Linux/PROCESSOR-SDK-AM437X: MMC2 not detected
Part Number: PROCESSOR-SDK-AM437X
Other Parts Discussed in Thread: WL1835
Tool/software: Linux
Hi all,
I am working on latest rt-linux SDK from TI (ti-processor-sdk-linux-rt-am437x-evm-04.02.00.09). I have custom board based on AM437x-gp-evm where  wifi-module  is connected on mmc2.
I have done the pin-muxing as "mmc3_pins_default " and phandle as &mmc3, according to ti wlink wl18xx integration (http://processors.wiki.ti.com/index.php/WL18xx_Platform_Integration_Guide )  all the changesare proper but i am not able to get the mmc2 device up.
I am getting unable to parse cd-gpios and wp-gpios of the node and  RX DMA channel request failed :
[    1.334203] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334208] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334213] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    1.334218] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed
[    1.334225] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
[    1.334229] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    1.334233] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334237] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334241] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    1.334245] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed
[    1.334396] omap_hsmmc 47810000.mmc: RX DMA channel request failed
Here are the dts file and dmesg log of the board:
DTS File:
 * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
/* AM437x GP EVM */
/dts-v1/;
#include "am4372.dtsi"
#include <dt-bindings/pinctrl/am43xx.h>
#include <dt-bindings/pwm/pwm.h>
#include <dt-bindings/gpio/gpio.h>
	model = "TI AM437x GP EVM";
	compatible = "ti,am437x-gp-evm","ti,am4372","ti,am43";
	aliases {
		display0 = &lcd0;
		serial1 = &uart1;
	chosen {
		stdout-path = &uart0;
	evm_v3_3d: fixedregulator-v3_3d {
		compatible = "regulator-fixed";
		regulator-name = "evm_v3_3d";
		regulator-min-microvolt = <3300000>;
		regulator-max-microvolt = <3300000>;
		enable-active-high;
	vtt_fixed: fixedregulator-vtt {
		regulator-name = "vtt_fixed";
		regulator-min-microvolt = <1500000>;
		regulator-max-microvolt = <1500000>;
		regulator-always-on;
		regulator-boot-on;
		enable-active-high;
		gpio = <&gpio5 7 GPIO_ACTIVE_HIGH>;
	wlan_en_reg: fixedregulator-mmcwl {
		regulator-name = "wlan_en_reg";
		regulator-min-microvolt = <1800000>;
		regulator-max-microvolt = <1800000>;
		gpio = <&gpio5 10 GPIO_ACTIVE_HIGH>;
		startup-delay-us = <70000>;
		enable-active-high;
        kim {
               compatible = "kim";
               nshutdown_gpio = <166>; /* Bank5, pin6 */
               dev_name = "/dev/ttyS3";
               flow_cntrl = <1>;
               baud_rate = <3000000>;
       btwilink {
               compatible = "btwilink";
	lcd_bl: backlight {
		compatible = "pwm-backlight";
		pwms = <&ehrpwm1 0 50000 PWM_POLARITY_INVERTED>;
		brightness-levels = <0 51 53 56 62 75 101 152 255>;
		default-brightness-level = <8>;
	lcd0: display {
		compatible = "osddisplays,osd057T0559-34ts", "panel-dpi";
		label = "lcd";
		backlight = <&lcd_bl>;
		panel-timing {
			clock-frequency = <33000000>;
			hactive = <800>;
			vactive = <480>;
			hfront-porch = <210>;
			hback-porch = <16>;
			hsync-len = <30>;
			vback-porch = <10>;
			vfront-porch = <22>;
			vsync-len = <13>;
			hsync-active = <0>;
			vsync-active = <0>;
			de-active = <1>;
			pixelclk-active = <1>;
		port {
			lcd_in: endpoint {
				remote-endpoint = <&dpi_out>;
	/* fixed 12MHz oscillator */
	refclk: oscillator {
		#clock-cells = <0>;
		compatible = "fixed-clock";
		clock-frequency = <12000000>;
	/* fixed 32k external oscillator clock */
	clk_32k_rtc: clk_32k_rtc {
		#clock-cells = <0>;
		clock-frequency = <32768>;
	leds {
		compatible = "gpio-leds";
		pinctrl-names = "default";
		pinctrl-0 = <&leds_pins_default>;
		pinctrl-1 = <&leds_pins_sleep>;
		led@0 {
			label = "am437x-gp-evm:red:heartbeat";
			gpios = <&gpio4 9 GPIO_ACTIVE_HIGH>;    /* Bank 4, pin 9 */
			linux,default-trigger = "none";
			default-state = "off";
		led@1 {
			label = "am437x-gp-evm:green:mmc1";
			gpios = <&gpio4 12 GPIO_ACTIVE_HIGH>;   /* Bank 4, pin 12 */
		led@2 {
			label = "am437x-gp-evm:blue:cpu0";
			gpios = <&gpio4 13 GPIO_ACTIVE_HIGH>;   /* Bank 4, pin 13 */
	sound0: sound0 {
		compatible = "simple-audio-card";
		simple-audio-card,name = "AM437x-GP-EVM";
		simple-audio-card,widgets =
			"Microphone", "Microphone Jack",
			"Headphone", "Headphone Jack",
			"Line", "Line In";
		simple-audio-card,routing =
			"Mono Out",             "MONO_LOUT",
			"LINE1L",		"Mic Bias";
		simple-audio-card,format = "dsp_b";
		simple-audio-card,bitclock-master = <&sound0_master>;
		simple-audio-card,frame-master = <&sound0_master>;
		simple-audio-card,bitclock-inversion;
		simple-audio-card,cpu {
			sound-dai = <&mcasp1>;
			system-clock-frequency = <12000000>;
		sound0_master: simple-audio-card,codec {
			sound-dai = <&tlv320aic3106>;
	audio_mstrclk: mclk_osc {
		#clock-cells = <0>;
&am43xx_pinmux {
	pinctrl-names = "default", "sleep";
	pinctrl-0 = <&clkout2_pin  &gpio_pins &ddr3_vtt_toggle_default &unused_pins &debugss_pins>;
	ddr3_vtt_toggle_default: ddr_vtt_toggle_default {
		pinctrl-single,pins = <
			AM4372_IOPAD(0xa68, DS0_PULL_UP_DOWN_EN | PIN_OUTPUT_PULLUP | DS0_FORCE_OFF_MODE | MUX_MODE7) /* .gpio3_23 */
	gpio_pins: gpio_pins {
			AM4372_IOPAD(0x944, PIN_INPUT_PULLUP | MUX_MODE7)            /* (A16) rmii1_ref_clk.gpio0_29 */
			AM4372_IOPAD(0x9cc, PIN_OUTPUT_PULLUP | MUX_MODE6)         /* Backlight.(gpio4_7)*/
			AM4372_IOPAD(0xa54, PIN_OUTPUT_PULLDOWN | MUX_MODE7)         /* spi4_d0.gpio5_5 */
			AM4372_IOPAD(0xa78, PIN_OUTPUT_PULLDOWN | MUX_MODE7)         /* (H20) clkreq.gpio0_24 */
	clkout2_pin: clkout_pin {
			AM4372_IOPAD(0xa74, PIN_OUTPUT_PULLUP | MUX_MODE3)	/* xdma_event_intr1.gpio5_6 CLKOUT2 */
	leds_pins_default: led_pins_default {
			AM4372_IOPAD(0x9d4, PIN_OUTPUT | MUX_MODE7)  /* (T22) spi0_d0.gpio0_3 */
			AM4372_IOPAD(0x9e0, PIN_OUTPUT | MUX_MODE7)  /* (AC25) cam1_field.gpio4_12 */
			AM4372_IOPAD(0x9e4, PIN_OUTPUT | MUX_MODE7)  /* (AB25) cam1_wen.gpio4_13 */
        leds_pins_sleep: led_pins_sleep {
                        AM4372_IOPAD(0x9d4, PIN_INPUT_PULLDOWN | MUX_MODE7)  /* (T22) spi0_d0.gpio0_3 */
                        AM4372_IOPAD(0x9e0, PIN_INPUT_PULLDOWN | MUX_MODE7)  /* (AC25) cam1_field.gpio4_12 */
                        AM4372_IOPAD(0x9e4, PIN_INPUT_PULLDOWN | MUX_MODE7)  /* (AB25) cam1_wen.gpio4_13 */
	i2c0_pins: i2c0_pins {
			AM4372_IOPAD(0x988, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)  /* i2c0_sda.i2c0_sda */
			AM4372_IOPAD(0x98c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)  /* i2c0_scl.i2c0_scl */
	i2c1_pins: i2c1_pins {
			AM4372_IOPAD(0x910, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* (B13) mii1_rx_er.I2C1_SCL */
			AM4372_IOPAD(0x90c, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE3)  /* (B14) mii1_crs.I2C1_SDA */
	mmc1_pins: pinmux_mmc1_pins {
			AM4372_IOPAD(0x900, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */
			AM4372_IOPAD(0x904, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */
			AM4372_IOPAD(0x8f0, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */
			AM4372_IOPAD(0x8f4, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */
			AM4372_IOPAD(0x8f8, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */
			AM4372_IOPAD(0x8fc, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */
			AM4372_IOPAD(0x960, PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */
	ehrpwm1_pins_default: ehrpwm1_pins_default {
			AM4372_IOPAD(0x9dc, PIN_OUTPUT | MUX_MODE6 ) /* (AE21) cam1_pclk.ehrpwm1A */
        ehrpwm1_pins_sleep: ehrpwm1_pins_sleep {
                        AM4372_IOPAD(0x9dc, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (AE21) cam1_pclk.ehrpwm1A */
	pixcir_ts_pins: pixcir_ts_pins {
			AM4372_IOPAD(0xa70, PIN_INPUT_PULLUP | MUX_MODE7)  /* gpio0_19 */
	cpsw_default: cpsw_default {
			/* Slave 1 */
			AM4372_IOPAD(0x914, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txen.rgmii1_txen */
			AM4372_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxdv.rgmii1_rxctl */
			AM4372_IOPAD(0x91c, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd1.rgmii1_txd3 */
			AM4372_IOPAD(0x920, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd0.rgmii1_txd2 */
			AM4372_IOPAD(0x924, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd1.rgmii1_txd1 */
			AM4372_IOPAD(0x928, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txd0.rgmii1_txd0 */
			AM4372_IOPAD(0x92c, PIN_OUTPUT_PULLDOWN | MUX_MODE2)	/* mii1_txclk.rmii1_tclk */
			AM4372_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxclk.rmii1_rclk */
			AM4372_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd1.rgmii1_rxd3 */
			AM4372_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd0.rgmii1_rxd2 */
			AM4372_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd1.rgmii1_rxd1 */
			AM4372_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE2)	/* mii1_rxd0.rgmii1_rxd0 */
			/* Slave 2 MII mode */
                       AM4372_IOPAD(0x878, PIN_INPUT | MUX_MODE1) /* (A3) gpmc_be1n.gmii2_col */
                       AM4372_IOPAD(0x870, PIN_INPUT | MUX_MODE1) /* (A2) gpmc_wait0.gmii2_crs */
                       AM4372_IOPAD(0x874, PIN_INPUT | MUX_MODE1) /* (B3) gpmc_wpn.gmii2_rxer */
                       AM4372_IOPAD(0x840, PIN_OUTPUT | MUX_MODE1) /* (C3) gpmc_a0.gmii2_txen */
                       AM4372_IOPAD(0x844, PIN_INPUT | MUX_MODE1) /* (C5) gpmc_a1.gmii2_rxdv */
                       AM4372_IOPAD(0x858, PIN_INPUT | MUX_MODE1) /* (E8) gpmc_a6.gmii2_txclk */
                       AM4372_IOPAD(0x85c, PIN_INPUT | MUX_MODE1) /* (F6) gpmc_a7.gmii2_rxclk */
                       AM4372_IOPAD(0x854, PIN_OUTPUT | MUX_MODE1) /* (E7) gpmc_a5.gmii2_txd0 */
                       AM4372_IOPAD(0x850, PIN_OUTPUT | MUX_MODE1) /* (D7) gpmc_a4.gmii2_txd1 */
                       AM4372_IOPAD(0x84c, PIN_OUTPUT | MUX_MODE1) /* (A4) gpmc_a3.gmii2_txd2 */
                       AM4372_IOPAD(0x848, PIN_OUTPUT | MUX_MODE1) /* (C6) gpmc_a2.gmii2_txd3 */
                       AM4372_IOPAD(0x86c, PIN_INPUT | MUX_MODE1)  /* (D8) gpmc_a11.gmii2_rxd0 */
                       AM4372_IOPAD(0x868, PIN_INPUT | MUX_MODE1) /* (G8) gpmc_a10.gmii2_rxd1 */
                       AM4372_IOPAD(0x864, PIN_INPUT | MUX_MODE1) /* (B4) gpmc_a9.gmii2_rxd2 */
                       AM4372_IOPAD(0x860, PIN_INPUT | MUX_MODE1 ) /* (F7) gpmc_a8.gmii2_rxd3 */
	cpsw_sleep: cpsw_sleep {
			/* Slave 1 reset value */
			AM4372_IOPAD(0x914, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x918, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x91c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x920, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x924, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x928, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x92c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x930, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x934, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x938, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x93c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x940, PIN_INPUT_PULLDOWN | MUX_MODE7)
                       AM4372_IOPAD(0x878, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A3) gpmc_be1n.gmii2_col */
                       AM4372_IOPAD(0x870, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A2) gpmc_wait0.gmii2_crs */
                       AM4372_IOPAD(0x874, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (B3) gpmc_wpn.gmii2_rxer */
                       AM4372_IOPAD(0x840, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (C3) gpmc_a0.gmii2_txen */
                       AM4372_IOPAD(0x844, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (C5) gpmc_a1.gmii2_rxdv */
                       AM4372_IOPAD(0x858, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (E8) gpmc_a6.gmii2_txclk */
                       AM4372_IOPAD(0x85c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (F6) gpmc_a7.gmii2_rxclk */
                       AM4372_IOPAD(0x854, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (E7) gpmc_a5.gmii2_txd0 */
                       AM4372_IOPAD(0x850, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (D7) gpmc_a4.gmii2_txd1 */
                       AM4372_IOPAD(0x84c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (A4) gpmc_a3.gmii2_txd2 */
                       AM4372_IOPAD(0x848, PIN_INPUT_PULLDOWN | MUX_MODE7) /* (C6) gpmc_a2.gmii2_txd3 */
                       AM4372_IOPAD(0x86c, PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* (D8) gpmc_a11.gmii2_rxd0 */
                       AM4372_IOPAD(0x868, PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* (G8) gpmc_a10.gmii2_rxd1 */
                       AM4372_IOPAD(0x864, PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* (B4) gpmc_a9.gmii2_rxd2 */
                       AM4372_IOPAD(0x860, PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* (F7) gpmc_a8.gmii2_rxd3 */
	davinci_mdio_default: davinci_mdio_default {
			/* MDIO */
			AM4372_IOPAD(0x948, PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0)	/* mdio_data.mdio_data */
			AM4372_IOPAD(0x94c, PIN_OUTPUT_PULLUP | MUX_MODE0)			/* mdio_clk.mdio_clk */
	davinci_mdio_sleep: davinci_mdio_sleep {
			/* MDIO reset value */
			AM4372_IOPAD(0x948, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x94c, PIN_INPUT_PULLDOWN | MUX_MODE7)
	davinci_mdio1_default: davinci_mdio1_default {
			/* MDIO1 */
			AM4372_IOPAD(0x88c, PIN_OUTPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE5 ) /* (A12) gpmc_clk.pr1_mdio_mdclk */
			AM4372_IOPAD(0x888, PIN_INPUT_PULLUP | MUX_MODE5 ) /* (B12) gpmc_csn3.pr1_mdio_data */
	davinci_mdio1_sleep: davinci_mdio1_sleep {
			/* MDIO1 reset value */
			AM4372_IOPAD(0x88C, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x888, PIN_INPUT_PULLDOWN | MUX_MODE7)
	dss_pins: dss_pins {
			AM4372_IOPAD(0x820, PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 8 -> DSS DATA 23 */
			AM4372_IOPAD(0x824, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x828, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x82c, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x830, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x834, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x838, PIN_OUTPUT_PULLUP | MUX_MODE1)
			AM4372_IOPAD(0x83c, PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 15 -> DSS DATA 16 */
			AM4372_IOPAD(0x8a0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 0 */
			AM4372_IOPAD(0x8a4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8a8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8ac, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8b0, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8b4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8b8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8bc, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8c0, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8c4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8c8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8cc, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8d0, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8d4, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8d8, PIN_OUTPUT_PULLUP | MUX_MODE0)
			AM4372_IOPAD(0x8dc, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 15 */
			AM4372_IOPAD(0x8e0, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS VSYNC */
			AM4372_IOPAD(0x8e4, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS HSYNC */
			AM4372_IOPAD(0x8e8, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS PCLK */
			AM4372_IOPAD(0x8ec, PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS AC BIAS EN */
	display_mux_pins: display_mux_pins {
			/* GPIO 5_8 to select LCD / HDMI */
			AM4372_IOPAD(0xa38, PIN_OUTPUT_PULLUP | MUX_MODE7)
	vpfe0_pins_default: vpfe0_pins_default {
			AM4372_IOPAD(0x9b0, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_hd mode 0*/
			AM4372_IOPAD(0x9b4, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_vd mode 0*/
			AM4372_IOPAD(0x9c0, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_pclk mode 0*/
			AM4372_IOPAD(0x9c4, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data8 mode 0*/
			AM4372_IOPAD(0x9c8, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data9 mode 0*/
			AM4372_IOPAD(0xa08, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data0 mode 0*/
			AM4372_IOPAD(0xa0c, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data1 mode 0*/
			AM4372_IOPAD(0xa10, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data2 mode 0*/
			AM4372_IOPAD(0xa14, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data3 mode 0*/
			AM4372_IOPAD(0xa18, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data4 mode 0*/
			AM4372_IOPAD(0xa1c, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data5 mode 0*/
			AM4372_IOPAD(0xa20, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data6 mode 0*/
			AM4372_IOPAD(0xa24, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam0_data7 mode 0*/
	vpfe0_pins_sleep: vpfe0_pins_sleep {
			AM4372_IOPAD(0x9b0, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_hd mode 0*/
			AM4372_IOPAD(0x9b4, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_vd mode 0*/
			AM4372_IOPAD(0x9c0, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_pclk mode 0*/
			AM4372_IOPAD(0x9c4, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data8 mode 0*/
			AM4372_IOPAD(0x9c8, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data9 mode 0*/
			AM4372_IOPAD(0xa08, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data0 mode 0*/
			AM4372_IOPAD(0xa0c, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data1 mode 0*/
			AM4372_IOPAD(0xa10, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data2 mode 0*/
			AM4372_IOPAD(0xa14, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data3 mode 0*/
			AM4372_IOPAD(0xa18, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data4 mode 0*/
			AM4372_IOPAD(0xa1c, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data5 mode 0*/
			AM4372_IOPAD(0xa20, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data6 mode 0*/
			AM4372_IOPAD(0xa24, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam0_data7 mode 0*/
	vpfe1_pins_default: vpfe1_pins_default {
			AM4372_IOPAD(0x9cc, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data9 mode 0*/
			AM4372_IOPAD(0x9d0, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data8 mode 0*/
			AM4372_IOPAD(0x9d4, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_hd mode 0*/
			AM4372_IOPAD(0x9d8, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_vd mode 0*/
			AM4372_IOPAD(0x9dC, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_pclk mode 0*/
			AM4372_IOPAD(0x9e8, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data0 mode 0*/
			AM4372_IOPAD(0x9ec, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data1 mode 0*/
			AM4372_IOPAD(0x9f0, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data2 mode 0*/
			AM4372_IOPAD(0x9f4, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data3 mode 0*/
			AM4372_IOPAD(0x9f8, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data4 mode 0*/
			AM4372_IOPAD(0x9fc, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data5 mode 0*/
			AM4372_IOPAD(0xa00, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data6 mode 0*/
			AM4372_IOPAD(0xa04, PIN_INPUT_PULLUP | MUX_MODE0)  /* cam1_data7 mode 0*/
	vpfe1_pins_sleep: vpfe1_pins_sleep {
			AM4372_IOPAD(0x9cc, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data9 mode 0*/
			AM4372_IOPAD(0x9d0, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data8 mode 0*/
			AM4372_IOPAD(0x9d4, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_hd mode 0*/
			AM4372_IOPAD(0x9d8, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_vd mode 0*/
			AM4372_IOPAD(0x9dc, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_pclk mode 0*/
			AM4372_IOPAD(0x9e8, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data0 mode 0*/
			AM4372_IOPAD(0x9ec, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data1 mode 0*/
			AM4372_IOPAD(0x9f0, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data2 mode 0*/
			AM4372_IOPAD(0x9f4, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data3 mode 0*/
			AM4372_IOPAD(0x9f8, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data4 mode 0*/
			AM4372_IOPAD(0x9fc, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data5 mode 0*/
			AM4372_IOPAD(0xa00, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data6 mode 0*/
			AM4372_IOPAD(0xa04, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)  /* cam1_data7 mode 0*/
	mmc3_pins_default: pinmux_mmc3_pins_default {
			AM4372_IOPAD(0x9f0, PIN_INPUT_PULLUP | MUX_MODE3)      /* (AD21) cam1_data2.mmc2_clk */
			AM4372_IOPAD(0x9f4, PIN_INPUT_PULLUP | MUX_MODE3)      /* (AE22) cam1_data3.mmc2_cmd */
			AM4372_IOPAD(0x9f8, PIN_INPUT_PULLUP | MUX_MODE3)      /* (AD22) cam1_data4.mmc2_dat0 */
			AM4372_IOPAD(0x9fc, PIN_INPUT_PULLUP | MUX_MODE3)      /* (AE23) cam1_data5.mmc2_dat1 */
			AM4372_IOPAD(0xa00, PIN_INPUT_PULLUP | MUX_MODE3)      /* (AD23) cam1_data6.mmc2_dat2 */
			AM4372_IOPAD(0xa04, PIN_INPUT_PULLUP | MUX_MODE3)      /* (AE24) cam1_data7.mmc2_dat3 */
	mmc3_pins_sleep: pinmux_mmc3_pins_sleep {
			AM4372_IOPAD(0x9f0, PIN_INPUT_PULLDOWN | MUX_MODE7)	/* .mmc2_clk */
			AM4372_IOPAD(0x9f4, PIN_INPUT | PULL_DISABLE | MUX_MODE7)	/* .mmc2_cmd */
			AM4372_IOPAD(0x9f8, PIN_INPUT | PULL_DISABLE | MUX_MODE7)	/* .mmc2_dat0 */
			AM4372_IOPAD(0x9fc, PIN_INPUT | PULL_DISABLE | MUX_MODE7)	/* .mmc2_dat1 */
			AM4372_IOPAD(0xa00, PIN_INPUT | PULL_DISABLE | MUX_MODE7)	/* .mmc2_dat2 */
			AM4372_IOPAD(0xa04, PIN_INPUT | PULL_DISABLE | MUX_MODE7)	/* .mmc2_dat3 */
	wlan_pins_default: pinmux_wlan_pins_default {
			AM4372_IOPAD(0xa40, PIN_OUTPUT_PULLUP | MUX_MODE7)		/* gpmc_a4.gpio1_20 WL_EN */
                        AM4372_IOPAD(0xa44, PIN_OUTPUT_PULLDOWN | MUX_MODE7)         /* gpio5_11.gpio5_11 WL_TXR_EN */
			AM4372_IOPAD(0xa58, PIN_OUTPUT_PULLDOWN | MUX_MODE7)		/* gpmc_a0.gpio1_16 BT_EN*/
	                AM4372_IOPAD(0xa50, PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7)   /* spi4_sclk.gpio5_4 WL_IRQ*/
	wlan_pins_sleep: pinmux_wlan_pins_sleep {
			AM4372_IOPAD(0xa40, PIN_OUTPUT_PULLDOWN | MUX_MODE7)		/* gpmc_a4.gpio1_20 WL_EN */
			AM4372_IOPAD(0xa58, PIN_OUTPUT_PULLUP | MUX_MODE7)		/* gpmc_a0.gpio1_16 BT_EN*/
	uart3_pins: uart3_pins {
			AM4372_IOPAD(0xa28, PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0)	/* (H25) uart3_rxd.uart3_rxd */
			AM4372_IOPAD(0xa2c, PIN_INPUT | PULL_DISABLE | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* (H24) uart3_txd */
			AM4372_IOPAD(0xa30, PIN_INPUT | MUX_MODE0)	/* uart3_ctsn.uart3_ctsn */
			AM4372_IOPAD(0xa34, PIN_INPUT | MUX_MODE0) /* uart3_rtsn.uart3_rtsn */
	mcasp1_pins: mcasp1_pins {
			AM4372_IOPAD( 0x9a0, PIN_INPUT_PULLDOWN | MUX_MODE3)  /* (L23) mcasp0_aclkr.mcasp1_aclkx */
			AM4372_IOPAD( 0x9a4, PIN_INPUT_PULLDOWN | MUX_MODE3)  /* (K23) mcasp0_fsr.mcasp1_fsx */
			AM4372_IOPAD( 0x9a8, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* (M25) mcasp0_axr1.mcasp1_axr0 */
			AM4372_IOPAD( 0x9ac, PIN_INPUT_PULLDOWN | MUX_MODE3)  /* (L24) mcasp0_ahclkx.mcasp1_axr1 */
	mcasp1_sleep_pins: mcasp1_sleep_pins {
			AM4372_IOPAD(0x9a0, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x9a4, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x9a8, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0x9ac, PIN_INPUT_PULLDOWN | MUX_MODE7)
	emmc_pins_default: emmc_pins_default {
			AM4372_IOPAD(0x800, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */
			AM4372_IOPAD(0x804, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */
			AM4372_IOPAD(0x808, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */
			AM4372_IOPAD(0x80c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */
			AM4372_IOPAD(0x810, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */
			AM4372_IOPAD(0x814, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */
			AM4372_IOPAD(0x818, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */
			AM4372_IOPAD(0x81c, PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */
			AM4372_IOPAD(0x880, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */
			AM4372_IOPAD(0x884, PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */
	emmc_pins_sleep: emmc_pins_sleep {
			AM4372_IOPAD(0x800, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpio1_0 */
			AM4372_IOPAD(0x804, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpio1_1 */
			AM4372_IOPAD(0x808, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpio1_2 */
			AM4372_IOPAD(0x80c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpio1_3 */
			AM4372_IOPAD(0x810, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpio1_4 */
			AM4372_IOPAD(0x814, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpio1_5 */
			AM4372_IOPAD(0x818, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpio1_6 */
			AM4372_IOPAD(0x81c, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpio1_7 */
			AM4372_IOPAD(0x880, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn1.gpio1_30 */
			AM4372_IOPAD(0x884, PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn2.gpio1_31 */
	unused_pins: unused_pins {
			AM4372_IOPAD(0xa3c, PIN_INPUT | PULL_DISABLE | MUX_MODE7)
			AM4372_IOPAD(0xa48, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa60, PIN_INPUT | PULL_DISABLE | MUX_MODE7)
			AM4372_IOPAD(0xa68, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xa7c, PIN_INPUT | PULL_DISABLE)
			AM4372_IOPAD(0xac8, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xad4, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xad8, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xadc, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xae0, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xae4, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xae8, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaec, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaf0, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaf4, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xaf8, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xafc, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb00, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb04, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb08, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb0c, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb10, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb14, PIN_INPUT_PULLDOWN | MUX_MODE7)
			AM4372_IOPAD(0xb18, PIN_INPUT_PULLDOWN | MUX_MODE7)
	debugss_pins: pinmux_debugss_pins {
			AM4372_IOPAD(0xa90, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xa94, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xa98, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xa9c, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xaa0, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xaa4, PIN_INPUT_PULLDOWN)
			AM4372_IOPAD(0xaa8, PIN_INPUT_PULLDOWN)
	uart0_pins_default: uart0_pins_default {
			AM4372_IOPAD(0x970, PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_rxd.uart0_rxd */
			AM4372_IOPAD(0x974, PIN_INPUT | PULL_DISABLE | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
	uart0_pins_sleep: uart0_pins_sleep {
			AM4372_IOPAD(0x974, PIN_INPUT_PULLDOWN | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */
	uart1_pins_default: uart1_pins_default {
			AM4372_IOPAD(0x9e8, PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE1 ) /* (AB20) cam1_data0.uart1_rxd */
			AM4372_IOPAD(   0x9ec, PIN_INPUT | PULL_DISABLE | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE1 ) /* (AC21) cam1_data1.uart1_txd */
	uart1_pins_sleep: uart1_pins_sleep {
			AM4372_IOPAD(0x9e8, PIN_INPUT_PULLUP | MUX_MODE7)    /* (AB20) cam1_data0.uart1_rxd */
			AM4372_IOPAD(0x9ec, PIN_INPUT_PULLUP | MUX_MODE7)    /* (AC21) cam1_data1.uart1_txd */
	uart_pruss1_pins_default: uart_pruss1_pins_default {
			AM4372_IOPAD(0x980, PIN_INPUT | MUX_MODE5 ) /* (K21) uart1_rxd.pr1_uart0_rxd */
			AM4372_IOPAD(0x984, PIN_OUTPUT | MUX_MODE5 ) /* (L21) uart1_txd.pr1_uart0_txd */
	uart_pruss1_pins_sleep: uart_pruss1_pins_sleep {
			AM4372_IOPAD(0x980, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (K21) uart1_rxd.pr1_uart0_rxd */
			AM4372_IOPAD(0x984, PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (L21) uart1_txd.pr1_uart0_txd */
	rtc_pins_default: rtc_pins_default {
			AM4372_IOPAD(0xab4, PIN_INPUT | MUX_MODE0 )         /* (AE6) RTC_PWRONRSTn.RTC_PORz */
			AM4372_IOPAD(0xab8, PIN_OUTPUT | MUX_MODE0 )        /* (AE3) RTC_WAKEUP.RTC_WAKEUP */
			AM4372_IOPAD(0xabc, PIN_INPUT | MUX_MODE0 )         /* (AD6) RTC_PMIC_EN.RTC_PMIC_EN */
	rtc_pins_sleep: rtc_pins_sleep {
			AM4372_IOPAD(0xab4, PIN_INPUT_PULLDOWN | MUX_MODE7)  /* (AE6) RTC_PWRONRSTn.RTC_PORz */
			AM4372_IOPAD(0xab8, PIN_INPUT_PULLDOWN | MUX_MODE7)  /* (AE3) RTC_WAKEUP.RTC_WAKEUP */
			AM4372_IOPAD(0xabc, PIN_INPUT_PULLDOWN | MUX_MODE7)  /* (AD6) RTC_PMIC_EN.RTC_PMIC_EN */
	usb1_pins_default: usb1_pins_default {
			AM4372_IOPAD(0xac0, DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE0)
	usb1_pins_sleep: usb1_pins_sleep {
			AM4372_IOPAD(0xac0, DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
	usb2_pins_default: usb2_pins_default {
			AM4372_IOPAD(0xac4, DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE0)
	usb2_pins_sleep: usb2_pins_sleep {
			AM4372_IOPAD(0xac4, DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7)
	spi0_pins_default: spi0_pins_default {
			AM4372_IOPAD(0x950,  PIN_INPUT_PULLUP | MUX_MODE0 )  /* (P23) spi0_sclk.spi0_sclk */
			AM4372_IOPAD(0x954,  PIN_INPUT | MUX_MODE0 )         /* (T22) spi0_d0.spi0_d0 */
			AM4372_IOPAD(0x958,  PIN_OUTPUT | MUX_MODE0 )        /* (T21) spi0_d1.spi0_d1 */
			AM4372_IOPAD(0x95c,  PIN_OUTPUT | MUX_MODE0 )        /* (T20) spi0_cs0.spi0_cs0 */
	spi0_pins_sleep: spi0_pins_sleep {
			AM4372_IOPAD(0x950, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)      /* (P23) spi0_sclk.spi0_sclk */
			AM4372_IOPAD(0x954, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)      /* (T22) spi0_d0.spi0_d0 */
			AM4372_IOPAD(0x958, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)      /* (T21) spi0_d1.spi0_d1 */
			AM4372_IOPAD(0x95c, DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7)      /* (T20) spi0_cs0.spi0_cs0 */
&i2c0 {
	status = "okay";
	pinctrl-0 = <&i2c0_pins>;
	clock-frequency = <100000>;
	tps65218: tps65218@24 {
		reg = <0x24>;
		compatible = "ti,tps65218";
		interrupts = <GIC_SPI 7 IRQ_TYPE_NONE>; /* NMIn */
		interrupt-controller;
		#interrupt-cells = <2>;
		dcdc1: regulator-dcdc1 {
			regulator-name = "vdd_core";
			regulator-min-microvolt = <912000>;
			regulator-max-microvolt = <1144000>;
			regulator-boot-on;
		dcdc2: regulator-dcdc2 {
			regulator-name = "vdd_mpu";
			regulator-max-microvolt = <1378000>;
			regulator-boot-on;
		dcdc3: regulator-dcdc3 {
			regulator-name = "vdcdc3";
			regulator-boot-on;
			regulator-state-mem {
				regulator-on-in-suspend;
			regulator-state-disk {
				regulator-off-in-suspend;
		dcdc5: regulator-dcdc5 {
			regulator-name = "v1_0bat";
			regulator-min-microvolt = <1000000>;
			regulator-max-microvolt = <1000000>;
			regulator-boot-on;
		dcdc6: regulator-dcdc6 {
			regulator-name = "v1_8bat";
			regulator-boot-on;
		ldo1: regulator-ldo1 {
			regulator-boot-on;
	ov2659@30 {
		compatible = "ovti,ov2659";
		reg = <0x30>;
		clocks = <&audio_mstrclk>;
		clock-names = "xvclk";
		port {
			ov2659_0: endpoint {
				remote-endpoint = <&vpfe1_ep>;
				link-frequencies = /bits/ 64 <70000000>;
&i2c1 {
	status = "okay";
	pinctrl-0 = <&i2c1_pins>;
	pixcir_ts@5c {
		compatible = "pixcir,pixcir_tangoc";
		pinctrl-0 = <&pixcir_ts_pins>;
		reg = <0x5c>;
		attb-gpio = <&gpio0 19 GPIO_ACTIVE_HIGH>;
		 * 0x270 represents the offset of padconf register of
		 * gpio0_19 from am43xx_pinmux base.
		interrupts-extended = <&gpio0 19 IRQ_TYPE_EDGE_FALLING>,
				      <&am43xx_pinmux 0x270>;
		interrupt-names = "tsc", "wakeup";
		touchscreen-size-x = <1024>;
		touchscreen-size-y = <600>;
		wakeup-source;
	ov2659@30 {
		reg = <0x30>;
		port {
			ov2659_1: endpoint {
				remote-endpoint = <&vpfe0_ep>;
	tlv320aic3106: tlv320aic3106@1b {
		#sound-dai-cells = <0>;
		compatible = "ti,tlv320aic3106";
		reg = <0x1b>;
		status = "okay";
		ai3x-micbias-vg = <0x1>;
		gpio = <&gpio2 3 GPIO_ACTIVE_LOW>;
		/* Regulators */
		IOVDD-supply = <&evm_v3_3d>; /* V3_3D -> <tps63031> EN: V1_8D -> VBAT */
		AVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
		DRVDD-supply = <&evm_v3_3d>; /* v3_3AUD -> V3_3D -> ... */
		DVDD-supply = <&ldo1>; /* V1_8D -> LDO1 */
&tscadc {
	status = "okay";
	adc {
		ti,adc-channels = <0 1 2 3 4 5 6 7>;
&epwmss1 {
	status = "okay";
	pinctrl-0 = <&ehrpwm1_pins_default>;
	pinctrl-1 = <&ehrpwm1_pins_sleep>;
	ehrpwm1: pwm@48302200 {
		status = "okay";
&gpio0 {
	status = "okay";
&gpio1 {
	status = "okay";
	p29 {
		/* PRU_UART Rs485 */
		gpio-hog;
		gpios = <29 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "PRU_UART";
&gpio2 {
	status = "okay";
&gpio3 {
	status = "okay";
&gpio4 {
	status = "okay";
	p7 {
		* High: LCD backlight ON.
		* low: LCD backlight OFF.
		gpio-hog;
		gpios = <7 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "Backlight";
&gpio5 {
	pinctrl-0 = <&display_mux_pins>;
	status = "okay";
	ti,no-reset-on-init;
	p8 {
		 * SelLCDorHDMI selects between display and audio paths:
		 * Low: HDMI display with audio via HDMI
		 * High: LCD display with analog audio via aic3111 codec
		gpio-hog;
		gpios = <8 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "SelLCDorHDMI";
	p9 {
		gpio-hog;
		gpios = <9 GPIO_ACTIVE_HIGH>;
		output-high;
		line-name = "PRU1_UART";
	p10 {
                gpio-hog;
                gpios = <10 GPIO_ACTIVE_HIGH>;
                output-high;
                line-name = "WL_EN";
        p11 {
                gpio-hog;
                output-low;
                line-name = "WL_TXR_EN";
&mmc1 {
	status = "okay";
	vmmc-supply = <&evm_v3_3d>;
	bus-width = <4>;
	pinctrl-0 = <&mmc1_pins>;
	cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>;
/* eMMC sits on mmc2 */
&mmc2 {
	 * When enabling eMMC, disable GPMC/NAND and set
	 * SelEMMCorNAND to output-high
	status = "okay";
	bus-width = <8>;
	pinctrl-0 = <&emmc_pins_default>;
	pinctrl-1 = <&emmc_pins_sleep>;
	ti,non-removable;
&mmc3 {
	status = "okay";
	/* these are on the crossbar and are outlined in the
	   xbar-event-map element */
	vmmc-supply = <&wlan_en_reg>;
	bus-width = <4>;
	pinctrl-0 = <&mmc3_pins_default &wlan_pins_default>;
	pinctrl-1 = <&mmc3_pins_sleep &wlan_pins_sleep>;
	cap-power-off-card;
	keep-power-in-suspend;
	ti,non-removable;
	enable-sdio-wakeup;
	/*ti,needs-special-hs-handling;
	broken-cd;
	disable-wp;*/
	#address-cells = <1>;
	#size-cells = <0>;
	wlcore: wlcore@0 {
		compatible = "ti,wl1835";
		reg = <2>;
		interrupt-parent = <&gpio5>;
		interrupts = <4 IRQ_TYPE_LEVEL_HIGH>;
               /* pinctrl-names = "default","sleep";*/
&uart3 {
	status = "okay";
	pinctrl-0 = <&uart3_pins>;
&usb2_phy1 {
	status = "okay";
&usb1 {
	dr_mode = "host";
	status = "okay";
	pinctrl-0 = <&usb1_pins_default>;
	pinctrl-1 = <&usb1_pins_sleep>;
&usb2_phy2 {
	status = "okay";
&usb2 {
	dr_mode = "host";
	status = "okay";
	pinctrl-0 = <&usb2_pins_default>;
	pinctrl-1 = <&usb2_pins_sleep>;
&mac {
	slaves = <2>;
	pinctrl-0 = <&cpsw_default>;
	pinctrl-1 = <&cpsw_sleep>;
	status = "okay";
	dual_emac;
	reset-gpio = <&gpio5 5 GPIO_ACTIVE_HIGH>;
&davinci_mdio {
	pinctrl-0 = <&davinci_mdio_default &davinci_mdio1_default>;
	pinctrl-1 = <&davinci_mdio_sleep &davinci_mdio1_sleep>;
	status = "okay";
&cpsw_emac0 {
	phy_id = <&davinci_mdio>, <0>;
	phy-mode = "rgmii";
	dual_emac_res_vlan = <1>;
&cpsw_emac1 {
	phy_id = <&davinci_mdio>, <1>;
	phy-mode = "mii";
	dual_emac_res_vlan = <2>;
&elm {
	status = "okay";
&uart0 {
	status = "okay";
	pinctrl-0 = <&uart0_pins_default>;
	pinctrl-1 = <&uart0_pins_sleep>;
&uart1 {
	status = "okay";
	pinctrl-0 = <&uart1_pins_default>;
	pinctrl-1 = <&uart1_pins_sleep>;
/*      rts-gpio = <&gpio5 9 GPIO_ACTIVE_HIGH>;*/
	rts-gpio = <&gpio1 29 GPIO_ACTIVE_HIGH>;
	rs485-rts-active-high;
	rs485-rx-during-tx;
	rs485-rts-delay = <1 1>;
	linux,rs485-enabled-at-boot-time;
&pruss1 {
	status = "okay";
	pinctrl-0 = <&uart_pruss1_pins_default>;
	pinctrl-1 = <&uart_pruss1_pins_sleep>;
/*      rts-gpio = <&gpio1 29 GPIO_ACTIVE_HIGH>;*/
&dss {
	status = "ok";
	pinctrl-0 = <&dss_pins>;
	port {
		dpi_out: endpoint {
			remote-endpoint = <&lcd_in>;
			data-lines = <24>;
&vpfe0 {
	status = "okay";
	pinctrl-0 = <&vpfe0_pins_default>;
	pinctrl-1 = <&vpfe0_pins_sleep>;
	port {
		vpfe0_ep: endpoint {
			remote-endpoint = <&ov2659_1>;
			ti,am437x-vpfe-interface = <0>;
			bus-width = <8>;
			hsync-active = <0>;
			vsync-active = <0>;
&vpfe1 {
	status = "disabled";
	pinctrl-0 = <&vpfe1_pins_default>;
	pinctrl-1 = <&vpfe1_pins_sleep>;
	port {
		vpfe1_ep: endpoint {
			remote-endpoint = <&ov2659_0>;
			bus-width = <8>;
			hsync-active = <0>;
			vsync-active = <0>;
&spi0 {
	#size-cells = <0>;
	ti,spi-num-cs = <1>;
	ti,hwmods = "spi0";
	ti,pindir-d1-out-d0-in;
	dma-names = "tx0", "rx0", "tx1", "rx1";
	pinctrl-0 = <&spi0_pins_default>;
	pinctrl-1 = <&spi0_pins_sleep>;
	status = "okay";
	w25x20@0 {
		#size-cells = <1>;
		compatible = "winbond,w25x20";
		spi-max-frequency = <48000000>;
		reg = <0>;
		partition@00000 {
			label = "BootLoader";
			reg = <0x0 0x40000>;
&mcasp1 {
	pinctrl-0 = <&mcasp1_pins>;
	pinctrl-1 = <&mcasp1_sleep_pins>;
	status = "okay";
	op-mode = <0>; /* MCASP_IIS_MODE */
	tdm-slots = <2>;
	/* 4 serializers */
	serial-dir = <  /* 0: INACTIVE, 1: TX, 2: RX */
		1 2 0 0
	tx-num-evt = <32>;
	rx-num-evt = <32>;
&rtc {
	clocks = <&clk_32k_rtc>, <&clk_32768_ck>;
	clock-names = "ext-clk", "int-clk";
	status = "okay";
&cpu {
	cpu0-supply = <&dcdc2>;
&wkup_m3_ipc {
	ti,set-io-isolation;
	ti,scale-data-fw = "am43x-evm-scale-data.bin";
&clkout_32k_mux_ck {
	clock-default = <&clk_32768_ck>;
&pruss_soc_bus {
	status = "okay";
	pruss1: pruss@54400000 {
		status = "okay";
		pru1_0: pru@54434000 {
			status = "okay";
		pru1_1: pru@54438000 {
			status = "okay";
	pruss0: pruss@54440000 {
		status = "okay";
		pru0_0: pru@54474000 {
			status = "okay";
		pru0_1: pru@54478000 {
			status = "okay";
&sgx {
	status = "okay";
I have attached the dmesg log file.
root@am437x-evm:~#
root@am437x-evm:~# dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.59-rt23-g273202a0d3 (root@lap000255) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #66 PREEMPT RT Tu8
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt:Machine model: TI AM437x GP EVM
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] cma: Reserved 48 MiB at 0xbd000000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] On node 0 totalpages: 262144
[    0.000000] free_area_init_node: node 0, pgdat c0d51360, node_mem_map ef6f9000
[    0.000000]   Normal zone: 1728 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 196608 pages, LIFO batch:31
[    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM437x ES1.2 (sgx neon)
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260416
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 rw
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 976136K/1048576K available (8192K kernel code, 331K rwdata, 2644K rodata, 1024K init, 354K bss, 23288K reserved, 49152K)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
                   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                     .text : 0xc0008000 - 0xc0900000   (9184 kB)
                     .init : 0xc0c00000 - 0xc0d00000   (1024 kB)
                     .data : 0xc0d00000 - 0xc0d52da0   ( 332 kB)
                      .bss : 0xc0d52da0 - 0xc0dab780   ( 355 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  RCU kthread priority: 1.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] OMAP L2C310: ROM does not support power control setting
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[    0.000000] 1 number of clocks
[    0.000000] omap2_clk_enable_init_clocks function is called
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000012] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000023] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000028] OMAP clocksource: timer1 at 24000000 Hz
[    0.000146] sched_clock: 64 bits at 500MHz, resolution 2ns, wraps every 4398046511103ns
[    0.000155] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xe6a171a037, max_idle_ns: 881590485102 ns
[    0.000170] Switching to timer-based delay loop, resolution 2ns
[    0.000539] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000541] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000951] Console: colour dummy device 80x30
[    0.001084] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001085] This ensures that you still see kernel messages. Please
[    0.001087] update your kernel commandline.
[    0.001109] Calibrating delay loop (skipped), value calculated using timer frequency.. 1000.00 BogoMIPS (lpj=5000000)
[    0.001114] pid_max: default: 32768 minimum: 301
[    0.001228] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001233] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002091] CPU: Testing write buffer coherency: ok
[    0.002403] Setting up static identity map for 0x80100000 - 0x80100060
[    0.003410] EFI services will not be available.
[    0.004201] devtmpfs: initialized
[    0.017233] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.017558] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.017583] futex hash table entries: 256 (order: 1, 8192 bytes)
[    0.021036] pinctrl core: initialized pinctrl subsystem
[    0.022246] NET: Registered protocol family 16
[    0.023697] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.093118] gpio gpiochip0: (gpio): added GPIO chardev (254:0)
[    0.093427] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio)
[    0.094799] OMAP GPIO hardware version 0.1
[    0.095507] GPIO line 61 (PRU_UART) hogged as output/high
[    0.095531] gpio gpiochip1: (gpio): added GPIO chardev (254:1)
[    0.095822] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio)
[    0.097494] gpio gpiochip2: (gpio): added GPIO chardev (254:2)
[    0.097765] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio)
[    0.099549] gpio gpiochip3: (gpio): added GPIO chardev (254:3)
[    0.099866] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio)
[    0.101796] GPIO line 135 (Backlight) hogged as output/high
[    0.101823] gpio gpiochip4: (gpio): added GPIO chardev (254:4)
[    0.102114] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio)
[    0.103755] omap_gpio 48322000.gpio: could not find pctldev for node /ocp@44000000/l4_wkup@44c00000/scm@210000/pinmux@800/display_mux_pins,e
[    0.111744] No ATAGs?
[    0.111770] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.111780] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.126630] edma 49000000.edma: TI EDMA DMA engine driver
[    0.126989] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-v3_3d[0]'
[    0.130681] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp@44000000/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins, deferrine
[    0.130739] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp@44000000/l4_wkup@44c00000/scm@210000/pinmux@800/i2c1_pins, deferrine
[    0.130865] media: Linux media interface: v0.10
[    0.130921] Linux video capture interface: v2.00
[    0.130962] pps_core: LinuxPPS API ver. 1 registered
[    0.130969] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.130990] PTP clock support registered
[    0.131029] EDAC MC: Ver: 3.0.0
[    0.131937] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.132287] Advanced Linux Sound Architecture Driver Initialized.
[    0.133859] clocksource: Switched to clocksource arm_global_timer
[    0.142817] NET: Registered protocol family 2
[    0.143545] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.143630] TCP bind hash table entries: 8192 (order: 5, 196608 bytes)
[    0.144193] TCP: Hash tables configured (established 8192 bind 8192)
[    0.144374] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    0.144489] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    0.144897] NET: Registered protocol family 1
[    0.145404] RPC: Registered named UNIX socket transport module.
[    0.145419] RPC: Registered udp transport module.
[    0.145425] RPC: Registered tcp transport module.
[    0.145431] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.145443] PCI: CLS 0 bytes, default 64
[    0.147892] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.153644] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.154605] NFS: Registering the id_resolver key type
[    0.154641] Key type id_resolver registered
[    0.154648] Key type id_legacy registered
[    0.154699] ntfs: driver 2.1.32 [Flags: R/O].
[    0.158491] bounce: pool size: 64 pages
[    0.158705] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.158717] io scheduler noop registered
[    0.158724] io scheduler deadline registered
[    0.158855] io scheduler cfq registered (default)
[    0.161938] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796
[    0.165055] pwm-backlight backlight: GPIO lookup for consumer enable
[    0.165065] pwm-backlight backlight: using device tree for GPIO lookup
[    0.165075] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
[    0.165080] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
[    0.165085] pwm-backlight backlight: using lookup tables for GPIO lookup
[    0.165091] pwm-backlight backlight: lookup for GPIO enable failed
[    0.165108] backlight supply power not found, using dummy regulator
[    0.216800] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.219128] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.219858] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    0.925761] console [ttyS0] enabled
[    0.929765] omap8250 48022000.serial: No clock speed specified: using default: 48000000
[    0.938434] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[    0.947598] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[    0.956226] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 32, base_baud = 3000000) is a 8250
[    0.966794] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[    0.973605] [drm] Initialized
[    0.977939] 4832a000.dss supply vdda_video not found, using dummy regulator
[    0.985087] OMAP DSS rev 2.0
[    0.988149] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops)
[    0.997103] panel-dpi display: GPIO lookup for consumer enable
[    0.997111] panel-dpi display: using device tree for GPIO lookup
[    0.997120] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/display[0]'
[    0.997125] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/display[0]'
[    0.997130] panel-dpi display: using lookup tables for GPIO lookup
[    0.997136] panel-dpi display: lookup for GPIO enable failed
[    0.997141] panel-dpi display: GPIO lookup for consumer reset
[    0.997145] panel-dpi display: using device tree for GPIO lookup
[    0.997149] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/display[0]'
[    0.997153] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/display[0]'
[    0.997157] panel-dpi display: using lookup tables for GPIO lookup
[    0.997161] panel-dpi display: lookup for GPIO reset failed
[    0.997174] display supply vcc not found, using dummy regulator
[    1.016758] brd: module loaded
[    1.026352] loop: module loaded
[    1.031996] spi spi1.0: not using DMA for McSPI (-19)
[    1.037448] m25p80 spi1.0: w25x20 (256 Kbytes)
[    1.041933] 1 ofpart partitions found on MTD device spi1.0
[    1.047445] Creating 1 MTD partitions on "spi1.0":
[    1.052265] 0x000000000000-0x000000040000 : "BootLoader"
[    1.059690] libphy: Fixed MDIO Bus: probed
[    1.133929] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    1.140065] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[    1.147750] libphy: 4a101000.mdio: probed
[    1.151796] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    1.161499] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI TLK10X 10/100 Mbps PHY
[    1.171960] cpsw 4a100000.ethernet: Detected MACID = 50:65:83:de:9d:e3
[    1.178631] cpsw 4a100000.ethernet: device node lookup for pps timer failed
[    1.185656] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.193703] cpsw 4a100000.ethernet: cpsw: Detected MACID = 50:65:83:de:9d:e5
[    1.202643] mousedev: PS/2 mouse device common for all mice
[    1.208793] i2c /dev entries driver
[    1.214098] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd
[    1.214106] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    1.214164] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp@44000000/mmc@48060000[0]' - status (0)
[    1.214230] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.218888] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp
[    1.218893] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup
[    1.218900] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@48060000[0]'
[    1.218906] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@48060000[0]'
[    1.218910] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup
[    1.218917] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed
[    1.274405] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd
[    1.274415] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
[    1.274423] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.274429] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.274434] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
[    1.274440] omap_hsmmc 481d8000.mmc: lookup for GPIO cd failed
[    1.274446] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp
[    1.274450] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
[    1.274455] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.274459] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@481d8000[0]'
[    1.274463] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
[    1.274467] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed
[    1.334271] omap_hsmmc 47810000.mmc: GPIO lookup for consumer cd
[    1.334280] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    1.334290] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334295] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334299] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    1.334306] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed
[    1.334313] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
[    1.334316] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
[    1.334321] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334325] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@47810000[0]'
[    1.334329] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
[    1.334333] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed
[    1.334486] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    1.341346] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@0[0]' - status (0)
[    1.341506] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@1[0]' - status (0)
[    1.341647] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led@2[0]' - status (0)
[    1.348338] NET: Registered protocol family 26
[    1.356018] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.363073] NET: Registered protocol family 10
[    1.368939] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.375690] NET: Registered protocol family 17
[    1.380250] Bridge firewalling registered
[    1.382227] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.385025] mmc0: new high speed SDHC card at address aaaa
[    1.394132] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    1.395840]  mmcblk0: p1 p2
[    1.407423] 8021q: 802.1Q VLAN Support v1.8
[    1.411684] Key type dns_resolver registered
[    1.416196] omap_voltage_late_init: Voltage driver support not added
[    1.429800] omapdrm omapdrm.0: DMM not available, disable DMM support
[    1.436869] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.443520] [drm] No driver support for vblank timestamp query.
[    1.511847] Console: switching to colour frame buffer device 100x30
[    1.534877] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    1.542379] GPIO line 168 (SelLCDorHDMI) hogged as output/high
[    1.548265] GPIO line 169 (PRU1_UART) hogged as output/high
[    1.553953] GPIO line 170 (WL_EN) hogged as output/high
[    1.559213] requesting hog GPIO WL_TXR_EN (chip gpio, offset 10) failed, -16
[    1.566308] gpiochip_add_data: GPIOs 160..191 (gpio) failed to register
[    1.572959] omap_gpio 48322000.gpio: Could not register gpio chip -16
[    1.579495] omap_gpio: probe of 48322000.gpio failed with error -16
[    1.629722] ov2659 0-0030: GPIO lookup for consumer pwrdn
[    1.629732] ov2659 0-0030: using device tree for GPIO lookup
[    1.629743] of_get_named_gpiod_flags: can't parse 'pwrdn-gpios' property of node '/ocp@44000000/i2c@44e0b000/ov2659@30[0]'
[    1.629748] of_get_named_gpiod_flags: can't parse 'pwrdn-gpio' property of node '/ocp@44000000/i2c@44e0b000/ov2659@30[0]'
[    1.629753] ov2659 0-0030: using lookup tables for GPIO lookup
[    1.629759] ov2659 0-0030: lookup for GPIO pwrdn failed
[    1.632455] ov2659 0-0030: Sensor detection failed (3030, 0)
[    1.638261] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
[    1.645466] ov2659 1-0030: GPIO lookup for consumer pwrdn
[    1.645476] ov2659 1-0030: using device tree for GPIO lookup
[    1.645486] of_get_named_gpiod_flags: can't parse 'pwrdn-gpios' property of node '/ocp@44000000/i2c@4802a000/ov2659@30[0]'
[    1.645491] of_get_named_gpiod_flags: can't parse 'pwrdn-gpio' property of node '/ocp@44000000/i2c@4802a000/ov2659@30[0]'
[    1.645496] ov2659 1-0030: using lookup tables for GPIO lookup
[    1.645501] ov2659 1-0030: lookup for GPIO pwrdn failed
[    1.676550] ov2659 1-0030: Sensor detection failed (3030, 0)
[    1.682722] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp@44000000/i2c@4802a000/tlv320aic3106@1b[0]'
[    1.683167] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz
[    1.690282] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound0[0]'
[    1.690293] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound0[0]'
[    1.691361] asoc-simple-card sound0: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[    1.710865] hctosys: unable to open rtc device (rtc0)
[    1.716662] ALSA device list:
[    1.719656]   #0: AM437x-GP-EVM
[    1.724990] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[    1.733910] random: fast init done
[    1.757214] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.765449] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    1.774500] devtmpfs: mounted
[    1.779328] Freeing unused kernel memory: 1024K
[    1.871654] mmc1: new high speed MMC card at address 0001
[    1.878906] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    1.885956] mmcblk1boot0: mmc1:0001 MMC04G partition 1 16.0 MiB
[    1.893348] mmcblk1boot1: mmc1:0001 MMC04G partition 2 16.0 MiB
[    1.904091]  mmcblk1: p1 p2 p3 p4
[    2.050744] systemd[1]: System time before build time, advancing clock.
[    2.079030] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCR)
[    2.097854] systemd[1]: Detected architecture arm.
[    2.141667] systemd[1]: Set hostname to <am437x-evm>.
[    2.626427] systemd[1]: Reached target Remote File Systems.
[    2.654161] systemd[1]: Reached target Swap.
[    2.684418] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    2.724364] systemd[1]: Listening on Syslog Socket.
[    2.754283] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.784340] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    2.824239] systemd[1]: Listening on udev Kernel Socket.
[    3.189723] cmemk: loading out-of-tree module taints kernel.
[    3.196902] CMEMK module: reference Linux version 4.9.59
[    3.203128] no physical memory specified
[    3.211430] cmemk initialized
[    3.224387] cryptodev: driver 1.8 loaded.
[    3.316844] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.229710] systemd-journald[148]: Received request to flush runtime journal from PID 1
[    5.900378] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    5.926760] remoteproc remoteproc0: wkup_m3 is available
[    6.034510] rtc rtc0: 44e3e000.rtc: dev (253:0)
[    6.034545] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[    6.116415] remoteproc remoteproc0: powering up wkup_m3
[    6.198924] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224268
[    6.324852] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    6.324978] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[    6.551353] pixcir_ts 1-005c: GPIO lookup for consumer attb
[    6.551366] pixcir_ts 1-005c: using device tree for GPIO lookup
[    6.551379] of_get_named_gpiod_flags: can't parse 'attb-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
[    6.551463] of_get_named_gpiod_flags: parsed 'attb-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]' - status (0)
[    6.551483] pixcir_ts 1-005c: GPIO lookup for consumer reset
[    6.551487] pixcir_ts 1-005c: using device tree for GPIO lookup
[    6.551494] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
[    6.551499] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
[    6.551503] pixcir_ts 1-005c: using lookup tables for GPIO lookup
[    6.551510] pixcir_ts 1-005c: lookup for GPIO reset failed
[    6.551515] pixcir_ts 1-005c: GPIO lookup for consumer wake
[    6.551519] pixcir_ts 1-005c: using device tree for GPIO lookup
[    6.551524] of_get_named_gpiod_flags: can't parse 'wake-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
[    6.551528] of_get_named_gpiod_flags: can't parse 'wake-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
[    6.551532] pixcir_ts 1-005c: using lookup tables for GPIO lookup
[    6.551536] pixcir_ts 1-005c: lookup for GPIO wake failed
[    6.551541] pixcir_ts 1-005c: GPIO lookup for consumer enable
[    6.551545] pixcir_ts 1-005c: using device tree for GPIO lookup
[    6.551550] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
[    6.551554] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
[    6.551558] pixcir_ts 1-005c: using lookup tables for GPIO lookup
[    6.551562] pixcir_ts 1-005c: lookup for GPIO enable failed
[    6.566891] input: pixcir_tangoc as /devices/platform/44000000.ocp/4802a000.i2c/i2c-1/1-005c/input/input0
[    7.609183] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
[    7.822094] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
[    7.870881] omap-aes 53501000.aes: will run requests pump with realtime priority
[    8.060915] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
[    8.111553] omap-des 53701000.des: will run requests pump with realtime priority
[    8.305109] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[   10.137722] net eth1: initializing cpsw version 1.15 (0)
[   10.208865] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[   10.208871] cpsw 4a100000.ethernet: ALE Table size 1024
[   10.304438] TI TLK10X 10/100 Mbps PHY 4a101000.mdio:01: attached PHY driver [TI TLK10X 10/100 Mbps PHY] (mii_bus:phy_addr=4a101000.mdio:01,)
[   10.325542] cpts ptp bc clkid 0
[   10.328905] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   10.328914] 8021q: adding VLAN 0 to HW filter on device eth1
[   10.441594] net eth0: initializing cpsw version 1.15 (0)
[   10.536576] Micrel KSZ9031 Gigabit PHY 4a101000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=4a101000.mdio:0)
[   10.572492] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.572501] 8021q: adding VLAN 0 to HW filter on device eth0
[   14.396698] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   14.449228] EXT4-fs (mmcblk1p3): mounting ext3 file system using the ext4 subsystem
[   14.543274] EXT4-fs (mmcblk1p3): recovery complete
[   14.543291] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[   14.811227] NET: Registered protocol family 15
[   14.961074] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   15.125609] FAT-fs (mmcblk1p4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   15.984362] EXT4-fs (mmcblk1p2): mounting ext3 file system using the ext4 subsystem
[   16.147811] EXT4-fs (mmcblk1p2): recovery complete
[   16.152656] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[   17.027016] Initializing XFRM netlink socket
[   18.335138] random: crng init done
[   22.498032] ti-pruss 54400000.pruss: creating PRU cores and other child platform devices
[   22.572565] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/intc@54420000 !
[   22.726043] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/intc@54420000 !
[   22.840995] ti-pruss 54440000.pruss: creating PRU cores and other child platform devices
[   22.943013] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54440000/intc@54460000 !
[   22.968361] usbcore: registered new interface driver usbfs
[   22.969722] usbcore: registered new interface driver hub
[   22.974586] usbcore: registered new device driver usb
[   23.010277] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   23.010324] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[   23.014781] xhci-hcd xhci-hcd.3.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x02010010
[   23.027849] xhci-hcd xhci-hcd.3.auto: irq 258, io mem 0x48390000
[   23.030136] hub 1-0:1.0: USB hub found
[   23.030192] hub 1-0:1.0: 1 port detected
[   23.039402] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   23.039425] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   23.045170] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   23.050479] hub 2-0:1.0: USB hub found
[   23.050553] hub 2-0:1.0: 1 port detected
[   23.056576] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[   23.056610] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 3
[   23.057638] xhci-hcd xhci-hcd.4.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x02010010
[   23.064078] xhci-hcd xhci-hcd.4.auto: irq 259, io mem 0x483d0000
[   23.071004] hub 3-0:1.0: USB hub found
[   23.071087] hub 3-0:1.0: 1 port detected
[   23.075733] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[   23.075755] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 4
[   23.079226] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   23.083327] hub 4-0:1.0: USB hub found
[   23.087695] hub 4-0:1.0: 1 port detected
[   24.102560] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54440000/intc@54460000 !
[   24.257488] remoteproc remoteproc1: 54434000.pru0 is available
[   24.263438] pru-rproc 54434000.pru0: PRU rproc node /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/pru@54434000 probed successfully
[   24.364938] remoteproc remoteproc2: 54438000.pru1 is available
[   24.370920] pru-rproc 54438000.pru1: PRU rproc node /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/pru@54438000 probed successfully
[   24.443249] remoteproc remoteproc3: 54474000.pru0 is available
[   24.458932] pru-rproc 54474000.pru0: PRU rproc node /ocp@44000000/pruss_soc_bus@54426000/pruss@54440000/pru@54474000 probed successfully
[   24.515047] remoteproc remoteproc4: 54478000.pru1 is available
[   24.521032] pru-rproc 54478000.pru1: PRU rproc node /ocp@44000000/pruss_soc_bus@54426000/pruss@54440000/pru@54478000 probed successfully
[   25.028367] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
root@am437x-evm:~#
Console boot log :
U-Boot SPL 2017.01-00458-gd10e262-dirty (Feb 26 2018 - 14:01:27)
Trying to boot from MMC1
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2017.01-00458-gd10e262-dirty (Feb 26 2018 - 14:01:27 +0530)
CPU  : AM437X-GP rev 1.2
Model: TI AM437x GP EVM
DRAM:  1 GiB
PMIC:  TPS65218
NAND:  0 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1, OMAP SD/MMC: 2
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
Net:   Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
** Bad device specification 0x82000000 uEnv **
3977744 bytes read in 804 ms (4.7 MiB/s)
55686 bytes read in 34 ms (1.6 MiB/s)
Booting from mmc0 ...
   Loading Device Tree to 8ffef000, end 8ffff985 ... OK
Starting kernel ...
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0900000   (9184 kB)
[    0.000000]       .init : 0xc0c00000 - 0xc0d00000   (1024 kB)
[    0.000000]       .data : 0xc0d00000 - 0xc0d52da0   ( 332 kB)
[    0.000000]        .bss : 0xc0d52da0 - 0xc0dab780   ( 355 kB)
[    0.000029] OMAP clocksource: timer1 at 24000000 Hz
[    0.000149] sched_clock: 64 bits at 500MHz, resolution 2ns, wraps every 4398046511103ns
[    0.000158] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0xe6a171a037, max_idle_ns: 881590485102 ns
[    0.000174] Switching to timer-based delay loop, resolution 2ns
[    0.000545] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000548] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000955] Console: colour dummy device 80x30
[    0.001089] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.001091] This ensures that you still see kernel messages. Please
[    0.001092] update your kernel commandline.
[    0.001114] Calibrating delay loop (skipped), value calculated using timer frequency.. 1000.00 BogoMIPS (lpj=5000000)
[    0.001119] pid_max: default: 32768 minimum: 301
[    0.001236] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001241] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002104] CPU: Testing write buffer coherency: ok
[    0.002414] Setting up static identity map for 0x80100000 - 0x80100060
[    0.003423] EFI services will not be available.
[    0.004207] devtmpfs: initialized
[    0.017224] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.017539] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.017565] futex hash table entries: 256 (order: 1, 8192 bytes)
[    0.021001] pinctrl core: initialized pinctrl subsystem
[    0.022203] NET: Registered protocol family 16
[    0.023647] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.094623] OMAP GPIO hardware version 0.1
[    0.095330] GPIO line 61 (PRU_UART) hogged as output/high
[    0.101614] GPIO line 135 (Backlight) hogged as output/high
[    0.103576] omap_gpio 48322000.gpio: could not find pctldev for node /ocp@44000000/l4_wkup@44c00000/scm@210000/pinmux@800/display_mux_pins,e
[    0.111649] No ATAGs?
[    0.111675] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.111686] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.126520] edma 49000000.edma: TI EDMA DMA engine driver
[    0.130585] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp@44000000/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins, deferrine
[    0.130641] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp@44000000/l4_wkup@44c00000/scm@210000/pinmux@800/i2c1_pins, deferrine
[    0.130773] media: Linux media interface: v0.10
[    0.130832] Linux video capture interface: v2.00
[    0.130872] pps_core: LinuxPPS API ver. 1 registered
[    0.130880] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.130902] PTP clock support registered
[    0.130941] EDAC MC: Ver: 3.0.0
[    0.131846] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.132192] Advanced Linux Sound Architecture Driver Initialized.
[    0.133764] clocksource: Switched to clocksource arm_global_timer
[    0.142739] NET: Registered protocol family 2
[    0.143460] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.143546] TCP bind hash table entries: 8192 (order: 5, 196608 bytes)
[    0.144110] TCP: Hash tables configured (established 8192 bind 8192)
[    0.144298] UDP hash table entries: 512 (order: 3, 32768 bytes)
[    0.144419] UDP-Lite hash table entries: 512 (order: 3, 32768 bytes)
[    0.144826] NET: Registered protocol family 1
[    0.145332] RPC: Registered named UNIX socket transport module.
[    0.145346] RPC: Registered udp transport module.
[    0.145351] RPC: Registered tcp transport module.
[    0.145357] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.147800] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.153539] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.154516] NFS: Registering the id_resolver key type
[    0.154552] Key type id_resolver registered
[    0.154560] Key type id_legacy registered
[    0.154614] ntfs: driver 2.1.32 [Flags: R/O].
[    0.158396] bounce: pool size: 64 pages
[    0.158607] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.158621] io scheduler noop registered
[    0.158628] io scheduler deadline registered
[    0.158759] io scheduler cfq registered (default)
[    0.161833] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796
[    0.165008] backlight supply power not found, using dummy regulator
[    0.216696] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.219029] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.219746] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[    0.925669] console [ttyS0] enabled
[    0.929671] omap8250 48022000.serial: No clock speed specified: using default: 48000000
[    0.938345] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[    0.947512] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[    0.956150] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 32, base_baud = 3000000) is a 8250
[    0.966697] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[    0.973512] [drm] Initialized
[    0.977839] 4832a000.dss supply vdda_video not found, using dummy regulator
[    0.984988] OMAP DSS rev 2.0
[    0.988045] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops)
[    0.997070] display supply vcc not found, using dummy regulator
[    1.016616] brd: module loaded
[    1.026202] loop: module loaded
[    1.031840] spi spi1.0: not using DMA for McSPI (-19)
[    1.037268] m25p80 spi1.0: w25x20 (256 Kbytes)
[    1.041752] 1 ofpart partitions found on MTD device spi1.0
[    1.047263] Creating 1 MTD partitions on "spi1.0":
[    1.052082] 0x000000000000-0x000000040000 : "BootLoader"
[    1.059520] libphy: Fixed MDIO Bus: probed
[    1.133835] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[    1.139971] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[    1.147682] libphy: 4a101000.mdio: probed
[    1.151727] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ9031 Gigabit PHY
[    1.161428] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI TLK10X 10/100 Mbps PHY
[    1.171900] cpsw 4a100000.ethernet: Detected MACID = 50:65:83:de:9d:e3
[    1.178601] cpsw 4a100000.ethernet: device node lookup for pps timer failed
[    1.185628] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.193681] cpsw 4a100000.ethernet: cpsw: Detected MACID = 50:65:83:de:9d:e5
[    1.202599] mousedev: PS/2 mouse device common for all mice
[    1.208753] i2c /dev entries driver
[    1.214187] omap_hsmmc 48060000.mmc: Got CD GPIO
[    1.334384] omap_hsmmc 47810000.mmc: RX DMA channel request failed
[    1.348232] NET: Registered protocol family 26
[    1.355914] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    1.362973] NET: Registered protocol family 10
[    1.368849] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.375652] NET: Registered protocol family 17
[    1.380206] Bridge firewalling registered
[    1.382408] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.385224] mmc0: new high speed SDHC card at address aaaa
[    1.394038] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
[    1.395743]  mmcblk0: p1 p2
[    1.407408] 8021q: 802.1Q VLAN Support v1.8
[    1.411664] Key type dns_resolver registered
[    1.416177] omap_voltage_late_init: Voltage driver support not added
[    1.429980] omapdrm omapdrm.0: DMM not available, disable DMM support
[    1.437145] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.443847] [drm] No driver support for vblank timestamp query.
[    1.512059] Console: switching to colour frame buffer device 100x30
[    1.535131] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[    1.542628] GPIO line 168 (SelLCDorHDMI) hogged as output/high
[    1.548513] GPIO line 169 (PRU1_UART) hogged as output/high
[    1.554151] GPIO line 170 (WL_EN) hogged as output/high
[    1.559407] requesting hog GPIO WL_TXR_EN (chip gpio, offset 10) failed, -16
[    1.566500] gpiochip_add_data: GPIOs 160..191 (gpio) failed to register
[    1.573150] omap_gpio 48322000.gpio: Could not register gpio chip -16
[    1.579689] omap_gpio: probe of 48322000.gpio failed with error -16
[    1.632390] ov2659 0-0030: Sensor detection failed (3030, 0)
[    1.638194] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 100 kHz
[    1.676456] ov2659 1-0030: Sensor detection failed (3030, 0)
[    1.683085] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 100 kHz
[    1.691255] asoc-simple-card sound0: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[    1.710813] hctosys: unable to open rtc device (rtc0)
[    1.716596] ALSA device list:
[    1.719588]   #0: AM437x-GP-EVM
[    1.724942] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[    1.733876] random: fast init done
[    1.871716] mmc1: new high speed MMC card at address 0001
[    1.880013] mmcblk1: mmc1:0001 MMC04G 3.60 GiB
[    1.886801] mmcblk1boot0: mmc1:0001 MMC04G partition 1 16.0 MiB
[    1.895139] mmcblk1boot1: mmc1:0001 MMC04G partition 2 16.0 MiB
[    1.906576]  mmcblk1: p1 p2 p3 p4
[    5.387314] EXT4-fs (mmcblk0p2): recovery complete
[    5.393929] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    5.402124] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    5.411665] devtmpfs: mounted
[    5.416511] Freeing unused kernel memory: 1024K
[    5.647353] systemd[1]: System time before build time, advancing clock.
[    5.676142] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCR)
[    5.694829] systemd[1]: Detected architecture arm.
Welcome to Arago 2017.10!
[    5.735080] systemd[1]: Set hostname to <am437x-evm>.
[    6.205267] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    6.244365] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    6.274297] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    6.314195] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    6.344018] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    6.374144] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    6.404317] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Reached target Swap.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Created slice System Slice.
         Starting Create list of required st... nodes for the current kernel...
         Starting Setup Virtual Console...
         Starting Load Kernel Modules...
[    6.760007] cmemk: loading out-of-tree module taints kernel.
[    6.768337] CMEMK module: reference Linux version 4.9.59
         [    6.779828] no physical memory specified
Mounting Temporary Directory...[    6.788831] cmemk initialized
[    6.814263] cryptodev: driver 1.8 loaded.
         Starting Remount Root and Kernel File Systems...
[    6.861034] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
         Starting Journal Service...
[  OK  ] Created slice system-serial\x2dgetty.slice.
         Mounting POSIX Message Queue File System...
[  OK  ] Created slice system-getty.slice.
[  OK  ] Reached target Slices.
[  OK  ] Listening on udev Control Socket.
         Starting alignment.service...
[  OK  ] Reached target Paths.
         Mounting Debug File System...
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Mounted Temporary Directory.
[  OK  ] Mounted Debug File System.
[  OK  ] Started Journal Service.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Setup Virtual Console.
[  OK  ] Started Load Kernel Modules.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Started alignment.service.
         Starting udev Coldplug all Devices...
         Mounting Configuration File System...
         Starting Apply Kernel Variables...
         Starting Create Static Device Nodes in /dev...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Mounted Configuration File System.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Started Create Static Device Nodes in /dev.
[    7.834673] systemd-journald[142]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started Load/Save Random Seed.
[  OK  ] Started Create Volatile Files and Directories.
         Starting Network Time Synchronization...
         Starting Update UTMP about System Boot/Shutdown...
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[  OK  ] Started Network Time Synchronization.
[  OK  ] Reached target System Time Synchronized.
[    9.474990] remoteproc remoteproc0: wkup_m3 is available
[  OK  ] Found device /dev/ttyS0.
[    9.558215] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[  OK  ] Started udev Coldplug all Devices.
[    9.633352] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[    9.752362] remoteproc remoteproc0: powering up wkup_m3
[  OK  ] Listening on D-Bus System Message Bus Socket.
[    9.852519] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224268
[  OK  ] Listening on dropbear.socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[    9.954799] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    9.954927] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[   10.077469] input: pixcir_tangoc as /devices/platform/44000000.ocp/4802a000.i2c/i2c-1/1-005c/input/input0
[  OK  ] Reached target Timers.
[  OK  ] Listening on RPCbind Server Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Login Service...
[  OK  ] Started D-Bus System Message Bus.
[   10.889277] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
[   11.043011] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
[   11.078866] omap-aes 53501000.aes: will run requests pump with realtime priority
[   11.205056] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
[   11.253943] omap-des 53701000.des: will run requests pump with realtime priority
         Starting Network Service...
[   11.359782] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
         Starting Avahi mDNS/DNS-SD Stack...
         Starting uim-sysfs.service...
         Starting Save/Restore Sound Card State...
         Starting Telephony service...
[  OK  ] Started System Logging Service.
         Starting Print notice about GPLv3 packages...
[   12.287941] net eth1: initializing cpsw version 1.15 (0)
[   12.293299] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[  OK  ] Started Kernel Logging Service.
[   12.514928] cpsw 4a100000.ethernet: ALE Table size 1024
[  OK  ] Started Network Service.
[  OK  ] Started Save/Restore Sound Card State.
[   12.674404] TI TLK10X 10/100 Mbps PHY 4a101000.mdio:01: attached PHY driver [TI TLK10X 10/100 Mbps PHY] (mii_bus:phy_addr=4a101000.mdio:01,)
[   12.868347] cpts ptp bc clkid 0
[   12.982176] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   13.038139] 8021q: adding VLAN 0 to HW filter on device eth1
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Telephony service.
[  OK  ] Started Login Service.
[  OK  ] Reached target Network.
[   13.347549] net eth0: initializing cpsw version 1.15 (0)
         Starting Lightning Fast Webserver With Light System Requirements...
[   13.546514] Micrel KSZ9031 Gigabit PHY 4a101000.mdio:00: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=4a101000.mdio:0)
         Starting Simple Network Management Protocol (SNMP) Daemon....
[   13.762753] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.768643] 8021q: adding VLAN 0 to HW filter on device eth0
[  OK  ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
         Starting Enable and configure wl18xx bluetooth stack...
         Starting Permit User Sessions...
         Starting Network Name Resolution...
[  OK  ] Started Lightning Fast Webserver With Light System Requirements.
[  OK  ] Started Permit User Sessions.
[  OK  ] Created slice system-systemd\x2dbacklight.slice.
         Starting Load/Save Screen Backlight...htness of backlight:backlight...
[  OK  ] Started Getty on tty1.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Started Network Name Resolution.
[  OK  ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[  OK  ] Started Synchronize System and HW clocks.
[  OK  ] Reached target Sound Card.
[   17.089689] EXT4-fs (mmcblk1p3): mounting ext3 file system using the ext4 subsystem
[   17.099020] EXT4-fs (mmcblk1p2): mounting ext3 file system using the ext4 subsystem
[   17.186996] EXT4-fs (mmcblk1p2): recovery complete
[   17.187013] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[   17.405684] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   17.408742] NET: Registered protocol family 15
[   17.427738] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   17.434970] FAT-fs (mmcblk1p4): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[   18.142482] EXT4-fs (mmcblk1p3): recovery complete
[   18.147763] EXT4-fs (mmcblk1p3): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Started Enable and configure wl18xx bluetooth stack.
[  OK  ] Started Simple Network Management Protocol (SNMP) Daemon..
[   19.918987] Initializing XFRM netlink socket
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org am437x-evm ttyS0
Arago 2017.10 am437x-evm ttyS0
am437x-evm login: [   22.276876] random: crng init done
[   26.397945] ti-pruss 54400000.pruss: creating PRU cores and other child platform devices
[   26.503029] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/intc@54420000 !
[   26.573469] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/intc@54420000 !
[   26.738139] ti-pruss 54440000.pruss: creating PRU cores and other child platform devices
[   26.822315] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54440000/intc@54460000 !
[   26.846497] usbcore: registered new interface driver usbfs
[   26.864029] usbcore: registered new interface driver hub
[   26.864676] usbcore: registered new device driver usb
[   26.889518] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.889561] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[   26.892789] xhci-hcd xhci-hcd.3.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x02010010
[   26.904068] xhci-hcd xhci-hcd.3.auto: irq 258, io mem 0x48390000
[   26.912057] hub 1-0:1.0: USB hub found
[   26.913872] hub 1-0:1.0: 1 port detected
[   26.915924] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[   26.915946] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[   26.921362] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   26.931355] hub 2-0:1.0: USB hub found
[   26.934045] hub 2-0:1.0: 1 port detected
[   26.939996] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[   26.940033] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 3
[   26.940624] xhci-hcd xhci-hcd.4.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x02010010
[   26.969780] xhci-hcd xhci-hcd.4.auto: irq 259, io mem 0x483d0000
[   26.971526] hub 3-0:1.0: USB hub found
[   26.971995] hub 3-0:1.0: 1 port detected
[   26.973410] xhci-hcd xhci-hcd.4.auto: xHCI Host Controller
[   26.973433] xhci-hcd xhci-hcd.4.auto: new USB bus registered, assigned bus number 4
[   26.974356] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[   26.976415] hub 4-0:1.0: USB hub found
[   26.976477] hub 4-0:1.0: 1 port detected
[   28.015103] irq: no irq domain found for /ocp@44000000/pruss_soc_bus@54426000/pruss@54440000/intc@54460000 !
[   28.213705] remoteproc remoteproc1: 54434000.pru0 is available
[   28.222252] pru-rproc 54434000.pru0: PRU rproc node /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/pru@54434000 probed successfully
**************************************************************[   28.332221] remoteproc remoteproc2: 54438000.pru1 is available
NOTICE: This file system contains the following GPLv3 packages:
        autoconf
        binutils
        cifs-utils
        cpp-symlinks
        cpp
        dosfstools
        g++-symlinks
        g++
        gawk-dev
        gawk
        gcc-symlinks
        gcc
        gdb
        gdbserver
        glmark2
        gstreamer1.0-libav
        hidapi
        libcairo-perf-utils
        libgmp10
        libidn11
        libmpc3
        libmpfr4
        libreadline-dev
        libreadline6
        m4-dev
        m4
        make
        nettle
        [   28.383494] pru-rproc 54438000.pru1: PRU rproc node /ocp@44000000/pruss_soc_bus@54426000/pruss@54400000/pru@54438000 probed successy
swig-dev
        swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution.  This can be done using
the opkg remove command.  i.e.:
    opkg[   28.442819] remoteproc remoteproc3: 54474000.pru0 is available
 remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
      will be notified of the dependent packages.  You [   28.468685] pru-rproc 54474000.pru0: PRU rproc node /ocp@44000000/pruss_soc_bus@5442y
should
      use the --force-removal-of-dependent-packages option to
      also remove the dependent packages as well
*******[   28.516405] remoteproc remoteproc4: 54478000.pru1 is available
******[   28.544082] pru-rproc 54478000.pru1: PRU rproc node /ocp@44000000/pruss_soc_bus@54426000/pruss@54440000/pru@54478000 probed successfuy
[   28.993459] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
 _____                    _____           _         _
              |___|                    |___|
am437x-evm login: root
^[[38;143Rroot@am437x-evm:~# ;143R
-sh: syntax error near unexpected token `;'
root@am437x-evm:~#
Any help why mmc2 is not getting detected?? What i am missing??
  • If you check the am437x-gp-evm.dts file you would see that mmc3 dma channels are on the cross bar and need to be mapped.
    I don't see this on your .dts above and this is probably why dma channel allocation is failing for you.
    &mmc3 {
    status = "okay";
    dmas = <&edma_xbar 30 0 1>,
    <&edma_xbar 31 0 2>;
    dma-names = "tx", "rx";
    vmmc-supply = <&vmmcwl_fixed>;
    bus-width = <4>;
    pinctrl-names = "default", "sleep";
    pinctrl-0 = <&mmc3_pins_default>;
    pinctrl-1 = <&mmc3_pins_sleep>;
    cap-power-off-card;
    ti,non-removable;
    #size-cells = <0>;
    wlcore: wlcore@0 {
    reg = <2>;
    interrupt-parent = <&gpio1>;
    interrupts = <23 IRQ_TYPE_LEVEL_HIGH>;
    BR,
    Eyal
  • Hi Eyal,
    I already tried that, but still the same errors. The SDIO interface is not getting initiallised. The updated mmc3 node looks like:
    &mmc3 {
           status = "okay";
           dmas = <&edma 32
                   &edma 33>;
           bus-width = <4>;
           broken-cd;
           disable-wp;
           cap-power-off-card;
           ti,non-removable;
           #size-cells = <0>;
           wlcore: wlcore@0 {
                   reg = <2>;
    &edma {
           ti,edma-xbar-event-map = /bits/ 16 <1 32
        2 33>;
           vmmcwl_fixed: fixedregulator-mmcwl {
                   compatible = "regulator-fixed";
                   regulator-name = "vmmcwl_fixed";
                   regulator-min-microvolt = <1800000>;
                   regulator-max-microvolt = <1800000>;
                   regulator-always-on;
                   enable-gpios = <&gpio5 11 GPIO_ACTIVE_LOW>; /* (Wlan_TXR_EN)*/
                   gpio = <&gpio5 10 GPIO_ACTIVE_HIGH>;   /*(WL_EN)*/
                   startup-delay-us = <70000>;
                   enable-active-high;
    NOTE: The same configuration is working with kernel 4.1 provided in linux-sdk 02.00.00.07.
    After this changes I am getting these errors:
    [    1.333856] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@47810000[0]'
    [    1.333862] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@47810000[0]'
    [    1.333867] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
    [    1.333872] omap_hsmmc 47810000.mmc: lookup for GPIO cd failed
    [    1.333879] omap_hsmmc 47810000.mmc: GPIO lookup for consumer wp
    [    1.333883] omap_hsmmc 47810000.mmc: using device tree for GPIO lookup
    [    1.333887] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@47810000[0]'
    [    1.333892] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@47810000[0]'
    [    1.333895] omap_hsmmc 47810000.mmc: using lookup tables for GPIO lookup
    [    1.333900] omap_hsmmc 47810000.mmc: lookup for GPIO wp failed
    [    1.334089] OF: /ocp@44000000/mmc@47810000: could not get #dma-cells for /ocp@44000000/l4_wkup@44c00000/prcm@1f0000/clocks/gfx_fclk_clksel_ck@423c
    [    1.350321] omap_hsmmc 47810000.mmc: RX DMA channel request failed
    [    1.381817] mmc0: host does not support reading read-only switch, assuming write-enable
    Still SDIO interface is not initialized.
    warm regards,
    Vimal
    I think you should change the dma settings as they are for the am437x-gp-evm for this 4.9.x kernel.
    Meaning:
    &mmc3 {
    status = "okay";
    What you have seems like an older method for setting xbar dma channels that has been updated.
    BR,
    Eyal
  • Hi Eyal,
    Actually I did that before. With these changes also i am getting the same error:
    Meanwhile I probed the WLAN_EN lines, It is not "HIGH", The voltage level is around 1.8, which is neither high nor low.
    I am also facing similar problem with another gpio also. It seems like pin-muxing configuration from dts is not working properly, something is resetting the values.
    I am not able to find out why this is happening, gpio is not also responding to sysfs changes.
    for example: I exported the gpio2_3 and tried to toggle the value but its not responding to the values written:
    root@am437x-evm:~# echo 67 > /sys/class/gpio/export
    root@am437x-evm:~# echo out > /sys/class/gpio/gpio67/direction
    root@am437x-evm:~#
    root@am437x-evm:~# echo 1 > /sys/class/gpio/gpio67/value
    root@am437x-evm:~# cat /sys/class/gpio/gpio67/value
    1
    root@am437x-evm:~# echo 0 > /sys/class/gpio/gpio67/value
    0
    root@am437x-evm:~#
    The values are changing but its not affecting the gpio voltage level. The gpio is always HIGH.
    Any idea why this is happening, Why dts configuration for mux-mode is not working properly?
  • Hi Vimal,
    I suggest to concentrate first on this error. as this is fatal.
    Nee to make sure that this channel is not assigned already for another peripheral that is enabled in your .dts file.
    As this is a crossbar mapping perhaps something new was added and you need to pick another channel number?
    BR,
    Eyal
  • Can you try with channels 32 and 33 instead of 30 and 31?:
    dmas = <&edma_xbar 32 0 1>,
    <&edma_xbar 33 0 2>;
    BR,
    Eyal
  • Hi Eyal,
    Thanks for looking into this, with the change you have suggested and some pin-muxing mode change now i am getting the mmc2 registered as SDIO device.
    Now wifi is also working.
