explanation of this feature in the manuals?
I tried to search "park" in the following documents with no results:
- SWAS035A
- SWRU465
- SWRU455C
- SPMU298D
