WL18XXCOM82SDMMC: Executing command in script is different to executing the same command in command library
Part Number: WL18XXCOM82SDMMC
In HCITester tool, if highlight the command in Command Library
HCI_Set_Event_Filter
and the value Window shows the parameters:
Type: sc
Opcode: 0x0c05
Filter type: (0x02) Connection Setup
Result Filter Type: (0x00) All Devices
Auto Accept Flag: (0x03) Accept with role switch enabled
This command executed correctly.
But if put the same command in a script:
Send_HCI_Set_Event_Filter 0x0C05, 0x02, 0x00, 0x03
It returns error from execution:
ERROR - Invalid argument value "0x00"
then check the command library again:
In the value Window, the 3rd parameters has been changed to
BD Addess of the device: BD_ADDR
Was the command in script wrong? or any additional commands need to run together, this command was executed after TTInit-11.8.32.bts executed.
Thanks for reply.
Shengchu
  • hi, can you post hci tester and firmware logs ?
    Saurabh
  • 16:47:37.913 Loading Library "C:\ti-bt-service-packs\xml\TIInit_11.8.32.xml"...
    16:47:38.007 Load Succeeded
    16:47:38.007 --
    16:47:38.007 VersionPlatform = "DIAMOND"
    16:47:38.007 VersionMajor = 8
    16:47:38.007 VersionMinor = 32
    16:47:38.007 --
    16:48:17.165 *** Script Started: "C:\Users\szhang\HCIScript115200.txt" ***
    16:48:17.165 --
    16:48:17.165 Packet "HCI_VS_Update_Uart_HCI_Baudrate", Opcode 0xff36
    16:48:17.165 Parameters:
    16:48:17.165 | Uart Baudrate : 0x0001c200
    16:48:17.165 --
    16:48:17.165 Outgoing Dump:
    16:48:17.165 0000: 01 36 ff 04 00 c2 01 00 .6......
    16:48:17.165 Incoming Dump:
    16:48:17.165 0000: 04 0e 04 01 36 ff 00 ....6..
    16:48:17.165 --
    16:48:17.165 Packet "HCI_Command_Complete_VS_Update_Uart_HCI_Baudrate_Event", Opcode 0xff36
    16:48:17.165 | Number HCI commands : 0x01
    16:48:17.165 | Command Opcode : 0xff36
    16:48:17.165 | Status : 0x00 (Success)
    16:48:17.165 --
    16:48:17.181 --
    16:48:17.181 Packet "HCI_VS_Start_VS_Lock", Opcode 0xfe37
    16:48:17.181 Parameters:
    16:48:17.181 | Major Version Number : 0x08
    16:48:17.181 | Minor Version Number : 0x20
    16:48:17.181 --
    16:48:17.181 Outgoing Dump:
    16:48:17.181 0000: 01 37 fe 02 08 20 .7...
    16:48:17.181 Incoming Dump:
    16:48:17.181 0000: 04 0e 04 01 37 fe 00 ....7..
    16:48:17.181 --
    16:48:17.181 Packet "HCI_Command_Complete_VS_Start_VS_Lock_Event", Opcode 0xfe37
    16:48:17.181 | Number HCI commands : 0x01
    16:48:17.181 | Command Opcode : 0xfe37
    16:48:17.181 | Status : 0x00 (Success)
    16:48:17.181 --
    16:48:17.181 --
    16:48:17.181 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:17.181 | Address : 0x200377b2
    16:48:17.181 | Type : 0x04
    16:48:17.181 | Value : 0x0008000a
    16:48:17.181 --
    16:48:17.181 0000: 01 03 ff 09 b2 77 03 20 04 0a 00 08 00 .....w. .....
    16:48:17.196 Incoming Dump:
    16:48:17.196 0000: 04 0e 04 01 03 ff 00 .......
    16:48:17.196 --
    16:48:17.196 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:17.196 Parameters:
    16:48:17.196 | Number HCI commands : 0x01
    16:48:17.196 | Command Opcode : 0xff03
    16:48:17.196 | Status : 0x00 (Success)
    16:48:17.196 --
    16:48:17.196 --
    16:48:17.196 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.196 | Address : 0x001a0000
    16:48:17.196 | Size : 0xf0
    16:48:17.196 | Values : "2D:E9:F0:43:07:46:77:4C:F8:7A:75:4E:25:46:2D:1D:A8:70:38:7B:02:21:E8:70:38:46:B0:47:28:80:07:F1:0F:01:20:46:09:88:0A:30:01:80:06:21:38:46:B0:47:4F:F0:01:08:E8:81:85:F8:04:80:38:7D:68:71:78:7D:A8:72:B8:7D:E8:72:F8:7D:28:73:07:F1:18:00:00:68:07:F1:1C:01:20:60:20:46:09:68:00:F1:14:00:01:60:97:F8:20:00:07:F1:21:01:28:75:20:46:0A:68:00:F1:1A:00:02:60:49:68:41:60:69:4E:97:F8:29:00:B0:70:18:B9:00:21:F1:60:08:46:09:E0:DF:F8:98:91:1F:21:38:46:C8:47:F0:60:23:21:38:46:C8:47:00:21:30:61:24:1F:61:48:85:F8:15:80:20:60:E8:89:B0:80:4F:F4:B9:70:F0:80:31:70:B1:60:71:70:BD:E8:F0:83:F0:B5:5A:4C:21:88:21:F0:01:01:59:4D:21:80:21:88:6F:F3:DF:31:21:80:21:88:21:F4:80:41:21:80:29:88:6F:F3:1F:31:41:F4:80:51:29:80:85:49:0A:88:60:F3:03:02"
    16:48:17.196 --
    16:48:17.196 Outgoing Dump:
    16:48:17.196 0000: 01 05 ff f5 00 00 1a 00 f0 2d e9 f0 43 07 46 77 .........-..C.Fw
    16:48:17.196 0010: 4c f8 7a 75 4e 25 46 2d 1d a8 70 38 7b 02 21 e8 L.zuN%F-..p8{.!.
    16:48:17.196 0020: 70 38 46 b0 47 28 80 07 f1 0f 01 20 46 09 88 0a p8F.G(..... F...
    16:48:17.196 0030: 30 01 80 06 21 38 46 b0 47 4f f0 01 08 e8 81 85 0...!8F.GO......
    16:48:17.196 0040: f8 04 80 38 7d 68 71 78 7d a8 72 b8 7d e8 72 f8 ...8}hqx}.r.}.r.
    16:48:17.196 0050: 7d 28 73 07 f1 18 00 00 68 07 f1 1c 01 20 60 20 }(s.....h.... `
    16:48:17.196 0060: 46 09 68 00 f1 14 00 01 60 97 f8 20 00 07 f1 21 F.h.....`.. ...!
    16:48:17.196 0070: 01 28 75 20 46 0a 68 00 f1 1a 00 02 60 49 68 41 .(u F.h.....`IhA
    16:48:17.196 0080: 60 69 4e 97 f8 29 00 b0 70 18 b9 00 21 f1 60 08 `iN..)..p...!.`.
    16:48:17.196 0090: 46 09 e0 df f8 98 91 1f 21 38 46 c8 47 f0 60 23 F.......!8F.G.`#
    16:48:17.196 00a0: 21 38 46 c8 47 00 21 30 61 24 1f 61 48 85 f8 15 !8F.G.!0a$.aH...
    16:48:17.196 00b0: 80 20 60 e8 89 b0 80 4f f4 b9 70 f0 80 31 70 b1 . `....O..p..1p.
    16:48:17.196 00c0: 60 71 70 bd e8 f0 83 f0 b5 5a 4c 21 88 21 f0 01 `qp......ZL!.!..
    16:48:17.196 00d0: 01 59 4d 21 80 21 88 6f f3 df 31 21 80 21 88 21 .YM!.!.o..1!.!.!
    16:48:17.196 00e0: f4 80 41 21 80 29 88 6f f3 1f 31 41 f4 80 51 29 ..A!.).o..1A..Q)
    16:48:17.196 00f0: 80 85 49 0a 88 60 f3 03 02 ..I..`...
    16:48:17.228 Incoming Dump:
    16:48:17.228 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.228 --
    16:48:17.228 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.228 Parameters:
    16:48:17.228 | Number HCI commands : 0x01
    16:48:17.228 | Command Opcode : 0xff05
    16:48:17.228 | Status : 0x00 (Success)
    16:48:17.228 --
    16:48:17.228 --
    16:48:17.228 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.228 | Address : 0x001a00f0
    16:48:17.228 | Size : 0xf0
    16:48:17.228 | Values : "0A:80:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:7A:48:21:88:08:43:20:80:20:88:40:F0:01:00:20:80:28:88:20:F4:80:70:28:80:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:82:4E:28:88:40:F4:80:70:28:80:32:20:B0:47:20:88:40:F4:80:40:20:80:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:00:BF:20:88:50:27:20:F4:80:40:20:80:01:E0:01:20:B0:47:28:46:00:1F:00:88:40:0A:04:D3:38:46:41:1E:00:28:8F:B2:F3:D1:A0:88:21:88:C0:F3:09:00:21:F0:01:01:21:80:F0:BD"
    16:48:17.228 --
    16:48:17.228 Outgoing Dump:
    16:48:17.228 0000: 01 05 ff f5 f0 00 1a 00 f0 0a 80 00 bf 00 bf 00 ................
    16:48:17.228 0010: bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 ................
    16:48:17.228 0020: bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 ................
    16:48:17.228 0030: bf 00 bf 7a 48 21 88 08 43 20 80 20 88 40 f0 01 ...zH!..C . .@..
    16:48:17.228 0040: 00 20 80 28 88 20 f4 80 70 28 80 00 bf 00 bf 00 . .(. ..p(......
    16:48:17.228 0050: bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 ................
    16:48:17.228 0060: bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 ................
    16:48:17.228 0070: bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 ................
    16:48:17.228 0080: bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 ................
    16:48:17.228 0090: bf 00 bf 00 bf 00 bf 00 bf 00 bf 82 4e 28 88 40 ............N(.@
    16:48:17.228 00a0: f4 80 70 28 80 32 20 b0 47 20 88 40 f4 80 40 20 ..p(.2 .G .@..@
    16:48:17.228 00b0: 80 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 bf 00 ................
    16:48:17.228 00c0: bf 00 bf 00 bf 20 88 50 27 20 f4 80 40 20 80 01 ..... .P' ..@ ..
    16:48:17.228 00d0: e0 01 20 b0 47 28 46 00 1f 00 88 40 0a 04 d3 38 .. .G(F....@...8
    16:48:17.228 00e0: 46 41 1e 00 28 8f b2 f3 d1 a0 88 21 88 c0 f3 09 FA..(......!....
    16:48:17.228 00f0: 00 21 f0 01 01 21 80 f0 bd .!...!...
    16:48:17.259 Incoming Dump:
    16:48:17.259 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.259 --
    16:48:17.259 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.259 Parameters:
    16:48:17.259 | Number HCI commands : 0x01
    16:48:17.259 | Command Opcode : 0xff05
    16:48:17.259 | Status : 0x00 (Success)
    16:48:17.259 --
    16:48:17.259 --
    16:48:17.259 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.259 | Address : 0x001a01e0
    16:48:17.259 | Size : 0xf0
    16:48:17.259 | Values : "E1:D2:00:00:58:2A:08:20:F0:B5:8C:B2:86:B2:07:0C:09:0C:04:FB:06:F5:01:FB:07:F0:7C:43:71:43:A7:B2:8E:B2:09:0C:F6:19:01:EB:14:41:06:EB:15:44:24:0C:18:BF:49:1C:05:EB:06:45:08:18:1D:60:10:60:F0:BD:B4:DC:08:20:25:D1:00:00:FC:2D:03:20:80:21:0C:20:86:21:0C:20:2D:E9:F0:4F:AD:F1:14:0D:0F:46:55:48:53:49:04:93:00:78:0C:5A:15:46:04:2C:B4:BF:04:F2:DE:44:24:1F:DF:F8:98:A2:A6:4A:DA:F8:00:10:38:68:A4:B2:00:91:AD:F8:04:40:90:47:00:28:48:BF:40:42:2A:1B:A1:49:40:F2:E2:44:60:43:15:18:10:18:88:47:4F:F0:00:09:EE:17:80:46:15:EB:08:05:DF:F8:6C:82:4F:F0:7D:02:4B:46:4F:EA:95:70:56:EB:09:06:B1:00:01:43:A8:00:C0:47:93:46:4B:46:28:46:31:46:22:46:C0:47:90:46:22:46:A1:4C:4B:46:31:46:28:46:A0:47:9F:4C:02:46:41:46:02:AB:68:46:A0:47:9A:F8:0C:00"
    16:48:17.259 --
    16:48:17.259 Outgoing Dump:
    16:48:17.259 0000: 01 05 ff f5 e0 01 1a 00 f0 e1 d2 00 00 58 2a 08 .............X*.
    16:48:17.259 0010: 20 f0 b5 8c b2 86 b2 07 0c 09 0c 04 fb 06 f5 01 ...............
    16:48:17.259 0020: fb 07 f0 7c 43 71 43 a7 b2 8e b2 09 0c f6 19 01 ...|CqC.........
    16:48:17.259 0030: eb 14 41 06 eb 15 44 24 0c 18 bf 49 1c 05 eb 06 ..A...D$...I....
    16:48:17.259 0040: 45 08 18 1d 60 10 60 f0 bd b4 dc 08 20 25 d1 00 E...`.`..... %..
    16:48:17.259 0050: 00 fc 2d 03 20 80 21 0c 20 86 21 0c 20 2d e9 f0 ..-. .!. .!. -..
    16:48:17.259 0060: 4f ad f1 14 0d 0f 46 55 48 53 49 04 93 00 78 0c O.....FUHSI...x.
    16:48:17.259 0070: 5a 15 46 04 2c b4 bf 04 f2 de 44 24 1f df f8 98 Z.F.,.....D$....
    16:48:17.259 0080: a2 a6 4a da f8 00 10 38 68 a4 b2 00 91 ad f8 04 ..J....8h.......
    16:48:17.259 0090: 40 90 47 00 28 48 bf 40 42 2a 1b a1 49 40 f2 e2 @.G.(H.@B*..I@..
    16:48:17.259 00a0: 44 60 43 15 18 10 18 88 47 4f f0 00 09 ee 17 80 D`C.....GO......
    16:48:17.259 00b0: 46 15 eb 08 05 df f8 6c 82 4f f0 7d 02 4b 46 4f F......l.O.}.KFO
    16:48:17.259 00c0: ea 95 70 56 eb 09 06 b1 00 01 43 a8 00 c0 47 93 ..pV......C...G.
    16:48:17.259 00d0: 46 4b 46 28 46 31 46 22 46 c0 47 90 46 22 46 a1 FKF(F1F"F.G.F"F.
    16:48:17.259 00e0: 4c 4b 46 31 46 28 46 a0 47 9f 4c 02 46 41 46 02 LKF1F(F.G.L.FAF.
    16:48:17.259 00f0: ab 68 46 a0 47 9a f8 0c 00 .hF.G....
    16:48:17.290 Incoming Dump:
    16:48:17.290 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.290 --
    16:48:17.290 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.290 Parameters:
    16:48:17.290 | Number HCI commands : 0x01
    16:48:17.290 | Command Opcode : 0xff05
    16:48:17.290 | Status : 0x00 (Success)
    16:48:17.290 --
    16:48:17.290 --
    16:48:17.290 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.290 | Address : 0x001a02d0
    16:48:17.290 | Size : 0xf0
    16:48:17.290 | Values : "0B:EB:00:01:28:29:07:DB:00:9A:02:98:90:42:04:BF:40:1C:20:F0:7C:40:00:E0:02:98:28:22:38:60:91:FB:F2:F0:50:43:09:1A:04:98:05:B0:01:80:BD:E8:F0:8F:8A:21:0C:20:00:80:FF:FF:2D:E9:F0:41:A0:4E:07:46:DF:F8:84:82:9F:4D:F0:78:01:28:22:D1:F8:08:20:D3:02:20:F0:70:40:46:01:78:28:88:2C:46:61:F3:05:10:28:80:20:88:20:F0:08:00:20:80:9E:48:80:47:9E:48:01:78:20:29:09:D1:C0:7D:38:B9:20:88:40:F0:08:00:20:80:20:88:20:F0:30:00:20:80:9F:49:4F:F4:80:70:08:80:30:78:80:B1:78:08:0E:D2:40:46:01:78:28:88:61:F3:05:10:28:80:28:88:20:F0:08:00:28:80:97:48:80:47:97:49:00:20:88:47:BD:E8:F0:81:8B:75:06:00:00:61:0E:20:75:2A:0A:00:2D:E9:F8:47:7E:4E:81:46:08:36:30:6D:81:45:00:F0:A0:80:00:24:01:27:A0:4D:DF:F8:78:A2:C6:F8:50:90:A0:46:9E:49:B8:B2:88:47"
    16:48:17.290 --
    16:48:17.290 Outgoing Dump:
    16:48:17.290 0000: 01 05 ff f5 d0 02 1a 00 f0 0b eb 00 01 28 29 07 .............().
    16:48:17.290 0010: db 00 9a 02 98 90 42 04 bf 40 1c 20 f0 7c 40 00 ......B..@. .|@.
    16:48:17.290 0020: e0 02 98 28 22 38 60 91 fb f2 f0 50 43 09 1a 04 ...("8`....PC...
    16:48:17.290 0030: 98 05 b0 01 80 bd e8 f0 8f 8a 21 0c 20 00 80 ff ..........!. ...
    16:48:17.290 0040: ff 2d e9 f0 41 a0 4e 07 46 df f8 84 82 9f 4d f0 .-..A.N.F.....M.
    16:48:17.290 0050: 78 01 28 22 d1 f8 08 20 d3 02 20 f0 70 40 46 01 x.("... .. .p@F.
    16:48:17.290 0060: 78 28 88 2c 46 61 f3 05 10 28 80 20 88 20 f0 08 x(.,Fa...(. . ..
    16:48:17.290 0070: 00 20 80 9e 48 80 47 9e 48 01 78 20 29 09 d1 c0 . ..H.G.H.x )...
    16:48:17.290 0080: 7d 38 b9 20 88 40 f0 08 00 20 80 20 88 20 f0 30 }8. .@... . . .0
    16:48:17.290 0090: 00 20 80 9f 49 4f f4 80 70 08 80 30 78 80 b1 78 . ..IO..p..0x..x
    16:48:17.290 00a0: 08 0e d2 40 46 01 78 28 88 61 f3 05 10 28 80 28 ...@F.x(.a...(.(
    16:48:17.290 00b0: 88 20 f0 08 00 28 80 97 48 80 47 97 49 00 20 88 . ...(..H.G.I. .
    16:48:17.290 00c0: 47 bd e8 f0 81 8b 75 06 00 00 61 0e 20 75 2a 0a G.....u...a. u*.
    16:48:17.290 00d0: 00 2d e9 f8 47 7e 4e 81 46 08 36 30 6d 81 45 00 .-..G~N.F.60m.E.
    16:48:17.290 00e0: f0 a0 80 00 24 01 27 a0 4d df f8 78 a2 c6 f8 50 ....$.'.M..x...P
    16:48:17.290 00f0: 90 a0 46 9e 49 b8 b2 88 47 ..F.I...G
    16:48:17.321 Incoming Dump:
    16:48:17.321 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.321 --
    16:48:17.321 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.321 Parameters:
    16:48:17.321 | Number HCI commands : 0x01
    16:48:17.321 | Command Opcode : 0xff05
    16:48:17.321 | Status : 0x00 (Success)
    16:48:17.321 --
    16:48:17.321 --
    16:48:17.321 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.321 | Address : 0x001a03c0
    16:48:17.321 | Size : 0xf0
    16:48:17.321 | Values : "30:B3:01:78:B4:22:02:FB:01:A1:01:F1:50:03:40:31:0A:7B:02:2A:1C:D1:09:78:09:B1:4F:F0:04:08:96:4A:19:78:32:F8:11:30:95:F8:5E:10:4F:EA:C1:0C:9C:45:0E:DA:95:F8:5F:20:11:01:01:EB:82:11:61:44:99:42:06:DD:C0:78:00:28:0C:BF:44:F0:02:04:44:F0:01:04:7F:1C:07:2F:D1:D9:89:4F:70:78:B8:F1:00:0F:04:D1:10:B1:4F:F0:00:00:70:70:22:E0:00:28:06:BF:48:46:70:65:70:6D:04:21:71:70:2E:4A:31:78:40:18:20:F0:7C:40:49:46:90:47:00:28:05:DC:28:6B:40:09:00:F0:04:01:0C:43:03:E0:28:6B:44:F0:04:04:40:09:71:6D:C0:F3:0A:02:4B:46:00:91:4F:F4:EA:70:21:46:B8:47:73:49:03:20:88:47:28:6B:72:49:C0:F3:42:12:A2:42:31:D0:64:F3:4F:10:28:63:A8:7C:40:1C:A8:74:95:F8:E6:00:40:1C:85:F8:E6:00:03:20:88:47:4E:48:4F:F4:00:71:3E:30:01:80:9D:48:01:78:FF:29:08:D0:01:20"
    16:48:17.321 --
    16:48:17.321 Outgoing Dump:
    16:48:17.321 0000: 01 05 ff f5 c0 03 1a 00 f0 30 b3 01 78 b4 22 02 .........0..x.".
    16:48:17.321 0010: fb 01 a1 01 f1 50 03 40 31 0a 7b 02 2a 1c d1 09 .....P.@1.{.*...
    16:48:17.321 0020: 78 09 b1 4f f0 04 08 96 4a 19 78 32 f8 11 30 95 x..O....J.x2..0.
    16:48:17.321 0030: f8 5e 10 4f ea c1 0c 9c 45 0e da 95 f8 5f 20 11 .^.O....E...._ .
    16:48:17.321 0040: 01 01 eb 82 11 61 44 99 42 06 dd c0 78 00 28 0c .....aD.B...x.(.
    16:48:17.321 0050: bf 44 f0 02 04 44 f0 01 04 7f 1c 07 2f d1 d9 89 .D...D....../...
    16:48:17.321 0060: 4f 70 78 b8 f1 00 0f 04 d1 10 b1 4f f0 00 00 70 Opx........O...p
    16:48:17.321 0070: 70 22 e0 00 28 06 bf 48 46 70 65 70 6d 04 21 71 p"..(..HFpepm.!q
    16:48:17.321 0080: 70 2e 4a 31 78 40 18 20 f0 7c 40 49 46 90 47 00 p.J1x@. .|@IF.G.
    16:48:17.321 0090: 28 05 dc 28 6b 40 09 00 f0 04 01 0c 43 03 e0 28 (..(k@......C..(
    16:48:17.321 00a0: 6b 44 f0 04 04 40 09 71 6d c0 f3 0a 02 4b 46 00 kD...@.qm....KF.
    16:48:17.321 00b0: 91 4f f4 ea 70 21 46 b8 47 73 49 03 20 88 47 28 .O..p!F.GsI. .G(
    16:48:17.321 00c0: 6b 72 49 c0 f3 42 12 a2 42 31 d0 64 f3 4f 10 28 krI..B..B1.d.O.(
    16:48:17.321 00d0: 63 a8 7c 40 1c a8 74 95 f8 e6 00 40 1c 85 f8 e6 c.|@..t....@....
    16:48:17.321 00e0: 00 03 20 88 47 4e 48 4f f4 00 71 3e 30 01 80 9d .. .GNHO..q>0...
    16:48:17.321 00f0: 48 01 78 ff 29 08 d0 01 20 H.x.)...
    16:48:17.353 Incoming Dump:
    16:48:17.353 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.353 --
    16:48:17.353 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.353 Parameters:
    16:48:17.353 | Number HCI commands : 0x01
    16:48:17.353 | Command Opcode : 0xff05
    16:48:17.353 | Status : 0x00 (Success)
    16:48:17.353 --
    16:48:17.353 --
    16:48:17.353 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.353 | Address : 0x001a04b0
    16:48:17.353 | Size : 0xf0
    16:48:17.353 | Values : "9B:4A:88:40:11:68:01:43:11:60:11:68:81:43:11:60:A4:48:00:68:95:F8:E6:30:00:90:28:6B:C0:F3:4A:11:A8:7C:4F:F4:7A:72:02:FB:00:32:4B:46:4F:F4:D7:70:B8:47:BD:E8:F8:87:03:20:88:47:BD:E8:F8:87:C0:46:54:6E:08:20:01:C4:07:00:8D:B8:08:20:A1:AB:08:00:03:69:40:F2:1F:41:99:42:07:D8:0A:46:02:F1:02:02:9A:42:12:D3:90:4A:E2:32:42:63:90:4A:B3:F5:7E:7F:03:D1:10:78:00:F0:FB:00:10:70:A1:F1:28:01:99:42:03:D1:10:78:00:F0:F7:00:10:70:70:47:A1:AB:08:00:A7:B8:08:20:10:B5:01:22:85:49:87:4B:0A:80:19:46:55:31:0C:78:72:49:FF:2C:03:D0:A2:40:0C:68:22:43:0A:60:0D:4A:B1:F8:1C:45:12:78:62:F3:05:14:A1:F8:1C:45:B1:F8:1C:25:22:F0:08:02:A1:F8:1C:25:79:4A:01:61:30:32:19:46:42:63:3C:31:81:61:10:BD:C0:46:34:82:08:20:20:F5:0E:20:D0:DC:08:20:1C:B5:74:4C"
    16:48:17.353 --
    16:48:17.353 Outgoing Dump:
    16:48:17.353 0000: 01 05 ff f5 b0 04 1a 00 f0 9b 4a 88 40 11 68 01 ..........J.@.h.
    16:48:17.353 0010: 43 11 60 11 68 81 43 11 60 a4 48 00 68 95 f8 e6 C.`.h.C.`.H.h...
    16:48:17.353 0020: 30 00 90 28 6b c0 f3 4a 11 a8 7c 4f f4 7a 72 02 0..(k..J..|O.zr.
    16:48:17.353 0030: fb 00 32 4b 46 4f f4 d7 70 b8 47 bd e8 f8 87 03 ..2KFO..p.G.....
    16:48:17.353 0040: 20 88 47 bd e8 f8 87 c0 46 54 6e 08 20 01 c4 07 .G.....FTn. ...
    16:48:17.353 0050: 00 8d b8 08 20 a1 ab 08 00 03 69 40 f2 1f 41 99 .... .....i@..A.
    16:48:17.353 0060: 42 07 d8 0a 46 02 f1 02 02 9a 42 12 d3 90 4a e2 B...F.....B...J.
    16:48:17.353 0070: 32 42 63 90 4a b3 f5 7e 7f 03 d1 10 78 00 f0 fb 2Bc.J..~....x...
    16:48:17.353 0080: 00 10 70 a1 f1 28 01 99 42 03 d1 10 78 00 f0 f7 ..p..(..B...x...
    16:48:17.353 0090: 00 10 70 70 47 a1 ab 08 00 a7 b8 08 20 10 b5 01 ..ppG....... ...
    16:48:17.353 00a0: 22 85 49 87 4b 0a 80 19 46 55 31 0c 78 72 49 ff ".I.K...FU1.xrI.
    16:48:17.353 00b0: 2c 03 d0 a2 40 0c 68 22 43 0a 60 0d 4a b1 f8 1c ,...@.h"C.`.J...
    16:48:17.353 00c0: 45 12 78 62 f3 05 14 a1 f8 1c 45 b1 f8 1c 25 22 E.xb......E...%"
    16:48:17.353 00d0: f0 08 02 a1 f8 1c 25 79 4a 01 61 30 32 19 46 42 ......%yJ.a02.FB
    16:48:17.353 00e0: 63 3c 31 81 61 10 bd c0 46 34 82 08 20 20 f5 0e c<1.a...F4.. ..
    16:48:17.353 00f0: 20 d0 dc 08 20 1c b5 74 4c ... ..tL
    16:48:17.400 Incoming Dump:
    16:48:17.400 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.400 --
    16:48:17.400 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.400 Parameters:
    16:48:17.400 | Number HCI commands : 0x01
    16:48:17.400 | Command Opcode : 0xff05
    16:48:17.400 | Status : 0x00 (Success)
    16:48:17.400 --
    16:48:17.400 --
    16:48:17.400 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.400 | Address : 0x001a05a0
    16:48:17.400 | Size : 0xf0
    16:48:17.400 | Values : "72:49:01:AB:6A:46:A0:47:01:98:00:99:40:0C:40:EA:C1:30:1C:BD:47:7B:08:00:00:30:0C:20:10:B5:04:46:A0:69:6C:49:00:68:81:42:04:D1:6B:48:80:47:6B:48:34:30:60:63:10:BD:C0:46:4E:E8:0C:20:CF:7C:08:00:83:7B:08:00:70:B5:06:46:B5:69:E8:09:1C:D3:64:48:04:88:20:09:05:D3:63:48:80:47:4F:F6:FD:70:20:40:04:46:A0:09:0A:D3:60:48:60:4A:01:78:39:20:90:47:5F:48:80:47:4F:F6:FD:70:20:40:04:46:A0:08:25:F0:40:05:01:D3:5B:48:80:47:B5:61:70:BD:E0:95:08:20:C0:F0:0C:20:D5:38:01:00:20:0C:0E:20:E5:C5:07:00:8B:26:07:00:21:20:07:00:2D:E9:FC:43:52:4D:07:46:DF:F8:5C:91:A8:6A:39:46:00:F5:48:70:20:F0:7C:40:C8:47:DF:F8:40:81:00:28:15:DD:4C:48:01:78:4C:48:AF:62:31:B9:01:89:00:91:41:89:01:91:40:F2:A9:31:05:E0:01:89:00:91:41:89:01:91:4F:F4:67:71:42:68"
    16:48:17.400 --
    16:48:17.400 Outgoing Dump:
    16:48:17.400 0000: 01 05 ff f5 a0 05 1a 00 f0 72 49 01 ab 6a 46 a0 .........rI..jF.
    16:48:17.400 0010: 47 01 98 00 99 40 0c 40 ea c1 30 1c bd 47 7b 08 G....@.@..0..G{.
    16:48:17.400 0020: 00 00 30 0c 20 10 b5 04 46 a0 69 6c 49 00 68 81 ..0. ...F.ilI.h.
    16:48:17.400 0030: 42 04 d1 6b 48 80 47 6b 48 34 30 60 63 10 bd c0 B..kH.GkH40`c...
    16:48:17.400 0040: 46 4e e8 0c 20 cf 7c 08 00 83 7b 08 00 70 b5 06 FN.. .|...{..p..
    16:48:17.400 0050: 46 b5 69 e8 09 1c d3 64 48 04 88 20 09 05 d3 63 F.i....dH.. ...c
    16:48:17.400 0060: 48 80 47 4f f6 fd 70 20 40 04 46 a0 09 0a d3 60 H.GO..p @.F....`
    16:48:17.400 0070: 48 60 4a 01 78 39 20 90 47 5f 48 80 47 4f f6 fd H`J.x9 .G_H.GO..
    16:48:17.400 0080: 70 20 40 04 46 a0 08 25 f0 40 05 01 d3 5b 48 80 p @.F..%.@...[H.
    16:48:17.400 0090: 47 b5 61 70 bd e0 95 08 20 c0 f0 0c 20 d5 38 01 G.ap.... ... .8.
    16:48:17.400 00a0: 00 20 0c 0e 20 e5 c5 07 00 8b 26 07 00 21 20 07 . .. .....&..! .
    16:48:17.400 00b0: 00 2d e9 fc 43 52 4d 07 46 df f8 5c 91 a8 6a 39 .-..CRM.F..\..j9
    16:48:17.400 00c0: 46 00 f5 48 70 20 f0 7c 40 c8 47 df f8 40 81 00 F..Hp .|@.G..@..
    16:48:17.400 00d0: 28 15 dd 4c 48 01 78 4c 48 af 62 31 b9 01 89 00 (..LH.xLH.b1....
    16:48:17.400 00e0: 91 41 89 01 91 40 f2 a9 31 05 e0 01 89 00 91 41 .A...@..1......A
    16:48:17.400 00f0: 89 01 91 4f f4 67 71 42 68 ...O.gqBh
    16:48:17.431 Incoming Dump:
    16:48:17.431 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.431 --
    16:48:17.431 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.431 Parameters:
    16:48:17.431 | Number HCI commands : 0x01
    16:48:17.431 | Command Opcode : 0xff05
    16:48:17.431 | Status : 0x00 (Success)
    16:48:17.431 --
    16:48:17.431 --
    16:48:17.431 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.431 | Address : 0x001a0690
    16:48:17.431 | Size : 0xf0
    16:48:17.431 | Values : "83:68:03:20:C0:47:28:68:39:46:00:F5:48:70:20:F0:7C:40:C8:47:00:28:23:D4:2F:60:00:24:66:1C:41:49:B0:B2:88:47:C8:B1:02:78:B4:21:51:43:3A:4A:51:5C:3D:4A:32:F8:11:10:C3:78:00:91:82:7C:C1:7C:41:EA:02:21:02:7D:42:EA:01:22:41:7D:41:EA:02:21:03:20:01:91:32:46:40:F2:AA:51:C0:47:64:1C:07:2C:DD:D3:68:68:39:46:00:F5:7A:60:20:F0:7C:40:C8:47:00:28:0A:D4:2A:48:01:8B:2D:4C:02:89:43:69:00:91:41:68:6F:60:40:F2:AB:30:A0:47:BD:E8:FC:83:90:77:08:20:04:F0:0E:20:10:B5:04:46:21:8A:40:F2:4D:10:88:42:0E:D1:19:49:20:39:0A:78:02:2A:02:D1:AD:4A:49:6D:90:47:AD:49:00:20:88:47:AC:48:00:F6:8E:10:60:63:10:BD:C0:46:D0:F1:0C:20:97:C4:07:00:86:81:08:20:50:02:01:20:7D:A3:06:00:38:77:08:20:00:77:01:00:E9:01:1A:00:57:A9:06:00:C1:BE:08:20:A3:A2:06:00"
    16:48:17.431 --
    16:48:17.431 Outgoing Dump:
    16:48:17.431 0000: 01 05 ff f5 90 06 1a 00 f0 83 68 03 20 c0 47 28 ..........h. .G(
    16:48:17.431 0010: 68 39 46 00 f5 48 70 20 f0 7c 40 c8 47 00 28 23 h9F..Hp .|@.G.(#
    16:48:17.431 0020: d4 2f 60 00 24 66 1c 41 49 b0 b2 88 47 c8 b1 02 ./`.$f.AI...G...
    16:48:17.431 0030: 78 b4 21 51 43 3a 4a 51 5c 3d 4a 32 f8 11 10 c3 x.!QC:JQ\=J2....
    16:48:17.431 0040: 78 00 91 82 7c c1 7c 41 ea 02 21 02 7d 42 ea 01 x...|.|A..!.}B..
    16:48:17.431 0050: 22 41 7d 41 ea 02 21 03 20 01 91 32 46 40 f2 aa "A}A..!. ..2F@..
    16:48:17.431 0060: 51 c0 47 64 1c 07 2c dd d3 68 68 39 46 00 f5 7a Q.Gd..,..hh9F..z
    16:48:17.431 0070: 60 20 f0 7c 40 c8 47 00 28 0a d4 2a 48 01 8b 2d ` .|@.G.(..*H..-
    16:48:17.431 0080: 4c 02 89 43 69 00 91 41 68 6f 60 40 f2 ab 30 a0 L..Ci..Aho`@..0.
    16:48:17.431 0090: 47 bd e8 fc 83 90 77 08 20 04 f0 0e 20 10 b5 04 G.....w. ... ...
    16:48:17.431 00a0: 46 21 8a 40 f2 4d 10 88 42 0e d1 19 49 20 39 0a F!.@.M..B...I 9.
    16:48:17.431 00b0: 78 02 2a 02 d1 ad 4a 49 6d 90 47 ad 49 00 20 88 x.*...JIm.G.I. .
    16:48:17.431 00c0: 47 ac 48 00 f6 8e 10 60 63 10 bd c0 46 d0 f1 0c G.H....`c...F...
    16:48:17.431 00d0: 20 97 c4 07 00 86 81 08 20 50 02 01 20 7d a3 06 ....... P.. }..
    16:48:17.431 00e0: 00 38 77 08 20 00 77 01 00 e9 01 1a 00 57 a9 06 .8w. .w......W..
    16:48:17.431 00f0: 00 c1 be 08 20 a3 a2 06 00 .... ....
    16:48:17.462 Incoming Dump:
    16:48:17.462 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.462 --
    16:48:17.462 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.462 Parameters:
    16:48:17.462 | Number HCI commands : 0x01
    16:48:17.462 | Command Opcode : 0xff05
    16:48:17.462 | Status : 0x00 (Success)
    16:48:17.462 --
    16:48:17.462 --
    16:48:17.462 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.462 | Address : 0x001a0780
    16:48:17.462 | Size : 0xf0
    16:48:17.462 | Values : "1C:40:01:20:11:7C:04:00:CC:00:01:20:4F:C7:07:00:6D:6D:07:00:C7:46:07:00:FC:DC:08:20:65:A3:08:20:C8:F1:0C:20:01:C6:07:00:30:96:08:20:7C:7D:08:20:01:C4:07:00:D5:38:01:00:20:0C:0E:20:E5:C5:07:00:2D:E9:F0:41:06:46:B4:69:DF:F8:3C:82:21:88:01:F4:7F:42:B2:F5:A8:4F:1B:DC:B2:F5:A8:4F:2E:D0:B2:F5:04:52:00:F0:C3:80:B2:F5:40:72:00:F0:9F:80:85:49:B2:F5:80:72:00:F0:8A:80:81:4D:B2:F5:80:52:75:D0:B2:F5:50:62:3E:D0:B2:F5:00:62:23:D0:BD:E8:F0:81:B2:F5:C0:42:00:F0:D4:80:B2:F5:80:72:00:F0:D0:80:B2:F5:80:72:00:F0:CC:80:B2:F5:80:72:00:F0:C8:80:B2:F5:80:72:00:F0:C4:80:BD:E8:F0:81:C9:B2:04:29:40:F0:D6:80:AC:49:60:7A:88:47:00:28:00:F0:CA:80:BD:E8:F0:81:E2:88:08:46:80:5C:41:01:01:EB:40:21:28:46:45:18:A3:49:0C:20:88:47:01:46:00:29:00:F0"
    16:48:17.462 --
    16:48:17.462 Outgoing Dump:
    16:48:17.462 0000: 01 05 ff f5 80 07 1a 00 f0 1c 40 01 20 11 7c 04 ..........@. .|.
    16:48:17.462 0010: 00 cc 00 01 20 4f c7 07 00 6d 6d 07 00 c7 46 07 .... O...mm...F.
    16:48:17.462 0020: 00 fc dc 08 20 65 a3 08 20 c8 f1 0c 20 01 c6 07 .... e.. ... ...
    16:48:17.462 0030: 00 30 96 08 20 7c 7d 08 20 01 c4 07 00 d5 38 01 .0.. |}. .....8.
    16:48:17.462 0040: 00 20 0c 0e 20 e5 c5 07 00 2d e9 f0 41 06 46 b4 . .. ....-..A.F.
    16:48:17.462 0050: 69 df f8 3c 82 21 88 01 f4 7f 42 b2 f5 a8 4f 1b i..<.!....B...O.
    16:48:17.462 0060: dc b2 f5 a8 4f 2e d0 b2 f5 04 52 00 f0 c3 80 b2 ....O.....R.....
    16:48:17.462 0070: f5 40 72 00 f0 9f 80 85 49 b2 f5 80 72 00 f0 8a .@r.....I...r...
    16:48:17.462 0080: 80 81 4d b2 f5 80 52 75 d0 b2 f5 50 62 3e d0 b2 ..M...Ru...Pb>..
    16:48:17.462 0090: f5 00 62 23 d0 bd e8 f0 81 b2 f5 c0 42 00 f0 d4 ..b#........B...
    16:48:17.462 00a0: 80 b2 f5 80 72 00 f0 d0 80 b2 f5 80 72 00 f0 cc ....r.......r...
    16:48:17.462 00b0: 80 b2 f5 80 72 00 f0 c8 80 b2 f5 80 72 00 f0 c4 ....r.......r...
    16:48:17.462 00c0: 80 bd e8 f0 81 c9 b2 04 29 40 f0 d6 80 ac 49 60 ........)@....I`
    16:48:17.462 00d0: 7a 88 47 00 28 00 f0 ca 80 bd e8 f0 81 e2 88 08 z.G.(...........
    16:48:17.462 00e0: 46 80 5c 41 01 01 eb 40 21 28 46 45 18 a3 49 0c F.\A...@!(FE..I.
    16:48:17.462 00f0: 20 88 47 01 46 00 29 00 f0 .G.F.)..
    16:48:17.493 Incoming Dump:
    16:48:17.493 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.493 --
    16:48:17.493 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.493 Parameters:
    16:48:17.493 | Number HCI commands : 0x01
    16:48:17.493 | Command Opcode : 0xff05
    16:48:17.493 | Status : 0x00 (Success)
    16:48:17.493 --
    16:48:17.493 --
    16:48:17.493 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.493 | Address : 0x001a0870
    16:48:17.493 | Size : 0xf0
    16:48:17.493 | Values : "B9:80:00:2D:00:F0:B6:80:4F:F4:01:60:9F:4A:08:80:28:46:AE:E0:04:F1:08:06:9D:4F:30:46:B8:47:AA:4D:DF:F8:74:82:A9:7B:28:70:01:29:09:D0:02:29:1B:D1:98:4B:09:22:FF:21:30:46:98:47:7F:20:60:74:13:E0:43:46:0A:26:08:34:22:78:99:7F:11:40:93:F8:32:20:76:1E:02:EA:01:02:93:F8:32:10:83:F8:28:20:03:F1:01:03:04:F8:01:1B:EE:D1:40:46:28:30:B8:47:02:46:8A:4B:29:78:55:20:98:47:BD:E8:F0:81:E0:88:41:01:01:EB:40:21:28:46:40:18:90:F8:3B:10:00:29:71:D1:90:F8:3C:10:00:29:6D:D1:81:4A:69:E0:22:78:B4:20:80:4B:50:43:18:5C:00:28:6A:D0:7F:48:00:78:00:28:66:D1:08:46:80:5C:07:28:62:DB:5B:E0:20:88:42:F2:01:41:81:42:0B:D0:B0:F5:10:5F:59:D1:77:49:91:F8:A9:00:00:F0:F7:00:81:F8:A9:00:BD:E8:F0:81:60:7A:00:28:4D:D1:72:49:17:20:88:47:78:4C:0A:20:71:49"
    16:48:17.493 --
    16:48:17.493 Outgoing Dump:
    16:48:17.493 0000: 01 05 ff f5 70 08 1a 00 f0 b9 80 00 2d 00 f0 b6 ....p.......-...
    16:48:17.493 0010: 80 4f f4 01 60 9f 4a 08 80 28 46 ae e0 04 f1 08 .O..`.J..(F.....
    16:48:17.493 0020: 06 9d 4f 30 46 b8 47 aa 4d df f8 74 82 a9 7b 28 ..O0F.G.M..t..{(
    16:48:17.493 0030: 70 01 29 09 d0 02 29 1b d1 98 4b 09 22 ff 21 30 p.)...)...K.".!0
    16:48:17.493 0040: 46 98 47 7f 20 60 74 13 e0 43 46 0a 26 08 34 22 F.G. `t..CF.&.4"
    16:48:17.493 0050: 78 99 7f 11 40 93 f8 32 20 76 1e 02 ea 01 02 93 x...@..2 v......
    16:48:17.493 0060: f8 32 10 83 f8 28 20 03 f1 01 03 04 f8 01 1b ee .2...( .........
    16:48:17.493 0070: d1 40 46 28 30 b8 47 02 46 8a 4b 29 78 55 20 98 .@F(0.G.F.K)xU .
    16:48:17.493 0080: 47 bd e8 f0 81 e0 88 41 01 01 eb 40 21 28 46 40 G......A...@!(F@
    16:48:17.493 0090: 18 90 f8 3b 10 00 29 71 d1 90 f8 3c 10 00 29 6d ...;..)q...<..)m
    16:48:17.493 00a0: d1 81 4a 69 e0 22 78 b4 20 80 4b 50 43 18 5c 00 ..Ji."x. .KPC.\.
    16:48:17.493 00b0: 28 6a d0 7f 48 00 78 00 28 66 d1 08 46 80 5c 07 (j..H.x.(f..F.\.
    16:48:17.493 00c0: 28 62 db 5b e0 20 88 42 f2 01 41 81 42 0b d0 b0 (b.[. .B..A.B...
    16:48:17.493 00d0: f5 10 5f 59 d1 77 49 91 f8 a9 00 00 f0 f7 00 81 .._Y.wI.........
    16:48:17.493 00e0: f8 a9 00 bd e8 f0 81 60 7a 00 28 4d d1 72 49 17 .......`z.(M.rI.
    16:48:17.493 00f0: 20 88 47 78 4c 0a 20 71 49 .GxL. qI
    16:48:17.525 Incoming Dump:
    16:48:17.525 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.525 --
    16:48:17.525 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.525 Parameters:
    16:48:17.525 | Number HCI commands : 0x01
    16:48:17.525 | Command Opcode : 0xff05
    16:48:17.525 | Status : 0x00 (Success)
    16:48:17.525 --
    16:48:17.525 --
    16:48:17.525 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.525 | Address : 0x001a0960
    16:48:17.525 | Size : 0xf0
    16:48:17.525 | Values : "20:60:00:20:88:47:60:60:BD:E8:F0:81:61:7A:20:7A:E2:7A:00:EB:01:20:05:13:A1:7A:80:B2:05:F0:03:05:01:EB:02:21:8F:B2:81:13:32:D1:FF:E7:6E:49:C0:F3:09:00:88:47:00:28:2B:D0:90:F8:34:10:41:B3:90:F8:01:80:67:80:01:2D:25:80:05:D0:5F:4D:3B:46:00:22:04:F1:0C:01:A8:47:5D:4A:21:46:40:46:90:47:13:E0:5B:4F:3D:88:38:46:5E:4A:02:21:80:1C:90:47:00:28:F8:D0:05:F0:FE:05:57:48:3D:80:80:47:59:4A:38:46:00:21:90:47:20:46:C0:47:04:48:00:F2:A4:50:70:63:BD:E8:F0:81:85:1F:06:00:F1:B9:08:20:A5:06:04:00:B0:84:08:20:74:A9:08:20:B7:08:03:00:30:B5:04:46:4E:48:0D:46:80:47:94:F8:D4:01:02:28:07:D0:94:F8:C0:01:02:28:03:D0:4A:48:01:68:02:2D:13:D0:01:2D:4B:D1:00:20:C4:F8:D8:01:C4:F8:DC:01:45:49:C4:F8:E0:01:4F:F0:FF:30:C4:F8:E4:01:01:20:84:F8:E8:01"
    16:48:17.525 --
    16:48:17.525 Outgoing Dump:
    16:48:17.525 0000: 01 05 ff f5 60 09 1a 00 f0 20 60 00 20 88 47 60 ....`.... `. .G`
    16:48:17.525 0010: 60 bd e8 f0 81 61 7a 20 7a e2 7a 00 eb 01 20 05 `....az z.z... .
    16:48:17.525 0020: 13 a1 7a 80 b2 05 f0 03 05 01 eb 02 21 8f b2 81 ..z.........!...
    16:48:17.525 0030: 13 32 d1 ff e7 6e 49 c0 f3 09 00 88 47 00 28 2b .2...nI.....G.(+
    16:48:17.525 0040: d0 90 f8 34 10 41 b3 90 f8 01 80 67 80 01 2d 25 ...4.A.....g..-%
    16:48:17.525 0050: 80 05 d0 5f 4d 3b 46 00 22 04 f1 0c 01 a8 47 5d ..._M;F.".....G]
    16:48:17.525 0060: 4a 21 46 40 46 90 47 13 e0 5b 4f 3d 88 38 46 5e J!F@F.G..[O=.8F^
    16:48:17.525 0070: 4a 02 21 80 1c 90 47 00 28 f8 d0 05 f0 fe 05 57 J.!...G.(......W
    16:48:17.525 0080: 48 3d 80 80 47 59 4a 38 46 00 21 90 47 20 46 c0 H=..GYJ8F.!.G F.
    16:48:17.525 0090: 47 04 48 00 f2 a4 50 70 63 bd e8 f0 81 85 1f 06 G.H...Ppc.......
    16:48:17.525 00a0: 00 f1 b9 08 20 a5 06 04 00 b0 84 08 20 74 a9 08 .... ....... t..
    16:48:17.525 00b0: 20 b7 08 03 00 30 b5 04 46 4e 48 0d 46 80 47 94 ....0..FNH.F.G.
    16:48:17.525 00c0: f8 d4 01 02 28 07 d0 94 f8 c0 01 02 28 03 d0 4a ....(.......(..J
    16:48:17.525 00d0: 48 01 68 02 2d 13 d0 01 2d 4b d1 00 20 c4 f8 d8 H.h.-...-K.. ...
    16:48:17.525 00e0: 01 c4 f8 dc 01 45 49 c4 f8 e0 01 4f f0 ff 30 c4 .....EI....O..0.
    16:48:17.525 00f0: f8 e4 01 01 20 84 f8 e8 01 .... ....
    16:48:17.556 Incoming Dump:
    16:48:17.556 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.556 --
    16:48:17.556 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.556 Parameters:
    16:48:17.556 | Number HCI commands : 0x01
    16:48:17.556 | Command Opcode : 0xff05
    16:48:17.556 | Status : 0x00 (Success)
    16:48:17.556 --
    16:48:17.556 --
    16:48:17.556 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.556 | Address : 0x001a0a50
    16:48:17.556 | Size : 0xf0
    16:48:17.556 | Values : "20:46:88:47:39:E0:40:48:91:B9:00:21:84:F8:D5:11:C4:F8:CC:11:02:78:C4:F8:C8:11:4F:F4:7A:70:C4:F8:C4:11:50:43:C4:F8:D0:01:02:22:84:F8:D4:21:12:E0:00:21:02:22:C4:F8:B0:11:C4:F8:B4:11:C4:F8:B8:11:01:78:84:F8:C0:21:4F:F4:7A:70:48:43:C4:F8:BC:01:01:21:84:F8:C1:11:84:F8:E9:11:46:F2:A8:11:C4:F8:D8:11:C4:F8:E4:01:84:F8:E8:21:40:F2:4D:11:C4:F8:DC:11:4E:F6:60:21:C4:F8:E0:11:24:4D:21:46:71:20:A8:47:24:49:B6:20:A8:47:06:49:0C:20:88:47:01:46:39:B1:4F:F4:94:40:08:80:20:78:1D:4A:C8:80:00:20:90:47:30:BD:07:0E:03:00:E3:4E:07:00:81:AB:02:00:69:F9:00:00:75:ED:08:00:30:A6:08:20:CD:C6:07:00:29:D0:01:00:2C:96:08:20:28:69:08:20:F4:A1:08:20:71:07:07:00:81:9F:08:00:35:24:01:00:E1:CA:02:00:02:30:0E:20:D1:1F:04:00:CC:DC:08:20:E4:DC:08:20"
    16:48:17.556 --
    16:48:17.556 Outgoing Dump:
    16:48:17.556 0000: 01 05 ff f5 50 0a 1a 00 f0 20 46 88 47 39 e0 40 ....P.... F.G9.@
    16:48:17.556 0010: 48 91 b9 00 21 84 f8 d5 11 c4 f8 cc 11 02 78 c4 H...!.........x.
    16:48:17.556 0020: f8 c8 11 4f f4 7a 70 c4 f8 c4 11 50 43 c4 f8 d0 ...O.zp....PC...
    16:48:17.556 0030: 01 02 22 84 f8 d4 21 12 e0 00 21 02 22 c4 f8 b0 .."...!...!."...
    16:48:17.556 0040: 11 c4 f8 b4 11 c4 f8 b8 11 01 78 84 f8 c0 21 4f ..........x...!O
    16:48:17.556 0050: f4 7a 70 48 43 c4 f8 bc 01 01 21 84 f8 c1 11 84 .zpHC.....!.....
    16:48:17.556 0060: f8 e9 11 46 f2 a8 11 c4 f8 d8 11 c4 f8 e4 01 84 ...F............
    16:48:17.556 0070: f8 e8 21 40 f2 4d 11 c4 f8 dc 11 4e f6 60 21 c4 ..!@.M.....N.`!.
    16:48:17.556 0080: f8 e0 11 24 4d 21 46 71 20 a8 47 24 49 b6 20 a8 ...$M!Fq .G$I. .
    16:48:17.556 0090: 47 06 49 0c 20 88 47 01 46 39 b1 4f f4 94 40 08 G.I. .G.F9.O..@.
    16:48:17.556 00a0: 80 20 78 1d 4a c8 80 00 20 90 47 30 bd 07 0e 03 . x.J... .G0....
    16:48:17.556 00b0: 00 e3 4e 07 00 81 ab 02 00 69 f9 00 00 75 ed 08 ..N......i...u..
    16:48:17.556 00c0: 00 30 a6 08 20 cd c6 07 00 29 d0 01 00 2c 96 08 .0.. ....)...,..
    16:48:17.556 00d0: 20 28 69 08 20 f4 a1 08 20 71 07 07 00 81 9f 08 (i. ... q......
    16:48:17.556 00e0: 00 35 24 01 00 e1 ca 02 00 02 30 0e 20 d1 1f 04 .5$.......0. ...
    16:48:17.556 00f0: 00 cc dc 08 20 e4 dc 08 20 .... ...
    16:48:17.587 Incoming Dump:
    16:48:17.587 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.587 --
    16:48:17.587 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.587 Parameters:
    16:48:17.587 | Number HCI commands : 0x01
    16:48:17.587 | Command Opcode : 0xff05
    16:48:17.587 | Status : 0x00 (Success)
    16:48:17.587 --
    16:48:17.587 --
    16:48:17.587 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.587 | Address : 0x001a0b40
    16:48:17.587 | Size : 0xf0
    16:48:17.587 | Values : "61:2D:08:00:ED:2B:08:00:D5:38:01:00:91:A7:02:00:F0:DC:08:20:B9:3D:06:00:E0:69:08:20:61:5D:08:00:29:88:08:00:65:A3:08:20:2D:E9:FE:4F:00:90:02:69:46:69:91:1C:01:91:90:F8:24:70:9D:48:00:F1:A4:05:30:78:B2:F8:00:E0:11:1D:43:00:8C:1C:03:EB:00:1C:3B:46:03:EB:C3:03:63:44:EB:5C:A1:46:00:2B:43:D1:53:79:03:F0:3F:03:01:2B:3E:D1:0B:78:13:F0:0C:0F:3A:D1:03:F0:03:03:02:2B:36:D1:BE:F1:04:0F:33:D3:52:88:01:2A:30:D0:AE:F1:02:01:49:08:1F:FA:81:F8:B8:F1:07:0F:23:DA:DF:F8:58:C2:02:46:43:46:39:46:40:F2:86:20:E0:47:38:46:43:46:00:EB:C0:00:61:78:32:78:C1:F3:C0:07:51:00:01:EB:02:11:14:F8:02:2B:5B:1E:01:EB:A2:01:01:44:29:44:4F:70:EF:D1:01:21:33:78:5A:00:02:EB:03:12:80:18:29:54:3F:E1:A3:4A:41:46:0D:20:90:47:3A:E1:4F:F0:00:00:07:B9:01:20"
    16:48:17.587 --
    16:48:17.587 Outgoing Dump:
    16:48:17.587 0000: 01 05 ff f5 40 0b 1a 00 f0 61 2d 08 00 ed 2b 08 ....@....a-...+.
    16:48:17.587 0010: 00 d5 38 01 00 91 a7 02 00 f0 dc 08 20 b9 3d 06 ..8......... .=.
    16:48:17.587 0020: 00 e0 69 08 20 61 5d 08 00 29 88 08 00 65 a3 08 ..i. a]..)...e..
    16:48:17.587 0030: 20 2d e9 fe 4f 00 90 02 69 46 69 91 1c 01 91 90 -..O...iFi.....
    16:48:17.587 0040: f8 24 70 9d 48 00 f1 a4 05 30 78 b2 f8 00 e0 11 .$p.H....0x.....
    16:48:17.587 0050: 1d 43 00 8c 1c 03 eb 00 1c 3b 46 03 eb c3 03 63 .C.......;F....c
    16:48:17.587 0060: 44 eb 5c a1 46 00 2b 43 d1 53 79 03 f0 3f 03 01 D.\.F.+C.Sy..?..
    16:48:17.587 0070: 2b 3e d1 0b 78 13 f0 0c 0f 3a d1 03 f0 03 03 02 +>..x....:......
    16:48:17.587 0080: 2b 36 d1 be f1 04 0f 33 d3 52 88 01 2a 30 d0 ae +6.....3.R..*0..
    16:48:17.587 0090: f1 02 01 49 08 1f fa 81 f8 b8 f1 07 0f 23 da df ...I.........#..
    16:48:17.587 00a0: f8 58 c2 02 46 43 46 39 46 40 f2 86 20 e0 47 38 .X..FCF9F@.. .G8
    16:48:17.587 00b0: 46 43 46 00 eb c0 00 61 78 32 78 c1 f3 c0 07 51 FCF....ax2x....Q
    16:48:17.587 00c0: 00 01 eb 02 11 14 f8 02 2b 5b 1e 01 eb a2 01 01 ........+[......
    16:48:17.587 00d0: 44 29 44 4f 70 ef d1 01 21 33 78 5a 00 02 eb 03 D)DOp...!3xZ....
    16:48:17.587 00e0: 12 80 18 29 54 3f e1 a3 4a 41 46 0d 20 90 47 3a ...)T?..JAF. .G:
    16:48:17.587 00f0: e1 4f f0 00 00 07 b9 01 20 .O......
    16:48:17.618 Incoming Dump:
    16:48:17.618 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.618 --
    16:48:17.618 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.618 Parameters:
    16:48:17.618 | Number HCI commands : 0x01
    16:48:17.618 | Command Opcode : 0xff05
    16:48:17.618 | Status : 0x00 (Success)
    16:48:17.618 --
    16:48:17.618 --
    16:48:17.618 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.618 | Address : 0x001a0c30
    16:48:17.618 | Size : 0xf0
    16:48:17.618 | Values : "DF:F8:7C:A2:80:46:08:EB:C8:00:02:90:96:F8:00:C0:62:46:50:00:00:EB:02:10:08:EB:4C:02:02:EB:C2:02:12:F8:05:B0:BB:F1:01:0F:26:D1:4B:78:03:F0:3F:03:06:2B:21:D1:0B:78:03:F0:0C:04:03:F0:03:03:23:43:1A:D1:01:9B:1B:88:01:2B:16:D0:BE:F1:03:0F:13:D1:99:F8:00:10:A8:18:89:10:62:46:41:70:40:F2:89:20:39:46:D0:47:31:78:48:00:CD:F8:08:80:00:EB:01:12:02:21:02:EB:C8:02:4E:E0:3C:46:00:EB:05:08:04:EB:C4:04:18:F8:04:20:02:2A:47:D1:4B:78:03:F0:3F:03:06:2B:42:D1:01:9B:1B:88:01:2B:3E:D0:0B:78:13:F0:0C:0F:3A:D1:03:F0:03:03:02:2B:36:D1:BE:F1:02:0F:33:D1:08:EB:04:03:5B:78:FF:2B:2E:D0:3F:B9:29:18:49:78:40:18:28:18:40:78:01:28:09:D0:0A:E0:01:2F:0E:D1:29:18:89:7A:40:18:28:18:80:7A:01:28:01:D0:01:23:00:E0:00:23:36:48:43:62:96:F8:00:C0:01:E0"
    16:48:17.618 --
    16:48:17.618 Outgoing Dump:
    16:48:17.618 0000: 01 05 ff f5 30 0c 1a 00 f0 df f8 7c a2 80 46 08 ....0......|..F.
    16:48:17.618 0010: eb c8 00 02 90 96 f8 00 c0 62 46 50 00 00 eb 02 .........bFP....
    16:48:17.618 0020: 10 08 eb 4c 02 02 eb c2 02 12 f8 05 b0 bb f1 01 ...L............
    16:48:17.618 0030: 0f 26 d1 4b 78 03 f0 3f 03 06 2b 21 d1 0b 78 03 .&.Kx..?..+!..x.
    16:48:17.618 0040: f0 0c 04 03 f0 03 03 23 43 1a d1 01 9b 1b 88 01 .......#C.......
    16:48:17.618 0050: 2b 16 d0 be f1 03 0f 13 d1 99 f8 00 10 a8 18 89 +...............
    16:48:17.618 0060: 10 62 46 41 70 40 f2 89 20 39 46 d0 47 31 78 48 .bFAp@.. 9F.G1xH
    16:48:17.618 0070: 00 cd f8 08 80 00 eb 01 12 02 21 02 eb c8 02 4e ..........!....N
    16:48:17.618 0080: e0 3c 46 00 eb 05 08 04 eb c4 04 18 f8 04 20 02 .<F........... .
    16:48:17.618 0090: 2a 47 d1 4b 78 03 f0 3f 03 06 2b 42 d1 01 9b 1b *G.Kx..?..+B....
    16:48:17.618 00a0: 88 01 2b 3e d0 0b 78 13 f0 0c 0f 3a d1 03 f0 03 ..+>..x....:....
    16:48:17.618 00b0: 03 02 2b 36 d1 be f1 02 0f 33 d1 08 eb 04 03 5b ..+6.....3.....[
    16:48:17.618 00c0: 78 ff 2b 2e d0 3f b9 29 18 49 78 40 18 28 18 40 x.+..?.).Ix@.(.@
    16:48:17.618 00d0: 78 01 28 09 d0 0a e0 01 2f 0e d1 29 18 89 7a 40 x.(...../..)..z@
    16:48:17.618 00e0: 18 28 18 80 7a 01 28 01 d0 01 23 00 e0 00 23 36 .(..z.(...#...#6
    16:48:17.618 00f0: 48 43 62 96 f8 00 c0 01 e0 HCb......
    16:48:17.650 Incoming Dump:
    16:48:17.650 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.650 --
    16:48:17.650 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.650 Parameters:
    16:48:17.650 | Number HCI commands : 0x01
    16:48:17.650 | Command Opcode : 0xff05
    16:48:17.650 | Status : 0x00 (Success)
    16:48:17.650 --
    16:48:17.650 --
    16:48:17.650 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.650 | Address : 0x001a0d20
    16:48:17.650 | Size : 0xf0
    16:48:17.650 | Values : "33:48:43:6A:39:46:42:4F:62:46:40:F2:91:20:B8:47:31:78:48:00:00:EB:01:10:20:18:03:21:29:54:30:78:42:00:02:EB:00:12:02:98:66:E7:03:2A:19:D1:48:78:00:F0:3F:00:07:28:14:D1:08:78:00:F0:0C:03:00:F0:03:00:18:43:0D:D1:01:98:00:88:01:28:09:D0:BE:F1:03:0F:06:D1:62:46:39:46:40:F2:8A:20:D0:47:04:21:53:E0:DF:F8:20:82:DF:F8:74:92:BB:F1:04:0F:31:D1:48:78:00:F0:3F:00:07:28:2C:D1:08:78:10:F0:0C:0F:28:D1:00:F0:03:00:02:28:24:D1:01:98:00:88:01:28:20:D0:BE:F1:02:0F:1D:D1:62:46:39:46:40:F2:8B:20:D0:47:31:78:48:00:00:EB:01:10:02:99:05:22:08:18:2A:54:31:78:48:00:00:EB:01:10:20:18:2A:54:31:78:01:20:88:40:99:F8:71:11:08:43:02:21:53:E0:C0:46:CC:DC:08:20:05:2A:1D:D1:48:78:00:F0:3F:00:09:28:18:D1:08:78:00:F0:0C:03:00:F0:03:00:18:43:11:D1"
    16:48:17.650 --
    16:48:17.650 Outgoing Dump:
    16:48:17.650 0000: 01 05 ff f5 20 0d 1a 00 f0 33 48 43 6a 39 46 42 .... ....3HCj9FB
    16:48:17.650 0010: 4f 62 46 40 f2 91 20 b8 47 31 78 48 00 00 eb 01 ObF@.. .G1xH....
    16:48:17.650 0020: 10 20 18 03 21 29 54 30 78 42 00 02 eb 00 12 02 . ..!)T0xB......
    16:48:17.650 0030: 98 66 e7 03 2a 19 d1 48 78 00 f0 3f 00 07 28 14 .f..*..Hx..?..(.
    16:48:17.650 0040: d1 08 78 00 f0 0c 03 00 f0 03 00 18 43 0d d1 01 ..x.........C...
    16:48:17.650 0050: 98 00 88 01 28 09 d0 be f1 03 0f 06 d1 62 46 39 ....(........bF9
    16:48:17.650 0060: 46 40 f2 8a 20 d0 47 04 21 53 e0 df f8 20 82 df F@.. .G.!S... ..
    16:48:17.650 0070: f8 74 92 bb f1 04 0f 31 d1 48 78 00 f0 3f 00 07 .t.....1.Hx..?..
    16:48:17.650 0080: 28 2c d1 08 78 10 f0 0c 0f 28 d1 00 f0 03 00 02 (,..x....(......
    16:48:17.650 0090: 28 24 d1 01 98 00 88 01 28 20 d0 be f1 02 0f 1d ($......( ......
    16:48:17.650 00a0: d1 62 46 39 46 40 f2 8b 20 d0 47 31 78 48 00 00 .bF9F@.. .G1xH..
    16:48:17.650 00b0: eb 01 10 02 99 05 22 08 18 2a 54 31 78 48 00 00 ......"..*T1xH..
    16:48:17.650 00c0: eb 01 10 20 18 2a 54 31 78 01 20 88 40 99 f8 71 ... .*T1x. .@..q
    16:48:17.650 00d0: 11 08 43 02 21 53 e0 c0 46 cc dc 08 20 05 2a 1d ..C.!S..F... .*.
    16:48:17.650 00e0: d1 48 78 00 f0 3f 00 09 28 18 d1 08 78 00 f0 0c .Hx..?..(...x...
    16:48:17.650 00f0: 03 00 f0 03 00 18 43 11 d1 ......C..
    16:48:17.681 Incoming Dump:
    16:48:17.681 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.681 --
    16:48:17.681 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.681 Parameters:
    16:48:17.681 | Number HCI commands : 0x01
    16:48:17.681 | Command Opcode : 0xff05
    16:48:17.681 | Status : 0x00 (Success)
    16:48:17.681 --
    16:48:17.681 --
    16:48:17.681 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.681 | Address : 0x001a0e10
    16:48:17.681 | Size : 0xf0
    16:48:17.681 | Values : "01:98:00:88:01:28:0D:D0:BE:F1:03:0F:0A:D1:62:46:39:46:4F:F4:23:70:D0:47:06:21:20:46:F0:E6:C0:46:49:C6:07:00:BB:F1:06:0F:31:D1:48:78:00:F0:3F:00:09:28:2C:D1:08:78:10:F0:0C:0F:28:D1:00:F0:03:00:02:28:24:D1:01:98:00:88:01:28:20:D0:BE:F1:02:0F:1D:D1:62:46:39:46:40:F2:8D:20:D0:47:31:78:48:00:00:EB:01:10:02:99:03:22:08:18:2A:54:31:78:48:00:00:EB:01:10:20:18:2A:54:30:78:01:21:01:FA:00:F2:99:F8:71:01:90:43:89:F8:71:01:30:46:C0:47:8A:48:00:99:00:F5:8F:70:48:63:BD:E8:FE:8F:41:C7:07:00:CD:C6:07:00:00:B5:86:48:01:78:88:00:00:EB:C1:10:82:49:09:18:C8:78:02:28:03:D1:08:78:08:B9:81:48:80:47:00:BD:00:B5:7E:48:01:78:88:00:00:EB:C1:10:7A:49:09:18:C8:78:01:28:03:D1:08:78:08:B9:79:48:80:47:00:BD:10:B5:AD:F1:14:0D:77:49:04:46:29:20"
    16:48:17.681 --
    16:48:17.681 Outgoing Dump:
    16:48:17.681 0000: 01 05 ff f5 10 0e 1a 00 f0 01 98 00 88 01 28 0d ..............(.
    16:48:17.681 0010: d0 be f1 03 0f 0a d1 62 46 39 46 4f f4 23 70 d0 .......bF9FO.#p.
    16:48:17.681 0020: 47 06 21 20 46 f0 e6 c0 46 49 c6 07 00 bb f1 06 G.! F...FI......
    16:48:17.681 0030: 0f 31 d1 48 78 00 f0 3f 00 09 28 2c d1 08 78 10 .1.Hx..?..(,..x.
    16:48:17.681 0040: f0 0c 0f 28 d1 00 f0 03 00 02 28 24 d1 01 98 00 ...(......($....
    16:48:17.681 0050: 88 01 28 20 d0 be f1 02 0f 1d d1 62 46 39 46 40 ..( .......bF9F@
    16:48:17.681 0060: f2 8d 20 d0 47 31 78 48 00 00 eb 01 10 02 99 03 .. .G1xH........
    16:48:17.681 0070: 22 08 18 2a 54 31 78 48 00 00 eb 01 10 20 18 2a "..*T1xH..... .*
    16:48:17.681 0080: 54 30 78 01 21 01 fa 00 f2 99 f8 71 01 90 43 89 T0x.!......q..C.
    16:48:17.681 0090: f8 71 01 30 46 c0 47 8a 48 00 99 00 f5 8f 70 48 .q.0F.G.H.....pH
    16:48:17.681 00a0: 63 bd e8 fe 8f 41 c7 07 00 cd c6 07 00 00 b5 86 c....A..........
    16:48:17.681 00b0: 48 01 78 88 00 00 eb c1 10 82 49 09 18 c8 78 02 H.x.......I...x.
    16:48:17.681 00c0: 28 03 d1 08 78 08 b9 81 48 80 47 00 bd 00 b5 7e (...x...H.G....~
    16:48:17.681 00d0: 48 01 78 88 00 00 eb c1 10 7a 49 09 18 c8 78 01 H.x......zI...x.
    16:48:17.681 00e0: 28 03 d1 08 78 08 b9 79 48 80 47 00 bd 10 b5 ad (...x..yH.G.....
    16:48:17.681 00f0: f1 14 0d 77 49 04 46 29 20 ...wI.F)
    16:48:17.712 Incoming Dump:
    16:48:17.712 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.712 --
    16:48:17.712 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.712 Parameters:
    16:48:17.712 | Number HCI commands : 0x01
    16:48:17.712 | Command Opcode : 0xff05
    16:48:17.712 | Status : 0x00 (Success)
    16:48:17.712 --
    16:48:17.712 --
    16:48:17.712 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.712 | Address : 0x001a0f00
    16:48:17.712 | Size : 0xf0
    16:48:17.712 | Values : "88:47:20:69:01:7A:0D:29:12:D0:31:F0:01:00:09:D0:05:29:18:BF:07:29:23:D1:AB:49:00:20:88:47:6F:49:08:60:1D:E0:6F:4B:6E:48:00:22:03:21:98:47:17:E0:01:7A:6D:4A:01:F0:3F:01:52:F8:21:20:69:46:90:47:04:20:6A:49:6A:4B:9D:F8:11:20:08:70:9D:F8:10:10:14:20:98:47:67:49:68:46:88:47:67:48:4C:30:60:63:05:B0:10:BD:00:B5:00:69:41:7C:04:29:06:D1:00:7C:01:28:03:D1:62:4A:61:48:06:21:90:47:00:BD:10:B5:00:69:61:49:5F:4C:00:7A:05:28:05:D0:07:28:07:D1:09:20:88:47:09:20:02:E0:0A:20:88:47:0A:20:A0:47:10:BD:C0:46:0D:0A:1A:00:2D:E9:F0:4F:04:46:57:48:00:88:91:46:40:08:C0:F0:85:80:55:48:04:EB:01:22:54:4D:03:68:40:F2:BC:51:02:20:A8:47:B9:F1:00:0F:02:D0:5C:49:03:20:88:47:58:4D:00:2C:62:D1:07:4A:2C:46:B2:F8:FC:10:4E:F6:FF:70:64:1F:08:40:A2:F8"
    16:48:17.712 --
    16:48:17.712 Outgoing Dump:
    16:48:17.712 0000: 01 05 ff f5 00 0f 1a 00 f0 88 47 20 69 01 7a 0d ..........G i.z.
    16:48:17.712 0010: 29 12 d0 31 f0 01 00 09 d0 05 29 18 bf 07 29 23 )..1......)...)#
    16:48:17.712 0020: d1 ab 49 00 20 88 47 6f 49 08 60 1d e0 6f 4b 6e ..I. .GoI.`..oKn
    16:48:17.712 0030: 48 00 22 03 21 98 47 17 e0 01 7a 6d 4a 01 f0 3f H.".!.G...zmJ..?
    16:48:17.712 0040: 01 52 f8 21 20 69 46 90 47 04 20 6a 49 6a 4b 9d .R.! iF.G. jIjK.
    16:48:17.712 0050: f8 11 20 08 70 9d f8 10 10 14 20 98 47 67 49 68 .. .p..... .GgIh
    16:48:17.712 0060: 46 88 47 67 48 4c 30 60 63 05 b0 10 bd 00 b5 00 F.GgHL0`c.......
    16:48:17.712 0070: 69 41 7c 04 29 06 d1 00 7c 01 28 03 d1 62 4a 61 iA|.)...|.(..bJa
    16:48:17.712 0080: 48 06 21 90 47 00 bd 10 b5 00 69 61 49 5f 4c 00 H.!.G.....iaI_L.
    16:48:17.712 0090: 7a 05 28 05 d0 07 28 07 d1 09 20 88 47 09 20 02 z.(...(... .G. .
    16:48:17.712 00a0: e0 0a 20 88 47 0a 20 a0 47 10 bd c0 46 0d 0a 1a .. .G. .G...F...
    16:48:17.712 00b0: 00 2d e9 f0 4f 04 46 57 48 00 88 91 46 40 08 c0 .-..O.FWH...F@..
    16:48:17.712 00c0: f0 85 80 55 48 04 eb 01 22 54 4d 03 68 40 f2 bc ...UH..."TM.h@..
    16:48:17.712 00d0: 51 02 20 a8 47 b9 f1 00 0f 02 d0 5c 49 03 20 88 Q. .G......\I. .
    16:48:17.712 00e0: 47 58 4d 00 2c 62 d1 07 4a 2c 46 b2 f8 fc 10 4e GXM.,b..J,F....N
    16:48:17.712 00f0: f6 ff 70 64 1f 08 40 a2 f8 ..pd..@..
    16:48:17.743 Incoming Dump:
    16:48:17.743 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.743 --
    16:48:17.743 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.743 Parameters:
    16:48:17.743 | Number HCI commands : 0x01
    16:48:17.743 | Command Opcode : 0xff05
    16:48:17.743 | Status : 0x00 (Success)
    16:48:17.743 --
    16:48:17.743 --
    16:48:17.743 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.743 | Address : 0x001a0ff0
    16:48:17.743 | Size : 0xf0
    16:48:17.743 | Values : "FC:00:60:79:02:28:0C:DA:02:E0:C0:46:F4:A1:08:20:45:4A:06:21:90:47:60:79:A3:49:00:F5:A8:70:80:B2:88:47:42:4A:01:21:00:20:90:47:DF:F8:04:B1:41:4F:08:21:58:46:B8:47:DF:F8:20:81:08:21:58:46:C0:47:08:21:58:46:B8:47:3C:4E:08:21:30:46:B8:47:08:21:30:46:C0:47:08:21:30:46:B8:47:61:8A:4F:F6:FF:70:88:42:2D:D0:35:48:02:21:B8:47:BA:46:33:48:04:21:D0:47:04:27:31:4C:36:4E:A4:1C:27:80:B0:47:10:20:20:80:B0:47:2D:48:02:21:C0:47:2C:48:39:46:C0:47:08:21:58:46:D0:47:08:21:58:46:C0:47:08:21:58:46:D0:47:FF:21:26:48:27:4A:01:80:02:20:90:47:26:48:80:47:05:E0:01:2C:03:D1:FF:20:28:70:01:20:68:70:4F:F6:FF:70:0D:35:B9:F1:00:0F:28:80:02:D0:A7:49:03:20:88:47:BD:E8:F0:8F:35:24:01:00:0B:4A:08:20:D0:49:08:20:29:52:02:00:AF:C7:07:00:CC:F1:0C:20"
    16:48:17.743 --
    16:48:17.743 Outgoing Dump:
    16:48:17.743 0000: 01 05 ff f5 f0 0f 1a 00 f0 fc 00 60 79 02 28 0c ...........`y.(.
    16:48:17.743 0010: da 02 e0 c0 46 f4 a1 08 20 45 4a 06 21 90 47 60 ....F... EJ.!.G`
    16:48:17.743 0020: 79 a3 49 00 f5 a8 70 80 b2 88 47 42 4a 01 21 00 y.I...p...GBJ.!.
    16:48:17.743 0030: 20 90 47 df f8 04 b1 41 4f 08 21 58 46 b8 47 df .G....AO.!XF.G.
    16:48:17.743 0040: f8 20 81 08 21 58 46 c0 47 08 21 58 46 b8 47 3c . ..!XF.G.!XF.G<
    16:48:17.743 0050: 4e 08 21 30 46 b8 47 08 21 30 46 c0 47 08 21 30 N.!0F.G.!0F.G.!0
    16:48:17.743 0060: 46 b8 47 61 8a 4f f6 ff 70 88 42 2d d0 35 48 02 F.Ga.O..p.B-.5H.
    16:48:17.743 0070: 21 b8 47 ba 46 33 48 04 21 d0 47 04 27 31 4c 36 !.G.F3H.!.G.'1L6
    16:48:17.743 0080: 4e a4 1c 27 80 b0 47 10 20 20 80 b0 47 2d 48 02 N..'..G. ..G-H.
    16:48:17.743 0090: 21 c0 47 2c 48 39 46 c0 47 08 21 58 46 d0 47 08 !.G,H9F.G.!XF.G.
    16:48:17.743 00a0: 21 58 46 c0 47 08 21 58 46 d0 47 ff 21 26 48 27 !XF.G.!XF.G.!&H'
    16:48:17.743 00b0: 4a 01 80 02 20 90 47 26 48 80 47 05 e0 01 2c 03 J... .G&H.G...,.
    16:48:17.743 00c0: d1 ff 20 28 70 01 20 68 70 4f f6 ff 70 0d 35 b9 .. (p. hpO..p.5.
    16:48:17.743 00d0: f1 00 0f 28 80 02 d0 a7 49 03 20 88 47 bd e8 f0 ...(....I. .G...
    16:48:17.743 00e0: 8f 35 24 01 00 0b 4a 08 20 d0 49 08 20 29 52 02 .5$...J. .I. )R.
    16:48:17.743 00f0: 00 af c7 07 00 cc f1 0c 20 ........
    16:48:17.775 Incoming Dump:
    16:48:17.775 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.775 --
    16:48:17.775 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.775 Parameters:
    16:48:17.775 | Number HCI commands : 0x01
    16:48:17.775 | Command Opcode : 0xff05
    16:48:17.775 | Status : 0x00 (Success)
    16:48:17.775 --
    16:48:17.775 --
    16:48:17.775 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.775 | Address : 0x001a10e0
    16:48:17.775 | Size : 0xf0
    16:48:17.775 | Values : "20:01:0E:20:8B:2B:08:00:38:FA:09:00:B3:76:08:20:A1:C6:07:00:57:69:07:00:65:6A:07:00:B8:81:08:20:33:79:06:00:1D:05:07:00:71:05:07:00:1C:6A:08:20:80:7D:08:20:A1:C8:07:00:FD:A9:00:00:31:9B:00:00:0C:50:0E:20:D1:2B:08:00:34:50:0E:20:22:0E:0E:20:2C:01:04:20:ED:EE:08:00:1F:EF:08:00:D1:DC:08:20:11:76:06:00:8B:26:07:00:ED:2B:08:00:2D:E9:F0:4F:DF:F8:74:80:00:20:C0:47:83:46:00:23:DF:F8:30:A2:8C:48:19:46:01:25:AA:F1:68:04:05:80:14:F8:B4:2F:02:2A:12:D1:85:48:40:18:90:F8:76:60:01:2E:0C:D1:90:F8:7D:60:4E:B9:4F:F0:05:02:80:F8:7D:20:4F:F0:B4:00:81:4A:00:FB:01:F0:12:5C:1A:B9:28:46:88:40:18:43:C3:B2:49:1C:07:29:E0:DB:92:49:08:78:03:42:1C:BF:98:43:08:70:4F:F4:80:54:8F:49:A0:B2:88:47:B0:F5:FA:4F:0A:D9:01:E0:81:9F:08:00:32:49:A0:B2"
    16:48:17.775 --
    16:48:17.775 Outgoing Dump:
    16:48:17.775 0000: 01 05 ff f5 e0 10 1a 00 f0 20 01 0e 20 8b 2b 08 ......... .. .+.
    16:48:17.775 0010: 00 38 fa 09 00 b3 76 08 20 a1 c6 07 00 57 69 07 .8....v. ....Wi.
    16:48:17.775 0020: 00 65 6a 07 00 b8 81 08 20 33 79 06 00 1d 05 07 .ej..... 3y.....
    16:48:17.775 0030: 00 71 05 07 00 1c 6a 08 20 80 7d 08 20 a1 c8 07 .q....j. .}. ...
    16:48:17.775 0040: 00 fd a9 00 00 31 9b 00 00 0c 50 0e 20 d1 2b 08 .....1....P. .+.
    16:48:17.775 0050: 00 34 50 0e 20 22 0e 0e 20 2c 01 04 20 ed ee 08 .4P. ".. ,.. ...
    16:48:17.775 0060: 00 1f ef 08 00 d1 dc 08 20 11 76 06 00 8b 26 07 ........ .v...&.
    16:48:17.775 0070: 00 ed 2b 08 00 2d e9 f0 4f df f8 74 80 00 20 c0 ..+..-..O..t.. .
    16:48:17.775 0080: 47 83 46 00 23 df f8 30 a2 8c 48 19 46 01 25 aa G.F.#..0..H.F.%.
    16:48:17.775 0090: f1 68 04 05 80 14 f8 b4 2f 02 2a 12 d1 85 48 40 .h....../.*...H@
    16:48:17.775 00a0: 18 90 f8 76 60 01 2e 0c d1 90 f8 7d 60 4e b9 4f ...v`......}`N.O
    16:48:17.775 00b0: f0 05 02 80 f8 7d 20 4f f0 b4 00 81 4a 00 fb 01 .....} O....J...
    16:48:17.775 00c0: f0 12 5c 1a b9 28 46 88 40 18 43 c3 b2 49 1c 07 ..\..(F.@.C..I..
    16:48:17.775 00d0: 29 e0 db 92 49 08 78 03 42 1c bf 98 43 08 70 4f )...I.x.B...C.pO
    16:48:17.775 00e0: f4 80 54 8f 49 a0 b2 88 47 b0 f5 fa 4f 0a d9 01 ..T.I...G...O...
    16:48:17.775 00f0: e0 81 9f 08 00 32 49 a0 b2 .....2I..
    16:48:17.806 Incoming Dump:
    16:48:17.806 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.806 --
    16:48:17.806 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.806 Parameters:
    16:48:17.806 | Number HCI commands : 0x01
    16:48:17.806 | Command Opcode : 0xff05
    16:48:17.806 | Status : 0x00 (Success)
    16:48:17.806 --
    16:48:17.806 --
    16:48:17.806 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.806 | Address : 0x001a11d0
    16:48:17.806 | Size : 0xf0
    16:48:17.806 | Values : "88:47:8A:4A:4F:F4:FA:41:A0:B2:90:47:64:1C:41:F2:09:00:A0:42:E9:DC:00:27:85:4C:3E:46:94:F8:38:00:0C:28:1C:D1:E0:78:20:B1:94:F8:3A:00:0E:28:08:BF:2F:1C:94:F8:3B:00:90:B9:FF:E7:94:F8:3C:00:70:B9:B4:F8:74:01:58:B1:91:49:04:20:88:47:01:46:31:B1:4F:F4:54:50:CE:80:8E:4A:08:80:00:20:90:47:76:1C:04:F5:08:74:07:2E:D9:D3:93:48:47:B9:07:46:07:F1:FC:00:02:88:4F:F2:FF:71:01:EA:02:01:05:E0:07:46:07:F1:FC:00:01:88:41:F4:00:61:8C:4C:01:80:DF:F8:30:92:A0:69:F8:B1:00:20:C0:47:01:46:85:48:00:78:30:B9:20:6A:81:42:03:D0:A0:69:21:62:40:1E:A0:61:E2:69:60:69:80:18:20:F0:7C:40:C8:47:00:28:05:DC:A0:69:28:B1:07:E0:C0:46:85:1B:06:00:00:20:A0:61:95:49:17:20:88:47:97:F8:71:01:30:B1:9A:F8:01:05:28:28:02:DD:8F:49:0B:20:88:47:90:4E:30:88:40:08"
    16:48:17.806 --
    16:48:17.806 Outgoing Dump:
    16:48:17.806 0000: 01 05 ff f5 d0 11 1a 00 f0 88 47 8a 4a 4f f4 fa ..........G.JO..
    16:48:17.806 0010: 41 a0 b2 90 47 64 1c 41 f2 09 00 a0 42 e9 dc 00 A...Gd.A....B...
    16:48:17.806 0020: 27 85 4c 3e 46 94 f8 38 00 0c 28 1c d1 e0 78 20 '.L>F..8..(...x
    16:48:17.806 0030: b1 94 f8 3a 00 0e 28 08 bf 2f 1c 94 f8 3b 00 90 ...:..(../...;..
    16:48:17.806 0040: b9 ff e7 94 f8 3c 00 70 b9 b4 f8 74 01 58 b1 91 .....<.p...t.X..
    16:48:17.806 0050: 49 04 20 88 47 01 46 31 b1 4f f4 54 50 ce 80 8e I. .G.F1.O.TP...
    16:48:17.806 0060: 4a 08 80 00 20 90 47 76 1c 04 f5 08 74 07 2e d9 J... .Gv....t...
    16:48:17.806 0070: d3 93 48 47 b9 07 46 07 f1 fc 00 02 88 4f f2 ff ..HG..F......O..
    16:48:17.806 0080: 71 01 ea 02 01 05 e0 07 46 07 f1 fc 00 01 88 41 q.......F......A
    16:48:17.806 0090: f4 00 61 8c 4c 01 80 df f8 30 92 a0 69 f8 b1 00 ..a.L....0..i...
    16:48:17.806 00a0: 20 c0 47 01 46 85 48 00 78 30 b9 20 6a 81 42 03 .G.F.H.x0. j.B.
    16:48:17.806 00b0: d0 a0 69 21 62 40 1e a0 61 e2 69 60 69 80 18 20 ..i!b@..a.i`i..
    16:48:17.806 00c0: f0 7c 40 c8 47 00 28 05 dc a0 69 28 b1 07 e0 c0 .|@.G.(...i(....
    16:48:17.806 00d0: 46 85 1b 06 00 00 20 a0 61 95 49 17 20 88 47 97 F..... .a.I. .G.
    16:48:17.806 00e0: f8 71 01 30 b1 9a f8 01 05 28 28 02 dd 8f 49 0b .q.0.....((...I.
    16:48:17.806 00f0: 20 88 47 90 4e 30 88 40 08 .G.N0.@.
    16:48:17.837 Incoming Dump:
    16:48:17.837 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.837 --
    16:48:17.837 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.837 Parameters:
    16:48:17.837 | Number HCI commands : 0x01
    16:48:17.837 | Command Opcode : 0xff05
    16:48:17.837 | Status : 0x00 (Success)
    16:48:17.837 --
    16:48:17.837 --
    16:48:17.837 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.837 | Address : 0x001a12c0
    16:48:17.837 | Size : 0xf0
    16:48:17.837 | Values : "22:D3:70:88:00:B3:00:20:C0:47:01:46:97:F8:AB:00:D0:B9:60:79:02:28:17:DA:70:88:02:01:02:EB:80:12:E0:6A:80:18:20:F0:7C:40:C8:47:00:28:0C:DD:E0:79:01:28:09:D1:00:26:A6:4B:2A:46:0A:21:A6:71:30:46:98:47:02:20:60:71:E6:71:A2:49:58:46:88:47:A2:49:58:46:88:47:20:78:4F:28:1D:DA:A0:49:28:46:88:47:C8:B9:9F:4D:9F:4B:09:22:FF:21:05:F1:3C:00:98:47:7F:20:0A:22:85:F8:45:00:AB:7F:95:F8:32:10:52:1E:01:EA:03:01:85:F8:28:10:05:F1:01:05:F4:D1:A0:48:80:47:4F:20:20:70:BD:E8:F0:8F:C0:46:21:20:07:00:10:B5:04:46:9D:48:00:68:04:28:0E:D0:20:69:99:49:81:42:0A:D8:98:49:81:42:07:D9:A6:4A:40:F2:AA:51:03:20:90:47:A4:48:48:30:60:63:10:BD:6C:9B:08:20:E0:95:08:20:50:02:01:20:2C:96:08:20:70:B5:04:46:9E:4A:21:7E:10:78:66:6A:A5:6A:88:42:05:D1:50:78"
    16:48:17.837 --
    16:48:17.837 Outgoing Dump:
    16:48:17.837 0000: 01 05 ff f5 c0 12 1a 00 f0 22 d3 70 88 00 b3 00 .........".p....
    16:48:17.837 0010: 20 c0 47 01 46 97 f8 ab 00 d0 b9 60 79 02 28 17 .G.F......`y.(.
    16:48:17.837 0020: da 70 88 02 01 02 eb 80 12 e0 6a 80 18 20 f0 7c .p........j.. .|
    16:48:17.837 0030: 40 c8 47 00 28 0c dd e0 79 01 28 09 d1 00 26 a6 @.G.(...y.(...&.
    16:48:17.837 0040: 4b 2a 46 0a 21 a6 71 30 46 98 47 02 20 60 71 e6 K*F.!.q0F.G. `q.
    16:48:17.837 0050: 71 a2 49 58 46 88 47 a2 49 58 46 88 47 20 78 4f q.IXF.G.IXF.G xO
    16:48:17.837 0060: 28 1d da a0 49 28 46 88 47 c8 b9 9f 4d 9f 4b 09 (...I(F.G...M.K.
    16:48:17.837 0070: 22 ff 21 05 f1 3c 00 98 47 7f 20 0a 22 85 f8 45 ".!..<..G. ."..E
    16:48:17.837 0080: 00 ab 7f 95 f8 32 10 52 1e 01 ea 03 01 85 f8 28 .....2.R.......(
    16:48:17.837 0090: 10 05 f1 01 05 f4 d1 a0 48 80 47 4f 20 20 70 bd ........H.GO p.
    16:48:17.837 00a0: e8 f0 8f c0 46 21 20 07 00 10 b5 04 46 9d 48 00 ....F! .....F.H.
    16:48:17.837 00b0: 68 04 28 0e d0 20 69 99 49 81 42 0a d8 98 49 81 h.(.. i.I.B...I.
    16:48:17.837 00c0: 42 07 d9 a6 4a 40 f2 aa 51 03 20 90 47 a4 48 48 B...J@..Q. .G.HH
    16:48:17.837 00d0: 30 60 63 10 bd 6c 9b 08 20 e0 95 08 20 50 02 01 0`c..l.. ... P..
    16:48:17.837 00e0: 20 2c 96 08 20 70 b5 04 46 9e 4a 21 7e 10 78 66 ,.. p..F.J!~.xf
    16:48:17.837 00f0: 6a a5 6a 88 42 05 d1 50 78 j.j.B..Px
    16:48:17.868 Incoming Dump:
    16:48:17.868 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.868 --
    16:48:17.868 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.868 Parameters:
    16:48:17.868 | Number HCI commands : 0x01
    16:48:17.868 | Command Opcode : 0xff05
    16:48:17.868 | Status : 0x00 (Success)
    16:48:17.868 --
    16:48:17.868 --
    16:48:17.868 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.868 | Address : 0x001a13b0
    16:48:17.868 | Size : 0xf0
    16:48:17.868 | Values : "05:28:02:D1:9A:49:01:20:08:70:AA:68:31:46:28:46:90:47:98:48:00:F5:A5:70:60:63:F0:7A:80:B1:96:4A:E8:78:11:78:81:42:02:D0:D1:79:81:42:08:D1:69:78:01:20:88:40:91:49:09:78:08:42:1C:BF:00:20:F0:72:70:BD:C0:46:A8:7E:08:20:15:1E:06:00:85:1F:06:00:B0:84:08:20:30:B5:05:46:6C:69:29:69:22:88:4F:F6:F3:40:3A:31:90:42:03:D0:00:F1:01:00:90:42:08:D1:08:78:30:B1:82:49:20:46:88:47:A8:48:00:F2:1A:60:68:63:20:88:40:F2:3D:41:81:42:0D:D1:E0:7F:05:28:0A:D1:94:F8:20:00:05:28:06:D1:A0:8B:00:F4:72:70:A0:83:40:F4:60:70:A0:83:30:BD:C0:46:F7:0D:03:00:29:88:08:00:10:B5:C1:7A:9A:4C:99:4B:00:22:A1:73:4F:F6:30:61:98:47:A6:4A:A1:7B:4F:F4:16:70:90:47:10:BD:C0:46:87:94:08:20:F4:A1:08:20:CC:DC:08:20:01:C4:07:00:70:B5:AD:F1:18:0D:06:46:9D:48:A0:49"
    16:48:17.868 --
    16:48:17.868 Outgoing Dump:
    16:48:17.868 0000: 01 05 ff f5 b0 13 1a 00 f0 05 28 02 d1 9a 49 01 ..........(...I.
    16:48:17.868 0010: 20 08 70 aa 68 31 46 28 46 90 47 98 48 00 f5 a5 .p.h1F(F.G.H...
    16:48:17.868 0020: 70 60 63 f0 7a 80 b1 96 4a e8 78 11 78 81 42 02 p`c.z...J.x.x.B.
    16:48:17.868 0030: d0 d1 79 81 42 08 d1 69 78 01 20 88 40 91 49 09 ..y.B..ix. .@.I.
    16:48:17.868 0040: 78 08 42 1c bf 00 20 f0 72 70 bd c0 46 a8 7e 08 x.B... .rp..F.~.
    16:48:17.868 0050: 20 15 1e 06 00 85 1f 06 00 b0 84 08 20 30 b5 05 ........... 0..
    16:48:17.868 0060: 46 6c 69 29 69 22 88 4f f6 f3 40 3a 31 90 42 03 Fli)i".O..@:1.B.
    16:48:17.868 0070: d0 00 f1 01 00 90 42 08 d1 08 78 30 b1 82 49 20 ......B...x0..I
    16:48:17.868 0080: 46 88 47 a8 48 00 f2 1a 60 68 63 20 88 40 f2 3d F.G.H...`hc .@.=
    16:48:17.868 0090: 41 81 42 0d d1 e0 7f 05 28 0a d1 94 f8 20 00 05 A.B.....(.... ..
    16:48:17.868 00a0: 28 06 d1 a0 8b 00 f4 72 70 a0 83 40 f4 60 70 a0 (......rp..@.`p.
    16:48:17.868 00b0: 83 30 bd c0 46 f7 0d 03 00 29 88 08 00 10 b5 c1 .0..F....)......
    16:48:17.868 00c0: 7a 9a 4c 99 4b 00 22 a1 73 4f f6 30 61 98 47 a6 z.L.K.".sO.0a.G.
    16:48:17.868 00d0: 4a a1 7b 4f f4 16 70 90 47 10 bd c0 46 87 94 08 J.{O..p.G...F...
    16:48:17.868 00e0: 20 f4 a1 08 20 cc dc 08 20 01 c4 07 00 70 b5 ad ... ... ....p..
    16:48:17.868 00f0: f1 18 0d 06 46 9d 48 a0 49 ....F.H.I
    16:48:17.900 Incoming Dump:
    16:48:17.900 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.900 --
    16:48:17.900 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.900 Parameters:
    16:48:17.900 | Number HCI commands : 0x01
    16:48:17.900 | Command Opcode : 0xff05
    16:48:17.900 | Status : 0x00 (Success)
    16:48:17.900 --
    16:48:17.900 --
    16:48:17.900 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.900 | Address : 0x001a14a0
    16:48:17.900 | Size : 0xf0
    16:48:17.900 | Values : "05:68:02:20:88:47:95:F8:A7:05:9B:4C:8D:F8:04:00:95:F8:A6:05:D5:F8:80:15:8D:F8:05:00:0D:F1:06:00:A0:47:D5:F8:78:15:A0:47:D5:F8:70:15:A0:47:D5:F8:84:15:A0:47:93:49:02:20:88:47:12:20:4F:F6:2A:61:8E:4C:8D:F8:00:00:00:22:01:AB:30:46:A0:47:06:B0:70:BD:C0:46:71:07:07:00:71:05:07:00:1C:6A:08:20:70:B5:06:46:83:48:86:49:05:68:02:20:88:47:00:24:C5:F8:74:45:C5:F8:7C:45:C5:F8:84:45:C5:F8:88:45:81:4A:C5:F8:8C:45:04:21:C5:F8:90:45:05:F1:08:00:C5:F8:94:45:90:47:C5:F8:70:45:C5:F8:98:45:79:49:C5:F8:78:45:02:20:85:F8:A5:45:C5:F8:80:45:88:47:5F:4B:4F:F6:29:61:30:46:22:46:98:47:70:BD:73:49:08:78:06:28:07:D1:88:7D:01:28:04:D0:70:49:08:88:20:F0:06:00:08:80:70:47:6C:48:16:30:00:78:01:28:04:D0:6B:49:08:88:40:F0:06:00:08:80:70:47:C0:46"
    16:48:17.900 --
    16:48:17.900 Outgoing Dump:
    16:48:17.900 0000: 01 05 ff f5 a0 14 1a 00 f0 05 68 02 20 88 47 95 ..........h. .G.
    16:48:17.900 0010: f8 a7 05 9b 4c 8d f8 04 00 95 f8 a6 05 d5 f8 80 ....L...........
    16:48:17.900 0020: 15 8d f8 05 00 0d f1 06 00 a0 47 d5 f8 78 15 a0 ..........G..x..
    16:48:17.900 0030: 47 d5 f8 70 15 a0 47 d5 f8 84 15 a0 47 93 49 02 G..p..G.....G.I.
    16:48:17.900 0040: 20 88 47 12 20 4f f6 2a 61 8e 4c 8d f8 00 00 00 .G. O.*a.L.....
    16:48:17.900 0050: 22 01 ab 30 46 a0 47 06 b0 70 bd c0 46 71 07 07 "..0F.G..p..Fq..
    16:48:17.900 0060: 00 71 05 07 00 1c 6a 08 20 70 b5 06 46 83 48 86 .q....j. p..F.H.
    16:48:17.900 0070: 49 05 68 02 20 88 47 00 24 c5 f8 74 45 c5 f8 7c I.h. .G.$..tE..|
    16:48:17.900 0080: 45 c5 f8 84 45 c5 f8 88 45 81 4a c5 f8 8c 45 04 E...E...E.J...E.
    16:48:17.900 0090: 21 c5 f8 90 45 05 f1 08 00 c5 f8 94 45 90 47 c5 !...E.......E.G.
    16:48:17.900 00a0: f8 70 45 c5 f8 98 45 79 49 c5 f8 78 45 02 20 85 .pE...EyI..xE. .
    16:48:17.900 00b0: f8 a5 45 c5 f8 80 45 88 47 5f 4b 4f f6 29 61 30 ..E...E.G_KO.)a0
    16:48:17.900 00c0: 46 22 46 98 47 70 bd 73 49 08 78 06 28 07 d1 88 F"F.Gp.sI.x.(...
    16:48:17.900 00d0: 7d 01 28 04 d0 70 49 08 88 20 f0 06 00 08 80 70 }.(..pI.. .....p
    16:48:17.900 00e0: 47 6c 48 16 30 00 78 01 28 04 d0 6b 49 08 88 40 GlH.0.x.(..kI..@
    16:48:17.900 00f0: f0 06 00 08 80 70 47 c0 46 .....pG.F
    16:48:17.931 Incoming Dump:
    16:48:17.931 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.931 --
    16:48:17.931 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.931 Parameters:
    16:48:17.931 | Number HCI commands : 0x01
    16:48:17.931 | Command Opcode : 0xff05
    16:48:17.931 | Status : 0x00 (Success)
    16:48:17.931 --
    16:48:17.931 --
    16:48:17.931 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.931 | Address : 0x001a1590
    16:48:17.931 | Size : 0xf0
    16:48:17.931 | Values : "A9:0F:1A:00:99:03:1A:00:49:06:1A:00:93:E4:06:00:30:A6:08:20:75:ED:08:00:30:B5:63:49:09:78:71:B1:62:4C:22:88:5A:B1:62:49:2D:39:09:88:C9:09:04:D3:01:7D:5C:4D:63:88:6A:20:A8:47:00:20:20:80:30:BD:B9:1F:01:00:24:68:03:20:40:69:03:20:A8:FE:08:20:30:B5:05:7D:54:48:00:78:98:B1:57:4C:11:2D:05:D1:54:48:00:78:01:28:01:D1:18:20:A0:47:08:2D:08:D1:42:49:08:78:01:28:1C:BF:01:20:08:70:01:D1:18:20:A0:47:30:BD:03:C8:07:00:A7:63:06:00:C4:94:08:20:69:A0:08:20:45:42:03:00:F5:80:08:20:A8:9E:08:20:B7:08:03:00:70:B5:00:7D:0B:28:45:D1:48:48:05:78:00:2D:41:D0:41:4B:19:78:00:29:3D:D1:40:48:00:68:42:0E:39:D3:02:09:37:D2:3E:4C:00:F0:07:02:A4:5C:01:22:02:FA:04:F4:2C:42:2E:D0:C0:F3:43:20:4C:F6:18:76:02:FA:00:F5:2E:42:26:D0:37:4D:2D:5C:37:48"
    16:48:17.931 --
    16:48:17.931 Outgoing Dump:
    16:48:17.931 0000: 01 05 ff f5 90 15 1a 00 f0 a9 0f 1a 00 99 03 1a ................
    16:48:17.931 0010: 00 49 06 1a 00 93 e4 06 00 30 a6 08 20 75 ed 08 .I.......0.. u..
    16:48:17.931 0020: 00 30 b5 63 49 09 78 71 b1 62 4c 22 88 5a b1 62 .0.cI.xq.bL".Z.b
    16:48:17.931 0030: 49 2d 39 09 88 c9 09 04 d3 01 7d 5c 4d 63 88 6a I-9.......}\Mc.j
    16:48:17.931 0040: 20 a8 47 00 20 20 80 30 bd b9 1f 01 00 24 68 03 .G. .0.....$h.
    16:48:17.931 0050: 20 40 69 03 20 a8 fe 08 20 30 b5 05 7d 54 48 00 @i. ... 0..}TH.
    16:48:17.931 0060: 78 98 b1 57 4c 11 2d 05 d1 54 48 00 78 01 28 01 x..WL.-..TH.x.(.
    16:48:17.931 0070: d1 18 20 a0 47 08 2d 08 d1 42 49 08 78 01 28 1c .. .G.-..BI.x.(.
    16:48:17.931 0080: bf 01 20 08 70 01 d1 18 20 a0 47 30 bd 03 c8 07 .. .p... .G0....
    16:48:17.931 0090: 00 a7 63 06 00 c4 94 08 20 69 a0 08 20 45 42 03 ..c..... i.. EB.
    16:48:17.931 00a0: 00 f5 80 08 20 a8 9e 08 20 b7 08 03 00 70 b5 00 .... ... ....p..
    16:48:17.931 00b0: 7d 0b 28 45 d1 48 48 05 78 00 2d 41 d0 41 4b 19 }.(E.HH.x.-A.AK.
    16:48:17.931 00c0: 78 00 29 3d d1 40 48 00 68 42 0e 39 d3 02 09 37 x.)=.@H.hB.9...7
    16:48:17.931 00d0: d2 3e 4c 00 f0 07 02 a4 5c 01 22 02 fa 04 f4 2c .>L.....\."....,
    16:48:17.931 00e0: 42 2e d0 c0 f3 43 20 4c f6 18 76 02 fa 00 f5 2e B....C L..v.....
    16:48:17.931 00f0: 42 26 d0 37 4d 2d 5c 37 48 B&.7M-\7H
    16:48:17.962 Incoming Dump:
    16:48:17.962 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.962 --
    16:48:17.962 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.962 Parameters:
    16:48:17.962 | Number HCI commands : 0x01
    16:48:17.962 | Command Opcode : 0xff05
    16:48:17.962 | Status : 0x00 (Success)
    16:48:17.962 --
    16:48:17.962 --
    16:48:17.962 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.962 | Address : 0x001a1680
    16:48:17.962 | Size : 0xf0
    16:48:17.962 | Values : "00:78:A8:42:20:DC:21:43:19:70:2C:49:01:F1:30:03:18:68:40:F0:20:00:18:60:88:7C:40:1C:88:74:91:F8:E6:00:40:1C:81:F8:E6:00:2E:49:4F:F4:00:70:08:80:2D:48:00:78:FF:28:07:D0:2C:49:82:40:08:68:10:43:08:60:08:68:90:43:08:60:70:BD:C0:46:81:AB:02:00:63:AB:08:00:CC:DC:08:20:70:B5:05:46:68:69:98:B9:28:7F:30:B1:22:48:00:88:80:09:02:D3:AD:49:01:20:88:47:AD:4C:A0:47:AD:49:06:46:88:47:A0:47:B0:42:F9:D1:AB:48:42:30:68:63:70:BD:C0:46:D6:DC:08:20:4F:C7:07:00:CC:81:08:20:7B:D3:00:00:11:AB:08:00:8B:26:07:00:21:20:07:00:33:79:06:00:7F:7C:08:20:06:10:0E:20:31:C6:07:00:A6:7E:08:20:C0:F0:0C:20:95:77:08:20:A2:00:08:20:71:05:07:00:D7:DC:08:20:40:A0:08:20:CB:9A:08:20:38:09:0A:00:E5:69:08:20:65:A3:08:20:8C:E8:0C:20:90:77:08:20:04:F0:0E:20"
    16:48:17.962 --
    16:48:17.962 Outgoing Dump:
    16:48:17.962 0000: 01 05 ff f5 80 16 1a 00 f0 00 78 a8 42 20 dc 21 ..........x.B .!
    16:48:17.962 0010: 43 19 70 2c 49 01 f1 30 03 18 68 40 f0 20 00 18 C.p,I..0..h@. ..
    16:48:17.962 0020: 60 88 7c 40 1c 88 74 91 f8 e6 00 40 1c 81 f8 e6 `.|@..t....@....
    16:48:17.962 0030: 00 2e 49 4f f4 00 70 08 80 2d 48 00 78 ff 28 07 ..IO..p..-H.x.(.
    16:48:17.962 0040: d0 2c 49 82 40 08 68 10 43 08 60 08 68 90 43 08 .,I.@.h.C.`.h.C.
    16:48:17.962 0050: 60 70 bd c0 46 81 ab 02 00 63 ab 08 00 cc dc 08 `p..F....c......
    16:48:17.962 0060: 20 70 b5 05 46 68 69 98 b9 28 7f 30 b1 22 48 00 p..Fhi..(.0."H.
    16:48:17.962 0070: 88 80 09 02 d3 ad 49 01 20 88 47 ad 4c a0 47 ad ......I. .G.L.G.
    16:48:17.962 0080: 49 06 46 88 47 a0 47 b0 42 f9 d1 ab 48 42 30 68 I.F.G.G.B...HB0h
    16:48:17.962 0090: 63 70 bd c0 46 d6 dc 08 20 4f c7 07 00 cc 81 08 cp..F... O......
    16:48:17.962 00a0: 20 7b d3 00 00 11 ab 08 00 8b 26 07 00 21 20 07 {........&..! .
    16:48:17.962 00b0: 00 33 79 06 00 7f 7c 08 20 06 10 0e 20 31 c6 07 .3y...|. ... 1..
    16:48:17.962 00c0: 00 a6 7e 08 20 c0 f0 0c 20 95 77 08 20 a2 00 08 ..~. ... .w. ...
    16:48:17.962 00d0: 20 71 05 07 00 d7 dc 08 20 40 a0 08 20 cb 9a 08 q...... @.. ...
    16:48:17.962 00e0: 20 38 09 0a 00 e5 69 08 20 65 a3 08 20 8c e8 0c 8....i. e.. ...
    16:48:17.962 00f0: 20 90 77 08 20 04 f0 0e 20 .w. ...
    16:48:17.993 Incoming Dump:
    16:48:17.993 0000: 04 0e 04 01 05 ff 00 .......
    16:48:17.993 --
    16:48:17.993 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:17.993 Parameters:
    16:48:17.993 | Number HCI commands : 0x01
    16:48:17.993 | Command Opcode : 0xff05
    16:48:17.993 | Status : 0x00 (Success)
    16:48:17.993 --
    16:48:17.993 --
    16:48:17.993 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:17.993 | Address : 0x001a1770
    16:48:17.993 | Size : 0xf0
    16:48:17.993 | Values : "CA:A6:08:20:2D:E9:F0:4F:AD:F1:14:0D:8D:49:DF:F8:90:B2:DF:F8:34:C2:02:90:0F:78:9B:F8:42:40:AC:F1:01:05:40:F2:E2:49:07:23:00:22:4F:F6:FF:71:88:46:03:91:11:46:15:F8:01:6F:B7:42:04:DB:5B:1E:01:F1:01:01:F7:D1:12:E0:CA:B2:B4:20:50:43:7F:4A:80:4E:15:5C:C8:B2:1C:F8:00:00:CB:B2:41:F2:B3:52:4F:F4:62:71:00:90:03:20:01:95:B0:47:01:22:9B:F8:5E:00:00:28:00:F0:B5:80:9B:F8:74:00:00:28:40:F0:B0:80:9C:48:00:2A:40:F0:94:80:FF:2C:20:D0:4F:EA:44:11:A1:EB:84:01:0C:46:04:EB:0B:01:91:F8:95:60:35:46:85:B1:4F:EA:05:11:40:5C:60:B1:93:49:30:46:88:47:92:49:30:46:88:47:92:49:30:46:88:47:59:46:64:18:94:F8:95:50:0B:EB:05:11:09:89:30:46:83:E0:03:99:8C:48:00:26:5F:46:04:91:A0:F1:08:0E:A1:F1:01:01:04:91:3E:F8:10:0F:40:F2:E2:42:10:1A:BB:1D:90:FB"
    16:48:17.993 --
    16:48:17.993 Outgoing Dump:
    16:48:17.993 0000: 01 05 ff f5 70 17 1a 00 f0 ca a6 08 20 2d e9 f0 ....p....... -..
    16:48:17.993 0010: 4f ad f1 14 0d 8d 49 df f8 90 b2 df f8 34 c2 02 O.....I......4..
    16:48:17.993 0020: 90 0f 78 9b f8 42 40 ac f1 01 05 40 f2 e2 49 07 ..x..B@....@..I.
    16:48:17.993 0030: 23 00 22 4f f6 ff 71 88 46 03 91 11 46 15 f8 01 #."O..q.F...F...
    16:48:17.993 0040: 6f b7 42 04 db 5b 1e 01 f1 01 01 f7 d1 12 e0 ca o.B..[..........
    16:48:17.993 0050: b2 b4 20 50 43 7f 4a 80 4e 15 5c c8 b2 1c f8 00 .. PC.J.N.\.....
    16:48:17.993 0060: 00 cb b2 41 f2 b3 52 4f f4 62 71 00 90 03 20 01 ...A..RO.bq... .
    16:48:17.993 0070: 95 b0 47 01 22 9b f8 5e 00 00 28 00 f0 b5 80 9b ..G."..^..(.....
    16:48:17.993 0080: f8 74 00 00 28 40 f0 b0 80 9c 48 00 2a 40 f0 94 .t..(@....H.*@..
    16:48:17.993 0090: 80 ff 2c 20 d0 4f ea 44 11 a1 eb 84 01 0c 46 04 .., .O.D......F.
    16:48:17.993 00a0: eb 0b 01 91 f8 95 60 35 46 85 b1 4f ea 05 11 40 ......`5F..O...@
    16:48:17.993 00b0: 5c 60 b1 93 49 30 46 88 47 92 49 30 46 88 47 92 \`..I0F.G.I0F.G.
    16:48:17.993 00c0: 49 30 46 88 47 59 46 64 18 94 f8 95 50 0b eb 05 I0F.GYFd....P...
    16:48:17.993 00d0: 11 09 89 30 46 83 e0 03 99 8c 48 00 26 5f 46 04 ...0F.....H.&_F.
    16:48:17.993 00e0: 91 a0 f1 08 0e a1 f1 01 01 04 91 3e f8 10 0f 40 ...........>...@
    16:48:17.993 00f0: f2 e2 42 10 1a bb 1d 90 fb ..B......
    16:48:18.025 Incoming Dump:
    16:48:18.025 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.025 --
    16:48:18.025 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.025 Parameters:
    16:48:18.025 | Number HCI commands : 0x01
    16:48:18.025 | Command Opcode : 0xff05
    16:48:18.025 | Status : 0x00 (Success)
    16:48:18.025 --
    16:48:18.025 --
    16:48:18.040 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.040 Parameters:
    16:48:18.040 | Address : 0x001a1860
    16:48:18.040 | Size : 0xf0
    16:48:18.040 | Values : "F2:F1:51:43:40:1A:1F:FA:80:FC:04:98:19:88:00:F1:01:00:88:42:04:D0:49:1C:00:25:88:45:03:DD:0C:E0:04:99:01:25:F9:80:19:88:88:45:1E:DB:59:88:DD:F8:0C:A0:61:44:CA:44:8A:45:17:D9:59:88:15:B1:18:80:4F:F0:00:05:B3:F8:00:80:03:91:72:49:F4:B2:01:EB:04:11:09:89:94:46:A2:EB:01:01:91:FB:FC:F2:02:FB:0C:F2:A1:EB:02:01:1F:FA:81:F9:05:B1:18:80:76:1C:10:37:04:2E:BD:DB:03:99:88:42:1F:D0:6C:B1:65:48:00:EB:04:10:40:7B:40:B1:5F:49:20:46:88:47:5F:49:20:46:88:47:5E:49:20:46:88:47:B8:F1:02:0F:BC:BF:20:1C:03:99:1F:DB:21:01:5B:F8:01:10:08:EB:01:02:03:99:52:1E:20:46:22:F0:7C:42:16:E0:7C:48:18:E0:4F:EA:05:12:0B:EB:02:01:0C:89:55:B1:80:5C:40:B1:4D:49:28:46:88:47:4D:49:28:46:88:47:4C:49:28:46:88:47:21:46:28:46:4F:F0:FF:32:70:4B:98:47:01:E0"
    16:48:18.040 --
    16:48:18.040 Outgoing Dump:
    16:48:18.040 0000: 01 05 ff f5 60 18 1a 00 f0 f2 f1 51 43 40 1a 1f ....`......QC@..
    16:48:18.040 0010: fa 80 fc 04 98 19 88 00 f1 01 00 88 42 04 d0 49 ............B..I
    16:48:18.040 0020: 1c 00 25 88 45 03 dd 0c e0 04 99 01 25 f9 80 19 ..%.E.......%...
    16:48:18.040 0030: 88 88 45 1e db 59 88 dd f8 0c a0 61 44 ca 44 8a ..E..Y.....aD.D.
    16:48:18.040 0040: 45 17 d9 59 88 15 b1 18 80 4f f0 00 05 b3 f8 00 E..Y.....O......
    16:48:18.040 0050: 80 03 91 72 49 f4 b2 01 eb 04 11 09 89 94 46 a2 ...rI.........F.
    16:48:18.040 0060: eb 01 01 91 fb fc f2 02 fb 0c f2 a1 eb 02 01 1f ................
    16:48:18.040 0070: fa 81 f9 05 b1 18 80 76 1c 10 37 04 2e bd db 03 .......v..7.....
    16:48:18.040 0080: 99 88 42 1f d0 6c b1 65 48 00 eb 04 10 40 7b 40 ..B..l.eH....@{@
    16:48:18.040 0090: b1 5f 49 20 46 88 47 5f 49 20 46 88 47 5e 49 20 ._I F.G_I F.G^I
    16:48:18.040 00a0: 46 88 47 b8 f1 02 0f bc bf 20 1c 03 99 1f db 21 F.G...... .....!
    16:48:18.040 00b0: 01 5b f8 01 10 08 eb 01 02 03 99 52 1e 20 46 22 .[.........R. F"
    16:48:18.040 00c0: f0 7c 42 16 e0 7c 48 18 e0 4f ea 05 12 0b eb 02 .|B..|H..O......
    16:48:18.040 00d0: 01 0c 89 55 b1 80 5c 40 b1 4d 49 28 46 88 47 4d ...U..\@.MI(F.GM
    16:48:18.040 00e0: 49 28 46 88 47 4c 49 28 46 88 47 21 46 28 46 4f I(F.GLI(F.G!F(FO
    16:48:18.040 00f0: f0 ff 32 70 4b 98 47 01 e0 ..2pK.G..
    16:48:18.071 Incoming Dump:
    16:48:18.071 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.071 --
    16:48:18.071 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.071 Parameters:
    16:48:18.071 | Number HCI commands : 0x01
    16:48:18.071 | Command Opcode : 0xff05
    16:48:18.071 | Status : 0x00 (Success)
    16:48:18.071 --
    16:48:18.071 --
    16:48:18.071 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.071 | Address : 0x001a1950
    16:48:18.071 | Size : 0xf0
    16:48:18.071 | Values : "70:48:80:47:71:4D:28:68:B0:F5:48:7F:1A:D3:70:4C:6A:69:2B:69:4F:F4:31:71:02:20:A0:47:EA:68:AB:68:40:F2:A1:31:02:20:A0:47:AA:69:EB:69:40:F2:9F:31:02:20:A0:47:00:20:E8:61:A8:61:E8:60:A8:60:28:61:68:61:28:60:02:99:60:48:05:B0:00:F5:95:70:48:63:BD:E8:F0:8F:4D:DE:04:00:AD:0C:06:00:09:03:1A:00:C5:E0:04:00:81:DC:08:20:88:DC:08:20:2F:96:08:20:01:C6:07:00:2D:E9:F0:41:56:4F:06:46:DF:F8:58:81:97:F8:26:00:71:69:28:B9:00:25:40:46:B5:61:24:30:70:63:00:E0:0F:25:05:29:3A:D1:40:46:08:4C:00:F1:24:08:94:F8:73:00:02:28:2F:D1:B4:F8:70:00:4F:F6:FF:71:81:42:29:D0:E0:6E:B0:F1:FF:3F:23:D0:01:E0:F4:9F:08:20:94:F8:72:00:FE:28:08:BF:94:F8:52:00:42:49:88:47:A2:4A:E1:6E:90:47:04:46:B9:8D:BA:7C:38:88:40:1A:40:F2:E2:41:01:FB:02:00:00:F5:16:70"
    16:48:18.071 --
    16:48:18.071 Outgoing Dump:
    16:48:18.071 0000: 01 05 ff f5 50 19 1a 00 f0 70 48 80 47 71 4d 28 ....P....pH.GqM(
    16:48:18.071 0010: 68 b0 f5 48 7f 1a d3 70 4c 6a 69 2b 69 4f f4 31 h..H...pLji+iO.1
    16:48:18.071 0020: 71 02 20 a0 47 ea 68 ab 68 40 f2 a1 31 02 20 a0 q. .G.h.h@..1. .
    16:48:18.071 0030: 47 aa 69 eb 69 40 f2 9f 31 02 20 a0 47 00 20 e8 G.i.i@..1. .G. .
    16:48:18.071 0040: 61 a8 61 e8 60 a8 60 28 61 68 61 28 60 02 99 60 a.a.`.`(aha(`..`
    16:48:18.071 0050: 48 05 b0 00 f5 95 70 48 63 bd e8 f0 8f 4d de 04 H.....pHc....M..
    16:48:18.071 0060: 00 ad 0c 06 00 09 03 1a 00 c5 e0 04 00 81 dc 08 ................
    16:48:18.071 0070: 20 88 dc 08 20 2f 96 08 20 01 c6 07 00 2d e9 f0 ... /.. ....-..
    16:48:18.071 0080: 41 56 4f 06 46 df f8 58 81 97 f8 26 00 71 69 28 AVO.F..X...&.qi(
    16:48:18.071 0090: b9 00 25 40 46 b5 61 24 30 70 63 00 e0 0f 25 05 ..%@F.a$0pc...%.
    16:48:18.071 00a0: 29 3a d1 40 46 08 4c 00 f1 24 08 94 f8 73 00 02 ):.@F.L..$...s..
    16:48:18.071 00b0: 28 2f d1 b4 f8 70 00 4f f6 ff 71 81 42 29 d0 e0 (/...p.O..q.B)..
    16:48:18.071 00c0: 6e b0 f1 ff 3f 23 d0 01 e0 f4 9f 08 20 94 f8 72 n...?#...... ..r
    16:48:18.071 00d0: 00 fe 28 08 bf 94 f8 52 00 42 49 88 47 a2 4a e1 ..(....R.BI.G.J.
    16:48:18.071 00e0: 6e 90 47 04 46 b9 8d ba 7c 38 88 40 1a 40 f2 e2 n.G.F...|8.@.@..
    16:48:18.071 00f0: 41 01 fb 02 00 00 f5 16 70 A.......p
    16:48:18.103 Incoming Dump:
    16:48:18.103 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.103 --
    16:48:18.103 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.103 Parameters:
    16:48:18.103 | Number HCI commands : 0x01
    16:48:18.103 | Command Opcode : 0xff05
    16:48:18.103 | Status : 0x00 (Success)
    16:48:18.103 --
    16:48:18.103 --
    16:48:18.103 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.103 | Address : 0x001a1a40
    16:48:18.103 | Size : 0xf0
    16:48:18.103 | Values : "61:43:88:42:07:DA:A4:49:06:20:88:47:A3:4A:A1:1E:06:20:90:47:01:E0:05:F0:F6:05:C6:F8:34:80:B5:61:BD:E8:F0:81:89:7D:08:20:01:B6:04:00:DD:C1:04:00:1D:B0:08:00:7C:7D:08:20:2D:E9:F0:41:98:4A:07:46:01:21:BD:69:3E:7C:28:46:90:47:A2:4C:95:F8:C7:30:95:F8:B5:20:89:20:31:46:A0:47:A1:4C:95:F8:C7:20:9A:B1:DF:F8:74:82:31:46:8F:20:C0:47:9B:49:28:46:88:47:95:F8:C7:20:42:B1:02:2E:06:D0:31:46:8F:20:C0:47:20:46:00:F2:04:70:78:63:02:2E:04:BF:00:20:68:85:20:46:80:30:78:63:BD:E8:F0:81:10:B5:04:46:90:48:00:78:04:28:09:D1:8F:49:00:20:88:47:B0:F1:FF:3F:03:D1:8D:48:00:F5:B0:70:60:63:10:BD:00:B5:8C:48:8B:49:00:68:88:47:00:BD:C0:46:E7:36:03:00:A7:40:03:00:39:38:03:00:ED:40:03:00:04:DD:08:20:A1:C8:07:00:8C:6E:08:20:89:A9:06:00:81:9F:08:00"
    16:48:18.103 --
    16:48:18.103 Outgoing Dump:
    16:48:18.103 0000: 01 05 ff f5 40 1a 1a 00 f0 61 43 88 42 07 da a4 ....@....aC.B...
    16:48:18.103 0010: 49 06 20 88 47 a3 4a a1 1e 06 20 90 47 01 e0 05 I. .G.J... .G...
    16:48:18.103 0020: f0 f6 05 c6 f8 34 80 b5 61 bd e8 f0 81 89 7d 08 .....4..a.....}.
    16:48:18.103 0030: 20 01 b6 04 00 dd c1 04 00 1d b0 08 00 7c 7d 08 ............|}.
    16:48:18.103 0040: 20 2d e9 f0 41 98 4a 07 46 01 21 bd 69 3e 7c 28 -..A.J.F.!.i>|(
    16:48:18.103 0050: 46 90 47 a2 4c 95 f8 c7 30 95 f8 b5 20 89 20 31 F.G.L...0... . 1
    16:48:18.103 0060: 46 a0 47 a1 4c 95 f8 c7 20 9a b1 df f8 74 82 31 F.G.L... ....t.1
    16:48:18.103 0070: 46 8f 20 c0 47 9b 49 28 46 88 47 95 f8 c7 20 42 F. .G.I(F.G... B
    16:48:18.103 0080: b1 02 2e 06 d0 31 46 8f 20 c0 47 20 46 00 f2 04 .....1F. .G F...
    16:48:18.103 0090: 70 78 63 02 2e 04 bf 00 20 68 85 20 46 80 30 78 pxc..... h. F.0x
    16:48:18.103 00a0: 63 bd e8 f0 81 10 b5 04 46 90 48 00 78 04 28 09 c.......F.H.x.(.
    16:48:18.103 00b0: d1 8f 49 00 20 88 47 b0 f1 ff 3f 03 d1 8d 48 00 ..I. .G...?...H.
    16:48:18.103 00c0: f5 b0 70 60 63 10 bd 00 b5 8c 48 8b 49 00 68 88 ..p`c.....H.I.h.
    16:48:18.103 00d0: 47 00 bd c0 46 e7 36 03 00 a7 40 03 00 39 38 03 G...F.6...@..98.
    16:48:18.103 00e0: 00 ed 40 03 00 04 dd 08 20 a1 c8 07 00 8c 6e 08 ..@..... .....n.
    16:48:18.103 00f0: 20 89 a9 06 00 81 9f 08 00 ........
    16:48:18.134 Incoming Dump:
    16:48:18.134 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.134 --
    16:48:18.134 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.134 Parameters:
    16:48:18.134 | Number HCI commands : 0x01
    16:48:18.134 | Command Opcode : 0xff05
    16:48:18.134 | Status : 0x00 (Success)
    16:48:18.134 --
    16:48:18.134 --
    16:48:18.134 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.134 | Address : 0x001a1b30
    16:48:18.134 | Size : 0xf0
    16:48:18.134 | Values : "2D:E9:F0:4F:AD:F1:14:0D:01:46:02:90:08:7E:03:90:0F:69:4F:F4:70:71:B9:80:01:21:79:80:B9:72:9E:49:09:68:78:4E:04:91:31:68:91:4D:00:91:00:21:AD:F8:04:10:29:78:08:42:00:F0:AE:80:8E:4C:20:78:DF:F8:44:82:C1:11:8C:48:DF:F8:34:B2:00:78:00:28:40:F0:8A:80:DF:F8:2C:91:69:68:04:98:C8:47:5C:46:82:46:20:78:C1:08:04:D3:E9:68:04:98:C8:47:81:46:20:78:B6:F9:04:B0:BA:F1:00:0F:11:DC:40:09:09:D2:80:48:80:47:70:89:18:B1:BB:F1:00:0F:4A:D5:50:E0:6B:46:64:E0:70:89:00:28:44:D1:7B:48:80:47:59:E0:81:10:C2:08:01:F0:01:01:0E:D3:B9:F1:00:0F:0B:D1:00:F0:FB:00:76:4B:20:70:00:22:B4:21:02:20:98:47:20:78:81:10:01:F0:01:01:DF:F8:C8:C1:BA:F1:01:0F:13:D0:AA:F1:01:00:80:B2:38:80:00:29:78:80:5B:D0:B9:F1:00:0F:06:DC:EA:68:6B:68:04:99:4F:F4:F2:70:E0:47"
    16:48:18.134 --
    16:48:18.134 Outgoing Dump:
    16:48:18.134 0000: 01 05 ff f5 30 1b 1a 00 f0 2d e9 f0 4f ad f1 14 ....0....-..O...
    16:48:18.134 0010: 0d 01 46 02 90 08 7e 03 90 0f 69 4f f4 70 71 b9 ..F...~...iO.pq.
    16:48:18.134 0020: 80 01 21 79 80 b9 72 9e 49 09 68 78 4e 04 91 31 ..!y..r.I.hxN..1
    16:48:18.134 0030: 68 91 4d 00 91 00 21 ad f8 04 10 29 78 08 42 00 h.M...!....)x.B.
    16:48:18.134 0040: f0 ae 80 8e 4c 20 78 df f8 44 82 c1 11 8c 48 df ....L x..D....H.
    16:48:18.134 0050: f8 34 b2 00 78 00 28 40 f0 8a 80 df f8 2c 91 69 .4..x.(@.....,.i
    16:48:18.134 0060: 68 04 98 c8 47 5c 46 82 46 20 78 c1 08 04 d3 e9 h...G\F.F x.....
    16:48:18.134 0070: 68 04 98 c8 47 81 46 20 78 b6 f9 04 b0 ba f1 00 h...G.F x.......
    16:48:18.134 0080: 0f 11 dc 40 09 09 d2 80 48 80 47 70 89 18 b1 bb ...@....H.Gp....
    16:48:18.134 0090: f1 00 0f 4a d5 50 e0 6b 46 64 e0 70 89 00 28 44 ...J.P.kFd.p..(D
    16:48:18.134 00a0: d1 7b 48 80 47 59 e0 81 10 c2 08 01 f0 01 01 0e .{H.GY..........
    16:48:18.134 00b0: d3 b9 f1 00 0f 0b d1 00 f0 fb 00 76 4b 20 70 00 ...........vK p.
    16:48:18.134 00c0: 22 b4 21 02 20 98 47 20 78 81 10 01 f0 01 01 df ".!. .G x.......
    16:48:18.134 00d0: f8 c8 c1 ba f1 01 0f 13 d0 aa f1 01 00 80 b2 38 ...............8
    16:48:18.134 00e0: 80 00 29 78 80 5b d0 b9 f1 00 0f 06 dc ea 68 6b ..)x.[........hk
    16:48:18.134 00f0: 68 04 99 4f f4 f2 70 e0 47 h..O..p.G
    16:48:18.165 Incoming Dump:
    16:48:18.165 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.165 --
    16:48:18.165 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.165 Parameters:
    16:48:18.165 | Number HCI commands : 0x01
    16:48:18.165 | Command Opcode : 0xff05
    16:48:18.165 | Status : 0x00 (Success)
    16:48:18.165 --
    16:48:18.165 --
    16:48:18.165 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.165 | Address : 0x001a1c20
    16:48:18.165 | Size : 0xf0
    16:48:18.165 | Values : "51:E0:A7:F8:02:90:4E:E0:02:09:4C:D2:40:F0:08:00:20:70:70:89:63:4E:30:B9:B0:47:10:BB:20:78:00:23:00:F0:F7:00:21:E0:6B:68:EA:68:A9:B9:BB:F1:00:0F:05:D4:00:20:A8:49:38:80:FF:20:88:47:33:E0:B0:47:20:78:00:F0:EF:00:20:70:03:9A:6B:46:A0:21:07:20:C0:47:01:20:38:80:26:E0:04:99:40:F2:E3:10:E0:47:B0:47:20:78:6B:46:00:F0:EF:00:20:70:03:9A:A0:21:07:20:C0:47:17:E0:69:B9:59:46:08:78:00:F0:EF:00:08:70:03:9A:6B:46:A0:21:07:20:C0:47:07:E0:C0:46:01:C4:07:00:41:4B:6A:46:B5:21:02:20:98:47:20:78:40:F0:80:00:20:70:02:99:8C:48:05:B0:00:F5:F4:70:48:63:BD:E8:F0:8F:C0:46:85:1B:06:00:85:1F:06:00:0D:61:00:00:01:68:91:F8:61:20:01:F1:5E:00:10:2A:07:D1:91:F8:5F:20:01:2A:03:D1:11:22:81:F8:61:20:82:70:C1:78:11:29:04:D1:41:78:11:B9:01:21:41:70"
    16:48:18.165 --
    16:48:18.165 Outgoing Dump:
    16:48:18.165 0000: 01 05 ff f5 20 1c 1a 00 f0 51 e0 a7 f8 02 90 4e .... ....Q.....N
    16:48:18.165 0010: e0 02 09 4c d2 40 f0 08 00 20 70 70 89 63 4e 30 ...L.@... pp.cN0
    16:48:18.165 0020: b9 b0 47 10 bb 20 78 00 23 00 f0 f7 00 21 e0 6b ..G.. x.#....!.k
    16:48:18.165 0030: 68 ea 68 a9 b9 bb f1 00 0f 05 d4 00 20 a8 49 38 h.h......... .I8
    16:48:18.165 0040: 80 ff 20 88 47 33 e0 b0 47 20 78 00 f0 ef 00 20 .. .G3..G x....
    16:48:18.165 0050: 70 03 9a 6b 46 a0 21 07 20 c0 47 01 20 38 80 26 p..kF.!. .G. 8.&
    16:48:18.165 0060: e0 04 99 40 f2 e3 10 e0 47 b0 47 20 78 6b 46 00 ...@....G.G xkF.
    16:48:18.165 0070: f0 ef 00 20 70 03 9a a0 21 07 20 c0 47 17 e0 69 ... p...!. .G..i
    16:48:18.165 0080: b9 59 46 08 78 00 f0 ef 00 08 70 03 9a 6b 46 a0 .YF.x.....p..kF.
    16:48:18.165 0090: 21 07 20 c0 47 07 e0 c0 46 01 c4 07 00 41 4b 6a !. .G...F....AKj
    16:48:18.165 00a0: 46 b5 21 02 20 98 47 20 78 40 f0 80 00 20 70 02 F.!. .G x@... p.
    16:48:18.165 00b0: 99 8c 48 05 b0 00 f5 f4 70 48 63 bd e8 f0 8f c0 ..H.....pHc.....
    16:48:18.165 00c0: 46 85 1b 06 00 85 1f 06 00 0d 61 00 00 01 68 91 F.........a...h.
    16:48:18.165 00d0: f8 61 20 01 f1 5e 00 10 2a 07 d1 91 f8 5f 20 01 .a ..^..*...._ .
    16:48:18.165 00e0: 2a 03 d1 11 22 81 f8 61 20 82 70 c1 78 11 29 04 *..."..a .p.x.).
    16:48:18.165 00f0: d1 41 78 11 b9 01 21 41 70 .Ax...!Ap
    16:48:18.196 Incoming Dump:
    16:48:18.196 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.196 --
    16:48:18.196 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.196 Parameters:
    16:48:18.196 | Number HCI commands : 0x01
    16:48:18.196 | Command Opcode : 0xff05
    16:48:18.196 | Status : 0x00 (Success)
    16:48:18.196 --
    16:48:18.196 --
    16:48:18.196 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.196 | Address : 0x001a1d10
    16:48:18.196 | Size : 0xf0
    16:48:18.196 | Values : "01:70:70:47:19:C6:07:00:8D:C6:07:00:F5:67:00:00:5D:6E:00:00:28:0A:08:20:5D:62:00:00:41:92:00:00:21:5E:00:00:F4:9F:08:20:30:B5:04:46:A1:69:65:69:00:29:2C:D0:88:88:08:18:02:7A:00:F1:09:03:F8:2A:4F:EA:62:00:2C:BF:1A:78:00:22:95:F8:3A:30:20:2B:08:BF:19:2A:14:D0:18:28:19:D1:24:2B:05:D0:95:F8:39:00:24:28:13:D1:62:49:07:E0:95:F8:AA:01:02:28:02:D1:60:49:28:46:88:47:5F:49:28:46:88:47:30:BD:5E:4A:05:F5:B6:70:90:47:5D:48:D2:30:60:63:30:BD:3C:81:08:20:CA:41:08:20:5C:81:08:20:3A:81:08:20:5F:34:00:00:F9:24:00:00:0B:3E:00:00:EF:2A:00:00:61:C6:07:00:2D:3F:00:00:80:7D:08:20:2D:E9:F8:4F:01:46:00:90:52:4A:DF:F8:40:81:4E:4B:DF:F8:48:91:50:4C:4F:69:CE:69:97:F8:01:B0:59:46:25:39:30:D0:49:1E:74:D1:04:20:B0:80:39:78:06:F1:0C:00:41:EA"
    16:48:18.196 --
    16:48:18.196 Outgoing Dump:
    16:48:18.196 0000: 01 05 ff f5 10 1d 1a 00 f0 01 70 70 47 19 c6 07 ..........ppG...
    16:48:18.196 0010: 00 8d c6 07 00 f5 67 00 00 5d 6e 00 00 28 0a 08 ......g..]n..(..
    16:48:18.196 0020: 20 5d 62 00 00 41 92 00 00 21 5e 00 00 f4 9f 08 ]b..A...!^.....
    16:48:18.196 0030: 20 30 b5 04 46 a1 69 65 69 00 29 2c d0 88 88 08 0..F.iei.),....
    16:48:18.196 0040: 18 02 7a 00 f1 09 03 f8 2a 4f ea 62 00 2c bf 1a ..z.....*O.b.,..
    16:48:18.196 0050: 78 00 22 95 f8 3a 30 20 2b 08 bf 19 2a 14 d0 18 x."..:0 +...*...
    16:48:18.196 0060: 28 19 d1 24 2b 05 d0 95 f8 39 00 24 28 13 d1 62 (..$+....9.$(..b
    16:48:18.196 0070: 49 07 e0 95 f8 aa 01 02 28 02 d1 60 49 28 46 88 I.......(..`I(F.
    16:48:18.196 0080: 47 5f 49 28 46 88 47 30 bd 5e 4a 05 f5 b6 70 90 G_I(F.G0.^J...p.
    16:48:18.196 0090: 47 5d 48 d2 30 60 63 30 bd 3c 81 08 20 ca 41 08 G]H.0`c0.<.. .A.
    16:48:18.196 00a0: 20 5c 81 08 20 3a 81 08 20 5f 34 00 00 f9 24 00 \.. :.. _4...$.
    16:48:18.196 00b0: 00 0b 3e 00 00 ef 2a 00 00 61 c6 07 00 2d 3f 00 ..>...*..a...-?.
    16:48:18.196 00c0: 00 80 7d 08 20 2d e9 f8 4f 01 46 00 90 52 4a df ..}. -..O.F..RJ.
    16:48:18.196 00d0: f8 40 81 4e 4b df f8 48 91 50 4c 4f 69 ce 69 97 .@.NK..H.PLOi.i.
    16:48:18.196 00e0: f8 01 b0 59 46 25 39 30 d0 49 1e 74 d1 04 20 b0 ...YF%90.I.t.. .
    16:48:18.196 00f0: 80 39 78 06 f1 0c 00 41 ea .9x....A.
    16:48:18.228 Incoming Dump:
    16:48:18.228 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.228 --
    16:48:18.228 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.228 Parameters:
    16:48:18.228 | Number HCI commands : 0x01
    16:48:18.228 | Command Opcode : 0xff05
    16:48:18.228 | Status : 0x00 (Success)
    16:48:18.228 --
    16:48:18.228 --
    16:48:18.228 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.228 | Address : 0x001a1e00
    16:48:18.228 | Size : 0xf0
    16:48:18.228 | Values : "4B:01:00:F8:01:1B:19:78:40:29:17:D0:41:29:0A:D0:08:21:92:46:00:F8:01:1B:0D:21:D0:47:49:46:09:78:06:29:3B:D0:38:E0:07:21:92:46:00:F8:01:1B:0D:21:D0:47:49:46:09:78:06:29:30:D0:2D:E0:06:25:92:46:0D:21:00:F8:01:5B:D0:47:49:46:09:78:06:29:34:D0:31:E0:04:20:B0:80:39:78:06:F1:0C:00:41:EA:4B:01:00:F8:01:1B:19:78:40:29:1B:D0:41:29:0A:D0:08:21:92:46:00:F8:01:1B:0D:21:D0:47:49:46:09:78:06:29:0C:D0:09:E0:07:21:92:46:00:F8:01:1B:0D:21:D0:47:49:46:09:78:06:29:01:D0:0B:21:00:E0:0C:21:06:25:0C:E0:06:25:92:46:0D:21:00:F8:01:5B:D0:47:49:46:09:78:06:29:01:D0:0B:21:00:E0:0C:21:42:46:12:78:02:F0:7F:02:42:EA:81:22:14:43:A1:B2:D0:47:75:80:03:20:30:80:11:48:00:99:00:F5:96:60:48:63:BB:F1:04:0F:07:D1:38:79:27:28:04:D1:78:79:1E:28:04:BF"
    16:48:18.228 --
    16:48:18.228 Outgoing Dump:
    16:48:18.228 0000: 01 05 ff f5 00 1e 1a 00 f0 4b 01 00 f8 01 1b 19 .........K......
    16:48:18.228 0010: 78 40 29 17 d0 41 29 0a d0 08 21 92 46 00 f8 01 x@)..A)...!.F...
    16:48:18.228 0020: 1b 0d 21 d0 47 49 46 09 78 06 29 3b d0 38 e0 07 ..!.GIF.x.);.8..
    16:48:18.228 0030: 21 92 46 00 f8 01 1b 0d 21 d0 47 49 46 09 78 06 !.F.....!.GIF.x.
    16:48:18.228 0040: 29 30 d0 2d e0 06 25 92 46 0d 21 00 f8 01 5b d0 )0.-..%.F.!...[.
    16:48:18.228 0050: 47 49 46 09 78 06 29 34 d0 31 e0 04 20 b0 80 39 GIF.x.)4.1.. ..9
    16:48:18.228 0060: 78 06 f1 0c 00 41 ea 4b 01 00 f8 01 1b 19 78 40 x....A.K......x@
    16:48:18.228 0070: 29 1b d0 41 29 0a d0 08 21 92 46 00 f8 01 1b 0d )..A)...!.F.....
    16:48:18.228 0080: 21 d0 47 49 46 09 78 06 29 0c d0 09 e0 07 21 92 !.GIF.x.).....!.
    16:48:18.228 0090: 46 00 f8 01 1b 0d 21 d0 47 49 46 09 78 06 29 01 F.....!.GIF.x.).
    16:48:18.228 00a0: d0 0b 21 00 e0 0c 21 06 25 0c e0 06 25 92 46 0d ..!...!.%...%.F.
    16:48:18.228 00b0: 21 00 f8 01 5b d0 47 49 46 09 78 06 29 01 d0 0b !...[.GIF.x.)...
    16:48:18.228 00c0: 21 00 e0 0c 21 42 46 12 78 02 f0 7f 02 42 ea 81 !...!BF.x....B..
    16:48:18.228 00d0: 22 14 43 a1 b2 d0 47 75 80 03 20 30 80 11 48 00 ".C...Gu.. 0..H.
    16:48:18.228 00e0: 99 00 f5 96 60 48 63 bb f1 04 0f 07 d1 38 79 27 ....`Hc......8y'
    16:48:18.228 00f0: 28 04 d1 78 79 1e 28 04 bf (..xy.(..
    16:48:18.259 Incoming Dump:
    16:48:18.259 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.259 --
    16:48:18.259 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.259 Parameters:
    16:48:18.259 | Number HCI commands : 0x01
    16:48:18.259 | Command Opcode : 0xff05
    16:48:18.259 | Status : 0x00 (Success)
    16:48:18.259 --
    16:48:18.259 --
    16:48:18.259 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.259 | Address : 0x001a1ef0
    16:48:18.259 | Size : 0xf0
    16:48:18.259 | Values : "23:20:78:71:BD:E8:F8:8F:A1:C2:00:00:55:40:00:00:EB:B1:02:00:15:D9:07:00:A1:B1:02:00:01:09:03:00:29:D0:01:00:E4:69:08:20:3B:84:08:20:71:AE:01:00:FB:D3:00:00:00:80:FF:FF:7F:7C:08:20:2D:E9:F0:4F:9F:48:9E:4C:07:46:0A:37:B7:F8:E0:13:C1:F3:44:21:0F:29:27:BF:B4:F8:84:15:C1:F3:C1:11:B4:F8:84:15:C1:F3:81:01:94:4B:99:70:5A:78:99:78:02:F0:07:02:01:F0:03:05:11:01:DA:78:41:EA:85:01:02:F0:03:02:0A:43:D1:B2:DB:4A:19:70:11:70:5A:78:00:21:3C:25:02:2A:04:D1:9A:78:12:B9:DA:78:02:B9:01:21:8A:46:D5:49:09:88:49:0A:0B:D3:B4:F8:9C:11:41:F0:C0:01:A4:F8:9C:11:B4:F8:7E:11:21:F0:02:01:A4:F8:7E:11:B4:F8:A0:11:21:F0:01:01:A4:F8:A0:11:CB:4B:B4:F8:80:11:41:F4:00:61:A4:F8:80:11:B4:F8:9C:13:21:F0:01:01:A4:F8:9C:13:B4:F8:58:11:01:22:21:F0:01:01"
    16:48:18.259 --
    16:48:18.259 Outgoing Dump:
    16:48:18.259 0000: 01 05 ff f5 f0 1e 1a 00 f0 23 20 78 71 bd e8 f8 .........# xq...
    16:48:18.259 0010: 8f a1 c2 00 00 55 40 00 00 eb b1 02 00 15 d9 07 .....U@.........
    16:48:18.259 0020: 00 a1 b1 02 00 01 09 03 00 29 d0 01 00 e4 69 08 .........)....i.
    16:48:18.259 0030: 20 3b 84 08 20 71 ae 01 00 fb d3 00 00 00 80 ff ;.. q..........
    16:48:18.259 0040: ff 7f 7c 08 20 2d e9 f0 4f 9f 48 9e 4c 07 46 0a ..|. -..O.H.L.F.
    16:48:18.259 0050: 37 b7 f8 e0 13 c1 f3 44 21 0f 29 27 bf b4 f8 84 7......D!.)'....
    16:48:18.259 0060: 15 c1 f3 c1 11 b4 f8 84 15 c1 f3 81 01 94 4b 99 ..............K.
    16:48:18.259 0070: 70 5a 78 99 78 02 f0 07 02 01 f0 03 05 11 01 da pZx.x...........
    16:48:18.259 0080: 78 41 ea 85 01 02 f0 03 02 0a 43 d1 b2 db 4a 19 xA........C...J.
    16:48:18.259 0090: 70 11 70 5a 78 00 21 3c 25 02 2a 04 d1 9a 78 12 p.pZx.!<%.*...x.
    16:48:18.259 00a0: b9 da 78 02 b9 01 21 8a 46 d5 49 09 88 49 0a 0b ..x...!.F.I..I..
    16:48:18.259 00b0: d3 b4 f8 9c 11 41 f0 c0 01 a4 f8 9c 11 b4 f8 7e .....A.........~
    16:48:18.259 00c0: 11 21 f0 02 01 a4 f8 7e 11 b4 f8 a0 11 21 f0 01 .!.....~.....!..
    16:48:18.259 00d0: 01 a4 f8 a0 11 cb 4b b4 f8 80 11 41 f4 00 61 a4 ......K....A..a.
    16:48:18.259 00e0: f8 80 11 b4 f8 9c 13 21 f0 01 01 a4 f8 9c 13 b4 .......!........
    16:48:18.259 00f0: f8 58 11 01 22 21 f0 01 01 .X.."!...
    16:48:18.290 Incoming Dump:
    16:48:18.290 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.290 --
    16:48:18.290 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.290 Parameters:
    16:48:18.290 | Number HCI commands : 0x01
    16:48:18.290 | Command Opcode : 0xff05
    16:48:18.290 | Status : 0x00 (Success)
    16:48:18.290 --
    16:48:18.290 --
    16:48:18.290 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.290 | Address : 0x001a1fe0
    16:48:18.290 | Size : 0xf0
    16:48:18.290 | Values : "A4:F8:58:11:00:21:98:47:B4:F8:7A:03:20:F4:80:60:40:F4:6C:50:A4:F8:7A:03:B4:F8:26:03:20:F0:10:00:A4:F8:26:03:BB:4E:B4:F8:26:03:DF:F8:FC:B2:20:F0:20:00:A4:F8:26:03:B4:F8:28:03:20:F0:01:00:A4:F8:28:03:B4:F8:28:03:20:F0:02:00:A4:F8:28:03:B4:F8:12:03:20:F4:80:70:A4:F8:12:03:B4:F8:16:03:20:F4:80:70:A4:F8:16:03:B4:F8:18:03:20:F4:80:70:A4:F8:18:03:B4:F8:1A:03:20:F4:80:70:A4:F8:1A:03:B4:F8:1C:03:20:F4:80:70:A4:F8:1C:03:B4:F8:F6:02:20:F4:80:70:A4:F8:F6:02:B4:F8:7C:03:20:F0:38:00:A4:F8:7C:03:B4:F8:88:03:20:F0:38:00:A4:F8:88:03:B4:F8:C6:02:20:F4:70:60:A4:F8:C6:02:95:48:DF:F8:60:92:01:88:21:F0:0F:01:41:F0:17:01:01:80:00:1D:00:88:20:F0:1F:00:A6:F8:4C:01:B4:F8:5A:01:20:F0:60:00:40:F0:18:00:A4:F8:5A:01:B4:F8:6C:00:BA:F1:00:0F"
    16:48:18.290 --
    16:48:18.290 Outgoing Dump:
    16:48:18.290 0000: 01 05 ff f5 e0 1f 1a 00 f0 a4 f8 58 11 00 21 98 ...........X..!.
    16:48:18.290 0010: 47 b4 f8 7a 03 20 f4 80 60 40 f4 6c 50 a4 f8 7a G..z. ..`@.lP..z
    16:48:18.290 0020: 03 b4 f8 26 03 20 f0 10 00 a4 f8 26 03 bb 4e b4 ...&. .....&..N.
    16:48:18.290 0030: f8 26 03 df f8 fc b2 20 f0 20 00 a4 f8 26 03 b4 .&..... . ...&..
    16:48:18.290 0040: f8 28 03 20 f0 01 00 a4 f8 28 03 b4 f8 28 03 20 .(. .....(...(.
    16:48:18.290 0050: f0 02 00 a4 f8 28 03 b4 f8 12 03 20 f4 80 70 a4 .....(..... ..p.
    16:48:18.290 0060: f8 12 03 b4 f8 16 03 20 f4 80 70 a4 f8 16 03 b4 ....... ..p.....
    16:48:18.290 0070: f8 18 03 20 f4 80 70 a4 f8 18 03 b4 f8 1a 03 20 ... ..p........
    16:48:18.290 0080: f4 80 70 a4 f8 1a 03 b4 f8 1c 03 20 f4 80 70 a4 ..p........ ..p.
    16:48:18.290 0090: f8 1c 03 b4 f8 f6 02 20 f4 80 70 a4 f8 f6 02 b4 ....... ..p.....
    16:48:18.290 00a0: f8 7c 03 20 f0 38 00 a4 f8 7c 03 b4 f8 88 03 20 .|. .8...|.....
    16:48:18.290 00b0: f0 38 00 a4 f8 88 03 b4 f8 c6 02 20 f4 70 60 a4 .8......... .p`.
    16:48:18.290 00c0: f8 c6 02 95 48 df f8 60 92 01 88 21 f0 0f 01 41 ....H..`...!...A
    16:48:18.290 00d0: f0 17 01 01 80 00 1d 00 88 20 f0 1f 00 a6 f8 4c ......... .....L
    16:48:18.290 00e0: 01 b4 f8 5a 01 20 f0 60 00 40 f0 18 00 a4 f8 5a ...Z. .`.@.....Z
    16:48:18.290 00f0: 01 b4 f8 6c 00 ba f1 00 0f ...l.....
    16:48:18.321 Incoming Dump:
    16:48:18.321 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.321 --
    16:48:18.321 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.321 Parameters:
    16:48:18.321 | Number HCI commands : 0x01
    16:48:18.321 | Command Opcode : 0xff05
    16:48:18.321 | Status : 0x00 (Success)
    16:48:18.321 --
    16:48:18.321 --
    16:48:18.321 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.321 | Address : 0x001a20d0
    16:48:18.321 | Size : 0xf0
    16:48:18.321 | Values : "00:F4:7F:40:A4:F8:6C:00:17:D0:DF:F8:20:82:86:48:00:21:C0:47:64:20:C8:47:86:48:00:21:C0:47:C8:46:64:20:C0:47:80:48:00:21:D8:47:64:20:C0:47:81:48:00:21:5A:46:90:47:64:20:C0:47:B4:F8:C2:02:20:F4:80:70:A4:F8:C2:02:B4:F8:B8:01:20:F0:02:00:A4:F8:B8:01:B4:F8:B8:01:20:F0:01:00:A4:F8:B8:01:77:48:07:21:01:70:6C:48:B0:F8:70:00:00:F0:1F:00:06:28:02:D1:CE:4A:CC:48:02:60:BA:F1:00:0F:16:D0:B4:F8:BC:00:40:F4:80:70:A4:F8:BC:00:20:46:BE:30:D8:47:B4:F8:8A:01:40:F0:01:00:A4:F8:8A:01:B4:F8:86:01:20:F0:0F:00:40:F0:07:00:A4:F8:86:01:B4:F8:78:03:20:F0:7F:00:40:F0:1C:00:A4:F8:78:03:B7:F8:EA:03:C0:F3:81:10:01:28:0D:D0:B4:F8:78:03:20:F4:FC:40:40:F4:10:60:0C:E0:C0:46:CB:77:08:20:88:20:0C:20:22:22:0C:20:B4:F8:78:03:20:F4:E0:40:40:F4:70:60"
    16:48:18.321 --
    16:48:18.321 Outgoing Dump:
    16:48:18.321 0000: 01 05 ff f5 d0 20 1a 00 f0 00 f4 7f 40 a4 f8 6c ..... ......@..l
    16:48:18.321 0010: 00 17 d0 df f8 20 82 86 48 00 21 c0 47 64 20 c8 ..... ..H.!.Gd .
    16:48:18.321 0020: 47 86 48 00 21 c0 47 c8 46 64 20 c0 47 80 48 00 G.H.!.G.Fd .G.H.
    16:48:18.321 0030: 21 d8 47 64 20 c0 47 81 48 00 21 5a 46 90 47 64 !.Gd .G.H.!ZF.Gd
    16:48:18.321 0040: 20 c0 47 b4 f8 c2 02 20 f4 80 70 a4 f8 c2 02 b4 .G.... ..p.....
    16:48:18.321 0050: f8 b8 01 20 f0 02 00 a4 f8 b8 01 b4 f8 b8 01 20 ... ...........
    16:48:18.321 0060: f0 01 00 a4 f8 b8 01 77 48 07 21 01 70 6c 48 b0 .......wH.!.plH.
    16:48:18.321 0070: f8 70 00 00 f0 1f 00 06 28 02 d1 ce 4a cc 48 02 .p......(...J.H.
    16:48:18.321 0080: 60 ba f1 00 0f 16 d0 b4 f8 bc 00 40 f4 80 70 a4 `..........@..p.
    16:48:18.321 0090: f8 bc 00 20 46 be 30 d8 47 b4 f8 8a 01 40 f0 01 ... F.0.G....@..
    16:48:18.321 00a0: 00 a4 f8 8a 01 b4 f8 86 01 20 f0 0f 00 40 f0 07 ......... ...@..
    16:48:18.321 00b0: 00 a4 f8 86 01 b4 f8 78 03 20 f0 7f 00 40 f0 1c .......x. ...@..
    16:48:18.321 00c0: 00 a4 f8 78 03 b7 f8 ea 03 c0 f3 81 10 01 28 0d ...x..........(.
    16:48:18.321 00d0: d0 b4 f8 78 03 20 f4 fc 40 40 f4 10 60 0c e0 c0 ...x. ..@@..`...
    16:48:18.321 00e0: 46 cb 77 08 20 88 20 0c 20 22 22 0c 20 b4 f8 78 F.w. . . "". ..x
    16:48:18.321 00f0: 03 20 f4 e0 40 40 f4 70 60 . ..@@.p`
    16:48:18.353 Incoming Dump:
    16:48:18.353 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.353 --
    16:48:18.353 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.353 Parameters:
    16:48:18.353 | Number HCI commands : 0x01
    16:48:18.353 | Command Opcode : 0xff05
    16:48:18.353 | Status : 0x00 (Success)
    16:48:18.353 --
    16:48:18.353 --
    16:48:18.353 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.353 | Address : 0x001a21c0
    16:48:18.353 | Size : 0xf0
    16:48:18.353 | Values : "A4:F8:78:03:B4:F8:5E:01:20:F0:02:00:A4:F8:5E:01:B6:F8:48:01:DF:F8:FC:82:20:F4:80:70:40:F4:00:70:A6:F8:48:01:B6:F8:22:01:20:F0:0F:00:40:F0:17:00:A6:F8:22:01:B6:F8:22:01:20:F4:00:70:40:F4:80:70:A6:F8:22:01:B6:F8:4C:01:40:F4:40:70:A6:F8:4C:01:B6:F8:40:01:20:F0:03:00:40:F0:1D:00:A6:F8:40:01:B6:F8:40:01:40:F4:40:70:A6:F8:40:01:B6:F8:B0:01:20:F0:01:00:A6:F8:B0:01:01:20:C0:47:F8:B9:B6:F8:6C:01:20:F0:03:00:40:F0:1D:00:A6:F8:6C:01:B6:F8:6C:01:20:F4:00:70:40:F4:80:70:A6:F8:6C:01:B6:F8:6E:01:20:F0:03:00:40:F0:1D:00:A6:F8:6E:01:B6:F8:6E:01:20:F4:00:70:40:F4:80:70:A6:F8:6E:01:B6:F8:70:01:40:F4:40:70:A6:F8:70:01:B6:F8:B0:01:40:F0:01:00:A6:F8:B0:01:B6:F8:0C:01:BA:F1:00:0F:20:F4:00:70:40:F4:80:70:A6:F8:0C:01:09:D0:B7:F8:3E:02"
    16:48:18.353 --
    16:48:18.353 Outgoing Dump:
    16:48:18.353 0000: 01 05 ff f5 c0 21 1a 00 f0 a4 f8 78 03 b4 f8 5e .....!.....x...^
    16:48:18.353 0010: 01 20 f0 02 00 a4 f8 5e 01 b6 f8 48 01 df f8 fc . .....^...H....
    16:48:18.353 0020: 82 20 f4 80 70 40 f4 00 70 a6 f8 48 01 b6 f8 22 . ..p@..p..H..."
    16:48:18.353 0030: 01 20 f0 0f 00 40 f0 17 00 a6 f8 22 01 b6 f8 22 . ...@....."..."
    16:48:18.353 0040: 01 20 f4 00 70 40 f4 80 70 a6 f8 22 01 b6 f8 4c . ..p@..p.."...L
    16:48:18.353 0050: 01 40 f4 40 70 a6 f8 4c 01 b6 f8 40 01 20 f0 03 .@.@p..L...@. ..
    16:48:18.353 0060: 00 40 f0 1d 00 a6 f8 40 01 b6 f8 40 01 40 f4 40 .@.....@...@.@.@
    16:48:18.353 0070: 70 a6 f8 40 01 b6 f8 b0 01 20 f0 01 00 a6 f8 b0 p..@..... ......
    16:48:18.353 0080: 01 01 20 c0 47 f8 b9 b6 f8 6c 01 20 f0 03 00 40 .. .G....l. ...@
    16:48:18.353 0090: f0 1d 00 a6 f8 6c 01 b6 f8 6c 01 20 f4 00 70 40 .....l...l. ..p@
    16:48:18.353 00a0: f4 80 70 a6 f8 6c 01 b6 f8 6e 01 20 f0 03 00 40 ..p..l...n. ...@
    16:48:18.353 00b0: f0 1d 00 a6 f8 6e 01 b6 f8 6e 01 20 f4 00 70 40 .....n...n. ..p@
    16:48:18.353 00c0: f4 80 70 a6 f8 6e 01 b6 f8 70 01 40 f4 40 70 a6 ..p..n...p.@.@p.
    16:48:18.353 00d0: f8 70 01 b6 f8 b0 01 40 f0 01 00 a6 f8 b0 01 b6 .p.....@........
    16:48:18.353 00e0: f8 0c 01 ba f1 00 0f 20 f4 00 70 40 f4 80 70 a6 ....... ..p@..p.
    16:48:18.353 00f0: f8 0c 01 09 d0 b7 f8 3e 02 .......>.
    16:48:18.384 Incoming Dump:
    16:48:18.384 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.384 --
    16:48:18.384 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.384 Parameters:
    16:48:18.384 | Number HCI commands : 0x01
    16:48:18.384 | Command Opcode : 0xff05
    16:48:18.384 | Status : 0x00 (Success)
    16:48:18.384 --
    16:48:18.384 --
    16:48:18.384 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.384 | Address : 0x001a22b0
    16:48:18.384 | Size : 0xf0
    16:48:18.384 | Values : "00:0B:05:D2:B4:F8:7A:02:20:F0:08:00:A4:F8:7A:02:B4:F8:58:00:4F:F0:80:0A:20:F0:08:00:A4:F8:58:00:A6:F8:1E:A8:B4:F8:A4:01:40:F4:00:60:A4:F8:A4:01:1A:E0:C0:46:9C:93:08:20:70:E3:0C:20:C9:2A:08:00:48:E1:0C:20:00:E0:0C:20:14:B5:01:20:D1:2B:08:00:8B:75:06:00:04:B5:01:20:ED:2B:08:00:CD:DC:08:20:01:20:C8:47:6D:1E:AD:B2:38:88:6F:F3:DF:20:C8:28:04:D9:00:2D:F4:D1:AD:49:FD:20:88:47:B4:F8:F8:02:40:F0:80:00:A4:F8:F8:02:B4:F8:08:03:40:F0:80:00:A4:F8:08:03:B4:F8:A4:01:20:F4:00:60:A4:F8:A4:01:B4:F8:9E:03:40:F0:08:00:A4:F8:9E:03:01:20:C8:47:B4:F8:9E:03:20:F0:02:00:A4:F8:9E:03:B4:F8:9E:03:40:F0:04:00:A4:F8:9E:03:01:20:C8:47:B4:F8:9E:03:20:F0:04:00:A4:F8:9E:03:20:88:6F:F3:0A:00:40:F0:05:00:20:80:B6:F8:78:03:C0:B2:40:F4:7F:40:A6:F8"
    16:48:18.384 --
    16:48:18.384 Outgoing Dump:
    16:48:18.384 0000: 01 05 ff f5 b0 22 1a 00 f0 00 0b 05 d2 b4 f8 7a .....".........z
    16:48:18.384 0010: 02 20 f0 08 00 a4 f8 7a 02 b4 f8 58 00 4f f0 80 . .....z...X.O..
    16:48:18.384 0020: 0a 20 f0 08 00 a4 f8 58 00 a6 f8 1e a8 b4 f8 a4 . .....X........
    16:48:18.384 0030: 01 40 f4 00 60 a4 f8 a4 01 1a e0 c0 46 9c 93 08 .@..`.......F...
    16:48:18.384 0040: 20 70 e3 0c 20 c9 2a 08 00 48 e1 0c 20 00 e0 0c p.. .*..H.. ...
    16:48:18.384 0050: 20 14 b5 01 20 d1 2b 08 00 8b 75 06 00 04 b5 01 ... .+...u.....
    16:48:18.384 0060: 20 ed 2b 08 00 cd dc 08 20 01 20 c8 47 6d 1e ad .+..... . .Gm..
    16:48:18.384 0070: b2 38 88 6f f3 df 20 c8 28 04 d9 00 2d f4 d1 ad .8.o.. .(...-...
    16:48:18.384 0080: 49 fd 20 88 47 b4 f8 f8 02 40 f0 80 00 a4 f8 f8 I. .G....@......
    16:48:18.384 0090: 02 b4 f8 08 03 40 f0 80 00 a4 f8 08 03 b4 f8 a4 .....@..........
    16:48:18.384 00a0: 01 20 f4 00 60 a4 f8 a4 01 b4 f8 9e 03 40 f0 08 . ..`........@..
    16:48:18.384 00b0: 00 a4 f8 9e 03 01 20 c8 47 b4 f8 9e 03 20 f0 02 ...... .G.... ..
    16:48:18.384 00c0: 00 a4 f8 9e 03 b4 f8 9e 03 40 f0 04 00 a4 f8 9e .........@......
    16:48:18.384 00d0: 03 01 20 c8 47 b4 f8 9e 03 20 f0 04 00 a4 f8 9e .. .G.... ......
    16:48:18.384 00e0: 03 20 88 6f f3 0a 00 40 f0 05 00 20 80 b6 f8 78 . .o...@... ...x
    16:48:18.384 00f0: 03 c0 b2 40 f4 7f 40 a6 f8 ...@..@..
    16:48:18.415 Incoming Dump:
    16:48:18.415 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.415 --
    16:48:18.415 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.415 Parameters:
    16:48:18.415 | Number HCI commands : 0x01
    16:48:18.415 | Command Opcode : 0xff05
    16:48:18.415 | Status : 0x00 (Success)
    16:48:18.415 --
    16:48:18.415 --
    16:48:18.415 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.415 | Address : 0x001a23a0
    16:48:18.415 | Size : 0xf0
    16:48:18.415 | Values : "78:03:B6:F8:78:03:40:F0:80:00:A6:F8:78:03:9C:48:9A:49:00:88:48:86:88:7C:40:1C:88:74:91:F8:E6:00:40:1C:81:F8:E6:00:4F:F4:00:70:A6:F8:8C:08:95:48:01:78:FF:29:08:D0:01:20:93:4A:88:40:11:68:01:43:11:60:11:68:81:43:11:60:90:48:FF:27:80:F8:31:70:80:F8:33:70:8E:48:07:70:8E:48:07:70:8E:48:8F:49:80:F8:BF:7A:80:F8:12:71:05:20:08:70:AC:48:00:25:05:70:01:20:C0:47:10:B1:AA:49:01:20:88:47:01:20:C0:47:DF:F8:A8:82:00:28:3B:D1:A7:49:01:20:88:47:00:28:34:D0:B4:F8:9A:15:5F:FA:91:F1:10:29:04:DA:06:29:B4:BF:1A:31:0A:31:C9:B2:B4:F8:B2:22:1C:29:42:F4:80:72:A4:F8:B2:22:03:DC:18:29:14:DA:14:29:12:DD:1D:29:0E:DA:16:29:0A:DD:B4:F8:B2:12:01:F4:7F:41:41:F0:10:01:0E:E0:6C:6E:08:20:D3:ED:9B:FD:09:31:02:E0:1D:39:00:E0:0D:39:B4:F8:B2:22:C9:B2"
    16:48:18.415 --
    16:48:18.415 Outgoing Dump:
    16:48:18.415 0000: 01 05 ff f5 a0 23 1a 00 f0 78 03 b6 f8 78 03 40 .....#...x...x.@
    16:48:18.415 0010: f0 80 00 a6 f8 78 03 9c 48 9a 49 00 88 48 86 88 .....x..H.I..H..
    16:48:18.415 0020: 7c 40 1c 88 74 91 f8 e6 00 40 1c 81 f8 e6 00 4f |@..t....@.....O
    16:48:18.415 0030: f4 00 70 a6 f8 8c 08 95 48 01 78 ff 29 08 d0 01 ..p.....H.x.)...
    16:48:18.415 0040: 20 93 4a 88 40 11 68 01 43 11 60 11 68 81 43 11 .J.@.h.C.`.h.C.
    16:48:18.415 0050: 60 90 48 ff 27 80 f8 31 70 80 f8 33 70 8e 48 07 `.H.'..1p..3p.H.
    16:48:18.415 0060: 70 8e 48 07 70 8e 48 8f 49 80 f8 bf 7a 80 f8 12 p.H.p.H.I...z...
    16:48:18.415 0070: 71 05 20 08 70 ac 48 00 25 05 70 01 20 c0 47 10 q. .p.H.%.p. .G.
    16:48:18.415 0080: b1 aa 49 01 20 88 47 01 20 c0 47 df f8 a8 82 00 ..I. .G. .G.....
    16:48:18.415 0090: 28 3b d1 a7 49 01 20 88 47 00 28 34 d0 b4 f8 9a (;..I. .G.(4....
    16:48:18.415 00a0: 15 5f fa 91 f1 10 29 04 da 06 29 b4 bf 1a 31 0a ._....)...)...1.
    16:48:18.415 00b0: 31 c9 b2 b4 f8 b2 22 1c 29 42 f4 80 72 a4 f8 b2 1.....".)B..r...
    16:48:18.415 00c0: 22 03 dc 18 29 14 da 14 29 12 dd 1d 29 0e da 16 "...)...)...)...
    16:48:18.415 00d0: 29 0a dd b4 f8 b2 12 01 f4 7f 41 41 f0 10 01 0e ).........AA....
    16:48:18.415 00e0: e0 6c 6e 08 20 d3 ed 9b fd 09 31 02 e0 1d 39 00 .ln. .....1...9.
    16:48:18.415 00f0: e0 0d 39 b4 f8 b2 22 c9 b2 ..9..."..
    16:48:18.446 Incoming Dump:
    16:48:18.446 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.446 --
    16:48:18.446 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.446 Parameters:
    16:48:18.446 | Number HCI commands : 0x01
    16:48:18.446 | Command Opcode : 0xff05
    16:48:18.446 | Status : 0x00 (Success)
    16:48:18.446 --
    16:48:18.446 --
    16:48:18.446 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.446 | Address : 0x001a2490
    16:48:18.446 | Size : 0xf0
    16:48:18.446 | Values : "02:F4:7F:42:11:43:A4:F8:B2:12:35:80:01:E0:5C:20:C0:47:96:49:96:4A:DF:F8:60:C2:96:4B:09:68:8A:42:12:DB:8A:42:1E:D0:B3:4A:89:1A:33:D0:B2:4A:89:1A:29:D0:5B:08:C9:1A:23:D0:62:46:52:08:89:1A:19:D0:0D:E0:C0:46:93:E4:06:00:AC:4A:89:1A:1B:D0:C9:1A:16:D0:62:46:89:1A:0D:D0:A9:4A:89:1A:02:D0:79:20:C0:47:1F:E0:68:20:02:22:4F:F4:A0:6C:4F:F6:70:65:0B:21:16:E0:50:46:02:22:AC:46:40:23:0A:21:11:E0:08:21:75:20:08:E0:4E:F6:25:3C:4F:F6:FC:75:08:21:78:20:05:E0:06:21:5B:20:4F:F6:C4:2C:4F:F6:33:75:01:22:3F:23:B4:F8:FA:E2:60:F3:08:0E:A4:F8:FA:E2:B4:F8:FC:02:61:F3:06:00:A4:F8:FC:02:A4:F8:FE:52:A4:F8:00:33:A4:F8:02:C3:35:20:A4:F8:04:23:A4:F8:06:03:B4:F8:0C:53:45:F0:05:00:A4:F8:0C:03:4F:F4:C8:70:C8:47:A4:F8:0C:53:B0:48:B1:4D:00:78:AE:4C"
    16:48:18.446 --
    16:48:18.446 Outgoing Dump:
    16:48:18.446 0000: 01 05 ff f5 90 24 1a 00 f0 02 f4 7f 42 11 43 a4 .....$......B.C.
    16:48:18.446 0010: f8 b2 12 35 80 01 e0 5c 20 c0 47 96 49 96 4a df ...5...\ .G.I.J.
    16:48:18.446 0020: f8 60 c2 96 4b 09 68 8a 42 12 db 8a 42 1e d0 b3 .`..K.h.B...B...
    16:48:18.446 0030: 4a 89 1a 33 d0 b2 4a 89 1a 29 d0 5b 08 c9 1a 23 J..3..J..).[...#
    16:48:18.446 0040: d0 62 46 52 08 89 1a 19 d0 0d e0 c0 46 93 e4 06 .bFR........F...
    16:48:18.446 0050: 00 ac 4a 89 1a 1b d0 c9 1a 16 d0 62 46 89 1a 0d ..J........bF...
    16:48:18.446 0060: d0 a9 4a 89 1a 02 d0 79 20 c0 47 1f e0 68 20 02 ..J....y .G..h .
    16:48:18.446 0070: 22 4f f4 a0 6c 4f f6 70 65 0b 21 16 e0 50 46 02 "O..lO.pe.!..PF.
    16:48:18.446 0080: 22 ac 46 40 23 0a 21 11 e0 08 21 75 20 08 e0 4e ".F@#.!...!u ..N
    16:48:18.446 0090: f6 25 3c 4f f6 fc 75 08 21 78 20 05 e0 06 21 5b .%<O..u.!x ...![
    16:48:18.446 00a0: 20 4f f6 c4 2c 4f f6 33 75 01 22 3f 23 b4 f8 fa O..,O.3u."?#...
    16:48:18.446 00b0: e2 60 f3 08 0e a4 f8 fa e2 b4 f8 fc 02 61 f3 06 .`...........a..
    16:48:18.446 00c0: 00 a4 f8 fc 02 a4 f8 fe 52 a4 f8 00 33 a4 f8 02 ........R...3...
    16:48:18.446 00d0: c3 35 20 a4 f8 04 23 a4 f8 06 03 b4 f8 0c 53 45 .5 ...#.......SE
    16:48:18.446 00e0: f0 05 00 a4 f8 0c 03 4f f4 c8 70 c8 47 a4 f8 0c .......O..p.G...
    16:48:18.446 00f0: 53 b0 48 b1 4d 00 78 ae 4c S.H.M.x.L
    16:48:18.478 Incoming Dump:
    16:48:18.478 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.478 --
    16:48:18.478 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.478 Parameters:
    16:48:18.478 | Number HCI commands : 0x01
    16:48:18.478 | Command Opcode : 0xff05
    16:48:18.478 | Status : 0x00 (Success)
    16:48:18.478 --
    16:48:18.478 --
    16:48:18.478 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.478 | Address : 0x001a2580
    16:48:18.478 | Size : 0xf0
    16:48:18.478 | Values : "05:28:27:70:0E:D0:06:28:25:D1:4F:F4:86:70:A6:F8:1E:01:14:20:C8:47:04:20:A8:47:4F:F4:00:51:A6:F8:1E:11:17:E0:B6:F8:B0:01:20:F0:01:00:A6:F8:B0:01:4F:F4:8B:70:A6:F8:72:01:14:20:C8:47:09:20:A8:47:4F:F4:84:41:A6:F8:72:11:B6:F8:B0:11:41:F0:01:01:A6:F8:B0:11:20:70:BD:E8:F0:8F:C0:46:D1:C7:07:00:70:B5:AA:4D:58:B1:2B:46:1B:18:5E:78:02:FB:01:F4:01:28:26:44:5E:70:02:D9:1E:78:A4:19:1C:70:4E:28:0B:D2:2B:46:4A:43:DB:1C:1B:18:19:78:4D:28:11:44:19:70:02:D2:58:78:12:18:5A:70:70:BD:C0:F0:0C:20:92:A3:08:20:90:77:08:20:04:F0:0E:20:70:7E:08:20:5D:76:08:20:E2:9A:08:20:00:00:08:20:E5:69:08:20:30:B5:05:46:2A:68:29:8C:2C:8A:02:F0:0F:00:52:09:34:BF:20:1A:20:44:AB:4A:84:B2:10:88:20:F4:00:50:10:80:10:88:6F:F3:DF:30:10:80:B2:F8:46:00:20:F4"
    16:48:18.478 --
    16:48:18.478 Outgoing Dump:
    16:48:18.478 0000: 01 05 ff f5 80 25 1a 00 f0 05 28 27 70 0e d0 06 .....%....('p...
    16:48:18.478 0010: 28 25 d1 4f f4 86 70 a6 f8 1e 01 14 20 c8 47 04 (%.O..p..... .G.
    16:48:18.478 0020: 20 a8 47 4f f4 00 51 a6 f8 1e 11 17 e0 b6 f8 b0 .GO..Q.........
    16:48:18.478 0030: 01 20 f0 01 00 a6 f8 b0 01 4f f4 8b 70 a6 f8 72 . .......O..p..r
    16:48:18.478 0040: 01 14 20 c8 47 09 20 a8 47 4f f4 84 41 a6 f8 72 .. .G. .GO..A..r
    16:48:18.478 0050: 11 b6 f8 b0 11 41 f0 01 01 a6 f8 b0 11 20 70 bd .....A....... p.
    16:48:18.478 0060: e8 f0 8f c0 46 d1 c7 07 00 70 b5 aa 4d 58 b1 2b ....F....p..MX.+
    16:48:18.478 0070: 46 1b 18 5e 78 02 fb 01 f4 01 28 26 44 5e 70 02 F..^x.....(&D^p.
    16:48:18.478 0080: d9 1e 78 a4 19 1c 70 4e 28 0b d2 2b 46 4a 43 db ..x...pN(..+FJC.
    16:48:18.478 0090: 1c 1b 18 19 78 4d 28 11 44 19 70 02 d2 58 78 12 ....xM(.D.p..Xx.
    16:48:18.478 00a0: 18 5a 70 70 bd c0 f0 0c 20 92 a3 08 20 90 77 08 .Zpp.... ... .w.
    16:48:18.478 00b0: 20 04 f0 0e 20 70 7e 08 20 5d 76 08 20 e2 9a 08 ... p~. ]v. ...
    16:48:18.478 00c0: 20 00 00 08 20 e5 69 08 20 30 b5 05 46 2a 68 29 ... .i. 0..F*h)
    16:48:18.478 00d0: 8c 2c 8a 02 f0 0f 00 52 09 34 bf 20 1a 20 44 ab .,.....R.4. . D.
    16:48:18.478 00e0: 4a 84 b2 10 88 20 f4 00 50 10 80 10 88 6f f3 df J.... ..P....o..
    16:48:18.478 00f0: 30 10 80 b2 f8 46 00 20 f4 0....F. .
    16:48:18.509 Incoming Dump:
    16:48:18.509 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.509 --
    16:48:18.509 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.509 Parameters:
    16:48:18.509 | Number HCI commands : 0x01
    16:48:18.509 | Command Opcode : 0xff05
    16:48:18.509 | Status : 0x00 (Success)
    16:48:18.509 --
    16:48:18.509 --
    16:48:18.509 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.509 | Address : 0x001a2670
    16:48:18.509 | Size : 0xf0
    16:48:18.509 | Values : "00:60:A2:F8:46:00:B2:F8:40:00:20:F0:01:00:A2:F8:40:00:B2:F8:4A:00:61:F3:03:00:AB:49:A2:F8:4A:00:92:F8:D6:02:20:F0:01:00:82:F8:D6:02:7D:20:88:47:A3:49:00:20:08:80:80:20:4F:F4:30:71:01:FB:04:00:1F:FA:90:F0:28:60:9F:48:00:F5:B9:70:30:BD:C0:46:D7:DC:08:20:0B:88:06:00:41:EF:08:00:F3:C7:07:00:30:B5:9A:4C:05:46:20:88:80:09:38:BF:00:20:03:D3:97:49:86:20:88:47:01:20:B4:F8:F2:10:29:68:08:43:28:60:A7:48:2C:61:1C:30:30:BD:C0:46:08:78:08:20:80:BA:8C:01:00:2F:0D:00:00:3E:49:00:2D:E9:F0:41:0E:46:A1:49:04:46:98:46:17:46:0A:20:88:47:05:46:75:B3:29:21:69:80:05:F1:08:00:04:21:99:4A:29:80:FF:21:00:F8:01:1B:27:21:00:F8:01:1B:4F:F4:10:61:90:47:00:F8:01:4B:A1:4C:D6:F8:78:15:A0:47:D6:F8:70:15:A0:47:D6:F8:80:15:A0:47:D6:F8:88:15:A0:47"
    16:48:18.509 --
    16:48:18.509 Outgoing Dump:
    16:48:18.509 0000: 01 05 ff f5 70 26 1a 00 f0 00 60 a2 f8 46 00 b2 ....p&....`..F..
    16:48:18.509 0010: f8 40 00 20 f0 01 00 a2 f8 40 00 b2 f8 4a 00 61 .@. .....@...J.a
    16:48:18.509 0020: f3 03 00 ab 49 a2 f8 4a 00 92 f8 d6 02 20 f0 01 ....I..J..... ..
    16:48:18.509 0030: 00 82 f8 d6 02 7d 20 88 47 a3 49 00 20 08 80 80 .....} .G.I. ...
    16:48:18.509 0040: 20 4f f4 30 71 01 fb 04 00 1f fa 90 f0 28 60 9f O.0q........(`.
    16:48:18.509 0050: 48 00 f5 b9 70 30 bd c0 46 d7 dc 08 20 0b 88 06 H...p0..F... ...
    16:48:18.509 0060: 00 41 ef 08 00 f3 c7 07 00 30 b5 9a 4c 05 46 20 .A.......0..L.F
    16:48:18.509 0070: 88 80 09 38 bf 00 20 03 d3 97 49 86 20 88 47 01 ...8.. ...I. .G.
    16:48:18.509 0080: 20 b4 f8 f2 10 29 68 08 43 28 60 a7 48 2c 61 1c ....)h.C(`.H,a.
    16:48:18.509 0090: 30 30 bd c0 46 08 78 08 20 80 ba 8c 01 00 2f 0d 00..F.x. ...../.
    16:48:18.509 00a0: 00 00 3e 49 00 2d e9 f0 41 0e 46 a1 49 04 46 98 ..>I.-..A.F.I.F.
    16:48:18.509 00b0: 46 17 46 0a 20 88 47 05 46 75 b3 29 21 69 80 05 F.F. .G.Fu.)!i..
    16:48:18.509 00c0: f1 08 00 04 21 99 4a 29 80 ff 21 00 f8 01 1b 27 ....!.J)..!....'
    16:48:18.509 00d0: 21 00 f8 01 1b 4f f4 10 61 90 47 00 f8 01 4b a1 !....O..a.G...K.
    16:48:18.509 00e0: 4c d6 f8 78 15 a0 47 d6 f8 70 15 a0 47 d6 f8 80 L..x..G..p..G...
    16:48:18.509 00f0: 15 a0 47 d6 f8 88 15 a0 47 ..G.....G
    16:48:18.540 Incoming Dump:
    16:48:18.540 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.540 --
    16:48:18.540 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.540 Parameters:
    16:48:18.540 | Number HCI commands : 0x01
    16:48:18.540 | Command Opcode : 0xff05
    16:48:18.540 | Status : 0x00 (Success)
    16:48:18.540 --
    16:48:18.540 --
    16:48:18.540 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.540 | Address : 0x001a2760
    16:48:18.540 | Size : 0xf0
    16:48:18.540 | Values : "D6:F8:8C:15:A0:47:D6:F8:90:15:A0:47:D6:F8:94:15:A0:47:39:46:A0:47:41:46:A0:47:95:49:28:46:88:47:BD:E8:F0:81:40:31:F7:00:40:90:02:00:00:83:F3:01:00:85:CF:00:2D:E9:F0:43:81:46:8E:48:8E:49:05:68:00:20:88:47:8D:4C:8F:4F:DF:F8:34:82:DF:F8:74:C2:23:68:B9:F1:01:0F:06:46:10:D0:B9:F1:02:0F:1B:D1:D5:F8:90:25:D5:F8:94:35:4F:F4:1F:71:02:20:E0:47:40:46:00:88:C0:08:0F:D3:02:20:09:E0:32:46:4F:F4:D9:71:02:20:E0:47:40:46:00:88:80:08:04:D3:01:20:23:68:32:46:29:46:B8:47:26:60:BD:E8:F0:83:10:B5:81:68:0C:78:00:F1:08:02:4B:1C:0C:2C:0E:D1:74:4C:38:3C:24:78:40:2C:06:D0:41:2C:1C:BF:08:23:4B:70:03:D1:07:21:00:E0:06:21:19:70:11:68:41:61:41:68:81:61:7D:48:08:30:10:BD:DB:DC:08:20:7F:7C:08:20:19:DE:08:00:01:78:7A:4A:60:29:08:DB:77:4B:19:88"
    16:48:18.540 --
    16:48:18.540 Outgoing Dump:
    16:48:18.540 0000: 01 05 ff f5 60 27 1a 00 f0 d6 f8 8c 15 a0 47 d6 ....`'........G.
    16:48:18.540 0010: f8 90 15 a0 47 d6 f8 94 15 a0 47 39 46 a0 47 41 ....G.....G9F.GA
    16:48:18.540 0020: 46 a0 47 95 49 28 46 88 47 bd e8 f0 81 40 31 f7 F.G.I(F.G....@1.
    16:48:18.540 0030: 00 40 90 02 00 00 83 f3 01 00 85 cf 00 2d e9 f0 .@...........-..
    16:48:18.540 0040: 43 81 46 8e 48 8e 49 05 68 00 20 88 47 8d 4c 8f C.F.H.I.h. .G.L.
    16:48:18.540 0050: 4f df f8 34 82 df f8 74 c2 23 68 b9 f1 01 0f 06 O..4...t.#h.....
    16:48:18.540 0060: 46 10 d0 b9 f1 02 0f 1b d1 d5 f8 90 25 d5 f8 94 F...........%...
    16:48:18.540 0070: 35 4f f4 1f 71 02 20 e0 47 40 46 00 88 c0 08 0f 5O..q. .G@F.....
    16:48:18.540 0080: d3 02 20 09 e0 32 46 4f f4 d9 71 02 20 e0 47 40 .. ..2FO..q. .G@
    16:48:18.540 0090: 46 00 88 80 08 04 d3 01 20 23 68 32 46 29 46 b8 F....... #h2F)F.
    16:48:18.540 00a0: 47 26 60 bd e8 f0 83 10 b5 81 68 0c 78 00 f1 08 G&`.......h.x...
    16:48:18.540 00b0: 02 4b 1c 0c 2c 0e d1 74 4c 38 3c 24 78 40 2c 06 .K..,..tL8<$x@,.
    16:48:18.540 00c0: d0 41 2c 1c bf 08 23 4b 70 03 d1 07 21 00 e0 06 .A,...#Kp...!...
    16:48:18.540 00d0: 21 19 70 11 68 41 61 41 68 81 61 7d 48 08 30 10 !.p.hAaAh.a}H.0.
    16:48:18.540 00e0: bd db dc 08 20 7f 7c 08 20 19 de 08 00 01 78 7a .... .|. .....xz
    16:48:18.540 00f0: 4a 60 29 08 db 77 4b 19 88 J`)..wK..
    16:48:18.571 Incoming Dump:
    16:48:18.571 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.571 --
    16:48:18.571 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.571 Parameters:
    16:48:18.571 | Number HCI commands : 0x01
    16:48:18.571 | Command Opcode : 0xff05
    16:48:18.571 | Status : 0x00 (Success)
    16:48:18.571 --
    16:48:18.571 --
    16:48:18.571 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.571 | Address : 0x001a2850
    16:48:18.571 | Size : 0xf0
    16:48:18.571 | Values : "09:B9:59:88:19:B1:10:46:00:F2:14:40:70:47:41:69:8B:88:74:49:C9:18:01:61:10:46:F6:30:70:47:5C:49:3A:39:09:78:81:60:A4:49:E7:39:91:F8:E7:20:91:F8:AB:10:89:18:01:60:9F:48:82:30:70:47:0D:A5:08:20:F0:B5:06:46:00:24:77:69:34:60:0C:E0:60:01:9B:4D:9B:4A:00:EB:44:20:39:46:2D:18:05:F1:10:00:90:47:00:B9:35:60:64:1C:A4:48:00:78:A0:42:EE:DC:A3:48:42:30:F0:BD:F0:B5:01:46:4A:00:4F:F0:00:0E:02:EB:01:12:9F:49:76:46:FF:24:02:25:8C:46:53:18:83:F8:00:E0:91:19:5C:70:07:27:61:44:89:1C:7F:1E:01:F8:01:4B:FB:D1:6D:1E:03:F1:09:03:06:F1:09:06:EE:D1:F0:BD:C0:46:40:21:0C:20:00:B5:00:69:9E:49:00:78:88:47:9E:48:00:F5:CA:70:00:BD:81:69:8A:48:40:1C:00:78:88:80:04:20:88:71:A7:48:00:F2:6A:20:70:47:06:E0:0C:20:2D:FC:05:00:8B:75:06:00:52:21:0C:20"
    16:48:18.571 --
    16:48:18.571 Outgoing Dump:
    16:48:18.571 0000: 01 05 ff f5 50 28 1a 00 f0 09 b9 59 88 19 b1 10 ....P(.....Y....
    16:48:18.571 0010: 46 00 f2 14 40 70 47 41 69 8b 88 74 49 c9 18 01 F...@pGAi..tI...
    16:48:18.571 0020: 61 10 46 f6 30 70 47 5c 49 3a 39 09 78 81 60 a4 a.F.0pG\I:9.x.`.
    16:48:18.571 0030: 49 e7 39 91 f8 e7 20 91 f8 ab 10 89 18 01 60 9f I.9... .......`.
    16:48:18.571 0040: 48 82 30 70 47 0d a5 08 20 f0 b5 06 46 00 24 77 H.0pG... ...F.$w
    16:48:18.571 0050: 69 34 60 0c e0 60 01 9b 4d 9b 4a 00 eb 44 20 39 i4`..`..M.J..D 9
    16:48:18.571 0060: 46 2d 18 05 f1 10 00 90 47 00 b9 35 60 64 1c a4 F-......G..5`d..
    16:48:18.571 0070: 48 00 78 a0 42 ee dc a3 48 42 30 f0 bd f0 b5 01 H.x.B...HB0.....
    16:48:18.571 0080: 46 4a 00 4f f0 00 0e 02 eb 01 12 9f 49 76 46 ff FJ.O........IvF.
    16:48:18.571 0090: 24 02 25 8c 46 53 18 83 f8 00 e0 91 19 5c 70 07 $.%.FS.......\p.
    16:48:18.571 00a0: 27 61 44 89 1c 7f 1e 01 f8 01 4b fb d1 6d 1e 03 'aD.......K..m..
    16:48:18.571 00b0: f1 09 03 06 f1 09 06 ee d1 f0 bd c0 46 40 21 0c ............F@!.
    16:48:18.571 00c0: 20 00 b5 00 69 9e 49 00 78 88 47 9e 48 00 f5 ca ...i.I.x.G.H...
    16:48:18.571 00d0: 70 00 bd 81 69 8a 48 40 1c 00 78 88 80 04 20 88 p...i.H@..x... .
    16:48:18.571 00e0: 71 a7 48 00 f2 6a 20 70 47 06 e0 0c 20 2d fc 05 q.H..j pG... -..
    16:48:18.571 00f0: 00 8b 75 06 00 52 21 0c 20 ..u..R!.
    16:48:18.603 Incoming Dump:
    16:48:18.603 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.603 --
    16:48:18.603 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.603 Parameters:
    16:48:18.603 | Number HCI commands : 0x01
    16:48:18.603 | Command Opcode : 0xff05
    16:48:18.603 | Status : 0x00 (Success)
    16:48:18.603 --
    16:48:18.603 --
    16:48:18.603 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.603 | Address : 0x001a2940
    16:48:18.603 | Size : 0xf0
    16:48:18.603 | Values : "F3:C7:07:00:70:B5:08:46:A0:4A:04:21:58:30:90:47:00:24:9F:4D:9F:48:01:46:50:31:0B:78:15:F8:01:1F:00:29:04:BF:00:22:11:1C:04:D0:49:1C:CA:B2:01:5D:01:F0:07:01:98:4E:8B:42:02:D0:8B:42:02:DA:01:21:20:46:B0:47:64:1C:4F:2C:E4:D3:A3:48:12:30:70:BD:0D:D1:01:00:FB:D3:00:00:07:0E:03:00:10:B5:02:46:51:68:9F:4B:9D:48:0C:7A:08:2C:09:D0:06:2C:04:D0:04:2C:02:D0:92:68:03:2A:03:D0:A6:4A:90:47:01:E0:0C:30:98:47:A8:48:1E:30:10:BD:C0:46:7B:D3:00:00:A7:63:06:00:CC:81:08:20:27:C2:07:00:84:DC:08:20:1C:6A:08:20:0D:27:1A:00:F0:B5:A4:49:00:78:88:47:00:25:A3:4F:A3:4C:00:21:38:46:80:1C:A0:47:06:46:00:21:38:46:A0:47:AA:1C:01:21:B0:43:91:40:01:42:02:D0:9D:49:E8:B2:88:47:6D:1C:02:2D:E9:DB:9B:48:3A:30:F0:BD:A1:C8:07:00:29:C6:04:00:02:00:08:20"
    16:48:18.603 --
    16:48:18.603 Outgoing Dump:
    16:48:18.603 0000: 01 05 ff f5 40 29 1a 00 f0 f3 c7 07 00 70 b5 08 ....@).......p..
    16:48:18.603 0010: 46 a0 4a 04 21 58 30 90 47 00 24 9f 4d 9f 48 01 F.J.!X0.G.$.M.H.
    16:48:18.603 0020: 46 50 31 0b 78 15 f8 01 1f 00 29 04 bf 00 22 11 FP1.x.....)...".
    16:48:18.603 0030: 1c 04 d0 49 1c ca b2 01 5d 01 f0 07 01 98 4e 8b ...I....].....N.
    16:48:18.603 0040: 42 02 d0 8b 42 02 da 01 21 20 46 b0 47 64 1c 4f B...B...! F.Gd.O
    16:48:18.603 0050: 2c e4 d3 a3 48 12 30 70 bd 0d d1 01 00 fb d3 00 ,...H.0p........
    16:48:18.603 0060: 00 07 0e 03 00 10 b5 02 46 51 68 9f 4b 9d 48 0c ........FQh.K.H.
    16:48:18.603 0070: 7a 08 2c 09 d0 06 2c 04 d0 04 2c 02 d0 92 68 03 z.,...,...,...h.
    16:48:18.603 0080: 2a 03 d0 a6 4a 90 47 01 e0 0c 30 98 47 a8 48 1e *...J.G...0.G.H.
    16:48:18.603 0090: 30 10 bd c0 46 7b d3 00 00 a7 63 06 00 cc 81 08 0...F{....c.....
    16:48:18.603 00a0: 20 27 c2 07 00 84 dc 08 20 1c 6a 08 20 0d 27 1a '...... .j. .'.
    16:48:18.603 00b0: 00 f0 b5 a4 49 00 78 88 47 00 25 a3 4f a3 4c 00 ....I.x.G.%.O.L.
    16:48:18.603 00c0: 21 38 46 80 1c a0 47 06 46 00 21 38 46 a0 47 aa !8F...G.F.!8F.G.
    16:48:18.603 00d0: 1c 01 21 b0 43 91 40 01 42 02 d0 9d 49 e8 b2 88 ..!.C.@.B...I...
    16:48:18.603 00e0: 47 6d 1c 02 2d e9 db 9b 48 3a 30 f0 bd a1 c8 07 Gm..-...H:0.....
    16:48:18.603 00f0: 00 29 c6 04 00 02 00 08 20 .)......
    16:48:18.634 Incoming Dump:
    16:48:18.634 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.634 --
    16:48:18.634 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.634 Parameters:
    16:48:18.634 | Number HCI commands : 0x01
    16:48:18.634 | Command Opcode : 0xff05
    16:48:18.634 | Status : 0x00 (Success)
    16:48:18.634 --
    16:48:18.634 --
    16:48:18.634 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.634 | Address : 0x001a2a30
    16:48:18.634 | Size : 0xf0
    16:48:18.634 | Values : "71:CA:04:00:00:00:08:20:2D:E9:FE:41:94:4C:05:46:94:4E:E0:7E:05:28:03:D0:06:28:18:BF:07:28:04:D1:30:46:00:F5:92:70:BD:E8:FE:81:94:F8:28:10:94:F8:27:00:40:EA:01:20:A0:82:94:F8:25:10:94:F8:26:00:01:F0:03:01:00:02:40:EA:81:10:94:F8:24:10:40:EA:A1:00:E0:82:94:F8:24:10:94:F8:23:00:40:EA:01:20:94:F8:22:10:80:01:40:EA:A1:00:80:B2:20:83:A1:8A:8D:F8:09:00:0A:12:8D:F8:05:10:8D:F8:04:20:E1:8A:DF:F8:78:82:8D:F8:07:10:0A:12:01:12:8D:F8:08:10:A1:49:8D:F8:06:20:40:46:88:47:07:46:10:4A:01:A8:41:46:90:47:88:B9:87:B1:B8:78:01:28:0D:D0:20:68:A1:8A:E2:8A:23:8B:9A:4C:00:90:3F:20:A0:47:97:48:68:61:30:46:6E:30:BD:E8:FE:81:30:46:68:30:BD:E8:FE:81:C0:46:75:2B:01:00:DB:A2:08:20:B0:84:08:20:27:79:06:00:10:B5:04:7F:02:7C:01:7E:03:7D:01:2C"
    16:48:18.634 --
    16:48:18.634 Outgoing Dump:
    16:48:18.634 0000: 01 05 ff f5 30 2a 1a 00 f0 71 ca 04 00 00 00 08 ....0*...q......
    16:48:18.634 0010: 20 2d e9 fe 41 94 4c 05 46 94 4e e0 7e 05 28 03 -..A.L.F.N.~.(.
    16:48:18.634 0020: d0 06 28 18 bf 07 28 04 d1 30 46 00 f5 92 70 bd ..(...(..0F...p.
    16:48:18.634 0030: e8 fe 81 94 f8 28 10 94 f8 27 00 40 ea 01 20 a0 .....(...'.@.. .
    16:48:18.634 0040: 82 94 f8 25 10 94 f8 26 00 01 f0 03 01 00 02 40 ...%...&.......@
    16:48:18.634 0050: ea 81 10 94 f8 24 10 40 ea a1 00 e0 82 94 f8 24 .....$.@.......$
    16:48:18.634 0060: 10 94 f8 23 00 40 ea 01 20 94 f8 22 10 80 01 40 ...#.@.. .."...@
    16:48:18.634 0070: ea a1 00 80 b2 20 83 a1 8a 8d f8 09 00 0a 12 8d ..... ..........
    16:48:18.634 0080: f8 05 10 8d f8 04 20 e1 8a df f8 78 82 8d f8 07 ...... ....x....
    16:48:18.634 0090: 10 0a 12 01 12 8d f8 08 10 a1 49 8d f8 06 20 40 ..........I... @
    16:48:18.634 00a0: 46 88 47 07 46 10 4a 01 a8 41 46 90 47 88 b9 87 F.G.F.J..AF.G...
    16:48:18.634 00b0: b1 b8 78 01 28 0d d0 20 68 a1 8a e2 8a 23 8b 9a ..x.(.. h....#..
    16:48:18.634 00c0: 4c 00 90 3f 20 a0 47 97 48 68 61 30 46 6e 30 bd L..? .G.Hha0Fn0.
    16:48:18.634 00d0: e8 fe 81 30 46 68 30 bd e8 fe 81 c0 46 75 2b 01 ...0Fh0.....Fu+.
    16:48:18.634 00e0: 00 db a2 08 20 b0 84 08 20 27 79 06 00 10 b5 04 .... ... 'y.....
    16:48:18.634 00f0: 7f 02 7c 01 7e 03 7d 01 2c ..|.~.}.,
    16:48:18.665 Incoming Dump:
    16:48:18.665 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.665 --
    16:48:18.665 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.665 Parameters:
    16:48:18.665 | Number HCI commands : 0x01
    16:48:18.665 | Command Opcode : 0xff05
    16:48:18.665 | Status : 0x00 (Success)
    16:48:18.665 --
    16:48:18.665 --
    16:48:18.665 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.665 | Address : 0x001a2b20
    16:48:18.665 | Size : 0xf0
    16:48:18.665 | Values : "02:D0:19:43:02:D1:0B:E0:19:43:06:D0:02:2A:07:D1:00:21:C1:61:9D:48:01:70:02:E0:9D:49:10:46:88:47:9C:48:4A:30:10:BD:C0:46:E2:69:08:20:99:EA:05:00:70:DD:08:20:98:49:B1:F8:98:20:03:89:B1:F8:6C:10:89:1A:41:F2:87:32:52:18:40:F2:E2:41:92:FB:F1:F2:9E:49:9A:42:04:DD:01:22:02:60:08:46:46:30:70:47:08:46:3C:30:70:47:C0:46:C5:28:1A:00:95:2D:01:00:00:B5:97:48:00:78:10:F0:1E:0F:0D:D1:96:48:95:49:00:78:80:02:08:63:00:20:48:87:9F:49:03:20:88:47:9E:49:03:20:88:47:04:E0:9D:48:80:47:9D:4A:03:21:90:47:9D:48:AA:30:00:BD:21:3F:01:00:33:79:06:00:57:00:01:20:43:9E:08:20:E1:25:1A:00:10:B5:97:4A:04:46:11:78:A0:69:05:29:00:F1:03:00:0C:D1:02:21:11:70:93:49:09:78:01:70:92:48:00:78:FF:28:03:D1:93:4A:91:48:03:21:90:47:50:48:A0:61:01:20:20:61"
    16:48:18.665 --
    16:48:18.665 Outgoing Dump:
    16:48:18.665 0000: 01 05 ff f5 20 2b 1a 00 f0 02 d0 19 43 02 d1 0b .... +......C...
    16:48:18.665 0010: e0 19 43 06 d0 02 2a 07 d1 00 21 c1 61 9d 48 01 ..C...*...!.a.H.
    16:48:18.665 0020: 70 02 e0 9d 49 10 46 88 47 9c 48 4a 30 10 bd c0 p...I.F.G.HJ0...
    16:48:18.665 0030: 46 e2 69 08 20 99 ea 05 00 70 dd 08 20 98 49 b1 F.i. ....p.. .I.
    16:48:18.665 0040: f8 98 20 03 89 b1 f8 6c 10 89 1a 41 f2 87 32 52 .. ....l...A..2R
    16:48:18.665 0050: 18 40 f2 e2 41 92 fb f1 f2 9e 49 9a 42 04 dd 01 .@..A.....I.B...
    16:48:18.665 0060: 22 02 60 08 46 46 30 70 47 08 46 3c 30 70 47 c0 ".`.FF0pG.F<0pG.
    16:48:18.665 0070: 46 c5 28 1a 00 95 2d 01 00 00 b5 97 48 00 78 10 F.(...-.....H.x.
    16:48:18.665 0080: f0 1e 0f 0d d1 96 48 95 49 00 78 80 02 08 63 00 ......H.I.x...c.
    16:48:18.665 0090: 20 48 87 9f 49 03 20 88 47 9e 49 03 20 88 47 04 H..I. .G.I. .G.
    16:48:18.665 00a0: e0 9d 48 80 47 9d 4a 03 21 90 47 9d 48 aa 30 00 ..H.G.J.!.G.H.0.
    16:48:18.665 00b0: bd 21 3f 01 00 33 79 06 00 57 00 01 20 43 9e 08 .!?..3y..W.. C..
    16:48:18.665 00c0: 20 e1 25 1a 00 10 b5 97 4a 04 46 11 78 a0 69 05 .%.....J.F.x.i.
    16:48:18.665 00d0: 29 00 f1 03 00 0c d1 02 21 11 70 93 49 09 78 01 ).......!.p.I.x.
    16:48:18.665 00e0: 70 92 48 00 78 ff 28 03 d1 93 4a 91 48 03 21 90 p.H.x.(...J.H.!.
    16:48:18.665 00f0: 47 50 48 a0 61 01 20 20 61 GPH.a. a
    16:48:18.696 Incoming Dump:
    16:48:18.696 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.696 --
    16:48:18.696 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.696 Parameters:
    16:48:18.696 | Number HCI commands : 0x01
    16:48:18.696 | Command Opcode : 0xff05
    16:48:18.696 | Status : 0x00 (Success)
    16:48:18.696 --
    16:48:18.696 --
    16:48:18.696 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.696 | Address : 0x001a2c10
    16:48:18.696 | Size : 0xf0
    16:48:18.696 | Values : "8E:48:50:30:10:BD:C0:46:39:00:01:00:B4:95:08:20:DD:09:03:00:10:B5:04:69:21:7F:B4:20:48:43:A4:49:08:5C:70:49:02:01:0C:31:89:5C:A3:4A:90:47:A3:49:00:20:88:47:A2:4A:20:7F:00:21:90:47:A1:48:12:30:10:BD:C0:46:01:09:03:00:00:B5:9F:49:02:20:88:47:9E:48:00:F2:06:20:00:BD:85:68:07:00:00:B5:9A:49:01:20:88:47:99:48:A2:30:00:BD:C0:46:31:30:07:00:20:0E:0E:20:FD:2C:08:00:E5:2F:07:00:3B:31:07:00:6C:94:08:20:2D:96:05:00:2D:E9:F0:47:45:69:89:49:28:78:00:01:0E:5C:8E:4F:28:78:B8:47:40:F2:34:41:81:42:F8:DD:DF:F8:9C:92:02:20:C8:47:DF:F8:24:82:28:78:C0:47:82:46:28:78:B8:47:A4:4C:29:78:49:B1:4F:EA:81:02:02:EB:41:12:9F:49:11:44:0A:88:6F:F3:0E:02:82:B9:A0:28:10:DB:B0:F5:D5:7F:0D:DC:02:20:A0:47:02:20:C8:47:28:78:C0:47:82:46:28:78:B8:47"
    16:48:18.696 --
    16:48:18.712 Outgoing Dump:
    16:48:18.712 0000: 01 05 ff f5 10 2c 1a 00 f0 8e 48 50 30 10 bd c0 .....,....HP0...
    16:48:18.712 0010: 46 39 00 01 00 b4 95 08 20 dd 09 03 00 10 b5 04 F9...... .......
    16:48:18.712 0020: 69 21 7f b4 20 48 43 a4 49 08 5c 70 49 02 01 0c i!.. HC.I.\pI...
    16:48:18.712 0030: 31 89 5c a3 4a 90 47 a3 49 00 20 88 47 a2 4a 20 1.\.J.G.I. .G.J
    16:48:18.712 0040: 7f 00 21 90 47 a1 48 12 30 10 bd c0 46 01 09 03 ..!.G.H.0...F...
    16:48:18.712 0050: 00 00 b5 9f 49 02 20 88 47 9e 48 00 f2 06 20 00 ....I. .G.H... .
    16:48:18.712 0060: bd 85 68 07 00 00 b5 9a 49 01 20 88 47 99 48 a2 ..h.....I. .G.H.
    16:48:18.712 0070: 30 00 bd c0 46 31 30 07 00 20 0e 0e 20 fd 2c 08 0...F10.. .. .,.
    16:48:18.712 0080: 00 e5 2f 07 00 3b 31 07 00 6c 94 08 20 2d 96 05 ../..;1..l.. -..
    16:48:18.712 0090: 00 2d e9 f0 47 45 69 89 49 28 78 00 01 0e 5c 8e .-..GEi.I(x...\.
    16:48:18.712 00a0: 4f 28 78 b8 47 40 f2 34 41 81 42 f8 dd df f8 9c O(x.G@.4A.B.....
    16:48:18.712 00b0: 92 02 20 c8 47 df f8 24 82 28 78 c0 47 82 46 28 .. .G..$.(x.G.F(
    16:48:18.712 00c0: 78 b8 47 a4 4c 29 78 49 b1 4f ea 81 02 02 eb 41 x.G.L)xI.O.....A
    16:48:18.712 00d0: 12 9f 49 11 44 0a 88 6f f3 0e 02 82 b9 a0 28 10 ..I.D..o......(.
    16:48:18.712 00e0: db b0 f5 d5 7f 0d dc 02 20 a0 47 02 20 c8 47 28 ........ .G. .G(
    16:48:18.712 00f0: 78 c0 47 82 46 28 78 b8 47 x.G.F(x.G
    16:48:18.743 Incoming Dump:
    16:48:18.743 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.743 --
    16:48:18.743 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.743 Parameters:
    16:48:18.743 | Number HCI commands : 0x01
    16:48:18.743 | Command Opcode : 0xff05
    16:48:18.743 | Status : 0x00 (Success)
    16:48:18.743 --
    16:48:18.743 --
    16:48:18.743 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.743 | Address : 0x001a2d00
    16:48:18.743 | Size : 0xf0
    16:48:18.743 | Values : "A0:28:F1:DA:01:E0:01:20:C8:72:A4:4A:A8:78:51:46:90:47:A3:4B:02:46:31:46:50:46:98:47:02:20:A0:47:A0:48:00:F5:89:70:BD:E8:F0:87:C0:46:B8:81:08:20:00:69:01:7C:9C:48:FF:29:02:D0:9C:49:09:78:09:B1:60:30:70:47:12:30:70:47:15:39:01:00:82:07:0E:20:E5:C5:07:00:70:B5:04:46:95:4A:20:78:40:F2:C9:41:90:47:95:4D:93:4A:91:49:50:B1:10:46:02:78:08:46:00:21:08:30:81:54:28:46:01:21:00:F5:99:70:12:E0:10:46:02:78:8E:4E:08:46:80:18:01:7A:49:1C:01:72:8A:48:CB:B2:02:68:4F:F4:D8:71:02:20:B0:47:28:46:00:21:00:F5:8F:70:21:60:70:BD:C0:46:66:94:08:20:79:2E:06:00:E9:2E:06:00:20:6E:08:20:10:B5:7D:48:FF:22:36:38:90:F8:36:10:80:F8:36:20:7C:4C:77:48:40:18:01:7A:49:1C:01:72:78:48:CB:B2:02:68:4F:F4:AD:71:02:20:A0:47:A9:48:A4:30:10:BD:AB:5B:08:00"
    16:48:18.743 --
    16:48:18.743 Outgoing Dump:
    16:48:18.743 0000: 01 05 ff f5 00 2d 1a 00 f0 a0 28 f1 da 01 e0 01 .....-....(.....
    16:48:18.743 0010: 20 c8 72 a4 4a a8 78 51 46 90 47 a3 4b 02 46 31 .r.J.xQF.G.K.F1
    16:48:18.743 0020: 46 50 46 98 47 02 20 a0 47 a0 48 00 f5 89 70 bd FPF.G. .G.H...p.
    16:48:18.743 0030: e8 f0 87 c0 46 b8 81 08 20 00 69 01 7c 9c 48 ff ....F... .i.|.H.
    16:48:18.743 0040: 29 02 d0 9c 49 09 78 09 b1 60 30 70 47 12 30 70 )...I.x..`0pG.0p
    16:48:18.743 0050: 47 15 39 01 00 82 07 0e 20 e5 c5 07 00 70 b5 04 G.9..... ....p..
    16:48:18.743 0060: 46 95 4a 20 78 40 f2 c9 41 90 47 95 4d 93 4a 91 F.J x@..A.G.M.J.
    16:48:18.743 0070: 49 50 b1 10 46 02 78 08 46 00 21 08 30 81 54 28 IP..F.x.F.!.0.T(
    16:48:18.743 0080: 46 01 21 00 f5 99 70 12 e0 10 46 02 78 8e 4e 08 F.!...p...F.x.N.
    16:48:18.743 0090: 46 80 18 01 7a 49 1c 01 72 8a 48 cb b2 02 68 4f F...zI..r.H...hO
    16:48:18.743 00a0: f4 d8 71 02 20 b0 47 28 46 00 21 00 f5 8f 70 21 ..q. .G(F.!...p!
    16:48:18.743 00b0: 60 70 bd c0 46 66 94 08 20 79 2e 06 00 e9 2e 06 `p..Ff.. y......
    16:48:18.743 00c0: 00 20 6e 08 20 10 b5 7d 48 ff 22 36 38 90 f8 36 . n. ..}H."68..6
    16:48:18.743 00d0: 10 80 f8 36 20 7c 4c 77 48 40 18 01 7a 49 1c 01 ...6 |LwH@..zI..
    16:48:18.743 00e0: 72 78 48 cb b2 02 68 4f f4 ad 71 02 20 a0 47 a9 rxH...hO..q. .G.
    16:48:18.743 00f0: 48 a4 30 10 bd ab 5b 08 00 H.0...[..
    16:48:18.775 Incoming Dump:
    16:48:18.775 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.775 --
    16:48:18.775 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.775 Parameters:
    16:48:18.775 | Number HCI commands : 0x01
    16:48:18.775 | Command Opcode : 0xff05
    16:48:18.775 | Status : 0x00 (Success)
    16:48:18.775 --
    16:48:18.775 --
    16:48:18.775 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.775 | Address : 0x001a2df0
    16:48:18.775 | Size : 0xf0
    16:48:18.775 | Values : "A8:9E:08:20:7C:7D:08:20:F0:94:08:20:10:B5:04:46:20:7F:48:B9:A2:48:00:78:30:B9:20:79:20:B9:01:20:A0:4B:02:21:02:46:98:47:60:68:20:62:E0:68:60:61:B4:48:0C:30:10:BD:C0:46:01:B6:04:00:DD:C1:04:00:69:B1:00:00:87:9E:08:00:0D:C6:06:00:C5:94:08:20:EF:80:08:20:27:69:08:20:00:04:0E:20:FD:57:06:00:D1:2B:08:00:F0:B5:A6:49:09:78:AA:4F:AA:4D:A7:4C:40:29:12:D0:00:69:08:26:00:21:00:F8:01:6B:B8:47:0D:21:00:F8:01:6B:B8:47:29:78:06:29:14:BF:0B:21:0C:21:0D:34:44:EA:81:24:15:E0:00:69:06:26:00:21:00:F8:01:6B:B8:47:0D:21:00:F8:01:6B:B8:47:29:78:06:29:14:BF:0B:22:0C:22:95:49:09:78:01:F0:7F:01:41:EA:82:21:0C:43:A1:B2:B8:47:8F:48:68:30:F0:BD:2F:96:08:20:88:7D:08:20:B3:9D:08:00:D1:25:01:00:5F:BC:06:00:FD:BC:06:00:95:27:1A:00:BD:88:07:00"
    16:48:18.775 --
    16:48:18.775 Outgoing Dump:
    16:48:18.775 0000: 01 05 ff f5 f0 2d 1a 00 f0 a8 9e 08 20 7c 7d 08 .....-...... |}.
    16:48:18.775 0010: 20 f0 94 08 20 10 b5 04 46 20 7f 48 b9 a2 48 00 ... ...F .H..H.
    16:48:18.775 0020: 78 30 b9 20 79 20 b9 01 20 a0 4b 02 21 02 46 98 x0. y .. .K.!.F.
    16:48:18.775 0030: 47 60 68 20 62 e0 68 60 61 b4 48 0c 30 10 bd c0 G`h b.h`a.H.0...
    16:48:18.775 0040: 46 01 b6 04 00 dd c1 04 00 69 b1 00 00 87 9e 08 F........i......
    16:48:18.775 0050: 00 0d c6 06 00 c5 94 08 20 ef 80 08 20 27 69 08 ........ ... 'i.
    16:48:18.775 0060: 20 00 04 0e 20 fd 57 06 00 d1 2b 08 00 f0 b5 a6 ... .W...+.....
    16:48:18.775 0070: 49 09 78 aa 4f aa 4d a7 4c 40 29 12 d0 00 69 08 I.x.O.M.L@)...i.
    16:48:18.775 0080: 26 00 21 00 f8 01 6b b8 47 0d 21 00 f8 01 6b b8 &.!...k.G.!...k.
    16:48:18.775 0090: 47 29 78 06 29 14 bf 0b 21 0c 21 0d 34 44 ea 81 G)x.)...!.!.4D..
    16:48:18.775 00a0: 24 15 e0 00 69 06 26 00 21 00 f8 01 6b b8 47 0d $...i.&.!...k.G.
    16:48:18.775 00b0: 21 00 f8 01 6b b8 47 29 78 06 29 14 bf 0b 22 0c !...k.G)x.)...".
    16:48:18.775 00c0: 22 95 49 09 78 01 f0 7f 01 41 ea 82 21 0c 43 a1 ".I.x....A..!.C.
    16:48:18.775 00d0: b2 b8 47 8f 48 68 30 f0 bd 2f 96 08 20 88 7d 08 ..G.Hh0../.. .}.
    16:48:18.775 00e0: 20 b3 9d 08 00 d1 25 01 00 5f bc 06 00 fd bc 06 .....%.._......
    16:48:18.775 00f0: 00 95 27 1a 00 bd 88 07 00 ..'......
    16:48:18.806 Incoming Dump:
    16:48:18.806 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.806 --
    16:48:18.806 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.806 Parameters:
    16:48:18.806 | Number HCI commands : 0x01
    16:48:18.806 | Command Opcode : 0xff05
    16:48:18.806 | Status : 0x00 (Success)
    16:48:18.806 --
    16:48:18.806 --
    16:48:18.806 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.806 | Address : 0x001a2ee0
    16:48:18.806 | Size : 0xf0
    16:48:18.806 | Values : "3B:9F:08:00:81:9F:08:00:38:B5:C0:6A:00:28:2C:D0:86:48:8A:4C:00:78:17:49:84:F8:34:00:03:20:88:47:A0:7C:16:49:40:1C:A0:74:94:F8:E6:00:40:1C:84:F8:E6:00:03:20:88:47:82:4D:23:6B:A1:7C:C3:F3:40:00:C3:F3:80:02:00:90:03:F0:01:03:4F:F4:CD:70:A8:47:20:6B:79:4B:C0:F3:C0:01:C0:F3:00:12:40:F2:97:10:98:47:73:49:4F:F4:00:70:08:80:72:48:00:F5:BD:70:38:BD:C0:46:8B:26:07:00:50:95:08:20:21:20:07:00:71:48:72:49:02:78:08:88:62:F3:05:10:08:80:08:88:20:F0:08:00:08:80:6B:48:2C:30:70:47:30:B5:04:46:6D:4A:25:68:20:21:28:46:90:47:69:48:25:60:60:61:68:48:A5:61:00:F5:27:70:30:BD:C0:46:C3:BF:07:00:29:B7:04:00:6D:18:08:00:CD:01:02:00:80:DC:08:20:FD:3A:03:00:F2:9E:08:20:75:04:02:00:80:7D:08:20:A1:C8:07:00:2D:E9:F0:41:AD:F1:1C:0D:44:69:5B:48"
    16:48:18.806 --
    16:48:18.806 Outgoing Dump:
    16:48:18.806 0000: 01 05 ff f5 e0 2e 1a 00 f0 3b 9f 08 00 81 9f 08 .........;......
    16:48:18.806 0010: 00 38 b5 c0 6a 00 28 2c d0 86 48 8a 4c 00 78 17 .8..j.(,..H.L.x.
    16:48:18.806 0020: 49 84 f8 34 00 03 20 88 47 a0 7c 16 49 40 1c a0 I..4.. .G.|.I@..
    16:48:18.806 0030: 74 94 f8 e6 00 40 1c 84 f8 e6 00 03 20 88 47 82 t....@...... .G.
    16:48:18.806 0040: 4d 23 6b a1 7c c3 f3 40 00 c3 f3 80 02 00 90 03 M#k.|..@........
    16:48:18.806 0050: f0 01 03 4f f4 cd 70 a8 47 20 6b 79 4b c0 f3 c0 ...O..p.G kyK...
    16:48:18.806 0060: 01 c0 f3 00 12 40 f2 97 10 98 47 73 49 4f f4 00 .....@....GsIO..
    16:48:18.806 0070: 70 08 80 72 48 00 f5 bd 70 38 bd c0 46 8b 26 07 p..rH...p8..F.&.
    16:48:18.806 0080: 00 50 95 08 20 21 20 07 00 71 48 72 49 02 78 08 .P.. ! ..qHrI.x.
    16:48:18.806 0090: 88 62 f3 05 10 08 80 08 88 20 f0 08 00 08 80 6b .b....... .....k
    16:48:18.806 00a0: 48 2c 30 70 47 30 b5 04 46 6d 4a 25 68 20 21 28 H,0pG0..FmJ%h !(
    16:48:18.806 00b0: 46 90 47 69 48 25 60 60 61 68 48 a5 61 00 f5 27 F.GiH%``ahH.a..'
    16:48:18.806 00c0: 70 30 bd c0 46 c3 bf 07 00 29 b7 04 00 6d 18 08 p0..F....)...m..
    16:48:18.806 00d0: 00 cd 01 02 00 80 dc 08 20 fd 3a 03 00 f2 9e 08 ........ .:.....
    16:48:18.806 00e0: 20 75 04 02 00 80 7d 08 20 a1 c8 07 00 2d e9 f0 u....}. ....-..
    16:48:18.806 00f0: 41 ad f1 1c 0d 44 69 5b 48 A....Di[H
    16:48:18.837 Incoming Dump:
    16:48:18.837 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.837 --
    16:48:18.837 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.837 Parameters:
    16:48:18.837 | Number HCI commands : 0x01
    16:48:18.837 | Command Opcode : 0xff05
    16:48:18.837 | Status : 0x00 (Success)
    16:48:18.837 --
    16:48:18.837 --
    16:48:18.837 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.837 | Address : 0x001a2fd0
    16:48:18.837 | Size : 0xf0
    16:48:18.837 | Values : "80:47:66:49:80:46:02:20:88:47:65:4F:97:F8:74:0A:80:1E:02:28:0F:D8:56:49:97:F8:87:0A:88:47:55:49:97:F8:88:0A:88:47:18:B1:53:49:97:F8:88:0A:88:47:01:20:87:F8:74:0A:51:49:97:F8:87:0A:88:47:FF:20:58:49:87:F8:87:0A:05:20:87:F8:74:0A:02:20:88:47:01:26:0F:20:8D:F8:12:00:8D:F8:10:60:97:F8:86:0A:8D:F8:11:00:B7:F8:84:0A:45:49:AD:F8:00:00:68:46:88:47:00:25:87:F8:74:5A:B8:F1:01:0F:18:BF:B8:F1:02:0F:01:D1:3F:48:80:47:3F:49:04:20:88:47:06:80:21:78:01:72:3D:49:88:47:3D:49:07:20:88:47:AD:F8:14:50:AD:F8:16:50:3B:4A:8D:F8:18:50:05:A9:B0:20:90:47:39:48:B8:30:07:B0:BD:E8:F0:81:55:0D:02:00:9F:A2:08:20:A9:0F:1A:00:30:B5:3A:4C:34:4D:94:F8:52:00:95:F8:9D:10:04:EB:00:10:40:89:01:29:02:D1:02:28:A8:BF:02:20:30:49:A5:F8:96:00:18:20:88:47"
    16:48:18.837 --
    16:48:18.837 Outgoing Dump:
    16:48:18.837 0000: 01 05 ff f5 d0 2f 1a 00 f0 80 47 66 49 80 46 02 ...../....GfI.F.
    16:48:18.837 0010: 20 88 47 65 4f 97 f8 74 0a 80 1e 02 28 0f d8 56 .GeO..t....(..V
    16:48:18.837 0020: 49 97 f8 87 0a 88 47 55 49 97 f8 88 0a 88 47 18 I.....GUI.....G.
    16:48:18.837 0030: b1 53 49 97 f8 88 0a 88 47 01 20 87 f8 74 0a 51 .SI.....G. ..t.Q
    16:48:18.837 0040: 49 97 f8 87 0a 88 47 ff 20 58 49 87 f8 87 0a 05 I.....G. XI.....
    16:48:18.837 0050: 20 87 f8 74 0a 02 20 88 47 01 26 0f 20 8d f8 12 ..t.. .G.&. ...
    16:48:18.837 0060: 00 8d f8 10 60 97 f8 86 0a 8d f8 11 00 b7 f8 84 ....`...........
    16:48:18.837 0070: 0a 45 49 ad f8 00 00 68 46 88 47 00 25 87 f8 74 .EI....hF.G.%..t
    16:48:18.837 0080: 5a b8 f1 01 0f 18 bf b8 f1 02 0f 01 d1 3f 48 80 Z............?H.
    16:48:18.837 0090: 47 3f 49 04 20 88 47 06 80 21 78 01 72 3d 49 88 G?I. .G..!x.r=I.
    16:48:18.837 00a0: 47 3d 49 07 20 88 47 ad f8 14 50 ad f8 16 50 3b G=I. .G...P...P;
    16:48:18.837 00b0: 4a 8d f8 18 50 05 a9 b0 20 90 47 39 48 b8 30 07 J...P... .G9H.0.
    16:48:18.837 00c0: b0 bd e8 f0 81 55 0d 02 00 9f a2 08 20 a9 0f 1a .....U...... ...
    16:48:18.837 00d0: 00 30 b5 3a 4c 34 4d 94 f8 52 00 95 f8 9d 10 04 .0.:L4M..R......
    16:48:18.837 00e0: eb 00 10 40 89 01 29 02 d1 02 28 a8 bf 02 20 30 ...@..)...(... 0
    16:48:18.837 00f0: 49 a5 f8 96 00 18 20 88 47 I..... .G
    16:48:18.868 Incoming Dump:
    16:48:18.868 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.868 --
    16:48:18.868 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.868 Parameters:
    16:48:18.868 | Number HCI commands : 0x01
    16:48:18.868 | Command Opcode : 0xff05
    16:48:18.868 | Status : 0x00 (Success)
    16:48:18.868 --
    16:48:18.868 --
    16:48:18.868 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.868 | Address : 0x001a30c0
    16:48:18.868 | Size : 0xf0
    16:48:18.868 | Values : "2E:49:01:20:08:70:95:F8:9D:10:2D:48:01:29:04:D0:61:6E:11:F0:01:2F:04:D1:06:E0:61:6E:11:F0:81:7F:02:D0:00:F5:06:70:30:BD:00:F5:02:70:30:BD:C0:46:E4:69:08:20:65:9D:03:00:B5:E7:00:00:00:80:FF:FF:3B:84:08:20:FB:D3:00:00:7F:7C:08:20:A8:7E:08:20:8C:E8:0C:20:91:8E:06:00:E1:C6:07:00:C0:F0:0C:20:E5:C5:07:00:83:7B:08:00:D0:DC:08:20:20:F5:0E:20:00:00:03:20:99:B0:04:00:33:79:06:00:C1:CF:04:00:0F:47:03:00:29:21:07:00:01:26:07:00:91:3C:03:00:B5:6C:07:00:39:C3:04:00:F7:0D:03:00:2D:BB:08:00:71:05:07:00:61:5D:08:00:3D:AF:05:00:8B:26:07:00:00:00:08:20:21:20:07:00:71:07:07:00:D6:DC:08:20:35:29:05:00:F4:9F:08:20:2D:E9:F0:47:AD:F1:20:0D:8D:4D:82:46:95:F8:36:10:DA:F8:14:00:DA:F8:24:60:A0:F1:01:00:21:B1:E9:6B:2A:6C:8A:42:01:D8:E0:E0"
    16:48:18.868 --
    16:48:18.868 Outgoing Dump:
    16:48:18.868 0000: 01 05 ff f5 c0 30 1a 00 f0 2e 49 01 20 08 70 95 .....0....I. .p.
    16:48:18.868 0010: f8 9d 10 2d 48 01 29 04 d0 61 6e 11 f0 01 2f 04 ...-H.)..an.../.
    16:48:18.868 0020: d1 06 e0 61 6e 11 f0 81 7f 02 d0 00 f5 06 70 30 ...an.........p0
    16:48:18.868 0030: bd 00 f5 02 70 30 bd c0 46 e4 69 08 20 65 9d 03 ....p0..F.i. e..
    16:48:18.868 0040: 00 b5 e7 00 00 00 80 ff ff 3b 84 08 20 fb d3 00 .........;.. ...
    16:48:18.868 0050: 00 7f 7c 08 20 a8 7e 08 20 8c e8 0c 20 91 8e 06 ..|. .~. ... ...
    16:48:18.868 0060: 00 e1 c6 07 00 c0 f0 0c 20 e5 c5 07 00 83 7b 08 ........ .....{.
    16:48:18.868 0070: 00 d0 dc 08 20 20 f5 0e 20 00 00 03 20 99 b0 04 .... .. ... ...
    16:48:18.868 0080: 00 33 79 06 00 c1 cf 04 00 0f 47 03 00 29 21 07 .3y.......G..)!.
    16:48:18.868 0090: 00 01 26 07 00 91 3c 03 00 b5 6c 07 00 39 c3 04 ..&...<...l..9..
    16:48:18.868 00a0: 00 f7 0d 03 00 2d bb 08 00 71 05 07 00 61 5d 08 .....-...q...a].
    16:48:18.868 00b0: 00 3d af 05 00 8b 26 07 00 00 00 08 20 21 20 07 .=....&..... ! .
    16:48:18.868 00c0: 00 71 07 07 00 d6 dc 08 20 35 29 05 00 f4 9f 08 .q...... 5).....
    16:48:18.868 00d0: 20 2d e9 f0 47 ad f1 20 0d 8d 4d 82 46 95 f8 36 -..G.. ..M.F..6
    16:48:18.868 00e0: 10 da f8 14 00 da f8 24 60 a0 f1 01 00 21 b1 e9 .......$`....!..
    16:48:18.868 00f0: 6b 2a 6c 8a 42 01 d8 e0 e0 k*l.B....
    16:48:18.900 Incoming Dump:
    16:48:18.900 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.900 --
    16:48:18.900 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.900 Parameters:
    16:48:18.900 | Number HCI commands : 0x01
    16:48:18.900 | Command Opcode : 0xff05
    16:48:18.900 | Status : 0x00 (Success)
    16:48:18.900 --
    16:48:18.900 --
    16:48:18.900 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.900 | Address : 0x001a31b0
    16:48:18.900 | Size : 0xf0
    16:48:18.900 | Values : "E9:6B:49:1C:E9:63:8F:4C:8D:4F:95:F8:35:C0:BC:F1:00:0F:57:D1:00:2E:43:D0:39:46:09:1F:0A:68:52:1C:0A:60:22:46:D2:1E:12:78:B2:42:33:D9:4A:68:93:49:09:78:31:B1:13:68:19:44:11:60:11:8C:01:F1:01:01:11:84:9A:49:09:78:31:B1:53:68:19:44:51:60:51:8C:01:F1:01:01:51:84:96:49:09:78:31:B1:93:69:19:44:91:61:91:8C:01:F1:01:01:91:84:92:49:93:68:09:78:19:44:91:60:90:49:D3:68:09:78:19:44:D1:60:8F:49:13:69:09:78:19:44:11:61:8D:49:09:78:53:69:19:44:51:61:0D:E0:4A:68:D1:8C:01:F1:01:01:D1:84:07:E0:88:4B:41:F2:F8:02:D1:5A:01:F1:01:01:D1:52:3A:68:D1:69:01:F1:01:01:D1:61:30:B9:51:8F:01:F1:01:01:51:87:01:E0:4F:F0:01:06:95:F8:34:10:DF:F8:00:82:E9:B9:30:43:19:D1:FF:E7:84:4A:7B:48:40:21:90:47:39:68:C8:69:40:1C:C8:61:78:49:40:F2:81:20:88:47"
    16:48:18.900 --
    16:48:18.900 Outgoing Dump:
    16:48:18.900 0000: 01 05 ff f5 b0 31 1a 00 f0 e9 6b 49 1c e9 63 8f .....1....kI..c.
    16:48:18.900 0010: 4c 8d 4f 95 f8 35 c0 bc f1 00 0f 57 d1 00 2e 43 L.O..5.....W...C
    16:48:18.900 0020: d0 39 46 09 1f 0a 68 52 1c 0a 60 22 46 d2 1e 12 .9F...hR..`"F...
    16:48:18.900 0030: 78 b2 42 33 d9 4a 68 93 49 09 78 31 b1 13 68 19 x.B3.Jh.I.x1..h.
    16:48:18.900 0040: 44 11 60 11 8c 01 f1 01 01 11 84 9a 49 09 78 31 D.`.........I.x1
    16:48:18.900 0050: b1 53 68 19 44 51 60 51 8c 01 f1 01 01 51 84 96 .Sh.DQ`Q.....Q..
    16:48:18.900 0060: 49 09 78 31 b1 93 69 19 44 91 61 91 8c 01 f1 01 I.x1..i.D.a.....
    16:48:18.900 0070: 01 91 84 92 49 93 68 09 78 19 44 91 60 90 49 d3 ....I.h.x.D.`.I.
    16:48:18.900 0080: 68 09 78 19 44 d1 60 8f 49 13 69 09 78 19 44 11 h.x.D.`.I.i.x.D.
    16:48:18.900 0090: 61 8d 49 09 78 53 69 19 44 51 61 0d e0 4a 68 d1 a.I.xSi.DQa..Jh.
    16:48:18.900 00a0: 8c 01 f1 01 01 d1 84 07 e0 88 4b 41 f2 f8 02 d1 ..........KA....
    16:48:18.900 00b0: 5a 01 f1 01 01 d1 52 3a 68 d1 69 01 f1 01 01 d1 Z.....R:h.i.....
    16:48:18.900 00c0: 61 30 b9 51 8f 01 f1 01 01 51 87 01 e0 4f f0 01 a0.Q.....Q...O..
    16:48:18.900 00d0: 06 95 f8 34 10 df f8 00 82 e9 b9 30 43 19 d1 ff ...4.......0C...
    16:48:18.900 00e0: e7 84 4a 7b 48 40 21 90 47 39 68 c8 69 40 1c c8 ..J{H@!.G9h.i@..
    16:48:18.900 00f0: 61 78 49 40 f2 81 20 88 47 axI@.. .G
    16:48:18.931 Incoming Dump:
    16:48:18.931 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.931 --
    16:48:18.931 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.931 Parameters:
    16:48:18.931 | Number HCI commands : 0x01
    16:48:18.931 | Command Opcode : 0xff05
    16:48:18.931 | Status : 0x00 (Success)
    16:48:18.931 --
    16:48:18.931 --
    16:48:18.931 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.931 | Address : 0x001a32a0
    16:48:18.931 | Size : 0xf0
    16:48:18.931 | Values : "01:20:85:F8:34:00:E8:63:05:F1:2C:00:C0:47:69:6C:28:8F:40:1A:A0:F2:99:10:5A:E0:00:20:58:E0:4F:F0:00:07:68:B9:7E:B9:BC:F1:00:0F:09:D1:05:F1:2C:00:C0:47:69:6C:28:8F:40:1A:A0:F2:99:10:20:80:3F:E0:BC:F1:01:0F:3C:D1:6A:49:04:A8:88:47:05:F1:2C:00:90:E8:03:00:06:AA:82:E8:03:00:28:8F:05:F1:2C:09:20:80:DF:F8:90:81:27:B1:04:A8:05:22:00:21:03:46:C0:47:06:AF:22:88:38:46:00:21:03:46:C0:47:68:6C:6B:46:00:21:00:F2:05:10:42:42:38:46:C0:47:55:4B:02:AA:04:A9:68:46:98:47:07:46:2A:8F:00:21:48:46:03:46:C0:47:FE:2F:DC:D0:00:20:20:80:02:99:BD:F8:0C:00:40:F2:E2:42:02:FB:01:00:4F:49:80:B2:88:47:49:4C:00:2E:20:88:0C:BF:20:F0:20:00:40:F0:20:00:20:80:00:20:85:F8:35:00:44:48:CA:F8:00:60:08:B0:00:F5:45:70:BD:E8:F0:87:10:B5:04:46:45:48:01:78"
    16:48:18.931 --
    16:48:18.931 Outgoing Dump:
    16:48:18.931 0000: 01 05 ff f5 a0 32 1a 00 f0 01 20 85 f8 34 00 e8 .....2.... ..4..
    16:48:18.931 0010: 63 05 f1 2c 00 c0 47 69 6c 28 8f 40 1a a0 f2 99 c..,..Gil(.@....
    16:48:18.931 0020: 10 5a e0 00 20 58 e0 4f f0 00 07 68 b9 7e b9 bc .Z.. X.O...h.~..
    16:48:18.931 0030: f1 00 0f 09 d1 05 f1 2c 00 c0 47 69 6c 28 8f 40 .......,..Gil(.@
    16:48:18.931 0040: 1a a0 f2 99 10 20 80 3f e0 bc f1 01 0f 3c d1 6a ..... .?.....<.j
    16:48:18.931 0050: 49 04 a8 88 47 05 f1 2c 00 90 e8 03 00 06 aa 82 I...G..,........
    16:48:18.931 0060: e8 03 00 28 8f 05 f1 2c 09 20 80 df f8 90 81 27 ...(...,. .....'
    16:48:18.931 0070: b1 04 a8 05 22 00 21 03 46 c0 47 06 af 22 88 38 ....".!.F.G..".8
    16:48:18.931 0080: 46 00 21 03 46 c0 47 68 6c 6b 46 00 21 00 f2 05 F.!.F.GhlkF.!...
    16:48:18.931 0090: 10 42 42 38 46 c0 47 55 4b 02 aa 04 a9 68 46 98 .BB8F.GUK....hF.
    16:48:18.931 00a0: 47 07 46 2a 8f 00 21 48 46 03 46 c0 47 fe 2f dc G.F*..!HF.F.G./.
    16:48:18.931 00b0: d0 00 20 20 80 02 99 bd f8 0c 00 40 f2 e2 42 02 .. .......@..B.
    16:48:18.931 00c0: fb 01 00 4f 49 80 b2 88 47 49 4c 00 2e 20 88 0c ...OI...GIL.. ..
    16:48:18.931 00d0: bf 20 f0 20 00 40 f0 20 00 20 80 00 20 85 f8 35 . . .@. . .. ..5
    16:48:18.931 00e0: 00 44 48 ca f8 00 60 08 b0 00 f5 45 70 bd e8 f0 .DH...`....Ep...
    16:48:18.931 00f0: 87 10 b5 04 46 45 48 01 78 ....FEH.x
    16:48:18.962 Incoming Dump:
    16:48:18.962 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.962 --
    16:48:18.962 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.962 Parameters:
    16:48:18.962 | Number HCI commands : 0x01
    16:48:18.962 | Command Opcode : 0xff05
    16:48:18.962 | Status : 0x00 (Success)
    16:48:18.962 --
    16:48:18.962 --
    16:48:18.962 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.962 | Address : 0x001a3390
    16:48:18.962 | Size : 0xf0
    16:48:18.962 | Values : "01:29:06:D1:01:46:44:4B:00:20:01:22:08:70:0A:21:98:47:20:69:40:1C:20:61:3D:48:28:30:10:BD:10:B5:04:46:20:69:3E:49:00:78:88:47:00:20:A0:60:B6:20:20:60:3A:48:3E:30:10:BD:80:DC:08:20:00:B5:00:69:38:4B:C1:78:2A:22:98:47:37:48:54:30:00:BD:37:49:09:88:C1:F3:C2:01:01:60:35:48:8E:30:70:47:C0:46:A0:81:08:20:6A:2A:08:20:00:B5:33:49:09:78:39:B1:C1:69:32:4B:01:F1:56:00:D1:F8:7C:11:10:22:98:47:2C:48:00:F5:A3:70:00:BD:2D:48:74:30:70:47:2D:48:2A:30:70:47:2C:48:16:30:70:47:C0:46:88:81:08:20:10:B5:80:69:72:B6:29:4C:21:68:49:1C:21:60:28:49:88:47:21:68:49:1E:21:60:00:D1:62:B6:26:49:03:20:88:47:24:48:00:F5:C2:70:10:BD:C0:46:89:81:08:20:8E:81:08:20:8A:81:08:20:8B:81:08:20:8C:81:08:20:8D:81:08:20:D4:19:08:20:FC:2D:03:20:C5:C7:07:00"
    16:48:18.962 --
    16:48:18.962 Outgoing Dump:
    16:48:18.962 0000: 01 05 ff f5 90 33 1a 00 f0 01 29 06 d1 01 46 44 .....3....)...FD
    16:48:18.962 0010: 4b 00 20 01 22 08 70 0a 21 98 47 20 69 40 1c 20 K. .".p.!.G i@.
    16:48:18.962 0020: 61 3d 48 28 30 10 bd 10 b5 04 46 20 69 3e 49 00 a=H(0.....F i>I.
    16:48:18.962 0030: 78 88 47 00 20 a0 60 b6 20 20 60 3a 48 3e 30 10 x.G. .`. `:H>0.
    16:48:18.962 0040: bd 80 dc 08 20 00 b5 00 69 38 4b c1 78 2a 22 98 .... ...i8K.x*".
    16:48:18.962 0050: 47 37 48 54 30 00 bd 37 49 09 88 c1 f3 c2 01 01 G7HT0..7I.......
    16:48:18.962 0060: 60 35 48 8e 30 70 47 c0 46 a0 81 08 20 6a 2a 08 `5H.0pG.F... j*.
    16:48:18.962 0070: 20 00 b5 33 49 09 78 39 b1 c1 69 32 4b 01 f1 56 ..3I.x9..i2K..V
    16:48:18.962 0080: 00 d1 f8 7c 11 10 22 98 47 2c 48 00 f5 a3 70 00 ...|..".G,H...p.
    16:48:18.962 0090: bd 2d 48 74 30 70 47 2d 48 2a 30 70 47 2c 48 16 .-Ht0pG-H*0pG,H.
    16:48:18.962 00a0: 30 70 47 c0 46 88 81 08 20 10 b5 80 69 72 b6 29 0pG.F... ...ir.)
    16:48:18.962 00b0: 4c 21 68 49 1c 21 60 28 49 88 47 21 68 49 1e 21 L!hI.!`(I.G!hI.!
    16:48:18.962 00c0: 60 00 d1 62 b6 26 49 03 20 88 47 24 48 00 f5 c2 `..b.&I. .G$H...
    16:48:18.962 00d0: 70 10 bd c0 46 89 81 08 20 8e 81 08 20 8a 81 08 p...F... ... ...
    16:48:18.962 00e0: 20 8b 81 08 20 8c 81 08 20 8d 81 08 20 d4 19 08 ... ... ... ...
    16:48:18.962 00f0: 20 fc 2d 03 20 c5 c7 07 00 .-. ....
    16:48:18.993 Incoming Dump:
    16:48:18.993 0000: 04 0e 04 01 05 ff 00 .......
    16:48:18.993 --
    16:48:18.993 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:18.993 Parameters:
    16:48:18.993 | Number HCI commands : 0x01
    16:48:18.993 | Command Opcode : 0xff05
    16:48:18.993 | Status : 0x00 (Success)
    16:48:18.993 --
    16:48:18.993 --
    16:48:18.993 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:18.993 | Address : 0x001a3480
    16:48:18.993 | Size : 0x6c
    16:48:18.993 | Values : "FD:CF:02:00:6B:BD:07:00:22:00:01:20:65:F1:02:00:95:1A:06:00:31:20:06:00:8B:75:06:00:33:79:06:00:A5:4C:01:00:D3:DC:08:20:A9:0F:1A:00:95:B2:02:00:C5:28:1A:00:13:B5:01:00:1D:30:08:00:10:00:01:20:C5:75:08:00:99:63:07:00:D5:DC:08:20:C9:E8:08:00:65:F8:06:00:AB:2F:00:00:F3:3D:00:00:9C:84:08:20:9B:08:03:00:3D:41:08:00:21:20:07:00"
    16:48:18.993 --
    16:48:18.993 Outgoing Dump:
    16:48:18.993 0000: 01 05 ff 71 80 34 1a 00 6c fd cf 02 00 6b bd 07 ...q.4..l....k..
    16:48:18.993 0010: 00 22 00 01 20 65 f1 02 00 95 1a 06 00 31 20 06 .".. e.......1 .
    16:48:18.993 0020: 00 8b 75 06 00 33 79 06 00 a5 4c 01 00 d3 dc 08 ..u..3y...L.....
    16:48:18.993 0030: 20 a9 0f 1a 00 95 b2 02 00 c5 28 1a 00 13 b5 01 .........(.....
    16:48:18.993 0040: 00 1d 30 08 00 10 00 01 20 c5 75 08 00 99 63 07 ..0..... .u...c.
    16:48:18.993 0050: 00 d5 dc 08 20 c9 e8 08 00 65 f8 06 00 ab 2f 00 .... ....e..../.
    16:48:18.993 0060: 00 f3 3d 00 00 9c 84 08 20 9b 08 03 00 3d 41 08 ..=..... ....=A.
    16:48:18.993 0070: 00 21 20 07 00 .! ..
    16:48:19.009 Incoming Dump:
    16:48:19.009 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.009 --
    16:48:19.009 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.009 Parameters:
    16:48:19.009 | Number HCI commands : 0x01
    16:48:19.009 | Command Opcode : 0xff05
    16:48:19.009 | Status : 0x00 (Success)
    16:48:19.009 --
    16:48:19.009 --
    16:48:19.009 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.009 | Address : 0x2008b140
    16:48:19.009 | Size : 0x20
    16:48:19.009 | Values : "C0:46:C0:46:02:24:0A:20:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46"
    16:48:19.009 --
    16:48:19.009 Outgoing Dump:
    16:48:19.009 0000: 01 05 ff 25 40 b1 08 20 20 c0 46 c0 46 02 24 0a ...%@.. .F.F.$.
    16:48:19.009 0010: 20 c0 46 c0 46 c0 46 c0 46 c0 46 c0 46 c0 46 c0 .F.F.F.F.F.F.F.
    16:48:19.009 0020: 46 c0 46 c0 46 c0 46 c0 46 F.F.F.F.F
    16:48:19.025 Incoming Dump:
    16:48:19.025 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.025 --
    16:48:19.025 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.025 Parameters:
    16:48:19.025 | Number HCI commands : 0x01
    16:48:19.025 | Command Opcode : 0xff05
    16:48:19.025 | Status : 0x00 (Success)
    16:48:19.025 --
    16:48:19.025 --
    16:48:19.025 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.025 | Address : 0x2008b860
    16:48:19.025 | Size : 0xf0
    16:48:19.025 | Values : "08:4A:02:F1:88:01:08:78:A0:F1:01:00:C0:B2:08:70:28:B9:10:78:18:B9:4F:F0:00:00:82:F8:89:00:02:48:12:30:70:47:DB:A2:08:20:D5:21:01:00:1C:B5:65:4C:4F:F4:40:71:01:AB:6A:46:A0:47:01:98:00:99:C0:0B:40:EA:41:40:1C:BD:70:B5:04:46:25:68:49:19:21:F0:7C:41:19:60:A4:88:12:19:0C:D4:40:F2:E2:40:90:42:C8:BF:00:25:14:DC:92:FB:F0:F4:92:FB:F0:F5:44:43:12:1B:0D:E0:40:F2:E2:44:92:FB:F4:F5:92:FB:F4:F6:6D:42:66:43:90:1B:18:BF:6D:1C:04:FB:05:22:6D:42:49:19:9A:80:21:F0:7C:41:19:60:70:BD:2D:E9:F0:41:49:49:80:46:04:20:88:47:38:B9:48:49:64:20:88:47:47:48:90:F9:00:00:BD:E8:F0:81:48:4F:45:4C:F8:88:40:08:03:D2:40:46:A0:47:04:46:1A:E0:3E:88:97:F8:8C:02:43:4D:40:F0:01:00:87:F8:8C:02:7D:20:A8:47:40:46:A0:47:04:46:38:88:06:F0:0F:06:66:F3:03:00"
    16:48:19.025 --
    16:48:19.025 Outgoing Dump:
    16:48:19.025 0000: 01 05 ff f5 60 b8 08 20 f0 08 4a 02 f1 88 01 08 ....`.. ..J.....
    16:48:19.025 0010: 78 a0 f1 01 00 c0 b2 08 70 28 b9 10 78 18 b9 4f x.......p(..x..O
    16:48:19.025 0020: f0 00 00 82 f8 89 00 02 48 12 30 70 47 db a2 08 ........H.0pG...
    16:48:19.025 0030: 20 d5 21 01 00 1c b5 65 4c 4f f4 40 71 01 ab 6a .!....eLO.@q..j
    16:48:19.025 0040: 46 a0 47 01 98 00 99 c0 0b 40 ea 41 40 1c bd 70 F.G......@.A@..p
    16:48:19.025 0050: b5 04 46 25 68 49 19 21 f0 7c 41 19 60 a4 88 12 ..F%hI.!.|A.`...
    16:48:19.025 0060: 19 0c d4 40 f2 e2 40 90 42 c8 bf 00 25 14 dc 92 ...@..@.B...%...
    16:48:19.025 0070: fb f0 f4 92 fb f0 f5 44 43 12 1b 0d e0 40 f2 e2 .......DC....@..
    16:48:19.025 0080: 44 92 fb f4 f5 92 fb f4 f6 6d 42 66 43 90 1b 18 D........mBfC...
    16:48:19.025 0090: bf 6d 1c 04 fb 05 22 6d 42 49 19 9a 80 21 f0 7c .m...."mBI...!.|
    16:48:19.025 00a0: 41 19 60 70 bd 2d e9 f0 41 49 49 80 46 04 20 88 A.`p.-..AII.F. .
    16:48:19.025 00b0: 47 38 b9 48 49 64 20 88 47 47 48 90 f9 00 00 bd G8.HId .GGH.....
    16:48:19.025 00c0: e8 f0 81 48 4f 45 4c f8 88 40 08 03 d2 40 46 a0 ...HOEL..@...@F.
    16:48:19.025 00d0: 47 04 46 1a e0 3e 88 97 f8 8c 02 43 4d 40 f0 01 G.F..>.....CM@..
    16:48:19.025 00e0: 00 87 f8 8c 02 7d 20 a8 47 40 46 a0 47 04 46 38 .....} .G@F.G.F8
    16:48:19.025 00f0: 88 06 f0 0f 06 66 f3 03 00 .....f...
    16:48:19.056 Incoming Dump:
    16:48:19.056 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.056 --
    16:48:19.056 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.056 Parameters:
    16:48:19.056 | Number HCI commands : 0x01
    16:48:19.056 | Command Opcode : 0xff05
    16:48:19.056 | Status : 0x00 (Success)
    16:48:19.056 --
    16:48:19.056 --
    16:48:19.056 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.056 | Address : 0x2008b950
    16:48:19.056 | Size : 0xf0
    16:48:19.056 | Values : "38:80:97:F8:8C:02:20:F0:01:00:87:F8:8C:02:7D:20:A8:47:35:49:00:20:08:80:20:46:BD:E8:F0:81:2D:E9:F0:4F:35:49:33:48:88:47:34:49:00:20:88:47:DF:F8:DC:B0:34:4C:DF:F8:C8:90:00:25:5E:46:04:F1:40:07:5A:36:34:34:19:F8:06:1F:33:48:40:5A:40:F2:A4:42:82:42:F9:DD:28:1D:4F:F0:01:08:DF:F8:AC:A0:08:FA:00:F0:30:80:D0:47:A9:B2:C8:00:00:EB:41:10:59:46:09:18:40:46:A8:40:F2:88:02:42:FC:D1:08:88:24:49:07:F8:01:0B:E8:B2:88:47:6D:1C:03:2D:44:F8:04:0B:D8:D3:20:48:80:47:00:28:FB:D1:D0:47:BD:E8:F0:8F:30:B5:20:49:05:46:0A:20:88:47:04:46:8C:B1:05:21:04:F1:08:00:19:4A:61:80:FF:21:00:F8:01:1B:03:21:00:F8:01:1B:4F:F4:C0:61:90:47:15:49:05:70:20:46:88:47:30:BD:E9:01:1A:00:41:EF:08:00:F3:C7:07:00:7E:7C:08:20:BF:00:1A:00:06:E0:0C:20:8A:21:0C:20"
    16:48:19.056 --
    16:48:19.056 Outgoing Dump:
    16:48:19.056 0000: 01 05 ff f5 50 b9 08 20 f0 38 80 97 f8 8c 02 20 ....P.. .8.....
    16:48:19.056 0010: f0 01 00 87 f8 8c 02 7d 20 a8 47 35 49 00 20 08 .......} .G5I. .
    16:48:19.056 0020: 80 20 46 bd e8 f0 81 2d e9 f0 4f 35 49 33 48 88 . F....-..O5I3H.
    16:48:19.056 0030: 47 34 49 00 20 88 47 df f8 dc b0 34 4c df f8 c8 G4I. .G....4L...
    16:48:19.056 0040: 90 00 25 5e 46 04 f1 40 07 5a 36 34 34 19 f8 06 ..%^F..@.Z644...
    16:48:19.056 0050: 1f 33 48 40 5a 40 f2 a4 42 82 42 f9 dd 28 1d 4f .3H@Z@..B.B..(.O
    16:48:19.056 0060: f0 01 08 df f8 ac a0 08 fa 00 f0 30 80 d0 47 a9 ...........0..G.
    16:48:19.056 0070: b2 c8 00 00 eb 41 10 59 46 09 18 40 46 a8 40 f2 .....A.YF..@F.@.
    16:48:19.056 0080: 88 02 42 fc d1 08 88 24 49 07 f8 01 0b e8 b2 88 ..B....$I.......
    16:48:19.056 0090: 47 6d 1c 03 2d 44 f8 04 0b d8 d3 20 48 80 47 00 Gm..-D..... H.G.
    16:48:19.056 00a0: 28 fb d1 d0 47 bd e8 f0 8f 30 b5 20 49 05 46 0a (...G....0. I.F.
    16:48:19.056 00b0: 20 88 47 04 46 8c b1 05 21 04 f1 08 00 19 4a 61 .G.F...!.....Ja
    16:48:19.056 00c0: 80 ff 21 00 f8 01 1b 03 21 00 f8 01 1b 4f f4 c0 ..!.....!....O..
    16:48:19.056 00d0: 61 90 47 15 49 05 70 20 46 88 47 30 bd e9 01 1a a.G.I.p F.G0....
    16:48:19.056 00e0: 00 41 ef 08 00 f3 c7 07 00 7e 7c 08 20 bf 00 1a .A.......~|. ...
    16:48:19.056 00f0: 00 06 e0 0c 20 8a 21 0c 20 .... .!.
    16:48:19.087 Incoming Dump:
    16:48:19.087 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.087 --
    16:48:19.087 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.087 Parameters:
    16:48:19.087 | Number HCI commands : 0x01
    16:48:19.087 | Command Opcode : 0xff05
    16:48:19.087 | Status : 0x00 (Success)
    16:48:19.087 --
    16:48:19.087 --
    16:48:19.087 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.087 | Address : 0x2008ba40
    16:48:19.087 | Size : 0xf0
    16:48:19.087 | Values : "8B:75:06:00:10:73:08:20:95:1A:06:00:A9:5A:08:00:6F:2A:0A:00:20:6E:08:20:11:76:06:00:12:61:0E:20:17:C3:07:00:0B:C1:07:00:00:61:0E:20:FB:D3:00:00:F5:EB:04:00:07:0E:03:00:2D:E9:FF:5F:68:46:01:F0:37:F8:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:52:F9:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:AD:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:AE:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:71:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:A8:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:A9:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:46:FD:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:F5:FC:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:80:FE:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:B5:FC:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:8E:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:D7:FE:BD:E8:FF:9F:2D:E9"
    16:48:19.087 --
    16:48:19.087 Outgoing Dump:
    16:48:19.087 0000: 01 05 ff f5 40 ba 08 20 f0 8b 75 06 00 10 73 08 ....@.. ..u...s.
    16:48:19.087 0010: 20 95 1a 06 00 a9 5a 08 00 6f 2a 0a 00 20 6e 08 .....Z..o*.. n.
    16:48:19.087 0020: 20 11 76 06 00 12 61 0e 20 17 c3 07 00 0b c1 07 .v...a. .......
    16:48:19.087 0030: 00 00 61 0e 20 fb d3 00 00 f5 eb 04 00 07 0e 03 ..a. ...........
    16:48:19.087 0040: 00 2d e9 ff 5f 68 46 01 f0 37 f8 bd e8 ff 9f 2d .-.._hF..7.....-
    16:48:19.087 0050: e9 ff 5f 68 46 00 f0 52 f9 bd e8 ff 9f 2d e9 ff .._hF..R.....-..
    16:48:19.087 0060: 5f 68 46 01 f0 ad fb bd e8 ff 9f 2d e9 ff 5f 68 _hF........-.._h
    16:48:19.087 0070: 46 01 f0 ae fb bd e8 ff 9f 2d e9 ff 5f 68 46 00 F........-.._hF.
    16:48:19.087 0080: f0 71 fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 a8 .q.....-.._hF...
    16:48:19.087 0090: fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 a9 fb bd .....-.._hF.....
    16:48:19.087 00a0: e8 ff 9f 2d e9 ff 5f 68 46 00 f0 46 fd bd e8 ff ...-.._hF..F....
    16:48:19.087 00b0: 9f 2d e9 ff 5f 68 46 00 f0 f5 fc bd e8 ff 9f 2d .-.._hF........-
    16:48:19.087 00c0: e9 ff 5f 68 46 00 f0 80 fe bd e8 ff 9f 2d e9 ff .._hF........-..
    16:48:19.087 00d0: 5f 68 46 00 f0 b5 fc bd e8 ff 9f 2d e9 ff 5f 68 _hF........-.._h
    16:48:19.087 00e0: 46 01 f0 8e fb bd e8 ff 9f 2d e9 ff 5f 68 46 00 F........-.._hF.
    16:48:19.087 00f0: f0 d7 fe bd e8 ff 9f 2d e9 .......-.
    16:48:19.118 Incoming Dump:
    16:48:19.118 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.118 --
    16:48:19.118 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.118 Parameters:
    16:48:19.118 | Number HCI commands : 0x01
    16:48:19.118 | Command Opcode : 0xff05
    16:48:19.118 | Status : 0x00 (Success)
    16:48:19.118 --
    16:48:19.118 --
    16:48:19.118 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.118 | Address : 0x2008bb30
    16:48:19.118 | Size : 0xf0
    16:48:19.118 | Values : "FF:5F:68:46:01:F0:28:FA:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:05:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:26:FF:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:D1:FA:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:CE:FA:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:75:FE:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:DC:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:41:FC:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:50:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:0B:FC:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4A:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4B:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4C:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4D:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4E:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4F:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:50:FB:BD:E8:FF:9F:2D:E9:FF:5F"
    16:48:19.118 --
    16:48:19.118 Outgoing Dump:
    16:48:19.118 0000: 01 05 ff f5 30 bb 08 20 f0 ff 5f 68 46 01 f0 28 ....0.. .._hF..(
    16:48:19.118 0010: fa bd e8 ff 9f 2d e9 ff 5f 68 46 00 f0 05 fb bd .....-.._hF.....
    16:48:19.118 0020: e8 ff 9f 2d e9 ff 5f 68 46 00 f0 26 ff bd e8 ff ...-.._hF..&....
    16:48:19.118 0030: 9f 2d e9 ff 5f 68 46 00 f0 d1 fa bd e8 ff 9f 2d .-.._hF........-
    16:48:19.118 0040: e9 ff 5f 68 46 01 f0 ce fa bd e8 ff 9f 2d e9 ff .._hF........-..
    16:48:19.118 0050: 5f 68 46 00 f0 75 fe bd e8 ff 9f 2d e9 ff 5f 68 _hF..u.....-.._h
    16:48:19.118 0060: 46 00 f0 dc fb bd e8 ff 9f 2d e9 ff 5f 68 46 00 F........-.._hF.
    16:48:19.118 0070: f0 41 fc bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 50 .A.....-.._hF..P
    16:48:19.118 0080: fb bd e8 ff 9f 2d e9 ff 5f 68 46 00 f0 0b fc bd .....-.._hF.....
    16:48:19.118 0090: e8 ff 9f 2d e9 ff 5f 68 46 01 f0 4a fb bd e8 ff ...-.._hF..J....
    16:48:19.118 00a0: 9f 2d e9 ff 5f 68 46 01 f0 4b fb bd e8 ff 9f 2d .-.._hF..K.....-
    16:48:19.118 00b0: e9 ff 5f 68 46 01 f0 4c fb bd e8 ff 9f 2d e9 ff .._hF..L.....-..
    16:48:19.118 00c0: 5f 68 46 01 f0 4d fb bd e8 ff 9f 2d e9 ff 5f 68 _hF..M.....-.._h
    16:48:19.118 00d0: 46 01 f0 4e fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 F..N.....-.._hF.
    16:48:19.118 00e0: f0 4f fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 50 .O.....-.._hF..P
    16:48:19.118 00f0: fb bd e8 ff 9f 2d e9 ff 5f .....-.._
    16:48:19.150 Incoming Dump:
    16:48:19.150 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.150 --
    16:48:19.150 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.150 Parameters:
    16:48:19.150 | Number HCI commands : 0x01
    16:48:19.150 | Command Opcode : 0xff05
    16:48:19.150 | Status : 0x00 (Success)
    16:48:19.150 --
    16:48:19.150 --
    16:48:19.150 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.150 | Address : 0x2008bc20
    16:48:19.150 | Size : 0xf0
    16:48:19.150 | Values : "68:46:00:F0:A7:F8:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:44:FA:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:43:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:44:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:45:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:46:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:47:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:48:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:49:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4A:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4B:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4C:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4D:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4E:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:4F:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:50:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:51:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46"
    16:48:19.150 --
    16:48:19.150 Outgoing Dump:
    16:48:19.150 0000: 01 05 ff f5 20 bc 08 20 f0 68 46 00 f0 a7 f8 bd .... .. .hF.....
    16:48:19.150 0010: e8 ff 9f 2d e9 ff 5f 68 46 00 f0 44 fa bd e8 ff ...-.._hF..D....
    16:48:19.150 0020: 9f 2d e9 ff 5f 68 46 01 f0 43 fb bd e8 ff 9f 2d .-.._hF..C.....-
    16:48:19.150 0030: e9 ff 5f 68 46 01 f0 44 fb bd e8 ff 9f 2d e9 ff .._hF..D.....-..
    16:48:19.150 0040: 5f 68 46 01 f0 45 fb bd e8 ff 9f 2d e9 ff 5f 68 _hF..E.....-.._h
    16:48:19.150 0050: 46 01 f0 46 fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 F..F.....-.._hF.
    16:48:19.150 0060: f0 47 fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 48 .G.....-.._hF..H
    16:48:19.150 0070: fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 49 fb bd .....-.._hF..I..
    16:48:19.150 0080: e8 ff 9f 2d e9 ff 5f 68 46 01 f0 4a fb bd e8 ff ...-.._hF..J....
    16:48:19.150 0090: 9f 2d e9 ff 5f 68 46 01 f0 4b fb bd e8 ff 9f 2d .-.._hF..K.....-
    16:48:19.150 00a0: e9 ff 5f 68 46 01 f0 4c fb bd e8 ff 9f 2d e9 ff .._hF..L.....-..
    16:48:19.150 00b0: 5f 68 46 01 f0 4d fb bd e8 ff 9f 2d e9 ff 5f 68 _hF..M.....-.._h
    16:48:19.150 00c0: 46 01 f0 4e fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 F..N.....-.._hF.
    16:48:19.150 00d0: f0 4f fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 50 .O.....-.._hF..P
    16:48:19.150 00e0: fb bd e8 ff 9f 2d e9 ff 5f 68 46 01 f0 51 fb bd .....-.._hF..Q..
    16:48:19.150 00f0: e8 ff 9f 2d e9 ff 5f 68 46 ...-.._hF
    16:48:19.181 Incoming Dump:
    16:48:19.181 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.181 --
    16:48:19.181 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.181 Parameters:
    16:48:19.181 | Number HCI commands : 0x01
    16:48:19.181 | Command Opcode : 0xff05
    16:48:19.181 | Status : 0x00 (Success)
    16:48:19.181 --
    16:48:19.181 --
    16:48:19.181 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.181 | Address : 0x2008bd10
    16:48:19.181 | Size : 0xf0
    16:48:19.181 | Values : "01:F0:52:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:53:FB:BD:E8:FF:9F:2D:E9:FF:5F:68:46:01:F0:54:FB:BD:E8:FF:9F:80:69:56:49:81:42:1A:D1:55:4A:B2:F8:C8:10:4F:F6:FD:70:08:40:A2:F8:C8:00:52:48:01:46:00:88:38:39:20:F4:80:70:08:87:50:48:02:78:02:2A:07:D1:42:78:2A:B9:80:78:18:B9:08:88:20:F0:08:00:08:80:70:47:30:B5:04:46:20:7D:06:28:0E:D1:48:48:80:47:48:4D:28:68:20:B1:47:49:17:20:88:47:00:20:28:60:46:48:30:30:60:63:01:20:20:60:30:BD:2D:E9:FF:4F:04:46:0D:46:42:4E:1E:23:5F:FA:84:F8:01:AA:69:46:40:46:B0:47:6A:42:3E:4D:00:21:02:AB:68:46:A8:47:3D:48:A7:4D:4F:EA:44:01:00:F1:01:00:01:EB:84:01:01:EB:00:06:08:44:81:78:00:98:DF:F8:DC:90:68:50:20:46:58:B1:40:1E:01:28:0D:D8:BD:F8:04:10:01:2C:19:BF:48:46:48:30:48:46:20:30:03:E0:48:46"
    16:48:19.181 --
    16:48:19.181 Outgoing Dump:
    16:48:19.181 0000: 01 05 ff f5 10 bd 08 20 f0 01 f0 52 fb bd e8 ff ....... ...R....
    16:48:19.181 0010: 9f 2d e9 ff 5f 68 46 01 f0 53 fb bd e8 ff 9f 2d .-.._hF..S.....-
    16:48:19.181 0020: e9 ff 5f 68 46 01 f0 54 fb bd e8 ff 9f 80 69 56 .._hF..T......iV
    16:48:19.181 0030: 49 81 42 1a d1 55 4a b2 f8 c8 10 4f f6 fd 70 08 I.B..UJ....O..p.
    16:48:19.181 0040: 40 a2 f8 c8 00 52 48 01 46 00 88 38 39 20 f4 80 @....RH.F..89 ..
    16:48:19.181 0050: 70 08 87 50 48 02 78 02 2a 07 d1 42 78 2a b9 80 p..PH.x.*..Bx*..
    16:48:19.181 0060: 78 18 b9 08 88 20 f0 08 00 08 80 70 47 30 b5 04 x.... .....pG0..
    16:48:19.181 0070: 46 20 7d 06 28 0e d1 48 48 80 47 48 4d 28 68 20 F }.(..HH.GHM(h
    16:48:19.181 0080: b1 47 49 17 20 88 47 00 20 28 60 46 48 30 30 60 .GI. .G. (`FH00`
    16:48:19.181 0090: 63 01 20 20 60 30 bd 2d e9 ff 4f 04 46 0d 46 42 c. `0.-..O.F.FB
    16:48:19.181 00a0: 4e 1e 23 5f fa 84 f8 01 aa 69 46 40 46 b0 47 6a N.#_.....iF@F.Gj
    16:48:19.181 00b0: 42 3e 4d 00 21 02 ab 68 46 a8 47 3d 48 a7 4d 4f B>M.!..hF.G=H.MO
    16:48:19.181 00c0: ea 44 01 00 f1 01 00 01 eb 84 01 01 eb 00 06 08 .D..............
    16:48:19.181 00d0: 44 81 78 00 98 df f8 dc 90 68 50 20 46 58 b1 40 D.x......hP FX.@
    16:48:19.181 00e0: 1e 01 28 0d d8 bd f8 04 10 01 2c 19 bf 48 46 48 ..(.......,..HFH
    16:48:19.181 00f0: 30 48 46 20 30 03 e0 48 46 0HF 0..HF
    16:48:19.212 Incoming Dump:
    16:48:19.212 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.212 --
    16:48:19.212 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.212 Parameters:
    16:48:19.212 | Number HCI commands : 0x01
    16:48:19.212 | Command Opcode : 0xff05
    16:48:19.212 | Status : 0x00 (Success)
    16:48:19.212 --
    16:48:19.212 --
    16:48:19.212 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.212 | Address : 0x2008be00
    16:48:19.212 | Size : 0xf0
    16:48:19.212 | Values : "BD:F8:04:10:00:1F:01:80:02:99:30:78:BD:F8:0C:20:29:50:70:78:DF:F8:90:B2:2A:52:4F:20:D8:47:DF:F8:8C:A2:F1:78:A2:4F:68:54:A0:1D:C1:B2:50:46:B8:47:A0:49:40:46:88:47:02:99:D8:47:4D:46:05:F1:5A:05:1C:B9:9D:49:09:78:66:1C:01:E0:66:1C:F1:B2:4A:46:8A:32:50:54:48:46:86:30:B8:47:41:46:50:46:B8:47:01:20:B0:40:28:80:A6:48:80:47:24:1D:E4:B2:48:46:A1:4A:21:46:60:30:90:47:00:28:F8:D1:9F:4A:00:21:50:46:90:47:00:20:00:90:85:F8:2C:00:BD:E8:FF:8F:00:02:01:01:00:01:01:20:3A:23:0C:20:CC:77:08:20:6F:B9:08:20:E4:DC:08:20:71:05:07:00:95:A8:06:00:41:B9:04:00:A7:B8:08:20:6F:2A:0A:00:12:61:0E:20:2D:E9:FF:4F:72:B6:A0:49:08:68:40:1C:08:60:9F:48:80:47:90:B9:88:4C:A4:48:00:21:A0:47:48:B1:A2:48:01:21:A0:47:28:B1:A0:48:02:21:A0:47:00:28:40:F0"
    16:48:19.212 --
    16:48:19.212 Outgoing Dump:
    16:48:19.212 0000: 01 05 ff f5 00 be 08 20 f0 bd f8 04 10 00 1f 01 ....... ........
    16:48:19.212 0010: 80 02 99 30 78 bd f8 0c 20 29 50 70 78 df f8 90 ...0x... )Ppx...
    16:48:19.212 0020: b2 2a 52 4f 20 d8 47 df f8 8c a2 f1 78 a2 4f 68 .*RO .G.....x.Oh
    16:48:19.212 0030: 54 a0 1d c1 b2 50 46 b8 47 a0 49 40 46 88 47 02 T....PF.G.I@F.G.
    16:48:19.212 0040: 99 d8 47 4d 46 05 f1 5a 05 1c b9 9d 49 09 78 66 ..GMF..Z....I.xf
    16:48:19.212 0050: 1c 01 e0 66 1c f1 b2 4a 46 8a 32 50 54 48 46 86 ...f...JF.2PTHF.
    16:48:19.212 0060: 30 b8 47 41 46 50 46 b8 47 01 20 b0 40 28 80 a6 0.GAFPF.G. .@(..
    16:48:19.212 0070: 48 80 47 24 1d e4 b2 48 46 a1 4a 21 46 60 30 90 H.G$...HF.J!F`0.
    16:48:19.212 0080: 47 00 28 f8 d1 9f 4a 00 21 50 46 90 47 00 20 00 G.(...J.!PF.G. .
    16:48:19.212 0090: 90 85 f8 2c 00 bd e8 ff 8f 00 02 01 01 00 01 01 ...,............
    16:48:19.212 00a0: 20 3a 23 0c 20 cc 77 08 20 6f b9 08 20 e4 dc 08 :#. .w. o.. ...
    16:48:19.212 00b0: 20 71 05 07 00 95 a8 06 00 41 b9 04 00 a7 b8 08 q.......A......
    16:48:19.212 00c0: 20 6f 2a 0a 00 12 61 0e 20 2d e9 ff 4f 72 b6 a0 o*...a. -..Or..
    16:48:19.212 00d0: 49 08 68 40 1c 08 60 9f 48 80 47 90 b9 88 4c a4 I.h@..`.H.G...L.
    16:48:19.212 00e0: 48 00 21 a0 47 48 b1 a2 48 01 21 a0 47 28 b1 a0 H.!.GH..H.!.G(..
    16:48:19.212 00f0: 48 02 21 a0 47 00 28 40 f0 H.!.G.(@.
    16:48:19.243 Incoming Dump:
    16:48:19.243 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.243 --
    16:48:19.243 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.243 Parameters:
    16:48:19.243 | Number HCI commands : 0x01
    16:48:19.243 | Command Opcode : 0xff05
    16:48:19.243 | Status : 0x00 (Success)
    16:48:19.243 --
    16:48:19.243 --
    16:48:19.243 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.243 | Address : 0x2008bef0
    16:48:19.243 | Size : 0xf0
    16:48:19.243 | Values : "D0:80:9E:49:31:20:88:47:CB:E0:A3:48:34:30:DF:F8:64:81:01:90:A0:48:4F:F0:00:09:08:F1:10:08:40:30:02:90:97:48:DF:F8:4C:A2:03:90:28:25:0F:FA:89:F0:00:FB:05:F1:4F:48:12:30:00:EB:01:0B:91:4C:00:21:58:46:A0:47:95:49:C6:B2:05:20:88:47:00:21:58:46:A0:47:76:1C:C4:B2:96:FB:F5:F0:68:43:36:1A:B4:42:EC:D1:5F:FA:89:FB:8E:49:58:46:88:47:06:46:86:48:00:78:00:19:C4:B2:26:2C:04:D0:27:2C:02:D0:28:2C:01:DA:05:E0:2C:46:28:3C:76:1C:E4:B2:26:F0:7C:46:01:98:84:4A:00:68:31:46:90:47:02:46:00:2A:48:BF:52:42:4F:EA:C2:01:01:EB:42:11:02:9A:12:78:A4:EB:02:05:0D:44:49:46:05:F1:01:05:49:B1:49:1E:04:D0:49:1E:08:BF:B8:F8:4C:70:04:E0:B8:F8:24:70:01:E0:B8:F8:00:70:7D:20:68:43:40:F2:E2:41:07:EB:90:07:01:98:9A:F8:00:30:00:68:B7:FB:F1:F2:12:18:21:48"
    16:48:19.243 --
    16:48:19.243 Outgoing Dump:
    16:48:19.243 0000: 01 05 ff f5 f0 be 08 20 f0 d0 80 9e 49 31 20 88 ....... ....I1 .
    16:48:19.243 0010: 47 cb e0 a3 48 34 30 df f8 64 81 01 90 a0 48 4f G...H40..d....HO
    16:48:19.243 0020: f0 00 09 08 f1 10 08 40 30 02 90 97 48 df f8 4c .......@0...H..L
    16:48:19.243 0030: a2 03 90 28 25 0f fa 89 f0 00 fb 05 f1 4f 48 12 ...(%........OH.
    16:48:19.243 0040: 30 00 eb 01 0b 91 4c 00 21 58 46 a0 47 95 49 c6 0.....L.!XF.G.I.
    16:48:19.243 0050: b2 05 20 88 47 00 21 58 46 a0 47 76 1c c4 b2 96 .. .G.!XF.Gv....
    16:48:19.243 0060: fb f5 f0 68 43 36 1a b4 42 ec d1 5f fa 89 fb 8e ...hC6..B.._....
    16:48:19.243 0070: 49 58 46 88 47 06 46 86 48 00 78 00 19 c4 b2 26 IXF.G.F.H.x....&
    16:48:19.243 0080: 2c 04 d0 27 2c 02 d0 28 2c 01 da 05 e0 2c 46 28 ,..',..(,....,F(
    16:48:19.243 0090: 3c 76 1c e4 b2 26 f0 7c 46 01 98 84 4a 00 68 31 <v...&.|F...J.h1
    16:48:19.243 00a0: 46 90 47 02 46 00 2a 48 bf 52 42 4f ea c2 01 01 F.G.F.*H.RBO....
    16:48:19.243 00b0: eb 42 11 02 9a 12 78 a4 eb 02 05 0d 44 49 46 05 .B....x.....DIF.
    16:48:19.243 00c0: f1 01 05 49 b1 49 1e 04 d0 49 1e 08 bf b8 f8 4c ...I.I...I.....L
    16:48:19.243 00d0: 70 04 e0 b8 f8 24 70 01 e0 b8 f8 00 70 7d 20 68 p....$p.....p} h
    16:48:19.243 00e0: 43 40 f2 e2 41 07 eb 90 07 01 98 9a f8 00 30 00 C@..A.........0.
    16:48:19.243 00f0: 68 b7 fb f1 f2 12 18 21 48 h......!H
    16:48:19.275 Incoming Dump:
    16:48:19.275 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.275 --
    16:48:19.275 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.275 Parameters:
    16:48:19.275 | Number HCI commands : 0x01
    16:48:19.275 | Command Opcode : 0xff05
    16:48:19.275 | Status : 0x00 (Success)
    16:48:19.275 --
    16:48:19.275 --
    16:48:19.275 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.275 | Address : 0x2008bfe0
    16:48:19.275 | Size : 0xf0
    16:48:19.275 | Values : "22:F0:7C:42:C2:50:B7:FB:F1:F2:4A:43:B9:1A:9A:F8:01:20:81:52:9A:F8:02:10:46:50:03:98:5F:4B:00:68:00:22:21:46:98:47:2A:4A:28:48:59:46:90:47:01:20:00:FA:09:F0:A8:F8:5E:00:37:4A:53:48:59:46:90:47:00:28:F9:D0:56:49:28:46:88:47:56:4A:01:46:48:46:90:47:01:98:00:1D:01:90:02:98:09:F1:01:09:40:1C:02:90:03:98:B9:F1:03:0F:0A:F1:06:0A:00:F1:04:00:03:90:FF:F6:62:AF:2A:48:80:47:4F:48:80:47:30:B9:02:E0:C0:46:00:61:0E:20:40:49:2F:20:88:47:AE:48:80:47:45:4C:AD:4A:69:46:04:F1:50:00:90:47:AC:48:00:88:C0:09:05:D3:AB:4B:21:6D:BD:F8:00:20:CA:20:98:47:2D:49:09:68:49:1E:2B:48:01:60:00:D1:62:B6:00:90:BD:E8:FF:8F:C0:46:C3:BF:07:00:70:61:0E:20:ED:2B:08:00:F3:19:08:00:B9:9E:08:20:30:B5:9E:4C:4F:F4:86:70:A0:47:40:F2:21:10:A0:47:4F:F4:85:70"
    16:48:19.275 --
    16:48:19.275 Outgoing Dump:
    16:48:19.275 0000: 01 05 ff f5 e0 bf 08 20 f0 22 f0 7c 42 c2 50 b7 ....... .".|B.P.
    16:48:19.275 0010: fb f1 f2 4a 43 b9 1a 9a f8 01 20 81 52 9a f8 02 ...JC..... .R...
    16:48:19.275 0020: 10 46 50 03 98 5f 4b 00 68 00 22 21 46 98 47 2a .FP.._K.h."!F.G*
    16:48:19.275 0030: 4a 28 48 59 46 90 47 01 20 00 fa 09 f0 a8 f8 5e J(HYF.G. ......^
    16:48:19.275 0040: 00 37 4a 53 48 59 46 90 47 00 28 f9 d0 56 49 28 .7JSHYF.G.(..VI(
    16:48:19.275 0050: 46 88 47 56 4a 01 46 48 46 90 47 01 98 00 1d 01 F.GVJ.FHF.G.....
    16:48:19.275 0060: 90 02 98 09 f1 01 09 40 1c 02 90 03 98 b9 f1 03 .......@........
    16:48:19.275 0070: 0f 0a f1 06 0a 00 f1 04 00 03 90 ff f6 62 af 2a .............b.*
    16:48:19.275 0080: 48 80 47 4f 48 80 47 30 b9 02 e0 c0 46 00 61 0e H.GOH.G0....F.a.
    16:48:19.275 0090: 20 40 49 2f 20 88 47 ae 48 80 47 45 4c ad 4a 69 @I/ .G.H.GEL.Ji
    16:48:19.275 00a0: 46 04 f1 50 00 90 47 ac 48 00 88 c0 09 05 d3 ab F..P..G.H.......
    16:48:19.275 00b0: 4b 21 6d bd f8 00 20 ca 20 98 47 2d 49 09 68 49 K!m... . .G-I.hI
    16:48:19.275 00c0: 1e 2b 48 01 60 00 d1 62 b6 00 90 bd e8 ff 8f c0 .+H.`..b........
    16:48:19.275 00d0: 46 c3 bf 07 00 70 61 0e 20 ed 2b 08 00 f3 19 08 F....pa. .+.....
    16:48:19.275 00e0: 00 b9 9e 08 20 30 b5 9e 4c 4f f4 86 70 a0 47 40 .... 0..LO..p.G@
    16:48:19.275 00f0: f2 21 10 a0 47 4f f4 85 70 .!..GO..p
    16:48:19.306 Incoming Dump:
    16:48:19.306 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.306 --
    16:48:19.306 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.306 Parameters:
    16:48:19.306 | Number HCI commands : 0x01
    16:48:19.306 | Command Opcode : 0xff05
    16:48:19.306 | Status : 0x00 (Success)
    16:48:19.306 --
    16:48:19.306 --
    16:48:19.306 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.306 | Address : 0x2008c0d0
    16:48:19.306 | Size : 0xf0
    16:48:19.306 | Values : "A0:47:4F:F4:90:70:A0:47:98:4D:99:4C:95:F8:58:01:81:08:03:D2:0A:20:A0:47:95:F8:58:01:40:08:01:D2:09:20:A0:47:30:BD:C0:46:61:2D:08:00:DD:2A:08:00:11:76:06:00:AD:48:00:78:E0:B1:AD:49:4F:F4:00:50:48:86:88:7C:40:1C:88:74:91:F8:E6:00:40:1C:81:F8:E6:00:A5:49:4F:F4:00:70:08:80:A6:48:01:78:FF:29:08:D0:01:20:A4:4A:88:40:11:68:01:43:11:60:11:68:81:43:11:60:70:47:C0:46:9C:84:08:20:F5:C0:07:00:10:B5:AE:4C:E0:78:10:B1:79:49:16:20:88:47:04:20:20:70:10:BD:70:2A:0A:00:72:61:0E:20:FB:C7:07:00:84:2A:0A:00:1B:2D:08:00:28:78:08:20:1F:2B:08:00:9D:05:1A:00:9F:BD:08:20:20:6E:08:20:8B:75:06:00:17:C3:07:00:01:C4:07:00:0B:C1:07:00:2D:E9:F8:41:82:69:9B:4D:12:B1:4F:F0:01:00:28:70:99:4C:9A:48:B4:F8:7C:10:08:3D:C9:0B:80:F0:89:80:80:46:98:F8"
    16:48:19.306 --
    16:48:19.306 Outgoing Dump:
    16:48:19.306 0000: 01 05 ff f5 d0 c0 08 20 f0 a0 47 4f f4 90 70 a0 ....... ..GO..p.
    16:48:19.306 0010: 47 98 4d 99 4c 95 f8 58 01 81 08 03 d2 0a 20 a0 G.M.L..X...... .
    16:48:19.306 0020: 47 95 f8 58 01 40 08 01 d2 09 20 a0 47 30 bd c0 G..X.@.... .G0..
    16:48:19.306 0030: 46 61 2d 08 00 dd 2a 08 00 11 76 06 00 ad 48 00 Fa-...*...v...H.
    16:48:19.306 0040: 78 e0 b1 ad 49 4f f4 00 50 48 86 88 7c 40 1c 88 x...IO..PH..|@..
    16:48:19.306 0050: 74 91 f8 e6 00 40 1c 81 f8 e6 00 a5 49 4f f4 00 t....@......IO..
    16:48:19.306 0060: 70 08 80 a6 48 01 78 ff 29 08 d0 01 20 a4 4a 88 p...H.x.)... .J.
    16:48:19.306 0070: 40 11 68 01 43 11 60 11 68 81 43 11 60 70 47 c0 @.h.C.`.h.C.`pG.
    16:48:19.306 0080: 46 9c 84 08 20 f5 c0 07 00 10 b5 ae 4c e0 78 10 F... .......L.x.
    16:48:19.306 0090: b1 79 49 16 20 88 47 04 20 20 70 10 bd 70 2a 0a .yI. .G. p..p*.
    16:48:19.306 00a0: 00 72 61 0e 20 fb c7 07 00 84 2a 0a 00 1b 2d 08 .ra. .....*...-.
    16:48:19.306 00b0: 00 28 78 08 20 1f 2b 08 00 9d 05 1a 00 9f bd 08 .(x. .+.........
    16:48:19.306 00c0: 20 20 6e 08 20 8b 75 06 00 17 c3 07 00 01 c4 07 n. .u.........
    16:48:19.306 00d0: 00 0b c1 07 00 2d e9 f8 41 82 69 9b 4d 12 b1 4f .....-..A.i.M..O
    16:48:19.306 00e0: f0 01 00 28 70 99 4c 9a 48 b4 f8 7c 10 08 3d c9 ...(p.L.H..|..=.
    16:48:19.306 00f0: 0b 80 f0 89 80 80 46 98 f8 ......F..
    16:48:19.352 Incoming Dump:
    16:48:19.352 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.352 --
    16:48:19.352 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.352 Parameters:
    16:48:19.352 | Number HCI commands : 0x01
    16:48:19.352 | Command Opcode : 0xff05
    16:48:19.352 | Status : 0x00 (Success)
    16:48:19.352 --
    16:48:19.352 --
    16:48:19.352 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.352 | Address : 0x2008c1c0
    16:48:19.352 | Size : 0xf0
    16:48:19.352 | Values : "02:00:01:46:1A:B1:98:F8:00:20:91:42:03:D1:2A:7A:01:2A:40:F0:85:80:05:F1:7C:06:DF:F8:98:C2:06:EB:C1:02:13:68:0C:F1:70:01:52:68:0B:60:4A:60:06:EB:C0:03:03:F1:10:02:17:68:0C:F1:78:01:0F:60:52:68:4A:60:9B:49:91:F9:00:10:67:46:11:F1:14:0F:09:DB:11:F1:13:0F:14:DD:93:F9:07:10:87:F8:77:10:93:F9:17:10:0B:E0:97:F9:77:10:12:29:C4:BF:12:21:87:F8:77:10:97:F9:7F:10:12:29:02:DD:12:21:87:F8:7F:10:06:EB:C0:00:90:F9:17:10:DF:F8:8C:C2:90:F9:07:30:97:F9:7F:20:00:91:97:F9:77:10:40:F2:93:10:E0:47:E8:7B:30:BB:97:F9:67:00:12:28:C4:BF:12:20:87:F8:67:00:A5:48:90:F9:18:10:12:29:C4:BF:12:21:01:76:90:F9:10:10:12:29:C4:BF:12:21:01:74:97:F9:5F:10:1E:29:A4:BF:1D:21:87:F8:5F:10:90:F9:08:10:1E:29:A4:BF:1D:21:01:72:90:F9:00:10:1E:29:A4:BF:1D:21"
    16:48:19.352 --
    16:48:19.352 Outgoing Dump:
    16:48:19.352 0000: 01 05 ff f5 c0 c1 08 20 f0 02 00 01 46 1a b1 98 ....... ....F...
    16:48:19.352 0010: f8 00 20 91 42 03 d1 2a 7a 01 2a 40 f0 85 80 05 .. .B..*z.*@....
    16:48:19.352 0020: f1 7c 06 df f8 98 c2 06 eb c1 02 13 68 0c f1 70 .|..........h..p
    16:48:19.352 0030: 01 52 68 0b 60 4a 60 06 eb c0 03 03 f1 10 02 17 .Rh.`J`.........
    16:48:19.352 0040: 68 0c f1 78 01 0f 60 52 68 4a 60 9b 49 91 f9 00 h..x..`RhJ`.I...
    16:48:19.352 0050: 10 67 46 11 f1 14 0f 09 db 11 f1 13 0f 14 dd 93 .gF.............
    16:48:19.352 0060: f9 07 10 87 f8 77 10 93 f9 17 10 0b e0 97 f9 77 .....w.........w
    16:48:19.352 0070: 10 12 29 c4 bf 12 21 87 f8 77 10 97 f9 7f 10 12 ..)...!..w......
    16:48:19.352 0080: 29 02 dd 12 21 87 f8 7f 10 06 eb c0 00 90 f9 17 )...!...........
    16:48:19.353 0090: 10 df f8 8c c2 90 f9 07 30 97 f9 7f 20 00 91 97 ........0... ...
    16:48:19.353 00a0: f9 77 10 40 f2 93 10 e0 47 e8 7b 30 bb 97 f9 67 .w.@....G.{0...g
    16:48:19.353 00b0: 00 12 28 c4 bf 12 20 87 f8 67 00 a5 48 90 f9 18 ..(... ..g..H...
    16:48:19.353 00c0: 10 12 29 c4 bf 12 21 01 76 90 f9 10 10 12 29 c4 ..)...!.v.....).
    16:48:19.353 00d0: bf 12 21 01 74 97 f9 5f 10 1e 29 a4 bf 1d 21 87 ..!.t.._..)...!.
    16:48:19.353 00e0: f8 5f 10 90 f9 08 10 1e 29 a4 bf 1d 21 01 72 90 ._......)...!.r.
    16:48:19.353 00f0: f9 00 10 1e 29 a4 bf 1d 21 ....)...!
    16:48:19.372 Incoming Dump:
    16:48:19.372 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.372 --
    16:48:19.372 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.372 Parameters:
    16:48:19.372 | Number HCI commands : 0x01
    16:48:19.372 | Command Opcode : 0xff05
    16:48:19.372 | Status : 0x00 (Success)
    16:48:19.372 --
    16:48:19.372 --
    16:48:19.372 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.372 | Address : 0x2008c2b0
    16:48:19.372 | Size : 0xf0
    16:48:19.372 | Values : "01:70:98:F8:02:00:95:4A:06:EB:40:06:96:F8:20:10:82:F8:41:11:96:F8:24:10:82:F8:42:11:01:E0:80:1C:00:78:29:7A:01:29:03:D1:00:21:29:72:8C:49:88:47:E0:7A:20:18:90:F8:4D:10:01:20:00:FA:01:F2:61:68:0A:42:14:D0:E1:7A:84:F8:7E:00:61:18:91:F8:4D:10:88:40:21:68:08:42:0C:BF:82:49:83:49:16:20:88:47:82:4C:0F:20:A0:47:16:20:A0:47:BD:E8:F8:81:00:20:84:F8:7E:00:BD:E8:F8:81:DD:AF:08:00:D1:C2:07:00:74:77:08:20:B3:C6:07:00:85:1B:06:00:70:A3:08:20:71:05:07:00:70:B5:77:4E:05:46:02:20:B0:47:74:4C:84:F8:22:00:03:20:B0:47:73:4A:74:4B:94:F9:22:10:84:F8:27:00:00:20:32:29:D8:BF:01:20:70:49:09:88:21:F0:01:01:08:43:D0:52:94:F8:3B:00:01:28:14:D1:6C:48:00:78:58:B9:94:F9:22:00:00:28:07:DD:32:28:05:DA:10:88:20:F0:7F:00:40:F0:17:00:04:E0:10:88"
    16:48:19.372 --
    16:48:19.372 Outgoing Dump:
    16:48:19.372 0000: 01 05 ff f5 b0 c2 08 20 f0 01 70 98 f8 02 00 95 ....... ..p.....
    16:48:19.372 0010: 4a 06 eb 40 06 96 f8 20 10 82 f8 41 11 96 f8 24 J..@... ...A...$
    16:48:19.372 0020: 10 82 f8 42 11 01 e0 80 1c 00 78 29 7a 01 29 03 ...B......x)z.).
    16:48:19.372 0030: d1 00 21 29 72 8c 49 88 47 e0 7a 20 18 90 f8 4d ..!)r.I.G.z ...M
    16:48:19.372 0040: 10 01 20 00 fa 01 f2 61 68 0a 42 14 d0 e1 7a 84 .. ....ah.B...z.
    16:48:19.372 0050: f8 7e 00 61 18 91 f8 4d 10 88 40 21 68 08 42 0c .~.a...M..@!h.B.
    16:48:19.372 0060: bf 82 49 83 49 16 20 88 47 82 4c 0f 20 a0 47 16 ..I.I. .G.L. .G.
    16:48:19.372 0070: 20 a0 47 bd e8 f8 81 00 20 84 f8 7e 00 bd e8 f8 .G..... ..~....
    16:48:19.372 0080: 81 dd af 08 00 d1 c2 07 00 74 77 08 20 b3 c6 07 .........tw. ...
    16:48:19.372 0090: 00 85 1b 06 00 70 a3 08 20 71 05 07 00 70 b5 77 .....p.. q...p.w
    16:48:19.372 00a0: 4e 05 46 02 20 b0 47 74 4c 84 f8 22 00 03 20 b0 N.F. .GtL..".. .
    16:48:19.372 00b0: 47 73 4a 74 4b 94 f9 22 10 84 f8 27 00 00 20 32 GsJtK.."...'.. 2
    16:48:19.372 00c0: 29 d8 bf 01 20 70 49 09 88 21 f0 01 01 08 43 d0 )... pI..!....C.
    16:48:19.372 00d0: 52 94 f8 3b 00 01 28 14 d1 6c 48 00 78 58 b9 94 R..;..(..lH.xX..
    16:48:19.372 00e0: f9 22 00 00 28 07 dd 32 28 05 da 10 88 20 f0 7f ."..(..2(.... ..
    16:48:19.372 00f0: 00 40 f0 17 00 04 e0 10 88 .@.......
    16:48:19.404 Incoming Dump:
    16:48:19.404 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.404 --
    16:48:19.404 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.404 Parameters:
    16:48:19.404 | Number HCI commands : 0x01
    16:48:19.404 | Command Opcode : 0xff05
    16:48:19.404 | Status : 0x00 (Success)
    16:48:19.404 --
    16:48:19.404 --
    16:48:19.404 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.404 | Address : 0x2008c3a0
    16:48:19.404 | Size : 0xf0
    16:48:19.404 | Values : "20:F0:7F:00:40:F0:1C:00:10:80:22:34:62:48:2C:61:66:30:68:63:70:BD:C0:46:8C:E8:0C:20:A6:7E:08:20:C0:F0:0C:20:90:77:08:20:04:F0:0E:20:10:B5:04:46:5A:49:20:7D:88:47:01:46:56:48:10:30:02:78:A1:60:02:F0:3F:00:D2:09:2C:BF:08:44:08:1A:4D:49:4E:31:61:63:4F:F4:7A:71:48:43:4F:F4:7F:71:B0:FB:F1:F1:40:F2:99:10:40:1A:00:B2:A0:61:10:BD:B3:76:08:20:D4:DC:08:20:38:76:08:20:CA:B7:08:20:00:B5:4C:49:02:7F:08:78:10:B3:48:78:20:B1:48:49:40:20:08:80:08:83:C8:83:42:48:00:68:00:0A:17:D3:B2:B1:41:48:0C:49:00:68:C0:09:07:D2:B1:F8:C8:20:4F:F6:FD:70:10:40:A1:F8:C8:00:00:BD:B1:F8:C8:00:40:F0:02:00:A1:F8:C8:00:38:49:40:F2:77:20:88:47:00:BD:C0:46:7E:7C:08:20:00:01:01:20:10:B5:41:69:01:29:2A:D1:00:69:38:4A:80:79:4F:F0:B4:01:01:FB:00:23:31:4A"
    16:48:19.404 --
    16:48:19.404 Outgoing Dump:
    16:48:19.404 0000: 01 05 ff f5 a0 c3 08 20 f0 20 f0 7f 00 40 f0 1c ....... . ...@..
    16:48:19.404 0010: 00 10 80 22 34 62 48 2c 61 66 30 68 63 70 bd c0 ..."4bH,af0hcp..
    16:48:19.404 0020: 46 8c e8 0c 20 a6 7e 08 20 c0 f0 0c 20 90 77 08 F... .~. ... .w.
    16:48:19.404 0030: 20 04 f0 0e 20 10 b5 04 46 5a 49 20 7d 88 47 01 ... ...FZI }.G.
    16:48:19.404 0040: 46 56 48 10 30 02 78 a1 60 02 f0 3f 00 d2 09 2c FVH.0.x.`..?...,
    16:48:19.404 0050: bf 08 44 08 1a 4d 49 4e 31 61 63 4f f4 7a 71 48 ..D..MIN1acO.zqH
    16:48:19.404 0060: 43 4f f4 7f 71 b0 fb f1 f1 40 f2 99 10 40 1a 00 CO..q....@...@..
    16:48:19.404 0070: b2 a0 61 10 bd b3 76 08 20 d4 dc 08 20 38 76 08 ..a...v. ... 8v.
    16:48:19.404 0080: 20 ca b7 08 20 00 b5 4c 49 02 7f 08 78 10 b3 48 ... ..LI...x..H
    16:48:19.404 0090: 78 20 b1 48 49 40 20 08 80 08 83 c8 83 42 48 00 x .HI@ ......BH.
    16:48:19.404 00a0: 68 00 0a 17 d3 b2 b1 41 48 0c 49 00 68 c0 09 07 h......AH.I.h...
    16:48:19.404 00b0: d2 b1 f8 c8 20 4f f6 fd 70 10 40 a1 f8 c8 00 00 .... O..p.@.....
    16:48:19.404 00c0: bd b1 f8 c8 00 40 f0 02 00 a1 f8 c8 00 38 49 40 .....@.......8I@
    16:48:19.404 00d0: f2 77 20 88 47 00 bd c0 46 7e 7c 08 20 00 01 01 .w .G...F~|. ...
    16:48:19.404 00e0: 20 10 b5 41 69 01 29 2a d1 00 69 38 4a 80 79 4f ..Ai.)*..i8J.yO
    16:48:19.404 00f0: f0 b4 01 01 fb 00 23 31 4a ......#1J
    16:48:19.435 Incoming Dump:
    16:48:19.435 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.435 --
    16:48:19.435 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.435 Parameters:
    16:48:19.435 | Number HCI commands : 0x01
    16:48:19.435 | Command Opcode : 0xff05
    16:48:19.435 | Status : 0x00 (Success)
    16:48:19.435 --
    16:48:19.435 --
    16:48:19.435 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.435 | Address : 0x2008c490
    16:48:19.435 | Size : 0xf0
    16:48:19.435 | Values : "93:F8:4F:00:4F:EA:80:01:01:EB:40:11:51:5A:6F:F3:0E:01:C1:B1:93:F8:8B:10:2B:4B:03:29:0E:D0:02:01:19:46:89:5C:01:29:14:BF:0E:24:0D:24:27:49:0A:89:09:88:91:43:01:22:A2:40:0A:42:04:D0:02:01:19:46:89:5C:23:4A:90:47:10:BD:E5:C5:07:00:23:49:91:F8:AA:30:01:2B:03:D1:91:F8:A9:20:92:09:05:D2:02:2B:08:D1:91:F8:A9:20:92:09:04:D3:01:61:1A:49:01:F5:A7:71:41:63:70:47:C0:46:67:B7:08:20:24:69:08:20:91:7F:04:00:DD:09:07:00:19:07:07:00:71:07:07:00:5C:7C:08:20:47:D6:06:00:00:24:0C:20:80:FE:FF:FF:80:22:0C:20:D1:77:08:20:C5:D6:06:00:FD:B8:08:20:FC:82:08:20:A8:F1:0C:20:C5:C7:07:00:00:E8:0C:20:A6:7E:08:20:50:95:08:20:88:7D:08:20:00:0E:0E:20:B3:9D:08:00:E0:95:08:20:49:31:01:00:F4:A1:08:20:2D:E9:F0:41:07:46:9A:4D:39:7D:97:4E:DF:F8:54:82"
    16:48:19.435 --
    16:48:19.435 Outgoing Dump:
    16:48:19.435 0000: 01 05 ff f5 90 c4 08 20 f0 93 f8 4f 00 4f ea 80 ....... ...O.O..
    16:48:19.435 0010: 01 01 eb 40 11 51 5a 6f f3 0e 01 c1 b1 93 f8 8b ...@.QZo........
    16:48:19.435 0020: 10 2b 4b 03 29 0e d0 02 01 19 46 89 5c 01 29 14 .+K.).....F.\.).
    16:48:19.435 0030: bf 0e 24 0d 24 27 49 0a 89 09 88 91 43 01 22 a2 ..$.$'I.....C.".
    16:48:19.435 0040: 40 0a 42 04 d0 02 01 19 46 89 5c 23 4a 90 47 10 @.B.....F.\#J.G.
    16:48:19.435 0050: bd e5 c5 07 00 23 49 91 f8 aa 30 01 2b 03 d1 91 .....#I...0.+...
    16:48:19.435 0060: f8 a9 20 92 09 05 d2 02 2b 08 d1 91 f8 a9 20 92 .. .....+..... .
    16:48:19.435 0070: 09 04 d3 01 61 1a 49 01 f5 a7 71 41 63 70 47 c0 ....a.I...qAcpG.
    16:48:19.435 0080: 46 67 b7 08 20 24 69 08 20 91 7f 04 00 dd 09 07 Fg.. $i. .......
    16:48:19.435 0090: 00 19 07 07 00 71 07 07 00 5c 7c 08 20 47 d6 06 .....q...\|. G..
    16:48:19.435 00a0: 00 00 24 0c 20 80 fe ff ff 80 22 0c 20 d1 77 08 ..$. .....". .w.
    16:48:19.435 00b0: 20 c5 d6 06 00 fd b8 08 20 fc 82 08 20 a8 f1 0c ....... ... ...
    16:48:19.435 00c0: 20 c5 c7 07 00 00 e8 0c 20 a6 7e 08 20 50 95 08 ....... .~. P..
    16:48:19.435 00d0: 20 88 7d 08 20 00 0e 0e 20 b3 9d 08 00 e0 95 08 .}. ... .......
    16:48:19.435 00e0: 20 49 31 01 00 f4 a1 08 20 2d e9 f0 41 07 46 9a I1..... -..A.F.
    16:48:19.435 00f0: 4d 39 7d 97 4e df f8 54 82 M9}.N..T.
    16:48:19.466 Incoming Dump:
    16:48:19.466 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.466 --
    16:48:19.466 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.466 Parameters:
    16:48:19.466 | Number HCI commands : 0x01
    16:48:19.466 | Command Opcode : 0xff05
    16:48:19.466 | Status : 0x00 (Success)
    16:48:19.466 --
    16:48:19.466 --
    16:48:19.466 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.466 | Address : 0x2008c580
    16:48:19.466 | Size : 0xf0
    16:48:19.466 | Values : "EA:7A:3C:69:4D:29:1C:DC:4C:29:80:F2:17:81:DF:F8:60:C2:DF:F8:60:E2:98:4B:98:4F:89:1F:00:F0:E6:80:90:4A:91:4C:C9:1E:01:29:40:F2:BE:80:8B:4E:0B:39:00:F0:9B:80:32:39:00:F0:8A:80:49:1F:7E:D0:BD:E8:F0:81:71:39:4D:D0:0A:39:28:D0:81:4C:87:4A:3D:39:14:D0:49:1E:40:F0:F9:80:A4:1C:20:79:00:28:00:F0:F4:80:01:20:90:47:00:28:00:F0:EF:80:60:78:FF:28:40:F0:EB:80:00:21:21:70:BD:E8:F0:81:A0:79:00:28:00:F0:E3:80:01:20:90:47:00:28:00:F0:DE:80:60:78:FF:28:40:F0:DA:80:00:21:20:46:20:E0:21:78:60:1D:03:29:14:D0:01:29:40:F0:D0:80:8C:48:00:78:0B:28:40:F0:CB:80:8A:49:48:F2:4F:10:88:47:00:28:00:F0:C4:80:88:49:48:F2:4F:10:88:47:BD:E8:F0:81:90:F9:00:10:11:F1:37:0F:40:F3:B8:80:6F:F0:36:01:04:46:C9:E7:20:78:C0:47:94:F8:E8:11:98:48:02:29:0F:D1"
    16:48:19.466 --
    16:48:19.466 Outgoing Dump:
    16:48:19.466 0000: 01 05 ff f5 80 c5 08 20 f0 ea 7a 3c 69 4d 29 1c ....... ..z<iM).
    16:48:19.466 0010: dc 4c 29 80 f2 17 81 df f8 60 c2 df f8 60 e2 98 .L)......`...`..
    16:48:19.466 0020: 4b 98 4f 89 1f 00 f0 e6 80 90 4a 91 4c c9 1e 01 K.O.......J.L...
    16:48:19.466 0030: 29 40 f2 be 80 8b 4e 0b 39 00 f0 9b 80 32 39 00 )@....N.9....29.
    16:48:19.466 0040: f0 8a 80 49 1f 7e d0 bd e8 f0 81 71 39 4d d0 0a ...I.~.....q9M..
    16:48:19.466 0050: 39 28 d0 81 4c 87 4a 3d 39 14 d0 49 1e 40 f0 f9 9(..L.J=9..I.@..
    16:48:19.466 0060: 80 a4 1c 20 79 00 28 00 f0 f4 80 01 20 90 47 00 ... y.(..... .G.
    16:48:19.466 0070: 28 00 f0 ef 80 60 78 ff 28 40 f0 eb 80 00 21 21 (....`x.(@....!!
    16:48:19.466 0080: 70 bd e8 f0 81 a0 79 00 28 00 f0 e3 80 01 20 90 p.....y.(..... .
    16:48:19.466 0090: 47 00 28 00 f0 de 80 60 78 ff 28 40 f0 da 80 00 G.(....`x.(@....
    16:48:19.466 00a0: 21 20 46 20 e0 21 78 60 1d 03 29 14 d0 01 29 40 ! F .!x`..)...)@
    16:48:19.466 00b0: f0 d0 80 8c 48 00 78 0b 28 40 f0 cb 80 8a 49 48 ....H.x.(@....IH
    16:48:19.466 00c0: f2 4f 10 88 47 00 28 00 f0 c4 80 88 49 48 f2 4f .O..G.(.....IH.O
    16:48:19.466 00d0: 10 88 47 bd e8 f0 81 90 f9 00 10 11 f1 37 0f 40 ..G..........7.@
    16:48:19.466 00e0: f3 b8 80 6f f0 36 01 04 46 c9 e7 20 78 c0 47 94 ...o.6..F.. x.G.
    16:48:19.466 00f0: f8 e8 11 98 48 02 29 0f d1 ....H.)..
    16:48:19.497 Incoming Dump:
    16:48:19.497 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.497 --
    16:48:19.497 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.497 Parameters:
    16:48:19.497 | Number HCI commands : 0x01
    16:48:19.497 | Command Opcode : 0xff05
    16:48:19.497 | Status : 0x00 (Success)
    16:48:19.497 --
    16:48:19.497 --
    16:48:19.497 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.497 | Address : 0x2008c670
    16:48:19.497 | Size : 0xf0
    16:48:19.497 | Values : "94:F8:D5:11:29:B1:94:F8:C1:11:01:29:14:D1:A9:30:00:E0:AA:30:21:78:B4:22:4A:43:01:21:81:54:0B:E0:22:78:B4:21:00:23:01:FB:02:02:82:F8:AA:30:22:78:01:FB:02:00:80:F8:A9:30:20:78:B0:47:00:20:B8:61:85:48:00:F2:EC:70:78:63:BD:E8:F0:81:30:78:00:28:7C:D1:00:20:82:4B:05:21:02:46:98:47:76:E0:81:48:00:78:03:28:79:D1:0A:20:A8:61:68:61:17:20:90:47:00:20:A0:47:E8:61:BD:E8:F0:81:30:46:40:1C:00:68:71:46:C0:0A:81:F8:71:00:91:F8:E6:00:40:1C:81:F8:E6:00:61:46:4F:F4:00:70:09:78:38:80:FF:29:07:D0:01:20:88:40:19:68:01:43:19:60:19:68:81:43:19:60:0C:20:90:47:BD:E8:F0:81:9B:48:00:78:20:B1:1E:20:68:61:A8:61:17:20:90:47:00:20:A0:47:94:4F:E8:61:00:25:17:F8:B4:0F:01:28:0B:D0:94:48:01:24:00:78:04:FA:05:F1:01:42:04:D0:E8:B2:C0:47:3C:70:E8:B2"
    16:48:19.497 --
    16:48:19.497 Outgoing Dump:
    16:48:19.497 0000: 01 05 ff f5 70 c6 08 20 f0 94 f8 d5 11 29 b1 94 ....p.. .....)..
    16:48:19.497 0010: f8 c1 11 01 29 14 d1 a9 30 00 e0 aa 30 21 78 b4 ....)...0...0!x.
    16:48:19.497 0020: 22 4a 43 01 21 81 54 0b e0 22 78 b4 21 00 23 01 "JC.!.T.."x.!.#.
    16:48:19.497 0030: fb 02 02 82 f8 aa 30 22 78 01 fb 02 00 80 f8 a9 ......0"x.......
    16:48:19.497 0040: 30 20 78 b0 47 00 20 b8 61 85 48 00 f2 ec 70 78 0 x.G. .a.H...px
    16:48:19.497 0050: 63 bd e8 f0 81 30 78 00 28 7c d1 00 20 82 4b 05 c....0x.(|.. .K.
    16:48:19.497 0060: 21 02 46 98 47 76 e0 81 48 00 78 03 28 79 d1 0a !.F.Gv..H.x.(y..
    16:48:19.497 0070: 20 a8 61 68 61 17 20 90 47 00 20 a0 47 e8 61 bd .aha. .G. .G.a.
    16:48:19.497 0080: e8 f0 81 30 46 40 1c 00 68 71 46 c0 0a 81 f8 71 ...0F@..hqF....q
    16:48:19.497 0090: 00 91 f8 e6 00 40 1c 81 f8 e6 00 61 46 4f f4 00 .....@.....aFO..
    16:48:19.497 00a0: 70 09 78 38 80 ff 29 07 d0 01 20 88 40 19 68 01 p.x8..)... .@.h.
    16:48:19.497 00b0: 43 19 60 19 68 81 43 19 60 0c 20 90 47 bd e8 f0 C.`.h.C.`. .G...
    16:48:19.497 00c0: 81 9b 48 00 78 20 b1 1e 20 68 61 a8 61 17 20 90 ..H.x .. ha.a. .
    16:48:19.497 00d0: 47 00 20 a0 47 94 4f e8 61 00 25 17 f8 b4 0f 01 G. .G.O.a.%.....
    16:48:19.497 00e0: 28 0b d0 94 48 01 24 00 78 04 fa 05 f1 01 42 04 (...H.$.x.....B.
    16:48:19.497 00f0: d0 e8 b2 c0 47 3c 70 e8 b2 ....G<p..
    16:48:19.529 Incoming Dump:
    16:48:19.529 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.529 --
    16:48:19.529 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.529 Parameters:
    16:48:19.529 | Number HCI commands : 0x01
    16:48:19.529 | Command Opcode : 0xff05
    16:48:19.529 | Status : 0x00 (Success)
    16:48:19.529 --
    16:48:19.529 --
    16:48:19.529 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.529 | Address : 0x2008c760
    16:48:19.529 | Size : 0xf0
    16:48:19.529 | Values : "B0:47:6D:1C:07:2D:EC:D3:BD:E8:F0:81:21:78:01:20:00:FA:01:F1:0A:42:28:D0:8A:43:EA:72:25:D1:71:46:01:F1:30:04:22:68:22:F0:20:02:22:60:8A:7C:52:1C:8A:74:91:F8:E6:20:52:1C:81:F8:E6:20:4F:F4:00:71:39:80:61:46:09:78:FF:29:0F:D0:88:40:19:68:01:43:19:60:19:68:81:43:19:60:BD:E8:F0:81:00:24:75:49:E0:B2:88:47:64:1C:07:2C:F9:D3:BD:E8:F0:81:C0:46:A0:7E:08:20:39:F5:01:00:75:F7:01:00:9F:A2:08:20:CC:DC:08:20:71:07:07:00:81:9F:08:00:93:E4:06:00:90:77:08:20:C0:F0:0C:20:04:F0:0E:20:8C:E8:0C:20:70:B5:C0:69:8B:49:00:F1:0C:05:8B:4C:C0:68:81:42:10:D1:21:46:91:F8:74:00:60:B9:20:46:C0:6C:40:0E:08:D2:88:48:02:68:88:48:88:4E:03:68:40:F2:C5:21:02:20:B0:47:29:68:81:48:88:42:0E:D1:80:48:01:68:01:F1:01:01:01:60:21:46:91:F8:74:20:2A:B9:C9:6C"
    16:48:19.529 --
    16:48:19.529 Outgoing Dump:
    16:48:19.529 0000: 01 05 ff f5 60 c7 08 20 f0 b0 47 6d 1c 07 2d ec ....`.. ..Gm..-.
    16:48:19.529 0010: d3 bd e8 f0 81 21 78 01 20 00 fa 01 f1 0a 42 28 .....!x. .....B(
    16:48:19.529 0020: d0 8a 43 ea 72 25 d1 71 46 01 f1 30 04 22 68 22 ..C.r%.qF..0."h"
    16:48:19.529 0030: f0 20 02 22 60 8a 7c 52 1c 8a 74 91 f8 e6 20 52 . ."`.|R..t... R
    16:48:19.529 0040: 1c 81 f8 e6 20 4f f4 00 71 39 80 61 46 09 78 ff .... O..q9.aF.x.
    16:48:19.529 0050: 29 0f d0 88 40 19 68 01 43 19 60 19 68 81 43 19 )...@.h.C.`.h.C.
    16:48:19.529 0060: 60 bd e8 f0 81 00 24 75 49 e0 b2 88 47 64 1c 07 `.....$uI...Gd..
    16:48:19.529 0070: 2c f9 d3 bd e8 f0 81 c0 46 a0 7e 08 20 39 f5 01 ,.......F.~. 9..
    16:48:19.529 0080: 00 75 f7 01 00 9f a2 08 20 cc dc 08 20 71 07 07 .u...... ... q..
    16:48:19.529 0090: 00 81 9f 08 00 93 e4 06 00 90 77 08 20 c0 f0 0c ..........w. ...
    16:48:19.529 00a0: 20 04 f0 0e 20 8c e8 0c 20 70 b5 c0 69 8b 49 00 ... ... p..i.I.
    16:48:19.529 00b0: f1 0c 05 8b 4c c0 68 81 42 10 d1 21 46 91 f8 74 ....L.h.B..!F..t
    16:48:19.529 00c0: 00 60 b9 20 46 c0 6c 40 0e 08 d2 88 48 02 68 88 .`. F.l@....H.h.
    16:48:19.529 00d0: 48 88 4e 03 68 40 f2 c5 21 02 20 b0 47 29 68 81 H.N.h@..!. .G)h.
    16:48:19.529 00e0: 48 88 42 0e d1 80 48 01 68 01 f1 01 01 01 60 21 H.B...H.h.....`!
    16:48:19.529 00f0: 46 91 f8 74 20 2a b9 c9 6c F..t *..l
    16:48:19.576 Incoming Dump:
    16:48:19.576 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.576 --
    16:48:19.576 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.576 Parameters:
    16:48:19.576 | Number HCI commands : 0x01
    16:48:19.576 | Command Opcode : 0xff05
    16:48:19.576 | Status : 0x00 (Success)
    16:48:19.576 --
    16:48:19.576 --
    16:48:19.576 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.576 | Address : 0x2008c850
    16:48:19.576 | Size : 0xf0
    16:48:19.576 | Values : "49:0E:02:D3:41:68:49:1C:41:60:70:BD:05:A5:08:20:2D:1C:06:00:85:1B:06:00:F0:B5:73:4C:94:F8:42:10:06:46:48:01:A0:EB:81:00:8C:49:05:19:00:19:98:30:02:69:94:35:91:42:11:D1:02:78:B4:20:50:43:88:4A:17:5C:28:46:88:47:00:21:04:2F:08:BF:01:21:30:60:86:48:84:F8:75:10:00:F5:48:70:70:63:69:69:81:48:88:42:07:D1:80:48:00:78:02:28:03:D1:60:48:00:21:46:38:01:70:F0:BD:C0:46:55:76:03:00:E0:95:08:20:A9:0F:1A:00:87:94:08:20:10:B5:57:49:59:4B:91:F8:42:00:FF:28:10:D0:42:01:A2:EB:80:02:88:18:95:30:42:78:05:2A:08:D1:00:78:00:01:1A:58:88:6E:90:42:04:BF:00:20:81:F8:5E:00:70:48:00:F1:20:02:14:68:40:68:04:42:04:D0:50:79:FF:28:06:D1:00:20:03:E0:00:20:82:F8:5E:00:50:79:90:71:63:48:98:38:90:F8:BF:2A:FF:2A:04:BF:00:22:80:F8:BE:2A:90:F8:12:21"
    16:48:19.576 --
    16:48:19.576 Outgoing Dump:
    16:48:19.576 0000: 01 05 ff f5 50 c8 08 20 f0 49 0e 02 d3 41 68 49 ....P.. .I...AhI
    16:48:19.576 0010: 1c 41 60 70 bd 05 a5 08 20 2d 1c 06 00 85 1b 06 .A`p.... -......
    16:48:19.576 0020: 00 f0 b5 73 4c 94 f8 42 10 06 46 48 01 a0 eb 81 ...sL..B..FH....
    16:48:19.576 0030: 00 8c 49 05 19 00 19 98 30 02 69 94 35 91 42 11 ..I.....0.i.5.B.
    16:48:19.576 0040: d1 02 78 b4 20 50 43 88 4a 17 5c 28 46 88 47 00 ..x. PC.J.\(F.G.
    16:48:19.576 0050: 21 04 2f 08 bf 01 21 30 60 86 48 84 f8 75 10 00 !./...!0`.H..u..
    16:48:19.576 0060: f5 48 70 70 63 69 69 81 48 88 42 07 d1 80 48 00 .Hppcii.H.B...H.
    16:48:19.576 0070: 78 02 28 03 d1 60 48 00 21 46 38 01 70 f0 bd c0 x.(..`H.!F8.p...
    16:48:19.576 0080: 46 55 76 03 00 e0 95 08 20 a9 0f 1a 00 87 94 08 FUv..... .......
    16:48:19.576 0090: 20 10 b5 57 49 59 4b 91 f8 42 00 ff 28 10 d0 42 ..WIYK..B..(..B
    16:48:19.576 00a0: 01 a2 eb 80 02 88 18 95 30 42 78 05 2a 08 d1 00 ........0Bx.*...
    16:48:19.576 00b0: 78 00 01 1a 58 88 6e 90 42 04 bf 00 20 81 f8 5e x...X.n.B... ..^
    16:48:19.576 00c0: 00 70 48 00 f1 20 02 14 68 40 68 04 42 04 d0 50 .pH.. ..h@h.B..P
    16:48:19.576 00d0: 79 ff 28 06 d1 00 20 03 e0 00 20 82 f8 5e 00 50 y.(... ... ..^.P
    16:48:19.576 00e0: 79 90 71 63 48 98 38 90 f8 bf 2a ff 2a 04 bf 00 y.qcH.8...*.*...
    16:48:19.576 00f0: 22 80 f8 be 2a 90 f8 12 21 "...*...!
    16:48:19.607 Incoming Dump:
    16:48:19.607 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.607 --
    16:48:19.607 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.607 Parameters:
    16:48:19.607 | Number HCI commands : 0x01
    16:48:19.607 | Command Opcode : 0xff05
    16:48:19.607 | Status : 0x00 (Success)
    16:48:19.607 --
    16:48:19.607 --
    16:48:19.607 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.607 | Address : 0x2008c940
    16:48:19.607 | Size : 0xf0
    16:48:19.607 | Values : "FF:2A:04:BF:00:22:80:F8:11:21:18:68:5E:4A:10:60:5B:48:49:6E:02:68:52:1C:02:60:02:69:09:0B:11:D3:41:69:49:1C:82:68:41:61:41:68:49:1C:41:60:8A:42:38:BF:81:60:53:49:09:88:09:0B:07:D3:C1:68:49:1C:C1:60:10:BD:00:21:52:1C:41:60:02:61:10:BD:C0:46:D6:95:08:20:1B:00:02:00:65:A3:08:20:A8:7E:08:20:70:B5:05:46:29:7D:2A:69:EC:69:08:39:27:D0:0B:39:1F:D0:6C:39:3D:D1:94:F8:7C:01:0D:28:39:D1:11:78:43:4A:20:46:90:47:01:46:00:29:32:D0:08:68:84:42:2F:D1:40:48:00:78:01:28:2B:D0:08:79:00:28:28:D0:01:20:3D:4C:3F:4A:20:70:4D:20:90:47:00:20:20:70:70:BD:E0:8A:10:B9:4F:F0:03:00:E0:82:70:BD:94:F8:78:01:4F:F0:01:01:10:B9:E0:78:10:B9:02:E0:E0:78:00:B9:00:21:2A:4E:C4:F8:7C:21:01:20:38:3E:2F:4A:70:72:20:46:90:47:00:20:70:72:2D:48:00:F5:44:70"
    16:48:19.607 --
    16:48:19.607 Outgoing Dump:
    16:48:19.607 0000: 01 05 ff f5 40 c9 08 20 f0 ff 2a 04 bf 00 22 80 ....@.. ..*...".
    16:48:19.607 0010: f8 11 21 18 68 5e 4a 10 60 5b 48 49 6e 02 68 52 ..!.h^J.`[HIn.hR
    16:48:19.607 0020: 1c 02 60 02 69 09 0b 11 d3 41 69 49 1c 82 68 41 ..`.i....AiI..hA
    16:48:19.607 0030: 61 41 68 49 1c 41 60 8a 42 38 bf 81 60 53 49 09 aAhI.A`.B8..`SI.
    16:48:19.607 0040: 88 09 0b 07 d3 c1 68 49 1c c1 60 10 bd 00 21 52 ......hI..`...!R
    16:48:19.607 0050: 1c 41 60 02 61 10 bd c0 46 d6 95 08 20 1b 00 02 .A`.a...F... ...
    16:48:19.607 0060: 00 65 a3 08 20 a8 7e 08 20 70 b5 05 46 29 7d 2a .e.. .~. p..F)}*
    16:48:19.607 0070: 69 ec 69 08 39 27 d0 0b 39 1f d0 6c 39 3d d1 94 i.i.9'..9..l9=..
    16:48:19.607 0080: f8 7c 01 0d 28 39 d1 11 78 43 4a 20 46 90 47 01 .|..(9..xCJ F.G.
    16:48:19.607 0090: 46 00 29 32 d0 08 68 84 42 2f d1 40 48 00 78 01 F.)2..h.B/.@H.x.
    16:48:19.607 00a0: 28 2b d0 08 79 00 28 28 d0 01 20 3d 4c 3f 4a 20 (+..y.((.. =L?J
    16:48:19.607 00b0: 70 4d 20 90 47 00 20 20 70 70 bd e0 8a 10 b9 4f pM .G. pp.....O
    16:48:19.607 00c0: f0 03 00 e0 82 70 bd 94 f8 78 01 4f f0 01 01 10 .....p...x.O....
    16:48:19.607 00d0: b9 e0 78 10 b9 02 e0 e0 78 00 b9 00 21 2a 4e c4 ..x.....x...!*N.
    16:48:19.607 00e0: f8 7c 21 01 20 38 3e 2f 4a 70 72 20 46 90 47 00 .|!. 8>/Jpr F.G.
    16:48:19.607 00f0: 20 70 72 2d 48 00 f5 44 70 pr-H..Dp
    16:48:19.638 Incoming Dump:
    16:48:19.638 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.638 --
    16:48:19.638 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.638 Parameters:
    16:48:19.638 | Number HCI commands : 0x01
    16:48:19.638 | Command Opcode : 0xff05
    16:48:19.638 | Status : 0x00 (Success)
    16:48:19.638 --
    16:48:19.638 --
    16:48:19.638 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.638 | Address : 0x2008ca30
    16:48:19.638 | Size : 0xf0
    16:48:19.638 | Values : "68:63:70:BD:95:B9:00:00:F4:9F:08:20:2D:08:02:00:1C:DD:08:20:80:7D:08:20:D0:F1:0C:20:A1:C8:07:00:42:7B:25:49:BA:B1:52:1E:26:D1:08:46:23:4A:01:88:11:40:41:F0:01:01:01:80:41:88:11:40:41:F0:01:01:41:80:81:88:11:40:41:F0:01:01:81:80:C1:88:11:40:41:F0:01:01:0F:E0:08:46:01:88:21:F0:1F:01:01:80:41:88:21:F0:1F:01:41:80:81:88:21:F0:1F:01:81:80:C1:88:21:F0:1F:01:C1:80:70:47:C0:46:19:7B:01:00:6B:96:08:20:05:2C:05:00:98:00:08:20:45:42:03:00:04:DD:08:20:C4:F0:0C:20:CC:F1:0C:20:38:76:08:20:75:E4:03:00:E8:A2:08:20:80:DC:08:20:99:63:07:00:7D:BC:01:00:61:5D:08:00:2E:E1:0C:20:E0:FC:FF:FF:2D:E9:F0:4F:AD:F1:1C:0D:01:46:04:90:4F:F6:CF:56:A0:4B:DF:F8:84:C2:DF:F8:78:82:DF:F8:6C:A2:0A:8A:4F:69:00:24:96:42:05:92:DF:F8:70:92:06:94:30:DB"
    16:48:19.638 --
    16:48:19.638 Outgoing Dump:
    16:48:19.638 0000: 01 05 ff f5 30 ca 08 20 f0 68 63 70 bd 95 b9 00 ....0.. .hcp....
    16:48:19.638 0010: 00 f4 9f 08 20 2d 08 02 00 1c dd 08 20 80 7d 08 .... -...... .}.
    16:48:19.638 0020: 20 d0 f1 0c 20 a1 c8 07 00 42 7b 25 49 ba b1 52 ... ....B{%I..R
    16:48:19.638 0030: 1e 26 d1 08 46 23 4a 01 88 11 40 41 f0 01 01 01 .&..F#J...@A....
    16:48:19.638 0040: 80 41 88 11 40 41 f0 01 01 41 80 81 88 11 40 41 .A..@A...A....@A
    16:48:19.638 0050: f0 01 01 81 80 c1 88 11 40 41 f0 01 01 0f e0 08 ........@A......
    16:48:19.638 0060: 46 01 88 21 f0 1f 01 01 80 41 88 21 f0 1f 01 41 F..!.....A.!...A
    16:48:19.638 0070: 80 81 88 21 f0 1f 01 81 80 c1 88 21 f0 1f 01 c1 ...!.......!....
    16:48:19.638 0080: 80 70 47 c0 46 19 7b 01 00 6b 96 08 20 05 2c 05 .pG.F.{..k.. .,.
    16:48:19.638 0090: 00 98 00 08 20 45 42 03 00 04 dd 08 20 c4 f0 0c .... EB..... ...
    16:48:19.638 00a0: 20 cc f1 0c 20 38 76 08 20 75 e4 03 00 e8 a2 08 ... 8v. u......
    16:48:19.638 00b0: 20 80 dc 08 20 99 63 07 00 7d bc 01 00 61 5d 08 ... .c..}...a].
    16:48:19.638 00c0: 00 2e e1 0c 20 e0 fc ff ff 2d e9 f0 4f ad f1 1c .... ....-..O...
    16:48:19.638 00d0: 0d 01 46 04 90 4f f6 cf 56 a0 4b df f8 84 c2 df ..F..O..V.K.....
    16:48:19.638 00e0: f8 78 82 df f8 6c a2 0a 8a 4f 69 00 24 96 42 05 .x...l...Oi.$.B.
    16:48:19.638 00f0: 92 df f8 70 92 06 94 30 db ...p...0.
    16:48:19.669 Incoming Dump:
    16:48:19.669 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.669 --
    16:48:19.669 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.669 Parameters:
    16:48:19.669 | Number HCI commands : 0x01
    16:48:19.669 | Command Opcode : 0xff05
    16:48:19.669 | Status : 0x00 (Success)
    16:48:19.669 --
    16:48:19.669 --
    16:48:19.669 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.669 | Address : 0x2008cb20
    16:48:19.669 | Size : 0xf0
    16:48:19.669 | Values : "31:46:91:42:00:F0:F8:80:94:4D:A1:F1:4B:01:91:42:14:DB:91:42:00:F0:46:81:A1:F1:78:01:52:1A:00:F0:EB:81:68:3A:00:F0:DF:81:92:1E:00:F0:D7:81:52:1E:00:F0:6D:81:0B:3A:00:F0:42:81:D7:E1:01:F1:03:01:52:1A:00:F0:15:81:12:1F:00:F0:AE:81:D2:1F:00:F0:F9:80:2A:3A:00:F0:9A:81:0E:3A:02:2A:40:F2:A9:81:C4:E1:06:F1:55:06:96:42:14:DB:A1:4D:DF:F8:84:B2:96:42:24:D0:A6:F1:52:06:92:1B:00:F0:7E:81:1D:3A:00:F0:75:81:0C:3A:7E:D0:12:1F:34:D0:11:3A:00:F0:5D:81:AB:E1:06:F1:05:06:92:1B:00:F0:53:81:52:1E:00:F0:4E:81:92:1F:00:F0:45:81:08:3A:40:F0:9E:81:9F:48:00:78:00:28:40:F0:99:81:A0:48:25:E1:F8:7A:0F:35:01:21:28:70:38:46:98:47:05:21:01:EB:C0:01:0A:20:B1:FB:F0:F0:68:65:40:F2:4D:10:C8:47:28:78:20:B1:99:4A:69:6D:40:F2:4D:10:90:47:22:46:31:46"
    16:48:19.669 --
    16:48:19.669 Outgoing Dump:
    16:48:19.669 0000: 01 05 ff f5 20 cb 08 20 f0 31 46 91 42 00 f0 f8 .... .. .1F.B...
    16:48:19.669 0010: 80 94 4d a1 f1 4b 01 91 42 14 db 91 42 00 f0 46 ..M..K..B...B..F
    16:48:19.669 0020: 81 a1 f1 78 01 52 1a 00 f0 eb 81 68 3a 00 f0 df ...x.R.....h:...
    16:48:19.669 0030: 81 92 1e 00 f0 d7 81 52 1e 00 f0 6d 81 0b 3a 00 .......R...m..:.
    16:48:19.669 0040: f0 42 81 d7 e1 01 f1 03 01 52 1a 00 f0 15 81 12 .B.......R......
    16:48:19.669 0050: 1f 00 f0 ae 81 d2 1f 00 f0 f9 80 2a 3a 00 f0 9a ...........*:...
    16:48:19.669 0060: 81 0e 3a 02 2a 40 f2 a9 81 c4 e1 06 f1 55 06 96 ..:.*@.......U..
    16:48:19.669 0070: 42 14 db a1 4d df f8 84 b2 96 42 24 d0 a6 f1 52 B...M.....B$...R
    16:48:19.669 0080: 06 92 1b 00 f0 7e 81 1d 3a 00 f0 75 81 0c 3a 7e .....~..:..u..:~
    16:48:19.669 0090: d0 12 1f 34 d0 11 3a 00 f0 5d 81 ab e1 06 f1 05 ...4..:..]......
    16:48:19.669 00a0: 06 92 1b 00 f0 53 81 52 1e 00 f0 4e 81 92 1f 00 .....S.R...N....
    16:48:19.669 00b0: f0 45 81 08 3a 40 f0 9e 81 9f 48 00 78 00 28 40 .E..:@....H.x.(@
    16:48:19.669 00c0: f0 99 81 a0 48 25 e1 f8 7a 0f 35 01 21 28 70 38 ....H%..z.5.!(p8
    16:48:19.669 00d0: 46 98 47 05 21 01 eb c0 01 0a 20 b1 fb f0 f0 68 F.G.!..... ....h
    16:48:19.669 00e0: 65 40 f2 4d 10 c8 47 28 78 20 b1 99 4a 69 6d 40 e@.M..G(x ..Jim@
    16:48:19.669 00f0: f2 4d 10 90 47 22 46 31 46 .M..G"F1F
    16:48:19.701 Incoming Dump:
    16:48:19.701 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.701 --
    16:48:19.701 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.701 Parameters:
    16:48:19.701 | Number HCI commands : 0x01
    16:48:19.701 | Command Opcode : 0xff05
    16:48:19.701 | Status : 0x00 (Success)
    16:48:19.701 --
    16:48:19.701 --
    16:48:19.701 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.701 | Address : 0x2008cc10
    16:48:19.701 | Size : 0xf0
    16:48:19.701 | Values : "38:46:D8:47:39:E1:56:46:F8:7A:20:36:30:70:38:7B:28:70:78:7B:70:70:01:20:B0:70:9E:48:80:47:31:78:9D:48:31:F0:7F:02:25:D1:49:08:39:BF:B0:F8:D2:10:21:F0:01:01:B0:F8:D2:10:41:F0:01:01:9D:4A:A0:F8:D2:10:31:78:89:08:3C:BF:01:88:6F:F3:DF:31:02:D3:03:88:11:46:19:43:01:80:31:78:C9:08:3C:BF:B0:F8:98:10:6F:F3:DF:31:03:D3:B0:F8:98:30:11:46:19:43:A0:F8:98:10:29:78:31:F0:7F:02:0A:D1:49:08:00:F1:D2:00:39:BF:01:88:21:F0:02:01:01:88:41:F0:02:01:01:80:9C:48:66:E0:FD:7A:02:21:38:46:98:47:4F:F0:01:09:AD:1E:04:D0:6D:1E:1D:D0:6D:1E:1F:D0:16:E0:41:46:A1:F1:70:01:0A:6C:40:EA:02:00:08:64:91:F8:4C:00:4C:64:98:B9:88:7E:88:B1:91:F8:27:00:30:B9:9A:48:00:78:58:B1:9F:49:48:46:88:47:38:B1:B9:F1:00:0F:04:D0:30:E1:41:46:FF:20:4C:39:08:70:98:48"
    16:48:19.701 --
    16:48:19.701 Outgoing Dump:
    16:48:19.701 0000: 01 05 ff f5 10 cc 08 20 f0 38 46 d8 47 39 e1 56 ....... .8F.G9.V
    16:48:19.701 0010: 46 f8 7a 20 36 30 70 38 7b 28 70 78 7b 70 70 01 F.z 60p8{(px{pp.
    16:48:19.701 0020: 20 b0 70 9e 48 80 47 31 78 9d 48 31 f0 7f 02 25 .p.H.G1x.H1...%
    16:48:19.701 0030: d1 49 08 39 bf b0 f8 d2 10 21 f0 01 01 b0 f8 d2 .I.9.....!......
    16:48:19.701 0040: 10 41 f0 01 01 9d 4a a0 f8 d2 10 31 78 89 08 3c .A....J....1x..<
    16:48:19.701 0050: bf 01 88 6f f3 df 31 02 d3 03 88 11 46 19 43 01 ...o..1.....F.C.
    16:48:19.701 0060: 80 31 78 c9 08 3c bf b0 f8 98 10 6f f3 df 31 03 .1x..<.....o..1.
    16:48:19.701 0070: d3 b0 f8 98 30 11 46 19 43 a0 f8 98 10 29 78 31 ....0.F.C....)x1
    16:48:19.701 0080: f0 7f 02 0a d1 49 08 00 f1 d2 00 39 bf 01 88 21 .....I.....9...!
    16:48:19.701 0090: f0 02 01 01 88 41 f0 02 01 01 80 9c 48 66 e0 fd .....A......Hf..
    16:48:19.701 00a0: 7a 02 21 38 46 98 47 4f f0 01 09 ad 1e 04 d0 6d z.!8F.GO.......m
    16:48:19.701 00b0: 1e 1d d0 6d 1e 1f d0 16 e0 41 46 a1 f1 70 01 0a ...m.....AF..p..
    16:48:19.701 00c0: 6c 40 ea 02 00 08 64 91 f8 4c 00 4c 64 98 b9 88 l@....d..L.Ld...
    16:48:19.701 00d0: 7e 88 b1 91 f8 27 00 30 b9 9a 48 00 78 58 b1 9f ~....'.0..H.xX..
    16:48:19.701 00e0: 49 48 46 88 47 38 b1 b9 f1 00 0f 04 d0 30 e1 41 IHF.G8.......0.A
    16:48:19.701 00f0: 46 ff 20 4c 39 08 70 98 48 F. L9.p.H
    16:48:19.732 Incoming Dump:
    16:48:19.732 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.732 --
    16:48:19.732 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.732 Parameters:
    16:48:19.732 | Number HCI commands : 0x01
    16:48:19.732 | Command Opcode : 0xff05
    16:48:19.732 | Status : 0x00 (Success)
    16:48:19.732 --
    16:48:19.732 --
    16:48:19.732 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.732 | Address : 0x2008cd00
    16:48:19.732 | Size : 0xf0
    16:48:19.732 | Values : "00:68:4C:46:04:28:C0:F0:0C:81:31:46:06:9A:38:46:01:F1:29:01:D8:47:04:E1:8C:48:3D:7B:FE:7A:00:78:40:B1:90:49:01:20:88:47:20:B1:95:48:00:68:80:08:80:F0:EC:80:8C:48:0A:2E:05:D1:01:88:21:F0:0F:01:41:F0:01:01:01:80:FF:2D:00:F0:06:81:35:B9:01:88:21:F0:0F:01:41:F0:01:01:01:80:FD:E0:01:88:21:F0:0F:01:F9:E7:F8:7A:00:28:40:F0:D0:80:7F:49:01:20:08:70:7F:48:80:47:D4:E0:84:7C:08:20:60:DD:08:20:A8:76:08:20:25:D1:00:00:E1:D2:00:00:85:1B:06:00:39:7B:08:29:02:DA:28:46:08:30:01:80:79:7B:08:29:02:DA:28:46:0C:30:01:80:F9:7C:08:29:02:DA:28:46:0A:30:01:80:38:7D:08:28:80:F2:A8:80:29:46:01:F1:0E:01:68:E0:21:46:38:46:E0:47:56:46:31:78:B1:EB:20:2F:40:F0:A6:80:C0:B2:A7:F8:0B:00:BC:E0:65:4B:0C:22:07:F1:0B:01:01:A8:98:47:9D:F8:04:10:62:4A"
    16:48:19.732 --
    16:48:19.732 Outgoing Dump:
    16:48:19.732 0000: 01 05 ff f5 00 cd 08 20 f0 00 68 4c 46 04 28 c0 ....... ..hLF.(.
    16:48:19.732 0010: f0 0c 81 31 46 06 9a 38 46 01 f1 29 01 d8 47 04 ...1F..8F..)..G.
    16:48:19.732 0020: e1 8c 48 3d 7b fe 7a 00 78 40 b1 90 49 01 20 88 ..H={.z.x@..I. .
    16:48:19.732 0030: 47 20 b1 95 48 00 68 80 08 80 f0 ec 80 8c 48 0a G ..H.h.......H.
    16:48:19.732 0040: 2e 05 d1 01 88 21 f0 0f 01 41 f0 01 01 01 80 ff .....!...A......
    16:48:19.732 0050: 2d 00 f0 06 81 35 b9 01 88 21 f0 0f 01 41 f0 01 -....5...!...A..
    16:48:19.732 0060: 01 01 80 fd e0 01 88 21 f0 0f 01 f9 e7 f8 7a 00 .......!......z.
    16:48:19.732 0070: 28 40 f0 d0 80 7f 49 01 20 08 70 7f 48 80 47 d4 (@....I. .p.H.G.
    16:48:19.732 0080: e0 84 7c 08 20 60 dd 08 20 a8 76 08 20 25 d1 00 ..|. `.. .v. %..
    16:48:19.732 0090: 00 e1 d2 00 00 85 1b 06 00 39 7b 08 29 02 da 28 .........9{.)..(
    16:48:19.732 00a0: 46 08 30 01 80 79 7b 08 29 02 da 28 46 0c 30 01 F.0..y{.)..(F.0.
    16:48:19.732 00b0: 80 f9 7c 08 29 02 da 28 46 0a 30 01 80 38 7d 08 ..|.)..(F.0..8}.
    16:48:19.732 00c0: 28 80 f2 a8 80 29 46 01 f1 0e 01 68 e0 21 46 38 (....)F....h.!F8
    16:48:19.732 00d0: 46 e0 47 56 46 31 78 b1 eb 20 2f 40 f0 a6 80 c0 F.GVF1x.. /@....
    16:48:19.732 00e0: b2 a7 f8 0b 00 bc e0 65 4b 0c 22 07 f1 0b 01 01 .......eK.".....
    16:48:19.732 00f0: a8 98 47 9d f8 04 10 62 4a ..G....bJ
    16:48:19.763 Incoming Dump:
    16:48:19.763 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.763 --
    16:48:19.763 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.763 Parameters:
    16:48:19.763 | Number HCI commands : 0x01
    16:48:19.763 | Command Opcode : 0xff05
    16:48:19.763 | Status : 0x00 (Success)
    16:48:19.763 --
    16:48:19.763 --
    16:48:19.763 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.763 | Address : 0x2008cdf0
    16:48:19.763 | Size : 0xf0
    16:48:19.763 | Values : "49:1E:11:D0:49:1E:08:D0:09:39:03:D0:49:1E:12:D1:28:46:0A:E0:10:46:08:30:07:E0:10:46:10:30:04:E0:CD:DC:08:20:63:AB:08:00:10:46:0D:F1:05:01:0A:68:02:60:49:68:41:60:57:48:01:24:04:70:94:E0:F8:7A:52:49:00:28:08:70:40:F0:8F:80:41:46:49:1D:08:78:00:28:00:F0:89:80:0C:70:40:F2:27:10:C8:47:83:E0:28:84:08:20:9E:49:38:46:88:47:16:E0:20:7C:08:20:9C:49:F8:E7:9C:49:F6:E7:85:1F:06:00:9B:49:38:46:88:47:9B:4B:02:21:13:F8:70:2F:01:2A:03:D1:99:4A:12:78:83:F8:62:20:49:1E:F5:D1:01:24:49:E0:01:21:38:46:E0:47:94:49:08:80:38:E0:94:49:38:46:88:47:3F:E0:C0:46:8D:0F:08:00:60:22:0C:20:22:46:01:25:94:4C:8F:4B:01:F1:35:01:38:46:8D:F8:00:50:A0:47:2C:46:2E:E0:00:80:FF:FF:8B:49:20:46:88:47:89:49:08:60:8A:48:00:88:08:B9:89:48:80:47:40:F2:27:10"
    16:48:19.763 --
    16:48:19.763 Outgoing Dump:
    16:48:19.763 0000: 01 05 ff f5 f0 cd 08 20 f0 49 1e 11 d0 49 1e 08 ....... .I...I..
    16:48:19.763 0010: d0 09 39 03 d0 49 1e 12 d1 28 46 0a e0 10 46 08 ..9..I...(F...F.
    16:48:19.763 0020: 30 07 e0 10 46 10 30 04 e0 cd dc 08 20 63 ab 08 0...F.0..... c..
    16:48:19.763 0030: 00 10 46 0d f1 05 01 0a 68 02 60 49 68 41 60 57 ..F.....h.`IhA`W
    16:48:19.763 0040: 48 01 24 04 70 94 e0 f8 7a 52 49 00 28 08 70 40 H.$.p...zRI.(.p@
    16:48:19.763 0050: f0 8f 80 41 46 49 1d 08 78 00 28 00 f0 89 80 0c ...AFI..x.(.....
    16:48:19.763 0060: 70 40 f2 27 10 c8 47 83 e0 28 84 08 20 9e 49 38 p@.'..G..(.. .I8
    16:48:19.763 0070: 46 88 47 16 e0 20 7c 08 20 9c 49 f8 e7 9c 49 f6 F.G.. |. .I...I.
    16:48:19.763 0080: e7 85 1f 06 00 9b 49 38 46 88 47 9b 4b 02 21 13 ......I8F.G.K.!.
    16:48:19.763 0090: f8 70 2f 01 2a 03 d1 99 4a 12 78 83 f8 62 20 49 .p/.*...J.x..b I
    16:48:19.763 00a0: 1e f5 d1 01 24 49 e0 01 21 38 46 e0 47 94 49 08 ....$I..!8F.G.I.
    16:48:19.763 00b0: 80 38 e0 94 49 38 46 88 47 3f e0 c0 46 8d 0f 08 .8..I8F.G?..F...
    16:48:19.763 00c0: 00 60 22 0c 20 22 46 01 25 94 4c 8f 4b 01 f1 35 .`". "F.%.L.K..5
    16:48:19.763 00d0: 01 38 46 8d f8 00 50 a0 47 2c 46 2e e0 00 80 ff .8F...P.G,F.....
    16:48:19.763 00e0: ff 8b 49 20 46 88 47 89 49 08 60 8a 48 00 88 08 ..I F.G.I.`.H...
    16:48:19.763 00f0: b9 89 48 80 47 40 f2 27 10 ..H.G@.'.
    16:48:19.794 Incoming Dump:
    16:48:19.794 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.794 --
    16:48:19.794 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.794 Parameters:
    16:48:19.794 | Number HCI commands : 0x01
    16:48:19.794 | Command Opcode : 0xff05
    16:48:19.794 | Status : 0x00 (Success)
    16:48:19.794 --
    16:48:19.794 --
    16:48:19.794 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.794 | Address : 0x2008cee0
    16:48:19.794 | Size : 0xf0
    16:48:19.794 | Values : "C8:47:4F:F4:01:40:C8:47:87:4A:A0:49:4F:F4:01:40:90:47:20:46:41:46:48:71:08:60:07:E0:05:21:38:46:98:47:9B:49:F8:E7:9B:49:38:46:88:47:06:98:40:B9:22:E0:C0:46:0D:D1:01:00:97:49:38:46:88:47:97:48:04:70:9A:48:00:78:03:28:05:D1:96:48:94:49:00:88:20:F0:0F:00:08:80:94:49:54:B9:04:9A:17:60:05:98:50:60:06:98:90:60:08:46:9C:30:03:E0:A6:7E:08:20:08:46:A0:30:04:99:48:63:07:B0:BD:E8:F0:8F:C0:46:A8:FE:08:20:93:E4:06:00:56:21:0C:20:61:A3:08:20:29:24:04:00:C9:E8:08:00:48:DD:08:20:71:2A:08:20:A8:F1:0C:20:D4:DC:08:20:2D:E9:FF:41:8A:4A:07:46:12:68:7E:69:39:69:04:2A:19:D0:4F:F6:03:72:8A:42:15:D0:02:F1:02:02:8A:42:11:D0:A2:F1:04:02:8A:42:0D:D0:A2:F1:C9:02:8A:42:09:D0:F2:88:41:F2:34:23:93:42:04:D0:78:48:86:62:01:21:81:70:7A:E0:A1:F2"
    16:48:19.794 --
    16:48:19.794 Outgoing Dump:
    16:48:19.794 0000: 01 05 ff f5 e0 ce 08 20 f0 c8 47 4f f4 01 40 c8 ....... ..GO..@.
    16:48:19.794 0010: 47 87 4a a0 49 4f f4 01 40 90 47 20 46 41 46 48 G.J.IO..@.G FAFH
    16:48:19.794 0020: 71 08 60 07 e0 05 21 38 46 98 47 9b 49 f8 e7 9b q.`...!8F.G.I...
    16:48:19.794 0030: 49 38 46 88 47 06 98 40 b9 22 e0 c0 46 0d d1 01 I8F.G..@."..F...
    16:48:19.794 0040: 00 97 49 38 46 88 47 97 48 04 70 9a 48 00 78 03 ..I8F.G.H.p.H.x.
    16:48:19.794 0050: 28 05 d1 96 48 94 49 00 88 20 f0 0f 00 08 80 94 (...H.I.. ......
    16:48:19.794 0060: 49 54 b9 04 9a 17 60 05 98 50 60 06 98 90 60 08 IT....`..P`...`.
    16:48:19.794 0070: 46 9c 30 03 e0 a6 7e 08 20 08 46 a0 30 04 99 48 F.0...~. .F.0..H
    16:48:19.794 0080: 63 07 b0 bd e8 f0 8f c0 46 a8 fe 08 20 93 e4 06 c.......F... ...
    16:48:19.794 0090: 00 56 21 0c 20 61 a3 08 20 29 24 04 00 c9 e8 08 .V!. a.. )$.....
    16:48:19.794 00a0: 00 48 dd 08 20 71 2a 08 20 a8 f1 0c 20 d4 dc 08 .H.. q*. ... ...
    16:48:19.794 00b0: 20 2d e9 ff 41 8a 4a 07 46 12 68 7e 69 39 69 04 -..A.J.F.h~i9i.
    16:48:19.794 00c0: 2a 19 d0 4f f6 03 72 8a 42 15 d0 02 f1 02 02 8a *..O..r.B.......
    16:48:19.794 00d0: 42 11 d0 a2 f1 04 02 8a 42 0d d0 a2 f1 c9 02 8a B.......B.......
    16:48:19.794 00e0: 42 09 d0 f2 88 41 f2 34 23 93 42 04 d0 78 48 86 B....A.4#.B..xH.
    16:48:19.794 00f0: 62 01 21 81 70 7a e0 a1 f2 b.!.pz...
    16:48:19.826 Incoming Dump:
    16:48:19.826 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.826 --
    16:48:19.826 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.826 Parameters:
    16:48:19.826 | Number HCI commands : 0x01
    16:48:19.826 | Command Opcode : 0xff05
    16:48:19.826 | Status : 0x00 (Success)
    16:48:19.826 --
    16:48:19.826 --
    16:48:19.826 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.826 | Address : 0x2008cfd0
    16:48:19.826 | Size : 0xf0
    16:48:19.826 | Values : "05:41:00:29:49:D0:A1:F6:13:01:91:B1:41:F2:05:42:89:1A:01:29:2D:D9:4D:F6:E6:62:89:1A:6D:D1:73:4A:00:21:30:46:90:47:6D:49:81:42:66:D1:65:48:80:47:63:E0:6F:4A:00:21:30:46:90:47:6E:49:48:86:88:7C:40:1C:88:74:91:F8:E6:00:40:1C:81:F8:E6:00:6A:49:4F:F4:00:70:08:80:69:48:01:78:FF:29:4D:D0:01:20:67:4A:88:40:11:68:01:43:11:60:11:68:81:43:11:60:43:E0:2F:48:80:47:63:4C:40:F2:27:10:A0:47:4F:F4:01:40:A0:47:2C:4A:45:49:4F:F4:01:40:90:47:5E:49:00:20:08:67:81:F8:75:00:2F:E0:4B:4B:6A:46:00:21:30:46:98:47:4E:4B:06:22:00:21:02:A8:98:47:00:24:01:E0:64:1C:A4:B2:45:48:00:78:A0:42:1D:DD:60:01:48:4D:DF:F8:0C:81:00:EB:44:20:69:46:2D:18:05:F1:10:00:C0:47:00:28:EC:D1:02:A9:68:46:C0:47:00:28:E7:D0:A8:78:01:28:E4:D0:3A:4B:3A:22:40:F2:05:41"
    16:48:19.826 --
    16:48:19.826 Outgoing Dump:
    16:48:19.826 0000: 01 05 ff f5 d0 cf 08 20 f0 05 41 00 29 49 d0 a1 ....... ..A.)I..
    16:48:19.826 0010: f6 13 01 91 b1 41 f2 05 42 89 1a 01 29 2d d9 4d .....A..B...)-.M
    16:48:19.826 0020: f6 e6 62 89 1a 6d d1 73 4a 00 21 30 46 90 47 6d ..b..m.sJ.!0F.Gm
    16:48:19.826 0030: 49 81 42 66 d1 65 48 80 47 63 e0 6f 4a 00 21 30 I.Bf.eH.Gc.oJ.!0
    16:48:19.826 0040: 46 90 47 6e 49 48 86 88 7c 40 1c 88 74 91 f8 e6 F.GnIH..|@..t...
    16:48:19.826 0050: 00 40 1c 81 f8 e6 00 6a 49 4f f4 00 70 08 80 69 .@.....jIO..p..i
    16:48:19.826 0060: 48 01 78 ff 29 4d d0 01 20 67 4a 88 40 11 68 01 H.x.)M.. gJ.@.h.
    16:48:19.826 0070: 43 11 60 11 68 81 43 11 60 43 e0 2f 48 80 47 63 C.`.h.C.`C./H.Gc
    16:48:19.826 0080: 4c 40 f2 27 10 a0 47 4f f4 01 40 a0 47 2c 4a 45 L@.'..GO..@.G,JE
    16:48:19.826 0090: 49 4f f4 01 40 90 47 5e 49 00 20 08 67 81 f8 75 IO..@.G^I. .g..u
    16:48:19.826 00a0: 00 2f e0 4b 4b 6a 46 00 21 30 46 98 47 4e 4b 06 ./.KKjF.!0F.GNK.
    16:48:19.826 00b0: 22 00 21 02 a8 98 47 00 24 01 e0 64 1c a4 b2 45 ".!...G.$..d...E
    16:48:19.826 00c0: 48 00 78 a0 42 1d dd 60 01 48 4d df f8 0c 81 00 H.x.B..`.HM.....
    16:48:19.826 00d0: eb 44 20 69 46 2d 18 05 f1 10 00 c0 47 00 28 ec .D iF-......G.(.
    16:48:19.826 00e0: d1 02 a9 68 46 c0 47 00 28 e7 d0 a8 78 01 28 e4 ...hF.G.(...x.(.
    16:48:19.826 00f0: d0 3a 4b 3a 22 40 f2 05 41 .:K:"@..A
    16:48:19.857 Incoming Dump:
    16:48:19.857 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.857 --
    16:48:19.857 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.857 Parameters:
    16:48:19.857 | Number HCI commands : 0x01
    16:48:19.857 | Command Opcode : 0xff05
    16:48:19.857 | Status : 0x00 (Success)
    16:48:19.857 --
    16:48:19.857 --
    16:48:19.857 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.857 | Address : 0x2008d0c0
    16:48:19.857 | Size : 0xf0
    16:48:19.857 | Values : "30:46:98:47:32:48:D0:30:78:63:00:90:BD:E8:FF:81:65:14:1A:00:95:14:1A:00:01:15:1A:00:4D:42:04:00:C0:A6:08:20:D9:A4:08:20:D8:72:08:20:01:00:1A:00:DB:DC:08:20:84:DC:08:20:27:C2:07:00:F0:A2:08:20:CF:83:02:00:11:AB:08:00:85:1F:06:00:00:B5:35:49:09:78:00:29:29:D0:00:7D:0F:28:26:D1:32:49:0A:88:D0:0B:C0:03:12:D1:2D:48:10:43:08:80:26:49:40:20:08:80:2B:48:03:78:FF:2B:05:D0:01:20:24:4A:98:40:13:68:18:43:10:60:4F:F4:00:50:08:80:22:48:42:68:01:6A:11:42:09:D0:00:68:01:42:0C:BF:23:49:24:49:16:20:88:47:23:49:16:20:88:47:00:BD:80:A9:03:00:C4:01:01:20:51:CA:08:20:15:DA:01:00:B3:6E:08:20:B0:77:03:20:14:F5:0E:20:E1:EE:01:00:28:84:08:20:47:F6:00:00:C9:B3:03:00:2D:D0:00:00:E2:69:08:20:27:79:06:00:87:9E:03:00:CC:DC:08:20:AC:FE:08:20"
    16:48:19.857 --
    16:48:19.857 Outgoing Dump:
    16:48:19.857 0000: 01 05 ff f5 c0 d0 08 20 f0 30 46 98 47 32 48 d0 ....... .0F.G2H.
    16:48:19.857 0010: 30 78 63 00 90 bd e8 ff 81 65 14 1a 00 95 14 1a 0xc......e......
    16:48:19.857 0020: 00 01 15 1a 00 4d 42 04 00 c0 a6 08 20 d9 a4 08 .....MB..... ...
    16:48:19.857 0030: 20 d8 72 08 20 01 00 1a 00 db dc 08 20 84 dc 08 .r. ....... ...
    16:48:19.857 0040: 20 27 c2 07 00 f0 a2 08 20 cf 83 02 00 11 ab 08 '...... .......
    16:48:19.857 0050: 00 85 1f 06 00 00 b5 35 49 09 78 00 29 29 d0 00 .......5I.x.))..
    16:48:19.857 0060: 7d 0f 28 26 d1 32 49 0a 88 d0 0b c0 03 12 d1 2d }.(&.2I........-
    16:48:19.857 0070: 48 10 43 08 80 26 49 40 20 08 80 2b 48 03 78 ff H.C..&I@ ..+H.x.
    16:48:19.857 0080: 2b 05 d0 01 20 24 4a 98 40 13 68 18 43 10 60 4f +... $J.@.h.C.`O
    16:48:19.857 0090: f4 00 50 08 80 22 48 42 68 01 6a 11 42 09 d0 00 ..P.."HBh.j.B...
    16:48:19.857 00a0: 68 01 42 0c bf 23 49 24 49 16 20 88 47 23 49 16 h.B..#I$I. .G#I.
    16:48:19.857 00b0: 20 88 47 00 bd 80 a9 03 00 c4 01 01 20 51 ca 08 .G......... Q..
    16:48:19.857 00c0: 20 15 da 01 00 b3 6e 08 20 b0 77 03 20 14 f5 0e .....n. .w. ...
    16:48:19.857 00d0: 20 e1 ee 01 00 28 84 08 20 47 f6 00 00 c9 b3 03 ....(.. G......
    16:48:19.857 00e0: 00 2d d0 00 00 e2 69 08 20 27 79 06 00 87 9e 03 .-....i. 'y.....
    16:48:19.857 00f0: 00 cc dc 08 20 ac fe 08 20 .... ...
    16:48:19.888 Incoming Dump:
    16:48:19.888 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.888 --
    16:48:19.888 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.888 Parameters:
    16:48:19.888 | Number HCI commands : 0x01
    16:48:19.888 | Command Opcode : 0xff05
    16:48:19.888 | Status : 0x00 (Success)
    16:48:19.888 --
    16:48:19.888 --
    16:48:19.888 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.888 | Address : 0x2008d1b0
    16:48:19.888 | Size : 0xf0
    16:48:19.888 | Values : "75:ED:08:00:B0:84:08:20:A8:FE:08:20:25:D1:00:00:E1:D2:00:00:C0:F0:0C:20:8C:E8:0C:20:90:77:08:20:04:F0:0E:20:85:1B:06:00:38:76:08:20:00:80:FF:FF:95:77:08:20:A6:7E:08:20:C4:F0:0C:20:DD:09:07:00:19:07:07:00:71:07:07:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:4D:11:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:61:13:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:C5:19:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:E5:05:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:C1:07:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:BD:05:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:A9:15:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:35:16:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:7F:0F:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:45:05:1A:00:82:B0:00:94:01:4C:01:94"
    16:48:19.888 --
    16:48:19.888 Outgoing Dump:
    16:48:19.888 0000: 01 05 ff f5 b0 d1 08 20 f0 75 ed 08 00 b0 84 08 ....... .u......
    16:48:19.888 0010: 20 a8 fe 08 20 25 d1 00 00 e1 d2 00 00 c0 f0 0c ... %..........
    16:48:19.888 0020: 20 8c e8 0c 20 90 77 08 20 04 f0 0e 20 85 1b 06 ... .w. ... ...
    16:48:19.888 0030: 00 38 76 08 20 00 80 ff ff 95 77 08 20 a6 7e 08 .8v. .....w. .~.
    16:48:19.888 0040: 20 c4 f0 0c 20 dd 09 07 00 19 07 07 00 71 07 07 ... ........q..
    16:48:19.888 0050: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 4d 11 1a ......L......M..
    16:48:19.888 0060: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 61 13 1a ......L......a..
    16:48:19.888 0070: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf c5 19 1a ......L.........
    16:48:19.888 0080: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf e5 05 1a ......L.........
    16:48:19.888 0090: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf c1 07 1a ......L.........
    16:48:19.888 00a0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf bd 05 1a ......L.........
    16:48:19.888 00b0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf a9 15 1a ......L.........
    16:48:19.888 00c0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 35 16 1a ......L......5..
    16:48:19.888 00d0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 7f 0f 1a ......L.........
    16:48:19.888 00e0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 45 05 1a ......L......E..
    16:48:19.888 00f0: 00 82 b0 00 94 01 4c 01 94 ......L..
    16:48:19.919 Incoming Dump:
    16:48:19.919 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.919 --
    16:48:19.919 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.919 Parameters:
    16:48:19.919 | Number HCI commands : 0x01
    16:48:19.919 | Command Opcode : 0xff05
    16:48:19.919 | Status : 0x00 (Success)
    16:48:19.919 --
    16:48:19.919 --
    16:48:19.919 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.919 | Address : 0x2008d2a0
    16:48:19.919 | Size : 0xf0
    16:48:19.919 | Values : "10:BD:00:BF:D9:16:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:E1:15:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:DD:1A:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:B5:0E:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:D5:0E:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:9D:13:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:5F:15:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:79:15:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:FF:1A:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:CD:1D:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:01:05:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:69:0B:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:25:07:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:75:17:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:65:0F:1A:00:82:B0:00:94:01:4C:01:94"
    16:48:19.919 --
    16:48:19.919 Outgoing Dump:
    16:48:19.919 0000: 01 05 ff f5 a0 d2 08 20 f0 10 bd 00 bf d9 16 1a ....... ........
    16:48:19.919 0010: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf e1 15 1a ......L.........
    16:48:19.919 0020: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf dd 1a 1a ......L.........
    16:48:19.919 0030: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf b5 0e 1a ......L.........
    16:48:19.919 0040: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf d5 0e 1a ......L.........
    16:48:19.919 0050: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 9d 13 1a ......L.........
    16:48:19.919 0060: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 5f 15 1a ......L......_..
    16:48:19.919 0070: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 79 15 1a ......L......y..
    16:48:19.919 0080: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf ff 1a 1a ......L.........
    16:48:19.919 0090: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf cd 1d 1a ......L.........
    16:48:19.919 00a0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 01 05 1a ......L.........
    16:48:19.919 00b0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 69 0b 1a ......L......i..
    16:48:19.919 00c0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 25 07 1a ......L......%..
    16:48:19.919 00d0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 75 17 1a ......L......u..
    16:48:19.919 00e0: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 65 0f 1a ......L......e..
    16:48:19.919 00f0: 00 82 b0 00 94 01 4c 01 94 ......L..
    16:48:19.951 Incoming Dump:
    16:48:19.951 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.951 --
    16:48:19.951 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.951 Parameters:
    16:48:19.951 | Number HCI commands : 0x01
    16:48:19.951 | Command Opcode : 0xff05
    16:48:19.951 | Status : 0x00 (Success)
    16:48:19.951 --
    16:48:19.951 --
    16:48:19.951 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.951 | Address : 0x2008d390
    16:48:19.951 | Size : 0xf0
    16:48:19.951 | Values : "10:BD:00:BF:39:1D:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:05:14:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:79:1A:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:F5:0E:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:E5:1C:1A:00:82:B0:00:94:01:4C:01:94:10:BD:00:BF:31:1B:1A:00:08:20:02:8D:40:1E:83:00:9F:48:00:1D:C1:50:9D:48:C2:50:70:47:10:B5:02:69:C1:69:89:1A:9B:4C:9D:4B:42:68:89:1A:09:1F:C1:61:99:49:04:F1:78:02:0E:20:98:47:04:F1:68:00:10:BD:10:B5:97:49:02:6B:08:88:6F:F3:0A:00:40:F0:01:00:08:80:94:48:00:78:01:28:14:BF:4F:F4:FA:44:4F:F4:00:44:91:48:03:46:5B:1E:02:FB:04:32:B2:FB:F0:F0:8A:4B:88:4C:B1:F8:7A:20:80:1C:60:F3:0A:02:A1:F8:7A:20:8A:49:0E:20:04:F1:64:02:98:47:04:F1:A2:00:10:BD:88:48:86:49:08:60:FE:E7:00:B5:87:49:28:20"
    16:48:19.951 --
    16:48:19.951 Outgoing Dump:
    16:48:19.951 0000: 01 05 ff f5 90 d3 08 20 f0 10 bd 00 bf 39 1d 1a ....... .....9..
    16:48:19.951 0010: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 05 14 1a ......L.........
    16:48:19.951 0020: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 79 1a 1a ......L......y..
    16:48:19.951 0030: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf f5 0e 1a ......L.........
    16:48:19.951 0040: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf e5 1c 1a ......L.........
    16:48:19.951 0050: 00 82 b0 00 94 01 4c 01 94 10 bd 00 bf 31 1b 1a ......L......1..
    16:48:19.951 0060: 00 08 20 02 8d 40 1e 83 00 9f 48 00 1d c1 50 9d .. ..@....H...P.
    16:48:19.951 0070: 48 c2 50 70 47 10 b5 02 69 c1 69 89 1a 9b 4c 9d H.PpG...i.i...L.
    16:48:19.951 0080: 4b 42 68 89 1a 09 1f c1 61 99 49 04 f1 78 02 0e KBh.....a.I..x..
    16:48:19.951 0090: 20 98 47 04 f1 68 00 10 bd 10 b5 97 49 02 6b 08 .G..h......I.k.
    16:48:19.951 00a0: 88 6f f3 0a 00 40 f0 01 00 08 80 94 48 00 78 01 .o...@......H.x.
    16:48:19.951 00b0: 28 14 bf 4f f4 fa 44 4f f4 00 44 91 48 03 46 5b (..O..DO..D.H.F[
    16:48:19.951 00c0: 1e 02 fb 04 32 b2 fb f0 f0 8a 4b 88 4c b1 f8 7a ....2.....K.L..z
    16:48:19.951 00d0: 20 80 1c 60 f3 0a 02 a1 f8 7a 20 8a 49 0e 20 04 ..`.....z .I. .
    16:48:19.951 00e0: f1 64 02 98 47 04 f1 a2 00 10 bd 88 48 86 49 08 .d..G.......H.I.
    16:48:19.951 00f0: 60 fe e7 00 b5 87 49 28 20 `.....I(
    16:48:19.982 Incoming Dump:
    16:48:19.982 0000: 04 0e 04 01 05 ff 00 .......
    16:48:19.982 --
    16:48:19.982 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:19.982 Parameters:
    16:48:19.982 | Number HCI commands : 0x01
    16:48:19.982 | Command Opcode : 0xff05
    16:48:19.982 | Status : 0x00 (Success)
    16:48:19.982 --
    16:48:19.982 --
    16:48:19.982 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:19.982 | Address : 0x2008d480
    16:48:19.982 | Size : 0xf0
    16:48:19.982 | Values : "88:47:85:48:4E:30:00:BD:10:B5:8C:4C:A4:F1:E7:04:20:68:28:B1:83:4B:00:22:C3:21:98:47:00:20:20:60:81:48:80:47:81:49:95:20:88:47:81:4A:73:4B:81:49:10:20:92:1C:98:47:80:48:00:F5:EF:70:10:BD:00:B5:7D:4A:6E:4B:7E:49:10:20:02:F5:E8:72:98:47:78:48:80:1D:00:BD:F0:B5:7B:48:00:88:7B:4E:00:25:10:F0:03:0F:03:D0:30:88:80:08:28:BF:01:25:77:48:80:47:00:24:C0:08:05:D3:30:46:80:1E:00:88:80:0A:28:BF:01:24:4F:F0:00:00:2D:B1:31:88:C9:0B:00:D3:0C:B9:4F:F0:01:00:4F:F0:00:01:14:B1:08:B9:4F:F0:01:01:6D:4C:C8:B9:F9:B1:6A:4E:4F:F4:D2:70:B0:47:07:46:4F:F4:F0:70:B0:47:87:42:07:DB:6D:B9:B4:F8:4C:00:20:F4:80:70:40:F0:80:00:0B:E0:B4:F8:4C:00:20:F0:80:00:40:F4:80:70:04:E0:B4:F8:4C:10:4F:F6:7F:60:08:40:A4:F8:4C:00:5B:48:78:30:F0:BD:2D:E9:F8:43"
    16:48:19.982 --
    16:48:19.982 Outgoing Dump:
    16:48:19.982 0000: 01 05 ff f5 80 d4 08 20 f0 88 47 85 48 4e 30 00 ....... ..G.HN0.
    16:48:19.982 0010: bd 10 b5 8c 4c a4 f1 e7 04 20 68 28 b1 83 4b 00 ....L.... h(..K.
    16:48:19.982 0020: 22 c3 21 98 47 00 20 20 60 81 48 80 47 81 49 95 ".!.G. `.H.G.I.
    16:48:19.982 0030: 20 88 47 81 4a 73 4b 81 49 10 20 92 1c 98 47 80 .G.JsK.I. ...G.
    16:48:19.982 0040: 48 00 f5 ef 70 10 bd 00 b5 7d 4a 6e 4b 7e 49 10 H...p....}JnK~I.
    16:48:19.982 0050: 20 02 f5 e8 72 98 47 78 48 80 1d 00 bd f0 b5 7b ...r.GxH......{
    16:48:19.982 0060: 48 00 88 7b 4e 00 25 10 f0 03 0f 03 d0 30 88 80 H..{N.%......0..
    16:48:19.982 0070: 08 28 bf 01 25 77 48 80 47 00 24 c0 08 05 d3 30 .(..%wH.G.$....0
    16:48:19.982 0080: 46 80 1e 00 88 80 0a 28 bf 01 24 4f f0 00 00 2d F......(..$O...-
    16:48:19.982 0090: b1 31 88 c9 0b 00 d3 0c b9 4f f0 01 00 4f f0 00 .1.......O...O..
    16:48:19.982 00a0: 01 14 b1 08 b9 4f f0 01 01 6d 4c c8 b9 f9 b1 6a .....O...mL....j
    16:48:19.982 00b0: 4e 4f f4 d2 70 b0 47 07 46 4f f4 f0 70 b0 47 87 NO..p.G.FO..p.G.
    16:48:19.982 00c0: 42 07 db 6d b9 b4 f8 4c 00 20 f4 80 70 40 f0 80 B..m...L. ..p@..
    16:48:19.982 00d0: 00 0b e0 b4 f8 4c 00 20 f0 80 00 40 f4 80 70 04 .....L. ...@..p.
    16:48:19.982 00e0: e0 b4 f8 4c 10 4f f6 7f 60 08 40 a4 f8 4c 00 5b ...L.O..`.@..L.[
    16:48:19.982 00f0: 48 78 30 f0 bd 2d e9 f8 43 Hx0..-..C
    16:48:20.013 Incoming Dump:
    16:48:20.013 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.013 --
    16:48:20.013 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.013 Parameters:
    16:48:20.013 | Number HCI commands : 0x01
    16:48:20.013 | Command Opcode : 0xff05
    16:48:20.013 | Status : 0x00 (Success)
    16:48:20.013 --
    16:48:20.013 --
    16:48:20.013 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.013 | Address : 0x2008d570
    16:48:20.013 | Size : 0xf0
    16:48:20.013 | Values : "07:46:61:48:DF:F8:68:81:00:88:3B:7C:40:08:07:D2:56:4A:18:46:06:21:90:47:40:46:D0:30:BD:E8:F8:83:DF:F8:50:91:42:4A:54:49:D9:F8:00:00:02:F1:FC:04:56:4E:08:60:56:4D:21:88:41:F4:80:51:21:80:55:4C:01:21:21:70:92:F8:6D:11:33:70:02:29:05:D0:03:29:1C:BF:4F:F6:FF:72:2A:80:14:D1:48:4C:E2:88:2A:80:82:B1:08:2A:0E:DA:4C:F6:FE:20:4B:49:44:4A:08:80:02:20:FF:21:90:47:4F:F6:FF:70:33:78:2A:88:E0:80:48:46:00:68:3F:4C:00:90:19:46:4F:F4:C7:70:A0:47:00:20:38:61:40:46:00:F5:A0:70:BD:E8:F8:83:00:B5:3E:48:41:68:02:6A:0A:42:0C:BF:00:22:01:22:3C:4B:C1:7A:4F:F4:CF:70:98:47:3A:48:46:30:00:BD:37:49:10:31:39:4A:83:69:09:88:B1:F5:C8:7F:11:DB:37:49:C0:69:09:78:C1:70:36:49:91:F8:53:00:01:EB:00:11:48:89:00:28:1C:BF:10:1C:00:F5:C5:70:04:D1:01:20"
    16:48:20.013 --
    16:48:20.013 Outgoing Dump:
    16:48:20.013 0000: 01 05 ff f5 70 d5 08 20 f0 07 46 61 48 df f8 68 ....p.. ..FaH..h
    16:48:20.013 0010: 81 00 88 3b 7c 40 08 07 d2 56 4a 18 46 06 21 90 ...;|@...VJ.F.!.
    16:48:20.013 0020: 47 40 46 d0 30 bd e8 f8 83 df f8 50 91 42 4a 54 G@F.0......P.BJT
    16:48:20.013 0030: 49 d9 f8 00 00 02 f1 fc 04 56 4e 08 60 56 4d 21 I........VN.`VM!
    16:48:20.013 0040: 88 41 f4 80 51 21 80 55 4c 01 21 21 70 92 f8 6d .A..Q!.UL.!!p..m
    16:48:20.013 0050: 11 33 70 02 29 05 d0 03 29 1c bf 4f f6 ff 72 2a .3p.)...)..O..r*
    16:48:20.013 0060: 80 14 d1 48 4c e2 88 2a 80 82 b1 08 2a 0e da 4c ...HL..*....*..L
    16:48:20.013 0070: f6 fe 20 4b 49 44 4a 08 80 02 20 ff 21 90 47 4f .. KIDJ... .!.GO
    16:48:20.013 0080: f6 ff 70 33 78 2a 88 e0 80 48 46 00 68 3f 4c 00 ..p3x*...HF.h?L.
    16:48:20.013 0090: 90 19 46 4f f4 c7 70 a0 47 00 20 38 61 40 46 00 ..FO..p.G. 8a@F.
    16:48:20.013 00a0: f5 a0 70 bd e8 f8 83 00 b5 3e 48 41 68 02 6a 0a ..p......>HAh.j.
    16:48:20.013 00b0: 42 0c bf 00 22 01 22 3c 4b c1 7a 4f f4 cf 70 98 B..."."<K.zO..p.
    16:48:20.013 00c0: 47 3a 48 46 30 00 bd 37 49 10 31 39 4a 83 69 09 G:HF0..7I.19J.i.
    16:48:20.013 00d0: 88 b1 f5 c8 7f 11 db 37 49 c0 69 09 78 c1 70 36 .......7I.i.x.p6
    16:48:20.013 00e0: 49 91 f8 53 00 01 eb 00 11 48 89 00 28 1c bf 10 I..S.....H..(...
    16:48:20.013 00f0: 1c 00 f5 c5 70 04 d1 01 20 ....p...
    16:48:20.044 Incoming Dump:
    16:48:20.044 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.044 --
    16:48:20.044 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.044 Parameters:
    16:48:20.044 | Number HCI commands : 0x01
    16:48:20.044 | Command Opcode : 0xff05
    16:48:20.044 | Status : 0x00 (Success)
    16:48:20.044 --
    16:48:20.044 --
    16:48:20.044 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.044 | Address : 0x2008d660
    16:48:20.044 | Size : 0xf0
    16:48:20.044 | Values : "18:80:10:46:00:F5:CC:70:70:47:C0:46:80:80:0B:20:FC:0E:09:20:89:FF:05:00:21:D4:08:20:ED:D3:08:20:0C:20:0C:20:26:78:08:20:40:42:0F:00:FD:D3:08:20:0C:ED:00:E0:01:00:FA:05:E5:19:06:00:8B:75:06:00:F4:A1:08:20:21:9F:03:00:75:E6:05:00:A3:5F:08:00:63:3D:01:00:BF:D4:08:20:A5:EB:05:00:DB:A2:08:20:89:D4:08:20:80:E3:0C:20:CC:A6:08:20:AD:0C:06:00:F9:13:01:00:E9:14:01:00:00:01:01:20:FD:A9:00:00:19:C3:00:00:80:7D:08:20:F8:DC:08:20:94:AA:08:20:ED:EE:08:00:E5:C5:07:00:1C:6A:08:20:D1:DC:08:20:DE:DC:08:20:D3:DC:08:20:2C:01:04:20:38:76:08:20:E1:C6:07:00:7D:7D:04:00:41:88:04:00:FD:80:08:20:F4:9F:08:20:2D:E9:F0:47:90:F8:24:C0:43:69:82:69:DF:F8:1C:92:DF:F8:14:82:90:F8:2C:E0:01:F1:08:0A:BC:F1:00:0F:03:F1:04:04:37:D1:BE:F1:00:0F:0B:D1"
    16:48:20.044 --
    16:48:20.044 Outgoing Dump:
    16:48:20.044 0000: 01 05 ff f5 60 d6 08 20 f0 18 80 10 46 00 f5 cc ....`.. ....F...
    16:48:20.044 0010: 70 70 47 c0 46 80 80 0b 20 fc 0e 09 20 89 ff 05 ppG.F... ... ...
    16:48:20.044 0020: 00 21 d4 08 20 ed d3 08 20 0c 20 0c 20 26 78 08 .!.. ... . . &x.
    16:48:20.044 0030: 20 40 42 0f 00 fd d3 08 20 0c ed 00 e0 01 00 fa @B..... .......
    16:48:20.044 0040: 05 e5 19 06 00 8b 75 06 00 f4 a1 08 20 21 9f 03 ......u..... !..
    16:48:20.044 0050: 00 75 e6 05 00 a3 5f 08 00 63 3d 01 00 bf d4 08 .u...._..c=.....
    16:48:20.044 0060: 20 a5 eb 05 00 db a2 08 20 89 d4 08 20 80 e3 0c ....... ... ...
    16:48:20.044 0070: 20 cc a6 08 20 ad 0c 06 00 f9 13 01 00 e9 14 01 ... ...........
    16:48:20.044 0080: 00 00 01 01 20 fd a9 00 00 19 c3 00 00 80 7d 08 .... .........}.
    16:48:20.044 0090: 20 f8 dc 08 20 94 aa 08 20 ed ee 08 00 e5 c5 07 ... ... .......
    16:48:20.044 00a0: 00 1c 6a 08 20 d1 dc 08 20 de dc 08 20 d3 dc 08 ..j. ... ... ...
    16:48:20.044 00b0: 20 2c 01 04 20 38 76 08 20 e1 c6 07 00 7d 7d 04 ,.. 8v. ....}}.
    16:48:20.044 00c0: 00 41 88 04 00 fd 80 08 20 f4 9f 08 20 2d e9 f0 .A...... ... -..
    16:48:20.044 00d0: 47 90 f8 24 c0 43 69 82 69 df f8 1c 92 df f8 14 G..$.Ci.i.......
    16:48:20.044 00e0: 82 90 f8 2c e0 01 f1 08 0a bc f1 00 0f 03 f1 04 ...,............
    16:48:20.044 00f0: 04 37 d1 be f1 00 0f 0b d1 .7.......
    16:48:20.076 Incoming Dump:
    16:48:20.076 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.076 --
    16:48:20.076 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.076 Parameters:
    16:48:20.076 | Number HCI commands : 0x01
    16:48:20.076 | Command Opcode : 0xff05
    16:48:20.076 | Status : 0x00 (Success)
    16:48:20.076 --
    16:48:20.076 --
    16:48:20.076 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.076 | Address : 0x2008d750
    16:48:20.076 | Size : 0xf0
    16:48:20.076 | Values : "40:46:90:F9:00:10:91:42:00:F3:EE:80:A3:7B:90:F9:09:10:99:42:0C:DD:E7:E0:40:46:90:F9:02:10:91:42:00:F3:E2:80:9B:7C:90:F9:0A:10:99:42:00:F3:DC:80:41:7D:E3:88:A5:88:59:43:8D:42:04:DC:81:7D:5B:19:99:42:02:DA:D0:E0:81:7D:5B:19:99:42:0D:DB:23:88:65:88:59:00:01:EB:03:11:83:7B:6B:43:99:42:04:DC:B0:F9:12:00:88:42:C0:F2:BF:80:BC:F1:01:0F:18:BF:BC:F1:02:0F:3D:D1:40:46:90:F9:02:10:BE:F1:00:0F:0A:D1:90:F9:01:10:91:42:00:F3:AE:80:A3:7B:90:F9:09:10:99:42:09:DD:A7:E0:91:42:00:F3:A5:80:A3:7B:90:F9:0A:10:99:42:00:F3:9F:80:21:88:C5:7B:4B:00:03:EB:01:13:61:88:4D:43:AB:42:05:DA:C9:18:B0:F9:12:30:8B:42:C0:F2:90:80:BC:F1:01:0F:04:D1:63:89:41:7B:99:42:C0:F2:88:80:43:7D:BC:F1:02:0F:08:D1:E1:88:A5:88:4B:43:9D:42:03:DA:80:7D:49:19:88:42"
    16:48:20.076 --
    16:48:20.076 Outgoing Dump:
    16:48:20.076 0000: 01 05 ff f5 50 d7 08 20 f0 40 46 90 f9 00 10 91 ....P.. .@F.....
    16:48:20.076 0010: 42 00 f3 ee 80 a3 7b 90 f9 09 10 99 42 0c dd e7 B.....{.....B...
    16:48:20.076 0020: e0 40 46 90 f9 02 10 91 42 00 f3 e2 80 9b 7c 90 .@F.....B.....|.
    16:48:20.076 0030: f9 0a 10 99 42 00 f3 dc 80 41 7d e3 88 a5 88 59 ....B....A}....Y
    16:48:20.076 0040: 43 8d 42 04 dc 81 7d 5b 19 99 42 02 da d0 e0 81 C.B...}[..B.....
    16:48:20.076 0050: 7d 5b 19 99 42 0d db 23 88 65 88 59 00 01 eb 03 }[..B..#.e.Y....
    16:48:20.076 0060: 11 83 7b 6b 43 99 42 04 dc b0 f9 12 00 88 42 c0 ..{kC.B.......B.
    16:48:20.076 0070: f2 bf 80 bc f1 01 0f 18 bf bc f1 02 0f 3d d1 40 .............=.@
    16:48:20.076 0080: 46 90 f9 02 10 be f1 00 0f 0a d1 90 f9 01 10 91 F...............
    16:48:20.076 0090: 42 00 f3 ae 80 a3 7b 90 f9 09 10 99 42 09 dd a7 B.....{.....B...
    16:48:20.076 00a0: e0 91 42 00 f3 a5 80 a3 7b 90 f9 0a 10 99 42 00 ..B.....{.....B.
    16:48:20.076 00b0: f3 9f 80 21 88 c5 7b 4b 00 03 eb 01 13 61 88 4d ...!..{K.....a.M
    16:48:20.076 00c0: 43 ab 42 05 da c9 18 b0 f9 12 30 8b 42 c0 f2 90 C.B.......0.B...
    16:48:20.076 00d0: 80 bc f1 01 0f 04 d1 63 89 41 7b 99 42 c0 f2 88 .......c.A{.B...
    16:48:20.076 00e0: 80 43 7d bc f1 02 0f 08 d1 e1 88 a5 88 4b 43 9d .C}..........KC.
    16:48:20.076 00f0: 42 03 da 80 7d 49 19 88 42 B...}I..B
    16:48:20.107 Incoming Dump:
    16:48:20.107 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.107 --
    16:48:20.107 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.107 Parameters:
    16:48:20.107 | Number HCI commands : 0x01
    16:48:20.107 | Command Opcode : 0xff05
    16:48:20.107 | Status : 0x00 (Success)
    16:48:20.107 --
    16:48:20.107 --
    16:48:20.107 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.107 | Address : 0x2008d840
    16:48:20.107 | Size : 0xf0
    16:48:20.107 | Values : "7A:DB:BC:F1:00:0F:32:D1:BE:F1:00:0F:40:46:04:D1:90:F9:03:10:91:42:04:DB:29:E0:90:F9:05:10:91:42:25:DA:A1:7B:BE:F1:00:0F:04:D1:90:F9:0B:30:8B:42:04:DD:1C:E0:90:F9:0C:30:8B:42:18:DC:A6:88:E1:88:07:7D:83:7D:8D:19:79:43:8E:42:01:DD:AB:42:4E:DB:AB:42:0C:DB:23:88:65:88:59:00:01:EB:03:11:83:7B:6B:43:99:42:03:DD:B0:F9:12:00:88:42:3F:DB:BC:F1:01:0F:18:BF:BC:F1:02:0F:43:D1:40:46:00:1D:90:F9:01:10:BE:F1:00:0F:04:D1:90:F9:00:10:91:42:02:DD:37:E0:91:42:35:DC:A1:7B:90:F9:08:20:BE:F1:00:0F:04:D1:90:F9:07:20:8A:42:02:DD:2A:E0:8A:42:28:DC:22:88:63:88:51:00:01:EB:02:11:82:7A:5A:43:91:42:1F:DD:B0:F9:0E:20:8A:42:1B:DA:BC:F1:01:0F:01:D1:61:89:61:B1:01:7C:BC:F1:02:0F:12:D1:E2:88:A3:88:51:43:8B:42:0D:DD:80:7C:D2:18:90:42:09:DA:02:20"
    16:48:20.107 --
    16:48:20.107 Outgoing Dump:
    16:48:20.107 0000: 01 05 ff f5 40 d8 08 20 f0 7a db bc f1 00 0f 32 ....@.. .z.....2
    16:48:20.107 0010: d1 be f1 00 0f 40 46 04 d1 90 f9 03 10 91 42 04 .....@F.......B.
    16:48:20.107 0020: db 29 e0 90 f9 05 10 91 42 25 da a1 7b be f1 00 .)......B%..{...
    16:48:20.107 0030: 0f 04 d1 90 f9 0b 30 8b 42 04 dd 1c e0 90 f9 0c ......0.B.......
    16:48:20.107 0040: 30 8b 42 18 dc a6 88 e1 88 07 7d 83 7d 8d 19 79 0.B.......}.}..y
    16:48:20.107 0050: 43 8e 42 01 dd ab 42 4e db ab 42 0c db 23 88 65 C.B...BN..B..#.e
    16:48:20.107 0060: 88 59 00 01 eb 03 11 83 7b 6b 43 99 42 03 dd b0 .Y......{kC.B...
    16:48:20.107 0070: f9 12 00 88 42 3f db bc f1 01 0f 18 bf bc f1 02 ....B?..........
    16:48:20.107 0080: 0f 43 d1 40 46 00 1d 90 f9 01 10 be f1 00 0f 04 .C.@F...........
    16:48:20.107 0090: d1 90 f9 00 10 91 42 02 dd 37 e0 91 42 35 dc a1 ......B..7..B5..
    16:48:20.107 00a0: 7b 90 f9 08 20 be f1 00 0f 04 d1 90 f9 07 20 8a {... ......... .
    16:48:20.107 00b0: 42 02 dd 2a e0 8a 42 28 dc 22 88 63 88 51 00 01 B..*..B(.".c.Q..
    16:48:20.107 00c0: eb 02 11 82 7a 5a 43 91 42 1f dd b0 f9 0e 20 8a ....zZC.B..... .
    16:48:20.107 00d0: 42 1b da bc f1 01 0f 01 d1 61 89 61 b1 01 7c bc B........a.a..|.
    16:48:20.107 00e0: f1 02 0f 12 d1 e2 88 a3 88 51 43 8b 42 0d dd 80 .........QC.B...
    16:48:20.107 00f0: 7c d2 18 90 42 09 da 02 20 |...B...
    16:48:20.138 Incoming Dump:
    16:48:20.138 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.138 --
    16:48:20.138 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.138 Parameters:
    16:48:20.138 | Number HCI commands : 0x01
    16:48:20.138 | Command Opcode : 0xff05
    16:48:20.138 | Status : 0x00 (Success)
    16:48:20.138 --
    16:48:20.138 --
    16:48:20.138 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.138 | Address : 0x2008d930
    16:48:20.138 | Size : 0xf0
    16:48:20.138 | Values : "49:46:08:70:00:20:02:E0:01:20:49:46:08:70:8A:F8:00:00:42:48:00:F2:26:30:BD:E8:F0:87:00:9C:08:20:FE:9B:08:20:10:B5:3E:4B:40:4A:3F:49:18:78:07:28:06:DA:3C:4C:24:88:A4:09:02:D3:0C:68:A4:08:15:D2:93:F8:28:00:07:28:06:DA:B2:F8:56:30:9B:0B:02:D3:09:68:89:08:0A:D2:92:F8:72:00:FE:28:04:D1:92:F8:52:00:88:B1:9C:48:00:78:11:46:0B:E0:11:46:9B:4A:12:5C:50:01:00:EB:42:20:9A:4A:12:5C:B4:20:50:43:99:4A:10:5C:81:F8:52:00:95:48:00:F5:B1:70:10:BD:01:68:8A:1D:C9:88:4F:F6:FF:73:8B:42:1C:BF:11:88:49:1C:C1:61:91:48:88:30:70:47:10:B5:04:46:90:48:80:47:40:B9:91:48:00:78:28:B9:8E:48:80:47:00:28:08:BF:01:20:00:D0:00:20:20:60:8B:48:1C:30:10:BD:8B:49:01:60:8B:48:00:F5:93:70:70:47:70:B5:01:68:44:68:8D:4D:01:61:8B:4E:04:62:95:F8:AB:20:23:46"
    16:48:20.138 --
    16:48:20.138 Outgoing Dump:
    16:48:20.138 0000: 01 05 ff f5 30 d9 08 20 f0 49 46 08 70 00 20 02 ....0.. .IF.p. .
    16:48:20.138 0010: e0 01 20 49 46 08 70 8a f8 00 00 42 48 00 f2 26 .. IF.p....BH..&
    16:48:20.138 0020: 30 bd e8 f0 87 00 9c 08 20 fe 9b 08 20 10 b5 3e 0....... ... ..>
    16:48:20.138 0030: 4b 40 4a 3f 49 18 78 07 28 06 da 3c 4c 24 88 a4 K@J?I.x.(..<L$..
    16:48:20.138 0040: 09 02 d3 0c 68 a4 08 15 d2 93 f8 28 00 07 28 06 ....h......(..(.
    16:48:20.138 0050: da b2 f8 56 30 9b 0b 02 d3 09 68 89 08 0a d2 92 ...V0.....h.....
    16:48:20.138 0060: f8 72 00 fe 28 04 d1 92 f8 52 00 88 b1 9c 48 00 .r..(....R....H.
    16:48:20.138 0070: 78 11 46 0b e0 11 46 9b 4a 12 5c 50 01 00 eb 42 x.F...F.J.\P...B
    16:48:20.138 0080: 20 9a 4a 12 5c b4 20 50 43 99 4a 10 5c 81 f8 52 .J.\. PC.J.\..R
    16:48:20.138 0090: 00 95 48 00 f5 b1 70 10 bd 01 68 8a 1d c9 88 4f ..H...p...h....O
    16:48:20.138 00a0: f6 ff 73 8b 42 1c bf 11 88 49 1c c1 61 91 48 88 ..s.B....I..a.H.
    16:48:20.138 00b0: 30 70 47 10 b5 04 46 90 48 80 47 40 b9 91 48 00 0pG...F.H.G@..H.
    16:48:20.138 00c0: 78 28 b9 8e 48 80 47 00 28 08 bf 01 20 00 d0 00 x(..H.G.(... ...
    16:48:20.138 00d0: 20 20 60 8b 48 1c 30 10 bd 8b 49 01 60 8b 48 00 `.H.0...I.`.H.
    16:48:20.138 00e0: f5 93 70 70 47 70 b5 01 68 44 68 8d 4d 01 61 8b ..ppGp..hDh.M.a.
    16:48:20.138 00f0: 4e 04 62 95 f8 ab 20 23 46 N.b... #F
    16:48:20.169 Incoming Dump:
    16:48:20.169 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.169 --
    16:48:20.169 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.169 Parameters:
    16:48:20.169 | Number HCI commands : 0x01
    16:48:20.169 | Command Opcode : 0xff05
    16:48:20.169 | Status : 0x00 (Success)
    16:48:20.169 --
    16:48:20.169 --
    16:48:20.169 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.169 | Address : 0x2008da20
    16:48:20.169 | Size : 0xf0
    16:48:20.169 | Values : "40:F2:DE:31:03:20:B0:47:95:F8:AB:00:28:B9:24:B9:01:20:81:4B:01:46:02:46:98:47:80:48:01:68:80:48:09:0B:2C:BF:10:30:7E:30:70:BD:C0:46:45:62:05:00:F4:9A:08:20:4A:A0:08:20:FC:82:08:20:F4:9F:08:20:2D:E9:FE:4F:81:46:D9:F8:08:10:D9:F8:00:40:D9:F8:04:60:01:91:33:78:01:25:A4:F1:08:01:9A:1E:02:2A:06:D9:52:1F:09:D0:52:1E:02:2A:01:D9:12:1F:10:D1:6E:48:02:95:00:EB:03:0B:0B:E0:03:20:08:71:06:F1:07:0B:0E:60:07:20:8B:F8:00:00:70:88:40:1C:C0:B2:02:90:00:20:48:71:66:48:00:68:DF:F8:9C:A1:01:88:C9:B2:09:29:11:D1:01:7A:02:29:0E:D1:40:F2:03:31:00:F1:08:02:AD:F8:00:10:40:88:5E:49:C0:1E:D2:1C:83:B2:20:46:D0:47:02:25:08:34:30:88:C0:B2:02:28:04:D0:03:28:08:D1:B0:79:00:1D:07:E0:F0:88:00:28:04:BF:B0:89:40:1D:01:D0:70:88:40:1C:86:B2:70:08"
    16:48:20.169 --
    16:48:20.169 Outgoing Dump:
    16:48:20.169 0000: 01 05 ff f5 20 da 08 20 f0 40 f2 de 31 03 20 b0 .... .. .@..1. .
    16:48:20.169 0010: 47 95 f8 ab 00 28 b9 24 b9 01 20 81 4b 01 46 02 G....(.$.. .K.F.
    16:48:20.169 0020: 46 98 47 80 48 01 68 80 48 09 0b 2c bf 10 30 7e F.G.H.h.H..,..0~
    16:48:20.169 0030: 30 70 bd c0 46 45 62 05 00 f4 9a 08 20 4a a0 08 0p..FEb..... J..
    16:48:20.169 0040: 20 fc 82 08 20 f4 9f 08 20 2d e9 fe 4f 81 46 d9 ... ... -..O.F.
    16:48:20.169 0050: f8 08 10 d9 f8 00 40 d9 f8 04 60 01 91 33 78 01 ......@...`..3x.
    16:48:20.169 0060: 25 a4 f1 08 01 9a 1e 02 2a 06 d9 52 1f 09 d0 52 %.......*..R...R
    16:48:20.169 0070: 1e 02 2a 01 d9 12 1f 10 d1 6e 48 02 95 00 eb 03 ..*......nH.....
    16:48:20.169 0080: 0b 0b e0 03 20 08 71 06 f1 07 0b 0e 60 07 20 8b .... .q.....`. .
    16:48:20.169 0090: f8 00 00 70 88 40 1c c0 b2 02 90 00 20 48 71 66 ...p.@...... Hqf
    16:48:20.169 00a0: 48 00 68 df f8 9c a1 01 88 c9 b2 09 29 11 d1 01 H.h.........)...
    16:48:20.169 00b0: 7a 02 29 0e d1 40 f2 03 31 00 f1 08 02 ad f8 00 z.)..@..1.......
    16:48:20.169 00c0: 10 40 88 5e 49 c0 1e d2 1c 83 b2 20 46 d0 47 02 .@.^I...... F.G.
    16:48:20.169 00d0: 25 08 34 30 88 c0 b2 02 28 04 d0 03 28 08 d1 b0 %.40....(...(...
    16:48:20.169 00e0: 79 00 1d 07 e0 f0 88 00 28 04 bf b0 89 40 1d 01 y.......(....@..
    16:48:20.169 00f0: d0 70 88 40 1c 86 b2 70 08 .p.@...p.
    16:48:20.201 Incoming Dump:
    16:48:20.201 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.201 --
    16:48:20.201 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.201 Parameters:
    16:48:20.201 | Number HCI commands : 0x01
    16:48:20.201 | Command Opcode : 0xff05
    16:48:20.201 | Status : 0x00 (Success)
    16:48:20.201 --
    16:48:20.201 --
    16:48:20.201 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.201 | Address : 0x2008db10
    16:48:20.201 | Size : 0xf0
    16:48:20.201 | Values : "3C:BF:76:1C:B6:B2:54:49:88:7B:21:F8:10:60:53:48:00:78:88:46:01:28:0D:D0:44:F2:03:10:AD:F8:00:00:4A:4A:98:F8:0E:00:02:23:08:EB:40:01:20:46:D0:47:6D:1C:3C:E0:4A:4F:03:20:44:4A:B9:1C:02:23:08:80:44:F2:03:10:AD:F8:00:00:20:46:D0:47:98:F8:0E:10:55:22:76:1D:08:34:07:F1:10:00:01:EB:41:01:03:23:42:54:08:18:32:12:79:18:46:70:10:31:56:46:82:70:44:F2:03:00:36:4A:AD:F8:00:00:20:46:B0:47:98:F8:0E:20:7B:88:07:F1:1C:00:08:34:91:00:38:F8:12:20:43:52:7F:18:40:18:1C:37:04:23:42:80:39:46:44:F2:03:10:2A:4A:AD:F8:00:00:20:46:B0:47:ED:1C:44:F2:03:00:AD:F8:00:00:26:4A:02:9E:08:34:59:46:33:46:20:46:D0:47:01:98:ED:B2:06:70:22:48:C9:F8:00:50:F2:30:BD:E8:FE:8F:10:B5:04:69:94:F8:3A:00:22:28:03:D1:20:4A:00:21:20:46:90:47:1F:4A:00:21:20:46"
    16:48:20.201 --
    16:48:20.216 Outgoing Dump:
    16:48:20.216 0000: 01 05 ff f5 10 db 08 20 f0 3c bf 76 1c b6 b2 54 ....... .<.v...T
    16:48:20.216 0010: 49 88 7b 21 f8 10 60 53 48 00 78 88 46 01 28 0d I.{!..`SH.x.F.(.
    16:48:20.216 0020: d0 44 f2 03 10 ad f8 00 00 4a 4a 98 f8 0e 00 02 .D.......JJ.....
    16:48:20.216 0030: 23 08 eb 40 01 20 46 d0 47 6d 1c 3c e0 4a 4f 03 #..@. F.Gm.<.JO.
    16:48:20.216 0040: 20 44 4a b9 1c 02 23 08 80 44 f2 03 10 ad f8 00 DJ...#..D......
    16:48:20.216 0050: 00 20 46 d0 47 98 f8 0e 10 55 22 76 1d 08 34 07 . F.G....U"v..4.
    16:48:20.216 0060: f1 10 00 01 eb 41 01 03 23 42 54 08 18 32 12 79 .....A..#BT..2.y
    16:48:20.216 0070: 18 46 70 10 31 56 46 82 70 44 f2 03 00 36 4a ad .Fp.1VF.pD...6J.
    16:48:20.216 0080: f8 00 00 20 46 b0 47 98 f8 0e 20 7b 88 07 f1 1c ... F.G... {....
    16:48:20.216 0090: 00 08 34 91 00 38 f8 12 20 43 52 7f 18 40 18 1c ..4..8.. CR..@..
    16:48:20.216 00a0: 37 04 23 42 80 39 46 44 f2 03 10 2a 4a ad f8 00 7.#B.9FD...*J...
    16:48:20.216 00b0: 00 20 46 b0 47 ed 1c 44 f2 03 00 ad f8 00 00 26 . F.G..D.......&
    16:48:20.216 00c0: 4a 02 9e 08 34 59 46 33 46 20 46 d0 47 01 98 ed J...4YF3F F.G...
    16:48:20.216 00d0: b2 06 70 22 48 c9 f8 00 50 f2 30 bd e8 fe 8f 10 ..p"H...P.0.....
    16:48:20.216 00e0: b5 04 69 94 f8 3a 00 22 28 03 d1 20 4a 00 21 20 ..i..:."(.. J.!
    16:48:20.216 00f0: 46 90 47 1f 4a 00 21 20 46 F.G.J.! F
    16:48:20.248 Incoming Dump:
    16:48:20.248 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.248 --
    16:48:20.248 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.248 Parameters:
    16:48:20.248 | Number HCI commands : 0x01
    16:48:20.248 | Command Opcode : 0xff05
    16:48:20.248 | Status : 0x00 (Success)
    16:48:20.248 --
    16:48:20.248 --
    16:48:20.248 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.248 | Address : 0x2008dc00
    16:48:20.248 | Size : 0x80
    16:48:20.248 | Values : "90:47:1E:48:70:30:10:BD:18:9D:08:20:74:A9:08:20:2D:39:03:00:B0:84:08:20:2F:96:08:20:ED:40:03:00:85:2E:00:00:55:53:07:00:15:7D:04:00:DB:A2:08:20:43:7A:08:20:85:3D:04:00:A9:0F:1A:00:74:A3:08:20:53:91:03:00:09:C7:07:00:F4:A1:08:20:D8:77:03:20:48:7C:08:20:00:36:0C:20:15:B5:08:00:0E:C2:02:20:08:C2:02:20:81:AD:05:00:A8:77:03:20:0D:6A:08:20:80:DC:08:20:15:27:01:00:45:07:05:00:39:0C:05:00"
    16:48:20.248 --
    16:48:20.248 Outgoing Dump:
    16:48:20.248 0000: 01 05 ff 85 00 dc 08 20 80 90 47 1e 48 70 30 10 ....... ..G.Hp0.
    16:48:20.248 0010: bd 18 9d 08 20 74 a9 08 20 2d 39 03 00 b0 84 08 .... t.. -9.....
    16:48:20.248 0020: 20 2f 96 08 20 ed 40 03 00 85 2e 00 00 55 53 07 /.. .@......US.
    16:48:20.248 0030: 00 15 7d 04 00 db a2 08 20 43 7a 08 20 85 3d 04 ..}..... Cz. .=.
    16:48:20.248 0040: 00 a9 0f 1a 00 74 a3 08 20 53 91 03 00 09 c7 07 .....t.. S......
    16:48:20.248 0050: 00 f4 a1 08 20 d8 77 03 20 48 7c 08 20 00 36 0c .... .w. H|. .6.
    16:48:20.248 0060: 20 15 b5 08 00 0e c2 02 20 08 c2 02 20 81 ad 05 ....... ... ...
    16:48:20.248 0070: 00 a8 77 03 20 0d 6a 08 20 80 dc 08 20 15 27 01 ..w. .j. ... .'.
    16:48:20.248 0080: 00 45 07 05 00 39 0c 05 00 .E...9...
    16:48:20.263 Incoming Dump:
    16:48:20.263 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.263 --
    16:48:20.263 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.263 Parameters:
    16:48:20.263 | Number HCI commands : 0x01
    16:48:20.263 | Command Opcode : 0xff05
    16:48:20.263 | Status : 0x00 (Success)
    16:48:20.263 --
    16:48:20.263 --
    16:48:20.263 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.263 | Address : 0x2008fe94
    16:48:20.263 | Size : 0x0e
    16:48:20.263 | Values : "2D:E9:FF:5F:68:46:A0:F7:B1:F8:BD:E8:FF:9F"
    16:48:20.263 --
    16:48:20.263 Outgoing Dump:
    16:48:20.263 0000: 01 05 ff 13 94 fe 08 20 0e 2d e9 ff 5f 68 46 a0 ....... .-.._hF.
    16:48:20.263 0010: f7 b1 f8 bd e8 ff 9f .......
    16:48:20.279 Incoming Dump:
    16:48:20.279 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.279 --
    16:48:20.279 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.279 Parameters:
    16:48:20.279 | Number HCI commands : 0x01
    16:48:20.279 | Command Opcode : 0xff05
    16:48:20.279 | Status : 0x00 (Success)
    16:48:20.279 --
    16:48:20.279 --
    16:48:20.279 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.279 | Address : 0x20090f00
    16:48:20.279 | Size : 0xf0
    16:48:20.279 | Values : "0F:D6:08:20:41:26:1A:00:D1:26:1A:00:E7:DB:08:20:C1:D9:08:20:25:D7:08:20:89:31:1A:00:FD:06:03:20:79:06:03:20:99:06:03:20:2F:D6:08:20:D5:D4:08:20:0F:D6:08:20:21:D4:08:20:7B:D4:08:20:BF:D4:08:20:F9:33:1A:00:25:2C:1A:00:E9:2E:1A:00:DF:33:1A:00:91:2B:1A:00:99:2C:1A:00:61:B8:08:20:45:29:1A:00:99:30:1A:00:61:2F:1A:00:15:2B:1A:00:55:D9:08:20:CD:33:1A:00:61:DA:08:20:73:D4:08:20:E9:29:1A:00:9D:29:1A:00:DD:2B:1A:00:7D:2F:1A:00:31:34:1A:00:FF:27:1A:00:55:2E:1A:00:6F:28:1A:00:AF:33:1A:00:09:29:1A:00:55:2B:1A:00:FD:2D:1A:00:39:2A:1A:00:BD:2D:1A:00:55:2D:1A:00:00:00:00:00:25:34:1A:00:1F:34:1A:00:0D:DA:08:20:6D:D5:08:20:89:33:1A:00:6D:2C:1A:00:59:2C:1A:00:DB:D9:08:20:45:28:1A:00:19:34:1A:00:1B:29:1A:00:31:2D:1A:00:91:28:1A:00"
    16:48:20.279 --
    16:48:20.279 Outgoing Dump:
    16:48:20.279 0000: 01 05 ff f5 00 0f 09 20 f0 0f d6 08 20 41 26 1a ....... .... A&.
    16:48:20.279 0010: 00 d1 26 1a 00 e7 db 08 20 c1 d9 08 20 25 d7 08 ..&..... ... %..
    16:48:20.279 0020: 20 89 31 1a 00 fd 06 03 20 79 06 03 20 99 06 03 .1..... y.. ...
    16:48:20.279 0030: 20 2f d6 08 20 d5 d4 08 20 0f d6 08 20 21 d4 08 /.. ... ... !..
    16:48:20.279 0040: 20 7b d4 08 20 bf d4 08 20 f9 33 1a 00 25 2c 1a {.. ... .3..%,.
    16:48:20.279 0050: 00 e9 2e 1a 00 df 33 1a 00 91 2b 1a 00 99 2c 1a ......3...+...,.
    16:48:20.279 0060: 00 61 b8 08 20 45 29 1a 00 99 30 1a 00 61 2f 1a .a.. E)...0..a/.
    16:48:20.279 0070: 00 15 2b 1a 00 55 d9 08 20 cd 33 1a 00 61 da 08 ..+..U.. .3..a..
    16:48:20.279 0080: 20 73 d4 08 20 e9 29 1a 00 9d 29 1a 00 dd 2b 1a s.. .)...)...+.
    16:48:20.279 0090: 00 7d 2f 1a 00 31 34 1a 00 ff 27 1a 00 55 2e 1a .}/..14...'..U..
    16:48:20.279 00a0: 00 6f 28 1a 00 af 33 1a 00 09 29 1a 00 55 2b 1a .o(...3...)..U+.
    16:48:20.279 00b0: 00 fd 2d 1a 00 39 2a 1a 00 bd 2d 1a 00 55 2d 1a ..-..9*...-..U-.
    16:48:20.279 00c0: 00 00 00 00 00 25 34 1a 00 1f 34 1a 00 0d da 08 .....%4...4.....
    16:48:20.279 00d0: 20 6d d5 08 20 89 33 1a 00 6d 2c 1a 00 59 2c 1a m.. .3..m,..Y,.
    16:48:20.279 00e0: 00 db d9 08 20 45 28 1a 00 19 34 1a 00 1b 29 1a .... E(...4...).
    16:48:20.279 00f0: 00 31 2d 1a 00 91 28 1a 00 .1-...(..
    16:48:20.310 Incoming Dump:
    16:48:20.310 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.310 --
    16:48:20.310 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.310 Parameters:
    16:48:20.310 | Number HCI commands : 0x01
    16:48:20.310 | Command Opcode : 0xff05
    16:48:20.310 | Status : 0x00 (Success)
    16:48:20.310 --
    16:48:20.310 --
    16:48:20.310 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.310 | Address : 0x20090ff0
    16:48:20.310 | Size : 0x10
    16:48:20.310 | Values : "C5:2F:1A:00:00:00:00:00:00:00:00:00:00:00:00:00"
    16:48:20.310 --
    16:48:20.310 Outgoing Dump:
    16:48:20.310 0000: 01 05 ff 15 f0 0f 09 20 10 c5 2f 1a 00 00 00 00 ....... ../.....
    16:48:20.310 0010: 00 00 00 00 00 00 00 00 00 .........
    16:48:20.326 Incoming Dump:
    16:48:20.326 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.326 --
    16:48:20.326 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.326 Parameters:
    16:48:20.326 | Number HCI commands : 0x01
    16:48:20.326 | Command Opcode : 0xff05
    16:48:20.326 | Status : 0x00 (Success)
    16:48:20.326 --
    16:48:20.326 --
    16:48:20.326 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.326 | Address : 0x200b8080
    16:48:20.326 | Size : 0xf0
    16:48:20.326 | Values : "B9:7D:04:00:31:FD:05:00:15:D1:01:00:A1:0C:05:00:71:41:03:00:C1:63:05:00:39:F3:02:00:5D:F5:02:00:E9:EA:02:00:ED:F4:02:00:C5:89:04:00:ED:14:01:00:B9:7D:04:00:01:00:06:00:2D:1A:06:00:65:3D:01:00:D1:64:07:00:01:BD:06:00:C1:8F:06:00:4D:76:08:00:B1:C6:06:00:25:19:08:00:E1:21:01:00:45:00:01:00:21:2B:05:00:9D:7B:08:00:29:2F:06:00:35:3A:03:00:21:30:08:00:89:AD:05:00:99:A6:06:00:41:31:07:00:8D:68:07:00:49:58:06:00:31:B3:04:00:C9:41:08:00:2D:C6:04:00:D9:E7:00:00:F1:2B:01:00:C9:B2:02:00:E9:2E:01:00:E1:5B:08:00:6D:9D:03:00:89:96:05:00:ED:0D:02:00:89:05:02:00:00:00:00:00:FD:3D:00:00:B1:2F:00:00:59:91:03:00:E1:C3:00:00:C9:4C:01:00:51:89:07:00:B1:8A:07:00:2D:7D:04:00:51:CB:04:00:B9:F8:06:00:85:41:01:00:D9:01:02:00:D5:EA:05:00"
    16:48:20.326 --
    16:48:20.326 Outgoing Dump:
    16:48:20.326 0000: 01 05 ff f5 80 80 0b 20 f0 b9 7d 04 00 31 fd 05 ....... ..}..1..
    16:48:20.326 0010: 00 15 d1 01 00 a1 0c 05 00 71 41 03 00 c1 63 05 .........qA...c.
    16:48:20.326 0020: 00 39 f3 02 00 5d f5 02 00 e9 ea 02 00 ed f4 02 .9...]..........
    16:48:20.326 0030: 00 c5 89 04 00 ed 14 01 00 b9 7d 04 00 01 00 06 ..........}.....
    16:48:20.326 0040: 00 2d 1a 06 00 65 3d 01 00 d1 64 07 00 01 bd 06 .-...e=...d.....
    16:48:20.326 0050: 00 c1 8f 06 00 4d 76 08 00 b1 c6 06 00 25 19 08 .....Mv......%..
    16:48:20.326 0060: 00 e1 21 01 00 45 00 01 00 21 2b 05 00 9d 7b 08 ..!..E...!+...{.
    16:48:20.326 0070: 00 29 2f 06 00 35 3a 03 00 21 30 08 00 89 ad 05 .)/..5:..!0.....
    16:48:20.326 0080: 00 99 a6 06 00 41 31 07 00 8d 68 07 00 49 58 06 .....A1...h..IX.
    16:48:20.326 0090: 00 31 b3 04 00 c9 41 08 00 2d c6 04 00 d9 e7 00 .1....A..-......
    16:48:20.326 00a0: 00 f1 2b 01 00 c9 b2 02 00 e9 2e 01 00 e1 5b 08 ..+...........[.
    16:48:20.326 00b0: 00 6d 9d 03 00 89 96 05 00 ed 0d 02 00 89 05 02 .m..............
    16:48:20.326 00c0: 00 00 00 00 00 fd 3d 00 00 b1 2f 00 00 59 91 03 ......=.../..Y..
    16:48:20.326 00d0: 00 e1 c3 00 00 c9 4c 01 00 51 89 07 00 b1 8a 07 ......L..Q......
    16:48:20.326 00e0: 00 2d 7d 04 00 51 cb 04 00 b9 f8 06 00 85 41 01 .-}..Q........A.
    16:48:20.326 00f0: 00 d9 01 02 00 d5 ea 05 00 .........
    16:48:20.357 Incoming Dump:
    16:48:20.357 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.357 --
    16:48:20.357 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.357 Parameters:
    16:48:20.357 | Number HCI commands : 0x01
    16:48:20.357 | Command Opcode : 0xff05
    16:48:20.357 | Status : 0x00 (Success)
    16:48:20.357 --
    16:48:20.357 --
    16:48:20.357 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.357 | Address : 0x200b8170
    16:48:20.357 | Size : 0x10
    16:48:20.357 | Values : "49:AF:05:00:00:00:00:00:00:00:00:00:00:00:00:00"
    16:48:20.357 --
    16:48:20.357 Outgoing Dump:
    16:48:20.357 0000: 01 05 ff 15 70 81 0b 20 10 49 af 05 00 00 00 00 ....p.. .I......
    16:48:20.357 0010: 00 00 00 00 00 00 00 00 00 .........
    16:48:20.372 Incoming Dump:
    16:48:20.372 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.372 --
    16:48:20.372 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.372 Parameters:
    16:48:20.372 | Number HCI commands : 0x01
    16:48:20.372 | Command Opcode : 0xff05
    16:48:20.372 | Status : 0x00 (Success)
    16:48:20.372 --
    16:48:20.372 --
    16:48:20.372 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.372 | Address : 0x20030000
    16:48:20.372 | Size : 0xf0
    16:48:20.372 | Values : "F0:B5:3D:4E:3B:4D:4A:4F:31:68:2A:68:89:1E:64:D0:42:4C:3A:4B:49:1E:45:D0:89:1E:69:D1:02:2A:01:D1:01:20:98:47:37:4D:36:4B:04:22:4F:F4:88:71:16:20:A8:47:35:4B:14:22:0C:21:17:20:A8:47:33:4B:02:22:4F:F4:88:71:18:20:A8:47:31:4B:02:22:4F:F4:80:71:19:20:A8:47:2F:4B:02:22:4F:F4:88:71:1A:20:A8:47:2D:4B:10:22:2C:21:1B:20:A8:47:E0:78:48:B1:2C:49:00:20:88:47:2B:49:01:20:88:47:10:B1:2A:49:40:20:08:80:04:20:30:60:29:48:C4:F8:24:01:01:20:38:70:A0:78:00:28:2C:D0:2E:4A:A1:6A:00:20:90:47:00:20:A0:70:F0:BD:01:2A:05:D1:00:20:98:47:21:48:80:47:02:20:28:60:20:48:01:68:01:29:19:D1:00:21:01:60:1F:48:1E:49:00:68:51:F8:20:00:80:47:1D:48:80:47:E4:1C:01:21:05:20:21:70:09:E0:1B:48:80:47:1B:48:80:47:00:20:38:70:30:68:02:28:01:D1:03:20:30:60"
    16:48:20.372 --
    16:48:20.372 Outgoing Dump:
    16:48:20.372 0000: 01 05 ff f5 00 00 03 20 f0 f0 b5 3d 4e 3b 4d 4a ....... ...=N;MJ
    16:48:20.372 0010: 4f 31 68 2a 68 89 1e 64 d0 42 4c 3a 4b 49 1e 45 O1h*h..d.BL:KI.E
    16:48:20.372 0020: d0 89 1e 69 d1 02 2a 01 d1 01 20 98 47 37 4d 36 ...i..*... .G7M6
    16:48:20.372 0030: 4b 04 22 4f f4 88 71 16 20 a8 47 35 4b 14 22 0c K."O..q. .G5K.".
    16:48:20.372 0040: 21 17 20 a8 47 33 4b 02 22 4f f4 88 71 18 20 a8 !. .G3K."O..q. .
    16:48:20.372 0050: 47 31 4b 02 22 4f f4 80 71 19 20 a8 47 2f 4b 02 G1K."O..q. .G/K.
    16:48:20.372 0060: 22 4f f4 88 71 1a 20 a8 47 2d 4b 10 22 2c 21 1b "O..q. .G-K.",!.
    16:48:20.372 0070: 20 a8 47 e0 78 48 b1 2c 49 00 20 88 47 2b 49 01 .G.xH.,I. .G+I.
    16:48:20.372 0080: 20 88 47 10 b1 2a 49 40 20 08 80 04 20 30 60 29 .G..*I@ ... 0`)
    16:48:20.372 0090: 48 c4 f8 24 01 01 20 38 70 a0 78 00 28 2c d0 2e H..$.. 8p.x.(,..
    16:48:20.372 00a0: 4a a1 6a 00 20 90 47 00 20 a0 70 f0 bd 01 2a 05 J.j. .G. .p...*.
    16:48:20.372 00b0: d1 00 20 98 47 21 48 80 47 02 20 28 60 20 48 01 .. .G!H.G. (` H.
    16:48:20.372 00c0: 68 01 29 19 d1 00 21 01 60 1f 48 1e 49 00 68 51 h.)...!.`.H.I.hQ
    16:48:20.372 00d0: f8 20 00 80 47 1d 48 80 47 e4 1c 01 21 05 20 21 . ..G.H.G...!. !
    16:48:20.372 00e0: 70 09 e0 1b 48 80 47 1b 48 80 47 00 20 38 70 30 p...H.G.H.G. 8p0
    16:48:20.372 00f0: 68 02 28 01 d1 03 20 30 60 h.(... 0`
    16:48:20.404 Incoming Dump:
    16:48:20.404 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.404 --
    16:48:20.404 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.404 Parameters:
    16:48:20.404 | Number HCI commands : 0x01
    16:48:20.404 | Command Opcode : 0xff05
    16:48:20.404 | Status : 0x00 (Success)
    16:48:20.404 --
    16:48:20.404 --
    16:48:20.404 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.404 | Address : 0x200300f0
    16:48:20.404 | Size : 0xf0
    16:48:20.404 | Values : "F0:BD:C0:46:AC:FE:08:20:A8:FE:08:20:71:7E:03:20:D8:7B:03:20:93:FD:02:00:38:80:03:20:C8:81:03:20:F8:83:03:20:08:86:03:20:38:88:03:20:CC:DC:08:20:B5:49:04:00:93:E4:06:00:00:E8:0C:20:95:BA:08:20:B2:6E:08:20:DB:87:03:20:B4:FE:08:20:D0:7E:03:20:A4:FE:08:20:DB:86:03:20:AD:7E:03:20:AD:04:03:20:29:88:08:00:2D:E9:F0:41:99:49:00:22:99:4B:C8:1C:8A:70:02:70:00:F2:1D:12:1A:60:97:4A:61:30:10:60:98:4A:96:48:C1:F8:2C:21:C1:F8:28:01:96:4A:C1:F8:30:21:96:4A:C1:F8:34:21:95:4A:91:48:C1:F8:38:21:06:22:80:F8:6C:20:93:4A:C1:F8:3C:21:07:22:82:71:91:4A:C1:F8:40:21:91:4A:C1:F8:44:21:09:22:42:71:8F:4A:C1:F8:48:21:0A:22:80:F8:34:20:8D:4A:B2:4F:C1:F8:4C:21:0B:22:02:72:8B:4A:02:23:03:26:4F:F0:04:0C:4F:F0:05:0E:4F:F0:08:08:C1:F8:50:21:14:25"
    16:48:20.404 --
    16:48:20.404 Outgoing Dump:
    16:48:20.404 0000: 01 05 ff f5 f0 00 03 20 f0 f0 bd c0 46 ac fe 08 ....... ....F...
    16:48:20.404 0010: 20 a8 fe 08 20 71 7e 03 20 d8 7b 03 20 93 fd 02 ... q~. .{. ...
    16:48:20.404 0020: 00 38 80 03 20 c8 81 03 20 f8 83 03 20 08 86 03 .8.. ... ... ...
    16:48:20.404 0030: 20 38 88 03 20 cc dc 08 20 b5 49 04 00 93 e4 06 8.. ... .I.....
    16:48:20.404 0040: 00 00 e8 0c 20 95 ba 08 20 b2 6e 08 20 db 87 03 .... ... .n. ...
    16:48:20.404 0050: 20 b4 fe 08 20 d0 7e 03 20 a4 fe 08 20 db 86 03 ... .~. ... ...
    16:48:20.404 0060: 20 ad 7e 03 20 ad 04 03 20 29 88 08 00 2d e9 f0 .~. ... )...-..
    16:48:20.404 0070: 41 99 49 00 22 99 4b c8 1c 8a 70 02 70 00 f2 1d A.I.".K...p.p...
    16:48:20.404 0080: 12 1a 60 97 4a 61 30 10 60 98 4a 96 48 c1 f8 2c ..`.Ja0.`.J.H..,
    16:48:20.404 0090: 21 c1 f8 28 01 96 4a c1 f8 30 21 96 4a c1 f8 34 !..(..J..0!.J..4
    16:48:20.404 00a0: 21 95 4a 91 48 c1 f8 38 21 06 22 80 f8 6c 20 93 !.J.H..8!."..l .
    16:48:20.404 00b0: 4a c1 f8 3c 21 07 22 82 71 91 4a c1 f8 40 21 91 J..<!.".q.J..@!.
    16:48:20.404 00c0: 4a c1 f8 44 21 09 22 42 71 8f 4a c1 f8 48 21 0a J..D!."Bq.J..H!.
    16:48:20.404 00d0: 22 80 f8 34 20 8d 4a b2 4f c1 f8 4c 21 0b 22 02 "..4 .J.O..L!.".
    16:48:20.404 00e0: 72 8b 4a 02 23 03 26 4f f0 04 0c 4f f0 05 0e 4f r.J.#.&O...O...O
    16:48:20.404 00f0: f0 08 08 c1 f8 50 21 14 25 .....P!.%
    16:48:20.435 Incoming Dump:
    16:48:20.435 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.435 --
    16:48:20.435 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.435 Parameters:
    16:48:20.435 | Number HCI commands : 0x01
    16:48:20.435 | Command Opcode : 0xff05
    16:48:20.435 | Status : 0x00 (Success)
    16:48:20.435 --
    16:48:20.435 --
    16:48:20.435 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.435 | Address : 0x200301e0
    16:48:20.435 | Size : 0xf0
    16:48:20.435 | Values : "CF:66:0C:22:80:F8:85:20:84:4A:80:F8:29:30:1E:24:C1:F8:54:21:06:71:80:F8:63:C0:80:F8:F5:E0:80:F8:F4:80:80:F8:35:50:80:F8:87:40:0D:22:80:F8:39:20:7B:4A:C1:F8:58:21:0E:22:80:F8:3E:20:79:4A:C1:F8:5C:21:0F:22:80:F8:27:20:77:4A:C1:F8:60:21:10:22:80:F8:30:20:75:4A:C1:F8:64:21:11:22:80:F8:86:20:73:4A:C1:F8:68:21:12:22:80:F8:43:20:71:4A:C1:F8:6C:21:13:22:82:74:70:4A:C1:F8:70:21:6F:4A:C1:F8:74:21:15:22:80:F8:66:20:6D:4A:C1:F8:78:21:16:22:80:F8:4C:20:6B:4A:C1:F8:7C:21:17:22:80:F8:21:20:69:4A:C1:F8:80:21:18:22:80:F8:4B:20:67:4A:C1:F8:84:21:19:22:82:72:66:4A:C1:F8:88:21:1A:22:80:F8:84:20:64:4A:C1:F8:8C:21:1B:22:80:F8:DD:20:62:4A:C1:F8:90:21:1C:22:80:F8:40:20:60:4A:C1:F8:94:21:1D:22:80:F8:5E:20:5E:4A:C1:F8:98:21:5D:4A:C1:F8"
    16:48:20.435 --
    16:48:20.435 Outgoing Dump:
    16:48:20.435 0000: 01 05 ff f5 e0 01 03 20 f0 cf 66 0c 22 80 f8 85 ....... ..f."...
    16:48:20.435 0010: 20 84 4a 80 f8 29 30 1e 24 c1 f8 54 21 06 71 80 .J..)0.$..T!.q.
    16:48:20.435 0020: f8 63 c0 80 f8 f5 e0 80 f8 f4 80 80 f8 35 50 80 .c...........5P.
    16:48:20.435 0030: f8 87 40 0d 22 80 f8 39 20 7b 4a c1 f8 58 21 0e ..@."..9 {J..X!.
    16:48:20.435 0040: 22 80 f8 3e 20 79 4a c1 f8 5c 21 0f 22 80 f8 27 "..> yJ..\!."..'
    16:48:20.435 0050: 20 77 4a c1 f8 60 21 10 22 80 f8 30 20 75 4a c1 wJ..`!."..0 uJ.
    16:48:20.435 0060: f8 64 21 11 22 80 f8 86 20 73 4a c1 f8 68 21 12 .d!."... sJ..h!.
    16:48:20.435 0070: 22 80 f8 43 20 71 4a c1 f8 6c 21 13 22 82 74 70 "..C qJ..l!.".tp
    16:48:20.435 0080: 4a c1 f8 70 21 6f 4a c1 f8 74 21 15 22 80 f8 66 J..p!oJ..t!."..f
    16:48:20.435 0090: 20 6d 4a c1 f8 78 21 16 22 80 f8 4c 20 6b 4a c1 mJ..x!."..L kJ.
    16:48:20.435 00a0: f8 7c 21 17 22 80 f8 21 20 69 4a c1 f8 80 21 18 .|!."..! iJ...!.
    16:48:20.435 00b0: 22 80 f8 4b 20 67 4a c1 f8 84 21 19 22 82 72 66 "..K gJ...!.".rf
    16:48:20.435 00c0: 4a c1 f8 88 21 1a 22 80 f8 84 20 64 4a c1 f8 8c J...!."... dJ...
    16:48:20.435 00d0: 21 1b 22 80 f8 dd 20 62 4a c1 f8 90 21 1c 22 80 !."... bJ...!.".
    16:48:20.435 00e0: f8 40 20 60 4a c1 f8 94 21 1d 22 80 f8 5e 20 5e .@ `J...!."..^ ^
    16:48:20.435 00f0: 4a c1 f8 98 21 5d 4a c1 f8 J...!]J..
    16:48:20.466 Incoming Dump:
    16:48:20.466 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.466 --
    16:48:20.466 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.466 Parameters:
    16:48:20.466 | Number HCI commands : 0x01
    16:48:20.466 | Command Opcode : 0xff05
    16:48:20.466 | Status : 0x00 (Success)
    16:48:20.466 --
    16:48:20.466 --
    16:48:20.466 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.466 | Address : 0x200302d0
    16:48:20.466 | Size : 0xf0
    16:48:20.466 | Values : "9C:21:1F:22:80:F8:92:20:5B:4A:C1:F8:A0:21:20:22:80:F8:57:20:59:4A:C1:F8:A4:21:21:22:80:F8:55:20:57:4A:C1:F8:A8:21:22:22:80:F8:8B:20:55:4A:C1:F8:AC:21:23:22:C2:74:54:4A:C1:F8:B0:21:24:22:82:73:52:4A:C1:F8:B4:21:25:22:80:F8:D9:20:50:4A:C1:F8:B8:21:26:22:C2:71:4F:4A:C1:F8:BC:21:27:22:42:73:4D:4A:C1:F8:C0:21:28:22:82:75:4C:4A:C1:F8:C4:21:29:22:80:F8:24:20:4A:4A:C1:F8:C8:21:2A:22:82:70:48:4A:C1:F8:CC:21:2B:22:80:F8:6F:20:46:4A:C1:F8:D0:21:2C:22:42:72:45:4A:C1:F8:D4:21:2D:22:42:77:44:4A:53:73:45:4B:0B:67:56:75:82:F8:14:C0:82:F8:33:E0:43:4B:4B:67:43:4B:8B:67:3D:48:42:4B:88:66:01:20:82:F8:2D:00:88:73:40:4A:1A:60:40:4A:42:49:82:F8:00:80:88:47:3F:49:10:B1:08:46:00:78:28:B9:08:46:5E:38:80:F8:5F:50:80:F8:5E:40:BD:E8:F0:81"
    16:48:20.466 --
    16:48:20.466 Outgoing Dump:
    16:48:20.466 0000: 01 05 ff f5 d0 02 03 20 f0 9c 21 1f 22 80 f8 92 ....... ..!."...
    16:48:20.466 0010: 20 5b 4a c1 f8 a0 21 20 22 80 f8 57 20 59 4a c1 [J...! "..W YJ.
    16:48:20.466 0020: f8 a4 21 21 22 80 f8 55 20 57 4a c1 f8 a8 21 22 ..!!"..U WJ...!"
    16:48:20.466 0030: 22 80 f8 8b 20 55 4a c1 f8 ac 21 23 22 c2 74 54 "... UJ...!#".tT
    16:48:20.466 0040: 4a c1 f8 b0 21 24 22 82 73 52 4a c1 f8 b4 21 25 J...!$".sRJ...!%
    16:48:20.466 0050: 22 80 f8 d9 20 50 4a c1 f8 b8 21 26 22 c2 71 4f "... PJ...!&".qO
    16:48:20.466 0060: 4a c1 f8 bc 21 27 22 42 73 4d 4a c1 f8 c0 21 28 J...!'"BsMJ...!(
    16:48:20.466 0070: 22 82 75 4c 4a c1 f8 c4 21 29 22 80 f8 24 20 4a ".uLJ...!)"..$ J
    16:48:20.466 0080: 4a c1 f8 c8 21 2a 22 82 70 48 4a c1 f8 cc 21 2b J...!*".pHJ...!+
    16:48:20.466 0090: 22 80 f8 6f 20 46 4a c1 f8 d0 21 2c 22 42 72 45 "..o FJ...!,"BrE
    16:48:20.466 00a0: 4a c1 f8 d4 21 2d 22 42 77 44 4a 53 73 45 4b 0b J...!-"BwDJSsEK.
    16:48:20.466 00b0: 67 56 75 82 f8 14 c0 82 f8 33 e0 43 4b 4b 67 43 gVu......3.CKKgC
    16:48:20.466 00c0: 4b 8b 67 3d 48 42 4b 88 66 01 20 82 f8 2d 00 88 K.g=HBK.f. ..-..
    16:48:20.466 00d0: 73 40 4a 1a 60 40 4a 42 49 82 f8 00 80 88 47 3f s@J.`@JBI.....G?
    16:48:20.466 00e0: 49 10 b1 08 46 00 78 28 b9 08 46 5e 38 80 f8 5f I...F.x(..F^8.._
    16:48:20.466 00f0: 50 80 f8 5e 40 bd e8 f0 81 P..^@....
    16:48:20.498 Incoming Dump:
    16:48:20.498 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.498 --
    16:48:20.498 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.498 Parameters:
    16:48:20.498 | Number HCI commands : 0x01
    16:48:20.498 | Command Opcode : 0xff05
    16:48:20.498 | Status : 0x00 (Success)
    16:48:20.498 --
    16:48:20.498 --
    16:48:20.498 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.498 | Address : 0x200303c0
    16:48:20.498 | Size : 0xf0
    16:48:20.498 | Values : "CC:DC:08:20:3C:84:08:20:40:84:08:20:A3:BA:08:20:24:6F:08:20:79:BA:08:20:87:BA:08:20:B1:BA:08:20:BF:BA:08:20:13:BB:08:20:9F:BB:08:20:DB:BA:08:20:F7:BA:08:20:05:BB:08:20:C9:BB:08:20:21:BB:08:20:2F:BB:08:20:3D:BB:08:20:59:BB:08:20:67:BB:08:20:1D:BC:08:20:2B:BC:08:20:75:BB:08:20:91:BB:08:20:83:BB:08:20:4B:BB:08:20:AD:BB:08:20:D7:BB:08:20:BB:BB:08:20:55:BC:08:20:E5:BB:08:20:F3:BB:08:20:01:BC:08:20:0F:BC:08:20:63:BC:08:20:71:BC:08:20:7F:BC:08:20:8D:BC:08:20:9B:BC:08:20:A9:BC:08:20:B7:BC:08:20:C5:BC:08:20:D3:BC:08:20:E1:BC:08:20:EF:BC:08:20:FD:BC:08:20:0B:BD:08:20:19:BD:08:20:CD:BA:08:20:24:70:08:20:E9:BA:08:20:39:BC:08:20:47:BC:08:20:27:BD:08:20:BC:83:08:20:35:02:1A:00:E3:69:08:20:1E:F1:0C:20:93:E4:06:00:70:B5:91:4D"
    16:48:20.498 --
    16:48:20.498 Outgoing Dump:
    16:48:20.498 0000: 01 05 ff f5 c0 03 03 20 f0 cc dc 08 20 3c 84 08 ....... .... <..
    16:48:20.498 0010: 20 40 84 08 20 a3 ba 08 20 24 6f 08 20 79 ba 08 @.. ... $o. y..
    16:48:20.498 0020: 20 87 ba 08 20 b1 ba 08 20 bf ba 08 20 13 bb 08 ... ... ... ...
    16:48:20.498 0030: 20 9f bb 08 20 db ba 08 20 f7 ba 08 20 05 bb 08 ... ... ... ...
    16:48:20.498 0040: 20 c9 bb 08 20 21 bb 08 20 2f bb 08 20 3d bb 08 ... !.. /.. =..
    16:48:20.498 0050: 20 59 bb 08 20 67 bb 08 20 1d bc 08 20 2b bc 08 Y.. g.. ... +..
    16:48:20.498 0060: 20 75 bb 08 20 91 bb 08 20 83 bb 08 20 4b bb 08 u.. ... ... K..
    16:48:20.498 0070: 20 ad bb 08 20 d7 bb 08 20 bb bb 08 20 55 bc 08 ... ... ... U..
    16:48:20.498 0080: 20 e5 bb 08 20 f3 bb 08 20 01 bc 08 20 0f bc 08 ... ... ... ...
    16:48:20.498 0090: 20 63 bc 08 20 71 bc 08 20 7f bc 08 20 8d bc 08 c.. q.. ... ...
    16:48:20.498 00a0: 20 9b bc 08 20 a9 bc 08 20 b7 bc 08 20 c5 bc 08 ... ... ... ...
    16:48:20.498 00b0: 20 d3 bc 08 20 e1 bc 08 20 ef bc 08 20 fd bc 08 ... ... ... ...
    16:48:20.498 00c0: 20 0b bd 08 20 19 bd 08 20 cd ba 08 20 24 70 08 ... ... ... $p.
    16:48:20.498 00d0: 20 e9 ba 08 20 39 bc 08 20 47 bc 08 20 27 bd 08 ... 9.. G.. '..
    16:48:20.498 00e0: 20 bc 83 08 20 35 02 1a 00 e3 69 08 20 1e f1 0c ... 5....i. ...
    16:48:20.498 00f0: 20 93 e4 06 00 70 b5 91 4d ....p..M
    16:48:20.529 Incoming Dump:
    16:48:20.529 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.529 --
    16:48:20.529 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.529 Parameters:
    16:48:20.529 | Number HCI commands : 0x01
    16:48:20.529 | Command Opcode : 0xff05
    16:48:20.529 | Status : 0x00 (Success)
    16:48:20.529 --
    16:48:20.529 --
    16:48:20.529 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.529 | Address : 0x200304b0
    16:48:20.529 | Size : 0xf0
    16:48:20.529 | Values : "8D:20:08:22:20:23:02:26:8F:4C:E8:70:40:F2:C5:51:2A:70:6B:70:AE:70:03:20:A0:47:AA:78:EB:78:40:F2:C6:51:03:20:A0:47:93:4A:40:F2:C7:51:03:20:90:47:91:48:80:47:00:22:91:4C:11:46:54:F8:04:0F:38:B1:01:F0:0F:03:4F:F0:01:00:00:FA:03:F0:40:EA:02:02:42:B1:01:F0:0F:00:0F:28:04:D1:89:4B:08:09:23:F8:10:20:00:22:49:1C:40:29:E7:D3:86:48:00:24:04:60:44:60:84:60:C4:60:04:61:44:61:84:61:C4:61:82:48:80:47:82:4D:07:22:29:46:08:31:52:1E:01:F8:01:4B:FB:D1:14:20:68:70:7E:48:7E:49:06:70:4F:F6:FF:70:08:80:7D:48:04:70:7E:49:7C:48:7E:4E:04:70:FF:20:08:80:7D:49:A6:F8:FA:40:20:46:88:47:7B:49:08:60:7B:49:08:60:7B:49:08:60:7B:48:04:60:7B:48:04:60:7B:48:04:60:7B:48:04:60:7B:48:04:60:7B:48:04:60:7B:48:04:60:7B:48:7C:49:04:60:6F:20:08:60:7B:49"
    16:48:20.529 --
    16:48:20.529 Outgoing Dump:
    16:48:20.529 0000: 01 05 ff f5 b0 04 03 20 f0 8d 20 08 22 20 23 02 ....... .. ." #.
    16:48:20.529 0010: 26 8f 4c e8 70 40 f2 c5 51 2a 70 6b 70 ae 70 03 &.L.p@..Q*pkp.p.
    16:48:20.529 0020: 20 a0 47 aa 78 eb 78 40 f2 c6 51 03 20 a0 47 93 .G.x.x@..Q. .G.
    16:48:20.529 0030: 4a 40 f2 c7 51 03 20 90 47 91 48 80 47 00 22 91 J@..Q. .G.H.G.".
    16:48:20.529 0040: 4c 11 46 54 f8 04 0f 38 b1 01 f0 0f 03 4f f0 01 L.FT...8.....O..
    16:48:20.529 0050: 00 00 fa 03 f0 40 ea 02 02 42 b1 01 f0 0f 00 0f .....@...B......
    16:48:20.529 0060: 28 04 d1 89 4b 08 09 23 f8 10 20 00 22 49 1c 40 (...K..#.. ."I.@
    16:48:20.529 0070: 29 e7 d3 86 48 00 24 04 60 44 60 84 60 c4 60 04 )...H.$.`D`.`.`.
    16:48:20.529 0080: 61 44 61 84 61 c4 61 82 48 80 47 82 4d 07 22 29 aDa.a.a.H.G.M.")
    16:48:20.529 0090: 46 08 31 52 1e 01 f8 01 4b fb d1 14 20 68 70 7e F.1R....K... hp~
    16:48:20.529 00a0: 48 7e 49 06 70 4f f6 ff 70 08 80 7d 48 04 70 7e H~I.pO..p..}H.p~
    16:48:20.529 00b0: 49 7c 48 7e 4e 04 70 ff 20 08 80 7d 49 a6 f8 fa I|H~N.p. ..}I...
    16:48:20.529 00c0: 40 20 46 88 47 7b 49 08 60 7b 49 08 60 7b 49 08 @ F.G{I.`{I.`{I.
    16:48:20.529 00d0: 60 7b 48 04 60 7b 48 04 60 7b 48 04 60 7b 48 04 `{H.`{H.`{H.`{H.
    16:48:20.529 00e0: 60 7b 48 04 60 7b 48 04 60 7b 48 04 60 7b 48 7c `{H.`{H.`{H.`{H|
    16:48:20.529 00f0: 49 04 60 6f 20 08 60 7b 49 I.`o .`{I
    16:48:20.560 Incoming Dump:
    16:48:20.560 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.560 --
    16:48:20.560 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.560 Parameters:
    16:48:20.560 | Number HCI commands : 0x01
    16:48:20.560 | Command Opcode : 0xff05
    16:48:20.560 | Status : 0x00 (Success)
    16:48:20.560 --
    16:48:20.560 --
    16:48:20.560 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.560 | Address : 0x200305a0
    16:48:20.560 | Size : 0xf0
    16:48:20.560 | Values : "2C:70:0A:20:08:70:7A:48:04:70:01:20:86:F8:45:01:70:BD:2D:E9:FC:4F:04:46:83:48:88:46:75:4A:D0:F8:00:B0:76:4B:74:49:59:48:00:1D:00:68:02:F5:90:72:00:90:01:20:98:47:72:49:0D:20:88:47:05:46:B8:F1:00:0F:38:D0:05:F1:08:00:4F:F0:00:09:24:1F:01:90:4E:46:54:F8:04:1F:4F:F4:00:50:0F:88:8A:78:28:80:68:4B:A5:F8:04:90:41:F2:34:20:E8:80:01:98:D2:1C:98:47:48:46:4F:F6:FB:51:B9:42:08:BF:01:20:82:46:61:48:07:78:61:48:80:47:87:42:FB:D1:60:4A:29:46:48:46:90:47:BA:F1:00:0F:0A:D0:5E:4F:02:E0:5E:48:80:47:7F:1E:5D:48:00:78:00:28:18:BF:00:2F:F6:D1:76:1C:B0:45:CD:D8:5D:4A:59:48:08:21:90:47:59:49:28:46:88:47:BB:F1:00:0F:04:D0:4C:4B:00:99:5A:46:01:20:98:47:BD:E8:FC:8F:10:B5:04:46:54:48:00:78:01:28:04:D1:53:49:01:20:08:70:53:48:80:47:00:20"
    16:48:20.560 --
    16:48:20.560 Outgoing Dump:
    16:48:20.560 0000: 01 05 ff f5 a0 05 03 20 f0 2c 70 0a 20 08 70 7a ....... .,p. .pz
    16:48:20.560 0010: 48 04 70 01 20 86 f8 45 01 70 bd 2d e9 fc 4f 04 H.p. ..E.p.-..O.
    16:48:20.560 0020: 46 83 48 88 46 75 4a d0 f8 00 b0 76 4b 74 49 59 F.H.FuJ....vKtIY
    16:48:20.560 0030: 48 00 1d 00 68 02 f5 90 72 00 90 01 20 98 47 72 H...h...r... .Gr
    16:48:20.560 0040: 49 0d 20 88 47 05 46 b8 f1 00 0f 38 d0 05 f1 08 I. .G.F....8....
    16:48:20.560 0050: 00 4f f0 00 09 24 1f 01 90 4e 46 54 f8 04 1f 4f .O...$...NFT...O
    16:48:20.560 0060: f4 00 50 0f 88 8a 78 28 80 68 4b a5 f8 04 90 41 ..P...x(.hK....A
    16:48:20.560 0070: f2 34 20 e8 80 01 98 d2 1c 98 47 48 46 4f f6 fb .4 .......GHFO..
    16:48:20.560 0080: 51 b9 42 08 bf 01 20 82 46 61 48 07 78 61 48 80 Q.B... .FaH.xaH.
    16:48:20.560 0090: 47 87 42 fb d1 60 4a 29 46 48 46 90 47 ba f1 00 G.B..`J)FHF.G...
    16:48:20.560 00a0: 0f 0a d0 5e 4f 02 e0 5e 48 80 47 7f 1e 5d 48 00 ...^O..^H.G..]H.
    16:48:20.560 00b0: 78 00 28 18 bf 00 2f f6 d1 76 1c b0 45 cd d8 5d x.(.../..v..E..]
    16:48:20.560 00c0: 4a 59 48 08 21 90 47 59 49 28 46 88 47 bb f1 00 JYH.!.GYI(F.G...
    16:48:20.560 00d0: 0f 04 d0 4c 4b 00 99 5a 46 01 20 98 47 bd e8 fc ...LK..ZF. .G...
    16:48:20.560 00e0: 8f 10 b5 04 46 54 48 00 78 01 28 04 d1 53 49 01 ....FTH.x.(..SI.
    16:48:20.560 00f0: 20 08 70 53 48 80 47 00 20 .pSH.G.
    16:48:20.591 Incoming Dump:
    16:48:20.591 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.591 --
    16:48:20.591 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.591 Parameters:
    16:48:20.591 | Number HCI commands : 0x01
    16:48:20.591 | Command Opcode : 0xff05
    16:48:20.591 | Status : 0x00 (Success)
    16:48:20.591 --
    16:48:20.591 --
    16:48:20.591 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.591 | Address : 0x20030690
    16:48:20.591 | Size : 0xf0
    16:48:20.591 | Values : "20:60:52:48:16:30:10:BD:3F:B5:00:24:50:4D:51:49:AD:F8:04:40:00:94:28:46:88:47:24:48:90:F8:36:30:1B:B1:C2:6B:01:6C:91:42:17:D9:90:F8:34:10:39:B1:33:B1:41:8F:00:8F:88:42:C4:BF:AD:F8:04:10:00:94:22:46:45:4C:02:AB:64:21:28:46:A0:47:43:48:45:4C:03:78:43:48:02:AA:69:46:A0:47:43:48:84:30:00:90:3F:BD:C0:46:38:84:08:20:09:C7:07:00:00:B5:3F:49:02:20:88:47:3E:49:FF:20:08:70:3E:49:01:20:88:47:3D:49:50:20:08:80:08:88:C0:09:FC:D2:2E:48:58:30:00:BD:C0:46:03:C8:07:00:55:01:03:20:FC:0E:09:20:80:81:0B:20:08:20:00:E0:D9:7B:03:20:80:DC:08:20:D1:DC:08:20:DE:DC:08:20:D2:DC:08:20:D3:DC:08:20:2C:01:04:20:24:69:08:20:81:9F:08:00:FC:DC:08:20:00:DD:08:20:24:DD:08:20:04:DD:08:20:08:DD:08:20:0C:DD:08:20:10:DD:08:20:14:DD:08:20:18:DD:08:20"
    16:48:20.591 --
    16:48:20.591 Outgoing Dump:
    16:48:20.591 0000: 01 05 ff f5 90 06 03 20 f0 20 60 52 48 16 30 10 ....... . `RH.0.
    16:48:20.591 0010: bd 3f b5 00 24 50 4d 51 49 ad f8 04 40 00 94 28 .?..$PMQI...@..(
    16:48:20.591 0020: 46 88 47 24 48 90 f8 36 30 1b b1 c2 6b 01 6c 91 F.G$H..60...k.l.
    16:48:20.591 0030: 42 17 d9 90 f8 34 10 39 b1 33 b1 41 8f 00 8f 88 B....4.9.3.A....
    16:48:20.591 0040: 42 c4 bf ad f8 04 10 00 94 22 46 45 4c 02 ab 64 B........"FEL..d
    16:48:20.591 0050: 21 28 46 a0 47 43 48 45 4c 03 78 43 48 02 aa 69 !(F.GCHEL.xCH..i
    16:48:20.591 0060: 46 a0 47 43 48 84 30 00 90 3f bd c0 46 38 84 08 F.GCH.0..?..F8..
    16:48:20.591 0070: 20 09 c7 07 00 00 b5 3f 49 02 20 88 47 3e 49 ff ......?I. .G>I.
    16:48:20.591 0080: 20 08 70 3e 49 01 20 88 47 3d 49 50 20 08 80 08 .p>I. .G=IP ...
    16:48:20.591 0090: 88 c0 09 fc d2 2e 48 58 30 00 bd c0 46 03 c8 07 ......HX0...F...
    16:48:20.591 00a0: 00 55 01 03 20 fc 0e 09 20 80 81 0b 20 08 20 00 .U.. ... ... . .
    16:48:20.591 00b0: e0 d9 7b 03 20 80 dc 08 20 d1 dc 08 20 de dc 08 ..{. ... ... ...
    16:48:20.591 00c0: 20 d2 dc 08 20 d3 dc 08 20 2c 01 04 20 24 69 08 ... ... ,.. $i.
    16:48:20.591 00d0: 20 81 9f 08 00 fc dc 08 20 00 dd 08 20 24 dd 08 ....... ... $..
    16:48:20.591 00e0: 20 04 dd 08 20 08 dd 08 20 0c dd 08 20 10 dd 08 ... ... ... ...
    16:48:20.591 00f0: 20 14 dd 08 20 18 dd 08 20 ... ...
    16:48:20.623 Incoming Dump:
    16:48:20.623 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.623 --
    16:48:20.623 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.623 Parameters:
    16:48:20.623 | Number HCI commands : 0x01
    16:48:20.623 | Command Opcode : 0xff05
    16:48:20.623 | Status : 0x00 (Success)
    16:48:20.623 --
    16:48:20.623 --
    16:48:20.623 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.623 | Address : 0x20030780
    16:48:20.623 | Size : 0x8c
    16:48:20.623 | Values : "1C:DD:08:20:20:DD:08:20:FC:82:08:20:D8:DC:08:20:D9:DC:08:20:85:3D:04:00:01:DA:08:20:ED:D3:08:20:07:0E:03:00:C9:E8:08:00:A0:82:08:20:8D:0F:08:00:29:88:08:00:00:09:3D:00:93:DA:05:00:65:76:08:20:02:10:0E:20:B7:08:03:00:80:80:0B:20:D1:2B:08:00:71:2A:08:20:B5:DC:08:20:09:F5:02:00:DD:EA:02:00:60:7A:08:20:95:1A:06:00:31:20:06:00:91:81:08:20:E0:7C:08:20:37:D9:02:00:81:F4:02:00:6B:1B:06:00:5E:81:08:20:27:F0:02:00:0A:E0:02:20"
    16:48:20.623 --
    16:48:20.623 Outgoing Dump:
    16:48:20.623 0000: 01 05 ff 91 80 07 03 20 8c 1c dd 08 20 20 dd 08 ....... .... ..
    16:48:20.623 0010: 20 fc 82 08 20 d8 dc 08 20 d9 dc 08 20 85 3d 04 ... ... ... .=.
    16:48:20.623 0020: 00 01 da 08 20 ed d3 08 20 07 0e 03 00 c9 e8 08 .... ... .......
    16:48:20.623 0030: 00 a0 82 08 20 8d 0f 08 00 29 88 08 00 00 09 3d .... ....).....=
    16:48:20.623 0040: 00 93 da 05 00 65 76 08 20 02 10 0e 20 b7 08 03 .....ev. ... ...
    16:48:20.623 0050: 00 80 80 0b 20 d1 2b 08 00 71 2a 08 20 b5 dc 08 .... .+..q*. ...
    16:48:20.623 0060: 20 09 f5 02 00 dd ea 02 00 60 7a 08 20 95 1a 06 ........`z. ...
    16:48:20.623 0070: 00 31 20 06 00 91 81 08 20 e0 7c 08 20 37 d9 02 .1 ..... .|. 7..
    16:48:20.623 0080: 00 81 f4 02 00 6b 1b 06 00 5e 81 08 20 27 f0 02 .....k...^.. '..
    16:48:20.623 0090: 00 0a e0 02 20 ....
    16:48:20.638 Incoming Dump:
    16:48:20.638 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.638 --
    16:48:20.638 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.638 Parameters:
    16:48:20.638 | Number HCI commands : 0x01
    16:48:20.638 | Command Opcode : 0xff05
    16:48:20.638 | Status : 0x00 (Success)
    16:48:20.638 --
    16:48:20.638 --
    16:48:20.638 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.638 | Address : 0x20037bd8
    16:48:20.638 | Size : 0xf0
    16:48:20.638 | Values : "2D:E9:F0:4F:80:20:77:4C:77:4E:20:80:77:4B:70:79:00:25:08:22:41:10:A5:80:20:46:98:47:74:4B:20:46:71:78:08:22:00:1D:98:47:DF:F8:F4:A1:71:4F:72:49:50:46:48:30:00:88:40:F4:80:50:78:52:6F:49:08:88:80:09:02:D3:08:88:40:09:03:D2:38:88:40:F0:04:00:38:80:6C:48:6A:4E:00:88:40:08:2C:BF:02:20:28:1C:69:4C:6A:4B:B6:F8:66:13:0C:22:01:F0:01:01:01:43:04:F1:A4:00:98:47:DF:F8:9C:B1:DF:F8:14:82:64:48:02:21:05:70:58:46:08:38:C0:47:DF:F8:8C:91:47:F2:07:71:4F:F6:0F:72:58:46:C8:47:58:46:5F:4B:2A:46:07:21:80:1C:98:47:05:21:50:46:C0:47:DF:F8:78:A1:DF:F8:70:81:04:21:50:46:80:1C:C0:47:40:F2:4A:41:43:F6:FF:72:50:46:C8:47:37:21:50:46:80:1E:C0:47:56:48:4F:F0:01:08:80:F8:01:51:80:F8:92:80:54:48:05:70:54:48:08:21:4F:F0:0A:09:81:81:A0:F8:0A:90"
    16:48:20.638 --
    16:48:20.638 Outgoing Dump:
    16:48:20.638 0000: 01 05 ff f5 d8 7b 03 20 f0 2d e9 f0 4f 80 20 77 .....{. .-..O. w
    16:48:20.638 0010: 4c 77 4e 20 80 77 4b 70 79 00 25 08 22 41 10 a5 LwN .wKpy.%."A..
    16:48:20.638 0020: 80 20 46 98 47 74 4b 20 46 71 78 08 22 00 1d 98 . F.GtK Fqx."...
    16:48:20.638 0030: 47 df f8 f4 a1 71 4f 72 49 50 46 48 30 00 88 40 G....qOrIPFH0..@
    16:48:20.638 0040: f4 80 50 78 52 6f 49 08 88 80 09 02 d3 08 88 40 ..PxRoI........@
    16:48:20.638 0050: 09 03 d2 38 88 40 f0 04 00 38 80 6c 48 6a 4e 00 ...8.@...8.lHjN.
    16:48:20.638 0060: 88 40 08 2c bf 02 20 28 1c 69 4c 6a 4b b6 f8 66 .@.,.. (.iLjK..f
    16:48:20.638 0070: 13 0c 22 01 f0 01 01 01 43 04 f1 a4 00 98 47 df ..".....C.....G.
    16:48:20.638 0080: f8 9c b1 df f8 14 82 64 48 02 21 05 70 58 46 08 .......dH.!.pXF.
    16:48:20.638 0090: 38 c0 47 df f8 8c 91 47 f2 07 71 4f f6 0f 72 58 8.G....G..qO..rX
    16:48:20.638 00a0: 46 c8 47 58 46 5f 4b 2a 46 07 21 80 1c 98 47 05 F.GXF_K*F.!...G.
    16:48:20.638 00b0: 21 50 46 c0 47 df f8 78 a1 df f8 70 81 04 21 50 !PF.G..x...p..!P
    16:48:20.638 00c0: 46 80 1c c0 47 40 f2 4a 41 43 f6 ff 72 50 46 c8 F...G@.JAC..rPF.
    16:48:20.638 00d0: 47 37 21 50 46 80 1e c0 47 56 48 4f f0 01 08 80 G7!PF...GVHO....
    16:48:20.638 00e0: f8 01 51 80 f8 92 80 54 48 05 70 54 48 08 21 4f ..Q....TH.pTH.!O
    16:48:20.638 00f0: f0 0a 09 81 81 a0 f8 0a 90 .........
    16:48:20.669 Incoming Dump:
    16:48:20.669 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.669 --
    16:48:20.669 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.669 Parameters:
    16:48:20.669 | Number HCI commands : 0x01
    16:48:20.669 | Command Opcode : 0xff05
    16:48:20.669 | Status : 0x00 (Success)
    16:48:20.669 --
    16:48:20.669 --
    16:48:20.669 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.669 | Address : 0x20037cc8
    16:48:20.669 | Size : 0xf0
    16:48:20.669 | Values : "51:48:41:69:41:F0:30:03:50:49:51:4A:81:F8:00:80:78:21:11:70:23:F0:01:01:B4:F8:A4:20:41:61:4D:49:B6:F8:62:03:C0:F3:01:20:08:70:4F:F6:FC:71:00:F0:03:00:11:40:A4:F8:A4:10:01:43:47:48:A4:F8:A4:10:80:47:58:4A:38:46:29:46:90:47:39:88:43:48:08:43:38:80:43:48:43:49:80:F8:00:80:08:88:20:F0:30:00:08:80:08:88:C0:F3:01:10:3F:49:40:4F:08:70:40:49:38:68:81:42:02:D0:3F:49:81:42:0B:D1:30:88:20:F4:7C:50:40:F4:A0:50:30:80:F0:88:20:F4:7C:50:40:F4:A0:50:F0:80:38:48:80:47:38:48:80:F8:00:80:38:48:05:70:38:48:38:49:05:70:4F:F0:09:00:08:70:4F:F0:59:00:36:49:84:F8:50:00:4F:F0:32:00:84:F8:51:00:4F:F0:28:00:84:F8:52:00:4F:F4:A0:70:08:80:30:49:48:46:08:60:2F:49:4F:F0:FF:00:08:70:2E:48:05:70:2E:48:00:78:18:B1:F8:7F:08:B9:87:F8:21:50:BD:E8"
    16:48:20.669 --
    16:48:20.669 Outgoing Dump:
    16:48:20.669 0000: 01 05 ff f5 c8 7c 03 20 f0 51 48 41 69 41 f0 30 .....|. .QHAiA.0
    16:48:20.669 0010: 03 50 49 51 4a 81 f8 00 80 78 21 11 70 23 f0 01 .PIQJ....x!.p#..
    16:48:20.669 0020: 01 b4 f8 a4 20 41 61 4d 49 b6 f8 62 03 c0 f3 01 .... AaMI..b....
    16:48:20.669 0030: 20 08 70 4f f6 fc 71 00 f0 03 00 11 40 a4 f8 a4 .pO..q.....@...
    16:48:20.669 0040: 10 01 43 47 48 a4 f8 a4 10 80 47 58 4a 38 46 29 ..CGH.....GXJ8F)
    16:48:20.669 0050: 46 90 47 39 88 43 48 08 43 38 80 43 48 43 49 80 F.G9.CH.C8.CHCI.
    16:48:20.669 0060: f8 00 80 08 88 20 f0 30 00 08 80 08 88 c0 f3 01 ..... .0........
    16:48:20.669 0070: 10 3f 49 40 4f 08 70 40 49 38 68 81 42 02 d0 3f .?I@O.p@I8h.B..?
    16:48:20.669 0080: 49 81 42 0b d1 30 88 20 f4 7c 50 40 f4 a0 50 30 I.B..0. .|P@..P0
    16:48:20.669 0090: 80 f0 88 20 f4 7c 50 40 f4 a0 50 f0 80 38 48 80 ... .|P@..P..8H.
    16:48:20.669 00a0: 47 38 48 80 f8 00 80 38 48 05 70 38 48 38 49 05 G8H....8H.p8H8I.
    16:48:20.669 00b0: 70 4f f0 09 00 08 70 4f f0 59 00 36 49 84 f8 50 pO....pO.Y.6I..P
    16:48:20.669 00c0: 00 4f f0 32 00 84 f8 51 00 4f f0 28 00 84 f8 52 .O.2...Q.O.(...R
    16:48:20.669 00d0: 00 4f f4 a0 70 08 80 30 49 48 46 08 60 2f 49 4f .O..p..0IHF.`/IO
    16:48:20.669 00e0: f0 ff 00 08 70 2e 48 05 70 2e 48 00 78 18 b1 f8 ....p.H.p.H.x...
    16:48:20.669 00f0: 7f 08 b9 87 f8 21 50 bd e8 .....!P..
    16:48:20.701 Incoming Dump:
    16:48:20.701 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.701 --
    16:48:20.701 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.701 Parameters:
    16:48:20.701 | Number HCI commands : 0x01
    16:48:20.701 | Command Opcode : 0xff05
    16:48:20.701 | Status : 0x00 (Success)
    16:48:20.701 --
    16:48:20.701 --
    16:48:20.701 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.701 | Address : 0x20037db8
    16:48:20.701 | Size : 0xf0
    16:48:20.701 | Values : "F0:8F:C0:46:02:B0:01:20:BE:77:08:20:31:2B:08:00:1F:2B:08:00:78:61:0E:20:E0:FE:FF:FF:00:80:0B:20:B4:22:0C:20:1A:26:0C:20:00:01:01:20:8B:2B:08:00:ED:9F:08:20:0A:30:0E:20:79:2C:08:00:55:2B:08:00:10:60:0E:20:19:2B:08:00:02:0F:0E:20:20:6E:08:20:0D:6A:08:20:A8:77:03:20:E8:82:08:20:48:83:08:20:49:83:08:20:D2:77:08:20:39:16:04:00:00:C0:FF:FF:97:7C:08:20:20:F5:0E:20:D0:DC:08:20:04:78:08:20:00:F8:24:01:00:B2:00:02:2D:1F:1A:00:CA:DC:08:20:D4:DC:08:20:D5:DC:08:20:5F:A5:08:20:F8:A6:08:20:E0:DC:08:20:CC:DC:08:20:5C:84:08:20:BB:77:08:20:ED:2B:08:00:D1:2B:08:00:30:B5:13:49:05:46:0D:20:88:47:04:46:4F:F4:00:51:00:20:A0:80:21:80:41:F2:34:21:E1:80:4F:F6:92:51:21:81:03:21:A1:72:01:21:E1:72:0A:4A:25:73:21:46:60:73:90:47:08:49:20:46"
    16:48:20.701 --
    16:48:20.701 Outgoing Dump:
    16:48:20.701 0000: 01 05 ff f5 b8 7d 03 20 f0 f0 8f c0 46 02 b0 01 .....}. ....F...
    16:48:20.701 0010: 20 be 77 08 20 31 2b 08 00 1f 2b 08 00 78 61 0e .w. 1+...+..xa.
    16:48:20.701 0020: 20 e0 fe ff ff 00 80 0b 20 b4 22 0c 20 1a 26 0c ....... .". .&.
    16:48:20.701 0030: 20 00 01 01 20 8b 2b 08 00 ed 9f 08 20 0a 30 0e ... .+..... .0.
    16:48:20.701 0040: 20 79 2c 08 00 55 2b 08 00 10 60 0e 20 19 2b 08 y,..U+...`. .+.
    16:48:20.701 0050: 00 02 0f 0e 20 20 6e 08 20 0d 6a 08 20 a8 77 03 .... n. .j. .w.
    16:48:20.701 0060: 20 e8 82 08 20 48 83 08 20 49 83 08 20 d2 77 08 ... H.. I.. .w.
    16:48:20.701 0070: 20 39 16 04 00 00 c0 ff ff 97 7c 08 20 20 f5 0e 9........|. ..
    16:48:20.701 0080: 20 d0 dc 08 20 04 78 08 20 00 f8 24 01 00 b2 00 ... .x. ..$....
    16:48:20.701 0090: 02 2d 1f 1a 00 ca dc 08 20 d4 dc 08 20 d5 dc 08 .-...... ... ...
    16:48:20.701 00a0: 20 5f a5 08 20 f8 a6 08 20 e0 dc 08 20 cc dc 08 _.. ... ... ...
    16:48:20.701 00b0: 20 5c 84 08 20 bb 77 08 20 ed 2b 08 00 d1 2b 08 \.. .w. .+...+.
    16:48:20.701 00c0: 00 30 b5 13 49 05 46 0d 20 88 47 04 46 4f f4 00 .0..I.F. .G.FO..
    16:48:20.701 00d0: 51 00 20 a0 80 21 80 41 f2 34 21 e1 80 4f f6 92 Q. ..!.A.4!..O..
    16:48:20.701 00e0: 51 21 81 03 21 a1 72 01 21 e1 72 0a 4a 25 73 21 Q!..!.r.!.r.J%s!
    16:48:20.701 00f0: 46 60 73 90 47 08 49 20 46 F`s.G.I F
    16:48:20.732 Incoming Dump:
    16:48:20.732 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.732 --
    16:48:20.732 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.732 Parameters:
    16:48:20.732 | Number HCI commands : 0x01
    16:48:20.732 | Command Opcode : 0xff05
    16:48:20.732 | Status : 0x00 (Success)
    16:48:20.732 --
    16:48:20.732 --
    16:48:20.732 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.732 | Address : 0x20037ea8
    16:48:20.732 | Size : 0xf0
    16:48:20.732 | Values : "88:47:30:BD:07:49:03:22:00:20:48:81:52:1E:01:F5:8A:71:FA:D1:70:47:C0:46:07:0E:03:00:29:88:08:00:B7:08:03:00:C0:2A:03:20:00:00:00:00:00:00:00:00:00:00:00:00:17:88:03:20:00:00:00:00:00:00:00:00:00:00:00:00:80:7F:03:20:90:7F:03:20:A0:7F:03:20:B0:7F:03:20:C0:7F:03:20:D0:7F:03:20:E0:7F:03:20:F0:7F:03:20:00:80:03:20:10:80:03:20:20:80:03:20:30:80:03:20:C8:80:03:20:60:81:03:20:F8:81:03:20:90:82:03:20:28:83:03:20:C0:83:03:20:58:84:03:20:F0:84:03:20:88:85:03:20:A0:85:03:20:B8:85:03:20:D0:85:03:20:E8:85:03:20:00:86:03:20:18:86:03:20:24:86:03:20:58:86:03:20:70:86:03:20:7C:86:03:20:94:86:03:20:A0:86:03:20:AC:86:03:20:B8:86:03:20:C4:86:03:20:D0:86:03:20:82:FD:0C:00:D3:DC:E5:EE:F7:00:0A:14:3F:FF:00:C0:82:FD:0C:03:D3:DC:E5:EE"
    16:48:20.732 --
    16:48:20.732 Outgoing Dump:
    16:48:20.732 0000: 01 05 ff f5 a8 7e 03 20 f0 88 47 30 bd 07 49 03 .....~. ..G0..I.
    16:48:20.732 0010: 22 00 20 48 81 52 1e 01 f5 8a 71 fa d1 70 47 c0 ". H.R....q..pG.
    16:48:20.732 0020: 46 07 0e 03 00 29 88 08 00 b7 08 03 00 c0 2a 03 F....)........*.
    16:48:20.732 0030: 20 00 00 00 00 00 00 00 00 00 00 00 00 17 88 03 ...............
    16:48:20.732 0040: 20 00 00 00 00 00 00 00 00 00 00 00 00 80 7f 03 ...............
    16:48:20.732 0050: 20 90 7f 03 20 a0 7f 03 20 b0 7f 03 20 c0 7f 03 ... ... ... ...
    16:48:20.732 0060: 20 d0 7f 03 20 e0 7f 03 20 f0 7f 03 20 00 80 03 ... ... ... ...
    16:48:20.732 0070: 20 10 80 03 20 20 80 03 20 30 80 03 20 c8 80 03 ... .. 0.. ...
    16:48:20.732 0080: 20 60 81 03 20 f8 81 03 20 90 82 03 20 28 83 03 `.. ... ... (..
    16:48:20.732 0090: 20 c0 83 03 20 58 84 03 20 f0 84 03 20 88 85 03 ... X.. ... ...
    16:48:20.732 00a0: 20 a0 85 03 20 b8 85 03 20 d0 85 03 20 e8 85 03 ... ... ... ...
    16:48:20.732 00b0: 20 00 86 03 20 18 86 03 20 24 86 03 20 58 86 03 ... ... $.. X..
    16:48:20.732 00c0: 20 70 86 03 20 7c 86 03 20 94 86 03 20 a0 86 03 p.. |.. ... ...
    16:48:20.732 00d0: 20 ac 86 03 20 b8 86 03 20 c4 86 03 20 d0 86 03 ... ... ... ...
    16:48:20.732 00e0: 20 82 fd 0c 00 d3 dc e5 ee f7 00 0a 14 3f ff 00 ............?..
    16:48:20.732 00f0: c0 82 fd 0c 03 d3 dc e5 ee .........
    16:48:20.763 Incoming Dump:
    16:48:20.763 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.763 --
    16:48:20.763 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.763 Parameters:
    16:48:20.763 | Number HCI commands : 0x01
    16:48:20.763 | Command Opcode : 0xff05
    16:48:20.763 | Status : 0x00 (Success)
    16:48:20.763 --
    16:48:20.763 --
    16:48:20.763 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.763 | Address : 0x20037f98
    16:48:20.763 | Size : 0xf0
    16:48:20.763 | Values : "F7:00:0A:14:3F:FF:00:C0:82:FD:0C:04:D3:DC:E5:EE:F7:00:0A:14:3F:FF:00:C0:82:FD:0C:01:CE:D7:E0:E9:F2:FC:06:10:3F:FF:00:C0:82:FD:0C:02:CE:D7:E0:E9:F2:FC:06:10:3F:FF:00:C0:82:FD:0C:08:D9:E3:ED:F7:01:0B:15:1F:3F:FF:00:C0:82:FD:0C:09:D4:DE:E8:F2:FC:06:10:1A:3F:FF:00:C0:82:FD:0C:0A:D9:E3:ED:F7:01:0B:15:1F:3F:FF:00:C0:82:FD:0C:0B:D3:DC:E5:EE:F7:00:0A:14:3F:FF:00:C0:82:FD:0C:0C:D3:DC:E5:EE:F7:00:0A:14:3F:FF:00:C0:87:FD:0A:05:05:05:05:05:04:05:04:04:04:C0:46:C0:24:FD:93:00:00:02:8C:00:00:00:00:00:00:00:37:77:71:DD:DD:DC:77:77:1D:DC:77:71:DD:C7:1D:C7:1C:71:C1:C7:01:C0:1C:00:00:00:00:0D:00:0D:03:40:D0:D0:D0:D3:74:DD:DD:DC:71:C1:C0:00:00:D0:DD:31:DC:07:0D:0D:31:C0:00:DD:C0:03:77:00:DD:C3:70:30:00:48:00:48:00:00:00:00:00:03"
    16:48:20.763 --
    16:48:20.763 Outgoing Dump:
    16:48:20.763 0000: 01 05 ff f5 98 7f 03 20 f0 f7 00 0a 14 3f ff 00 ....... .....?..
    16:48:20.763 0010: c0 82 fd 0c 04 d3 dc e5 ee f7 00 0a 14 3f ff 00 .............?..
    16:48:20.763 0020: c0 82 fd 0c 01 ce d7 e0 e9 f2 fc 06 10 3f ff 00 .............?..
    16:48:20.763 0030: c0 82 fd 0c 02 ce d7 e0 e9 f2 fc 06 10 3f ff 00 .............?..
    16:48:20.763 0040: c0 82 fd 0c 08 d9 e3 ed f7 01 0b 15 1f 3f ff 00 .............?..
    16:48:20.763 0050: c0 82 fd 0c 09 d4 de e8 f2 fc 06 10 1a 3f ff 00 .............?..
    16:48:20.763 0060: c0 82 fd 0c 0a d9 e3 ed f7 01 0b 15 1f 3f ff 00 .............?..
    16:48:20.763 0070: c0 82 fd 0c 0b d3 dc e5 ee f7 00 0a 14 3f ff 00 .............?..
    16:48:20.763 0080: c0 82 fd 0c 0c d3 dc e5 ee f7 00 0a 14 3f ff 00 .............?..
    16:48:20.763 0090: c0 87 fd 0a 05 05 05 05 05 04 05 04 04 04 c0 46 ...............F
    16:48:20.763 00a0: c0 24 fd 93 00 00 02 8c 00 00 00 00 00 00 00 37 .$.............7
    16:48:20.763 00b0: 77 71 dd dd dc 77 77 1d dc 77 71 dd c7 1d c7 1c wq...ww..wq.....
    16:48:20.763 00c0: 71 c1 c7 01 c0 1c 00 00 00 00 0d 00 0d 03 40 d0 q.............@.
    16:48:20.763 00d0: d0 d0 d3 74 dd dd dc 71 c1 c0 00 00 d0 dd 31 dc ...t...q......1.
    16:48:20.763 00e0: 07 0d 0d 31 c0 00 dd c0 03 77 00 dd c3 70 30 00 ...1.....w...p0.
    16:48:20.763 00f0: 48 00 48 00 00 00 00 00 03 H.H......
    16:48:20.794 Incoming Dump:
    16:48:20.794 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.794 --
    16:48:20.794 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.794 Parameters:
    16:48:20.794 | Number HCI commands : 0x01
    16:48:20.794 | Command Opcode : 0xff05
    16:48:20.794 | Status : 0x00 (Success)
    16:48:20.794 --
    16:48:20.794 --
    16:48:20.794 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.794 | Address : 0x20038088
    16:48:20.794 | Size : 0xf0
    16:48:20.794 | Values : "40:35:C0:0D:0D:00:D0:34:34:D3:43:43:4D:34:DD:37:4D:DD:DC:71:DC:77:07:1C:00:77:1D:C1:C7:77:1C:01:C0:77:77:70:00:70:1D:C1:C7:71:DD:D3:4D:0D:DD:00:DD:00:07:07:03:40:D3:50:CD:20:20:00:00:00:C0:46:24:FD:93:00:01:02:8C:00:00:00:00:00:00:00:37:77:71:DD:DD:DC:77:77:1D:DC:77:71:DD:C7:1D:C7:1C:71:C1:C7:01:C0:1C:00:00:00:00:0D:00:0D:03:40:D0:D0:D0:D3:74:DD:DD:DC:71:C1:C0:00:00:D0:DD:31:DC:07:0D:0D:31:C0:00:DD:C0:03:77:00:DD:C3:70:30:00:48:00:48:00:00:00:00:00:03:40:35:C0:0D:0D:00:D0:34:34:D3:43:43:4D:34:DD:37:4D:DD:DC:71:DC:77:07:1C:00:77:1D:C1:C7:77:1C:01:C0:77:77:70:00:70:1D:C1:C7:71:DD:D3:4D:0D:DD:00:DD:00:07:07:03:40:D3:50:CD:20:20:00:00:00:C0:46:24:FD:93:00:02:02:8C:00:00:00:00:00:00:00:37:77:71:DD:DD:DC:77:77:1D:DC"
    16:48:20.794 --
    16:48:20.794 Outgoing Dump:
    16:48:20.794 0000: 01 05 ff f5 88 80 03 20 f0 40 35 c0 0d 0d 00 d0 ....... .@5.....
    16:48:20.794 0010: 34 34 d3 43 43 4d 34 dd 37 4d dd dc 71 dc 77 07 44.CCM4.7M..q.w.
    16:48:20.794 0020: 1c 00 77 1d c1 c7 77 1c 01 c0 77 77 70 00 70 1d ..w...w...wwp.p.
    16:48:20.794 0030: c1 c7 71 dd d3 4d 0d dd 00 dd 00 07 07 03 40 d3 ..q..M........@.
    16:48:20.794 0040: 50 cd 20 20 00 00 00 c0 46 24 fd 93 00 01 02 8c P. ....F$......
    16:48:20.794 0050: 00 00 00 00 00 00 00 37 77 71 dd dd dc 77 77 1d .......7wq...ww.
    16:48:20.794 0060: dc 77 71 dd c7 1d c7 1c 71 c1 c7 01 c0 1c 00 00 .wq.....q.......
    16:48:20.794 0070: 00 00 0d 00 0d 03 40 d0 d0 d0 d3 74 dd dd dc 71 ......@....t...q
    16:48:20.794 0080: c1 c0 00 00 d0 dd 31 dc 07 0d 0d 31 c0 00 dd c0 ......1....1....
    16:48:20.794 0090: 03 77 00 dd c3 70 30 00 48 00 48 00 00 00 00 00 .w...p0.H.H.....
    16:48:20.794 00a0: 03 40 35 c0 0d 0d 00 d0 34 34 d3 43 43 4d 34 dd .@5.....44.CCM4.
    16:48:20.794 00b0: 37 4d dd dc 71 dc 77 07 1c 00 77 1d c1 c7 77 1c 7M..q.w...w...w.
    16:48:20.794 00c0: 01 c0 77 77 70 00 70 1d c1 c7 71 dd d3 4d 0d dd ..wwp.p...q..M..
    16:48:20.794 00d0: 00 dd 00 07 07 03 40 d3 50 cd 20 20 00 00 00 c0 ......@.P. ....
    16:48:20.794 00e0: 46 24 fd 93 00 02 02 8c 00 00 00 00 00 00 00 37 F$.............7
    16:48:20.794 00f0: 77 71 dd dd dc 77 77 1d dc wq...ww..
    16:48:20.826 Incoming Dump:
    16:48:20.826 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.826 --
    16:48:20.826 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.826 Parameters:
    16:48:20.826 | Number HCI commands : 0x01
    16:48:20.826 | Command Opcode : 0xff05
    16:48:20.826 | Status : 0x00 (Success)
    16:48:20.826 --
    16:48:20.826 --
    16:48:20.826 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.826 | Address : 0x20038178
    16:48:20.826 | Size : 0xf0
    16:48:20.826 | Values : "77:71:DD:C7:1D:C7:1C:71:C1:C7:01:C0:1C:00:00:00:00:0D:00:0D:03:40:D0:D0:D0:D3:74:DD:DD:DC:71:C1:C0:00:00:D0:DD:31:DC:07:0D:0D:31:C0:00:DD:C0:03:77:00:DD:C3:70:30:00:48:00:48:00:00:00:00:00:03:40:35:C0:0D:0D:00:D0:34:34:D3:43:43:4D:34:DD:37:4D:DD:DC:71:DC:77:07:1C:00:77:1D:C1:C7:77:1C:01:C0:77:77:70:00:70:1D:C1:C7:71:DD:D3:4D:0D:DD:00:DD:00:07:07:03:40:D3:50:CD:20:20:00:00:00:C0:46:24:FD:93:01:00:02:8C:00:00:00:00:00:00:00:C0:70:00:1C:00:00:1C:00:00:00:07:00:00:00:00:00:0D:00:00:03:40:03:40:0D:00:34:0D:0D:34:D3:4D:D3:77:77:71:C7:1C:1C:07:00:00:00:00:00:0D:03:4D:37:77:1C:1C:00:34:34:C7:70:00:03:77:70:0D:37:00:30:00:28:00:28:00:07:00:00:00:0D:03:40:03:40:D0:34:00:D0:0D:D3:77:74:03:40:34:00:34:DC:74:DD:0D:D0:DD:34"
    16:48:20.826 --
    16:48:20.826 Outgoing Dump:
    16:48:20.826 0000: 01 05 ff f5 78 81 03 20 f0 77 71 dd c7 1d c7 1c ....x.. .wq.....
    16:48:20.826 0010: 71 c1 c7 01 c0 1c 00 00 00 00 0d 00 0d 03 40 d0 q.............@.
    16:48:20.826 0020: d0 d0 d3 74 dd dd dc 71 c1 c0 00 00 d0 dd 31 dc ...t...q......1.
    16:48:20.826 0030: 07 0d 0d 31 c0 00 dd c0 03 77 00 dd c3 70 30 00 ...1.....w...p0.
    16:48:20.826 0040: 48 00 48 00 00 00 00 00 03 40 35 c0 0d 0d 00 d0 H.H......@5.....
    16:48:20.826 0050: 34 34 d3 43 43 4d 34 dd 37 4d dd dc 71 dc 77 07 44.CCM4.7M..q.w.
    16:48:20.826 0060: 1c 00 77 1d c1 c7 77 1c 01 c0 77 77 70 00 70 1d ..w...w...wwp.p.
    16:48:20.826 0070: c1 c7 71 dd d3 4d 0d dd 00 dd 00 07 07 03 40 d3 ..q..M........@.
    16:48:20.826 0080: 50 cd 20 20 00 00 00 c0 46 24 fd 93 01 00 02 8c P. ....F$......
    16:48:20.826 0090: 00 00 00 00 00 00 00 c0 70 00 1c 00 00 1c 00 00 ........p.......
    16:48:20.826 00a0: 00 07 00 00 00 00 00 0d 00 00 03 40 03 40 0d 00 ...........@.@..
    16:48:20.826 00b0: 34 0d 0d 34 d3 4d d3 77 77 71 c7 1c 1c 07 00 00 4..4.M.wwq......
    16:48:20.826 00c0: 00 00 00 0d 03 4d 37 77 1c 1c 00 34 34 c7 70 00 .....M7w...44.p.
    16:48:20.826 00d0: 03 77 70 0d 37 00 30 00 28 00 28 00 07 00 00 00 .wp.7.0.(.(.....
    16:48:20.826 00e0: 0d 03 40 03 40 d0 34 00 d0 0d d3 77 74 03 40 34 ..@.@.4....wt.@4
    16:48:20.826 00f0: 00 34 dc 74 dd 0d d0 dd 34 .4.t....4
    16:48:20.857 Incoming Dump:
    16:48:20.857 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.857 --
    16:48:20.857 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.857 Parameters:
    16:48:20.857 | Number HCI commands : 0x01
    16:48:20.857 | Command Opcode : 0xff05
    16:48:20.857 | Status : 0x00 (Success)
    16:48:20.857 --
    16:48:20.857 --
    16:48:20.857 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.857 | Address : 0x20038268
    16:48:20.857 | Size : 0xf0
    16:48:20.857 | Values : "0D:0D:D3:4D:DD:34:D0:DD:C7:74:DD:37:4D:C7:1C:1C:74:DD:34:DC:1D:DD:DD:00:00:37:77:77:06:FE:47:77:40:D0:00:00:00:00:C0:46:24:FD:93:01:01:02:8C:00:00:00:00:00:00:00:C0:70:00:1C:00:00:1C:00:00:00:07:00:00:00:00:00:0D:00:00:03:40:03:40:0D:00:34:0D:0D:34:D3:4D:D3:77:77:71:C7:1C:1C:07:00:00:00:00:00:0D:03:4D:37:77:1C:1C:00:34:34:C7:70:00:03:77:70:0D:37:00:30:00:28:00:28:00:07:00:00:00:0D:03:40:03:40:D0:34:00:D0:0D:D3:77:74:03:40:34:00:34:DC:74:DD:0D:D0:DD:34:0D:0D:D3:4D:DD:34:D0:DD:C7:74:DD:37:4D:C7:1C:1C:74:DD:34:DC:1D:DD:DD:00:00:37:77:77:06:FE:47:77:40:D0:00:00:00:00:C0:46:24:FD:93:01:02:02:8C:00:00:00:00:00:00:00:C0:70:00:1C:00:00:1C:00:00:00:07:00:00:00:00:00:0D:00:00:03:40:03:40:0D:00:34:0D:0D:34:D3:4D:D3:77:77"
    16:48:20.857 --
    16:48:20.857 Outgoing Dump:
    16:48:20.857 0000: 01 05 ff f5 68 82 03 20 f0 0d 0d d3 4d dd 34 d0 ....h.. ....M.4.
    16:48:20.857 0010: dd c7 74 dd 37 4d c7 1c 1c 74 dd 34 dc 1d dd dd ..t.7M...t.4....
    16:48:20.857 0020: 00 00 37 77 77 06 fe 47 77 40 d0 00 00 00 00 c0 ..7ww..Gw@......
    16:48:20.857 0030: 46 24 fd 93 01 01 02 8c 00 00 00 00 00 00 00 c0 F$..............
    16:48:20.857 0040: 70 00 1c 00 00 1c 00 00 00 07 00 00 00 00 00 0d p...............
    16:48:20.857 0050: 00 00 03 40 03 40 0d 00 34 0d 0d 34 d3 4d d3 77 ...@.@..4..4.M.w
    16:48:20.857 0060: 77 71 c7 1c 1c 07 00 00 00 00 00 0d 03 4d 37 77 wq...........M7w
    16:48:20.857 0070: 1c 1c 00 34 34 c7 70 00 03 77 70 0d 37 00 30 00 ...44.p..wp.7.0.
    16:48:20.857 0080: 28 00 28 00 07 00 00 00 0d 03 40 03 40 d0 34 00 (.(.......@.@.4.
    16:48:20.857 0090: d0 0d d3 77 74 03 40 34 00 34 dc 74 dd 0d d0 dd ...wt.@4.4.t....
    16:48:20.857 00a0: 34 0d 0d d3 4d dd 34 d0 dd c7 74 dd 37 4d c7 1c 4...M.4...t.7M..
    16:48:20.857 00b0: 1c 74 dd 34 dc 1d dd dd 00 00 37 77 77 06 fe 47 .t.4......7ww..G
    16:48:20.857 00c0: 77 40 d0 00 00 00 00 c0 46 24 fd 93 01 02 02 8c w@......F$......
    16:48:20.857 00d0: 00 00 00 00 00 00 00 c0 70 00 1c 00 00 1c 00 00 ........p.......
    16:48:20.857 00e0: 00 07 00 00 00 00 00 0d 00 00 03 40 03 40 0d 00 ...........@.@..
    16:48:20.857 00f0: 34 0d 0d 34 d3 4d d3 77 77 4..4.M.ww
    16:48:20.888 Incoming Dump:
    16:48:20.888 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.888 --
    16:48:20.888 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.888 Parameters:
    16:48:20.888 | Number HCI commands : 0x01
    16:48:20.888 | Command Opcode : 0xff05
    16:48:20.888 | Status : 0x00 (Success)
    16:48:20.888 --
    16:48:20.904 --
    16:48:20.904 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.904 Parameters:
    16:48:20.904 | Address : 0x20038358
    16:48:20.904 | Size : 0xf0
    16:48:20.904 | Values : "71:C7:1C:1C:07:00:00:00:00:00:0D:03:4D:37:77:1C:1C:00:34:34:C7:70:00:03:77:70:0D:37:00:30:00:28:00:28:00:07:00:00:00:0D:03:40:03:40:D0:34:00:D0:0D:D3:77:74:03:40:34:00:34:DC:74:DD:0D:D0:DD:34:0D:0D:D3:4D:DD:34:D0:DD:C7:74:DD:37:4D:C7:1C:1C:74:DD:34:DC:1D:DD:DD:00:00:37:77:77:06:FE:47:77:40:D0:00:00:00:00:C0:46:24:FD:93:02:00:02:8C:00:00:00:00:00:00:00:34:DD:37:74:DD:DD:37:77:77:77:77:77:77:77:77:77:1D:C7:1C:70:70:1C:00:00:00:00:00:00:00:00:00:34:00:D0:34:34:D3:4D:DD:C7:70:70:1C:00:D0:34:D3:71:C7:00:03:4D:DC:00:03:71:C0:D3:70:03:70:03:1B:F9:C0:00:00:00:00:47:00:47:00:35:C0:00:00:00:00:00:00:00:00:D0:00:00:00:34:D0:D0:0D:0D:00:00:D3:1D:DC:70:07:00:70:00:07:07:00:01:C0:01:C0:07:07:1C:77:71:D3:70:1D:DD:DD:C1:DD:D3"
    16:48:20.904 --
    16:48:20.904 Outgoing Dump:
    16:48:20.904 0000: 01 05 ff f5 58 83 03 20 f0 71 c7 1c 1c 07 00 00 ....X.. .q......
    16:48:20.904 0010: 00 00 00 0d 03 4d 37 77 1c 1c 00 34 34 c7 70 00 .....M7w...44.p.
    16:48:20.904 0020: 03 77 70 0d 37 00 30 00 28 00 28 00 07 00 00 00 .wp.7.0.(.(.....
    16:48:20.904 0030: 0d 03 40 03 40 d0 34 00 d0 0d d3 77 74 03 40 34 ..@.@.4....wt.@4
    16:48:20.904 0040: 00 34 dc 74 dd 0d d0 dd 34 0d 0d d3 4d dd 34 d0 .4.t....4...M.4.
    16:48:20.904 0050: dd c7 74 dd 37 4d c7 1c 1c 74 dd 34 dc 1d dd dd ..t.7M...t.4....
    16:48:20.904 0060: 00 00 37 77 77 06 fe 47 77 40 d0 00 00 00 00 c0 ..7ww..Gw@......
    16:48:20.904 0070: 46 24 fd 93 02 00 02 8c 00 00 00 00 00 00 00 34 F$.............4
    16:48:20.904 0080: dd 37 74 dd dd 37 77 77 77 77 77 77 77 77 77 1d .7t..7wwwwwwwww.
    16:48:20.904 0090: c7 1c 70 70 1c 00 00 00 00 00 00 00 00 00 34 00 ..pp..........4.
    16:48:20.904 00a0: d0 34 34 d3 4d dd c7 70 70 1c 00 d0 34 d3 71 c7 .44.M..pp...4.q.
    16:48:20.904 00b0: 00 03 4d dc 00 03 71 c0 d3 70 03 70 03 1b f9 c0 ..M...q..p.p....
    16:48:20.904 00c0: 00 00 00 00 47 00 47 00 35 c0 00 00 00 00 00 00 ....G.G.5.......
    16:48:20.904 00d0: 00 00 d0 00 00 00 34 d0 d0 0d 0d 00 00 d3 1d dc ......4.........
    16:48:20.904 00e0: 70 07 00 70 00 07 07 00 01 c0 01 c0 07 07 1c 77 p..p...........w
    16:48:20.904 00f0: 71 d3 70 1d dd dd c1 dd d3 q.p......
    16:48:20.935 Incoming Dump:
    16:48:20.935 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.935 --
    16:48:20.935 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.935 Parameters:
    16:48:20.935 | Number HCI commands : 0x01
    16:48:20.935 | Command Opcode : 0xff05
    16:48:20.935 | Status : 0x00 (Success)
    16:48:20.935 --
    16:48:20.935 --
    16:48:20.935 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.935 | Address : 0x20038448
    16:48:20.935 | Size : 0xf0
    16:48:20.935 | Values : "1C:07:77:77:77:4D:C1:1D:0D:31:D3:D0:43:00:C0:46:24:FD:93:02:01:02:8C:00:00:00:00:00:00:00:34:DD:37:74:DD:DD:37:77:77:77:77:77:77:77:77:77:1D:C7:1C:70:70:1C:00:00:00:00:00:00:00:00:00:34:00:D0:34:34:D3:4D:DD:C7:70:70:1C:00:D0:34:D3:71:C7:00:03:4D:DC:00:03:71:C0:D3:70:03:70:03:1B:F9:C0:00:00:00:00:47:00:47:00:35:C0:00:00:00:00:00:00:00:00:D0:00:00:00:34:D0:D0:0D:0D:00:00:D3:1D:DC:70:07:00:70:00:07:07:00:01:C0:01:C0:07:07:1C:77:71:D3:70:1D:DD:DD:C1:DD:D3:1C:07:77:77:77:4D:C1:1D:0D:31:D3:D0:43:00:C0:46:24:FD:93:02:02:02:8C:00:00:00:00:00:00:00:34:DD:37:74:DD:DD:37:77:77:77:77:77:77:77:77:77:1D:C7:1C:70:70:1C:00:00:00:00:00:00:00:00:00:34:00:D0:34:34:D3:4D:DD:C7:70:70:1C:00:D0:34:D3:71:C7:00:03:4D:DC:00:03:71:C0:D3"
    16:48:20.935 --
    16:48:20.935 Outgoing Dump:
    16:48:20.935 0000: 01 05 ff f5 48 84 03 20 f0 1c 07 77 77 77 4d c1 ....H.. ...wwwM.
    16:48:20.935 0010: 1d 0d 31 d3 d0 43 00 c0 46 24 fd 93 02 01 02 8c ..1..C..F$......
    16:48:20.935 0020: 00 00 00 00 00 00 00 34 dd 37 74 dd dd 37 77 77 .......4.7t..7ww
    16:48:20.935 0030: 77 77 77 77 77 77 77 1d c7 1c 70 70 1c 00 00 00 wwwwwww...pp....
    16:48:20.935 0040: 00 00 00 00 00 00 34 00 d0 34 34 d3 4d dd c7 70 ......4..44.M..p
    16:48:20.935 0050: 70 1c 00 d0 34 d3 71 c7 00 03 4d dc 00 03 71 c0 p...4.q...M...q.
    16:48:20.935 0060: d3 70 03 70 03 1b f9 c0 00 00 00 00 47 00 47 00 .p.p........G.G.
    16:48:20.935 0070: 35 c0 00 00 00 00 00 00 00 00 d0 00 00 00 34 d0 5.............4.
    16:48:20.935 0080: d0 0d 0d 00 00 d3 1d dc 70 07 00 70 00 07 07 00 ........p..p....
    16:48:20.935 0090: 01 c0 01 c0 07 07 1c 77 71 d3 70 1d dd dd c1 dd .......wq.p.....
    16:48:20.935 00a0: d3 1c 07 77 77 77 4d c1 1d 0d 31 d3 d0 43 00 c0 ...wwwM...1..C..
    16:48:20.935 00b0: 46 24 fd 93 02 02 02 8c 00 00 00 00 00 00 00 34 F$.............4
    16:48:20.935 00c0: dd 37 74 dd dd 37 77 77 77 77 77 77 77 77 77 1d .7t..7wwwwwwwww.
    16:48:20.935 00d0: c7 1c 70 70 1c 00 00 00 00 00 00 00 00 00 34 00 ..pp..........4.
    16:48:20.935 00e0: d0 34 34 d3 4d dd c7 70 70 1c 00 d0 34 d3 71 c7 .44.M..pp...4.q.
    16:48:20.935 00f0: 00 03 4d dc 00 03 71 c0 d3 ..M...q..
    16:48:20.966 Incoming Dump:
    16:48:20.966 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.966 --
    16:48:20.966 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.966 Parameters:
    16:48:20.966 | Number HCI commands : 0x01
    16:48:20.966 | Command Opcode : 0xff05
    16:48:20.966 | Status : 0x00 (Success)
    16:48:20.966 --
    16:48:20.966 --
    16:48:20.966 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.966 | Address : 0x20038538
    16:48:20.966 | Size : 0xf0
    16:48:20.966 | Values : "70:03:70:03:1B:F9:C0:00:00:00:00:47:00:47:00:35:C0:00:00:00:00:00:00:00:00:D0:00:00:00:34:D0:D0:0D:0D:00:00:D3:1D:DC:70:07:00:70:00:07:07:00:01:C0:01:C0:07:07:1C:77:71:D3:70:1D:DD:DD:C1:DD:D3:1C:07:77:77:77:4D:C1:1D:0D:31:D3:D0:43:00:C0:46:84:FD:12:00:00:59:0E:40:0E:F3:0D:CC:0D:73:0D:26:0D:00:0D:00:0D:C0:46:C0:84:FD:12:01:00:80:10:26:10:CC:0F:B3:0F:66:0F:19:0F:E6:0E:E6:0E:C0:46:C0:84:FD:12:00:01:00:0E:66:0D:33:0D:D9:0C:80:0C:4C:0C:33:0C:33:0C:C0:46:C0:84:FD:12:01:01:0C:10:73:0F:40:0F:E6:0E:99:0E:66:0E:4C:0E:4C:0E:C0:46:C0:84:FD:12:00:02:00:0F:80:0E:40:0E:00:0E:A6:0D:66:0D:4C:0D:4C:0D:C0:46:C0:84:FD:12:01:02:CC:10:59:10:0C:10:CC:0F:80:0F:40:0F:33:0F:33:0F:C0:46:C0:01:FF:06:00:40:01:20:00:00:C0:46:C0:76:FD:31:01"
    16:48:20.966 --
    16:48:20.966 Outgoing Dump:
    16:48:20.966 0000: 01 05 ff f5 38 85 03 20 f0 70 03 70 03 1b f9 c0 ....8.. .p.p....
    16:48:20.966 0010: 00 00 00 00 47 00 47 00 35 c0 00 00 00 00 00 00 ....G.G.5.......
    16:48:20.966 0020: 00 00 d0 00 00 00 34 d0 d0 0d 0d 00 00 d3 1d dc ......4.........
    16:48:20.966 0030: 70 07 00 70 00 07 07 00 01 c0 01 c0 07 07 1c 77 p..p...........w
    16:48:20.966 0040: 71 d3 70 1d dd dd c1 dd d3 1c 07 77 77 77 4d c1 q.p........wwwM.
    16:48:20.966 0050: 1d 0d 31 d3 d0 43 00 c0 46 84 fd 12 00 00 59 0e ..1..C..F.....Y.
    16:48:20.966 0060: 40 0e f3 0d cc 0d 73 0d 26 0d 00 0d 00 0d c0 46 @.....s.&......F
    16:48:20.966 0070: c0 84 fd 12 01 00 80 10 26 10 cc 0f b3 0f 66 0f ........&.....f.
    16:48:20.966 0080: 19 0f e6 0e e6 0e c0 46 c0 84 fd 12 00 01 00 0e .......F........
    16:48:20.966 0090: 66 0d 33 0d d9 0c 80 0c 4c 0c 33 0c 33 0c c0 46 f.3.....L.3.3..F
    16:48:20.966 00a0: c0 84 fd 12 01 01 0c 10 73 0f 40 0f e6 0e 99 0e ........s.@.....
    16:48:20.966 00b0: 66 0e 4c 0e 4c 0e c0 46 c0 84 fd 12 00 02 00 0f f.L.L..F........
    16:48:20.966 00c0: 80 0e 40 0e 00 0e a6 0d 66 0d 4c 0d 4c 0d c0 46 ..@.....f.L.L..F
    16:48:20.966 00d0: c0 84 fd 12 01 02 cc 10 59 10 0c 10 cc 0f 80 0f ........Y.......
    16:48:20.966 00e0: 40 0f 33 0f 33 0f c0 46 c0 01 ff 06 00 40 01 20 @.3.3..F.....@.
    16:48:20.966 00f0: 00 00 c0 46 c0 76 fd 31 01 ...F.v.1.
    16:48:20.998 Incoming Dump:
    16:48:20.998 0000: 04 0e 04 01 05 ff 00 .......
    16:48:20.998 --
    16:48:20.998 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:20.998 Parameters:
    16:48:20.998 | Number HCI commands : 0x01
    16:48:20.998 | Command Opcode : 0xff05
    16:48:20.998 | Status : 0x00 (Success)
    16:48:20.998 --
    16:48:20.998 --
    16:48:20.998 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:20.998 | Address : 0x20038628
    16:48:20.998 | Size : 0xf0
    16:48:20.998 | Values : "06:00:08:00:66:53:08:00:14:05:0A:05:00:03:07:06:01:12:13:0A:04:11:05:0E:0F:08:09:0B:0C:0D:10:02:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:00:00:00:00:12:FE:13:7F:00:B8:0B:54:0B:FA:00:E4:0C:1C:0C:28:0A:02:0F:0F:0F:06:C0:46:FB:FD:06:00:00:08:00:00:01:C0:46:C0:12:FE:13:7F:00:80:0C:B8:0B:FA:00:E4:0C:1C:0C:28:0A:02:0F:0F:0F:06:C0:46:FB:FD:06:00:0B:00:00:00:01:C0:46:C0:FB:FD:07:01:1E:F0:1B:0A:00:00:C0:46:FB:FD:06:02:00:40:04:00:01:C0:46:C0:FB:FD:07:03:1E:D0:5B:0A:00:00:C0:46:FB:FD:07:04:1E:00:00:04:00:00:C0:46:FB:FD:06:00:04:00:00:00:01:00:00:B5:AD:F1:94:0D:06:4B:05:49:94:22:68:46:98:47:05:4A:25:21:68:46:90:47:25:B0:00:BD:C0:46:EC:7E:03:20:C9:E8:08:00:B3:05:03:20:30:87:03:20:34:87:03:20:40:87:03:20:5C:87:03:20:68:87:03:20"
    16:48:20.998 --
    16:48:20.998 Outgoing Dump:
    16:48:20.998 0000: 01 05 ff f5 28 86 03 20 f0 06 00 08 00 66 53 08 ....(.. .....fS.
    16:48:20.998 0010: 00 14 05 0a 05 00 03 07 06 01 12 13 0a 04 11 05 ................
    16:48:20.998 0020: 0e 0f 08 09 0b 0c 0d 10 02 ff ff ff ff ff ff ff ................
    16:48:20.998 0030: ff ff ff ff ff 00 00 00 00 12 fe 13 7f 00 b8 0b ................
    16:48:20.998 0040: 54 0b fa 00 e4 0c 1c 0c 28 0a 02 0f 0f 0f 06 c0 T.......(.......
    16:48:20.998 0050: 46 fb fd 06 00 00 08 00 00 01 c0 46 c0 12 fe 13 F..........F....
    16:48:20.998 0060: 7f 00 80 0c b8 0b fa 00 e4 0c 1c 0c 28 0a 02 0f ............(...
    16:48:20.998 0070: 0f 0f 06 c0 46 fb fd 06 00 0b 00 00 00 01 c0 46 ....F..........F
    16:48:20.998 0080: c0 fb fd 07 01 1e f0 1b 0a 00 00 c0 46 fb fd 06 ............F...
    16:48:20.998 0090: 02 00 40 04 00 01 c0 46 c0 fb fd 07 03 1e d0 5b ..@....F.......[
    16:48:20.998 00a0: 0a 00 00 c0 46 fb fd 07 04 1e 00 00 04 00 00 c0 ....F...........
    16:48:20.998 00b0: 46 fb fd 06 00 04 00 00 00 01 00 00 b5 ad f1 94 F...............
    16:48:20.998 00c0: 0d 06 4b 05 49 94 22 68 46 98 47 05 4a 25 21 68 ..K.I."hF.G.J%!h
    16:48:20.998 00d0: 46 90 47 25 b0 00 bd c0 46 ec 7e 03 20 c9 e8 08 F.G%....F.~. ...
    16:48:20.998 00e0: 00 b3 05 03 20 30 87 03 20 34 87 03 20 40 87 03 .... 0.. 4.. @..
    16:48:20.998 00f0: 20 5c 87 03 20 68 87 03 20 \.. h..
    16:48:21.029 Incoming Dump:
    16:48:21.029 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.029 --
    16:48:21.029 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.029 Parameters:
    16:48:21.029 | Number HCI commands : 0x01
    16:48:21.029 | Command Opcode : 0xff05
    16:48:21.029 | Status : 0x00 (Success)
    16:48:21.029 --
    16:48:21.029 --
    16:48:21.029 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.029 | Address : 0x20038718
    16:48:21.029 | Size : 0xf0
    16:48:21.029 | Values : "80:87:03:20:98:87:03:20:9C:87:03:20:A4:87:03:20:B0:87:03:20:D4:87:03:20:0F:FD:01:01:09:FD:08:20:F5:0E:20:08:00:38:00:C0:E7:FD:19:02:08:02:04:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:00:00:00:00:00:00:00:00:09:FD:08:20:F5:0E:20:00:00:38:00:C0:1C:FD:13:FF:88:13:00:00:FF:04:FF:FF:FF:FF:00:00:00:00:FF:FF:00:00:C0:46:1C:FD:13:FF:88:13:00:00:FF:04:FF:FF:FF:FF:01:00:00:00:FF:FF:00:00:C0:46:2C:FE:01:02:C1:FF:03:03:A0:03:C0:46:5D:FD:08:20:40:3C:C8:40:06:00:00:C0:58:FD:21:01:CE:CE:CE:E2:E2:E2:EC:EC:B0:00:00:00:00:03:14:0A:90:00:90:00:3C:0A:19:02:01:01:01:14:F6:EC:F6:EC:FF:FD:03:80:80:00:30:B5:AD:F1:2C:0D:07:48:3C:C8:69:46:3C:C1:3C:C8:3C:C1:90:E8:0D:00:81:E8:0D:00:03:4A:0B:21:68:46:90:47:0B:B0:30:BD:04:87:03:20:B3:05:03:20"
    16:48:21.029 --
    16:48:21.029 Outgoing Dump:
    16:48:21.029 0000: 01 05 ff f5 18 87 03 20 f0 80 87 03 20 98 87 03 ....... .... ...
    16:48:21.029 0010: 20 9c 87 03 20 a4 87 03 20 b0 87 03 20 d4 87 03 ... ... ... ...
    16:48:21.029 0020: 20 0f fd 01 01 09 fd 08 20 f5 0e 20 08 00 38 00 ....... .. ..8.
    16:48:21.029 0030: c0 e7 fd 19 02 08 02 04 ff ff ff ff ff ff ff ff ................
    16:48:21.029 0040: ff ff ff ff ff 00 00 00 00 00 00 00 00 09 fd 08 ................
    16:48:21.029 0050: 20 f5 0e 20 00 00 38 00 c0 1c fd 13 ff 88 13 00 .. ..8.........
    16:48:21.029 0060: 00 ff 04 ff ff ff ff 00 00 00 00 ff ff 00 00 c0 ................
    16:48:21.029 0070: 46 1c fd 13 ff 88 13 00 00 ff 04 ff ff ff ff 01 F...............
    16:48:21.029 0080: 00 00 00 ff ff 00 00 c0 46 2c fe 01 02 c1 ff 03 ........F,......
    16:48:21.029 0090: 03 a0 03 c0 46 5d fd 08 20 40 3c c8 40 06 00 00 ....F].. @<.@...
    16:48:21.029 00a0: c0 58 fd 21 01 ce ce ce e2 e2 e2 ec ec b0 00 00 .X.!............
    16:48:21.029 00b0: 00 00 03 14 0a 90 00 90 00 3c 0a 19 02 01 01 01 .........<......
    16:48:21.029 00c0: 14 f6 ec f6 ec ff fd 03 80 80 00 30 b5 ad f1 2c ...........0...,
    16:48:21.029 00d0: 0d 07 48 3c c8 69 46 3c c1 3c c8 3c c1 90 e8 0d ..H<.iF<.<.<....
    16:48:21.029 00e0: 00 81 e8 0d 00 03 4a 0b 21 68 46 90 47 0b b0 30 ......J.!hF.G..0
    16:48:21.029 00f0: bd 04 87 03 20 b3 05 03 20 .... ...
    16:48:21.060 Incoming Dump:
    16:48:21.060 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.060 --
    16:48:21.060 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.060 Parameters:
    16:48:21.060 | Number HCI commands : 0x01
    16:48:21.060 | Command Opcode : 0xff05
    16:48:21.060 | Status : 0x00 (Success)
    16:48:21.060 --
    16:48:21.060 --
    16:48:21.060 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.060 | Address : 0x20038808
    16:48:21.060 | Size : 0x28
    16:48:21.060 | Values : "0C:88:03:20:CF:FD:07:08:FF:FF:FF:FF:FF:FF:08:B5:03:48:04:4A:00:68:01:21:00:90:68:46:90:47:08:BD:08:88:03:20:B3:05:03:20"
    16:48:21.060 --
    16:48:21.060 Outgoing Dump:
    16:48:21.060 0000: 01 05 ff 2d 08 88 03 20 28 0c 88 03 20 cf fd 07 ...-... (... ...
    16:48:21.060 0010: 08 ff ff ff ff ff ff 08 b5 03 48 04 4a 00 68 01 ..........H.J.h.
    16:48:21.060 0020: 21 00 90 68 46 90 47 08 bd 08 88 03 20 b3 05 03 !..hF.G..... ...
    16:48:21.060 0030: 20
    16:48:21.076 Incoming Dump:
    16:48:21.076 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.076 --
    16:48:21.076 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.076 Parameters:
    16:48:21.076 | Number HCI commands : 0x01
    16:48:21.076 | Command Opcode : 0xff05
    16:48:21.076 | Status : 0x00 (Success)
    16:48:21.076 --
    16:48:21.076 --
    16:48:21.076 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:21.076 | Address : 0x2008fea8
    16:48:21.076 | Type : 0x04
    16:48:21.076 | Value : 0x00000002
    16:48:21.076 --
    16:48:21.076 Outgoing Dump:
    16:48:21.076 0000: 01 03 ff 09 a8 fe 08 20 04 02 00 00 00 ....... .....
    16:48:21.091 Incoming Dump:
    16:48:21.091 0000: 04 0e 04 01 03 ff 00 .......
    16:48:21.091 --
    16:48:21.091 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:21.091 Parameters:
    16:48:21.091 | Number HCI commands : 0x01
    16:48:21.091 | Command Opcode : 0xff03
    16:48:21.091 | Status : 0x00 (Success)
    16:48:21.091 --
    16:48:21.091 --
    16:48:21.091 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:21.091 | Address : 0x2008ddf0
    16:48:21.091 | Type : 0x04
    16:48:21.091 | Value : 0x2008fe95
    16:48:21.091 --
    16:48:21.091 Outgoing Dump:
    16:48:21.091 0000: 01 03 ff 09 f0 dd 08 20 04 95 fe 08 20 ....... ....
    16:48:21.107 Incoming Dump:
    16:48:21.107 0000: 04 0e 04 01 03 ff 00 .......
    16:48:21.107 --
    16:48:21.107 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:21.107 Parameters:
    16:48:21.107 | Number HCI commands : 0x01
    16:48:21.107 | Command Opcode : 0xff03
    16:48:21.107 | Status : 0x00 (Success)
    16:48:21.107 --
    16:48:21.107 --
    16:48:21.107 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:21.107 | Address : 0x2008843c
    16:48:21.107 | Type : 0x04
    16:48:21.107 | Value : 0x2008ddec
    16:48:21.107 --
    16:48:21.107 Outgoing Dump:
    16:48:21.107 0000: 01 03 ff 09 3c 84 08 20 04 ec dd 08 20 ....<.. ....
    16:48:21.122 Incoming Dump:
    16:48:21.122 0000: 04 0e 04 01 03 ff 00 .......
    16:48:21.122 --
    16:48:21.122 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:21.122 Parameters:
    16:48:21.122 | Number HCI commands : 0x01
    16:48:21.122 | Command Opcode : 0xff03
    16:48:21.122 | Status : 0x00 (Success)
    16:48:21.122 --
    16:48:21.122 --
    16:48:21.122 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:21.122 | Address : 0x20086f24
    16:48:21.122 | Type : 0x01
    16:48:21.122 | Value : 0x01
    16:48:21.122 --
    16:48:21.122 Outgoing Dump:
    16:48:21.122 0000: 01 03 ff 06 24 6f 08 20 01 01 ....$o. ..
    16:48:21.138 Incoming Dump:
    16:48:21.138 0000: 04 0e 04 01 03 ff 00 .......
    16:48:21.138 --
    16:48:21.138 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:21.138 Parameters:
    16:48:21.138 | Number HCI commands : 0x01
    16:48:21.138 | Command Opcode : 0xff03
    16:48:21.138 | Status : 0x00 (Success)
    16:48:21.138 --
    16:48:21.138 --
    16:48:21.138 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:21.138 | Address : 0x2008fea4
    16:48:21.138 | Type : 0x04
    16:48:21.138 | Value : 0x00000003
    16:48:21.138 --
    16:48:21.138 Outgoing Dump:
    16:48:21.138 0000: 01 03 ff 09 a4 fe 08 20 04 03 00 00 00 ....... .....
    16:48:21.154 Incoming Dump:
    16:48:21.154 0000: 04 0e 04 01 03 ff 00 .......
    16:48:21.154 --
    16:48:21.154 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:21.154 Parameters:
    16:48:21.154 | Number HCI commands : 0x01
    16:48:21.154 | Command Opcode : 0xff03
    16:48:21.154 | Status : 0x00 (Success)
    16:48:21.154 --
    16:48:21.154 --
    16:48:21.154 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:21.154 | Address : 0x2008feac
    16:48:21.154 | Type : 0x04
    16:48:21.154 | Value : 0x00000001
    16:48:21.154 --
    16:48:21.154 Outgoing Dump:
    16:48:21.154 0000: 01 03 ff 09 ac fe 08 20 04 01 00 00 00 ....... .....
    16:48:21.154 --
    16:48:21.154 --
    16:48:21.154 --
    16:48:21.154 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.154 | Address : 0x20040300
    16:48:21.154 | Size : 0x20
    16:48:21.154 | Values : "03:21:76:20:C0:46:C0:46:04:22:40:1C:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46:C0:46"
    16:48:21.154 --
    16:48:21.154 0000: 01 05 ff 25 00 03 04 20 20 03 21 76 20 c0 46 c0 ...%... .!v .F.
    16:48:21.154 0010: 46 04 22 40 1c c0 46 c0 46 c0 46 c0 46 c0 46 c0 F."@..F.F.F.F.F.
    16:48:21.154 0020: 46 c0 46 c0 46 c0 46 c0 46 F.F.F.F.F
    16:48:21.169 Incoming Dump:
    16:48:21.169 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.169 --
    16:48:21.169 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.169 Parameters:
    16:48:21.169 | Number HCI commands : 0x01
    16:48:21.169 | Command Opcode : 0xff05
    16:48:21.169 | Status : 0x00 (Success)
    16:48:21.169 --
    16:48:21.169 --
    16:48:21.169 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.169 | Address : 0x20042720
    16:48:21.169 | Size : 0xfa
    16:48:21.169 | Values : "02:06:02:8D:00:78:08:41:00:F0:01:00:70:47:00:00:00:00:00:00:00:00:00:00:00:00:00:00:07:48:06:49:08:60:07:49:01:22:CA:71:06:4A:42:60:02:22:8A:71:05:49:81:60:70:47:C0:46:38:01:04:20:30:27:04:20:00:00:04:20:25:2B:04:20:33:2B:04:20:10:B5:0F:23:04:78:91:40:93:40:9C:43:0C:43:04:70:10:BD:2D:E9:F0:41:DF:F8:14:82:85:4E:D8:F8:00:00:86:42:01:D0:83:48:80:47:72:B6:4F:F0:00:03:4F:F0:01:01:81:4D:81:4C:1A:46:29:60:54:F8:04:0B:20:B1:02:F0:0F:00:01:FA:00:F0:03:43:02:F0:0F:00:0F:28:02:D1:7B:48:03:80:00:23:52:1C:10:2A:ED:D3:79:48:80:47:79:48:00:27:02:21:07:60:78:4C:47:60:A1:70:06:22:62:70:87:60:C7:60:07:61:47:61:87:61:C7:61:8D:20:E0:70:D8:F8:00:00:21:70:86:42:09:D0:A1:4E:2D:20:B0:47:A1:78:E2:78:2E:20:B0:47:9E:49:2F:20:88:47:2F:60:BD:E8:F0:81:2D:E9:F0:4F:00:68"
    16:48:21.169 --
    16:48:21.169 Outgoing Dump:
    16:48:21.169 0000: 01 05 ff ff 20 27 04 20 fa 02 06 02 8d 00 78 08 .... '. ......x.
    16:48:21.169 0010: 41 00 f0 01 00 70 47 00 00 00 00 00 00 00 00 00 A....pG.........
    16:48:21.169 0020: 00 00 00 00 00 07 48 06 49 08 60 07 49 01 22 ca ......H.I.`.I.".
    16:48:21.169 0030: 71 06 4a 42 60 02 22 8a 71 05 49 81 60 70 47 c0 q.JB`.".q.I.`pG.
    16:48:21.169 0040: 46 38 01 04 20 30 27 04 20 00 00 04 20 25 2b 04 F8.. 0'. ... %+.
    16:48:21.169 0050: 20 33 2b 04 20 10 b5 0f 23 04 78 91 40 93 40 9c 3+. ...#.x.@.@.
    16:48:21.169 0060: 43 0c 43 04 70 10 bd 2d e9 f0 41 df f8 14 82 85 C.C.p..-..A.....
    16:48:21.169 0070: 4e d8 f8 00 00 86 42 01 d0 83 48 80 47 72 b6 4f N.....B...H.Gr.O
    16:48:21.169 0080: f0 00 03 4f f0 01 01 81 4d 81 4c 1a 46 29 60 54 ...O....M.L.F)`T
    16:48:21.169 0090: f8 04 0b 20 b1 02 f0 0f 00 01 fa 00 f0 03 43 02 ... ..........C.
    16:48:21.169 00a0: f0 0f 00 0f 28 02 d1 7b 48 03 80 00 23 52 1c 10 ....(..{H...#R..
    16:48:21.169 00b0: 2a ed d3 79 48 80 47 79 48 00 27 02 21 07 60 78 *..yH.GyH.'.!.`x
    16:48:21.169 00c0: 4c 47 60 a1 70 06 22 62 70 87 60 c7 60 07 61 47 LG`.p."bp.`.`.aG
    16:48:21.169 00d0: 61 87 61 c7 61 8d 20 e0 70 d8 f8 00 00 21 70 86 a.a.a. .p....!p.
    16:48:21.169 00e0: 42 09 d0 a1 4e 2d 20 b0 47 a1 78 e2 78 2e 20 b0 B...N- .G.x.x. .
    16:48:21.169 00f0: 47 9e 49 2f 20 88 47 2f 60 bd e8 f0 81 2d e9 f0 G.I/ .G/`....-..
    16:48:21.169 0100: 4f 00 68 O.h
    16:48:21.201 Incoming Dump:
    16:48:21.201 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.201 --
    16:48:21.201 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.201 Parameters:
    16:48:21.201 | Number HCI commands : 0x01
    16:48:21.201 | Command Opcode : 0xff05
    16:48:21.201 | Status : 0x00 (Success)
    16:48:21.201 --
    16:48:21.201 --
    16:48:21.201 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.201 | Address : 0x2004281a
    16:48:21.201 | Size : 0xfa
    16:48:21.201 | Values : "00:F0:03:00:03:28:3F:D1:99:4E:DF:F8:68:92:98:4D:37:88:4C:46:00:22:40:F6:FE:70:46:34:30:80:10:46:4C:F2:50:31:81:42:00:F1:01:02:04:D3:21:88:20:88:28:80:88:42:F3:D0:DF:F8:40:B2:08:21:48:46:D8:47:DF:F8:3C:82:08:21:48:46:C0:47:08:21:48:46:D8:47:DF:F8:30:A2:08:21:50:46:D8:47:08:21:50:46:C0:47:08:21:50:46:D8:47:34:F8:28:0C:86:49:08:80:21:88:29:80:24:F8:26:0C:28:88:08:21:60:80:48:46:C0:47:08:21:50:46:C0:47:37:80:80:48:1A:30:BD:E8:F0:8F:00:B5:3A:48:00:21:E8:38:7D:4A:80:F8:04:11:B0:F8:00:01:4C:F6:FE:23:83:42:02:D1:8C:20:90:47:04:E0:01:21:8C:20:90:47:76:48:80:47:76:48:12:30:00:BD:76:48:00:F5:8D:70:70:47:10:B5:75:49:01:23:73:4C:0A:78:84:F8:FE:3E:11:01:41:F0:08:01:84:F8:FF:1E:02:60:70:48:4E:30:84:F8:96:37:10:BD:62:4A:92:1D:D1:88:93:88:8B:42:03:DB:12:88"
    16:48:21.201 --
    16:48:21.201 Outgoing Dump:
    16:48:21.201 0000: 01 05 ff ff 1a 28 04 20 fa 00 f0 03 00 03 28 3f .....(. ......(?
    16:48:21.201 0010: d1 99 4e df f8 68 92 98 4d 37 88 4c 46 00 22 40 ..N..h..M7.LF."@
    16:48:21.201 0020: f6 fe 70 46 34 30 80 10 46 4c f2 50 31 81 42 00 ..pF40..FL.P1.B.
    16:48:21.201 0030: f1 01 02 04 d3 21 88 20 88 28 80 88 42 f3 d0 df .....!. .(..B...
    16:48:21.201 0040: f8 40 b2 08 21 48 46 d8 47 df f8 3c 82 08 21 48 .@..!HF.G..<..!H
    16:48:21.201 0050: 46 c0 47 08 21 48 46 d8 47 df f8 30 a2 08 21 50 F.G.!HF.G..0..!P
    16:48:21.201 0060: 46 d8 47 08 21 50 46 c0 47 08 21 50 46 d8 47 34 F.G.!PF.G.!PF.G4
    16:48:21.201 0070: f8 28 0c 86 49 08 80 21 88 29 80 24 f8 26 0c 28 .(..I..!.).$.&.(
    16:48:21.201 0080: 88 08 21 60 80 48 46 c0 47 08 21 50 46 c0 47 37 ..!`.HF.G.!PF.G7
    16:48:21.201 0090: 80 80 48 1a 30 bd e8 f0 8f 00 b5 3a 48 00 21 e8 ..H.0......:H.!.
    16:48:21.201 00a0: 38 7d 4a 80 f8 04 11 b0 f8 00 01 4c f6 fe 23 83 8}J........L..#.
    16:48:21.201 00b0: 42 02 d1 8c 20 90 47 04 e0 01 21 8c 20 90 47 76 B... .G...!. .Gv
    16:48:21.201 00c0: 48 80 47 76 48 12 30 00 bd 76 48 00 f5 8d 70 70 H.GvH.0..vH...pp
    16:48:21.201 00d0: 47 10 b5 75 49 01 23 73 4c 0a 78 84 f8 fe 3e 11 G..uI.#sL.x...>.
    16:48:21.201 00e0: 01 41 f0 08 01 84 f8 ff 1e 02 60 70 48 4e 30 84 .A........`pHN0.
    16:48:21.201 00f0: f8 96 37 10 bd 62 4a 92 1d d1 88 93 88 8b 42 03 ..7..bJ.......B.
    16:48:21.201 0100: db 12 88 ...
    16:48:21.232 Incoming Dump:
    16:48:21.232 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.232 --
    16:48:21.232 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.232 Parameters:
    16:48:21.232 | Number HCI commands : 0x01
    16:48:21.232 | Command Opcode : 0xff05
    16:48:21.232 | Status : 0x00 (Success)
    16:48:21.232 --
    16:48:21.232 --
    16:48:21.232 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.232 | Address : 0x20042914
    16:48:21.232 | Size : 0xfa
    16:48:21.232 | Values : "D2:1A:89:18:00:E0:C9:1A:01:60:69:48:14:30:70:47:00:B5:57:49:4F:F4:A9:70:88:47:67:4B:65:49:F0:22:00:20:98:47:65:48:00:F5:AA:70:00:BD:70:B5:53:4D:04:8B:64:4E:04:22:00:21:28:46:80:1E:B0:47:04:22:00:21:28:46:40:1E:B0:47:5F:49:0A:88:5F:49:09:78:49:1E:04:D0:89:1E:01:29:07:D9:09:1F:09:D1:4B:48:80:1E:02:88:28:46:1C:30:01:E0:28:46:44:30:12:1B:02:80:44:4A:08:21:28:46:90:47:55:48:00:F2:36:30:70:BD:C0:46:14:01:04:20:FE:CA:FE:CA:F7:71:00:00:1C:1E:04:20:C0:33:04:20:80:A1:07:20:3D:27:04:20:08:20:00:E0:34:01:04:20:2D:E9:F0:4F:44:4F:49:4A:04:46:19:21:38:46:0A:30:01:80:00:21:38:46:90:47:26:69:DF:F8:20:81:DF:F8:14:91:70:09:2D:D3:DF:F8:08:B1:07:21:58:46:C8:47:45:4D:44:4C:DF:F8:00:A1:68:B9:4A:46:02:21:50:46:90:47:40:B1:40:46:00:78:01:28:04:D1:3C:48:80:47:80:20"
    16:48:21.232 --
    16:48:21.232 Outgoing Dump:
    16:48:21.232 0000: 01 05 ff ff 14 29 04 20 fa d2 1a 89 18 00 e0 c9 .....). ........
    16:48:21.232 0010: 1a 01 60 69 48 14 30 70 47 00 b5 57 49 4f f4 a9 ..`iH.0pG..WIO..
    16:48:21.232 0020: 70 88 47 67 4b 65 49 f0 22 00 20 98 47 65 48 00 p.GgKeI.". .GeH.
    16:48:21.232 0030: f5 aa 70 00 bd 70 b5 53 4d 04 8b 64 4e 04 22 00 ..p..p.SM..dN.".
    16:48:21.232 0040: 21 28 46 80 1e b0 47 04 22 00 21 28 46 40 1e b0 !(F...G.".!(F@..
    16:48:21.232 0050: 47 5f 49 0a 88 5f 49 09 78 49 1e 04 d0 89 1e 01 G_I.._I.xI......
    16:48:21.232 0060: 29 07 d9 09 1f 09 d1 4b 48 80 1e 02 88 28 46 1c )......KH....(F.
    16:48:21.232 0070: 30 01 e0 28 46 44 30 12 1b 02 80 44 4a 08 21 28 0..(FD0....DJ.!(
    16:48:21.232 0080: 46 90 47 55 48 00 f2 36 30 70 bd c0 46 14 01 04 F.GUH..60p..F...
    16:48:21.232 0090: 20 fe ca fe ca f7 71 00 00 1c 1e 04 20 c0 33 04 .....q..... .3.
    16:48:21.232 00a0: 20 80 a1 07 20 3d 27 04 20 08 20 00 e0 34 01 04 ... ='. . ..4..
    16:48:21.232 00b0: 20 2d e9 f0 4f 44 4f 49 4a 04 46 19 21 38 46 0a -..ODOIJ.F.!8F.
    16:48:21.232 00c0: 30 01 80 00 21 38 46 90 47 26 69 df f8 20 81 df 0...!8F.G&i.. ..
    16:48:21.232 00d0: f8 14 91 70 09 2d d3 df f8 08 b1 07 21 58 46 c8 ...p.-......!XF.
    16:48:21.232 00e0: 47 45 4d 44 4c df f8 00 a1 68 b9 4a 46 02 21 50 GEMDL....h.JF.!P
    16:48:21.232 00f0: 46 90 47 40 b1 40 46 00 78 01 28 04 d1 3c 48 80 F.G@.@F.x.(..<H.
    16:48:21.232 0100: 47 80 20 G.
    16:48:21.263 Incoming Dump:
    16:48:21.263 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.263 --
    16:48:21.263 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.263 Parameters:
    16:48:21.263 | Number HCI commands : 0x01
    16:48:21.263 | Command Opcode : 0xff05
    16:48:21.263 | Status : 0x00 (Success)
    16:48:21.263 --
    16:48:21.279 --
    16:48:21.279 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.279 Parameters:
    16:48:21.279 | Address : 0x20042a0e
    16:48:21.279 | Size : 0xfa
    16:48:21.279 | Values : "20:80:A8:47:58:46:CB:46:04:21:D8:47:80:B9:00:21:50:46:D8:47:60:B1:40:46:00:78:02:28:03:D0:01:28:06:D1:35:48:00:E0:26:48:80:47:10:20:20:80:A8:47:30:0B:11:D3:32:48:80:47:32:4A:00:21:38:46:90:47:50:B1:38:46:00:21:10:30:C8:47:28:B1:40:46:00:78:02:28:01:D1:2C:48:80:47:2C:48:78:30:BD:E8:F0:8F:40:1E:2B:4B:80:00:19:50:29:49:0A:50:70:47:70:47:C0:46:75:71:00:00:87:71:00:00:00:F6:0E:20:EA:1D:04:20:0C:50:0E:20:D3:6D:00:00:EF:6D:00:00:34:50:0E:20:E4:1D:04:20:17:56:00:00:7F:71:00:00:33:56:00:00:35:42:00:00:61:43:00:00:20:03:04:20:14:1D:04:20:A1:4A:00:00:DF:4B:00:00:48:0F:04:20:05:55:00:00:05:4C:00:00:0A:50:0E:20:6D:27:04:20:E8:1D:04:20:D5:1D:04:20:B5:56:00:00:E1:6D:00:00:22:0E:0E:20:29:6E:00:00:6C:02:0E:20:30:01:04:20:29:63:00:00:24:0E:0E:20:89:6D:00:00"
    16:48:21.279 --
    16:48:21.279 Outgoing Dump:
    16:48:21.279 0000: 01 05 ff ff 0e 2a 04 20 fa 20 80 a8 47 58 46 cb .....*. . ..GXF.
    16:48:21.279 0010: 46 04 21 d8 47 80 b9 00 21 50 46 d8 47 60 b1 40 F.!.G...!PF.G`.@
    16:48:21.279 0020: 46 00 78 02 28 03 d0 01 28 06 d1 35 48 00 e0 26 F.x.(...(..5H..&
    16:48:21.279 0030: 48 80 47 10 20 20 80 a8 47 30 0b 11 d3 32 48 80 H.G. ..G0...2H.
    16:48:21.279 0040: 47 32 4a 00 21 38 46 90 47 50 b1 38 46 00 21 10 G2J.!8F.GP.8F.!.
    16:48:21.279 0050: 30 c8 47 28 b1 40 46 00 78 02 28 01 d1 2c 48 80 0.G(.@F.x.(..,H.
    16:48:21.279 0060: 47 2c 48 78 30 bd e8 f0 8f 40 1e 2b 4b 80 00 19 G,Hx0....@.+K...
    16:48:21.279 0070: 50 29 49 0a 50 70 47 70 47 c0 46 75 71 00 00 87 P)I.PpGpG.Fuq...
    16:48:21.279 0080: 71 00 00 00 f6 0e 20 ea 1d 04 20 0c 50 0e 20 d3 q..... ... .P. .
    16:48:21.279 0090: 6d 00 00 ef 6d 00 00 34 50 0e 20 e4 1d 04 20 17 m...m..4P. ... .
    16:48:21.279 00a0: 56 00 00 7f 71 00 00 33 56 00 00 35 42 00 00 61 V...q..3V..5B..a
    16:48:21.279 00b0: 43 00 00 20 03 04 20 14 1d 04 20 a1 4a 00 00 df C.. .. ... .J...
    16:48:21.279 00c0: 4b 00 00 48 0f 04 20 05 55 00 00 05 4c 00 00 0a K..H.. .U...L...
    16:48:21.279 00d0: 50 0e 20 6d 27 04 20 e8 1d 04 20 d5 1d 04 20 b5 P. m'. ... ... .
    16:48:21.279 00e0: 56 00 00 e1 6d 00 00 22 0e 0e 20 29 6e 00 00 6c V...m..".. )n..l
    16:48:21.279 00f0: 02 0e 20 30 01 04 20 29 63 00 00 24 0e 0e 20 89 .. 0.. )c..$.. .
    16:48:21.279 0100: 6d 00 00 m..
    16:48:21.310 Incoming Dump:
    16:48:21.310 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.310 --
    16:48:21.310 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.310 Parameters:
    16:48:21.310 | Number HCI commands : 0x01
    16:48:21.310 | Command Opcode : 0xff05
    16:48:21.310 | Status : 0x00 (Success)
    16:48:21.310 --
    16:48:21.310 --
    16:48:21.310 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.310 | Address : 0x20042b08
    16:48:21.310 | Size : 0xfa
    16:48:21.310 | Values : "69:63:00:00:91:5B:00:00:25:27:04:20:51:48:00:00:85:5F:00:00:80:A0:07:20:C0:33:04:20:2D:E9:FF:5F:68:46:00:F0:2B:F8:BD:E8:FF:9F:2D:E9:FF:5F:68:46:00:F0:02:F8:BD:E8:FF:9F:30:B5:77:4D:77:4B:04:46:F0:22:00:20:05:F6:28:41:98:47:75:48:80:47:75:4A:13:78:01:21:18:01:40:F0:08:00:85:F8:FF:0E:72:48:85:F8:FE:1E:36:30:21:61:25:62:62:61:60:63:6F:48:A0:61:6F:48:23:60:00:88:E0:61:30:BD:2D:E9:F8:4F:6C:4A:65:4C:05:46:4F:F0:00:09:6B:4E:12:78:34:23:04:F6:22:41:04:F6:16:40:8D:F8:00:90:B0:47:DF:F8:90:A1:6E:4F:DF:F8:A8:B1:DF:F8:A0:81:AA:F1:03:0A:38:78:9A:F8:00:10:80:29:66:D1:03:28:17:D0:02:28:0D:D0:01:28:15:D1:94:F8:3A:0F:00:F0:0F:00:08:28:0D:D1:94:F8:3B:0F:AD:28:09:D1:3B:26:04:E0:94:F8:3A:0F:AD:28:03:D1:3A:26:03:20:38:70:3F:E0:48:46:38:70:4B:46:3A:26:04:F6:3B:72"
    16:48:21.310 --
    16:48:21.310 Outgoing Dump:
    16:48:21.310 0000: 01 05 ff ff 08 2b 04 20 fa 69 63 00 00 91 5b 00 .....+. .ic...[.
    16:48:21.310 0010: 00 25 27 04 20 51 48 00 00 85 5f 00 00 80 a0 07 .%'. QH..._.....
    16:48:21.310 0020: 20 c0 33 04 20 2d e9 ff 5f 68 46 00 f0 2b f8 bd .3. -.._hF..+..
    16:48:21.310 0030: e8 ff 9f 2d e9 ff 5f 68 46 00 f0 02 f8 bd e8 ff ...-.._hF.......
    16:48:21.310 0040: 9f 30 b5 77 4d 77 4b 04 46 f0 22 00 20 05 f6 28 .0.wMwK.F.". ..(
    16:48:21.310 0050: 41 98 47 75 48 80 47 75 4a 13 78 01 21 18 01 40 A.GuH.GuJ.x.!..@
    16:48:21.310 0060: f0 08 00 85 f8 ff 0e 72 48 85 f8 fe 1e 36 30 21 .......rH....60!
    16:48:21.310 0070: 61 25 62 62 61 60 63 6f 48 a0 61 6f 48 23 60 00 a%bba`coH.aoH#`.
    16:48:21.310 0080: 88 e0 61 30 bd 2d e9 f8 4f 6c 4a 65 4c 05 46 4f ..a0.-..OlJeL.FO
    16:48:21.310 0090: f0 00 09 6b 4e 12 78 34 23 04 f6 22 41 04 f6 16 ...kN.x4#.."A...
    16:48:21.310 00a0: 40 8d f8 00 90 b0 47 df f8 90 a1 6e 4f df f8 a8 @.....G....nO...
    16:48:21.310 00b0: b1 df f8 a0 81 aa f1 03 0a 38 78 9a f8 00 10 80 .........8x.....
    16:48:21.310 00c0: 29 66 d1 03 28 17 d0 02 28 0d d0 01 28 15 d1 94 )f..(...(...(...
    16:48:21.310 00d0: f8 3a 0f 00 f0 0f 00 08 28 0d d1 94 f8 3b 0f ad .:......(....;..
    16:48:21.310 00e0: 28 09 d1 3b 26 04 e0 94 f8 3a 0f ad 28 03 d1 3a (..;&....:..(..:
    16:48:21.310 00f0: 26 03 20 38 70 3f e0 48 46 38 70 4b 46 3a 26 04 &. 8p?.HF8pKF:&.
    16:48:21.310 0100: f6 3b 72 .;r
    16:48:21.341 Incoming Dump:
    16:48:21.341 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.341 --
    16:48:21.341 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.341 Parameters:
    16:48:21.341 | Number HCI commands : 0x01
    16:48:21.341 | Command Opcode : 0xff05
    16:48:21.341 | Status : 0x00 (Success)
    16:48:21.341 --
    16:48:21.341 --
    16:48:21.341 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.341 | Address : 0x20042c02
    16:48:21.341 | Size : 0xfa
    16:48:21.341 | Values : "04:F6:39:7C:1C:F8:01:1F:01:29:07:D1:11:78:01:F0:0F:01:08:29:02:D1:51:78:AD:29:06:D0:76:1E:03:F1:01:03:02:F1:01:02:ED:D1:01:E0:03:20:38:70:5E:B2:3A:2E:13:D1:03:28:11:D0:94:F8:74:1F:01:29:05:D1:94:F8:75:1F:01:F0:0F:01:08:29:05:D0:94:F8:75:1F:01:29:03:D1:01:20:00:E0:02:20:38:70:00:2E:16:DD:03:28:14:D1:1E:2E:05:D1:37:4A:35:48:49:46:90:47:03:28:0C:D0:35:4A:B1:B2:48:46:90:47:48:46:31:46:38:70:04:F6:16:40:C0:47:59:46:8C:31:34:E0:94:F8:3A:0F:01:28:05:D1:94:F8:3B:0F:00:F0:0F:00:08:28:23:D0:94:F8:58:0F:01:28:1C:D1:94:F8:59:0F:00:F0:0F:00:08:28:16:D1:23:4A:22:48:49:46:90:47:03:28:10:D1:9A:F8:00:00:80:28:07:D0:1B:49:09:78:04:F6:16:40:C0:47:59:46:76:31:0E:E0:1F:49:E4:20:88:47:1E:21:CE:E7:15:49:09:78:CB:E7:13:49:09:78:04:F6:16:40:C0:47:59:46:A8:31:15:4A"
    16:48:21.341 --
    16:48:21.341 Outgoing Dump:
    16:48:21.341 0000: 01 05 ff ff 02 2c 04 20 fa 04 f6 39 7c 1c f8 01 .....,. ...9|...
    16:48:21.341 0010: 1f 01 29 07 d1 11 78 01 f0 0f 01 08 29 02 d1 51 ..)...x.....)..Q
    16:48:21.341 0020: 78 ad 29 06 d0 76 1e 03 f1 01 03 02 f1 01 02 ed x.)..v..........
    16:48:21.341 0030: d1 01 e0 03 20 38 70 5e b2 3a 2e 13 d1 03 28 11 .... 8p^.:....(.
    16:48:21.341 0040: d0 94 f8 74 1f 01 29 05 d1 94 f8 75 1f 01 f0 0f ...t..)....u....
    16:48:21.341 0050: 01 08 29 05 d0 94 f8 75 1f 01 29 03 d1 01 20 00 ..)....u..)... .
    16:48:21.341 0060: e0 02 20 38 70 00 2e 16 dd 03 28 14 d1 1e 2e 05 .. 8p.....(.....
    16:48:21.341 0070: d1 37 4a 35 48 49 46 90 47 03 28 0c d0 35 4a b1 .7J5HIF.G.(..5J.
    16:48:21.341 0080: b2 48 46 90 47 48 46 31 46 38 70 04 f6 16 40 c0 .HF.GHF1F8p...@.
    16:48:21.341 0090: 47 59 46 8c 31 34 e0 94 f8 3a 0f 01 28 05 d1 94 GYF.14...:..(...
    16:48:21.341 00a0: f8 3b 0f 00 f0 0f 00 08 28 23 d0 94 f8 58 0f 01 .;......(#...X..
    16:48:21.341 00b0: 28 1c d1 94 f8 59 0f 00 f0 0f 00 08 28 16 d1 23 (....Y......(..#
    16:48:21.341 00c0: 4a 22 48 49 46 90 47 03 28 10 d1 9a f8 00 00 80 J"HIF.G.(.......
    16:48:21.341 00d0: 28 07 d0 1b 49 09 78 04 f6 16 40 c0 47 59 46 76 (...I.x...@.GYFv
    16:48:21.341 00e0: 31 0e e0 1f 49 e4 20 88 47 1e 21 ce e7 15 49 09 1...I. .G.!...I.
    16:48:21.341 00f0: 78 cb e7 13 49 09 78 04 f6 16 40 c0 47 59 46 a8 x...I.x...@.GYF.
    16:48:21.341 0100: 31 15 4a 1.J
    16:48:21.372 Incoming Dump:
    16:48:21.372 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.372 --
    16:48:21.372 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.372 Parameters:
    16:48:21.372 | Number HCI commands : 0x01
    16:48:21.372 | Command Opcode : 0xff05
    16:48:21.372 | Status : 0x00 (Success)
    16:48:21.372 --
    16:48:21.372 --
    16:48:21.372 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.372 | Address : 0x20042cfc
    16:48:21.372 | Size : 0x6c
    16:48:21.372 | Values : "10:80:18:48:69:63:00:88:2C:61:92:1E:28:60:AA:62:07:48:68:61:48:46:A8:61:04:F6:3A:70:E8:61:BD:E8:F8:8F:C0:46:20:03:04:20:FD:59:00:00:23:42:00:00:14:1D:04:20:A5:49:00:00:04:F0:0E:20:24:01:04:20:6B:1D:04:20:39:67:00:00:02:05:0E:20:19:42:00:00:7F:71:00:00:66:02:0E:20:19:67:00:00:05:4C:00:00:87:71:00:00:1E:1D:04:20:30:27:04:20"
    16:48:21.372 --
    16:48:21.372 Outgoing Dump:
    16:48:21.372 0000: 01 05 ff 71 fc 2c 04 20 6c 10 80 18 48 69 63 00 ...q.,. l...Hic.
    16:48:21.372 0010: 88 2c 61 92 1e 28 60 aa 62 07 48 68 61 48 46 a8 .,a..(`.b.HhaHF.
    16:48:21.372 0020: 61 04 f6 3a 70 e8 61 bd e8 f8 8f c0 46 20 03 04 a..:p.a.....F ..
    16:48:21.372 0030: 20 fd 59 00 00 23 42 00 00 14 1d 04 20 a5 49 00 .Y..#B..... .I.
    16:48:21.372 0040: 00 04 f0 0e 20 24 01 04 20 6b 1d 04 20 39 67 00 .... $.. k.. 9g.
    16:48:21.372 0050: 00 02 05 0e 20 19 42 00 00 7f 71 00 00 66 02 0e .... .B...q..f..
    16:48:21.372 0060: 20 19 67 00 00 05 4c 00 00 87 71 00 00 1e 1d 04 .g...L...q.....
    16:48:21.372 0070: 20 30 27 04 20 0'.
    16:48:21.388 Incoming Dump:
    16:48:21.388 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.388 --
    16:48:21.388 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.388 Parameters:
    16:48:21.388 | Number HCI commands : 0x01
    16:48:21.388 | Command Opcode : 0xff05
    16:48:21.388 | Status : 0x00 (Success)
    16:48:21.388 --
    16:48:21.388 --
    16:48:21.388 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.388 | Address : 0x200433b4
    16:48:21.388 | Size : 0x4c
    16:48:21.388 | Values : "00:B5:01:48:80:47:00:BD:7F:27:04:20:15:28:04:20:E3:28:04:20:41:29:04:20:AB:28:04:20:25:29:04:20:07:29:04:20:DB:28:04:20:BD:29:04:20:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00"
    16:48:21.388 --
    16:48:21.388 Outgoing Dump:
    16:48:21.388 0000: 01 05 ff 51 b4 33 04 20 4c 00 b5 01 48 80 47 00 ...Q.3. L...H.G.
    16:48:21.388 0010: bd 7f 27 04 20 15 28 04 20 e3 28 04 20 41 29 04 ..'. .(. .(. A).
    16:48:21.388 0020: 20 ab 28 04 20 25 29 04 20 07 29 04 20 db 28 04 .(. %). .). .(.
    16:48:21.388 0030: 20 bd 29 04 20 00 00 00 00 00 00 00 00 00 00 00 .). ...........
    16:48:21.388 0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:21.388 0050: 00 00 00 00 00 .....
    16:48:21.404 Incoming Dump:
    16:48:21.404 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.404 --
    16:48:21.404 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.404 Parameters:
    16:48:21.404 | Number HCI commands : 0x01
    16:48:21.404 | Command Opcode : 0xff05
    16:48:21.404 | Status : 0x00 (Success)
    16:48:21.404 --
    16:48:21.404 --
    16:48:21.404 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.404 | Address : 0x2007a080
    16:48:21.404 | Size : 0x40
    16:48:21.404 | Values : "19:56:00:00:E1:4A:00:00:E5:59:00:00:3D:42:00:00:51:4D:00:00:E1:4B:00:00:75:44:00:00:89:5F:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00"
    16:48:21.404 --
    16:48:21.404 Outgoing Dump:
    16:48:21.404 0000: 01 05 ff 45 80 a0 07 20 40 19 56 00 00 e1 4a 00 ...E... @.V...J.
    16:48:21.404 0010: 00 e5 59 00 00 3d 42 00 00 51 4d 00 00 e1 4b 00 ..Y..=B..QM...K.
    16:48:21.404 0020: 00 75 44 00 00 89 5f 00 00 00 00 00 00 00 00 00 .uD..._.........
    16:48:21.404 0030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:21.404 0040: 00 00 00 00 00 00 00 00 00 .........
    16:48:21.419 Incoming Dump:
    16:48:21.419 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.419 --
    16:48:21.419 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.419 Parameters:
    16:48:21.419 | Number HCI commands : 0x01
    16:48:21.419 | Command Opcode : 0xff05
    16:48:21.419 | Status : 0x00 (Success)
    16:48:21.419 --
    16:48:21.419 --
    16:48:21.419 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:21.419 | Address : 0x200433b0
    16:48:21.419 | Type : 0x04
    16:48:21.419 | Value : 0x200433b4
    16:48:21.419 --
    16:48:21.419 Outgoing Dump:
    16:48:21.419 0000: 01 03 ff 09 b0 33 04 20 04 b4 33 04 20 .....3. ..3.
    16:48:21.435 Incoming Dump:
    16:48:21.435 0000: 04 0e 04 01 03 ff 00 .......
    16:48:21.435 --
    16:48:21.435 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:21.435 Parameters:
    16:48:21.435 | Number HCI commands : 0x01
    16:48:21.435 | Command Opcode : 0xff03
    16:48:21.435 | Status : 0x00 (Success)
    16:48:21.435 --
    16:48:21.435 --
    16:48:21.435 Packet "HCI_VS_Write_Hardware_Register", Opcode 0xff01
    16:48:21.435 | Address : 0x20014000
    16:48:21.435 | Value : 0x0001
    16:48:21.435 --
    16:48:21.435 Outgoing Dump:
    16:48:21.435 0000: 01 01 ff 06 00 40 01 20 01 00 .....@. ..
    16:48:21.451 Incoming Dump:
    16:48:21.451 0000: 04 0e 04 01 01 ff 00 .......
    16:48:21.451 --
    16:48:21.451 Packet "HCI_Command_Complete_VS_Write_Hardware_Register_Event", Opcode 0xff01
    16:48:21.451 Parameters:
    16:48:21.451 | Number HCI commands : 0x01
    16:48:21.451 | Command Opcode : 0xff01
    16:48:21.451 | Status : 0x00 (Success)
    16:48:21.451 --
    16:48:21.451 --
    16:48:21.451 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.451 | Address : 0x20000000
    16:48:21.451 | Size : 0xf0
    16:48:21.451 | Values : "00:0C:01:20:3D:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:7F:4E:00:00:7F:4E:00:00:00:00:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:A9:36:00:00:F3:33:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:2D:35:00:00:C5:34:00:00:7F:4E:00:00:7F:4E:00:00:7F:4E:00:00:CD:36:00:00:7F:4E:00:00:AD:30:00:00:00:B5:02:20:03:F0:5E:FD:9E:49:01:20:08:70:00:BD:2D:E9:F0:4F:0E:46:9C:49:81:46:C8:8A:4F:EA:00:2B:88:8A:45:02:48:8A:09:88:17:46:00:04:CC:02:03:F0:E1:FE:80:46:28:46:03:F0:DD:FE:82:46:20:46:03:F0:D9:FE:05:46:91:48:00:78:00:28:0C:BF:61:24:91:24:B9:F1:01:0F:44:44:A4:EB"
    16:48:21.451 --
    16:48:21.451 Outgoing Dump:
    16:48:21.451 0000: 01 05 ff f5 00 00 00 20 f0 00 0c 01 20 3d 4e 00 ....... .... =N.
    16:48:21.451 0010: 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 ..N...N...N...N.
    16:48:21.451 0020: 00 7f 4e 00 00 00 00 00 00 00 00 00 00 00 00 00 ..N.............
    16:48:21.451 0030: 00 00 00 00 00 7f 4e 00 00 7f 4e 00 00 00 00 00 ......N...N.....
    16:48:21.451 0040: 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 ..N...N...N...N.
    16:48:21.451 0050: 00 a9 36 00 00 f3 33 00 00 7f 4e 00 00 7f 4e 00 ..6...3...N...N.
    16:48:21.451 0060: 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 ..N...N...N...N.
    16:48:21.451 0070: 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 00 7f 4e 00 ..N...N...N...N.
    16:48:21.451 0080: 00 2d 35 00 00 c5 34 00 00 7f 4e 00 00 7f 4e 00 .-5...4...N...N.
    16:48:21.451 0090: 00 7f 4e 00 00 cd 36 00 00 7f 4e 00 00 ad 30 00 ..N...6...N...0.
    16:48:21.451 00a0: 00 00 b5 02 20 03 f0 5e fd 9e 49 01 20 08 70 00 .... ..^..I. .p.
    16:48:21.451 00b0: bd 2d e9 f0 4f 0e 46 9c 49 81 46 c8 8a 4f ea 00 .-..O.F.I.F..O..
    16:48:21.451 00c0: 2b 88 8a 45 02 48 8a 09 88 17 46 00 04 cc 02 03 +..E.H....F.....
    16:48:21.451 00d0: f0 e1 fe 80 46 28 46 03 f0 dd fe 82 46 20 46 03 ....F(F.....F F.
    16:48:21.451 00e0: f0 d9 fe 05 46 91 48 00 78 00 28 0c bf 61 24 91 ....F.H.x.(..a$.
    16:48:21.451 00f0: 24 b9 f1 01 0f 44 44 a4 eb $....DD..
    16:48:21.482 Incoming Dump:
    16:48:21.482 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.482 --
    16:48:21.482 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.482 Parameters:
    16:48:21.482 | Number HCI commands : 0x01
    16:48:21.482 | Command Opcode : 0xff05
    16:48:21.482 | Status : 0x00 (Success)
    16:48:21.482 --
    16:48:21.482 --
    16:48:21.482 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.482 | Address : 0x200000f0
    16:48:21.482 | Size : 0xf0
    16:48:21.482 | Values : "0A:04:10:D0:58:46:03:F0:C9:FE:28:1A:B6:30:04:D4:B0:F5:80:7F:A8:BF:FF:20:00:E0:00:20:30:70:A3:48:00:88:02:28:00:D1:2C:19:00:2C:04:D4:B4:F5:80:7F:A8:BF:FF:24:00:E0:00:24:3C:70:BD:E8:F0:8F:B0:49:91:F8:4A:20:C8:6C:B0:FB:F2:F0:AE:4A:13:46:08:60:5B:08:83:42:09:D2:82:42:3C:BF:82:08:02:20:02:D3:08:68:42:08:01:20:0A:60:00:E0:00:20:AE:49:08:70:70:47:AE:48:01:89:00:29:0C:BF:00:68:40:68:B3:49:B0:FB:F1:F0:40:1D:0A:21:B0:FB:F1:F1:87:48:20:38:01:70:70:47:70:B5:01:46:B1:F5:80:71:04:46:09:D0:B1:F5:E0:61:04:D0:B1:F5:00:61:08:BF:19:26:02:E0:78:26:00:E0:02:26:AE:4D:A8:88:04:42:0D:D0:30:46:03:F0:D4:FC:99:48:B0:30:00:68:00:0E:05:D3:41:F2:11:12:31:46:3E:20:03:F0:ED:FC:28:88:04:43:2C:80:70:BD:10:B5:4F:F4:80:70:FF:F7:D4:FF:A2:4C:6F:48"
    16:48:21.482 --
    16:48:21.482 Outgoing Dump:
    16:48:21.482 0000: 01 05 ff f5 f0 00 00 20 f0 0a 04 10 d0 58 46 03 ....... .....XF.
    16:48:21.482 0010: f0 c9 fe 28 1a b6 30 04 d4 b0 f5 80 7f a8 bf ff ...(..0.........
    16:48:21.482 0020: 20 00 e0 00 20 30 70 a3 48 00 88 02 28 00 d1 2c ... 0p.H...(..,
    16:48:21.482 0030: 19 00 2c 04 d4 b4 f5 80 7f a8 bf ff 24 00 e0 00 ..,.........$...
    16:48:21.482 0040: 24 3c 70 bd e8 f0 8f b0 49 91 f8 4a 20 c8 6c b0 $<p.....I..J .l.
    16:48:21.482 0050: fb f2 f0 ae 4a 13 46 08 60 5b 08 83 42 09 d2 82 ....J.F.`[..B...
    16:48:21.482 0060: 42 3c bf 82 08 02 20 02 d3 08 68 42 08 01 20 0a B<.... ...hB.. .
    16:48:21.482 0070: 60 00 e0 00 20 ae 49 08 70 70 47 ae 48 01 89 00 `... .I.ppG.H...
    16:48:21.482 0080: 29 0c bf 00 68 40 68 b3 49 b0 fb f1 f0 40 1d 0a )...h@h.I....@..
    16:48:21.482 0090: 21 b0 fb f1 f1 87 48 20 38 01 70 70 47 70 b5 01 !.....H 8.ppGp..
    16:48:21.482 00a0: 46 b1 f5 80 71 04 46 09 d0 b1 f5 e0 61 04 d0 b1 F...q.F.....a...
    16:48:21.482 00b0: f5 00 61 08 bf 19 26 02 e0 78 26 00 e0 02 26 ae ..a...&..x&...&.
    16:48:21.482 00c0: 4d a8 88 04 42 0d d0 30 46 03 f0 d4 fc 99 48 b0 M...B..0F.....H.
    16:48:21.482 00d0: 30 00 68 00 0e 05 d3 41 f2 11 12 31 46 3e 20 03 0.h....A...1F> .
    16:48:21.482 00e0: f0 ed fc 28 88 04 43 2c 80 70 bd 10 b5 4f f4 80 ...(..C,.p...O..
    16:48:21.482 00f0: 70 ff f7 d4 ff a2 4c 6f 48 p.....LoH
    16:48:21.513 Incoming Dump:
    16:48:21.513 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.513 --
    16:48:21.513 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.513 Parameters:
    16:48:21.513 | Number HCI commands : 0x01
    16:48:21.513 | Command Opcode : 0xff05
    16:48:21.513 | Status : 0x00 (Success)
    16:48:21.513 --
    16:48:21.513 --
    16:48:21.513 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.513 | Address : 0x200001e0
    16:48:21.513 | Size : 0xf0
    16:48:21.513 | Values : "4F:F4:A0:61:3C:30:01:80:01:20:04:F8:1C:0C:84:F8:4C:00:84:F8:48:00:84:F8:54:00:04:F8:38:0C:84:F8:D8:00:20:70:84:F8:7C:00:00:20:03:F0:A7:FC:00:20:20:70:84:F8:7C:00:84:F8:E8:04:10:BD:00:B5:4F:F4:80:70:FF:F7:AF:FF:8F:49:00:20:08:80:8E:49:38:39:81:F8:10:01:08:70:81:F8:8C:00:81:F8:80:00:81:F8:84:00:81:F8:20:05:00:BD:70:B5:4F:F4:80:50:FF:F7:99:FF:86:4C:94:F8:A4:09:F0:B9:81:49:40:39:08:88:00:26:20:F0:1C:00:08:80:06:20:26:70:03:F0:76:FC:84:F8:80:60:06:20:03:F0:71:FC:01:25:84:F8:28:51:05:20:03:F0:6B:FC:25:70:05:20:84:F8:34:51:03:F0:65:FC:84:F8:80:50:05:E0:01:25:84:F8:28:51:84:F8:34:51:00:26:84:F8:24:59:84:F8:20:69:70:BD:30:B5:4F:F4:80:50:FF:F7:66:FF:6D:4D:00:24:06:20:2C:73:03:F0:4C:FC:66:49:2C:70:40:39:08:88:40:F0:1C:00"
    16:48:21.513 --
    16:48:21.513 Outgoing Dump:
    16:48:21.513 0000: 01 05 ff f5 e0 01 00 20 f0 4f f4 a0 61 3c 30 01 ....... .O..a<0.
    16:48:21.513 0010: 80 01 20 04 f8 1c 0c 84 f8 4c 00 84 f8 48 00 84 .. ......L...H..
    16:48:21.513 0020: f8 54 00 04 f8 38 0c 84 f8 d8 00 20 70 84 f8 7c .T...8..... p..|
    16:48:21.513 0030: 00 00 20 03 f0 a7 fc 00 20 20 70 84 f8 7c 00 84 .. ..... p..|..
    16:48:21.513 0040: f8 e8 04 10 bd 00 b5 4f f4 80 70 ff f7 af ff 8f .......O..p.....
    16:48:21.513 0050: 49 00 20 08 80 8e 49 38 39 81 f8 10 01 08 70 81 I. ...I89.....p.
    16:48:21.513 0060: f8 8c 00 81 f8 80 00 81 f8 84 00 81 f8 20 05 00 ............. ..
    16:48:21.513 0070: bd 70 b5 4f f4 80 50 ff f7 99 ff 86 4c 94 f8 a4 .p.O..P.....L...
    16:48:21.513 0080: 09 f0 b9 81 49 40 39 08 88 00 26 20 f0 1c 00 08 ....I@9...& ....
    16:48:21.513 0090: 80 06 20 26 70 03 f0 76 fc 84 f8 80 60 06 20 03 .. &p..v....`. .
    16:48:21.513 00a0: f0 71 fc 01 25 84 f8 28 51 05 20 03 f0 6b fc 25 .q..%..(Q. ..k.%
    16:48:21.513 00b0: 70 05 20 84 f8 34 51 03 f0 65 fc 84 f8 80 50 05 p. ..4Q..e....P.
    16:48:21.513 00c0: e0 01 25 84 f8 28 51 84 f8 34 51 00 26 84 f8 24 ..%..(Q..4Q.&..$
    16:48:21.513 00d0: 59 84 f8 20 69 70 bd 30 b5 4f f4 80 50 ff f7 66 Y.. ip.0.O..P..f
    16:48:21.513 00e0: ff 6d 4d 00 24 06 20 2c 73 03 f0 4c fc 66 49 2c .mM.$. ,s..L.fI,
    16:48:21.513 00f0: 70 40 39 08 88 40 f0 1c 00 p@9..@...
    16:48:21.544 Incoming Dump:
    16:48:21.544 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.544 --
    16:48:21.544 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.544 Parameters:
    16:48:21.544 | Number HCI commands : 0x01
    16:48:21.544 | Command Opcode : 0xff05
    16:48:21.544 | Status : 0x00 (Success)
    16:48:21.544 --
    16:48:21.544 --
    16:48:21.544 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.544 | Address : 0x200002d0
    16:48:21.544 | Size : 0xf0
    16:48:21.544 | Values : "08:80:85:F8:FC:47:85:F8:F8:47:30:BD:B0:F9:00:20:47:F6:FF:73:93:42:07:D0:C2:EB:C1:13:61:49:09:88:59:43:02:EB:21:22:00:E0:CA:01:02:80:70:47:10:B5:02:78:42:B1:5B:4B:1B:88:C3:F5:80:74:62:43:01:FB:03:21:80:31:09:12:01:70:10:BD:C0:46:24:20:3E:22:06:81:01:20:C0:22:30:22:2D:E9:F0:41:8C:46:01:28:17:46:19:46:2F:D0:DF:F8:FC:82:B8:F8:04:00:BE:4D:C0:F3:42:04:34:B9:85:F8:68:70:85:F8:60:C0:85:F8:58:10:16:E0:26:4E:06:EB:44:06:B0:1D:FF:F7:BE:FF:B6:F9:06:00:64:19:61:46:40:30:C0:11:84:F8:58:00:04:F1:60:00:FF:F7:C3:FF:39:46:04:F1:68:00:FF:F7:BE:FF:AE:48:00:78:80:08:05:D3:B8:F8:00:00:C0:F3:86:10:2D:18:2F:72:BD:E8:F0:81:C0:46:58:40:01:20:A7:49:00:28:0C:BF:B1:F8:14:01:B1:F8:16:01:40:01:09:78:00:B2:80:30:C2:11:00:EB:12:60:0D:22:02:EB"
    16:48:21.544 --
    16:48:21.544 Outgoing Dump:
    16:48:21.544 0000: 01 05 ff f5 d0 02 00 20 f0 08 80 85 f8 fc 47 85 ....... ......G.
    16:48:21.544 0010: f8 f8 47 30 bd b0 f9 00 20 47 f6 ff 73 93 42 07 ..G0.... G..s.B.
    16:48:21.544 0020: d0 c2 eb c1 13 61 49 09 88 59 43 02 eb 21 22 00 .....aI..YC..!".
    16:48:21.544 0030: e0 ca 01 02 80 70 47 10 b5 02 78 42 b1 5b 4b 1b .....pG...xB.[K.
    16:48:21.544 0040: 88 c3 f5 80 74 62 43 01 fb 03 21 80 31 09 12 01 ....tbC...!.1...
    16:48:21.544 0050: 70 10 bd c0 46 24 20 3e 22 06 81 01 20 c0 22 30 p...F$ >"... ."0
    16:48:21.544 0060: 22 2d e9 f0 41 8c 46 01 28 17 46 19 46 2f d0 df "-..A.F.(.F.F/..
    16:48:21.544 0070: f8 fc 82 b8 f8 04 00 be 4d c0 f3 42 04 34 b9 85 ........M..B.4..
    16:48:21.544 0080: f8 68 70 85 f8 60 c0 85 f8 58 10 16 e0 26 4e 06 .hp..`...X...&N.
    16:48:21.544 0090: eb 44 06 b0 1d ff f7 be ff b6 f9 06 00 64 19 61 .D...........d.a
    16:48:21.544 00a0: 46 40 30 c0 11 84 f8 58 00 04 f1 60 00 ff f7 c3 F@0....X...`....
    16:48:21.544 00b0: ff 39 46 04 f1 68 00 ff f7 be ff ae 48 00 78 80 .9F..h......H.x.
    16:48:21.544 00c0: 08 05 d3 b8 f8 00 00 c0 f3 86 10 2d 18 2f 72 bd ...........-./r.
    16:48:21.544 00d0: e8 f0 81 c0 46 58 40 01 20 a7 49 00 28 0c bf b1 ....FX@. .I.(...
    16:48:21.544 00e0: f8 14 01 b1 f8 16 01 40 01 09 78 00 b2 80 30 c2 .......@..x...0.
    16:48:21.544 00f0: 11 00 eb 12 60 0d 22 02 eb ....`."..
    16:48:21.576 Incoming Dump:
    16:48:21.576 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.576 --
    16:48:21.576 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.576 Parameters:
    16:48:21.576 | Number HCI commands : 0x01
    16:48:21.576 | Command Opcode : 0xff05
    16:48:21.576 | Status : 0x00 (Success)
    16:48:21.576 --
    16:48:21.576 --
    16:48:21.576 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.576 | Address : 0x200003c0
    16:48:21.576 | Size : 0xf0
    16:48:21.576 | Values : "20:22:10:B2:40:1A:00:B2:10:F1:80:0F:B8:BF:6F:F0:7F:00:40:B2:70:47:10:B5:C0:4C:01:20:20:70:00:20:03:F0:BC:FB:00:20:20:70:03:F0:B8:FB:10:BD:C0:46:80:08:01:20:00:00:EE:02:B9:49:0A:88:00:28:42:F4:40:72:0A:80:1B:4A:07:BF:10:1C:16:30:10:1C:18:30:00:78:08:73:70:47:C0:46:1B:B1:01:20:00:01:01:20:B0:49:09:68:B0:FB:F1:F2:02:FB:11:00:80:01:89:0A:B0:FB:F1:F0:00:EB:02:40:00:02:70:47:40:42:0F:00:A9:4A:02:EB:41:02:A9:49:01:EB:C0:00:B2:F8:70:11:01:80:B2:F8:80:11:41:80:B2:F8:90:11:81:80:70:47:58:B5:01:20:94:40:01:20:38:A6:36:22:00:A2:36:22:28:A3:36:22:28:05:01:20:2D:E9:F0:4F:88:46:07:46:93:46:B8:F1:00:0F:14:BF:01:20:02:20:98:4D:29:88:99:4E:21:F0:03:01:08:43:96:49:28:80:08:88:40:F0:70:00:08:80:01:20:06:F8:D4:0C:00:24:06:F8:D0:0C"
    16:48:21.576 --
    16:48:21.576 Outgoing Dump:
    16:48:21.576 0000: 01 05 ff f5 c0 03 00 20 f0 20 22 10 b2 40 1a 00 ....... . "..@..
    16:48:21.576 0010: b2 10 f1 80 0f b8 bf 6f f0 7f 00 40 b2 70 47 10 .......o...@.pG.
    16:48:21.576 0020: b5 c0 4c 01 20 20 70 00 20 03 f0 bc fb 00 20 20 ..L. p. .....
    16:48:21.576 0030: 70 03 f0 b8 fb 10 bd c0 46 80 08 01 20 00 00 ee p.......F... ...
    16:48:21.576 0040: 02 b9 49 0a 88 00 28 42 f4 40 72 0a 80 1b 4a 07 ..I...(B.@r...J.
    16:48:21.576 0050: bf 10 1c 16 30 10 1c 18 30 00 78 08 73 70 47 c0 ....0...0.x.spG.
    16:48:21.576 0060: 46 1b b1 01 20 00 01 01 20 b0 49 09 68 b0 fb f1 F... ... .I.h...
    16:48:21.576 0070: f2 02 fb 11 00 80 01 89 0a b0 fb f1 f0 00 eb 02 ................
    16:48:21.576 0080: 40 00 02 70 47 40 42 0f 00 a9 4a 02 eb 41 02 a9 @..pG@B...J..A..
    16:48:21.576 0090: 49 01 eb c0 00 b2 f8 70 11 01 80 b2 f8 80 11 41 I......p.......A
    16:48:21.576 00a0: 80 b2 f8 90 11 81 80 70 47 58 b5 01 20 94 40 01 .......pGX.. .@.
    16:48:21.576 00b0: 20 38 a6 36 22 00 a2 36 22 28 a3 36 22 28 05 01 8.6"..6"(.6"(..
    16:48:21.576 00c0: 20 2d e9 f0 4f 88 46 07 46 93 46 b8 f1 00 0f 14 -..O.F.F.F.....
    16:48:21.576 00d0: bf 01 20 02 20 98 4d 29 88 99 4e 21 f0 03 01 08 .. . .M)..N!....
    16:48:21.576 00e0: 43 96 49 28 80 08 88 40 f0 70 00 08 80 01 20 06 C.I(...@.p.... .
    16:48:21.576 00f0: f8 d4 0c 00 24 06 f8 d0 0c ....$....
    16:48:21.607 Incoming Dump:
    16:48:21.607 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.607 --
    16:48:21.607 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.607 Parameters:
    16:48:21.607 | Number HCI commands : 0x01
    16:48:21.607 | Command Opcode : 0xff05
    16:48:21.607 | Status : 0x00 (Success)
    16:48:21.607 --
    16:48:21.607 --
    16:48:21.607 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.607 | Address : 0x200004b0
    16:48:21.607 | Size : 0xf0
    16:48:21.607 | Values : "1F:3D:06:F8:98:0C:C5:F8:53:40:B8:F1:00:0F:30:70:08:BF:30:72:DF:F8:20:A2:B9:48:B8:F1:00:0F:00:FB:07:F0:08:D0:51:46:89:1D:B1:F9:00:10:4F:F4:7A:72:01:FB:02:F1:40:1A:FF:F7:9B:FF:C5:F8:47:00:20:46:03:F0:34:FB:A1:46:B8:F1:00:0F:86:F8:00:90:08:BF:86:F8:08:90:56:46:B0:8C:C1:11:49:08:2C:BF:00:F0:03:00:48:46:03:F0:7A:FC:FF:20:B8:F1:00:0F:85:F8:57:00:09:D1:A1:48:01:78:4F:EA:4B:00:00:EB:81:00:30:18:B0:F8:A6:00:01:E0:B6:F8:AA:00:78:43:4F:EA:4B:01:00:14:89:19:A5:F8:07:00:B1:F8:B2:30:B1:F8:B6:00:A7:F6:62:12:40:02:03:FB:12:00:00:14:25:F8:01:0C:B1:F8:AE:00:A5:F8:03:00:48:46:03:F0:F6:FA:85:F8:57:90:FF:F7:2F:FF:08:27:03:2C:05:D1:B8:F1:00:0F:04:BF:03:20:05:21:01:D0:E1:B2:E0:B2:FF:F7:57:FF:24:B1:30:19:90:F8:6B:01:03:F0:DF:FA:B5:F8"
    16:48:21.607 --
    16:48:21.607 Outgoing Dump:
    16:48:21.607 0000: 01 05 ff f5 b0 04 00 20 f0 1f 3d 06 f8 98 0c c5 ....... ..=.....
    16:48:21.607 0010: f8 53 40 b8 f1 00 0f 30 70 08 bf 30 72 df f8 20 .S@....0p..0r..
    16:48:21.607 0020: a2 b9 48 b8 f1 00 0f 00 fb 07 f0 08 d0 51 46 89 ..H..........QF.
    16:48:21.607 0030: 1d b1 f9 00 10 4f f4 7a 72 01 fb 02 f1 40 1a ff .....O.zr....@..
    16:48:21.607 0040: f7 9b ff c5 f8 47 00 20 46 03 f0 34 fb a1 46 b8 .....G. F..4..F.
    16:48:21.607 0050: f1 00 0f 86 f8 00 90 08 bf 86 f8 08 90 56 46 b0 .............VF.
    16:48:21.607 0060: 8c c1 11 49 08 2c bf 00 f0 03 00 48 46 03 f0 7a ...I.,.....HF..z
    16:48:21.607 0070: fc ff 20 b8 f1 00 0f 85 f8 57 00 09 d1 a1 48 01 .. ......W....H.
    16:48:21.607 0080: 78 4f ea 4b 00 00 eb 81 00 30 18 b0 f8 a6 00 01 xO.K.....0......
    16:48:21.607 0090: e0 b6 f8 aa 00 78 43 4f ea 4b 01 00 14 89 19 a5 .....xCO.K......
    16:48:21.607 00a0: f8 07 00 b1 f8 b2 30 b1 f8 b6 00 a7 f6 62 12 40 ......0......b.@
    16:48:21.607 00b0: 02 03 fb 12 00 00 14 25 f8 01 0c b1 f8 ae 00 a5 .......%........
    16:48:21.607 00c0: f8 03 00 48 46 03 f0 f6 fa 85 f8 57 90 ff f7 2f ...HF......W.../
    16:48:21.607 00d0: ff 08 27 03 2c 05 d1 b8 f1 00 0f 04 bf 03 20 05 ..'.,......... .
    16:48:21.607 00e0: 21 01 d0 e1 b2 e0 b2 ff f7 57 ff 24 b1 30 19 90 !........W.$.0..
    16:48:21.607 00f0: f8 6b 01 03 f0 df fa b5 f8 .k.......
    16:48:21.638 Incoming Dump:
    16:48:21.638 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.638 --
    16:48:21.638 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.638 Parameters:
    16:48:21.638 | Number HCI commands : 0x01
    16:48:21.638 | Command Opcode : 0xff05
    16:48:21.638 | Status : 0x00 (Success)
    16:48:21.638 --
    16:48:21.638 --
    16:48:21.638 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.638 | Address : 0x200005a0
    16:48:21.638 | Size : 0xf0
    16:48:21.638 | Values : "53:00:47:FA:04:F1:64:1C:20:F0:0F:00:04:2C:41:EA:00:01:A5:F8:53:10:E0:DB:B5:F8:55:00:B8:F1:01:0F:E1:B2:40:F0:70:00:A5:F8:55:00:07:D1:B5:F8:55:00:20:F4:80:70:40:F0:80:00:A5:F8:55:00:70:18:90:F8:6B:01:03:F0:BB:FA:AE:4C:B8:F1:00:0F:05:D0:96:F8:C0:00:30:F0:7F:00:08:D1:05:E0:01:20:20:70:B6:F8:B2:02:03:F0:AB:FA:84:F8:00:90:86:F8:0C:90:BD:E8:F0:8F:AC:49:01:20:08:70:03:F0:A0:BA:00:B5:03:F0:9D:FA:A8:48:01:21:30:38:01:70:60:48:37:30:01:70:00:BD:C0:46:02:00:01:20:50:00:01:20:57:01:01:20:94:81:01:20:27:48:47:F6:FF:73:07:22:01:46:08:31:52:1E:21:F8:02:3B:FB:D1:9E:4B:19:68:00:22:01:60:80:F8:22:20:80:F8:56:20:80:F8:55:20:80:F8:54:20:80:F8:53:20:80:F8:21:20:80:F8:20:20:82:76:02:76:B3:F8:9A:10:C2:82:01:F0:1F:01:03:29:14:BF:8E:49"
    16:48:21.638 --
    16:48:21.638 Outgoing Dump:
    16:48:21.638 0000: 01 05 ff f5 a0 05 00 20 f0 53 00 47 fa 04 f1 64 ....... .S.G...d
    16:48:21.638 0010: 1c 20 f0 0f 00 04 2c 41 ea 00 01 a5 f8 53 10 e0 . ....,A.....S..
    16:48:21.638 0020: db b5 f8 55 00 b8 f1 01 0f e1 b2 40 f0 70 00 a5 ...U.......@.p..
    16:48:21.638 0030: f8 55 00 07 d1 b5 f8 55 00 20 f4 80 70 40 f0 80 .U.....U. ..p@..
    16:48:21.638 0040: 00 a5 f8 55 00 70 18 90 f8 6b 01 03 f0 bb fa ae ...U.p...k......
    16:48:21.638 0050: 4c b8 f1 00 0f 05 d0 96 f8 c0 00 30 f0 7f 00 08 L..........0....
    16:48:21.638 0060: d1 05 e0 01 20 20 70 b6 f8 b2 02 03 f0 ab fa 84 .... p.........
    16:48:21.638 0070: f8 00 90 86 f8 0c 90 bd e8 f0 8f ac 49 01 20 08 ............I. .
    16:48:21.638 0080: 70 03 f0 a0 ba 00 b5 03 f0 9d fa a8 48 01 21 30 p...........H.!0
    16:48:21.638 0090: 38 01 70 60 48 37 30 01 70 00 bd c0 46 02 00 01 8.p`H70.p...F...
    16:48:21.638 00a0: 20 50 00 01 20 57 01 01 20 94 81 01 20 27 48 47 P.. W.. ... 'HG
    16:48:21.638 00b0: f6 ff 73 07 22 01 46 08 31 52 1e 21 f8 02 3b fb ..s.".F.1R.!..;.
    16:48:21.638 00c0: d1 9e 4b 19 68 00 22 01 60 80 f8 22 20 80 f8 56 ..K.h.".`.." ..V
    16:48:21.638 00d0: 20 80 f8 55 20 80 f8 54 20 80 f8 53 20 80 f8 21 ..U ..T ..S ..!
    16:48:21.638 00e0: 20 80 f8 20 20 82 76 02 76 b3 f8 9a 10 c2 82 01 .. .v.v.......
    16:48:21.638 00f0: f0 1f 01 03 29 14 bf 8e 49 ....)...I
    16:48:21.669 Incoming Dump:
    16:48:21.669 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.669 --
    16:48:21.669 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.669 Parameters:
    16:48:21.669 | Number HCI commands : 0x01
    16:48:21.669 | Command Opcode : 0xff05
    16:48:21.669 | Status : 0x00 (Success)
    16:48:21.669 --
    16:48:21.669 --
    16:48:21.669 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.669 | Address : 0x20000690
    16:48:21.669 | Size : 0xf0
    16:48:21.669 | Values : "8E:49:03:68:09:78:49:1C:80:F8:4A:10:02:21:C2:76:80:F8:4B:10:90:F8:4A:10:02:77:59:43:C1:64:42:77:80:F8:50:20:80:F8:23:20:42:76:80:F8:49:20:80:F8:24:20:80:F8:51:20:80:F8:48:20:80:F8:52:20:82:77:80:F8:57:20:7E:49:41:60:C2:77:70:47:4C:05:34:22:4A:80:01:20:80:08:01:20:50:02:01:20:DC:A0:01:20:2C:A0:01:20:18:B1:01:20:04:21:3E:22:B2:48:01:88:45:F6:A3:50:88:42:18:DB:88:42:3E:D0:FF:39:4A:D0:44:F6:EB:12:89:1A:44:D0:B1:F5:B0:71:3F:D0:A1:F6:1C:11:00:29:39:D0:A1:F2:0F:31:00:29:33:D0:B1:F5:FC:71:2E:D0:59:39:2A:D0:17:E0:46:F2:D6:52:89:1A:21:D0:B1:F5:61:71:1C:D0:43:F6:0B:22:89:1A:16:D0:A1:F2:75:11:89:B1:A1:F2:92:51:61:B1:41:F6:70:32:89:1A:06:D0:A1:F2:91:61:09:B1:FF:20:70:47:0A:20:70:47:02:20:70:47:06:20:70:47:00:20:70:47:01:20"
    16:48:21.669 --
    16:48:21.669 Outgoing Dump:
    16:48:21.669 0000: 01 05 ff f5 90 06 00 20 f0 8e 49 03 68 09 78 49 ....... ..I.h.xI
    16:48:21.669 0010: 1c 80 f8 4a 10 02 21 c2 76 80 f8 4b 10 90 f8 4a ...J..!.v..K...J
    16:48:21.669 0020: 10 02 77 59 43 c1 64 42 77 80 f8 50 20 80 f8 23 ..wYC.dBw..P ..#
    16:48:21.669 0030: 20 42 76 80 f8 49 20 80 f8 24 20 80 f8 51 20 80 Bv..I ..$ ..Q .
    16:48:21.669 0040: f8 48 20 80 f8 52 20 82 77 80 f8 57 20 7e 49 41 .H ..R .w..W ~IA
    16:48:21.669 0050: 60 c2 77 70 47 4c 05 34 22 4a 80 01 20 80 08 01 `.wpGL.4"J.. ...
    16:48:21.669 0060: 20 50 02 01 20 dc a0 01 20 2c a0 01 20 18 b1 01 P.. ... ,.. ...
    16:48:21.669 0070: 20 04 21 3e 22 b2 48 01 88 45 f6 a3 50 88 42 18 .!>".H..E..P.B.
    16:48:21.669 0080: db 88 42 3e d0 ff 39 4a d0 44 f6 eb 12 89 1a 44 ..B>..9J.D.....D
    16:48:21.669 0090: d0 b1 f5 b0 71 3f d0 a1 f6 1c 11 00 29 39 d0 a1 ....q?......)9..
    16:48:21.669 00a0: f2 0f 31 00 29 33 d0 b1 f5 fc 71 2e d0 59 39 2a ..1.)3....q..Y9*
    16:48:21.669 00b0: d0 17 e0 46 f2 d6 52 89 1a 21 d0 b1 f5 61 71 1c ...F..R..!...aq.
    16:48:21.669 00c0: d0 43 f6 0b 22 89 1a 16 d0 a1 f2 75 11 89 b1 a1 .C.."......u....
    16:48:21.669 00d0: f2 92 51 61 b1 41 f6 70 32 89 1a 06 d0 a1 f2 91 ..Qa.A.p2.......
    16:48:21.669 00e0: 61 09 b1 ff 20 70 47 0a 20 70 47 02 20 70 47 06 a... pG. pG. pG.
    16:48:21.669 00f0: 20 70 47 00 20 70 47 01 20 pG. pG.
    16:48:21.701 Incoming Dump:
    16:48:21.701 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.701 --
    16:48:21.701 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.701 Parameters:
    16:48:21.701 | Number HCI commands : 0x01
    16:48:21.701 | Command Opcode : 0xff05
    16:48:21.701 | Status : 0x00 (Success)
    16:48:21.701 --
    16:48:21.701 --
    16:48:21.701 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.701 | Address : 0x20000780
    16:48:21.701 | Size : 0xf0
    16:48:21.701 | Values : "70:47:05:20:70:47:09:20:70:47:0E:20:70:47:08:20:70:47:0D:20:70:47:03:20:70:47:0C:20:70:47:0B:20:70:47:04:20:70:47:0F:20:70:47:C0:46:9E:08:01:20:40:42:0F:00:F0:B5:B4:4D:AB:4B:B5:F8:F8:22:1E:46:4F:EA:22:22:A6:F1:0C:06:A6:4F:B2:86:A4:4A:04:46:01:F0:0F:01:6C:B3:64:1E:59:D1:05:EB:41:00:B0:F8:20:03:30:80:95:F8:F5:02:82:F8:40:00:95:F8:F5:02:40:10:10:70:95:F8:F5:02:80:10:10:74:95:F8:F5:02:C0:10:82:F8:20:00:95:F8:F4:02:00:11:10:71:95:F8:F3:02:17:22:B0:85:19:20:00:FB:01:74:18:46:21:46:04:F0:7E:FA:B5:F8:CA:01:B4:F8:17:10:C0:F3:80:00:2A:E0:05:EB:41:00:B0:F8:00:03:19:24:30:80:95:F8:F4:02:4C:43:82:F8:40:00:B1:49:95:F8:F4:02:40:10:10:70:95:F8:F4:02:80:10:10:74:95:F8:F4:02:C0:10:82:F8:20:00:95:F8:F4:02:00:11:10:71:95:F8:F2:02"
    16:48:21.701 --
    16:48:21.701 Outgoing Dump:
    16:48:21.701 0000: 01 05 ff f5 80 07 00 20 f0 70 47 05 20 70 47 09 ....... .pG. pG.
    16:48:21.701 0010: 20 70 47 0e 20 70 47 08 20 70 47 0d 20 70 47 03 pG. pG. pG. pG.
    16:48:21.701 0020: 20 70 47 0c 20 70 47 0b 20 70 47 04 20 70 47 0f pG. pG. pG. pG.
    16:48:21.701 0030: 20 70 47 c0 46 9e 08 01 20 40 42 0f 00 f0 b5 b4 pG.F... @B.....
    16:48:21.701 0040: 4d ab 4b b5 f8 f8 22 1e 46 4f ea 22 22 a6 f1 0c M.K...".FO.""...
    16:48:21.701 0050: 06 a6 4f b2 86 a4 4a 04 46 01 f0 0f 01 6c b3 64 ..O...J.F....l.d
    16:48:21.701 0060: 1e 59 d1 05 eb 41 00 b0 f8 20 03 30 80 95 f8 f5 .Y...A... .0....
    16:48:21.701 0070: 02 82 f8 40 00 95 f8 f5 02 40 10 10 70 95 f8 f5 ...@.....@..p...
    16:48:21.701 0080: 02 80 10 10 74 95 f8 f5 02 c0 10 82 f8 20 00 95 ....t........ ..
    16:48:21.701 0090: f8 f4 02 00 11 10 71 95 f8 f3 02 17 22 b0 85 19 ......q....."...
    16:48:21.701 00a0: 20 00 fb 01 74 18 46 21 46 04 f0 7e fa b5 f8 ca ...t.F!F..~....
    16:48:21.701 00b0: 01 b4 f8 17 10 c0 f3 80 00 2a e0 05 eb 41 00 b0 .........*...A..
    16:48:21.701 00c0: f8 00 03 19 24 30 80 95 f8 f4 02 4c 43 82 f8 40 ....$0.....LC..@
    16:48:21.701 00d0: 00 b1 49 95 f8 f4 02 40 10 10 70 95 f8 f4 02 80 ..I....@..p.....
    16:48:21.701 00e0: 10 10 74 95 f8 f4 02 c0 10 82 f8 20 00 95 f8 f4 ..t........ ....
    16:48:21.701 00f0: 02 00 11 10 71 95 f8 f2 02 ....q....
    16:48:21.732 Incoming Dump:
    16:48:21.732 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.732 --
    16:48:21.732 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.732 Parameters:
    16:48:21.732 | Number HCI commands : 0x01
    16:48:21.732 | Command Opcode : 0xff05
    16:48:21.732 | Status : 0x00 (Success)
    16:48:21.732 --
    16:48:21.732 --
    16:48:21.732 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.732 | Address : 0x20000870
    16:48:21.732 | Size : 0xf0
    16:48:21.732 | Values : "09:19:17:22:B0:85:18:46:04:F0:52:FA:17:37:B5:F8:CA:01:39:5B:C0:F3:40:00:71:80:A0:49:08:70:B5:F8:F6:02:F0:85:95:F8:5F:00:00:F0:0F:00:B0:87:F0:BD:70:0C:34:22:10:B5:70:4C:47:F6:FF:70:24:34:60:80:20:80:E0:89:02:20:03:F0:51:F9:17:20:60:80:20:80:10:BD:C0:46:BC:81:01:20:48:82:84:23:48:82:85:23:20:20:10:10:00:01:01:20:2D:E9:F0:4F:DF:F8:34:C2:96:46:20:B1:40:1E:01:28:98:BF:0C:F1:10:0C:01:F0:0F:00:49:08:27:BF:00:02:40:F0:55:00:00:02:40:F0:AA:00:4F:F0:00:05:4F:F0:05:0B:4F:F0:0F:09:4F:F0:09:03:A8:46:46:46:82:46:4A:FA:03:F0:00:F0:07:00:C0:F3:80:02:1A:B1:4F:F0:07:01:21:EA:00:00:5C:F8:20:10:03:2E:C1:F3:13:00:07:DB:34:B2:04:FB:0B:F4:2C:2C:B8:BF:4F:FA:B1:F1:01:DB:4F:F0:00:01:BA:B1:00:24:A7:00:09:FA:07:F2:64:1C:20:EA:02:02:F8:40"
    16:48:21.732 --
    16:48:21.732 Outgoing Dump:
    16:48:21.732 0000: 01 05 ff f5 70 08 00 20 f0 09 19 17 22 b0 85 18 ....p.. ...."...
    16:48:21.732 0010: 46 04 f0 52 fa 17 37 b5 f8 ca 01 39 5b c0 f3 40 F..R..7....9[..@
    16:48:21.732 0020: 00 71 80 a0 49 08 70 b5 f8 f6 02 f0 85 95 f8 5f .q..I.p........_
    16:48:21.732 0030: 00 00 f0 0f 00 b0 87 f0 bd 70 0c 34 22 10 b5 70 .........p.4"..p
    16:48:21.732 0040: 4c 47 f6 ff 70 24 34 60 80 20 80 e0 89 02 20 03 LG..p$4`. .... .
    16:48:21.732 0050: f0 51 f9 17 20 60 80 20 80 10 bd c0 46 bc 81 01 .Q.. `. ....F...
    16:48:21.732 0060: 20 48 82 84 23 48 82 85 23 20 20 10 10 00 01 01 H..#H..# .....
    16:48:21.732 0070: 20 2d e9 f0 4f df f8 34 c2 96 46 20 b1 40 1e 01 -..O..4..F .@..
    16:48:21.732 0080: 28 98 bf 0c f1 10 0c 01 f0 0f 00 49 08 27 bf 00 (..........I.'..
    16:48:21.732 0090: 02 40 f0 55 00 00 02 40 f0 aa 00 4f f0 00 05 4f .@.U...@...O...O
    16:48:21.732 00a0: f0 05 0b 4f f0 0f 09 4f f0 09 03 a8 46 46 46 82 ...O...O....FFF.
    16:48:21.732 00b0: 46 4a fa 03 f0 00 f0 07 00 c0 f3 80 02 1a b1 4f FJ.............O
    16:48:21.732 00c0: f0 07 01 21 ea 00 00 5c f8 20 10 03 2e c1 f3 13 ...!...\. ......
    16:48:21.732 00d0: 00 07 db 34 b2 04 fb 0b f4 2c 2c b8 bf 4f fa b1 ...4.....,,..O..
    16:48:21.732 00e0: f1 01 db 4f f0 00 01 ba b1 00 24 a7 00 09 fa 07 ...O......$.....
    16:48:21.732 00f0: f2 64 1c 20 ea 02 02 f8 40 .d. ....@
    16:48:21.763 Incoming Dump:
    16:48:21.763 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.763 --
    16:48:21.763 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.763 Parameters:
    16:48:21.763 | Number HCI commands : 0x01
    16:48:21.763 | Command Opcode : 0xff05
    16:48:21.763 | Status : 0x00 (Success)
    16:48:21.763 --
    16:48:21.763 --
    16:48:21.763 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.763 | Address : 0x20000960
    16:48:21.763 | Size : 0xf0
    16:48:21.763 | Values : "05:2C:6F:EA:00:00:00:F1:01:00:00:F0:0F:00:00:FA:07:F0:40:EA:02:00:EC:DB:11:B1:C9:43:49:1C:49:B2:72:08:38:BF:EA:1C:0B:D3:05:EB:0E:02:12:F8:01:4C:60:F3:1F:14:4F:EA:10:10:02:F8:01:4C:05:F1:02:02:4E:F8:05:00:D5:B2:11:B1:41:44:0F:FA:81:F8:5B:1E:76:1C:DB:B2:09:2E:AF:DB:1E:20:98:FB:F0:F0:2E:F8:05:00:BD:E8:F0:8F:C0:46:48:01:01:20:70:B5:00:24:4F:4E:00:25:32:46:E9:B2:20:46:FF:F7:7D:FF:6D:1C:19:36:10:2D:F6:DB:64:1C:E4:B2:00:2C:F0:D0:70:BD:F0:B5:11:20:A6:4E:24:4F:01:24:A6:4D:F0:70:B7:F8:B6:02:2C:70:03:F0:AA:F8:B7:F8:B4:02:2C:71:03:F0:A5:F8:2C:74:B7:F8:BA:02:85:F8:34:40:03:F0:9E:F8:86:F8:4A:40:20:46:2C:73:03:F0:98:F8:00:20:86:F8:4A:00:B7:F8:B8:02:03:F0:91:F8:30:88:40:F4:FF:50:30:80:97:F8:5E:00:85:F8:28:40:10:F0:07:0F:18:BF"
    16:48:21.763 --
    16:48:21.763 Outgoing Dump:
    16:48:21.763 0000: 01 05 ff f5 60 09 00 20 f0 05 2c 6f ea 00 00 00 ....`.. ..,o....
    16:48:21.763 0010: f1 01 00 00 f0 0f 00 00 fa 07 f0 40 ea 02 00 ec ...........@....
    16:48:21.763 0020: db 11 b1 c9 43 49 1c 49 b2 72 08 38 bf ea 1c 0b ....CI.I.r.8....
    16:48:21.763 0030: d3 05 eb 0e 02 12 f8 01 4c 60 f3 1f 14 4f ea 10 ........L`...O..
    16:48:21.763 0040: 10 02 f8 01 4c 05 f1 02 02 4e f8 05 00 d5 b2 11 ....L....N......
    16:48:21.763 0050: b1 41 44 0f fa 81 f8 5b 1e 76 1c db b2 09 2e af .AD....[.v......
    16:48:21.763 0060: db 1e 20 98 fb f0 f0 2e f8 05 00 bd e8 f0 8f c0 .. .............
    16:48:21.763 0070: 46 48 01 01 20 70 b5 00 24 4f 4e 00 25 32 46 e9 FH.. p..$ON.%2F.
    16:48:21.763 0080: b2 20 46 ff f7 7d ff 6d 1c 19 36 10 2d f6 db 64 . F..}.m..6.-..d
    16:48:21.763 0090: 1c e4 b2 00 2c f0 d0 70 bd f0 b5 11 20 a6 4e 24 ....,..p.... .N$
    16:48:21.763 00a0: 4f 01 24 a6 4d f0 70 b7 f8 b6 02 2c 70 03 f0 aa O.$.M.p....,p...
    16:48:21.763 00b0: f8 b7 f8 b4 02 2c 71 03 f0 a5 f8 2c 74 b7 f8 ba .....,q....,t...
    16:48:21.763 00c0: 02 85 f8 34 40 03 f0 9e f8 86 f8 4a 40 20 46 2c ...4@......J@ F,
    16:48:21.763 00d0: 73 03 f0 98 f8 00 20 86 f8 4a 00 b7 f8 b8 02 03 s..... ..J......
    16:48:21.763 00e0: f0 91 f8 30 88 40 f4 ff 50 30 80 97 f8 5e 00 85 ...0.@..P0...^..
    16:48:21.763 00f0: f8 28 40 10 f0 07 0f 18 bf .(@......
    16:48:21.794 Incoming Dump:
    16:48:21.794 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.794 --
    16:48:21.794 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.794 Parameters:
    16:48:21.794 | Number HCI commands : 0x01
    16:48:21.794 | Command Opcode : 0xff05
    16:48:21.794 | Status : 0x00 (Success)
    16:48:21.794 --
    16:48:21.794 --
    16:48:21.794 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.794 | Address : 0x20000a50
    16:48:21.794 | Size : 0xf0
    16:48:21.794 | Values : "85:F8:38:40:9A:49:08:88:20:F0:7C:00:08:80:F0:BD:80:55:30:22:70:5E:00:00:74:82:01:20:06:4B:88:49:B3:F8:7C:02:E8:39:00:F0:0F:00:A1:F8:66:00:B3:F8:7E:02:00:F0:7F:00:01:E0:50:02:01:20:A1:F8:64:00:93:F8:80:02:81:F8:79:00:B3:F8:82:02:6F:F3:5F:20:B3:F8:8E:22:A1:F8:8E:00:B3:F8:84:02:6F:F3:5F:20:A1:F8:92:00:B3:F8:86:02:6F:F3:5F:20:A1:F8:90:00:B3:F8:88:02:6F:F3:5F:20:A1:F8:8C:00:B3:F8:8A:02:6F:F3:9F:20:21:F8:0E:0C:B3:F8:8C:02:6F:F3:9F:20:21:F8:0C:0C:88:8B:62:F3:09:00:76:4A:88:83:B3:F8:94:02:00:F0:01:00:10:70:B3:F8:9A:22:08:88:62:F3:0B:20:08:80:2D:20:81:F8:06:01:70:47:30:1B:30:22:E0:5C:00:00:B0:05:01:20:2D:E9:FC:4F:4F:F0:00:08:03:46:8B:46:C1:46:4F:F0:06:04:4F:F0:01:02:4F:F0:02:01:CD:F8:00:80:CA:46:CD:F8:04:80:A3:B1:5B:1E"
    16:48:21.794 --
    16:48:21.794 Outgoing Dump:
    16:48:21.794 0000: 01 05 ff f5 50 0a 00 20 f0 85 f8 38 40 9a 49 08 ....P.. ...8@.I.
    16:48:21.794 0010: 88 20 f0 7c 00 08 80 f0 bd 80 55 30 22 70 5e 00 . .|......U0"p^.
    16:48:21.794 0020: 00 74 82 01 20 06 4b 88 49 b3 f8 7c 02 e8 39 00 .t.. .K.I..|..9.
    16:48:21.794 0030: f0 0f 00 a1 f8 66 00 b3 f8 7e 02 00 f0 7f 00 01 .....f...~......
    16:48:21.794 0040: e0 50 02 01 20 a1 f8 64 00 93 f8 80 02 81 f8 79 .P.. ..d.......y
    16:48:21.794 0050: 00 b3 f8 82 02 6f f3 5f 20 b3 f8 8e 22 a1 f8 8e .....o._ ..."...
    16:48:21.794 0060: 00 b3 f8 84 02 6f f3 5f 20 a1 f8 92 00 b3 f8 86 .....o._ .......
    16:48:21.794 0070: 02 6f f3 5f 20 a1 f8 90 00 b3 f8 88 02 6f f3 5f .o._ ........o._
    16:48:21.794 0080: 20 a1 f8 8c 00 b3 f8 8a 02 6f f3 9f 20 21 f8 0e ........o.. !..
    16:48:21.794 0090: 0c b3 f8 8c 02 6f f3 9f 20 21 f8 0c 0c 88 8b 62 .....o.. !.....b
    16:48:21.794 00a0: f3 09 00 76 4a 88 83 b3 f8 94 02 00 f0 01 00 10 ...vJ...........
    16:48:21.794 00b0: 70 b3 f8 9a 22 08 88 62 f3 0b 20 08 80 2d 20 81 p..."..b.. ..- .
    16:48:21.794 00c0: f8 06 01 70 47 30 1b 30 22 e0 5c 00 00 b0 05 01 ...pG0.0".\.....
    16:48:21.794 00d0: 20 2d e9 fc 4f 4f f0 00 08 03 46 8b 46 c1 46 4f -..OO....F.F.FO
    16:48:21.794 00e0: f0 06 04 4f f0 01 02 4f f0 02 01 cd f8 00 80 ca ...O...O........
    16:48:21.794 00f0: 46 cd f8 04 80 a3 b1 5b 1e F......[.
    16:48:21.826 Incoming Dump:
    16:48:21.826 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.826 --
    16:48:21.826 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.826 Parameters:
    16:48:21.826 | Number HCI commands : 0x01
    16:48:21.826 | Command Opcode : 0xff05
    16:48:21.826 | Status : 0x00 (Success)
    16:48:21.826 --
    16:48:21.826 --
    16:48:21.826 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.826 | Address : 0x20000b40
    16:48:21.826 | Size : 0xf0
    16:48:21.826 | Values : "0F:D0:5B:1E:0A:D0:5B:1E:10:D1:0A:46:01:21:4F:F0:03:0A:4F:F0:0B:09:00:91:88:46:01:91:05:27:15:24:04:E0:4F:F4:AD:77:01:E0:40:F2:5A:37:79:4E:01:23:79:4D:A6:F5:09:70:03:70:28:88:20:F0:03:00:02:43:2A:80:00:BF:00:BF:00:BF:00:BF:00:BF:28:88:20:F0:0C:00:40:EA:81:00:28:80:00:20:02:F0:DF:FF:06:F8:04:8C:00:BF:00:BF:00:BF:00:BF:00:BF:00:98:30:70:01:20:02:F0:D3:FF:4F:F0:00:08:86:F8:00:80:28:88:20:F4:70:70:40:EA:89:10:28:80:01:98:86:F8:1C:01:00:BF:00:BF:00:BF:00:BF:00:BF:28:88:20:F4:40:60:40:EA:8A:20:28:80:40:46:02:F0:B8:FF:82:49:08:88:20:F0:1F:00:04:43:0C:80:00:BF:00:BF:00:BF:00:BF:00:BF:BB:F1:00:0F:4F:80:05:D1:48:88:20:F0:78:00:40:F0:B0:00:48:80:40:46:02:F0:A0:FF:BD:E8:FC:8F:4D:4A:00:21:91:80:00:BF:00:BF:00:BF:00:BF:00:BF"
    16:48:21.826 --
    16:48:21.826 Outgoing Dump:
    16:48:21.826 0000: 01 05 ff f5 40 0b 00 20 f0 0f d0 5b 1e 0a d0 5b ....@.. ...[...[
    16:48:21.826 0010: 1e 10 d1 0a 46 01 21 4f f0 03 0a 4f f0 0b 09 00 ....F.!O...O....
    16:48:21.826 0020: 91 88 46 01 91 05 27 15 24 04 e0 4f f4 ad 77 01 ..F...'.$..O..w.
    16:48:21.826 0030: e0 40 f2 5a 37 79 4e 01 23 79 4d a6 f5 09 70 03 .@.Z7yN.#yM...p.
    16:48:21.826 0040: 70 28 88 20 f0 03 00 02 43 2a 80 00 bf 00 bf 00 p(. ....C*......
    16:48:21.826 0050: bf 00 bf 00 bf 28 88 20 f0 0c 00 40 ea 81 00 28 .....(. ...@...(
    16:48:21.826 0060: 80 00 20 02 f0 df ff 06 f8 04 8c 00 bf 00 bf 00 .. .............
    16:48:21.826 0070: bf 00 bf 00 bf 00 98 30 70 01 20 02 f0 d3 ff 4f .......0p. ....O
    16:48:21.826 0080: f0 00 08 86 f8 00 80 28 88 20 f4 70 70 40 ea 89 .......(. .pp@..
    16:48:21.826 0090: 10 28 80 01 98 86 f8 1c 01 00 bf 00 bf 00 bf 00 .(..............
    16:48:21.826 00a0: bf 00 bf 28 88 20 f4 40 60 40 ea 8a 20 28 80 40 ...(. .@`@.. (.@
    16:48:21.826 00b0: 46 02 f0 b8 ff 82 49 08 88 20 f0 1f 00 04 43 0c F.....I.. ....C.
    16:48:21.826 00c0: 80 00 bf 00 bf 00 bf 00 bf 00 bf bb f1 00 0f 4f ...............O
    16:48:21.826 00d0: 80 05 d1 48 88 20 f0 78 00 40 f0 b0 00 48 80 40 ...H. .x.@...H.@
    16:48:21.826 00e0: 46 02 f0 a0 ff bd e8 fc 8f 4d 4a 00 21 91 80 00 F........MJ.!...
    16:48:21.826 00f0: bf 00 bf 00 bf 00 bf 00 bf .........
    16:48:21.857 Incoming Dump:
    16:48:21.857 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.857 --
    16:48:21.857 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.857 Parameters:
    16:48:21.857 | Number HCI commands : 0x01
    16:48:21.857 | Command Opcode : 0xff05
    16:48:21.857 | Status : 0x00 (Success)
    16:48:21.857 --
    16:48:21.857 --
    16:48:21.857 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.857 | Address : 0x20000c30
    16:48:21.857 | Size : 0xf0
    16:48:21.857 | Values : "50:88:20:F0:1F:00:50:80:00:BF:00:BF:00:BF:00:BF:00:BF:10:88:20:F4:40:60:10:80:00:BF:00:BF:00:BF:00:BF:00:BF:7D:4B:10:88:20:F4:70:70:10:80:83:F8:20:11:00:BF:00:BF:00:BF:00:BF:00:BF:10:88:20:F0:03:00:40:F0:01:00:10:80:00:BF:00:BF:00:BF:00:BF:00:BF:19:70:10:88:20:F0:0C:00:10:80:70:47:C0:46:64:81:01:20:80:2C:30:22:00:B5:13:46:FF:F7:D0:FB:18:46:02:F0:5B:FF:88:49:08:78:C0:43:08:70:87:49:08:88:20:F4:80:70:40:F0:80:00:08:80:00:BD:C0:46:50:B0:01:20:00:0F:30:22:70:B5:06:46:80:48:01:25:05:70:03:20:02:F0:42:FF:00:2E:14:BF:04:20:00:20:1D:4C:00:2E:04:F1:48:04:20:73:14:BF:FF:20:1F:20:20:70:00:BF:00:BF:00:BF:00:BF:00:BF:00:2E:14:BF:03:20:28:1C:E0:70:00:BF:00:BF:00:BF:00:BF:00:BF:00:2E:14:BF:0F:20:03:20:60:70:00:20:02:F0:1E:FF"
    16:48:21.857 --
    16:48:21.857 Outgoing Dump:
    16:48:21.857 0000: 01 05 ff f5 30 0c 00 20 f0 50 88 20 f0 1f 00 50 ....0.. .P. ...P
    16:48:21.857 0010: 80 00 bf 00 bf 00 bf 00 bf 00 bf 10 88 20 f4 40 ............. .@
    16:48:21.857 0020: 60 10 80 00 bf 00 bf 00 bf 00 bf 00 bf 7d 4b 10 `............}K.
    16:48:21.857 0030: 88 20 f4 70 70 10 80 83 f8 20 11 00 bf 00 bf 00 . .pp.... ......
    16:48:21.857 0040: bf 00 bf 00 bf 10 88 20 f0 03 00 40 f0 01 00 10 ....... ...@....
    16:48:21.857 0050: 80 00 bf 00 bf 00 bf 00 bf 00 bf 19 70 10 88 20 ............p..
    16:48:21.857 0060: f0 0c 00 10 80 70 47 c0 46 64 81 01 20 80 2c 30 .....pG.Fd.. .,0
    16:48:21.857 0070: 22 00 b5 13 46 ff f7 d0 fb 18 46 02 f0 5b ff 88 "...F.....F..[..
    16:48:21.857 0080: 49 08 78 c0 43 08 70 87 49 08 88 20 f4 80 70 40 I.x.C.p.I.. ..p@
    16:48:21.857 0090: f0 80 00 08 80 00 bd c0 46 50 b0 01 20 00 0f 30 ........FP.. ..0
    16:48:21.857 00a0: 22 70 b5 06 46 80 48 01 25 05 70 03 20 02 f0 42 "p..F.H.%.p. ..B
    16:48:21.857 00b0: ff 00 2e 14 bf 04 20 00 20 1d 4c 00 2e 04 f1 48 ...... . .L....H
    16:48:21.857 00c0: 04 20 73 14 bf ff 20 1f 20 20 70 00 bf 00 bf 00 . s... . p.....
    16:48:21.857 00d0: bf 00 bf 00 bf 00 2e 14 bf 03 20 28 1c e0 70 00 .......... (..p.
    16:48:21.857 00e0: bf 00 bf 00 bf 00 bf 00 bf 00 2e 14 bf 0f 20 03 .............. .
    16:48:21.857 00f0: 20 60 70 00 20 02 f0 1e ff `p. ....
    16:48:21.888 Incoming Dump:
    16:48:21.888 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.888 --
    16:48:21.888 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.888 Parameters:
    16:48:21.888 | Number HCI commands : 0x01
    16:48:21.888 | Command Opcode : 0xff05
    16:48:21.888 | Status : 0x00 (Success)
    16:48:21.888 --
    16:48:21.888 --
    16:48:21.888 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.888 | Address : 0x20000d20
    16:48:21.888 | Size : 0xf0
    16:48:21.888 | Values : "00:2E:14:BF:0F:20:05:20:A0:70:03:20:A0:71:28:46:02:F0:14:FF:00:20:00:2E:A0:71:14:BF:40:F2:01:10:28:1C:A0:80:92:48:05:70:92:48:00:88:02:F0:06:FF:70:BD:C0:46:94:04:36:22:24:B0:01:20:70:B5:0E:46:8D:49:5B:4C:8D:4D:09:88:01:B1:38:B1:76:B9:28:88:20:F0:7C:00:40:F0:02:00:28:80:07:E0:28:88:40:F0:7E:00:00:21:28:80:20:46:34:30:01:70:05:20:02:F0:E5:FE:1C:34:01:20:20:70:02:F0:E0:FE:4F:F0:00:00:20:70:26:B9:28:88:40:F4:40:70:28:80:70:BD:03:20:68:80:70:BD:30:B5:14:46:0D:46:FF:F7:85:FF:21:46:28:46:FF:F7:CB:FF:30:BD:8E:49:00:20:88:80:88:70:00:BF:00:BF:00:BF:00:BF:00:BF:48:70:00:BF:00:BF:00:BF:00:BF:00:BF:C8:70:00:BF:00:BF:00:BF:00:BF:00:BF:08:70:70:47:C0:46:26:B0:01:20:81:48:1C:38:01:88:21:F4:40:71:01:80:01:88:21:F0:7E:01:01:80"
    16:48:21.888 --
    16:48:21.888 Outgoing Dump:
    16:48:21.888 0000: 01 05 ff f5 20 0d 00 20 f0 00 2e 14 bf 0f 20 05 .... .. ...... .
    16:48:21.888 0010: 20 a0 70 03 20 a0 71 28 46 02 f0 14 ff 00 20 00 .p. .q(F..... .
    16:48:21.888 0020: 2e a0 71 14 bf 40 f2 01 10 28 1c a0 80 92 48 05 ..q..@...(....H.
    16:48:21.888 0030: 70 92 48 00 88 02 f0 06 ff 70 bd c0 46 94 04 36 p.H......p..F..6
    16:48:21.888 0040: 22 24 b0 01 20 70 b5 0e 46 8d 49 5b 4c 8d 4d 09 "$.. p..F.I[L.M.
    16:48:21.888 0050: 88 01 b1 38 b1 76 b9 28 88 20 f0 7c 00 40 f0 02 ...8.v.(. .|.@..
    16:48:21.888 0060: 00 28 80 07 e0 28 88 40 f0 7e 00 00 21 28 80 20 .(...(.@.~..!(.
    16:48:21.888 0070: 46 34 30 01 70 05 20 02 f0 e5 fe 1c 34 01 20 20 F40.p. .....4.
    16:48:21.888 0080: 70 02 f0 e0 fe 4f f0 00 00 20 70 26 b9 28 88 40 p....O... p&.(.@
    16:48:21.888 0090: f4 40 70 28 80 70 bd 03 20 68 80 70 bd 30 b5 14 .@p(.p.. h.p.0..
    16:48:21.888 00a0: 46 0d 46 ff f7 85 ff 21 46 28 46 ff f7 cb ff 30 F.F....!F(F....0
    16:48:21.888 00b0: bd 8e 49 00 20 88 80 88 70 00 bf 00 bf 00 bf 00 ..I. ...p.......
    16:48:21.888 00c0: bf 00 bf 48 70 00 bf 00 bf 00 bf 00 bf 00 bf c8 ...Hp...........
    16:48:21.888 00d0: 70 00 bf 00 bf 00 bf 00 bf 00 bf 08 70 70 47 c0 p...........ppG.
    16:48:21.888 00e0: 46 26 b0 01 20 81 48 1c 38 01 88 21 f4 40 71 01 F&.. .H.8..!.@q.
    16:48:21.888 00f0: 80 01 88 21 f0 7e 01 01 80 ...!.~...
    16:48:21.919 Incoming Dump:
    16:48:21.919 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.919 --
    16:48:21.919 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.919 Parameters:
    16:48:21.919 | Number HCI commands : 0x01
    16:48:21.919 | Command Opcode : 0xff05
    16:48:21.919 | Status : 0x00 (Success)
    16:48:21.919 --
    16:48:21.919 --
    16:48:21.935 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.935 Parameters:
    16:48:21.935 | Address : 0x20000e10
    16:48:21.935 | Size : 0xf0
    16:48:21.935 | Values : "61:49:8A:39:B1:F9:00:10:89:08:02:D3:7A:49:09:78:09:B9:00:21:41:80:2A:48:01:21:80:F8:34:10:00:BF:00:BF:00:BF:00:BF:00:BF:00:21:01:70:70:47:00:B5:FF:F7:C2:FF:FF:F7:DA:FF:00:BD:C0:46:90:04:36:22:10:B5:6F:49:82:1E:16:D0:92:1F:0C:D0:52:1E:02:D0:92:1F:17:D1:0F:E0:08:46:90:F8:C3:41:B0:F8:BC:11:90:F8:C2:01:0E:E0:08:46:90:F8:C1:41:B0:F8:BA:11:90:F8:C0:01:06:E0:08:46:90:F8:BF:41:B0:F8:B8:11:90:F8:BE:01:01:F4:F8:63:01:F0:3F:02:01:F4:78:41:42:EA:83:02:59:4B:42:EA:41:12:43:F8:04:2C:19:88:21:F0:1F:01:08:43:18:80:18:88:20:F4:70:60:40:EA:04:20:18:80:10:BD:C0:46:64:0C:34:22:62:A0:01:20:00:0A:36:22:2D:E9:F0:41:4E:4C:94:F8:00:80:4E:4D:20:88:26:46:20:F0:0F:00:40:F0:03:00:20:80:28:88:53:3E:20:F4:E0:60:40:F4:00:70:A6:F8:47:00:02:20"
    16:48:21.935 --
    16:48:21.935 Outgoing Dump:
    16:48:21.935 0000: 01 05 ff f5 10 0e 00 20 f0 61 49 8a 39 b1 f9 00 ....... .aI.9...
    16:48:21.935 0010: 10 89 08 02 d3 7a 49 09 78 09 b9 00 21 41 80 2a .....zI.x...!A.*
    16:48:21.935 0020: 48 01 21 80 f8 34 10 00 bf 00 bf 00 bf 00 bf 00 H.!..4..........
    16:48:21.935 0030: bf 00 21 01 70 70 47 00 b5 ff f7 c2 ff ff f7 da ..!.ppG.........
    16:48:21.935 0040: ff 00 bd c0 46 90 04 36 22 10 b5 6f 49 82 1e 16 ....F..6"..oI...
    16:48:21.935 0050: d0 92 1f 0c d0 52 1e 02 d0 92 1f 17 d1 0f e0 08 .....R..........
    16:48:21.935 0060: 46 90 f8 c3 41 b0 f8 bc 11 90 f8 c2 01 0e e0 08 F...A...........
    16:48:21.935 0070: 46 90 f8 c1 41 b0 f8 ba 11 90 f8 c0 01 06 e0 08 F...A...........
    16:48:21.935 0080: 46 90 f8 bf 41 b0 f8 b8 11 90 f8 be 01 01 f4 f8 F...A...........
    16:48:21.935 0090: 63 01 f0 3f 02 01 f4 78 41 42 ea 83 02 59 4b 42 c..?...xAB...YKB
    16:48:21.935 00a0: ea 41 12 43 f8 04 2c 19 88 21 f0 1f 01 08 43 18 .A.C..,..!....C.
    16:48:21.935 00b0: 80 18 88 20 f4 70 60 40 ea 04 20 18 80 10 bd c0 ... .p`@.. .....
    16:48:21.935 00c0: 46 64 0c 34 22 62 a0 01 20 00 0a 36 22 2d e9 f0 Fd.4"b.. ..6"-..
    16:48:21.935 00d0: 41 4e 4c 94 f8 00 80 4e 4d 20 88 26 46 20 f0 0f ANL....NM .&F ..
    16:48:21.935 00e0: 00 40 f0 03 00 20 80 28 88 53 3e 20 f4 e0 60 40 .@... .(.S> ..`@
    16:48:21.935 00f0: f4 00 70 a6 f8 47 00 02 20 ..p..G..
    16:48:21.966 Incoming Dump:
    16:48:21.966 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.966 --
    16:48:21.966 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.966 Parameters:
    16:48:21.966 | Number HCI commands : 0x01
    16:48:21.966 | Command Opcode : 0xff05
    16:48:21.966 | Status : 0x00 (Success)
    16:48:21.966 --
    16:48:21.966 --
    16:48:21.966 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.966 | Address : 0x20000f00
    16:48:21.966 | Size : 0xf0
    16:48:21.966 | Values : "02:F0:2C:FE:D6:F8:87:70:28:88:20:F4:E0:60:A6:F8:47:00:01:20:02:F0:22:FE:AD:34:00:2F:4F:EA:E7:00:04:D5:40:42:00:12:40:42:47:B2:02:E0:80:30:4F:FA:90:F7:B6:F8:47:00:20:F0:0F:00:A6:F8:47:00:01:20:02:F0:0C:FE:35:48:01:25:05:70:28:46:02:F0:06:FE:96:F8:6F:00:40:00:36:F9:01:1C:40:B2:40:10:A1:EB:00:21:01:EB:07:21:28:46:26:F8:01:1C:02:F0:F6:FD:2B:49:86:F8:53:80:00:20:08:70:B4:F8:FF:0F:20:F0:70:00:A4:F8:FF:0F:27:48:05:70:BD:E8:F0:81:C0:46:E0:20:3E:22:0C:05:01:20:5E:03:01:20:50:B0:01:20:70:B5:21:49:08:88:40:F0:70:00:08:80:1C:48:01:25:05:70:28:46:02:F0:D2:FD:16:4B:1C:48:1C:4C:53:3B:C1:8A:00:7E:23:F8:01:1C:00:26:84:F8:50:0E:07:21:F0:B2:FF:F7:35:FA:76:1C:04:2E:F8:DB:B3:F8:47:00:20:F0:0F:00:40:F0:01:00:A3:F8:47:00:25:70:0D:4D"
    16:48:21.966 --
    16:48:21.966 Outgoing Dump:
    16:48:21.966 0000: 01 05 ff f5 00 0f 00 20 f0 02 f0 2c fe d6 f8 87 ....... ...,....
    16:48:21.966 0010: 70 28 88 20 f4 e0 60 a6 f8 47 00 01 20 02 f0 22 p(. ..`..G.. .."
    16:48:21.966 0020: fe ad 34 00 2f 4f ea e7 00 04 d5 40 42 00 12 40 ..4./O.....@B..@
    16:48:21.966 0030: 42 47 b2 02 e0 80 30 4f fa 90 f7 b6 f8 47 00 20 BG....0O.....G.
    16:48:21.966 0040: f0 0f 00 a6 f8 47 00 01 20 02 f0 0c fe 35 48 01 .....G.. ....5H.
    16:48:21.966 0050: 25 05 70 28 46 02 f0 06 fe 96 f8 6f 00 40 00 36 %.p(F......o.@.6
    16:48:21.966 0060: f9 01 1c 40 b2 40 10 a1 eb 00 21 01 eb 07 21 28 ...@.@....!...!(
    16:48:21.966 0070: 46 26 f8 01 1c 02 f0 f6 fd 2b 49 86 f8 53 80 00 F&.......+I..S..
    16:48:21.966 0080: 20 08 70 b4 f8 ff 0f 20 f0 70 00 a4 f8 ff 0f 27 .p.... .p.....'
    16:48:21.966 0090: 48 05 70 bd e8 f0 81 c0 46 e0 20 3e 22 0c 05 01 H.p.....F. >"...
    16:48:21.966 00a0: 20 5e 03 01 20 50 b0 01 20 70 b5 21 49 08 88 40 ^.. P.. p.!I..@
    16:48:21.966 00b0: f0 70 00 08 80 1c 48 01 25 05 70 28 46 02 f0 d2 .p....H.%.p(F...
    16:48:21.966 00c0: fd 16 4b 1c 48 1c 4c 53 3b c1 8a 00 7e 23 f8 01 ..K.H.LS;...~#..
    16:48:21.966 00d0: 1c 00 26 84 f8 50 0e 07 21 f0 b2 ff f7 35 fa 76 ..&..P..!....5.v
    16:48:21.966 00e0: 1c 04 2e f8 db b3 f8 47 00 20 f0 0f 00 40 f0 01 .......G. ...@..
    16:48:21.966 00f0: 00 a3 f8 47 00 25 70 0d 4d ...G.%p.M
    16:48:21.998 Incoming Dump:
    16:48:21.998 0000: 04 0e 04 01 05 ff 00 .......
    16:48:21.998 --
    16:48:21.998 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:21.998 Parameters:
    16:48:21.998 | Number HCI commands : 0x01
    16:48:21.998 | Command Opcode : 0xff05
    16:48:21.998 | Status : 0x00 (Success)
    16:48:21.998 --
    16:48:21.998 --
    16:48:21.998 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:21.998 | Address : 0x20000ff0
    16:48:21.998 | Size : 0xf0
    16:48:21.998 | Values : "0C:3D:B5:F8:B2:02:02:F0:B1:FD:00:20:20:70:28:73:70:BD:C0:46:6C:B0:01:20:D1:08:01:20:94:80:01:20:50:02:01:20:6C:A0:01:20:60:A0:01:20:C0:1A:34:22:6C:20:3E:22:5C:02:01:20:18:B1:01:20:80:08:01:20:70:0C:34:22:2D:E9:F0:4F:AD:F1:50:0D:01:90:98:48:01:78:98:48:02:90:31:B1:49:1E:01:22:02:98:8A:40:01:88:0A:43:02:80:94:48:00:68:C0:0F:05:D3:93:48:01:99:02:78:49:20:02:F0:9D:FD:93:4C:4F:F0:00:08:8F:48:90:4A:21:7C:80:F8:F0:8F:90:4D:11:70:E1:8A:8F:4A:85:F8:20:80:01:F0:1F:01:80:F8:F3:1F:21:8B:85:F8:21:80:01:F0:1F:01:80:F8:FB:1F:7F:21:03:92:82:F8:70:10:82:F8:74:80:86:49:82:F8:72:80:0B:78:85:F8:48:80:42:46:51:2B:08:BF:01:22:04:92:42:46:05:92:4F:F0:01:03:06:92:7F:49:07:93:08:92:09:91:04:99:41:B1:A1:8F:89:08:03:D2:04:99:01:29:02:D1"
    16:48:21.998 --
    16:48:21.998 Outgoing Dump:
    16:48:21.998 0000: 01 05 ff f5 f0 0f 00 20 f0 0c 3d b5 f8 b2 02 02 ....... ..=.....
    16:48:21.998 0010: f0 b1 fd 00 20 20 70 28 73 70 bd c0 46 6c b0 01 .... p(sp..Fl..
    16:48:21.998 0020: 20 d1 08 01 20 94 80 01 20 50 02 01 20 6c a0 01 ... ... P.. l..
    16:48:21.998 0030: 20 60 a0 01 20 c0 1a 34 22 6c 20 3e 22 5c 02 01 `.. ..4"l >"\..
    16:48:21.998 0040: 20 18 b1 01 20 80 08 01 20 70 0c 34 22 2d e9 f0 ... ... p.4"-..
    16:48:21.998 0050: 4f ad f1 50 0d 01 90 98 48 01 78 98 48 02 90 31 O..P....H.x.H..1
    16:48:21.998 0060: b1 49 1e 01 22 02 98 8a 40 01 88 0a 43 02 80 94 .I.."...@...C...
    16:48:21.998 0070: 48 00 68 c0 0f 05 d3 93 48 01 99 02 78 49 20 02 H.h.....H...xI .
    16:48:21.998 0080: f0 9d fd 93 4c 4f f0 00 08 8f 48 90 4a 21 7c 80 ....LO....H.J!|.
    16:48:21.998 0090: f8 f0 8f 90 4d 11 70 e1 8a 8f 4a 85 f8 20 80 01 ....M.p...J.. ..
    16:48:21.998 00a0: f0 1f 01 80 f8 f3 1f 21 8b 85 f8 21 80 01 f0 1f .......!...!....
    16:48:21.998 00b0: 01 80 f8 fb 1f 7f 21 03 92 82 f8 70 10 82 f8 74 ......!....p...t
    16:48:21.998 00c0: 80 86 49 82 f8 72 80 0b 78 85 f8 48 80 42 46 51 ..I..r..x..H.BFQ
    16:48:21.998 00d0: 2b 08 bf 01 22 04 92 42 46 05 92 4f f0 01 03 06 +..."..BF..O....
    16:48:21.998 00e0: 92 7f 49 07 93 08 92 09 91 04 99 41 b1 a1 8f 89 ..I........A....
    16:48:21.998 00f0: 08 03 d2 04 99 01 29 02 d1 ......)..
    16:48:22.029 Incoming Dump:
    16:48:22.029 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.029 --
    16:48:22.029 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.029 Parameters:
    16:48:22.029 | Number HCI commands : 0x01
    16:48:22.029 | Command Opcode : 0xff05
    16:48:22.029 | Status : 0x00 (Success)
    16:48:22.029 --
    16:48:22.029 --
    16:48:22.029 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.029 | Address : 0x200010e0
    16:48:22.029 | Size : 0xf0
    16:48:22.029 | Values : "12:E0:05:99:04:91:95:F8:24:10:01:29:0C:D0:95:F8:23:10:01:29:08:D0:A1:8F:89:08:05:D2:94:F8:10:11:01:29:18:BF:07:99:00:D1:05:99:0A:91:AC:49:AD:4A:09:78:30:F8:01:0C:29:76:91:46:E8:82:11:8C:DD:F8:1C:B0:D0:8B:85:F8:19:B0:05:9B:01:9A:0B:93:FA:B1:A9:F8:22:80:01:F0:03:01:0C:91:41:13:41:F0:08:01:0D:91:09:99:B1:F8:9C:10:49:0A:09:D2:0D:99:C9:08:08:D3:07:99:0B:91:0D:99:0F:29:03:D0:02:21:00:E0:0A:21:0D:91:C0:F3:42:02:4F:F4:80:51:0E:92:11:E0:A9:F8:06:80:B9:F8:04:10:B9:F8:02:00:01:F0:03:01:C0:F3:44:02:0C:91:03:9B:0E:92:10:21:92:10:9A:80:02:22:0D:92:9C:4A:0F:92:A2:F8:63:10:A4:F8:62:10:04:99:01:29:1A:D0:95:F8:24:10:01:29:16:D0:95:F8:23:10:01:29:12:D0:94:F8:10:11:01:29:0E:D0:09:99:B1:F8:4A:20:B4:F9:84:10:11:40:11:F0:01:01:85:F8"
    16:48:22.029 --
    16:48:22.029 Outgoing Dump:
    16:48:22.029 0000: 01 05 ff f5 e0 10 00 20 f0 12 e0 05 99 04 91 95 ....... ........
    16:48:22.029 0010: f8 24 10 01 29 0c d0 95 f8 23 10 01 29 08 d0 a1 .$..)....#..)...
    16:48:22.029 0020: 8f 89 08 05 d2 94 f8 10 11 01 29 18 bf 07 99 00 ..........).....
    16:48:22.029 0030: d1 05 99 0a 91 ac 49 ad 4a 09 78 30 f8 01 0c 29 ......I.J.x0...)
    16:48:22.029 0040: 76 91 46 e8 82 11 8c dd f8 1c b0 d0 8b 85 f8 19 v.F.............
    16:48:22.029 0050: b0 05 9b 01 9a 0b 93 fa b1 a9 f8 22 80 01 f0 03 ..........."....
    16:48:22.029 0060: 01 0c 91 41 13 41 f0 08 01 0d 91 09 99 b1 f8 9c ...A.A..........
    16:48:22.029 0070: 10 49 0a 09 d2 0d 99 c9 08 08 d3 07 99 0b 91 0d .I..............
    16:48:22.029 0080: 99 0f 29 03 d0 02 21 00 e0 0a 21 0d 91 c0 f3 42 ..)...!...!....B
    16:48:22.029 0090: 02 4f f4 80 51 0e 92 11 e0 a9 f8 06 80 b9 f8 04 .O..Q...........
    16:48:22.029 00a0: 10 b9 f8 02 00 01 f0 03 01 c0 f3 44 02 0c 91 03 ...........D....
    16:48:22.029 00b0: 9b 0e 92 10 21 92 10 9a 80 02 22 0d 92 9c 4a 0f ....!....."...J.
    16:48:22.029 00c0: 92 a2 f8 63 10 a4 f8 62 10 04 99 01 29 1a d0 95 ...c...b....)...
    16:48:22.029 00d0: f8 24 10 01 29 16 d0 95 f8 23 10 01 29 12 d0 94 .$..)....#..)...
    16:48:22.029 00e0: f8 10 11 01 29 0e d0 09 99 b1 f8 4a 20 b4 f9 84 ....)......J ...
    16:48:22.029 00f0: 10 11 40 11 f0 01 01 85 f8 ..@......
    16:48:22.060 Incoming Dump:
    16:48:22.060 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.060 --
    16:48:22.060 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.060 Parameters:
    16:48:22.060 | Number HCI commands : 0x01
    16:48:22.060 | Command Opcode : 0xff05
    16:48:22.060 | Status : 0x00 (Success)
    16:48:22.060 --
    16:48:22.060 --
    16:48:22.060 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.060 | Address : 0x200011d0
    16:48:22.060 | Size : 0xf0
    16:48:22.060 | Values : "51:10:0C:BF:59:46:02:21:85:F8:52:10:C0:F3:86:16:30:46:02:F0:5B:FE:02:46:88:49:10:90:51:43:11:91:10:9A:40:F6:7C:11:91:42:C8:BF:07:99:06:DC:10:9A:01:F1:1A:01:91:42:B4:BF:02:21:05:99:B4:F8:68:20:52:08:0F:D3:CA:00:02:EB:41:12:7F:4B:7D:4F:7C:49:89:18:0A:22:51:F8:04:CB:17:F8:01:EB:52:1E:43:F8:3E:C0:F7:D1:B4:F8:BE:10:01:F0:03:02:03:2A:09:D0:B4:F8:60:10:CA:08:0B:D2:09:99:B1:F8:4C:10:C1:F3:C1:11:07:E0:49:0A:27:BF:C1:49:09:78:C1:49:89:5D:01:F0:03:01:DF:F8:00:A3:4F:F0:F0:0C:4F:F0:30:03:12:91:59:B3:49:1E:0B:D0:49:1E:2C:D1:50:46:01:88:4F:F0:D2:0C:2A:23:21:F0:80:01:41:F0:40:01:21:E0:50:46:01:88:21:F0:40:01:41:F0:80:01:1A:E0:C0:46:F0:00:01:20:04:F0:0E:20:B0:01:01:20:A2:08:01:20:19:A0:01:20:18:B0:01:20:50:02:01:20:80:08:01:20"
    16:48:22.060 --
    16:48:22.060 Outgoing Dump:
    16:48:22.060 0000: 01 05 ff f5 d0 11 00 20 f0 51 10 0c bf 59 46 02 ....... .Q...YF.
    16:48:22.060 0010: 21 85 f8 52 10 c0 f3 86 16 30 46 02 f0 5b fe 02 !..R.....0F..[..
    16:48:22.060 0020: 46 88 49 10 90 51 43 11 91 10 9a 40 f6 7c 11 91 F.I..QC....@.|..
    16:48:22.060 0030: 42 c8 bf 07 99 06 dc 10 9a 01 f1 1a 01 91 42 b4 B.............B.
    16:48:22.060 0040: bf 02 21 05 99 b4 f8 68 20 52 08 0f d3 ca 00 02 ..!....h R......
    16:48:22.060 0050: eb 41 12 7f 4b 7d 4f 7c 49 89 18 0a 22 51 f8 04 .A..K}O|I..."Q..
    16:48:22.060 0060: cb 17 f8 01 eb 52 1e 43 f8 3e c0 f7 d1 b4 f8 be .....R.C.>......
    16:48:22.060 0070: 10 01 f0 03 02 03 2a 09 d0 b4 f8 60 10 ca 08 0b ......*....`....
    16:48:22.060 0080: d2 09 99 b1 f8 4c 10 c1 f3 c1 11 07 e0 49 0a 27 .....L.......I.'
    16:48:22.060 0090: bf c1 49 09 78 c1 49 89 5d 01 f0 03 01 df f8 00 ..I.x.I.].......
    16:48:22.060 00a0: a3 4f f0 f0 0c 4f f0 30 03 12 91 59 b3 49 1e 0b .O...O.0...Y.I..
    16:48:22.060 00b0: d0 49 1e 2c d1 50 46 01 88 4f f0 d2 0c 2a 23 21 .I.,.PF..O...*#!
    16:48:22.060 00c0: f0 80 01 41 f0 40 01 21 e0 50 46 01 88 21 f0 40 ...A.@.!.PF..!.@
    16:48:22.060 00d0: 01 41 f0 80 01 1a e0 c0 46 f0 00 01 20 04 f0 0e .A......F... ...
    16:48:22.060 00e0: 20 b0 01 01 20 a2 08 01 20 19 a0 01 20 18 b0 01 ... ... ... ...
    16:48:22.060 00f0: 20 50 02 01 20 80 08 01 20 P.. ...
    16:48:22.091 Incoming Dump:
    16:48:22.091 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.091 --
    16:48:22.091 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.091 Parameters:
    16:48:22.091 | Number HCI commands : 0x01
    16:48:22.091 | Command Opcode : 0xff05
    16:48:22.091 | Status : 0x00 (Success)
    16:48:22.091 --
    16:48:22.091 --
    16:48:22.091 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.091 | Address : 0x200012c0
    16:48:22.091 | Size : 0xf0
    16:48:22.091 | Values : "50:00:01:20:E1:08:01:20:00:01:01:20:50:46:01:88:21:F0:C0:01:01:80:12:99:C3:4E:B4:F9:06:20:08:46:41:EA:00:11:06:F8:D6:1C:10:98:4F:F4:7A:27:4F:F4:7A:7E:47:43:0E:FB:00:F1:A7:EB:82:27:07:F5:FA:77:B7:FB:FE:F0:19:27:07:EB:80:27:32:20:B7:FB:F0:F0:00:EB:63:00:B0:FB:F3:F3:6F:F3:1F:53:CA:F8:04:30:B4:F9:08:30:89:1A:D2:18:26:F8:A2:2C:4A:08:02:EB:0C:62:B2:FB:F1:F0:80:B2:C0:00:26:F8:A0:0C:70:46:48:43:FF:F7:6D:F8:00:F5:00:07:11:9B:29:68:3A:0E:01:FB:12:32:00:2A:B8:BF:52:42:B5:4B:93:42:1C:DD:B4:F8:EE:20:01:F5:80:71:02:F0:01:02:4F:F4:00:73:08:92:49:0A:07:F0:7F:42:12:1A:10:32:52:11:01:FB:02:31:89:12:40:F2:5B:33:4F:F4:00:42:03:FB:01:21:09:14:26:F8:8A:1C:07:99:06:91:0D:9A:A6:4B:A5:49:92:1E:13:93:10:D0:92:1F:00:F0:48:81:52:1E:00:F0"
    16:48:22.091 --
    16:48:22.091 Outgoing Dump:
    16:48:22.091 0000: 01 05 ff f5 c0 12 00 20 f0 50 00 01 20 e1 08 01 ....... .P.. ...
    16:48:22.091 0010: 20 00 01 01 20 50 46 01 88 21 f0 c0 01 01 80 12 ... PF..!......
    16:48:22.091 0020: 99 c3 4e b4 f9 06 20 08 46 41 ea 00 11 06 f8 d6 ..N... .FA......
    16:48:22.091 0030: 1c 10 98 4f f4 7a 27 4f f4 7a 7e 47 43 0e fb 00 ...O.z'O.z~GC...
    16:48:22.091 0040: f1 a7 eb 82 27 07 f5 fa 77 b7 fb fe f0 19 27 07 ....'...w.....'.
    16:48:22.091 0050: eb 80 27 32 20 b7 fb f0 f0 00 eb 63 00 b0 fb f3 ..'2 ......c....
    16:48:22.091 0060: f3 6f f3 1f 53 ca f8 04 30 b4 f9 08 30 89 1a d2 .o..S...0...0...
    16:48:22.091 0070: 18 26 f8 a2 2c 4a 08 02 eb 0c 62 b2 fb f1 f0 80 .&..,J....b.....
    16:48:22.091 0080: b2 c0 00 26 f8 a0 0c 70 46 48 43 ff f7 6d f8 00 ...&...pFHC..m..
    16:48:22.091 0090: f5 00 07 11 9b 29 68 3a 0e 01 fb 12 32 00 2a b8 .....)h:....2.*.
    16:48:22.091 00a0: bf 52 42 b5 4b 93 42 1c dd b4 f8 ee 20 01 f5 80 .RB.K.B..... ...
    16:48:22.091 00b0: 71 02 f0 01 02 4f f4 00 73 08 92 49 0a 07 f0 7f q....O..s..I....
    16:48:22.091 00c0: 42 12 1a 10 32 52 11 01 fb 02 31 89 12 40 f2 5b B...2R....1..@.[
    16:48:22.091 00d0: 33 4f f4 00 42 03 fb 01 21 09 14 26 f8 8a 1c 07 3O..B...!..&....
    16:48:22.091 00e0: 99 06 91 0d 9a a6 4b a5 49 92 1e 13 93 10 d0 92 ......K.I.......
    16:48:22.091 00f0: 1f 00 f0 48 81 52 1e 00 f0 ...H.R...
    16:48:22.123 Incoming Dump:
    16:48:22.123 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.123 --
    16:48:22.123 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.123 Parameters:
    16:48:22.123 | Number HCI commands : 0x01
    16:48:22.123 | Command Opcode : 0xff05
    16:48:22.123 | Status : 0x00 (Success)
    16:48:22.123 --
    16:48:22.123 --
    16:48:22.123 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.123 | Address : 0x200013b0
    16:48:22.123 | Size : 0xf0
    16:48:22.123 | Values : "1D:81:52:1E:00:F0:F4:80:52:1F:00:F0:D7:80:B1:E1:C0:1A:34:22:00:00:01:20:0F:98:A0:F8:53:80:0F:9A:02:20:A2:F8:4F:00:0E:98:02:28:1F:DC:0B:98:78:B9:0E:9A:09:98:00:EB:C2:00:C2:68:00:69:46:F8:22:2C:46:F8:1E:0C:30:88:20:F0:07:00:40:F0:01:00:2B:E0:09:98:02:6C:C0:6B:F1:E7:09:40:01:20:40:42:0F:00:E0:5B:00:00:58:5C:00:00:3C:B1:01:20:09:98:40:6A:46:F8:22:0C:09:98:80:6A:46:F8:1E:0C:09:98:C0:6A:46:F8:1A:0C:09:98:00:6B:46:F8:16:0C:09:98:40:6B:46:F8:12:0C:09:98:80:6B:46:F8:0E:0C:0E:9A:30:88:20:F0:07:00:40:EA:A2:00:30:80:3F:20:26:F8:0A:0C:30:88:20:F4:7F:60:40:F4:A0:50:30:80:B4:F8:40:02:00:F0:0F:00:B0:80:B4:F8:42:02:00:F0:7F:00:70:80:94:F8:44:02:F0:75:B4:F8:46:02:32:89:6F:F3:08:02:10:43:30:81:B4:F8:48:02:F0:80:B4:F8:4A:02:70:82"
    16:48:22.123 --
    16:48:22.123 Outgoing Dump:
    16:48:22.123 0000: 01 05 ff f5 b0 13 00 20 f0 1d 81 52 1e 00 f0 f4 ....... ...R....
    16:48:22.123 0010: 80 52 1f 00 f0 d7 80 b1 e1 c0 1a 34 22 00 00 01 .R.........4"...
    16:48:22.123 0020: 20 0f 98 a0 f8 53 80 0f 9a 02 20 a2 f8 4f 00 0e ....S.... ..O..
    16:48:22.123 0030: 98 02 28 1f dc 0b 98 78 b9 0e 9a 09 98 00 eb c2 ..(....x........
    16:48:22.123 0040: 00 c2 68 00 69 46 f8 22 2c 46 f8 1e 0c 30 88 20 ..h.iF.",F...0.
    16:48:22.123 0050: f0 07 00 40 f0 01 00 2b e0 09 98 02 6c c0 6b f1 ...@...+....l.k.
    16:48:22.123 0060: e7 09 40 01 20 40 42 0f 00 e0 5b 00 00 58 5c 00 ..@. @B...[..X\.
    16:48:22.123 0070: 00 3c b1 01 20 09 98 40 6a 46 f8 22 0c 09 98 80 .<.. ..@jF."....
    16:48:22.123 0080: 6a 46 f8 1e 0c 09 98 c0 6a 46 f8 1a 0c 09 98 00 jF......jF......
    16:48:22.123 0090: 6b 46 f8 16 0c 09 98 40 6b 46 f8 12 0c 09 98 80 kF.....@kF......
    16:48:22.123 00a0: 6b 46 f8 0e 0c 0e 9a 30 88 20 f0 07 00 40 ea a2 kF.....0. ...@..
    16:48:22.123 00b0: 00 30 80 3f 20 26 f8 0a 0c 30 88 20 f4 7f 60 40 .0.? &...0. ..`@
    16:48:22.123 00c0: f4 a0 50 30 80 b4 f8 40 02 00 f0 0f 00 b0 80 b4 ..P0...@........
    16:48:22.123 00d0: f8 42 02 00 f0 7f 00 70 80 94 f8 44 02 f0 75 b4 .B.....p...D..u.
    16:48:22.123 00e0: f8 46 02 32 89 6f f3 08 02 10 43 30 81 b4 f8 48 .F.2.o....C0...H
    16:48:22.123 00f0: 02 f0 80 b4 f8 4a 02 70 82 .....J.p.
    16:48:22.154 Incoming Dump:
    16:48:22.154 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.154 --
    16:48:22.154 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.154 Parameters:
    16:48:22.154 | Number HCI commands : 0x01
    16:48:22.154 | Command Opcode : 0xff05
    16:48:22.154 | Status : 0x00 (Success)
    16:48:22.154 --
    16:48:22.154 --
    16:48:22.154 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.154 | Address : 0x200014a0
    16:48:22.154 | Size : 0xf0
    16:48:22.154 | Values : "B4:F8:4C:02:70:83:B4:F8:4E:02:B4:F8:64:22:B0:83:B4:F8:50:02:00:F0:07:00:86:F8:20:00:94:F8:52:02:B4:F8:AE:91:F0:77:B4:F8:54:02:6F:F3:5F:20:B0:85:B4:F8:56:02:6F:F3:5F:20:30:86:B4:F8:58:02:6F:F3:5F:20:F0:85:B4:F8:5A:02:6F:F3:5F:20:70:85:B4:F8:5C:02:6F:F3:9F:20:26:F8:70:0C:B4:F8:5E:02:6F:F3:9F:20:26:F8:6E:0C:B4:F8:60:02:6F:F3:5F:20:26:F8:64:0C:B4:F8:62:02:6F:F3:5F:20:26:F8:58:0C:36:F8:46:0C:62:F3:09:00:26:F8:46:0C:B4:F8:90:02:00:F0:01:00:08:70:B4:F8:96:12:36:F8:62:0C:61:F3:0B:20:26:F8:62:0C:94:F8:66:02:06:F8:88:0C:B4:F8:C4:02:00:F0:0F:00:86:F8:C0:00:3C:20:86:F8:A4:00:E1:E0:4F:06:01:20:00:06:01:20:00:F1:01:20:30:88:6F:F3:0C:10:40:F4:20:60:30:80:09:98:C0:6B:B4:F8:B6:91:46:F8:1E:0C:1F:20:26:F8:0A:0C:FF:F7:6F:FA:B4:F8"
    16:48:22.154 --
    16:48:22.154 Outgoing Dump:
    16:48:22.154 0000: 01 05 ff f5 a0 14 00 20 f0 b4 f8 4c 02 70 83 b4 ....... ...L.p..
    16:48:22.154 0010: f8 4e 02 b4 f8 64 22 b0 83 b4 f8 50 02 00 f0 07 .N...d"....P....
    16:48:22.154 0020: 00 86 f8 20 00 94 f8 52 02 b4 f8 ae 91 f0 77 b4 ... ...R......w.
    16:48:22.154 0030: f8 54 02 6f f3 5f 20 b0 85 b4 f8 56 02 6f f3 5f .T.o._ ....V.o._
    16:48:22.154 0040: 20 30 86 b4 f8 58 02 6f f3 5f 20 f0 85 b4 f8 5a 0...X.o._ ....Z
    16:48:22.154 0050: 02 6f f3 5f 20 70 85 b4 f8 5c 02 6f f3 9f 20 26 .o._ p...\.o.. &
    16:48:22.154 0060: f8 70 0c b4 f8 5e 02 6f f3 9f 20 26 f8 6e 0c b4 .p...^.o.. &.n..
    16:48:22.154 0070: f8 60 02 6f f3 5f 20 26 f8 64 0c b4 f8 62 02 6f .`.o._ &.d...b.o
    16:48:22.154 0080: f3 5f 20 26 f8 58 0c 36 f8 46 0c 62 f3 09 00 26 ._ &.X.6.F.b...&
    16:48:22.154 0090: f8 46 0c b4 f8 90 02 00 f0 01 00 08 70 b4 f8 96 .F..........p...
    16:48:22.154 00a0: 12 36 f8 62 0c 61 f3 0b 20 26 f8 62 0c 94 f8 66 .6.b.a.. &.b...f
    16:48:22.154 00b0: 02 06 f8 88 0c b4 f8 c4 02 00 f0 0f 00 86 f8 c0 ................
    16:48:22.154 00c0: 00 3c 20 86 f8 a4 00 e1 e0 4f 06 01 20 00 06 01 .< ......O.. ...
    16:48:22.154 00d0: 20 00 f1 01 20 30 88 6f f3 0c 10 40 f4 20 60 30 ... 0.o...@. `0
    16:48:22.154 00e0: 80 09 98 c0 6b b4 f8 b6 91 46 f8 1e 0c 1f 20 26 ....k....F.... &
    16:48:22.154 00f0: f8 0a 0c ff f7 6f fa b4 f8 .....o...
    16:48:22.185 Incoming Dump:
    16:48:22.185 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.185 --
    16:48:22.185 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.185 Parameters:
    16:48:22.185 | Number HCI commands : 0x01
    16:48:22.185 | Command Opcode : 0xff05
    16:48:22.185 | Status : 0x00 (Success)
    16:48:22.185 --
    16:48:22.185 --
    16:48:22.185 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.185 | Address : 0x20001590
    16:48:22.185 | Size : 0xf0
    16:48:22.185 | Values : "C4:02:94:F8:C6:11:C0:F3:03:22:94:F8:C8:01:3F:E0:30:88:20:F4:7F:60:40:F4:A0:50:30:80:D9:F8:28:00:46:F8:22:0C:D9:F8:2C:00:B4:F8:B4:91:46:F8:1E:0C:3F:20:26:F8:0A:0C:FF:F7:51:FA:B4:F8:C4:02:C0:F3:03:20:86:F8:C0:00:B4:F8:C4:01:13:99:00:F0:01:00:08:70:07:98:0E:90:95:E0:DE:80:01:20:30:88:6F:F3:0C:10:40:F4:A0:60:30:80:09:98:B0:F8:48:00:B4:F8:B2:91:26:F8:1C:0C:0F:20:26:F8:0A:0C:FF:F7:2E:FA:B4:F8:C4:02:94:F8:C7:11:C0:F3:03:12:94:F8:C9:01:86:F8:C0:20:A6:F8:D4:11:07:99:0E:91:78:E0:C0:46:28:E7:09:00:00:0F:30:22:00:17:30:22:30:88:6F:F3:0C:10:40:F4:20:60:30:80:09:98:C0:6B:46:F8:1E:0C:09:98:00:6C:46:F8:16:0C:09:98:40:6C:46:F8:0E:0C:1F:20:26:F8:0A:0C:B4:F8:68:02:00:F0:0F:00:B0:80:B4:F8:6A:02:00:F0:7F:00:70:80:94:F8:6C:02:B4:F8"
    16:48:22.185 --
    16:48:22.185 Outgoing Dump:
    16:48:22.185 0000: 01 05 ff f5 90 15 00 20 f0 c4 02 94 f8 c6 11 c0 ....... ........
    16:48:22.185 0010: f3 03 22 94 f8 c8 01 3f e0 30 88 20 f4 7f 60 40 .."....?.0. ..`@
    16:48:22.185 0020: f4 a0 50 30 80 d9 f8 28 00 46 f8 22 0c d9 f8 2c ..P0...(.F."...,
    16:48:22.185 0030: 00 b4 f8 b4 91 46 f8 1e 0c 3f 20 26 f8 0a 0c ff .....F...? &....
    16:48:22.185 0040: f7 51 fa b4 f8 c4 02 c0 f3 03 20 86 f8 c0 00 b4 .Q........ .....
    16:48:22.185 0050: f8 c4 01 13 99 00 f0 01 00 08 70 07 98 0e 90 95 ..........p.....
    16:48:22.185 0060: e0 de 80 01 20 30 88 6f f3 0c 10 40 f4 a0 60 30 .... 0.o...@..`0
    16:48:22.185 0070: 80 09 98 b0 f8 48 00 b4 f8 b2 91 26 f8 1c 0c 0f .....H.....&....
    16:48:22.185 0080: 20 26 f8 0a 0c ff f7 2e fa b4 f8 c4 02 94 f8 c7 &..............
    16:48:22.185 0090: 11 c0 f3 03 12 94 f8 c9 01 86 f8 c0 20 a6 f8 d4 ............ ...
    16:48:22.185 00a0: 11 07 99 0e 91 78 e0 c0 46 28 e7 09 00 00 0f 30 .....x..F(.....0
    16:48:22.185 00b0: 22 00 17 30 22 30 88 6f f3 0c 10 40 f4 20 60 30 "..0"0.o...@. `0
    16:48:22.185 00c0: 80 09 98 c0 6b 46 f8 1e 0c 09 98 00 6c 46 f8 16 ....kF......lF..
    16:48:22.185 00d0: 0c 09 98 40 6c 46 f8 0e 0c 1f 20 26 f8 0a 0c b4 ...@lF.... &....
    16:48:22.185 00e0: f8 68 02 00 f0 0f 00 b0 80 b4 f8 6a 02 00 f0 7f .h.........j....
    16:48:22.185 00f0: 00 70 80 94 f8 6c 02 b4 f8 .p...l...
    16:48:22.216 Incoming Dump:
    16:48:22.216 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.216 --
    16:48:22.216 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.216 Parameters:
    16:48:22.216 | Number HCI commands : 0x01
    16:48:22.216 | Command Opcode : 0xff05
    16:48:22.216 | Status : 0x00 (Success)
    16:48:22.216 --
    16:48:22.216 --
    16:48:22.216 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.216 | Address : 0x20001680
    16:48:22.216 | Size : 0xf0
    16:48:22.216 | Values : "7A:22:F0:75:B4:F8:6E:02:6F:F3:5F:20:B0:85:B4:F8:70:02:6F:F3:5F:20:30:86:B4:F8:72:02:6F:F3:5F:20:F0:85:B4:F8:74:02:6F:F3:5F:20:70:85:B4:F8:76:02:6F:F3:9F:20:26:F8:70:0C:B4:F8:78:02:6F:F3:9F:20:26:F8:6E:0C:36:F8:46:0C:62:F3:09:00:B4:F8:98:22:26:F8:46:0C:B4:F8:92:02:00:F0:01:00:08:70:36:F8:62:0C:62:F3:0B:20:26:F8:62:0C:B4:F8:B0:91:81:F8:30:B4:36:F8:76:0C:20:F4:00:70:40:F4:80:70:26:F8:76:0C:B4:F8:C4:02:C0:F3:03:20:86:F8:C0:00:2D:20:86:F8:A4:00:94:F8:C6:01:A6:F8:D4:01:94:F8:C8:01:A6:F8:D2:01:96:48:11:90:01:98:00:28:35:D0:0F:99:31:20:A1:F8:53:00:31:88:0E:98:21:F0:07:01:08:43:30:80:B4:F8:9C:02:31:89:6F:F3:08:01:08:43:30:81:B4:F8:9E:02:F0:80:B4:F8:A0:02:70:82:B4:F8:A2:02:70:83:B4:F8:A4:02:B0:83:B4:F8:A6:02:00:F0:07:00"
    16:48:22.216 --
    16:48:22.216 Outgoing Dump:
    16:48:22.216 0000: 01 05 ff f5 80 16 00 20 f0 7a 22 f0 75 b4 f8 6e ....... .z".u..n
    16:48:22.216 0010: 02 6f f3 5f 20 b0 85 b4 f8 70 02 6f f3 5f 20 30 .o._ ....p.o._ 0
    16:48:22.216 0020: 86 b4 f8 72 02 6f f3 5f 20 f0 85 b4 f8 74 02 6f ...r.o._ ....t.o
    16:48:22.216 0030: f3 5f 20 70 85 b4 f8 76 02 6f f3 9f 20 26 f8 70 ._ p...v.o.. &.p
    16:48:22.216 0040: 0c b4 f8 78 02 6f f3 9f 20 26 f8 6e 0c 36 f8 46 ...x.o.. &.n.6.F
    16:48:22.216 0050: 0c 62 f3 09 00 b4 f8 98 22 26 f8 46 0c b4 f8 92 .b......"&.F....
    16:48:22.216 0060: 02 00 f0 01 00 08 70 36 f8 62 0c 62 f3 0b 20 26 ......p6.b.b.. &
    16:48:22.216 0070: f8 62 0c b4 f8 b0 91 81 f8 30 b4 36 f8 76 0c 20 .b.......0.6.v.
    16:48:22.216 0080: f4 00 70 40 f4 80 70 26 f8 76 0c b4 f8 c4 02 c0 ..p@..p&.v......
    16:48:22.216 0090: f3 03 20 86 f8 c0 00 2d 20 86 f8 a4 00 94 f8 c6 .. ....- .......
    16:48:22.216 00a0: 01 a6 f8 d4 01 94 f8 c8 01 a6 f8 d2 01 96 48 11 ..............H.
    16:48:22.216 00b0: 90 01 98 00 28 35 d0 0f 99 31 20 a1 f8 53 00 31 ....(5...1 ..S.1
    16:48:22.216 00c0: 88 0e 98 21 f0 07 01 08 43 30 80 b4 f8 9c 02 31 ...!....C0.....1
    16:48:22.216 00d0: 89 6f f3 08 01 08 43 30 81 b4 f8 9e 02 f0 80 b4 .o....C0........
    16:48:22.216 00e0: f8 a0 02 70 82 b4 f8 a2 02 70 83 b4 f8 a4 02 b0 ...p.....p......
    16:48:22.216 00f0: 83 b4 f8 a6 02 00 f0 07 00 .........
    16:48:22.247 Incoming Dump:
    16:48:22.247 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.247 --
    16:48:22.247 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.247 Parameters:
    16:48:22.247 | Number HCI commands : 0x01
    16:48:22.247 | Command Opcode : 0xff05
    16:48:22.247 | Status : 0x00 (Success)
    16:48:22.247 --
    16:48:22.247 --
    16:48:22.247 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.247 | Address : 0x20001770
    16:48:22.247 | Size : 0xf0
    16:48:22.247 | Values : "86:F8:20:00:94:F8:A8:02:F0:77:B4:F8:AA:02:6F:F3:5F:20:26:F8:64:0C:B4:F8:AC:02:6F:F3:5F:20:26:F8:58:0C:94:F8:AE:02:06:F8:88:0C:0D:98:FF:F7:58:FB:B4:F8:B0:02:77:49:26:F8:52:0C:95:F8:52:00:20:44:90:F8:D8:00:08:70:0C:99:69:B1:49:1E:0D:D0:49:1E:09:D0:49:1E:0C:D1:B4:F8:5A:00:00:F0:01:00:07:90:58:46:06:90:04:E0:07:98:01:E0:07:98:06:90:05:90:07:98:11:99:08:70:95:F8:22:00:10:B1:01:98:01:28:12:D0:A0:8F:81:08:0C:D2:40:08:0D:D3:0A:98:58:B1:09:98:B0:F8:98:00:79:38:C1:B2:58:46:02:F0:22:FA:02:E0:02:F0:C1:F9:E0:87:85:F8:48:B0:07:98:00:28:0C:BF:58:46:40:46:12:99:FF:F7:76:F9:07:98:FF:F7:4B:FA:10:98:42:46:59:46:FE:F7:1E:FE:A2:4F:A1:88:9F:48:8A:08:1F:D3:04:9A:EA:B9:39:46:A1:F1:04:01:09:78:91:B1:85:F8:1C:B0:09:98:D0:F8:B0:00:C0:09"
    16:48:22.247 --
    16:48:22.247 Outgoing Dump:
    16:48:22.247 0000: 01 05 ff f5 70 17 00 20 f0 86 f8 20 00 94 f8 a8 ....p.. ... ....
    16:48:22.247 0010: 02 f0 77 b4 f8 aa 02 6f f3 5f 20 26 f8 64 0c b4 ..w....o._ &.d..
    16:48:22.247 0020: f8 ac 02 6f f3 5f 20 26 f8 58 0c 94 f8 ae 02 06 ...o._ &.X......
    16:48:22.247 0030: f8 88 0c 0d 98 ff f7 58 fb b4 f8 b0 02 77 49 26 .......X.....wI&
    16:48:22.247 0040: f8 52 0c 95 f8 52 00 20 44 90 f8 d8 00 08 70 0c .R...R. D.....p.
    16:48:22.247 0050: 99 69 b1 49 1e 0d d0 49 1e 09 d0 49 1e 0c d1 b4 .i.I...I...I....
    16:48:22.247 0060: f8 5a 00 00 f0 01 00 07 90 58 46 06 90 04 e0 07 .Z.......XF.....
    16:48:22.247 0070: 98 01 e0 07 98 06 90 05 90 07 98 11 99 08 70 95 ..............p.
    16:48:22.247 0080: f8 22 00 10 b1 01 98 01 28 12 d0 a0 8f 81 08 0c ."......(.......
    16:48:22.247 0090: d2 40 08 0d d3 0a 98 58 b1 09 98 b0 f8 98 00 79 .@.....X.......y
    16:48:22.247 00a0: 38 c1 b2 58 46 02 f0 22 fa 02 e0 02 f0 c1 f9 e0 8..XF.."........
    16:48:22.247 00b0: 87 85 f8 48 b0 07 98 00 28 0c bf 58 46 40 46 12 ...H....(..XF@F.
    16:48:22.247 00c0: 99 ff f7 76 f9 07 98 ff f7 4b fa 10 98 42 46 59 ...v.....K...BFY
    16:48:22.247 00d0: 46 fe f7 1e fe a2 4f a1 88 9f 48 8a 08 1f d3 04 F.....O...H.....
    16:48:22.247 00e0: 9a ea b9 39 46 a1 f1 04 01 09 78 91 b1 85 f8 1c ...9F.....x.....
    16:48:22.247 00f0: b0 09 98 d0 f8 b0 00 c0 09 .........
    16:48:22.279 Incoming Dump:
    16:48:22.279 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.279 --
    16:48:22.279 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.279 Parameters:
    16:48:22.279 | Number HCI commands : 0x01
    16:48:22.279 | Command Opcode : 0xff05
    16:48:22.279 | Status : 0x00 (Success)
    16:48:22.279 --
    16:48:22.279 --
    16:48:22.279 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.279 | Address : 0x20001860
    16:48:22.279 | Size : 0xf0
    16:48:22.279 | Values : "06:D3:9A:48:01:78:41:F2:11:12:2A:20:02:F0:9A:F9:01:98:00:28:40:F0:4A:83:44:E3:92:49:80:F8:08:80:09:88:80:F8:28:80:C9:08:34:D3:0C:99:03:29:31:D1:04:99:00:29:2E:D1:80:F8:00:80:80:F8:20:80:90:F8:60:02:38:B3:20:8C:02:F0:0B:FA:85:F8:1D:B0:09:98:D0:F8:B0:00:80:0D:06:D3:84:48:01:78:41:F2:11:12:39:20:02:F0:6F:F9:08:20:02:F0:B6:F9:00:09:11:D3:09:98:D0:F8:B0:00:C0:0D:06:D3:7C:48:01:78:41:F2:11:12:3A:20:02:F0:5E:F9:78:48:00:78:21:28:00:F0:09:83:0B:E3:03:98:90:F8:AC:00:68:B1:A0:F1:01:00:59:46:01:FA:00:F1:02:98:02:88:41:EA:02:02:02:80:02:88:22:EA:01:02:02:80:0A:98:80:B1:95:F8:22:00:10:B1:01:98:01:28:0A:D0:02:F0:36:F9:02:46:B2:F5:D2:7F:04:DA:65:48:01:78:57:20:02:F0:33:F9:95:F8:51:00:40:B9:0F:99:4F:F4:A0:60:A1:F8:8B:00:04:20"
    16:48:22.279 --
    16:48:22.279 Outgoing Dump:
    16:48:22.279 0000: 01 05 ff f5 60 18 00 20 f0 06 d3 9a 48 01 78 41 ....`.. ....H.xA
    16:48:22.279 0010: f2 11 12 2a 20 02 f0 9a f9 01 98 00 28 40 f0 4a ...* .......(@.J
    16:48:22.279 0020: 83 44 e3 92 49 80 f8 08 80 09 88 80 f8 28 80 c9 .D..I........(..
    16:48:22.279 0030: 08 34 d3 0c 99 03 29 31 d1 04 99 00 29 2e d1 80 .4....)1....)...
    16:48:22.279 0040: f8 00 80 80 f8 20 80 90 f8 60 02 38 b3 20 8c 02 ..... ...`.8. ..
    16:48:22.279 0050: f0 0b fa 85 f8 1d b0 09 98 d0 f8 b0 00 80 0d 06 ................
    16:48:22.279 0060: d3 84 48 01 78 41 f2 11 12 39 20 02 f0 6f f9 08 ..H.xA...9 ..o..
    16:48:22.279 0070: 20 02 f0 b6 f9 00 09 11 d3 09 98 d0 f8 b0 00 c0 ...............
    16:48:22.279 0080: 0d 06 d3 7c 48 01 78 41 f2 11 12 3a 20 02 f0 5e ...|H.xA...: ..^
    16:48:22.279 0090: f9 78 48 00 78 21 28 00 f0 09 83 0b e3 03 98 90 .xH.x!(.........
    16:48:22.279 00a0: f8 ac 00 68 b1 a0 f1 01 00 59 46 01 fa 00 f1 02 ...h.....YF.....
    16:48:22.279 00b0: 98 02 88 41 ea 02 02 02 80 02 88 22 ea 01 02 02 ...A......."....
    16:48:22.279 00c0: 80 0a 98 80 b1 95 f8 22 00 10 b1 01 98 01 28 0a ......."......(.
    16:48:22.279 00d0: d0 02 f0 36 f9 02 46 b2 f5 d2 7f 04 da 65 48 01 ...6..F......eH.
    16:48:22.279 00e0: 78 57 20 02 f0 33 f9 95 f8 51 00 40 b9 0f 99 4f xW ..3...Q.@...O
    16:48:22.279 00f0: f4 a0 60 a1 f8 8b 00 04 20 ..`.....
    16:48:22.310 Incoming Dump:
    16:48:22.310 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.310 --
    16:48:22.310 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.310 Parameters:
    16:48:22.310 | Number HCI commands : 0x01
    16:48:22.310 | Command Opcode : 0xff05
    16:48:22.310 | Status : 0x00 (Success)
    16:48:22.310 --
    16:48:22.310 --
    16:48:22.310 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.310 | Address : 0x20001950
    16:48:22.310 | Size : 0xf0
    16:48:22.310 | Values : "02:F0:04:F9:01:E0:FE:F7:3C:FC:14:20:02:F0:B0:F9:94:F8:C0:00:30:F0:7F:00:0E:D1:06:98:60:B9:20:7B:50:B9:03:20:02:F0:F2:F8:FF:F7:AC:FA:07:E0:C0:46:00:00:30:22:58:B5:01:20:0A:20:02:F0:E7:F8:08:20:02:F0:46:F9:A0:88:00:09:09:D3:09:98:B0:F8:9A:00:C0:F3:05:20:18:B1:38:78:00:28:40:F0:9D:82:01:99:40:46:4F:F0:02:07:11:B1:0B:99:01:B9:58:46:95:F8:51:10:FF:F7:CB:F9:BA:F8:00:00:40:F0:3F:00:AA:F8:00:00:AF:48:80:F8:5C:B0:FF:F7:0A:F8:0F:98:B0:F8:23:00:C0:F3:C0:10:85:F8:20:00:08:20:02:F0:68:F9:36:F8:02:1C:6F:F3:08:01:49:EA:01:01:26:F8:02:1C:94:F8:4A:10:84:F8:5C:10:94:F8:4B:10:84:F8:5D:10:0D:99:08:39:1F:D0:49:1E:26:D1:94:F8:48:00:84:F8:5C:00:94:F8:49:00:84:F8:5D:00:94:F8:5E:00:80:08:1A:D3:FE:F7:63:FE:01:46:FF:29:15:D0:58:46:FE:F7"
    16:48:22.310 --
    16:48:22.310 Outgoing Dump:
    16:48:22.310 0000: 01 05 ff f5 50 19 00 20 f0 02 f0 04 f9 01 e0 fe ....P.. ........
    16:48:22.310 0010: f7 3c fc 14 20 02 f0 b0 f9 94 f8 c0 00 30 f0 7f .<.. ........0..
    16:48:22.310 0020: 00 0e d1 06 98 60 b9 20 7b 50 b9 03 20 02 f0 f2 .....`. {P.. ...
    16:48:22.310 0030: f8 ff f7 ac fa 07 e0 c0 46 00 00 30 22 58 b5 01 ........F..0"X..
    16:48:22.310 0040: 20 0a 20 02 f0 e7 f8 08 20 02 f0 46 f9 a0 88 00 . ..... ..F....
    16:48:22.310 0050: 09 09 d3 09 98 b0 f8 9a 00 c0 f3 05 20 18 b1 38 ............ ..8
    16:48:22.310 0060: 78 00 28 40 f0 9d 82 01 99 40 46 4f f0 02 07 11 x.(@.....@FO....
    16:48:22.310 0070: b1 0b 99 01 b9 58 46 95 f8 51 10 ff f7 cb f9 ba .....XF..Q......
    16:48:22.310 0080: f8 00 00 40 f0 3f 00 aa f8 00 00 af 48 80 f8 5c ...@.?......H..\
    16:48:22.310 0090: b0 ff f7 0a f8 0f 98 b0 f8 23 00 c0 f3 c0 10 85 .........#......
    16:48:22.310 00a0: f8 20 00 08 20 02 f0 68 f9 36 f8 02 1c 6f f3 08 . .. ..h.6...o..
    16:48:22.310 00b0: 01 49 ea 01 01 26 f8 02 1c 94 f8 4a 10 84 f8 5c .I...&.....J...\
    16:48:22.310 00c0: 10 94 f8 4b 10 84 f8 5d 10 0d 99 08 39 1f d0 49 ...K...]....9..I
    16:48:22.310 00d0: 1e 26 d1 94 f8 48 00 84 f8 5c 00 94 f8 49 00 84 .&...H...\...I..
    16:48:22.310 00e0: f8 5d 00 94 f8 5e 00 80 08 1a d3 fe f7 63 fe 01 .]...^.......c..
    16:48:22.310 00f0: 46 ff 29 15 d0 58 46 fe f7 F.)..XF..
    16:48:22.341 Incoming Dump:
    16:48:22.341 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.341 --
    16:48:22.341 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.341 Parameters:
    16:48:22.341 | Number HCI commands : 0x01
    16:48:22.341 | Command Opcode : 0xff05
    16:48:22.341 | Status : 0x00 (Success)
    16:48:22.341 --
    16:48:22.341 --
    16:48:22.341 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.341 | Address : 0x20001a40
    16:48:22.341 | Size : 0xf0
    16:48:22.341 | Values : "B9:FE:36:F8:02:1C:B4:F8:CC:01:6F:F3:08:01:08:43:26:F8:02:0C:08:E0:94:F8:5E:00:40:08:04:D3:16:F8:1E:1C:40:46:FE:F7:A6:FE:08:20:02:F0:D9:F8:82:46:95:F8:20:10:CA:F3:C0:10:08:43:85:F8:20:00:12:20:86:F8:89:00:FE:F7:C5:FD:40:46:FE:F7:89:FC:94:F9:52:10:81:42:B8:BF:85:F8:21:B0:87:48:00:88:40:08:28:BF:85:F8:56:B0:08:98:10:B1:11:98:80:F8:24:89:01:98:08:B1:0B:98:58:B1:4F:F0:03:00:0A:E0:C0:46:24:11:28:22:54:02:01:20:90:13:28:22:E1:08:01:20:4F:F0:07:00:0F:99:08:70:03:98:90:F8:AD:00:48:B1:40:1E:59:46:81:40:02:98:02:88:0A:43:02:80:02:88:8A:43:02:80:0F:98:A0:F8:15:70:A0:8F:80:08:80:F0:EE:81:0A:98:00:28:00:F0:0C:82:02:F0:45:F8:02:46:95:F8:22:00:20:B1:01:98:01:28:08:BF:78:20:00:D0:87:20:41:00:01:EB:C0:01:88:B2:90:42:04:DA:AB:48"
    16:48:22.341 --
    16:48:22.341 Outgoing Dump:
    16:48:22.341 0000: 01 05 ff f5 40 1a 00 20 f0 b9 fe 36 f8 02 1c b4 ....@.. ...6....
    16:48:22.341 0010: f8 cc 01 6f f3 08 01 08 43 26 f8 02 0c 08 e0 94 ...o....C&......
    16:48:22.341 0020: f8 5e 00 40 08 04 d3 16 f8 1e 1c 40 46 fe f7 a6 .^.@.......@F...
    16:48:22.341 0030: fe 08 20 02 f0 d9 f8 82 46 95 f8 20 10 ca f3 c0 .. .....F.. ....
    16:48:22.341 0040: 10 08 43 85 f8 20 00 12 20 86 f8 89 00 fe f7 c5 ..C.. .. .......
    16:48:22.341 0050: fd 40 46 fe f7 89 fc 94 f9 52 10 81 42 b8 bf 85 .@F......R..B...
    16:48:22.341 0060: f8 21 b0 87 48 00 88 40 08 28 bf 85 f8 56 b0 08 .!..H..@.(...V..
    16:48:22.341 0070: 98 10 b1 11 98 80 f8 24 89 01 98 08 b1 0b 98 58 .......$.......X
    16:48:22.341 0080: b1 4f f0 03 00 0a e0 c0 46 24 11 28 22 54 02 01 .O......F$.("T..
    16:48:22.341 0090: 20 90 13 28 22 e1 08 01 20 4f f0 07 00 0f 99 08 ..("... O......
    16:48:22.341 00a0: 70 03 98 90 f8 ad 00 48 b1 40 1e 59 46 81 40 02 p......H.@.YF.@.
    16:48:22.341 00b0: 98 02 88 0a 43 02 80 02 88 8a 43 02 80 0f 98 a0 ....C.....C.....
    16:48:22.341 00c0: f8 15 70 a0 8f 80 08 80 f0 ee 81 0a 98 00 28 00 ..p...........(.
    16:48:22.341 00d0: f0 0c 82 02 f0 45 f8 02 46 95 f8 22 00 20 b1 01 .....E..F..". ..
    16:48:22.341 00e0: 98 01 28 08 bf 78 20 00 d0 87 20 41 00 01 eb c0 ..(..x ... A....
    16:48:22.341 00f0: 01 88 b2 90 42 04 da ab 48 ....B...H
    16:48:22.372 Incoming Dump:
    16:48:22.372 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.372 --
    16:48:22.372 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.372 Parameters:
    16:48:22.372 | Number HCI commands : 0x01
    16:48:22.372 | Command Opcode : 0xff05
    16:48:22.372 | Status : 0x00 (Success)
    16:48:22.372 --
    16:48:22.372 --
    16:48:22.372 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.372 | Address : 0x20001b30
    16:48:22.372 | Size : 0xf0
    16:48:22.372 | Values : "01:78:58:20:02:F0:36:F8:05:98:01:28:40:F0:BE:80:01:98:00:28:6D:D0:0B:98:01:28:6A:D0:94:F8:5C:00:40:08:C0:F0:A8:80:0F:98:B0:F8:23:00:44:F2:01:07:38:46:02:F0:5D:F8:82:46:5F:EA:5A:00:80:F0:9B:80:07:EA:0A:00:40:09:0A:D3:FE:F7:94:FE:85:F8:54:80:85:F8:53:80:4F:F6:EF:70:86:F8:AE:80:07:40:5F:EA:DA:30:36:D3:B6:F8:C8:91:09:F0:0F:09:5F:EA:59:00:19:D3:95:F8:53:00:B0:B9:94:F8:5C:10:85:F8:53:B0:88:08:0B:D3:95:F8:55:00:40:B9:95:F8:56:00:08:B1:C8:08:03:D3:94:F8:5D:00:FE:F7:28:FD:B4:F8:46:03:40:1C:A4:F8:46:03:5F:EA:19:10:12:D3:95:F8:54:00:78:B9:B4:F8:44:03:40:1C:A4:F8:44:03:94:F8:5C:00:85:F8:54:B0:40:09:56:D3:3C:20:02:F0:4F:F8:47:F0:10:07:08:98:00:28:AB:D0:5F:EA:1A:20:03:D2:95:F8:20:00:01:28:A4:D1:11:98:80:F8:24:B9:CD:F8:20:80"
    16:48:22.372 --
    16:48:22.372 Outgoing Dump:
    16:48:22.372 0000: 01 05 ff f5 30 1b 00 20 f0 01 78 58 20 02 f0 36 ....0.. ..xX ..6
    16:48:22.372 0010: f8 05 98 01 28 40 f0 be 80 01 98 00 28 6d d0 0b ....(@......(m..
    16:48:22.372 0020: 98 01 28 6a d0 94 f8 5c 00 40 08 c0 f0 a8 80 0f ..(j...\.@......
    16:48:22.372 0030: 98 b0 f8 23 00 44 f2 01 07 38 46 02 f0 5d f8 82 ...#.D...8F..]..
    16:48:22.372 0040: 46 5f ea 5a 00 80 f0 9b 80 07 ea 0a 00 40 09 0a F_.Z.........@..
    16:48:22.372 0050: d3 fe f7 94 fe 85 f8 54 80 85 f8 53 80 4f f6 ef .......T...S.O..
    16:48:22.372 0060: 70 86 f8 ae 80 07 40 5f ea da 30 36 d3 b6 f8 c8 p.....@_..06....
    16:48:22.372 0070: 91 09 f0 0f 09 5f ea 59 00 19 d3 95 f8 53 00 b0 ....._.Y.....S..
    16:48:22.372 0080: b9 94 f8 5c 10 85 f8 53 b0 88 08 0b d3 95 f8 55 ...\...S.......U
    16:48:22.372 0090: 00 40 b9 95 f8 56 00 08 b1 c8 08 03 d3 94 f8 5d .@...V.........]
    16:48:22.372 00a0: 00 fe f7 28 fd b4 f8 46 03 40 1c a4 f8 46 03 5f ...(...F.@...F._
    16:48:22.372 00b0: ea 19 10 12 d3 95 f8 54 00 78 b9 b4 f8 44 03 40 .......T.x...D.@
    16:48:22.372 00c0: 1c a4 f8 44 03 94 f8 5c 00 85 f8 54 b0 40 09 56 ...D...\...T.@.V
    16:48:22.372 00d0: d3 3c 20 02 f0 4f f8 47 f0 10 07 08 98 00 28 ab .< ..O.G......(.
    16:48:22.372 00e0: d0 5f ea 1a 20 03 d2 95 f8 20 00 01 28 a4 d1 11 ._.. .... ..(...
    16:48:22.372 00f0: 98 80 f8 24 b9 cd f8 20 80 ...$... .
    16:48:22.404 Incoming Dump:
    16:48:22.404 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.404 --
    16:48:22.404 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.404 Parameters:
    16:48:22.404 | Number HCI commands : 0x01
    16:48:22.404 | Command Opcode : 0xff05
    16:48:22.404 | Status : 0x00 (Success)
    16:48:22.404 --
    16:48:22.404 --
    16:48:22.404 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.404 | Address : 0x20001c20
    16:48:22.404 | Size : 0xf0
    16:48:22.404 | Values : "9E:E7:09:98:B4:F8:C2:12:B0:F8:A8:00:40:1A:01:B2:0A:20:01:FB:00:F0:0F:99:A1:F8:33:00:88:20:01:F0:EF:FF:82:46:5F:EA:1A:20:03:D2:95:F8:20:00:01:28:04:D1:11:98:80:F8:24:B9:CD:F8:20:80:5F:EA:1A:20:02:D3:08:20:01:F0:DC:FF:FE:F7:D3:FC:40:46:FE:F7:97:FB:94:F9:C1:10:81:42:0C:DB:95:F8:20:00:01:28:08:D0:94:F8:C0:00:40:08:0D:D3:0C:98:58:B9:46:E1:08:20:3E:22:08:98:01:28:02:D1:40:46:FE:F7:AC:FB:13:98:80:F8:00:B0:DD:F8:4C:90:1A:F0:81:0F:0B:D1:81:20:01:F0:B5:FF:06:E0:A6:82:01:20:81:20:01:F0:AF:FF:DD:F8:4C:90:82:46:5F:EA:1A:20:03:D2:95:F8:20:00:01:28:04:D1:11:98:80:F8:24:B9:CD:F8:20:80:09:98:D0:F8:B0:00:80:0A:0A:D3:95:F8:20:10:95:F8:21:00:08:9A:40:EA:C1:10:81:B2:2D:20:01:F0:52:FF:5F:EA:5A:00:02:D2:58:46:01:F0:8A:FF:03:98:90:F8"
    16:48:22.404 --
    16:48:22.404 Outgoing Dump:
    16:48:22.404 0000: 01 05 ff f5 20 1c 00 20 f0 9e e7 09 98 b4 f8 c2 .... .. ........
    16:48:22.404 0010: 12 b0 f8 a8 00 40 1a 01 b2 0a 20 01 fb 00 f0 0f .....@.... .....
    16:48:22.404 0020: 99 a1 f8 33 00 88 20 01 f0 ef ff 82 46 5f ea 1a ...3.. .....F_..
    16:48:22.404 0030: 20 03 d2 95 f8 20 00 01 28 04 d1 11 98 80 f8 24 .... ..(......$
    16:48:22.404 0040: b9 cd f8 20 80 5f ea 1a 20 02 d3 08 20 01 f0 dc ... ._.. ... ...
    16:48:22.404 0050: ff fe f7 d3 fc 40 46 fe f7 97 fb 94 f9 c1 10 81 .....@F.........
    16:48:22.404 0060: 42 0c db 95 f8 20 00 01 28 08 d0 94 f8 c0 00 40 B.... ..(......@
    16:48:22.404 0070: 08 0d d3 0c 98 58 b9 46 e1 08 20 3e 22 08 98 01 .....X.F.. >"...
    16:48:22.404 0080: 28 02 d1 40 46 fe f7 ac fb 13 98 80 f8 00 b0 dd (..@F...........
    16:48:22.404 0090: f8 4c 90 1a f0 81 0f 0b d1 81 20 01 f0 b5 ff 06 .L........ .....
    16:48:22.404 00a0: e0 a6 82 01 20 81 20 01 f0 af ff dd f8 4c 90 82 .... . ......L..
    16:48:22.404 00b0: 46 5f ea 1a 20 03 d2 95 f8 20 00 01 28 04 d1 11 F_.. .... ..(...
    16:48:22.404 00c0: 98 80 f8 24 b9 cd f8 20 80 09 98 d0 f8 b0 00 80 ...$... ........
    16:48:22.404 00d0: 0a 0a d3 95 f8 20 10 95 f8 21 00 08 9a 40 ea c1 ..... ...!...@..
    16:48:22.404 00e0: 10 81 b2 2d 20 01 f0 52 ff 5f ea 5a 00 02 d2 58 ...- ..R._.Z...X
    16:48:22.404 00f0: 46 01 f0 8a ff 03 98 90 f8 F........
    16:48:22.435 Incoming Dump:
    16:48:22.435 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.435 --
    16:48:22.435 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.435 Parameters:
    16:48:22.435 | Number HCI commands : 0x01
    16:48:22.435 | Command Opcode : 0xff05
    16:48:22.435 | Status : 0x00 (Success)
    16:48:22.435 --
    16:48:22.435 --
    16:48:22.435 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.435 | Address : 0x20001d10
    16:48:22.435 | Size : 0xf0
    16:48:22.435 | Values : "A1:00:48:B1:40:1E:59:46:81:40:02:98:02:88:0A:43:02:80:02:88:8A:43:02:80:09:98:D0:F8:B0:00:40:08:05:D3:41:F2:11:11:24:20:0A:46:01:F0:33:FF:B4:F8:42:03:40:1C:A4:F8:42:03:01:98:01:28:15:D1:08:98:01:28:02:D1:58:46:FE:F7:4F:FB:FE:F7:5A:FC:40:46:FE:F7:1E:FB:03:99:81:F8:70:00:94:F9:53:10:81:42:BC:BF:03:98:80:F8:74:B0:03:E0:B4:F8:C0:02:01:F0:9F:FF:07:20:01:F0:8A:FF:94:F8:C0:00:41:46:C0:F3:02:12:01:2A:08:BF:59:46:20:7B:01:28:04:D0:02:2A:09:D1:FF:F7:97:F8:06:E0:08:98:01:28:18:BF:01:29:01:D1:FF:F7:F5:F8:10:20:01:F0:32:FF:96:F8:23:00:03:28:08:BF:04:20:01:99:51:B9:0E:99:02:29:C7:BF:03:99:88:80:03:98:A0:F8:04:80:0B:E0:E1:08:01:20:96:F8:22:10:00:F0:07:00:C9:00:01:F4:7E:71:08:43:03:99:C8:80:B0:8C:03:99:6F:F3:5F:20:A1:F8:82:00"
    16:48:22.435 --
    16:48:22.435 Outgoing Dump:
    16:48:22.435 0000: 01 05 ff f5 10 1d 00 20 f0 a1 00 48 b1 40 1e 59 ....... ...H.@.Y
    16:48:22.435 0010: 46 81 40 02 98 02 88 0a 43 02 80 02 88 8a 43 02 F.@.....C.....C.
    16:48:22.435 0020: 80 09 98 d0 f8 b0 00 40 08 05 d3 41 f2 11 11 24 .......@...A...$
    16:48:22.435 0030: 20 0a 46 01 f0 33 ff b4 f8 42 03 40 1c a4 f8 42 .F..3...B.@...B
    16:48:22.435 0040: 03 01 98 01 28 15 d1 08 98 01 28 02 d1 58 46 fe ....(.....(..XF.
    16:48:22.435 0050: f7 4f fb fe f7 5a fc 40 46 fe f7 1e fb 03 99 81 .O...Z.@F.......
    16:48:22.435 0060: f8 70 00 94 f9 53 10 81 42 bc bf 03 98 80 f8 74 .p...S..B......t
    16:48:22.435 0070: b0 03 e0 b4 f8 c0 02 01 f0 9f ff 07 20 01 f0 8a ............ ...
    16:48:22.435 0080: ff 94 f8 c0 00 41 46 c0 f3 02 12 01 2a 08 bf 59 .....AF.....*..Y
    16:48:22.435 0090: 46 20 7b 01 28 04 d0 02 2a 09 d1 ff f7 97 f8 06 F {.(...*.......
    16:48:22.435 00a0: e0 08 98 01 28 18 bf 01 29 01 d1 ff f7 f5 f8 10 ....(...).......
    16:48:22.435 00b0: 20 01 f0 32 ff 96 f8 23 00 03 28 08 bf 04 20 01 ..2...#..(... .
    16:48:22.435 00c0: 99 51 b9 0e 99 02 29 c7 bf 03 99 88 80 03 98 a0 .Q....).........
    16:48:22.435 00d0: f8 04 80 0b e0 e1 08 01 20 96 f8 22 10 00 f0 07 ........ .."....
    16:48:22.435 00e0: 00 c9 00 01 f4 7e 71 08 43 03 99 c8 80 b0 8c 03 .....~q.C.......
    16:48:22.435 00f0: 99 6f f3 5f 20 a1 f8 82 00 .o._ ....
    16:48:22.466 Incoming Dump:
    16:48:22.466 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.466 --
    16:48:22.466 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.466 Parameters:
    16:48:22.466 | Number HCI commands : 0x01
    16:48:22.466 | Command Opcode : 0xff05
    16:48:22.466 | Status : 0x00 (Success)
    16:48:22.466 --
    16:48:22.466 --
    16:48:22.466 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.466 | Address : 0x20001e00
    16:48:22.466 | Size : 0xf0
    16:48:22.466 | Values : "03:98:D6:F8:DA:11:C0:F8:84:10:D6:F8:DE:11:03:98:C0:F8:88:10:09:98:D0:F8:B0:00:C0:0A:07:D3:B0:8C:01:99:6F:F3:5F:20:82:B2:2E:20:01:F0:BB:FE:3E:4F:B4:F8:BE:02:87:F8:24:80:01:F0:90:FE:FE:F7:E9:FB:87:F8:00:80:39:48:80:F8:00:80:01:98:10:B1:0B:98:01:28:02:D1:0C:20:01:F0:EF:FE:89:F8:00:80:89:F8:40:B0:01:98:10:B1:0B:98:01:28:2B:D1:0F:99:04:20:08:70:B4:F8:C0:02:C0:F1:38:00:80:B2:01:F0:20:FF:09:20:01:F0:CD:FE:40:08:09:D3:95:F8:20:00:30:B9:95:F8:21:00:18:B9:B4:F8:CE:02:26:F8:52:0C:0F:99:06:20:08:70:64:20:01:F0:0B:FF:09:20:01:F0:C4:FE:40:08:07:D3:0A:20:01:F0:51:FE:87:F8:1C:80:11:98:80:F8:70:B9:01:98:01:28:2B:D1:B4:F8:CA:00:40:B3:03:9A:69:46:58:46:72:32:FE:F7:E6:F8:21:E0:01:F0:5B:FE:A4:F8:40:00:1C:E0:11:48:85:F8:1C:B0:01:78"
    16:48:22.466 --
    16:48:22.466 Outgoing Dump:
    16:48:22.466 0000: 01 05 ff f5 00 1e 00 20 f0 03 98 d6 f8 da 11 c0 ....... ........
    16:48:22.466 0010: f8 84 10 d6 f8 de 11 03 98 c0 f8 88 10 09 98 d0 ................
    16:48:22.466 0020: f8 b0 00 c0 0a 07 d3 b0 8c 01 99 6f f3 5f 20 82 ...........o._ .
    16:48:22.466 0030: b2 2e 20 01 f0 bb fe 3e 4f b4 f8 be 02 87 f8 24 .. ....>O......$
    16:48:22.466 0040: 80 01 f0 90 fe fe f7 e9 fb 87 f8 00 80 39 48 80 .............9H.
    16:48:22.466 0050: f8 00 80 01 98 10 b1 0b 98 01 28 02 d1 0c 20 01 ..........(... .
    16:48:22.466 0060: f0 ef fe 89 f8 00 80 89 f8 40 b0 01 98 10 b1 0b .........@......
    16:48:22.466 0070: 98 01 28 2b d1 0f 99 04 20 08 70 b4 f8 c0 02 c0 ..(+.... .p.....
    16:48:22.466 0080: f1 38 00 80 b2 01 f0 20 ff 09 20 01 f0 cd fe 40 .8..... .. ....@
    16:48:22.466 0090: 08 09 d3 95 f8 20 00 30 b9 95 f8 21 00 18 b9 b4 ..... .0...!....
    16:48:22.466 00a0: f8 ce 02 26 f8 52 0c 0f 99 06 20 08 70 64 20 01 ...&.R.... .pd .
    16:48:22.466 00b0: f0 0b ff 09 20 01 f0 c4 fe 40 08 07 d3 0a 20 01 .... ....@.... .
    16:48:22.466 00c0: f0 51 fe 87 f8 1c 80 11 98 80 f8 70 b9 01 98 01 .Q.........p....
    16:48:22.466 00d0: 28 2b d1 b4 f8 ca 00 40 b3 03 9a 69 46 58 46 72 (+.....@...iFXFr
    16:48:22.466 00e0: 32 fe f7 e6 f8 21 e0 01 f0 5b fe a4 f8 40 00 1c 2....!...[...@..
    16:48:22.466 00f0: e0 11 48 85 f8 1c b0 01 78 ..H.....x
    16:48:22.497 Incoming Dump:
    16:48:22.497 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.497 --
    16:48:22.497 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.497 Parameters:
    16:48:22.497 | Number HCI commands : 0x01
    16:48:22.497 | Command Opcode : 0xff05
    16:48:22.497 | Status : 0x00 (Success)
    16:48:22.497 --
    16:48:22.497 --
    16:48:22.497 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.497 | Address : 0x20001ef0
    16:48:22.497 | Size : 0xf0
    16:48:22.497 | Values : "0F:98:90:F8:93:00:C0:F3:01:12:59:20:01:F0:52:FE:01:98:18:B9:0F:98:80:F8:44:B0:02:E0:0F:98:80:F8:46:B0:60:89:01:28:08:BF:D8:46:85:F8:22:80:01:F0:CF:F9:14:B0:BD:E8:F0:8F:90:2C:30:22:08:20:3E:22:E1:08:01:20:2D:E9:F0:4F:AD:F1:40:0D:00:90:AE:48:01:90:01:78:AD:48:02:90:31:B1:49:1E:01:22:02:98:8A:40:01:88:0A:43:02:80:AF:48:00:68:C0:0F:05:D3:AE:48:00:99:02:78:4A:20:01:F0:1C:FE:AC:48:01:46:AC:4C:03:90:88:39:03:91:00:68:40:F4:80:30:C1:F8:88:00:A0:8B:01:F0:9C:FE:DF:F8:A0:82:A6:4F:A8:48:98:F8:55:10:49:08:16:D3:B4:F8:8A:10:4A:08:12:D2:98:F8:54:20:02:F0:0F:02:02:2A:0C:D1:B8:F8:C8:20:02:EA:51:01:49:08:06:D2:06:46:31:88:21:F0:03:00:40:F0:04:00:12:E0:98:F8:54:10:01:F0:0F:01:01:29:06:D0:06:46:30:88:20:F0:07:00:40:F0:01:00:05:E0"
    16:48:22.497 --
    16:48:22.497 Outgoing Dump:
    16:48:22.497 0000: 01 05 ff f5 f0 1e 00 20 f0 0f 98 90 f8 93 00 c0 ....... ........
    16:48:22.497 0010: f3 01 12 59 20 01 f0 52 fe 01 98 18 b9 0f 98 80 ...Y ..R........
    16:48:22.497 0020: f8 44 b0 02 e0 0f 98 80 f8 46 b0 60 89 01 28 08 .D.......F.`..(.
    16:48:22.497 0030: bf d8 46 85 f8 22 80 01 f0 cf f9 14 b0 bd e8 f0 ..F.."..........
    16:48:22.497 0040: 8f 90 2c 30 22 08 20 3e 22 e1 08 01 20 2d e9 f0 ..,0". >"... -..
    16:48:22.497 0050: 4f ad f1 40 0d 00 90 ae 48 01 90 01 78 ad 48 02 O..@....H...x.H.
    16:48:22.497 0060: 90 31 b1 49 1e 01 22 02 98 8a 40 01 88 0a 43 02 .1.I.."...@...C.
    16:48:22.497 0070: 80 af 48 00 68 c0 0f 05 d3 ae 48 00 99 02 78 4a ..H.h.....H...xJ
    16:48:22.497 0080: 20 01 f0 1c fe ac 48 01 46 ac 4c 03 90 88 39 03 .....H.F.L...9.
    16:48:22.497 0090: 91 00 68 40 f4 80 30 c1 f8 88 00 a0 8b 01 f0 9c ..h@..0.........
    16:48:22.497 00a0: fe df f8 a0 82 a6 4f a8 48 98 f8 55 10 49 08 16 ......O.H..U.I..
    16:48:22.497 00b0: d3 b4 f8 8a 10 4a 08 12 d2 98 f8 54 20 02 f0 0f .....J.....T ...
    16:48:22.497 00c0: 02 02 2a 0c d1 b8 f8 c8 20 02 ea 51 01 49 08 06 ..*..... ..Q.I..
    16:48:22.497 00d0: d2 06 46 31 88 21 f0 03 00 40 f0 04 00 12 e0 98 ..F1.!...@......
    16:48:22.497 00e0: f8 54 10 01 f0 0f 01 01 29 06 d0 06 46 30 88 20 .T......)...F0.
    16:48:22.497 00f0: f0 07 00 40 f0 01 00 05 e0 ...@.....
    16:48:22.529 Incoming Dump:
    16:48:22.529 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.529 --
    16:48:22.529 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.529 Parameters:
    16:48:22.529 | Number HCI commands : 0x01
    16:48:22.529 | Command Opcode : 0xff05
    16:48:22.529 | Status : 0x00 (Success)
    16:48:22.529 --
    16:48:22.529 --
    16:48:22.529 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.529 | Address : 0x20001fe0
    16:48:22.529 | Size : 0xf0
    16:48:22.529 | Values : "06:46:30:88:20:F0:07:00:40:F0:02:00:04:96:30:80:08:20:01:F0:15:FE:01:25:B2:49:06:F8:13:5C:0A:78:00:20:51:2A:08:BF:28:1C:05:90:40:B1:A0:8F:80:08:03:D2:05:98:01:28:02:D1:0B:E0:00:20:05:90:B4:F8:88:00:01:28:05:D0:94:F8:10:01:01:28:18:BF:06:95:02:D1:4F:F0:00:00:06:90:4F:F0:00:00:87:F8:48:00:4F:F0:09:00:B0:4B:AE:4E:07:90:00:99:AD:48:F1:B1:08:90:05:70:4F:F4:80:70:03:99:A4:F8:62:00:A1:F8:64:00:98:8B:00:F0:07:02:42:F0:08:02:C1:08:09:92:0A:D3:0F:2A:0A:95:05:D0:09:99:4F:F0:00:0E:01:F0:03:01:11:E0:02:21:0F:E0:00:21:0A:91:0D:E0:08:90:00:21:01:70:03:98:A0:F8:64:50:18:88:A4:F8:62:50:00:F0:04:0E:00:F0:03:01:09:91:05:99:01:29:05:D0:94:F8:10:11:01:29:18:BF:87:F8:52:50:10:F0:40:0C:0E:BF:C0:F3:C2:01:B4:F8:4E:10:C1:F3:82:21:94:F8"
    16:48:22.529 --
    16:48:22.529 Outgoing Dump:
    16:48:22.529 0000: 01 05 ff f5 e0 1f 00 20 f0 06 46 30 88 20 f0 07 ....... ..F0. ..
    16:48:22.529 0010: 00 40 f0 02 00 04 96 30 80 08 20 01 f0 15 fe 01 .@.....0.. .....
    16:48:22.529 0020: 25 b2 49 06 f8 13 5c 0a 78 00 20 51 2a 08 bf 28 %.I...\.x. Q*..(
    16:48:22.529 0030: 1c 05 90 40 b1 a0 8f 80 08 03 d2 05 98 01 28 02 ...@..........(.
    16:48:22.529 0040: d1 0b e0 00 20 05 90 b4 f8 88 00 01 28 05 d0 94 .... .......(...
    16:48:22.529 0050: f8 10 01 01 28 18 bf 06 95 02 d1 4f f0 00 00 06 ....(......O....
    16:48:22.529 0060: 90 4f f0 00 00 87 f8 48 00 4f f0 09 00 b0 4b ae .O.....H.O....K.
    16:48:22.529 0070: 4e 07 90 00 99 ad 48 f1 b1 08 90 05 70 4f f4 80 N.....H.....pO..
    16:48:22.529 0080: 70 03 99 a4 f8 62 00 a1 f8 64 00 98 8b 00 f0 07 p....b...d......
    16:48:22.529 0090: 02 42 f0 08 02 c1 08 09 92 0a d3 0f 2a 0a 95 05 .B..........*...
    16:48:22.529 00a0: d0 09 99 4f f0 00 0e 01 f0 03 01 11 e0 02 21 0f ...O..........!.
    16:48:22.529 00b0: e0 00 21 0a 91 0d e0 08 90 00 21 01 70 03 98 a0 ..!.......!.p...
    16:48:22.529 00c0: f8 64 50 18 88 a4 f8 62 50 00 f0 04 0e 00 f0 03 .dP....bP.......
    16:48:22.529 00d0: 01 09 91 05 99 01 29 05 d0 94 f8 10 11 01 29 18 ......).......).
    16:48:22.529 00e0: bf 87 f8 52 50 10 f0 40 0c 0e bf c0 f3 c2 01 b4 ...RP..@........
    16:48:22.529 00f0: f8 4e 10 c1 f3 82 21 94 f8 .N....!..
    16:48:22.560 Incoming Dump:
    16:48:22.560 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.560 --
    16:48:22.560 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.560 Parameters:
    16:48:22.560 | Number HCI commands : 0x01
    16:48:22.560 | Command Opcode : 0xff05
    16:48:22.560 | Status : 0x00 (Success)
    16:48:22.560 --
    16:48:22.560 --
    16:48:22.560 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.560 | Address : 0x200020d0
    16:48:22.560 | Size : 0xf0
    16:48:22.560 | Values : "E2:22:0B:92:94:F8:E4:22:0C:92:94:F8:E6:22:0D:92:09:9A:C0:F3:C6:10:00:2A:00:F0:8A:80:52:1E:53:D0:52:1E:3B:D0:92:1F:18:D0:52:1E:40:F0:CF:80:08:EB:01:02:BC:F1:00:0F:92:F9:68:B0:94:F9:C5:20:04:BF:04:EB:41:01:B1:F8:F4:11:04:D0:B4:F8:4E:10:6F:F3:9F:21:89:B2:4F:F0:29:09:1D:E0:08:EB:01:02:BC:F1:00:0F:92:F9:60:B0:94:F9:C4:20:04:BF:04:EB:41:01:B1:F8:E4:11:04:D0:B4:F8:4E:10:6F:F3:9F:21:89:B2:94:F8:E3:32:0B:93:94:F8:E5:32:0C:93:94:F8:E7:32:4F:F0:40:09:0D:93:08:9B:59:86:97:E0:08:EB:01:02:BC:F1:00:0F:92:F9:58:B0:94:F9:C7:20:04:BF:04:EB:41:01:B1:F8:D4:11:04:D0:B4:F8:4E:10:6F:F3:9F:21:89:B2:08:9B:59:86:7F:E0:BE:F1:00:0F:09:D0:1A:8A:C2:F3:C2:02:8A:42:03:DD:89:1A:C9:1D:C9:B2:00:E0:07:21:08:EB:01:02:BC:F1:00:0F:92:F9:78:B0:94:F9"
    16:48:22.560 --
    16:48:22.560 Outgoing Dump:
    16:48:22.560 0000: 01 05 ff f5 d0 20 00 20 f0 e2 22 0b 92 94 f8 e4 ..... . ..".....
    16:48:22.560 0010: 22 0c 92 94 f8 e6 22 0d 92 09 9a c0 f3 c6 10 00 ".....".........
    16:48:22.560 0020: 2a 00 f0 8a 80 52 1e 53 d0 52 1e 3b d0 92 1f 18 *....R.S.R.;....
    16:48:22.560 0030: d0 52 1e 40 f0 cf 80 08 eb 01 02 bc f1 00 0f 92 .R.@............
    16:48:22.560 0040: f9 68 b0 94 f9 c5 20 04 bf 04 eb 41 01 b1 f8 f4 .h.... ....A....
    16:48:22.560 0050: 11 04 d0 b4 f8 4e 10 6f f3 9f 21 89 b2 4f f0 29 .....N.o..!..O.)
    16:48:22.560 0060: 09 1d e0 08 eb 01 02 bc f1 00 0f 92 f9 60 b0 94 .............`..
    16:48:22.560 0070: f9 c4 20 04 bf 04 eb 41 01 b1 f8 e4 11 04 d0 b4 .. ....A........
    16:48:22.560 0080: f8 4e 10 6f f3 9f 21 89 b2 94 f8 e3 32 0b 93 94 .N.o..!.....2...
    16:48:22.560 0090: f8 e5 32 0c 93 94 f8 e7 32 4f f0 40 09 0d 93 08 ..2.....2O.@....
    16:48:22.560 00a0: 9b 59 86 97 e0 08 eb 01 02 bc f1 00 0f 92 f9 58 .Y.............X
    16:48:22.560 00b0: b0 94 f9 c7 20 04 bf 04 eb 41 01 b1 f8 d4 11 04 .... ....A......
    16:48:22.560 00c0: d0 b4 f8 4e 10 6f f3 9f 21 89 b2 08 9b 59 86 7f ...N.o..!....Y..
    16:48:22.560 00d0: e0 be f1 00 0f 09 d0 1a 8a c2 f3 c2 02 8a 42 03 ..............B.
    16:48:22.560 00e0: dd 89 1a c9 1d c9 b2 00 e0 07 21 08 eb 01 02 bc ..........!.....
    16:48:22.560 00f0: f1 00 0f 92 f9 78 b0 94 f9 .....x...
    16:48:22.591 Incoming Dump:
    16:48:22.591 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.591 --
    16:48:22.607 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.607 Parameters:
    16:48:22.607 | Number HCI commands : 0x01
    16:48:22.607 | Command Opcode : 0xff05
    16:48:22.607 | Status : 0x00 (Success)
    16:48:22.607 --
    16:48:22.607 --
    16:48:22.607 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.607 | Address : 0x200021c0
    16:48:22.607 | Size : 0xf0
    16:48:22.607 | Values : "C9:20:04:BF:04:EB:41:01:B1:F8:14:12:04:D0:B4:F8:4E:10:6F:F3:9F:21:89:B2:98:F8:54:30:03:F0:0F:03:06:2B:06:D9:94:F9:7C:30:5B:45:C8:BF:B4:F8:80:30:43:DC:B4:F8:D2:32:40:E0:F2:00:01:20:04:F0:0E:20:BE:F1:00:0F:17:D0:1A:8A:02:F0:07:02:8A:42:11:DD:89:1A:C9:1D:C9:B2:0E:E0:B0:01:01:20:A2:08:01:20:90:40:01:20:50:02:01:20:80:08:01:20:00:01:01:20:1C:B0:01:20:07:21:08:EB:01:02:BC:F1:00:0F:92:F9:70:B0:94:F9:C8:20:04:BF:04:EB:41:01:B1:F8:04:12:04:D0:B4:F8:4E:10:6F:F3:9F:21:89:B2:98:F8:54:30:03:F0:0F:03:06:2B:06:D9:94:F9:7C:30:5B:45:C8:BF:B4:F8:7E:30:01:DC:B4:F8:D0:32:4F:F4:00:7C:01:FB:03:C3:DD:F8:20:C0:4F:EA:A3:23:AC:F8:32:30:AC:F8:30:10:4F:F0:29:01:07:91:4F:F0:52:09:B4:F8:C2:10:91:B9:B8:F8:C8:10:89:08:02:D3:B4:F8:8C:10:79:B9"
    16:48:22.607 --
    16:48:22.607 Outgoing Dump:
    16:48:22.607 0000: 01 05 ff f5 c0 21 00 20 f0 c9 20 04 bf 04 eb 41 .....!. .. ....A
    16:48:22.607 0010: 01 b1 f8 14 12 04 d0 b4 f8 4e 10 6f f3 9f 21 89 .........N.o..!.
    16:48:22.607 0020: b2 98 f8 54 30 03 f0 0f 03 06 2b 06 d9 94 f9 7c ...T0.....+....|
    16:48:22.607 0030: 30 5b 45 c8 bf b4 f8 80 30 43 dc b4 f8 d2 32 40 0[E.....0C....2@
    16:48:22.607 0040: e0 f2 00 01 20 04 f0 0e 20 be f1 00 0f 17 d0 1a .... ... .......
    16:48:22.607 0050: 8a 02 f0 07 02 8a 42 11 dd 89 1a c9 1d c9 b2 0e ......B.........
    16:48:22.607 0060: e0 b0 01 01 20 a2 08 01 20 90 40 01 20 50 02 01 .... ... .@. P..
    16:48:22.607 0070: 20 80 08 01 20 00 01 01 20 1c b0 01 20 07 21 08 ... ... ... .!.
    16:48:22.607 0080: eb 01 02 bc f1 00 0f 92 f9 70 b0 94 f9 c8 20 04 .........p.... .
    16:48:22.607 0090: bf 04 eb 41 01 b1 f8 04 12 04 d0 b4 f8 4e 10 6f ...A.........N.o
    16:48:22.607 00a0: f3 9f 21 89 b2 98 f8 54 30 03 f0 0f 03 06 2b 06 ..!....T0.....+.
    16:48:22.607 00b0: d9 94 f9 7c 30 5b 45 c8 bf b4 f8 7e 30 01 dc b4 ...|0[E....~0...
    16:48:22.607 00c0: f8 d0 32 4f f4 00 7c 01 fb 03 c3 dd f8 20 c0 4f ..2O..|...... .O
    16:48:22.607 00d0: ea a3 23 ac f8 32 30 ac f8 30 10 4f f0 29 01 07 ..#..20..0.O.)..
    16:48:22.607 00e0: 91 4f f0 52 09 b4 f8 c2 10 91 b9 b8 f8 c8 10 89 .O.R............
    16:48:22.607 00f0: 08 02 d3 b4 f8 8c 10 79 b9 .......y.
    16:48:22.638 Incoming Dump:
    16:48:22.638 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.638 --
    16:48:22.638 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.638 Parameters:
    16:48:22.638 | Number HCI commands : 0x01
    16:48:22.638 | Command Opcode : 0xff05
    16:48:22.638 | Status : 0x00 (Success)
    16:48:22.638 --
    16:48:22.638 --
    16:48:22.638 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.638 | Address : 0x200022b0
    16:48:22.638 | Size : 0xf0
    16:48:22.638 | Values : "5A:45:2B:DA:94:F8:C6:10:C1:F3:00:11:0E:91:41:B9:27:E0:C0:46:E1:08:01:20:01:29:1F:D0:02:29:1D:D1:0E:95:E1:8A:04:9A:C1:F3:84:21:02:F8:10:1C:21:8B:C1:F3:84:21:02:F8:08:1C:94:F8:2C:10:11:75:94:F8:2D:10:51:75:07:99:41:F0:10:01:07:91:14:E0:C0:46:1C:A0:01:20:00:90:01:20:00:00:01:20:4F:F0:00:01:0E:91:E1:8A:04:9A:C1:F3:44:11:02:F8:10:1C:21:8B:C1:F3:44:11:02:F8:08:1C:DF:F8:C8:A1:9A:F8:04:17:B9:76:05:99:39:B9:94:F9:67:10:59:45:A4:BF:94:F8:66:10:8A:F8:04:17:F9:7F:31:B9:94:F9:86:20:00:21:5A:45:A8:BF:29:1C:B9:77:B9:7F:04:9A:61:18:09:7C:02:F8:04:1C:A3:4A:B9:7F:82:F8:A4:10:B4:F8:0A:11:49:08:24:BF:A0:49:0D:70:00:99:21:B1:0A:99:00:29:08:BF:31:21:03:D0:09:99:09:01:41:F0:01:01:03:9A:A2:F8:54:10:01:F0:82:FD:4F:EA:60:02:0F:90:02:F1"
    16:48:22.638 --
    16:48:22.638 Outgoing Dump:
    16:48:22.638 0000: 01 05 ff f5 b0 22 00 20 f0 5a 45 2b da 94 f8 c6 .....". .ZE+....
    16:48:22.638 0010: 10 c1 f3 00 11 0e 91 41 b9 27 e0 c0 46 e1 08 01 .......A.'..F...
    16:48:22.638 0020: 20 01 29 1f d0 02 29 1d d1 0e 95 e1 8a 04 9a c1 .)...).........
    16:48:22.638 0030: f3 84 21 02 f8 10 1c 21 8b c1 f3 84 21 02 f8 08 ..!....!....!...
    16:48:22.638 0040: 1c 94 f8 2c 10 11 75 94 f8 2d 10 51 75 07 99 41 ...,..u..-.Qu..A
    16:48:22.638 0050: f0 10 01 07 91 14 e0 c0 46 1c a0 01 20 00 90 01 ........F... ...
    16:48:22.638 0060: 20 00 00 01 20 4f f0 00 01 0e 91 e1 8a 04 9a c1 ... O..........
    16:48:22.638 0070: f3 44 11 02 f8 10 1c 21 8b c1 f3 44 11 02 f8 08 .D.....!...D....
    16:48:22.638 0080: 1c df f8 c8 a1 9a f8 04 17 b9 76 05 99 39 b9 94 ..........v..9..
    16:48:22.638 0090: f9 67 10 59 45 a4 bf 94 f8 66 10 8a f8 04 17 f9 .g.YE....f......
    16:48:22.638 00a0: 7f 31 b9 94 f9 86 20 00 21 5a 45 a8 bf 29 1c b9 .1.... .!ZE..)..
    16:48:22.638 00b0: 77 b9 7f 04 9a 61 18 09 7c 02 f8 04 1c a3 4a b9 w....a..|.....J.
    16:48:22.638 00c0: 7f 82 f8 a4 10 b4 f8 0a 11 49 08 24 bf a0 49 0d .........I.$..I.
    16:48:22.638 00d0: 70 00 99 21 b1 0a 99 00 29 08 bf 31 21 03 d0 09 p..!....)..1!...
    16:48:22.638 00e0: 99 09 01 41 f0 01 01 03 9a a2 f8 54 10 01 f0 82 ...A.......T....
    16:48:22.638 00f0: fd 4f ea 60 02 0f 90 02 f1 .O.`.....
    16:48:22.669 Incoming Dump:
    16:48:22.669 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.669 --
    16:48:22.669 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.669 Parameters:
    16:48:22.669 | Number HCI commands : 0x01
    16:48:22.669 | Command Opcode : 0xff05
    16:48:22.669 | Status : 0x00 (Success)
    16:48:22.669 --
    16:48:22.669 --
    16:48:22.669 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.669 | Address : 0x200023a0
    16:48:22.669 | Size : 0xf0
    16:48:22.669 | Values : "C0:41:DD:F8:20:C0:B1:FB:F0:F1:4F:EA:81:01:CC:F8:90:10:49:46:4F:EA:01:43:03:EB:41:43:1A:44:92:FB:F0:F1:AC:F8:1C:10:97:F8:52:10:21:44:91:F8:D8:20:04:99:81:F8:3C:25:9E:4A:4F:F0:00:01:11:70:11:46:0D:74:9C:49:0D:70:B4:F8:CA:22:3B:68:4F:EA:42:11:01:EB:82:11:4F:F4:7A:72:B3:FB:F2:FC:B4:F8:CC:32:00:FB:03:F0:02:FB:00:F2:B2:FB:FC:F0:4F:F4:C0:42:A0:EB:01:01:B1:FB:F2:F0:80:B2:03:B2:03:FB:02:F2:A1:EB:02:01:8A:B2:31:8D:21:F0:E0:01:41:EA:40:11:31:85:4F:F0:60:01:B2:FB:F1:F1:8A:B2:B4:F8:EC:12:08:44:8A:F8:34:27:B4:F8:EA:12:8A:F8:08:07:BA:F8:38:07:20:F0:1E:00:40:EA:41:00:AA:F8:38:07:06:98:60:B1:0E:98:04:EB:40:01:B1:F8:72:00:C0:F3:04:20:B0:70:B1:F8:72:00:00:F0:1F:00:30:70:A0:8F:81:08:1A:D2:40:08:1B:D3:06:98:C8:B1:00:98:50:B1:0A:98"
    16:48:22.669 --
    16:48:22.669 Outgoing Dump:
    16:48:22.669 0000: 01 05 ff f5 a0 23 00 20 f0 c0 41 dd f8 20 c0 b1 .....#. ..A.. ..
    16:48:22.669 0010: fb f0 f1 4f ea 81 01 cc f8 90 10 49 46 4f ea 01 ...O.......IFO..
    16:48:22.669 0020: 43 03 eb 41 43 1a 44 92 fb f0 f1 ac f8 1c 10 97 C..AC.D.........
    16:48:22.669 0030: f8 52 10 21 44 91 f8 d8 20 04 99 81 f8 3c 25 9e .R.!D... ....<%.
    16:48:22.669 0040: 4a 4f f0 00 01 11 70 11 46 0d 74 9c 49 0d 70 b4 JO....p.F.t.I.p.
    16:48:22.669 0050: f8 ca 22 3b 68 4f ea 42 11 01 eb 82 11 4f f4 7a ..";hO.B.....O.z
    16:48:22.669 0060: 72 b3 fb f2 fc b4 f8 cc 32 00 fb 03 f0 02 fb 00 r.......2.......
    16:48:22.669 0070: f2 b2 fb fc f0 4f f4 c0 42 a0 eb 01 01 b1 fb f2 .....O..B.......
    16:48:22.669 0080: f0 80 b2 03 b2 03 fb 02 f2 a1 eb 02 01 8a b2 31 ...............1
    16:48:22.669 0090: 8d 21 f0 e0 01 41 ea 40 11 31 85 4f f0 60 01 b2 .!...A.@.1.O.`..
    16:48:22.669 00a0: fb f1 f1 8a b2 b4 f8 ec 12 08 44 8a f8 34 27 b4 ..........D..4'.
    16:48:22.669 00b0: f8 ea 12 8a f8 08 07 ba f8 38 07 20 f0 1e 00 40 .........8. ...@
    16:48:22.669 00c0: ea 41 00 aa f8 38 07 06 98 60 b1 0e 98 04 eb 40 .A...8...`.....@
    16:48:22.669 00d0: 01 b1 f8 72 00 c0 f3 04 20 b0 70 b1 f8 72 00 00 ...r.... .p..r..
    16:48:22.669 00e0: f0 1f 00 30 70 a0 8f 81 08 1a d2 40 08 1b d3 06 ...0p......@....
    16:48:22.669 00f0: 98 c8 b1 00 98 50 b1 0a 98 .....P...
    16:48:22.701 Incoming Dump:
    16:48:22.701 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.701 --
    16:48:22.701 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.701 Parameters:
    16:48:22.701 | Number HCI commands : 0x01
    16:48:22.701 | Command Opcode : 0xff05
    16:48:22.701 | Status : 0x00 (Success)
    16:48:22.701 --
    16:48:22.701 --
    16:48:22.701 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.701 | Address : 0x20002490
    16:48:22.701 | Size : 0xf0
    16:48:22.701 | Values : "01:28:07:D0:97:F8:22:00:20:B1:B8:F8:98:00:C0:B2:69:30:03:E0:B8:F8:98:00:C0:B2:87:30:80:B2:C1:B2:00:20:01:F0:CF:FB:02:E0:01:F0:6E:FB:E0:87:A0:88:40:08:1E:D3:05:98:E0:B9:85:48:90:F8:60:12:99:B1:D8:F8:B0:00:FD:76:80:09:06:D3:82:48:01:78:41:F2:11:12:29:20:01:F0:5E:FB:00:98:00:28:40:F0:63:81:5D:E1:C0:46:00:F1:01:20:4F:F0:00:01:01:70:80:F8:20:10:07:98:03:99:A1:F8:8C:00:06:98:80:B1:97:F8:22:00:10:B1:00:98:01:28:0A:D0:01:F0:3D:FB:02:46:B2:F5:D2:7F:04:DA:6F:48:01:78:57:20:01:F0:3A:FB:01:98:80:7A:48:B1:40:1E:29:46:81:40:02:98:02:88:0A:43:02:80:02:88:8A:43:02:80:14:20:01:F0:B8:FB:87:F8:48:50:0E:98:00:28:14:BF:03:20:02:20:03:21:FE:F7:DA:FA:DF:F8:90:92:BA:F8:00:00:40:F4:E0:60:AA:F8:00:00:89:F8:3C:50:0F:98:0E:9A:00:21:FD:F7"
    16:48:22.701 --
    16:48:22.701 Outgoing Dump:
    16:48:22.701 0000: 01 05 ff f5 90 24 00 20 f0 01 28 07 d0 97 f8 22 .....$. ..(...."
    16:48:22.701 0010: 00 20 b1 b8 f8 98 00 c0 b2 69 30 03 e0 b8 f8 98 . .......i0.....
    16:48:22.701 0020: 00 c0 b2 87 30 80 b2 c1 b2 00 20 01 f0 cf fb 02 ....0..... .....
    16:48:22.701 0030: e0 01 f0 6e fb e0 87 a0 88 40 08 1e d3 05 98 e0 ...n.....@......
    16:48:22.701 0040: b9 85 48 90 f8 60 12 99 b1 d8 f8 b0 00 fd 76 80 ..H..`........v.
    16:48:22.701 0050: 09 06 d3 82 48 01 78 41 f2 11 12 29 20 01 f0 5e ....H.xA...) ..^
    16:48:22.701 0060: fb 00 98 00 28 40 f0 63 81 5d e1 c0 46 00 f1 01 ....(@.c.]..F...
    16:48:22.701 0070: 20 4f f0 00 01 01 70 80 f8 20 10 07 98 03 99 a1 O....p.. ......
    16:48:22.701 0080: f8 8c 00 06 98 80 b1 97 f8 22 00 10 b1 00 98 01 ........."......
    16:48:22.701 0090: 28 0a d0 01 f0 3d fb 02 46 b2 f5 d2 7f 04 da 6f (....=..F......o
    16:48:22.701 00a0: 48 01 78 57 20 01 f0 3a fb 01 98 80 7a 48 b1 40 H.xW ..:....zH.@
    16:48:22.701 00b0: 1e 29 46 81 40 02 98 02 88 0a 43 02 80 02 88 8a .)F.@.....C.....
    16:48:22.701 00c0: 43 02 80 14 20 01 f0 b8 fb 87 f8 48 50 0e 98 00 C... ......HP...
    16:48:22.701 00d0: 28 14 bf 03 20 02 20 03 21 fe f7 da fa df f8 90 (... . .!.......
    16:48:22.701 00e0: 92 ba f8 00 00 40 f4 e0 60 aa f8 00 00 89 f8 3c .....@..`......<
    16:48:22.701 00f0: 50 0f 98 0e 9a 00 21 fd f7 P.....!..
    16:48:22.732 Incoming Dump:
    16:48:22.732 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.732 --
    16:48:22.732 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.732 Parameters:
    16:48:22.732 | Number HCI commands : 0x01
    16:48:22.732 | Command Opcode : 0xff05
    16:48:22.732 | Status : 0x00 (Success)
    16:48:22.732 --
    16:48:22.732 --
    16:48:22.732 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.732 | Address : 0x20002580
    16:48:22.732 | Size : 0xf0
    16:48:22.732 | Values : "7B:FF:00:98:38:B1:0A:98:28:B9:F0:8F:20:F4:00:60:40:F4:80:60:F0:87:30:8D:20:F4:00:70:40:F4:80:60:30:85:B4:F8:88:00:00:28:40:F0:12:81:08:20:01:F0:37:FB:A0:88:00:09:0C:D3:B8:F8:9A:00:C0:F3:05:20:38:B1:03:98:90:F8:94:00:C0:F3:01:10:00:28:40:F0:E1:80:04:99:00:20:C8:86:08:98:06:49:80:F8:78:50:11:20:8A:F8:00:07:0D:70:00:BF:00:BF:00:BF:00:BF:00:BF:03:E0:80:22:36:22:40:05:34:22:94:F9:1E:10:59:45:A8:BF:10:20:04:99:81:F8:F4:00:04:20:01:F0:57:FB:08:98:85:86:41:F2:08:00:01:F0:01:FB:00:20:89:F8:00:00:0A:48:80:F8:BC:53:03:98:4F:F0:02:08:80:F8:00:80:60:8C:01:F0:43:FB:94:F8:46:20:00:20:04:21:FE:F7:29:FB:01:98:40:78:98:B1:04:E0:C0:46:90:08:34:22:14:07:3F:22:A0:F1:01:00:29:46:01:FA:00:F1:02:98:02:88:41:EA:02:02:02:80:02:88:22:EA"
    16:48:22.732 --
    16:48:22.732 Outgoing Dump:
    16:48:22.732 0000: 01 05 ff f5 80 25 00 20 f0 7b ff 00 98 38 b1 0a .....%. .{...8..
    16:48:22.732 0010: 98 28 b9 f0 8f 20 f4 00 60 40 f4 80 60 f0 87 30 .(... ..`@..`..0
    16:48:22.732 0020: 8d 20 f4 00 70 40 f4 80 60 30 85 b4 f8 88 00 00 . ..p@..`0......
    16:48:22.732 0030: 28 40 f0 12 81 08 20 01 f0 37 fb a0 88 00 09 0c (@.... ..7......
    16:48:22.732 0040: d3 b8 f8 9a 00 c0 f3 05 20 38 b1 03 98 90 f8 94 ........ 8......
    16:48:22.732 0050: 00 c0 f3 01 10 00 28 40 f0 e1 80 04 99 00 20 c8 ......(@...... .
    16:48:22.732 0060: 86 08 98 06 49 80 f8 78 50 11 20 8a f8 00 07 0d ....I..xP. .....
    16:48:22.732 0070: 70 00 bf 00 bf 00 bf 00 bf 00 bf 03 e0 80 22 36 p............."6
    16:48:22.732 0080: 22 40 05 34 22 94 f9 1e 10 59 45 a8 bf 10 20 04 "@.4"....YE... .
    16:48:22.732 0090: 99 81 f8 f4 00 04 20 01 f0 57 fb 08 98 85 86 41 ...... ..W.....A
    16:48:22.732 00a0: f2 08 00 01 f0 01 fb 00 20 89 f8 00 00 0a 48 80 ........ .....H.
    16:48:22.732 00b0: f8 bc 53 03 98 4f f0 02 08 80 f8 00 80 60 8c 01 ..S..O.......`..
    16:48:22.732 00c0: f0 43 fb 94 f8 46 20 00 20 04 21 fe f7 29 fb 01 .C...F . .!..)..
    16:48:22.732 00d0: 98 40 78 98 b1 04 e0 c0 46 90 08 34 22 14 07 3f .@x.....F..4"..?
    16:48:22.732 00e0: 22 a0 f1 01 00 29 46 01 fa 00 f1 02 98 02 88 41 "....)F........A
    16:48:22.732 00f0: ea 02 02 02 80 02 88 22 ea .......".
    16:48:22.763 Incoming Dump:
    16:48:22.763 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.763 --
    16:48:22.763 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.763 Parameters:
    16:48:22.763 | Number HCI commands : 0x01
    16:48:22.763 | Command Opcode : 0xff05
    16:48:22.763 | Status : 0x00 (Success)
    16:48:22.763 --
    16:48:22.763 --
    16:48:22.763 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.763 | Address : 0x20002670
    16:48:22.763 | Size : 0xf0
    16:48:22.763 | Values : "01:02:02:80:03:98:A0:F8:16:80:06:98:B0:B1:01:F0:8B:FA:02:46:97:F8:22:00:20:B1:00:98:01:28:08:BF:78:20:00:D0:87:20:41:00:01:EB:C0:01:88:B2:90:42:04:DA:10:48:01:78:58:20:01:F0:7C:FA:0A:20:01:F0:B7:FA:09:98:02:28:02:DA:03:99:03:20:08:70:B4:F8:0A:01:40:08:10:D2:09:98:02:28:80:F2:91:80:0A:20:01:F0:A6:FA:80:08:C0:F0:8B:80:FD:F7:DD:FC:87:E0:28:11:28:22:E1:08:01:20:30:8D:6F:F3:9F:30:30:85:28:46:01:F0:33:FA:30:8D:B4:F8:DA:12:6F:F3:9F:30:40:F4:80:40:30:85:70:8D:20:F0:0F:00:01:43:3C:48:71:85:80:F8:20:50:80:F8:24:50:0B:98:01:F0:1E:FA:B4:F8:DC:12:70:8D:20:F0:0F:00:01:43:71:85:0C:98:01:F0:14:FA:B4:F8:DE:12:70:8D:20:F0:0F:00:01:43:71:85:0D:98:01:F0:BC:FA:09:98:02:28:09:DA:0A:20:01:F0:66:FA:05:46:A8:08:01:D3:FD:F7:9D:FC:28:09"
    16:48:22.763 --
    16:48:22.763 Outgoing Dump:
    16:48:22.763 0000: 01 05 ff f5 70 26 00 20 f0 01 02 02 80 03 98 a0 ....p&. ........
    16:48:22.763 0010: f8 16 80 06 98 b0 b1 01 f0 8b fa 02 46 97 f8 22 ............F.."
    16:48:22.763 0020: 00 20 b1 00 98 01 28 08 bf 78 20 00 d0 87 20 41 . ....(..x ... A
    16:48:22.763 0030: 00 01 eb c0 01 88 b2 90 42 04 da 10 48 01 78 58 ........B...H.xX
    16:48:22.763 0040: 20 01 f0 7c fa 0a 20 01 f0 b7 fa 09 98 02 28 02 ..|.. .......(.
    16:48:22.763 0050: da 03 99 03 20 08 70 b4 f8 0a 01 40 08 10 d2 09 .... .p....@....
    16:48:22.763 0060: 98 02 28 80 f2 91 80 0a 20 01 f0 a6 fa 80 08 c0 ..(..... .......
    16:48:22.763 0070: f0 8b 80 fd f7 dd fc 87 e0 28 11 28 22 e1 08 01 .........(.("...
    16:48:22.763 0080: 20 30 8d 6f f3 9f 30 30 85 28 46 01 f0 33 fa 30 0.o..00.(F..3.0
    16:48:22.763 0090: 8d b4 f8 da 12 6f f3 9f 30 40 f4 80 40 30 85 70 .....o..0@..@0.p
    16:48:22.763 00a0: 8d 20 f0 0f 00 01 43 3c 48 71 85 80 f8 20 50 80 . ....C<Hq... P.
    16:48:22.763 00b0: f8 24 50 0b 98 01 f0 1e fa b4 f8 dc 12 70 8d 20 .$P..........p.
    16:48:22.763 00c0: f0 0f 00 01 43 71 85 0c 98 01 f0 14 fa b4 f8 de ....Cq..........
    16:48:22.763 00d0: 12 70 8d 20 f0 0f 00 01 43 71 85 0d 98 01 f0 bc .p. ....Cq......
    16:48:22.763 00e0: fa 09 98 02 28 09 da 0a 20 01 f0 66 fa 05 46 a8 ....(... ..f..F.
    16:48:22.763 00f0: 08 01 d3 fd f7 9d fc 28 09 .......(.
    16:48:22.795 Incoming Dump:
    16:48:22.795 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.795 --
    16:48:22.795 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.795 Parameters:
    16:48:22.795 | Number HCI commands : 0x01
    16:48:22.795 | Command Opcode : 0xff05
    16:48:22.795 | Status : 0x00 (Success)
    16:48:22.795 --
    16:48:22.795 --
    16:48:22.795 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.795 | Address : 0x20002760
    16:48:22.795 | Size : 0xf0
    16:48:22.795 | Values : "02:D2:08:20:01:F0:5C:FA:70:8D:B4:F8:E0:12:20:F0:0F:00:01:43:71:85:09:98:02:28:39:DB:B4:F8:0A:01:80:08:35:D3:03:20:01:F0:E9:F9:31:8D:1B:48:08:43:30:85:2D:E0:1B:48:FD:76:01:78:03:98:90:F8:94:00:C0:F3:01:12:59:20:01:F0:FD:F9:00:98:18:B9:03:98:80:F8:45:50:02:E0:03:98:80:F8:47:50:61:89:00:20:01:29:08:BF:28:1C:87:F8:22:00:00:F0:79:FD:0F:E0:0B:48:94:F8:46:20:03:21:80:F8:BC:53:00:20:FE:F7:5B:FA:A0:8F:80:08:03:D3:01:F0:D6:F9:A4:F8:40:00:10:B0:BD:E8:F0:8F:C0:46:24:20:3E:22:00:C0:FF:FF:90:08:34:22:E1:08:01:20:70:B5:32:48:00:68:60:4C:00:08:06:D3:20:46:22:30:02:78:00:21:53:20:01:F0:C1:F9:20:46:2C:4C:00:26:30:4D:21:78:80:F8:23:60:01:29:3F:D1:29:4A:A2:F2:51:13:1E:80:9E:70:1E:71:9E:71:B3:F8:42:10:C9:B2:A3:F8:42:10:24:49:51:4B"
    16:48:22.795 --
    16:48:22.795 Outgoing Dump:
    16:48:22.795 0000: 01 05 ff f5 60 27 00 20 f0 02 d2 08 20 01 f0 5c ....`'. .... ..\
    16:48:22.795 0010: fa 70 8d b4 f8 e0 12 20 f0 0f 00 01 43 71 85 09 .p..... ....Cq..
    16:48:22.795 0020: 98 02 28 39 db b4 f8 0a 01 80 08 35 d3 03 20 01 ..(9.......5.. .
    16:48:22.795 0030: f0 e9 f9 31 8d 1b 48 08 43 30 85 2d e0 1b 48 fd ...1..H.C0.-..H.
    16:48:22.795 0040: 76 01 78 03 98 90 f8 94 00 c0 f3 01 12 59 20 01 v.x..........Y .
    16:48:22.795 0050: f0 fd f9 00 98 18 b9 03 98 80 f8 45 50 02 e0 03 ...........EP...
    16:48:22.795 0060: 98 80 f8 47 50 61 89 00 20 01 29 08 bf 28 1c 87 ...GPa.. .)..(..
    16:48:22.795 0070: f8 22 00 00 f0 79 fd 0f e0 0b 48 94 f8 46 20 03 ."...y....H..F .
    16:48:22.795 0080: 21 80 f8 bc 53 00 20 fe f7 5b fa a0 8f 80 08 03 !...S. ..[......
    16:48:22.795 0090: d3 01 f0 d6 f9 a4 f8 40 00 10 b0 bd e8 f0 8f c0 .......@........
    16:48:22.795 00a0: 46 24 20 3e 22 00 c0 ff ff 90 08 34 22 e1 08 01 F$ >"......4"...
    16:48:22.795 00b0: 20 70 b5 32 48 00 68 60 4c 00 08 06 d3 20 46 22 p.2H.h`L.... F"
    16:48:22.795 00c0: 30 02 78 00 21 53 20 01 f0 c1 f9 20 46 2c 4c 00 0.x.!S .... F,L.
    16:48:22.795 00d0: 26 30 4d 21 78 80 f8 23 60 01 29 3f d1 29 4a a2 &0M!x..#`.)?.)J.
    16:48:22.795 00e0: f2 51 13 1e 80 9e 70 1e 71 9e 71 b3 f8 42 10 c9 .Q....p.q.q..B..
    16:48:22.795 00f0: b2 a3 f8 42 10 24 49 51 4b ...B.$IQK
    16:48:22.826 Incoming Dump:
    16:48:22.826 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.826 --
    16:48:22.826 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.826 Parameters:
    16:48:22.826 | Number HCI commands : 0x01
    16:48:22.826 | Command Opcode : 0xff05
    16:48:22.826 | Status : 0x00 (Success)
    16:48:22.826 --
    16:48:22.826 --
    16:48:22.826 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.826 | Address : 0x20002850
    16:48:22.826 | Size : 0xf0
    16:48:22.826 | Values : "0E:70:1E:81:5E:81:32:F8:93:1C:21:F0:03:01:22:F8:93:1C:81:6A:19:60:C1:6A:59:60:90:F8:3D:10:82:F8:BB:1F:90:F8:3C:10:82:F8:BC:1F:01:6B:C2:F8:CF:1F:41:6B:C2:F8:D7:1F:81:6B:C2:F8:FF:1F:01:6C:90:F8:46:00:C2:F8:D3:1F:13:49:08:80:30:46:01:F0:42:FE:28:46:A0:F1:4D:00:00:78:18:B9:0F:49:4F:F0:10:00:08:80:26:70:29:78:31:B1:49:1E:01:20:0C:4A:88:40:11:88:81:43:11:80:70:BD:01:12:49:42:08:43:C0:B2:70:47:C0:46:B0:01:01:20:E5:08:01:20:69:A1:01:20:4C:0C:34:22:B0:02:01:20:1E:40:01:20:F4:00:01:20:04:F0:0E:20:2D:E9:F0:4F:AD:F1:54:0D:04:93:05:92:06:91:07:90:40:08:C0:F0:5F:81:22:48:20:4E:01:68:B1:62:41:68:8A:4F:F1:62:79:78:86:F8:3C:10:39:78:86:F8:3D:10:79:69:31:63:F9:69:71:63:79:6C:B1:63:B9:69:DF:F8:10:B2:31:64:9B:F8:60:10:86:F8:46:10"
    16:48:22.826 --
    16:48:22.826 Outgoing Dump:
    16:48:22.826 0000: 01 05 ff f5 50 28 00 20 f0 0e 70 1e 81 5e 81 32 ....P(. ..p..^.2
    16:48:22.826 0010: f8 93 1c 21 f0 03 01 22 f8 93 1c 81 6a 19 60 c1 ...!..."....j.`.
    16:48:22.826 0020: 6a 59 60 90 f8 3d 10 82 f8 bb 1f 90 f8 3c 10 82 jY`..=.......<..
    16:48:22.826 0030: f8 bc 1f 01 6b c2 f8 cf 1f 41 6b c2 f8 d7 1f 81 ....k....Ak.....
    16:48:22.826 0040: 6b c2 f8 ff 1f 01 6c 90 f8 46 00 c2 f8 d3 1f 13 k.....l..F......
    16:48:22.826 0050: 49 08 80 30 46 01 f0 42 fe 28 46 a0 f1 4d 00 00 I..0F..B.(F..M..
    16:48:22.826 0060: 78 18 b9 0f 49 4f f0 10 00 08 80 26 70 29 78 31 x...IO.....&p)x1
    16:48:22.826 0070: b1 49 1e 01 20 0c 4a 88 40 11 88 81 43 11 80 70 .I.. .J.@...C..p
    16:48:22.826 0080: bd 01 12 49 42 08 43 c0 b2 70 47 c0 46 b0 01 01 ...IB.C..pG.F...
    16:48:22.826 0090: 20 e5 08 01 20 69 a1 01 20 4c 0c 34 22 b0 02 01 ... i.. L.4"...
    16:48:22.826 00a0: 20 1e 40 01 20 f4 00 01 20 04 f0 0e 20 2d e9 f0 .@. ... ... -..
    16:48:22.826 00b0: 4f ad f1 54 0d 04 93 05 92 06 91 07 90 40 08 c0 O..T.........@..
    16:48:22.826 00c0: f0 5f 81 22 48 20 4e 01 68 b1 62 41 68 8a 4f f1 ._."H N.h.bAh.O.
    16:48:22.826 00d0: 62 79 78 86 f8 3c 10 39 78 86 f8 3d 10 79 69 31 byx..<.9x..=.yi1
    16:48:22.826 00e0: 63 f9 69 71 63 79 6c b1 63 b9 69 df f8 10 b2 31 c.iqcyl.c.i....1
    16:48:22.826 00f0: 64 9b f8 60 10 86 f8 46 10 d..`...F.
    16:48:22.857 Incoming Dump:
    16:48:22.857 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.857 --
    16:48:22.857 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.857 Parameters:
    16:48:22.857 | Number HCI commands : 0x01
    16:48:22.857 | Command Opcode : 0xff05
    16:48:22.857 | Status : 0x00 (Success)
    16:48:22.857 --
    16:48:22.857 --
    16:48:22.857 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.857 | Address : 0x20002940
    16:48:22.857 | Size : 0xf0
    16:48:22.857 | Values : "19:21:81:70:AD:49:00:24:81:F8:20:40:0C:70:41:88:21:F4:E0:61:41:F4:00:61:41:80:C0:1E:80:46:B0:F8:05:00:20:F4:40:50:A8:F8:05:00:AC:48:AA:4D:00:88:C0:F3:C1:11:01:29:04:BF:04:20:AB:F8:60:00:4F:F0:04:09:02:29:08:D0:3C:21:08:22:18:20:3F:23:07:E0:80:08:01:20:1C:80:01:20:3D:21:07:22:15:20:40:23:88:F8:07:30:88:F8:08:20:88:F8:09:10:88:F8:0A:00:9B:48:FD:F7:35:FD:E8:64:01:20:38:70:BB:F8:D6:00:00:F0:03:00:38:75:BB:F8:D6:00:C0:F3:82:00:78:75:BB:F8:D6:00:C0:F3:42:10:B8:75:BB:F8:D6:00:C0:F3:00:20:F8:75:30:46:40:68:B8:61:02:20:3C:77:B8:77:01:21:7C:77:F9:77:87:F8:44:40:87:F8:46:90:87:F8:45:00:08:46:87:49:87:F8:47:00:4F:F4:A0:70:48:80:7C:70:88:88:20:F0:03:00:88:80:01:20:31:46:81:F8:52:00:20:46:AC:81:FE:F7:05:FB:42:F2:09:00:A8:F8"
    16:48:22.857 --
    16:48:22.857 Outgoing Dump:
    16:48:22.857 0000: 01 05 ff f5 40 29 00 20 f0 19 21 81 70 ad 49 00 ....@). ..!.p.I.
    16:48:22.857 0010: 24 81 f8 20 40 0c 70 41 88 21 f4 e0 61 41 f4 00 $.. @.pA.!..aA..
    16:48:22.857 0020: 61 41 80 c0 1e 80 46 b0 f8 05 00 20 f4 40 50 a8 aA....F.... .@P.
    16:48:22.857 0030: f8 05 00 ac 48 aa 4d 00 88 c0 f3 c1 11 01 29 04 ....H.M.......).
    16:48:22.857 0040: bf 04 20 ab f8 60 00 4f f0 04 09 02 29 08 d0 3c .. ..`.O....)..<
    16:48:22.857 0050: 21 08 22 18 20 3f 23 07 e0 80 08 01 20 1c 80 01 !.". ?#..... ...
    16:48:22.857 0060: 20 3d 21 07 22 15 20 40 23 88 f8 07 30 88 f8 08 =!.". @#...0...
    16:48:22.857 0070: 20 88 f8 09 10 88 f8 0a 00 9b 48 fd f7 35 fd e8 .........H..5..
    16:48:22.857 0080: 64 01 20 38 70 bb f8 d6 00 00 f0 03 00 38 75 bb d. 8p........8u.
    16:48:22.857 0090: f8 d6 00 c0 f3 82 00 78 75 bb f8 d6 00 c0 f3 42 .......xu......B
    16:48:22.857 00a0: 10 b8 75 bb f8 d6 00 c0 f3 00 20 f8 75 30 46 40 ..u....... .u0F@
    16:48:22.857 00b0: 68 b8 61 02 20 3c 77 b8 77 01 21 7c 77 f9 77 87 h.a. <w.w.!|w.w.
    16:48:22.857 00c0: f8 44 40 87 f8 46 90 87 f8 45 00 08 46 87 49 87 .D@..F...E..F.I.
    16:48:22.857 00d0: f8 47 00 4f f4 a0 70 48 80 7c 70 88 88 20 f0 03 .G.O..pH.|p.. ..
    16:48:22.857 00e0: 00 88 80 01 20 31 46 81 f8 52 00 20 46 ac 81 fe .... 1F..R. F...
    16:48:22.857 00f0: f7 05 fb 42 f2 09 00 a8 f8 ...B.....
    16:48:22.888 Incoming Dump:
    16:48:22.888 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.888 --
    16:48:22.888 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.888 Parameters:
    16:48:22.888 | Number HCI commands : 0x01
    16:48:22.888 | Command Opcode : 0xff05
    16:48:22.888 | Status : 0x00 (Success)
    16:48:22.888 --
    16:48:22.888 --
    16:48:22.888 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.888 | Address : 0x20002a30
    16:48:22.888 | Size : 0xf0
    16:48:22.888 | Values : "4B:01:BB:F8:AE:00:A8:80:06:98:04:9E:08:90:05:98:09:90:AB:48:4F:F0:18:09:0A:90:87:1C:45:F6:E3:50:0B:90:0D:F1:07:00:0C:90:0D:F1:0B:00:0D:90:0D:F1:03:00:0E:90:AD:F1:01:00:0F:90:40:F6:6C:10:10:90:20:46:11:90:11:98:38:B1:6C:65:FD:F7:AC:FC:10:98:22:46:01:21:FD:F7:F8:FC:AA:49:01:20:08:70:05:20:01:F0:64:F8:A7:49:E8:6F:0C:70:0F:99:01:F8:01:0F:0F:91:0E:9A:01:0A:02:F8:01:1F:0E:92:0D:9A:01:0C:02:F8:01:1F:0D:92:0C:99:00:0E:01:F8:01:0F:0C:91:9B:F8:CC:10:B5:F8:4E:00:B6:1E:4F:F0:05:0A:61:F3:1F:20:98:49:A5:F8:4E:00:01:20:81:F8:BC:06:0B:F1:CB:00:12:90:AB:48:AA:49:00:68:B0:FB:F1:F2:BB:F8:B2:00:09:FB:00:F1:BB:F8:B6:00:40:02:A0:EB:11:10:00:0C:50:43:41:01:01:EB:80:11:0B:98:B1:FB:F0:F0:80:B2:26:F8:02:0F:28:80:12:98:10:F8:01:1F:12:90"
    16:48:22.888 --
    16:48:22.888 Outgoing Dump:
    16:48:22.888 0000: 01 05 ff f5 30 2a 00 20 f0 4b 01 bb f8 ae 00 a8 ....0*. .K......
    16:48:22.888 0010: 80 06 98 04 9e 08 90 05 98 09 90 ab 48 4f f0 18 ............HO..
    16:48:22.888 0020: 09 0a 90 87 1c 45 f6 e3 50 0b 90 0d f1 07 00 0c .....E..P.......
    16:48:22.888 0030: 90 0d f1 0b 00 0d 90 0d f1 03 00 0e 90 ad f1 01 ................
    16:48:22.888 0040: 00 0f 90 40 f6 6c 10 10 90 20 46 11 90 11 98 38 ...@.l... F....8
    16:48:22.888 0050: b1 6c 65 fd f7 ac fc 10 98 22 46 01 21 fd f7 f8 .le......"F.!...
    16:48:22.888 0060: fc aa 49 01 20 08 70 05 20 01 f0 64 f8 a7 49 e8 ..I. .p. ..d..I.
    16:48:22.888 0070: 6f 0c 70 0f 99 01 f8 01 0f 0f 91 0e 9a 01 0a 02 o.p.............
    16:48:22.888 0080: f8 01 1f 0e 92 0d 9a 01 0c 02 f8 01 1f 0d 92 0c ................
    16:48:22.888 0090: 99 00 0e 01 f8 01 0f 0c 91 9b f8 cc 10 b5 f8 4e ...............N
    16:48:22.888 00a0: 00 b6 1e 4f f0 05 0a 61 f3 1f 20 98 49 a5 f8 4e ...O...a.. .I..N
    16:48:22.888 00b0: 00 01 20 81 f8 bc 06 0b f1 cb 00 12 90 ab 48 aa .. ...........H.
    16:48:22.888 00c0: 49 00 68 b0 fb f1 f2 bb f8 b2 00 09 fb 00 f1 bb I.h.............
    16:48:22.888 00d0: f8 b6 00 40 02 a0 eb 11 10 00 0c 50 43 41 01 01 ...@.......PCA..
    16:48:22.888 00e0: eb 80 11 0b 98 b1 fb f0 f0 80 b2 26 f8 02 0f 28 ...........&...(
    16:48:22.888 00f0: 80 12 98 10 f8 01 1f 12 90 .........
    16:48:22.919 Incoming Dump:
    16:48:22.919 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.919 --
    16:48:22.919 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.919 Parameters:
    16:48:22.919 | Number HCI commands : 0x01
    16:48:22.919 | Command Opcode : 0xff05
    16:48:22.919 | Status : 0x00 (Success)
    16:48:22.919 --
    16:48:22.919 --
    16:48:22.919 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.919 | Address : 0x20002b20
    16:48:22.919 | Size : 0xf0
    16:48:22.919 | Values : "B5:F8:4E:00:61:F3:1F:20:A5:F8:4E:00:01:20:88:F8:00:00:20:46:01:F0:12:F8:4F:F4:80:70:06:E0:C0:46:24:B1:01:20:50:02:01:20:A0:F1:01:00:2B:49:91:F8:A0:11:09:B9:00:28:F7:D1:B8:F8:13:20:08:99:21:F8:02:2B:08:91:09:99:B8:F8:15:20:21:F8:02:2B:09:91:0A:99:21:F8:08:4B:0A:91:3C:80:7C:80:BC:80:0B:99:08:37:09:F1:40:09:BA:F1:01:0A:01:F1:28:01:0B:91:A8:D1:10:98:14:30:80:B2:10:90:11:98:B6:1C:40:1C:04:28:11:90:FF:F4:66:AF:A5:F8:54:40:B5:F8:CA:00:40:F0:03:00:A5:F8:CA:00:0F:20:85:F8:58:00:01:20:00:F0:CC:FF:85:F8:58:40:07:98:80:08:C0:F0:81:81:7B:4D:28:78:41:28:18:BF:07:27:02:D1:0F:48:0A:30:07:78:40:F2:6E:20:01:F0:6B:F8:00:24:26:46:A2:46:B3:46:00:2F:00:F0:5B:81:02:E0:C0:46:80:03:30:22:10:97:58:46:DF:F8:C0:91:DF:F8:0C:80:6D:4D:13:94"
    16:48:22.919 --
    16:48:22.919 Outgoing Dump:
    16:48:22.919 0000: 01 05 ff f5 20 2b 00 20 f0 b5 f8 4e 00 61 f3 1f .... +. ...N.a..
    16:48:22.919 0010: 20 a5 f8 4e 00 01 20 88 f8 00 00 20 46 01 f0 12 ..N.. .... F...
    16:48:22.919 0020: f8 4f f4 80 70 06 e0 c0 46 24 b1 01 20 50 02 01 .O..p...F$.. P..
    16:48:22.919 0030: 20 a0 f1 01 00 2b 49 91 f8 a0 11 09 b9 00 28 f7 ....+I.......(.
    16:48:22.919 0040: d1 b8 f8 13 20 08 99 21 f8 02 2b 08 91 09 99 b8 .... ..!..+.....
    16:48:22.919 0050: f8 15 20 21 f8 02 2b 09 91 0a 99 21 f8 08 4b 0a .. !..+....!..K.
    16:48:22.919 0060: 91 3c 80 7c 80 bc 80 0b 99 08 37 09 f1 40 09 ba .<.|......7..@..
    16:48:22.919 0070: f1 01 0a 01 f1 28 01 0b 91 a8 d1 10 98 14 30 80 .....(........0.
    16:48:22.919 0080: b2 10 90 11 98 b6 1c 40 1c 04 28 11 90 ff f4 66 .......@..(....f
    16:48:22.919 0090: af a5 f8 54 40 b5 f8 ca 00 40 f0 03 00 a5 f8 ca ...T@....@......
    16:48:22.919 00a0: 00 0f 20 85 f8 58 00 01 20 00 f0 cc ff 85 f8 58 .. ..X.. ......X
    16:48:22.919 00b0: 40 07 98 80 08 c0 f0 81 81 7b 4d 28 78 41 28 18 @........{M(xA(.
    16:48:22.919 00c0: bf 07 27 02 d1 0f 48 0a 30 07 78 40 f2 6e 20 01 ..'...H.0.x@.n .
    16:48:22.919 00d0: f0 6b f8 00 24 26 46 a2 46 b3 46 00 2f 00 f0 5b .k..$&F.F.F./..[
    16:48:22.919 00e0: 81 02 e0 c0 46 80 03 30 22 10 97 58 46 df f8 c0 ....F..0"..XF...
    16:48:22.919 00f0: 91 df f8 0c 80 6d 4d 13 94 .....mM..
    16:48:22.951 Incoming Dump:
    16:48:22.951 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.951 --
    16:48:22.951 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.951 Parameters:
    16:48:22.951 | Number HCI commands : 0x01
    16:48:22.951 | Command Opcode : 0xff05
    16:48:22.951 | Status : 0x00 (Success)
    16:48:22.951 --
    16:48:22.951 --
    16:48:22.951 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.951 | Address : 0x20002c10
    16:48:22.951 | Size : 0xf0
    16:48:22.951 | Values : "5F:46:14:90:08:E0:C0:46:0C:A0:01:20:4C:01:01:20:00:09:3D:00:00:00:01:20:04:98:0B:90:06:98:08:90:05:98:09:90:04:20:07:90:14:98:0A:90:0D:F1:07:00:0C:90:0D:F1:0B:00:0D:90:0D:F1:03:00:0E:90:AD:F1:01:00:0F:90:0F:99:11:F8:01:0F:00:02:0F:91:A8:F8:0C:00:0E:99:11:F8:01:0F:0E:91:88:F8:0E:00:0D:99:11:F8:01:0F:0D:91:88:F8:10:00:0C:99:11:F8:01:0F:0C:91:88:F8:12:00:09:F1:CB:00:12:90:05:20:11:90:0B:98:80:1E:0B:90:08:98:80:1E:08:90:09:98:80:1E:09:90:0B:99:31:F8:02:0F:0B:91:A8:F8:00:00:12:98:10:F8:01:1F:12:90:B8:F8:4E:00:61:F3:1F:20:A8:F8:4E:00:08:99:31:F8:02:0F:08:91:A8:81:09:99:31:F8:02:0F:09:91:E8:81:3A:48:00:78:41:28:2C:D0:01:20:28:70:30:46:FF:F7:F0:FD:01:49:08:55:08:46:01:E0:50:06:01:20:24:18:50:46:FF:F7:E6:FD:60:70:58:46"
    16:48:22.951 --
    16:48:22.951 Outgoing Dump:
    16:48:22.951 0000: 01 05 ff f5 10 2c 00 20 f0 5f 46 14 90 08 e0 c0 .....,. ._F.....
    16:48:22.951 0010: 46 0c a0 01 20 4c 01 01 20 00 09 3d 00 00 00 01 F... L.. ..=....
    16:48:22.951 0020: 20 04 98 0b 90 06 98 08 90 05 98 09 90 04 20 07 ............. .
    16:48:22.951 0030: 90 14 98 0a 90 0d f1 07 00 0c 90 0d f1 0b 00 0d ................
    16:48:22.951 0040: 90 0d f1 03 00 0e 90 ad f1 01 00 0f 90 0f 99 11 ................
    16:48:22.951 0050: f8 01 0f 00 02 0f 91 a8 f8 0c 00 0e 99 11 f8 01 ................
    16:48:22.951 0060: 0f 0e 91 88 f8 0e 00 0d 99 11 f8 01 0f 0d 91 88 ................
    16:48:22.951 0070: f8 10 00 0c 99 11 f8 01 0f 0c 91 88 f8 12 00 09 ................
    16:48:22.951 0080: f1 cb 00 12 90 05 20 11 90 0b 98 80 1e 0b 90 08 ...... .........
    16:48:22.951 0090: 98 80 1e 08 90 09 98 80 1e 09 90 0b 99 31 f8 02 .............1..
    16:48:22.951 00a0: 0f 0b 91 a8 f8 00 00 12 98 10 f8 01 1f 12 90 b8 ................
    16:48:22.951 00b0: f8 4e 00 61 f3 1f 20 a8 f8 4e 00 08 99 31 f8 02 .N.a.. ..N...1..
    16:48:22.951 00c0: 0f 08 91 a8 81 09 99 31 f8 02 0f 09 91 e8 81 3a .......1.......:
    16:48:22.951 00d0: 48 00 78 41 28 2c d0 01 20 28 70 30 46 ff f7 f0 H.xA(,.. (p0F...
    16:48:22.951 00e0: fd 01 49 08 55 08 46 01 e0 50 06 01 20 24 18 50 ..I.U.F..P.. $.P
    16:48:22.951 00f0: 46 ff f7 e6 fd 60 70 58 46 F....`pXF
    16:48:22.982 Incoming Dump:
    16:48:22.982 0000: 04 0e 04 01 05 ff 00 .......
    16:48:22.982 --
    16:48:22.982 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:22.982 Parameters:
    16:48:22.982 | Number HCI commands : 0x01
    16:48:22.982 | Command Opcode : 0xff05
    16:48:22.982 | Status : 0x00 (Success)
    16:48:22.982 --
    16:48:22.982 --
    16:48:22.982 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:22.982 | Address : 0x20002d00
    16:48:22.982 | Size : 0xf0
    16:48:22.982 | Values : "FF:F7:E2:FD:A0:70:38:46:FF:F7:DE:FD:E0:70:13:99:0A:01:02:EB:81:12:0A:99:89:18:95:4A:12:78:00:2A:FB:D0:EE:8B:B5:F8:1C:A0:B5:F8:18:B0:6F:8B:8C:B2:9C:E0:C0:46:90:05:34:22:01:20:00:F0:0F:FF:01:20:28:70:00:F0:0B:FF:8A:48:00:78:00:28:FB:D0:EE:8B:B5:F8:1C:A0:B5:F8:18:B0:56:45:6F:8B:B4:BF:50:46:30:1C:BB:45:B4:BF:39:1C:59:46:88:42:B8:BF:08:1C:B9:F8:1C:11:81:42:0F:DB:B9:F8:1A:11:81:42:4D:DC:99:F8:D5:00:B9:F8:1E:41:00:F0:0F:00:09:E0:C0:46:A0:86:01:00:80:08:01:20:99:F8:D5:00:B9:F8:20:41:00:11:98:49:00:2C:81:F8:B9:0F:37:D0:14:9E:AE:81:01:20:EE:81:68:70:00:F0:D1:FE:30:46:07:E0:C0:46:E1:08:01:20:18:80:01:20:50:02:01:20:40:1C:68:49:91:F8:20:10:00:29:08:BF:5F:EA:10:21:F6:D0:A8:8A:A8:81:E8:8A:E8:81:01:20:00:F0:B8:FE:01:20:28:70"
    16:48:22.982 --
    16:48:22.982 Outgoing Dump:
    16:48:22.982 0000: 01 05 ff f5 00 2d 00 20 f0 ff f7 e2 fd a0 70 38 .....-. ......p8
    16:48:22.982 0010: 46 ff f7 de fd e0 70 13 99 0a 01 02 eb 81 12 0a F.....p.........
    16:48:22.982 0020: 99 89 18 95 4a 12 78 00 2a fb d0 ee 8b b5 f8 1c ....J.x.*.......
    16:48:22.982 0030: a0 b5 f8 18 b0 6f 8b 8c b2 9c e0 c0 46 90 05 34 .....o......F..4
    16:48:22.982 0040: 22 01 20 00 f0 0f ff 01 20 28 70 00 f0 0b ff 8a ". ..... (p.....
    16:48:22.982 0050: 48 00 78 00 28 fb d0 ee 8b b5 f8 1c a0 b5 f8 18 H.x.(...........
    16:48:22.982 0060: b0 56 45 6f 8b b4 bf 50 46 30 1c bb 45 b4 bf 39 .VEo...PF0..E..9
    16:48:22.982 0070: 1c 59 46 88 42 b8 bf 08 1c b9 f8 1c 11 81 42 0f .YF.B.........B.
    16:48:22.982 0080: db b9 f8 1a 11 81 42 4d dc 99 f8 d5 00 b9 f8 1e ......BM........
    16:48:22.982 0090: 41 00 f0 0f 00 09 e0 c0 46 a0 86 01 00 80 08 01 A.......F.......
    16:48:22.982 00a0: 20 99 f8 d5 00 b9 f8 20 41 00 11 98 49 00 2c 81 ...... A...I.,.
    16:48:22.982 00b0: f8 b9 0f 37 d0 14 9e ae 81 01 20 ee 81 68 70 00 ...7...... ..hp.
    16:48:22.982 00c0: f0 d1 fe 30 46 07 e0 c0 46 e1 08 01 20 18 80 01 ...0F...F... ...
    16:48:22.982 00d0: 20 50 02 01 20 40 1c 68 49 91 f8 20 10 00 29 08 P.. @.hI.. ..).
    16:48:22.982 00e0: bf 5f ea 10 21 f6 d0 a8 8a a8 81 e8 8a e8 81 01 ._..!...........
    16:48:22.982 00f0: 20 00 f0 b8 fe 01 20 28 70 ..... (p
    16:48:23.013 Incoming Dump:
    16:48:23.013 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.013 --
    16:48:23.013 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.013 Parameters:
    16:48:23.013 | Number HCI commands : 0x01
    16:48:23.013 | Command Opcode : 0xff05
    16:48:23.013 | Status : 0x00 (Success)
    16:48:23.013 --
    16:48:23.013 --
    16:48:23.013 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.013 | Address : 0x20002df0
    16:48:23.013 | Size : 0xf0
    16:48:23.013 | Values : "00:F0:B4:FE:5E:48:00:78:00:28:FB:D0:E8:8B:60:43:1F:FA:90:F6:A8:8B:60:43:1F:FA:90:FA:28:8B:60:43:1F:FA:90:FB:68:8B:44:43:1F:FA:94:F7:0A:98:9A:49:84:B2:60:00:09:5A:B1:42:BC:BF:97:49:0E:52:96:48:00:EB:44:00:80:1C:01:88:51:45:B8:BF:A0:F8:00:A0:41:88:59:45:B8:BF:A0:F8:02:B0:81:88:B9:42:B8:BF:87:80:6C:49:14:98:81:F8:B9:0F:00:F0:9D:FE:B9:F8:34:21:51:00:01:EB:C2:01:81:42:32:DB:0A:99:09:1D:0A:91:11:99:49:1E:11:91:7F:F4:13:AF:09:99:89:1C:09:91:08:99:89:1C:08:91:0B:99:89:1C:0B:91:07:99:49:1E:07:91:7F:F4:DE:AE:14:98:00:F0:5F:FE:13:99:49:1C:13:91:10:99:49:1E:10:91:7F:F4:BD:AE:77:48:00:78:41:28:0D:D0:30:46:FF:F7:06:FD:72:49:08:55:50:46:64:18:FF:F7:00:FD:60:70:58:46:FF:F7:FC:FC:A0:70:15:B0:BD:E8:F0:8F:F0:B5:AD:F1:78:0D:69:4D"
    16:48:23.013 --
    16:48:23.013 Outgoing Dump:
    16:48:23.013 0000: 01 05 ff f5 f0 2d 00 20 f0 00 f0 b4 fe 5e 48 00 .....-. .....^H.
    16:48:23.013 0010: 78 00 28 fb d0 e8 8b 60 43 1f fa 90 f6 a8 8b 60 x.(....`C......`
    16:48:23.013 0020: 43 1f fa 90 fa 28 8b 60 43 1f fa 90 fb 68 8b 44 C....(.`C....h.D
    16:48:23.013 0030: 43 1f fa 94 f7 0a 98 9a 49 84 b2 60 00 09 5a b1 C.......I..`..Z.
    16:48:23.013 0040: 42 bc bf 97 49 0e 52 96 48 00 eb 44 00 80 1c 01 B...I.R.H..D....
    16:48:23.013 0050: 88 51 45 b8 bf a0 f8 00 a0 41 88 59 45 b8 bf a0 .QE......A.YE...
    16:48:23.013 0060: f8 02 b0 81 88 b9 42 b8 bf 87 80 6c 49 14 98 81 ......B....lI...
    16:48:23.013 0070: f8 b9 0f 00 f0 9d fe b9 f8 34 21 51 00 01 eb c2 .........4!Q....
    16:48:23.013 0080: 01 81 42 32 db 0a 99 09 1d 0a 91 11 99 49 1e 11 ..B2.........I..
    16:48:23.013 0090: 91 7f f4 13 af 09 99 89 1c 09 91 08 99 89 1c 08 ................
    16:48:23.013 00a0: 91 0b 99 89 1c 0b 91 07 99 49 1e 07 91 7f f4 de .........I......
    16:48:23.013 00b0: ae 14 98 00 f0 5f fe 13 99 49 1c 13 91 10 99 49 ....._...I.....I
    16:48:23.013 00c0: 1e 10 91 7f f4 bd ae 77 48 00 78 41 28 0d d0 30 .......wH.xA(..0
    16:48:23.013 00d0: 46 ff f7 06 fd 72 49 08 55 50 46 64 18 ff f7 00 F....rI.UPFd....
    16:48:23.013 00e0: fd 60 70 58 46 ff f7 fc fc a0 70 15 b0 bd e8 f0 .`pXF.....p.....
    16:48:23.013 00f0: 8f f0 b5 ad f1 78 0d 69 4d .....x.iM
    16:48:23.044 Incoming Dump:
    16:48:23.044 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.044 --
    16:48:23.044 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.044 Parameters:
    16:48:23.044 | Number HCI commands : 0x01
    16:48:23.044 | Command Opcode : 0xff05
    16:48:23.044 | Status : 0x00 (Success)
    16:48:23.044 --
    16:48:23.044 --
    16:48:23.044 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.044 | Address : 0x20002ee0
    16:48:23.044 | Size : 0xf0
    16:48:23.044 | Values : "6B:4E:95:F8:4D:00:4F:F0:01:04:F4:71:30:B1:69:49:40:1E:0A:88:04:FA:00:F0:10:43:08:80:66:4F:38:68:C0:0F:04:D3:B2:79:00:21:4C:20:00:F0:4B:FE:00:20:28:70:62:48:14:AB:0A:AA:69:46:04:70:03:20:FF:F7:E9:FC:31:78:39:B1:38:68:40:0F:06:D3:2A:78:43:20:00:F0:38:FE:01:E0:FF:20:28:70:1E:B0:F0:BD:00:B5:55:48:00:68:00:08:06:D3:51:48:80:1D:02:78:00:21:55:20:00:F0:27:FE:51:48:01:78:02:29:03:D1:00:21:01:70:48:4A:11:70:4E:49:10:20:08:80:00:BD:C0:46:00:05:30:22:F0:B5:44:4A:11:88:53:88:8B:42:D8:BF:19:1C:94:88:53:88:A2:F8:A0:10:9C:42:B4:BF:1E:1C:26:1C:15:88:11:46:AE:42:03:DC:9C:42:A8:BF:23:1C:1D:46:A2:F8:A2:50:4C:27:A4:32:0B:88:4D:88:9D:42:B4:BF:9C:46:AC:46:8C:88:CE:88:A6:42:B4:BF:A6:46:B6:46:E6:45:04:DC:A6:42:A8:BF:34:1C:25:46:01:E0"
    16:48:23.044 --
    16:48:23.044 Outgoing Dump:
    16:48:23.044 0000: 01 05 ff f5 e0 2e 00 20 f0 6b 4e 95 f8 4d 00 4f ....... .kN..M.O
    16:48:23.044 0010: f0 01 04 f4 71 30 b1 69 49 40 1e 0a 88 04 fa 00 ....q0.iI@......
    16:48:23.044 0020: f0 10 43 08 80 66 4f 38 68 c0 0f 04 d3 b2 79 00 ..C..fO8h.....y.
    16:48:23.044 0030: 21 4c 20 00 f0 4b fe 00 20 28 70 62 48 14 ab 0a !L ..K.. (pbH...
    16:48:23.044 0040: aa 69 46 04 70 03 20 ff f7 e9 fc 31 78 39 b1 38 .iF.p. ....1x9.8
    16:48:23.044 0050: 68 40 0f 06 d3 2a 78 43 20 00 f0 38 fe 01 e0 ff h@...*xC ..8....
    16:48:23.044 0060: 20 28 70 1e b0 f0 bd 00 b5 55 48 00 68 00 08 06 (p......UH.h...
    16:48:23.044 0070: d3 51 48 80 1d 02 78 00 21 55 20 00 f0 27 fe 51 .QH...x.!U ..'.Q
    16:48:23.044 0080: 48 01 78 02 29 03 d1 00 21 01 70 48 4a 11 70 4e H.x.)...!.pHJ.pN
    16:48:23.044 0090: 49 10 20 08 80 00 bd c0 46 00 05 30 22 f0 b5 44 I. .....F..0"..D
    16:48:23.044 00a0: 4a 11 88 53 88 8b 42 d8 bf 19 1c 94 88 53 88 a2 J..S..B......S..
    16:48:23.044 00b0: f8 a0 10 9c 42 b4 bf 1e 1c 26 1c 15 88 11 46 ae ....B....&....F.
    16:48:23.044 00c0: 42 03 dc 9c 42 a8 bf 23 1c 1d 46 a2 f8 a2 50 4c B...B..#..F...PL
    16:48:23.044 00d0: 27 a4 32 0b 88 4d 88 9d 42 b4 bf 9c 46 ac 46 8c '.2..M..B...F.F.
    16:48:23.044 00e0: 88 ce 88 a6 42 b4 bf a6 46 b6 46 e6 45 04 dc a6 ....B...F.F.E...
    16:48:23.044 00f0: 42 a8 bf 34 1c 25 46 01 e0 B..4.%F..
    16:48:23.076 Incoming Dump:
    16:48:23.076 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.076 --
    16:48:23.076 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.076 Parameters:
    16:48:23.076 | Number HCI commands : 0x01
    16:48:23.076 | Command Opcode : 0xff05
    16:48:23.076 | Status : 0x00 (Success)
    16:48:23.076 --
    16:48:23.076 --
    16:48:23.076 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.076 | Address : 0x20002fd0
    16:48:23.076 | Size : 0xf0
    16:48:23.076 | Values : "9D:42:00:DB:2B:46:13:80:7F:1E:01:F1:02:01:02:F1:02:02:E2:D1:08:88:4B:88:83:42:B4:BF:04:1C:1C:1C:89:88:A1:42:03:DD:83:42:A8:BF:18:1C:01:46:11:80:F0:BD:C0:46:6C:A1:01:20:F0:B5:AD:F1:A0:0D:22:48:00:68:C0:0F:05:D3:1A:48:02:78:00:21:4E:20:00:F0:C1:FD:20:4D:02:20:1D:4C:29:88:20:70:48:B2:00:28:0B:DC:00:02:40:42:80:B2:00:F0:52:FE:41:F6:6A:01:41:43:1F:FA:A1:F6:29:88:01:E0:4F:F6:FF:76:49:0A:12:D3:15:4B:4F:21:00:22:4F:F6:FF:77:6D:46:25:F8:02:7B:49:1E:03:F8:01:2B:F9:D1:68:46:FF:F7:82:FF:31:46:68:46:00:F0:F1:FB:28:B0:00:20:20:70:F0:BD:A2:08:01:20:A7:00:01:20:50:06:01:20:E1:08:01:20:9C:08:01:20:04:F0:0E:20:B0:01:01:20:E5:08:01:20:1E:40:01:20:0C:00:01:20:58:00:01:20:2D:E9:F0:47:87:4C:99:4D:DF:F8:24:92:DF:F8:1C:A2:DF:F8:20:82"
    16:48:23.076 --
    16:48:23.076 Outgoing Dump:
    16:48:23.076 0000: 01 05 ff f5 d0 2f 00 20 f0 9d 42 00 db 2b 46 13 ...../. ..B..+F.
    16:48:23.076 0010: 80 7f 1e 01 f1 02 01 02 f1 02 02 e2 d1 08 88 4b ...............K
    16:48:23.076 0020: 88 83 42 b4 bf 04 1c 1c 1c 89 88 a1 42 03 dd 83 ..B.........B...
    16:48:23.076 0030: 42 a8 bf 18 1c 01 46 11 80 f0 bd c0 46 6c a1 01 B.....F.....Fl..
    16:48:23.076 0040: 20 f0 b5 ad f1 a0 0d 22 48 00 68 c0 0f 05 d3 1a ......"H.h.....
    16:48:23.076 0050: 48 02 78 00 21 4e 20 00 f0 c1 fd 20 4d 02 20 1d H.x.!N .... M. .
    16:48:23.076 0060: 4c 29 88 20 70 48 b2 00 28 0b dc 00 02 40 42 80 L). pH..(....@B.
    16:48:23.076 0070: b2 00 f0 52 fe 41 f6 6a 01 41 43 1f fa a1 f6 29 ...R.A.j.AC....)
    16:48:23.076 0080: 88 01 e0 4f f6 ff 76 49 0a 12 d3 15 4b 4f 21 00 ...O..vI....KO!.
    16:48:23.076 0090: 22 4f f6 ff 77 6d 46 25 f8 02 7b 49 1e 03 f8 01 "O..wmF%..{I....
    16:48:23.076 00a0: 2b f9 d1 68 46 ff f7 82 ff 31 46 68 46 00 f0 f1 +..hF....1FhF...
    16:48:23.076 00b0: fb 28 b0 00 20 20 70 f0 bd a2 08 01 20 a7 00 01 .(.. p..... ...
    16:48:23.076 00c0: 20 50 06 01 20 e1 08 01 20 9c 08 01 20 04 f0 0e P.. ... ... ...
    16:48:23.076 00d0: 20 b0 01 01 20 e5 08 01 20 1e 40 01 20 0c 00 01 ... ... .@. ...
    16:48:23.076 00e0: 20 58 00 01 20 2d e9 f0 47 87 4c 99 4d df f8 24 X.. -..G.L.M..$
    16:48:23.076 00f0: 92 df f8 1c a2 df f8 20 82 ....... .
    16:48:23.107 Incoming Dump:
    16:48:23.107 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.107 --
    16:48:23.107 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.107 Parameters:
    16:48:23.107 | Number HCI commands : 0x01
    16:48:23.107 | Command Opcode : 0xff05
    16:48:23.107 | Status : 0x00 (Success)
    16:48:23.107 --
    16:48:23.107 --
    16:48:23.107 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.107 | Address : 0x200030c0
    16:48:23.107 | Size : 0xf0
    16:48:23.107 | Values : "20:78:00:28:00:F0:B1:80:21:78:82:4F:30:29:19:DC:30:29:5A:D0:20:29:0C:DC:20:29:64:D0:10:39:6B:D0:49:1E:6C:D0:C9:1E:67:D0:49:1E:63:D0:49:1E:5E:D0:68:E0:21:39:53:D0:C9:1E:4F:D0:49:1E:4B:D0:49:1E:46:D0:5F:E0:51:29:0A:DC:51:29:2D:D0:31:39:39:D0:0F:39:0D:D0:49:1E:2D:D0:0F:39:28:D0:52:E0:70:39:1F:D0:49:1E:1A:D0:0F:39:15:D0:49:1E:0F:D0:49:E0:38:78:41:28:08:D1:52:46:10:78:28:B9:4E:46:30:78:10:B9:4F:F0:81:00:10:70:FF:F7:5E:FB:3A:E0:FF:F7:5B:FF:80:20:11:E0:FF:F7:F2:FE:33:E0:01:F0:E3:F8:30:E0:01:F0:93:F8:2D:E0:01:F0:06:FB:2A:E0:01:F0:25:FE:27:E0:FF:F7:B0:FE:40:20:52:46:10:70:00:20:28:70:1F:E0:00:F0:CC:FF:1C:E0:00:F0:B7:FE:19:E0:01:F0:80:FE:16:E0:01:20:02:E0:01:20:04:E0:00:20:FD:F7:48:FF:0E:E0:00:20:01:F0:BC:F9:0A:E0:01:F0"
    16:48:23.107 --
    16:48:23.107 Outgoing Dump:
    16:48:23.107 0000: 01 05 ff f5 c0 30 00 20 f0 20 78 00 28 00 f0 b1 .....0. . x.(...
    16:48:23.107 0010: 80 21 78 82 4f 30 29 19 dc 30 29 5a d0 20 29 0c .!x.O0)..0)Z. ).
    16:48:23.107 0020: dc 20 29 64 d0 10 39 6b d0 49 1e 6c d0 c9 1e 67 . )d..9k.I.l...g
    16:48:23.107 0030: d0 49 1e 63 d0 49 1e 5e d0 68 e0 21 39 53 d0 c9 .I.c.I.^.h.!9S..
    16:48:23.107 0040: 1e 4f d0 49 1e 4b d0 49 1e 46 d0 5f e0 51 29 0a .O.I.K.I.F._.Q).
    16:48:23.107 0050: dc 51 29 2d d0 31 39 39 d0 0f 39 0d d0 49 1e 2d .Q)-.199..9..I.-
    16:48:23.107 0060: d0 0f 39 28 d0 52 e0 70 39 1f d0 49 1e 1a d0 0f ..9(.R.p9..I....
    16:48:23.107 0070: 39 15 d0 49 1e 0f d0 49 e0 38 78 41 28 08 d1 52 9..I...I.8xA(..R
    16:48:23.107 0080: 46 10 78 28 b9 4e 46 30 78 10 b9 4f f0 81 00 10 F.x(.NF0x..O....
    16:48:23.107 0090: 70 ff f7 5e fb 3a e0 ff f7 5b ff 80 20 11 e0 ff p..^.:...[.. ...
    16:48:23.107 00a0: f7 f2 fe 33 e0 01 f0 e3 f8 30 e0 01 f0 93 f8 2d ...3.....0.....-
    16:48:23.107 00b0: e0 01 f0 06 fb 2a e0 01 f0 25 fe 27 e0 ff f7 b0 .....*...%.'....
    16:48:23.107 00c0: fe 40 20 52 46 10 70 00 20 28 70 1f e0 00 f0 cc .@ RF.p. (p.....
    16:48:23.107 00d0: ff 1c e0 00 f0 b7 fe 19 e0 01 f0 80 fe 16 e0 01 ................
    16:48:23.107 00e0: 20 02 e0 01 20 04 e0 00 20 fd f7 48 ff 0e e0 00 ... ... ..H....
    16:48:23.107 00f0: 20 01 f0 bc f9 0a e0 01 f0 ........
    16:48:23.138 Incoming Dump:
    16:48:23.138 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.138 --
    16:48:23.138 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.138 Parameters:
    16:48:23.138 | Number HCI commands : 0x01
    16:48:23.138 | Command Opcode : 0xff05
    16:48:23.138 | Status : 0x00 (Success)
    16:48:23.138 --
    16:48:23.138 --
    16:48:23.138 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.138 | Address : 0x200031b0
    16:48:23.138 | Size : 0xf0
    16:48:23.138 | Values : "6E:FE:07:E0:01:20:03:E0:01:F0:E8:FC:02:E0:00:20:FE:F7:B8:FE:91:49:40:46:80:31:08:60:20:78:00:26:38:70:26:70:28:78:32:46:10:F0:03:0F:18:BF:01:22:28:46:00:2A:52:46:15:D1:03:78:70:2B:11:D0:13:78:3B:B1:03:78:17:78:03:F0:04:03:07:F0:04:07:BB:42:07:D0:07:78:96:4B:FF:08:38:BF:9B:1E:4F:F0:01:07:1F:70:06:70:13:78:43:B1:13:78:03:70:00:78:20:70:4F:F0:15:00:16:70:C1:F8:80:0D:4E:46:06:F1:06:06:76:4F:DF:F8:4C:92:96:F8:27:00:70:B1:48:46:8C:38:B0:F8:8C:10:49:08:08:D3:00:78:C7:F8:00:80:00:F0:D4:FC:4F:F4:00:40:00:F0:E3:FC:C7:F8:80:80:28:78:D0:B9:48:46:00:88:40:08:0D:D2:94:48:00:78:00:F0:0F:00:0F:28:10:D0:70:20:28:70:28:78:00:21:20:70:54:46:08:46:03:E0:71:20:28:70:29:78:00:20:21:70:30:70:15:20:C7:F8:00:0E:C7:F8:00:80:BD:E8:F0:87"
    16:48:23.138 --
    16:48:23.138 Outgoing Dump:
    16:48:23.138 0000: 01 05 ff f5 b0 31 00 20 f0 6e fe 07 e0 01 20 03 .....1. .n.... .
    16:48:23.138 0010: e0 01 f0 e8 fc 02 e0 00 20 fe f7 b8 fe 91 49 40 ........ .....I@
    16:48:23.138 0020: 46 80 31 08 60 20 78 00 26 38 70 26 70 28 78 32 F.1.` x.&8p&p(x2
    16:48:23.138 0030: 46 10 f0 03 0f 18 bf 01 22 28 46 00 2a 52 46 15 F......."(F.*RF.
    16:48:23.138 0040: d1 03 78 70 2b 11 d0 13 78 3b b1 03 78 17 78 03 ..xp+...x;..x.x.
    16:48:23.138 0050: f0 04 03 07 f0 04 07 bb 42 07 d0 07 78 96 4b ff ........B...x.K.
    16:48:23.138 0060: 08 38 bf 9b 1e 4f f0 01 07 1f 70 06 70 13 78 43 .8...O....p.p.xC
    16:48:23.138 0070: b1 13 78 03 70 00 78 20 70 4f f0 15 00 16 70 c1 ..x.p.x pO....p.
    16:48:23.138 0080: f8 80 0d 4e 46 06 f1 06 06 76 4f df f8 4c 92 96 ...NF....vO..L..
    16:48:23.138 0090: f8 27 00 70 b1 48 46 8c 38 b0 f8 8c 10 49 08 08 .'.p.HF.8....I..
    16:48:23.138 00a0: d3 00 78 c7 f8 00 80 00 f0 d4 fc 4f f4 00 40 00 ..x........O..@.
    16:48:23.138 00b0: f0 e3 fc c7 f8 80 80 28 78 d0 b9 48 46 00 88 40 .......(x..HF..@
    16:48:23.138 00c0: 08 0d d2 94 48 00 78 00 f0 0f 00 0f 28 10 d0 70 ....H.x.....(..p
    16:48:23.138 00d0: 20 28 70 28 78 00 21 20 70 54 46 08 46 03 e0 71 (p(x.! pTF.F..q
    16:48:23.138 00e0: 20 28 70 29 78 00 20 21 70 30 70 15 20 c7 f8 00 (p)x. !p0p. ...
    16:48:23.138 00f0: 0e c7 f8 00 80 bd e8 f0 87 .........
    16:48:23.169 Incoming Dump:
    16:48:23.169 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.169 --
    16:48:23.169 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.169 Parameters:
    16:48:23.169 | Number HCI commands : 0x01
    16:48:23.169 | Command Opcode : 0xff05
    16:48:23.169 | Status : 0x00 (Success)
    16:48:23.169 --
    16:48:23.169 --
    16:48:23.169 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.169 | Address : 0x200032a0
    16:48:23.169 | Size : 0xf0
    16:48:23.169 | Values : "0F:48:85:49:08:60:86:49:01:20:08:80:1A:49:08:78:00:F0:FC:00:08:70:08:78:05:49:08:70:01:F0:D2:BD:15:48:05:49:00:78:20:F0:03:00:08:70:70:47:C0:46:E3:08:01:20:E4:08:01:20:E2:08:01:20:9C:08:01:20:0C:C0:28:00:F0:B5:0C:4C:8B:4D:06:46:06:F0:03:00:01:28:1E:D1:20:78:10:F0:03:0F:16:D1:29:46:01:20:08:31:01:F8:07:0C:88:88:0A:88:82:42:06:D4:0B:88:02:46:18:46:03:E0:C0:46:E1:08:01:20:0A:88:80:1A:80:B2:06:28:B8:BF:05:20:08:80:01:20:28:70:00:20:28:70:96:48:00:68:80:0F:04:D3:22:78:31:46:48:20:00:F0:30:FC:21:78:73:4F:76:48:00:29:48:D0:01:78:91:4A:94:4B:99:B9:21:78:01:F0:FC:01:21:70:21:78:01:70:00:20:39:46:25:78:08:70:B5:42:3D:D0:1E:70:23:78:70:2B:38:D0:12:88:01:2A:35:D1:17:E0:21:78:11:F0:03:0F:15:D1:20:78:B0:42:2E:D0:18:78:48:B1"
    16:48:23.169 --
    16:48:23.169 Outgoing Dump:
    16:48:23.169 0000: 01 05 ff f5 a0 32 00 20 f0 0f 48 85 49 08 60 86 .....2. ..H.I.`.
    16:48:23.169 0010: 49 01 20 08 80 1a 49 08 78 00 f0 fc 00 08 70 08 I. ...I.x.....p.
    16:48:23.169 0020: 78 05 49 08 70 01 f0 d2 bd 15 48 05 49 00 78 20 x.I.p.....H.I.x
    16:48:23.169 0030: f0 03 00 08 70 70 47 c0 46 e3 08 01 20 e4 08 01 ....ppG.F... ...
    16:48:23.169 0040: 20 e2 08 01 20 9c 08 01 20 0c c0 28 00 f0 b5 0c ... ... ..(....
    16:48:23.169 0050: 4c 8b 4d 06 46 06 f0 03 00 01 28 1e d1 20 78 10 L.M.F.....(.. x.
    16:48:23.169 0060: f0 03 0f 16 d1 29 46 01 20 08 31 01 f8 07 0c 88 .....)F. .1.....
    16:48:23.169 0070: 88 0a 88 82 42 06 d4 0b 88 02 46 18 46 03 e0 c0 ....B.....F.F...
    16:48:23.169 0080: 46 e1 08 01 20 0a 88 80 1a 80 b2 06 28 b8 bf 05 F... .......(...
    16:48:23.169 0090: 20 08 80 01 20 28 70 00 20 28 70 96 48 00 68 80 ... (p. (p.H.h.
    16:48:23.169 00a0: 0f 04 d3 22 78 31 46 48 20 00 f0 30 fc 21 78 73 ..."x1FH ..0.!xs
    16:48:23.169 00b0: 4f 76 48 00 29 48 d0 01 78 91 4a 94 4b 99 b9 21 OvH.)H..x.J.K..!
    16:48:23.169 00c0: 78 01 f0 fc 01 21 70 21 78 01 70 00 20 39 46 25 x....!p!x.p. 9F%
    16:48:23.169 00d0: 78 08 70 b5 42 3d d0 1e 70 23 78 70 2b 38 d0 12 x.p.B=..p#xp+8..
    16:48:23.169 00e0: 88 01 2a 35 d1 17 e0 21 78 11 f0 03 0f 15 d1 20 ..*5...!x......
    16:48:23.169 00f0: 78 b0 42 2e d0 18 78 48 b1 x.B...xH.
    16:48:23.201 Incoming Dump:
    16:48:23.201 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.201 --
    16:48:23.201 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.201 Parameters:
    16:48:23.201 | Number HCI commands : 0x01
    16:48:23.201 | Command Opcode : 0xff05
    16:48:23.201 | Status : 0x00 (Success)
    16:48:23.201 --
    16:48:23.201 --
    16:48:23.201 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.201 | Address : 0x20003390
    16:48:23.201 | Size : 0xf0
    16:48:23.201 | Values : "18:78:18:35:C0:F3:80:01:00:29:4F:F0:01:00:0C:BF:28:70:A8:70:11:88:1E:70:00:20:01:29:1C:D1:01:20:1A:E0:21:78:01:F0:FC:01:21:70:21:78:01:70:58:48:00:21:24:78:41:71:B4:42:07:D0:12:88:1E:70:0B:46:01:2A:08:BF:01:23:01:70:43:71:FF:F7:61:FF:F0:BD:26:70:21:78:01:70:00:20:38:70:4C:49:15:20:08:60:F0:BD:4B:48:2E:30:72:49:00:78:00:01:10:38:08:70:45:48:14:30:00:78:FF:F7:6D:BF:C0:46:00:E1:00:E0:10:B5:2B:48:4F:F0:00:01:01:80:43:49:4F:F0:20:02:81:F8:15:23:67:4A:4F:F0:0E:03:53:71:3C:4B:1B:78:4F:F0:FF:04:14:70:03:B9:54:70:02:22:C1:F8:14:2C:98:4A:5F:4C:0A:60:15:22:C1:F8:00:2E:06:22:01:21:B0:F8:DC:30:01:80:1B:09:28:BF:22:70:30:BF:F7:E7:4E:40:01:20:00:B5:FD:F7:ED:F8:FC:F7:7A:FE:04:48:00:88:40:08:02:D3:91:49:71:20:08:70:00:BD:C0:46"
    16:48:23.201 --
    16:48:23.201 Outgoing Dump:
    16:48:23.201 0000: 01 05 ff f5 90 33 00 20 f0 18 78 18 35 c0 f3 80 .....3. ..x.5...
    16:48:23.201 0010: 01 00 29 4f f0 01 00 0c bf 28 70 a8 70 11 88 1e ..)O.....(p.p...
    16:48:23.201 0020: 70 00 20 01 29 1c d1 01 20 1a e0 21 78 01 f0 fc p. .)... ..!x...
    16:48:23.201 0030: 01 21 70 21 78 01 70 58 48 00 21 24 78 41 71 b4 .!p!x.pXH.!$xAq.
    16:48:23.201 0040: 42 07 d0 12 88 1e 70 0b 46 01 2a 08 bf 01 23 01 B.....p.F.*...#.
    16:48:23.201 0050: 70 43 71 ff f7 61 ff f0 bd 26 70 21 78 01 70 00 pCq..a...&p!x.p.
    16:48:23.201 0060: 20 38 70 4c 49 15 20 08 60 f0 bd 4b 48 2e 30 72 8pLI. .`..KH.0r
    16:48:23.201 0070: 49 00 78 00 01 10 38 08 70 45 48 14 30 00 78 ff I.x...8.pEH.0.x.
    16:48:23.201 0080: f7 6d bf c0 46 00 e1 00 e0 10 b5 2b 48 4f f0 00 .m..F......+HO..
    16:48:23.201 0090: 01 01 80 43 49 4f f0 20 02 81 f8 15 23 67 4a 4f ...CIO. ....#gJO
    16:48:23.201 00a0: f0 0e 03 53 71 3c 4b 1b 78 4f f0 ff 04 14 70 03 ...Sq<K.xO....p.
    16:48:23.201 00b0: b9 54 70 02 22 c1 f8 14 2c 98 4a 5f 4c 0a 60 15 .Tp."...,.J_L.`.
    16:48:23.201 00c0: 22 c1 f8 00 2e 06 22 01 21 b0 f8 dc 30 01 80 1b ".....".!...0...
    16:48:23.201 00d0: 09 28 bf 22 70 30 bf f7 e7 4e 40 01 20 00 b5 fd .(."p0...N@. ...
    16:48:23.201 00e0: f7 ed f8 fc f7 7a fe 04 48 00 88 40 08 02 d3 91 .....z..H..@....
    16:48:23.201 00f0: 49 71 20 08 70 00 bd c0 46 Iq .p...F
    16:48:23.232 Incoming Dump:
    16:48:23.232 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.232 --
    16:48:23.232 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.232 Parameters:
    16:48:23.232 | Number HCI commands : 0x01
    16:48:23.232 | Command Opcode : 0xff05
    16:48:23.232 | Status : 0x00 (Success)
    16:48:23.232 --
    16:48:23.232 --
    16:48:23.232 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.232 | Address : 0x20003480
    16:48:23.232 | Size : 0xf0
    16:48:23.232 | Values : "2C:03:01:20:F0:B5:8E:4E:8E:4C:75:42:A0:1B:05:F0:03:05:85:42:0F:D0:27:68:24:1D:20:68:3A:46:24:1D:21:46:01:F0:3D:FC:3C:19:60:42:00:F0:03:00:04:19:A0:1B:85:42:EF:D1:F0:BD:80:E1:00:E0:08:B0:01:20:50:02:01:20:30:B5:16:4D:3E:4C:3D:49:95:F8:2E:00:00:01:3C:3C:10:38:08:70:94:F8:39:00:80:08:18:D3:79:48:01:78:31:B1:49:1E:01:20:9B:4A:88:40:11:88:81:43:11:80:25:48:00:68:40:0A:06:D3:6F:48:01:78:41:F2:11:12:2C:20:00:F0:4D:FB:00:20:20:70:28:70:A0:70:30:BD:A2:08:01:20:34:40:01:20:00:EF:00:E0:9D:08:01:20:E3:08:01:20:00:E1:00:E0:2D:E9:F0:4F:96:4F:24:4E:22:49:97:F8:30:00:60:4D:DF:F8:58:B0:DF:F8:14:92:00:01:3C:3E:10:38:08:70:96:F8:38:80:5F:EA:98:00:38:D3:5C:48:4F:F0:01:04:01:78:BC:70:31:B1:48:46:49:1E:02:88:04:FA:01:F1:11:43:01:80"
    16:48:23.232 --
    16:48:23.232 Outgoing Dump:
    16:48:23.232 0000: 01 05 ff f5 80 34 00 20 f0 2c 03 01 20 f0 b5 8e .....4. .,.. ...
    16:48:23.232 0010: 4e 8e 4c 75 42 a0 1b 05 f0 03 05 85 42 0f d0 27 N.LuB.......B..'
    16:48:23.232 0020: 68 24 1d 20 68 3a 46 24 1d 21 46 01 f0 3d fc 3c h$. h:F$.!F..=.<
    16:48:23.232 0030: 19 60 42 00 f0 03 00 04 19 a0 1b 85 42 ef d1 f0 .`B.........B...
    16:48:23.232 0040: bd 80 e1 00 e0 08 b0 01 20 50 02 01 20 30 b5 16 ........ P.. 0..
    16:48:23.232 0050: 4d 3e 4c 3d 49 95 f8 2e 00 00 01 3c 3c 10 38 08 M>L=I......<<.8.
    16:48:23.232 0060: 70 94 f8 39 00 80 08 18 d3 79 48 01 78 31 b1 49 p..9.....yH.x1.I
    16:48:23.232 0070: 1e 01 20 9b 4a 88 40 11 88 81 43 11 80 25 48 00 .. .J.@...C..%H.
    16:48:23.232 0080: 68 40 0a 06 d3 6f 48 01 78 41 f2 11 12 2c 20 00 h@...oH.xA..., .
    16:48:23.232 0090: f0 4d fb 00 20 20 70 28 70 a0 70 30 bd a2 08 01 .M.. p(p.p0....
    16:48:23.232 00a0: 20 34 40 01 20 00 ef 00 e0 9d 08 01 20 e3 08 01 4@. ....... ...
    16:48:23.232 00b0: 20 00 e1 00 e0 2d e9 f0 4f 96 4f 24 4e 22 49 97 ....-..O.O$N"I.
    16:48:23.232 00c0: f8 30 00 60 4d df f8 58 b0 df f8 14 92 00 01 3c .0.`M..X.......<
    16:48:23.232 00d0: 3e 10 38 08 70 96 f8 38 80 5f ea 98 00 38 d3 5c >.8.p..8._...8.\
    16:48:23.232 00e0: 48 4f f0 01 04 01 78 bc 70 31 b1 48 46 49 1e 02 HO....x.p1.HFI..
    16:48:23.232 00f0: 88 04 fa 01 f1 11 43 01 80 ......C..
    16:48:23.263 Incoming Dump:
    16:48:23.263 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.263 --
    16:48:23.263 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.263 Parameters:
    16:48:23.263 | Number HCI commands : 0x01
    16:48:23.263 | Command Opcode : 0xff05
    16:48:23.263 | Status : 0x00 (Success)
    16:48:23.263 --
    16:48:23.279 --
    16:48:23.279 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.279 Parameters:
    16:48:23.279 | Address : 0x20003570
    16:48:23.279 | Size : 0xf0
    16:48:23.279 | Values : "06:48:00:68:00:0A:05:D3:29:78:41:F2:11:12:2B:20:00:F0:10:FB:28:78:21:28:08:D0:01:E0:B0:01:01:20:28:78:25:28:18:D1:01:E0:5A:02:01:20:7E:49:28:78:02:E0:C0:46:E2:08:01:20:08:70:58:46:00:88:00:21:01:28:08:BF:21:1C:F9:71:FF:F7:72:FE:04:E0:C0:46:02:F1:01:20:89:40:01:20:DF:F8:C4:A1:5F:EA:D8:00:2D:D3:50:46:00:78:4F:F0:01:04:48:B1:40:1E:21:46:81:40:48:46:02:88:0A:43:02:80:02:88:8A:43:02:80:68:48:00:68:C0:08:05:D3:29:78:41:F2:11:12:25:20:00:F0:D0:FA:28:78:3C:70:11:28:02:D0:28:78:15:28:0D:D1:28:78:11:28:14:BF:B4:70:34:70:58:46:00:88:00:21:01:28:08:BF:21:1C:F9:71:FF:F7:39:FE:5F:EA:18:10:35:D3:50:46:00:F1:01:00:00:78:4F:F0:01:04:48:B1:40:1E:21:46:81:40:48:46:02:88:0A:43:02:80:02:88:8A:43:02:80:4F:48:00:68:80:08:05:D3:29:78"
    16:48:23.279 --
    16:48:23.279 Outgoing Dump:
    16:48:23.279 0000: 01 05 ff f5 70 35 00 20 f0 06 48 00 68 00 0a 05 ....p5. ..H.h...
    16:48:23.279 0010: d3 29 78 41 f2 11 12 2b 20 00 f0 10 fb 28 78 21 .)xA...+ ....(x!
    16:48:23.279 0020: 28 08 d0 01 e0 b0 01 01 20 28 78 25 28 18 d1 01 (....... (x%(...
    16:48:23.279 0030: e0 5a 02 01 20 7e 49 28 78 02 e0 c0 46 e2 08 01 .Z.. ~I(x...F...
    16:48:23.279 0040: 20 08 70 58 46 00 88 00 21 01 28 08 bf 21 1c f9 .pXF...!.(..!..
    16:48:23.279 0050: 71 ff f7 72 fe 04 e0 c0 46 02 f1 01 20 89 40 01 q..r....F... .@.
    16:48:23.279 0060: 20 df f8 c4 a1 5f ea d8 00 2d d3 50 46 00 78 4f ...._...-.PF.xO
    16:48:23.279 0070: f0 01 04 48 b1 40 1e 21 46 81 40 48 46 02 88 0a ...H.@.!F.@HF...
    16:48:23.279 0080: 43 02 80 02 88 8a 43 02 80 68 48 00 68 c0 08 05 C.....C..hH.h...
    16:48:23.279 0090: d3 29 78 41 f2 11 12 25 20 00 f0 d0 fa 28 78 3c .)xA...% ....(x<
    16:48:23.279 00a0: 70 11 28 02 d0 28 78 15 28 0d d1 28 78 11 28 14 p.(..(x.(..(x.(.
    16:48:23.279 00b0: bf b4 70 34 70 58 46 00 88 00 21 01 28 08 bf 21 ..p4pXF...!.(..!
    16:48:23.279 00c0: 1c f9 71 ff f7 39 fe 5f ea 18 10 35 d3 50 46 00 ..q..9._...5.PF.
    16:48:23.279 00d0: f1 01 00 00 78 4f f0 01 04 48 b1 40 1e 21 46 81 ....xO...H.@.!F.
    16:48:23.279 00e0: 40 48 46 02 88 0a 43 02 80 02 88 8a 43 02 80 4f @HF...C.....C..O
    16:48:23.279 00f0: 48 00 68 80 08 05 d3 29 78 H.h....)x
    16:48:23.310 Incoming Dump:
    16:48:23.310 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.310 --
    16:48:23.310 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.310 Parameters:
    16:48:23.310 | Number HCI commands : 0x01
    16:48:23.310 | Command Opcode : 0xff05
    16:48:23.310 | Status : 0x00 (Success)
    16:48:23.310 --
    16:48:23.310 --
    16:48:23.310 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.310 | Address : 0x20003660
    16:48:23.310 | Size : 0xf0
    16:48:23.310 | Values : "41:F2:11:12:26:20:00:F0:9D:FA:28:78:7C:70:21:28:08:D0:28:78:25:28:05:D0:28:78:31:28:02:D0:28:78:41:28:0D:D1:28:78:21:28:14:BF:B4:70:34:70:58:46:00:88:00:21:01:28:08:BF:21:1C:F9:71:FF:F7:00:FE:BD:E8:F0:8F:0C:C0:28:00:37:48:3D:49:00:78:00:01:10:38:08:70:39:48:00:78:FF:F7:14:BE:E1:08:01:20:79:50:00:00:9C:4E:00:00:FA:00:01:20:70:B5:2E:48:33:49:00:78:4F:EA:00:10:A0:F1:10:00:08:70:2F:48:A0:F1:38:00:06:88:2F:48:01:78:49:B1:49:1E:01:20:19:4A:88:40:11:88:01:43:11:80:11:88:81:43:11:80:24:4C:29:4D:70:08:08:D3:20:68:00:0B:05:D3:29:78:41:F2:11:12:2F:20:00:F0:45:FA:B0:08:08:D3:20:68:40:0B:05:D3:29:78:41:F2:11:12:30:20:00:F0:3A:FA:F0:08:0A:D3:20:68:80:0B:05:D3:29:78:41:F2:11:12:31:20:00:F0:2F:FA:FC:F7:7F:FD:30:09:0E:D3:20:68"
    16:48:23.310 --
    16:48:23.310 Outgoing Dump:
    16:48:23.310 0000: 01 05 ff f5 60 36 00 20 f0 41 f2 11 12 26 20 00 ....`6. .A...& .
    16:48:23.310 0010: f0 9d fa 28 78 7c 70 21 28 08 d0 28 78 25 28 05 ...(x|p!(..(x%(.
    16:48:23.310 0020: d0 28 78 31 28 02 d0 28 78 41 28 0d d1 28 78 21 .(x1(..(xA(..(x!
    16:48:23.310 0030: 28 14 bf b4 70 34 70 58 46 00 88 00 21 01 28 08 (...p4pXF...!.(.
    16:48:23.310 0040: bf 21 1c f9 71 ff f7 00 fe bd e8 f0 8f 0c c0 28 .!..q..........(
    16:48:23.310 0050: 00 37 48 3d 49 00 78 00 01 10 38 08 70 39 48 00 .7H=I.x...8.p9H.
    16:48:23.310 0060: 78 ff f7 14 be e1 08 01 20 79 50 00 00 9c 4e 00 x....... yP...N.
    16:48:23.310 0070: 00 fa 00 01 20 70 b5 2e 48 33 49 00 78 4f ea 00 .... p..H3I.xO..
    16:48:23.310 0080: 10 a0 f1 10 00 08 70 2f 48 a0 f1 38 00 06 88 2f ......p/H..8.../
    16:48:23.310 0090: 48 01 78 49 b1 49 1e 01 20 19 4a 88 40 11 88 01 H.xI.I.. .J.@...
    16:48:23.310 00a0: 43 11 80 11 88 81 43 11 80 24 4c 29 4d 70 08 08 C.....C..$L)Mp..
    16:48:23.310 00b0: d3 20 68 00 0b 05 d3 29 78 41 f2 11 12 2f 20 00 . h....)xA.../ .
    16:48:23.310 00c0: f0 45 fa b0 08 08 d3 20 68 40 0b 05 d3 29 78 41 .E..... h@...)xA
    16:48:23.310 00d0: f2 11 12 30 20 00 f0 3a fa f0 08 0a d3 20 68 80 ...0 ..:..... h.
    16:48:23.310 00e0: 0b 05 d3 29 78 41 f2 11 12 31 20 00 f0 2f fa fc ...)xA...1 ../..
    16:48:23.310 00f0: f7 7f fd 30 09 0e d3 20 68 ...0... h
    16:48:23.341 Incoming Dump:
    16:48:23.341 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.341 --
    16:48:23.341 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.341 Parameters:
    16:48:23.341 | Number HCI commands : 0x01
    16:48:23.341 | Command Opcode : 0xff05
    16:48:23.341 | Status : 0x00 (Success)
    16:48:23.341 --
    16:48:23.341 --
    16:48:23.341 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.341 | Address : 0x20003750
    16:48:23.341 | Size : 0xf0
    16:48:23.341 | Values : "C0:0B:09:D3:02:E0:C0:46:04:F0:0E:20:29:78:41:F2:11:12:32:20:00:F0:1E:FA:FC:F7:A1:FD:70:09:0A:D3:20:68:00:0C:05:D3:29:78:41:F2:11:12:33:20:00:F0:11:FA:04:F0:33:FC:70:BD:CB:08:01:20:9B:08:01:20:F8:00:01:20:B0:01:01:20:E2:08:01:20:44:40:01:20:02:F1:01:20:FB:00:01:20:E1:08:01:20:2D:E9:F0:4F:09:AF:A4:4C:B4:F8:22:61:B4:F8:24:41:02:FB:06:42:02:F5:80:72:4F:EA:22:38:9F:4A:3D:78:12:88:8C:46:01:46:42:45:A8:BF:90:46:5E:00:9C:4C:A5:4A:4F:F0:00:0E:9D:42:34:44:1A:44:34:DB:A3:4F:ED:1A:76:18:A4:1E:F1:46:4F:F0:02:0A:4F:F0:03:0B:6D:1C:B6:1E:36:F8:02:1F:34:F8:02:3F:19:40:88:45:1B:DA:39:78:59:43:08:31:BC:EB:21:1F:13:DC:79:78:59:43:08:31:BC:EB:21:1F:0A:DC:B9:78:4B:43:08:33:BC:EB:23:1F:DA:BF:04:21:11:70:82:F8:00:B0:04:E0:82:F8:00:A0"
    16:48:23.341 --
    16:48:23.341 Outgoing Dump:
    16:48:23.341 0000: 01 05 ff f5 50 37 00 20 f0 c0 0b 09 d3 02 e0 c0 ....P7. ........
    16:48:23.341 0010: 46 04 f0 0e 20 29 78 41 f2 11 12 32 20 00 f0 1e F... )xA...2 ...
    16:48:23.341 0020: fa fc f7 a1 fd 70 09 0a d3 20 68 00 0c 05 d3 29 .....p... h....)
    16:48:23.341 0030: 78 41 f2 11 12 33 20 00 f0 11 fa 04 f0 33 fc 70 xA...3 ......3.p
    16:48:23.341 0040: bd cb 08 01 20 9b 08 01 20 f8 00 01 20 b0 01 01 .... ... ... ...
    16:48:23.341 0050: 20 e2 08 01 20 44 40 01 20 02 f1 01 20 fb 00 01 ... D@. ... ...
    16:48:23.341 0060: 20 e1 08 01 20 2d e9 f0 4f 09 af a4 4c b4 f8 22 ... -..O...L.."
    16:48:23.341 0070: 61 b4 f8 24 41 02 fb 06 42 02 f5 80 72 4f ea 22 a..$A...B...rO."
    16:48:23.341 0080: 38 9f 4a 3d 78 12 88 8c 46 01 46 42 45 a8 bf 90 8.J=x...F.FBE...
    16:48:23.341 0090: 46 5e 00 9c 4c a5 4a 4f f0 00 0e 9d 42 34 44 1a F^..L.JO....B4D.
    16:48:23.341 00a0: 44 34 db a3 4f ed 1a 76 18 a4 1e f1 46 4f f0 02 D4..O..v....FO..
    16:48:23.341 00b0: 0a 4f f0 03 0b 6d 1c b6 1e 36 f8 02 1f 34 f8 02 .O...m...6...4..
    16:48:23.341 00c0: 3f 19 40 88 45 1b da 39 78 59 43 08 31 bc eb 21 ?.@.E..9xYC.1..!
    16:48:23.341 00d0: 1f 13 dc 79 78 59 43 08 31 bc eb 21 1f 0a dc b9 ...yxYC.1..!....
    16:48:23.341 00e0: 78 4b 43 08 33 bc eb 23 1f da bf 04 21 11 70 82 xKC.3..#....!.p.
    16:48:23.341 00f0: f8 00 b0 04 e0 82 f8 00 a0 .........
    16:48:23.373 Incoming Dump:
    16:48:23.373 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.373 --
    16:48:23.373 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.373 Parameters:
    16:48:23.373 | Number HCI commands : 0x01
    16:48:23.373 | Command Opcode : 0xff05
    16:48:23.373 | Status : 0x00 (Success)
    16:48:23.373 --
    16:48:23.373 --
    16:48:23.373 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.373 | Address : 0x20003840
    16:48:23.373 | Size : 0xf0
    16:48:23.373 | Values : "01:E0:82:F8:00:90:11:78:71:45:A8:BF:8E:46:52:1C:6D:1E:D5:D1:70:46:BD:E8:F0:8F:2D:E9:F0:4F:AD:F1:48:0D:86:4B:05:91:00:25:01:46:77:4C:06:91:59:78:AC:46:07:91:1A:78:21:80:02:F0:0F:02:61:46:08:95:E6:46:09:95:01:26:0A:96:9B:46:0B:95:0B:E0:64:1E:A2:F1:01:02:40:F0:37:81:0A:9A:52:1C:0A:92:9B:F8:00:20:02:F0:0F:02:0A:9B:9A:42:C0:F0:38:81:65:4A:66:4C:B2:F8:26:91:B2:F8:28:A1:09:9A:A0:34:02:2A:04:DB:08:9A:60:4B:92:B2:07:92:1A:80:06:9A:DD:F8:2C:80:4F:26:A5:1E:92:1E:35:F8:02:7F:32:F8:02:3F:3B:40:43:45:A8:BF:98:46:76:1E:F5:D1:08:FB:09:A2:02:F5:00:62:12:13:08:92:07:9B:93:42:24:BF:07:9A:08:92:A4:1E:51:4A:0C:94:92:1E:0D:92:06:9A:0E:92:0B:9C:A1:46:0F:94:0D:9A:32:F8:02:3F:0D:92:0C:9A:32:F8:02:5F:AB:42:0C:92:B4:BF:2E:1C:1E:1C:0E:9A"
    16:48:23.373 --
    16:48:23.373 Outgoing Dump:
    16:48:23.373 0000: 01 05 ff f5 40 38 00 20 f0 01 e0 82 f8 00 90 11 ....@8. ........
    16:48:23.373 0010: 78 71 45 a8 bf 8e 46 52 1c 6d 1e d5 d1 70 46 bd xqE...FR.m...pF.
    16:48:23.373 0020: e8 f0 8f 2d e9 f0 4f ad f1 48 0d 86 4b 05 91 00 ...-..O..H..K...
    16:48:23.373 0030: 25 01 46 77 4c 06 91 59 78 ac 46 07 91 1a 78 21 %.FwL..Yx.F...x!
    16:48:23.373 0040: 80 02 f0 0f 02 61 46 08 95 e6 46 09 95 01 26 0a .....aF...F...&.
    16:48:23.373 0050: 96 9b 46 0b 95 0b e0 64 1e a2 f1 01 02 40 f0 37 ..F....d.....@.7
    16:48:23.373 0060: 81 0a 9a 52 1c 0a 92 9b f8 00 20 02 f0 0f 02 0a ...R...... .....
    16:48:23.373 0070: 9b 9a 42 c0 f0 38 81 65 4a 66 4c b2 f8 26 91 b2 ..B..8.eJfL..&..
    16:48:23.373 0080: f8 28 a1 09 9a a0 34 02 2a 04 db 08 9a 60 4b 92 .(....4.*....`K.
    16:48:23.373 0090: b2 07 92 1a 80 06 9a dd f8 2c 80 4f 26 a5 1e 92 .........,.O&...
    16:48:23.373 00a0: 1e 35 f8 02 7f 32 f8 02 3f 3b 40 43 45 a8 bf 98 .5...2..?;@CE...
    16:48:23.373 00b0: 46 76 1e f5 d1 08 fb 09 a2 02 f5 00 62 12 13 08 Fv..........b...
    16:48:23.373 00c0: 92 07 9b 93 42 24 bf 07 9a 08 92 a4 1e 51 4a 0c ....B$.......QJ.
    16:48:23.373 00d0: 94 92 1e 0d 92 06 9a 0e 92 0b 9c a1 46 0f 94 0d ............F...
    16:48:23.373 00e0: 9a 32 f8 02 3f 0d 92 0c 9a 32 f8 02 5f ab 42 0c .2..?....2.._.B.
    16:48:23.373 00f0: 92 b4 bf 2e 1c 1e 1c 0e 9a .........
    16:48:23.404 Incoming Dump:
    16:48:23.404 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.404 --
    16:48:23.404 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.404 Parameters:
    16:48:23.404 | Number HCI commands : 0x01
    16:48:23.404 | Command Opcode : 0xff05
    16:48:23.404 | Status : 0x00 (Success)
    16:48:23.404 --
    16:48:23.404 --
    16:48:23.404 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.404 | Address : 0x20003930
    16:48:23.404 | Size : 0xf0
    16:48:23.404 | Values : "08:9F:12:88:16:40:B7:42:84:BF:0C:F1:01:06:5F:FA:86:FC:03:D8:DD:F8:2C:C0:49:1C:C9:B2:BE:F1:00:0F:08:BF:01:29:03:D0:BE:F1:01:0F:0A:D0:C1:E0:0F:9E:DD:F8:2C:C0:4F:F0:01:0E:5F:FA:86:F9:E0:46:CD:F8:40:C0:9B:F8:03:70:9B:F8:00:60:8F:42:4F:EA:26:16:03:D1:61:44:DD:F8:2C:C0:C9:B2:DD:F8:40:A0:9A:45:DC:BF:13:40:10:93:2A:40:42:45:A8:BF:1F:FA:82:F8:66:45:03:D0:0F:9A:4E:2A:40:F0:9B:80:0F:9A:9B:F8:02:50:8F:42:A2:EB:0C:02:D6:B2:1E:DD:00:29:73:D0:06:98:05:99:10:9A:8D:F8:00:60:4B:46:FF:F7:EE:FE:1D:49:11:90:09:88:10:9A:07:91:9B:F8:04:10:B2:EB:01:1F:61:DD:07:9A:9B:F8:06:10:9B:F8:08:50:91:42:55:DB:07:91:14:4A:11:80:51:E0:5A:46:52:1D:12:78:4F:EA:02:1C:1C:4A:05:9B:12:78:08:FB:02:F2:08:32:B3:EB:22:1F:1C:DC:18:4A:05:9B:52:78:08:FB:02:F2"
    16:48:23.404 --
    16:48:23.404 Outgoing Dump:
    16:48:23.404 0000: 01 05 ff f5 30 39 00 20 f0 08 9f 12 88 16 40 b7 ....09. ......@.
    16:48:23.404 0010: 42 84 bf 0c f1 01 06 5f fa 86 fc 03 d8 dd f8 2c B......_.......,
    16:48:23.404 0020: c0 49 1c c9 b2 be f1 00 0f 08 bf 01 29 03 d0 be .I..........)...
    16:48:23.404 0030: f1 01 0f 0a d0 c1 e0 0f 9e dd f8 2c c0 4f f0 01 ...........,.O..
    16:48:23.404 0040: 0e 5f fa 86 f9 e0 46 cd f8 40 c0 9b f8 03 70 9b ._....F..@....p.
    16:48:23.404 0050: f8 00 60 8f 42 4f ea 26 16 03 d1 61 44 dd f8 2c ..`.BO.&...aD..,
    16:48:23.404 0060: c0 c9 b2 dd f8 40 a0 9a 45 dc bf 13 40 10 93 2a .....@..E...@..*
    16:48:23.404 0070: 40 42 45 a8 bf 1f fa 82 f8 66 45 03 d0 0f 9a 4e @BE......fE....N
    16:48:23.404 0080: 2a 40 f0 9b 80 0f 9a 9b f8 02 50 8f 42 a2 eb 0c *@........P.B...
    16:48:23.404 0090: 02 d6 b2 1e dd 00 29 73 d0 06 98 05 99 10 9a 8d ......)s........
    16:48:23.404 00a0: f8 00 60 4b 46 ff f7 ee fe 1d 49 11 90 09 88 10 ..`KF.....I.....
    16:48:23.404 00b0: 9a 07 91 9b f8 04 10 b2 eb 01 1f 61 dd 07 9a 9b ...........a....
    16:48:23.404 00c0: f8 06 10 9b f8 08 50 91 42 55 db 07 91 14 4a 11 ......P.BU....J.
    16:48:23.404 00d0: 80 51 e0 5a 46 52 1d 12 78 4f ea 02 1c 1c 4a 05 .Q.ZFR..xO....J.
    16:48:23.404 00e0: 9b 12 78 08 fb 02 f2 08 32 b3 eb 22 1f 1c dc 18 ..x.....2.."....
    16:48:23.404 00f0: 4a 05 9b 52 78 08 fb 02 f2 J..Rx....
    16:48:23.435 Incoming Dump:
    16:48:23.435 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.435 --
    16:48:23.435 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.435 Parameters:
    16:48:23.435 | Number HCI commands : 0x01
    16:48:23.435 | Command Opcode : 0xff05
    16:48:23.435 | Status : 0x00 (Success)
    16:48:23.435 --
    16:48:23.435 --
    16:48:23.435 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.435 | Address : 0x20003a20
    16:48:23.435 | Size : 0xf0
    16:48:23.435 | Values : "08:32:B3:EB:22:1F:0B:DC:13:4A:05:9B:92:78:08:FB:02:F2:08:32:B3:EB:22:1F:D4:BF:04:22:03:22:08:E0:02:22:06:E0:50:02:01:20:E6:08:01:20:50:06:01:20:0B:9A:4E:45:11:92:0A:D3:A6:EB:09:02:05:4B:52:1C:4B:44:DD:F8:44:E0:52:1E:03:F8:01:EB:F9:D1:C4:45:1A:DA:05:E0:58:00:01:20:50:01:01:20:7A:03:01:20:9B:F8:07:20:9B:F8:09:50:32:4B:07:92:1A:80:09:9A:B1:EB:47:0F:02:F1:01:02:D2:B2:09:92:04:DB:09:99:01:F1:01:01:C9:B2:09:91:11:99:B9:B1:05:2C:15:D2:0B:99:B9:EB:05:02:58:BF:01:21:12:B2:AD:19:01:FB:02:F1:4E:2D:04:EB:0D:02:11:71:04:EB:0D:01:01:F1:0C:01:D4:BF:EA:B2:4E:22:64:1C:0A:70:0B:99:8E:46:8C:46:0E:9A:92:1C:0E:92:0F:9A:52:1C:4F:2A:0F:92:FF:F4:11:AF:00:2C:3F:F4:CF:AE:04:EB:0D:02:04:EB:0D:03:0B:32:1B:1D:13:F8:01:5D:16:78:AE:42:FF:F4"
    16:48:23.435 --
    16:48:23.435 Outgoing Dump:
    16:48:23.435 0000: 01 05 ff f5 20 3a 00 20 f0 08 32 b3 eb 22 1f 0b .... :. ..2.."..
    16:48:23.435 0010: dc 13 4a 05 9b 92 78 08 fb 02 f2 08 32 b3 eb 22 ..J...x.....2.."
    16:48:23.435 0020: 1f d4 bf 04 22 03 22 08 e0 02 22 06 e0 50 02 01 ...."."..."..P..
    16:48:23.435 0030: 20 e6 08 01 20 50 06 01 20 0b 9a 4e 45 11 92 0a ... P.. ..NE...
    16:48:23.435 0040: d3 a6 eb 09 02 05 4b 52 1c 4b 44 dd f8 44 e0 52 ......KR.KD..D.R
    16:48:23.435 0050: 1e 03 f8 01 eb f9 d1 c4 45 1a da 05 e0 58 00 01 ........E....X..
    16:48:23.435 0060: 20 50 01 01 20 7a 03 01 20 9b f8 07 20 9b f8 09 P.. z.. ... ...
    16:48:23.435 0070: 50 32 4b 07 92 1a 80 09 9a b1 eb 47 0f 02 f1 01 P2K........G....
    16:48:23.435 0080: 02 d2 b2 09 92 04 db 09 99 01 f1 01 01 c9 b2 09 ................
    16:48:23.435 0090: 91 11 99 b9 b1 05 2c 15 d2 0b 99 b9 eb 05 02 58 ......,........X
    16:48:23.435 00a0: bf 01 21 12 b2 ad 19 01 fb 02 f1 4e 2d 04 eb 0d ..!........N-...
    16:48:23.435 00b0: 02 11 71 04 eb 0d 01 01 f1 0c 01 d4 bf ea b2 4e ..q............N
    16:48:23.435 00c0: 22 64 1c 0a 70 0b 99 8e 46 8c 46 0e 9a 92 1c 0e "d..p...F.F.....
    16:48:23.435 00d0: 92 0f 9a 52 1c 4f 2a 0f 92 ff f4 11 af 00 2c 3f ...R.O*.......,?
    16:48:23.435 00e0: f4 cf ae 04 eb 0d 02 04 eb 0d 03 0b 32 1b 1d 13 ............2...
    16:48:23.435 00f0: f8 01 5d 16 78 ae 42 ff f4 ..].x.B..
    16:48:23.466 Incoming Dump:
    16:48:23.466 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.466 --
    16:48:23.466 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.466 Parameters:
    16:48:23.466 | Number HCI commands : 0x01
    16:48:23.466 | Command Opcode : 0xff05
    16:48:23.466 | Status : 0x00 (Success)
    16:48:23.466 --
    16:48:23.466 --
    16:48:23.466 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.466 | Address : 0x20003b10
    16:48:23.466 | Size : 0xf0
    16:48:23.466 | Values : "BE:AE:0B:9F:06:9E:26:F8:15:70:6D:1C:F5:E7:06:99:0D:4B:0B:9A:4F:25:89:1E:9B:1E:33:F8:02:6F:31:F8:02:4F:34:40:94:42:A8:BF:22:1C:6D:1E:F5:D1:4E:20:8D:F8:00:00:05:99:0B:9B:06:98:FF:F7:2F:FE:12:B0:BD:E8:F0:8F:E6:08:01:20:50:06:01:20:7C:49:0A:89:00:2A:0C:BF:09:68:49:68:A4:4A:B1:FB:F2:F1:C9:B2:48:43:81:42:2C:BF:01:20:40:1A:A1:49:04:22:0A:80:20:F0:7F:40:48:60:00:20:08:81:05:20:08:80:48:88:00:28:FC:D0:0A:80:70:47:9A:48:01:21:01:70:B0:F8:0B:00:70:47:30:B5:98:4C:23:78:65:78:5D:1B:05:F0:3F:05:3C:2D:1D:DC:45:13:08:BF:40:F4:80:40:04:EB:43:05:5B:1C:40:F4:80:50:03:F0:3F:03:A8:80:04:EB:43:00:5B:1C:81:80:03:F0:3F:03:01:21:04:EB:43:00:5B:1C:82:80:03:F0:3F:03:86:48:23:70:17:38:01:80:30:BD:60:88:40:1C:60:80:30:BD:82:4A:4F:F0:01:01"
    16:48:23.466 --
    16:48:23.466 Outgoing Dump:
    16:48:23.466 0000: 01 05 ff f5 10 3b 00 20 f0 be ae 0b 9f 06 9e 26 .....;. .......&
    16:48:23.466 0010: f8 15 70 6d 1c f5 e7 06 99 0d 4b 0b 9a 4f 25 89 ..pm......K..O%.
    16:48:23.466 0020: 1e 9b 1e 33 f8 02 6f 31 f8 02 4f 34 40 94 42 a8 ...3..o1..O4@.B.
    16:48:23.466 0030: bf 22 1c 6d 1e f5 d1 4e 20 8d f8 00 00 05 99 0b .".m...N .......
    16:48:23.466 0040: 9b 06 98 ff f7 2f fe 12 b0 bd e8 f0 8f e6 08 01 ...../..........
    16:48:23.466 0050: 20 50 06 01 20 7c 49 0a 89 00 2a 0c bf 09 68 49 P.. |I...*...hI
    16:48:23.466 0060: 68 a4 4a b1 fb f2 f1 c9 b2 48 43 81 42 2c bf 01 h.J......HC.B,..
    16:48:23.466 0070: 20 40 1a a1 49 04 22 0a 80 20 f0 7f 40 48 60 00 @..I.".. ..@H`.
    16:48:23.466 0080: 20 08 81 05 20 08 80 48 88 00 28 fc d0 0a 80 70 ... ..H..(....p
    16:48:23.466 0090: 47 9a 48 01 21 01 70 b0 f8 0b 00 70 47 30 b5 98 G.H.!.p....pG0..
    16:48:23.466 00a0: 4c 23 78 65 78 5d 1b 05 f0 3f 05 3c 2d 1d dc 45 L#xex]...?.<-..E
    16:48:23.466 00b0: 13 08 bf 40 f4 80 40 04 eb 43 05 5b 1c 40 f4 80 ...@..@..C.[.@..
    16:48:23.466 00c0: 50 03 f0 3f 03 a8 80 04 eb 43 00 5b 1c 81 80 03 P..?.....C.[....
    16:48:23.466 00d0: f0 3f 03 01 21 04 eb 43 00 5b 1c 82 80 03 f0 3f .?..!..C.[.....?
    16:48:23.466 00e0: 03 86 48 23 70 17 38 01 80 30 bd 60 88 40 1c 60 ..H#p.8..0.`.@.`
    16:48:23.466 00f0: 80 30 bd 82 4a 4f f0 01 01 .0..JO...
    16:48:23.497 Incoming Dump:
    16:48:23.497 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.497 --
    16:48:23.497 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.497 Parameters:
    16:48:23.497 | Number HCI commands : 0x01
    16:48:23.497 | Command Opcode : 0xff05
    16:48:23.497 | Status : 0x00 (Success)
    16:48:23.497 --
    16:48:23.497 --
    16:48:23.497 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.497 | Address : 0x20003c00
    16:48:23.497 | Size : 0xf0
    16:48:23.497 | Values : "A2:F1:09:02:51:72:4F:EA:40:01:01:EB:C0:01:88:B2:00:B9:05:20:91:8A:40:18:A2:F8:54:00:10:88:70:47:01:46:78:4A:C8:43:09:3A:90:80:10:88:01:42:02:D1:20:BF:20:BF:10:88:70:47:10:B5:72:4B:04:46:09:3B:E0:43:98:80:01:20:FF:F7:89:FF:18:88:20:46:FF:F7:E7:FF:10:BD:30:B5:05:46:A1:48:0A:46:00:2D:0C:BF:03:88:43:88:00:2D:14:BF:44:79:04:79:FF:F7:94:FF:0A:21:C0:18:90:FB:F1:F0:12:1A:12:1B:90:B2:02:28:05:DC:FF:22:29:46:21:20:FF:F7:8C:FF:30:BD:FF:F7:B4:FF:4F:F4:00:40:FF:F7:CF:FF:30:BD:59:4A:4F:F0:01:01:A2:F1:09:02:51:72:4F:EA:40:01:01:EB:C0:01:88:B2:00:B9:05:20:91:8A:40:18:50:82:10:88:70:47:86:4A:4F:F0:01:01:51:72:4F:EA:40:01:01:EB:C0:01:88:B2:00:B9:05:20:91:8A:40:18:10:82:10:88:70:47:10:B5:4F:F4:C0:62:B0:FB:F2:F3:99:B2:1B:B2:03:FB"
    16:48:23.497 --
    16:48:23.497 Outgoing Dump:
    16:48:23.497 0000: 01 05 ff f5 00 3c 00 20 f0 a2 f1 09 02 51 72 4f .....<. .....QrO
    16:48:23.497 0010: ea 40 01 01 eb c0 01 88 b2 00 b9 05 20 91 8a 40 .@.......... ..@
    16:48:23.497 0020: 18 a2 f8 54 00 10 88 70 47 01 46 78 4a c8 43 09 ...T...pG.FxJ.C.
    16:48:23.497 0030: 3a 90 80 10 88 01 42 02 d1 20 bf 20 bf 10 88 70 :.....B.. . ...p
    16:48:23.497 0040: 47 10 b5 72 4b 04 46 09 3b e0 43 98 80 01 20 ff G..rK.F.;.C... .
    16:48:23.497 0050: f7 89 ff 18 88 20 46 ff f7 e7 ff 10 bd 30 b5 05 ..... F......0..
    16:48:23.497 0060: 46 a1 48 0a 46 00 2d 0c bf 03 88 43 88 00 2d 14 F.H.F.-....C..-.
    16:48:23.497 0070: bf 44 79 04 79 ff f7 94 ff 0a 21 c0 18 90 fb f1 .Dy.y.....!.....
    16:48:23.497 0080: f0 12 1a 12 1b 90 b2 02 28 05 dc ff 22 29 46 21 ........(...")F!
    16:48:23.497 0090: 20 ff f7 8c ff 30 bd ff f7 b4 ff 4f f4 00 40 ff ....0.....O..@.
    16:48:23.497 00a0: f7 cf ff 30 bd 59 4a 4f f0 01 01 a2 f1 09 02 51 ...0.YJO.......Q
    16:48:23.497 00b0: 72 4f ea 40 01 01 eb c0 01 88 b2 00 b9 05 20 91 rO.@.......... .
    16:48:23.497 00c0: 8a 40 18 50 82 10 88 70 47 86 4a 4f f0 01 01 51 .@.P...pG.JO...Q
    16:48:23.497 00d0: 72 4f ea 40 01 01 eb c0 01 88 b2 00 b9 05 20 91 rO.@.......... .
    16:48:23.497 00e0: 8a 40 18 10 82 10 88 70 47 10 b5 4f f4 c0 62 b0 .@.....pG..O..b.
    16:48:23.497 00f0: fb f2 f3 99 b2 1b b2 03 fb .........
    16:48:23.529 Incoming Dump:
    16:48:23.529 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.529 --
    16:48:23.529 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.529 Parameters:
    16:48:23.529 | Number HCI commands : 0x01
    16:48:23.529 | Command Opcode : 0xff05
    16:48:23.529 | Status : 0x00 (Success)
    16:48:23.529 --
    16:48:23.529 --
    16:48:23.529 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.529 | Address : 0x20003cf0
    16:48:23.529 | Size : 0xf0
    16:48:23.529 | Values : "02:F2:82:1A:94:B2:0A:46:53:02:03:EB:82:23:C0:1A:80:B2:00:28:04:BF:4F:F4:80:10:10:41:18:D0:04:FB:04:F2:D9:20:03:23:50:43:C0:13:80:B2:04:FB:00:F2:92:FB:F3:F3:EB:22:53:43:62:43:DB:14:D2:10:9B:B2:92:B2:80:1A:4F:F4:80:12:C0:1A:02:EB:00:10:08:41:41:43:40:F6:B9:12:4A:43:00:EB:12:50:10:BD:C0:46:00:01:01:20:C1:0B:12:BF:62:49:00:04:62:49:63:4A:C3:0D:03:D1:13:46:00:02:5B:00:C9:1A:C3:0E:04:BF:00:01:89:1A:42:0F:03:D1:49:F6:20:22:80:00:89:1A:82:0F:03:D1:44:F6:10:52:40:00:89:1A:00:EB:50:02:13:08:03:D2:10:46:42:F6:14:52:89:1A:00:EB:90:02:13:08:03:D2:10:46:41:F6:CF:02:89:1A:00:EB:D0:02:13:08:3C:BF:10:1C:A1:F6:18:51:00:EB:10:12:13:08:3C:BF:10:1C:A1:F2:BD:61:00:EB:50:12:13:08:3C:BF:10:1C:A1:F2:6B:31:00:EB:90:12:13:08:3C:BF:10:1C"
    16:48:23.529 --
    16:48:23.529 Outgoing Dump:
    16:48:23.529 0000: 01 05 ff f5 f0 3c 00 20 f0 02 f2 82 1a 94 b2 0a .....<. ........
    16:48:23.529 0010: 46 53 02 03 eb 82 23 c0 1a 80 b2 00 28 04 bf 4f FS....#.....(..O
    16:48:23.529 0020: f4 80 10 10 41 18 d0 04 fb 04 f2 d9 20 03 23 50 ....A....... .#P
    16:48:23.529 0030: 43 c0 13 80 b2 04 fb 00 f2 92 fb f3 f3 eb 22 53 C............."S
    16:48:23.529 0040: 43 62 43 db 14 d2 10 9b b2 92 b2 80 1a 4f f4 80 CbC..........O..
    16:48:23.529 0050: 12 c0 1a 02 eb 00 10 08 41 41 43 40 f6 b9 12 4a ........AAC@...J
    16:48:23.529 0060: 43 00 eb 12 50 10 bd c0 46 00 01 01 20 c1 0b 12 C...P...F... ...
    16:48:23.529 0070: bf 62 49 00 04 62 49 63 4a c3 0d 03 d1 13 46 00 .bI..bIcJ.....F.
    16:48:23.529 0080: 02 5b 00 c9 1a c3 0e 04 bf 00 01 89 1a 42 0f 03 .[...........B..
    16:48:23.529 0090: d1 49 f6 20 22 80 00 89 1a 82 0f 03 d1 44 f6 10 .I. "........D..
    16:48:23.529 00a0: 52 40 00 89 1a 00 eb 50 02 13 08 03 d2 10 46 42 R@.....P......FB
    16:48:23.529 00b0: f6 14 52 89 1a 00 eb 90 02 13 08 03 d2 10 46 41 ..R...........FA
    16:48:23.529 00c0: f6 cf 02 89 1a 00 eb d0 02 13 08 3c bf 10 1c a1 ...........<....
    16:48:23.529 00d0: f6 18 51 00 eb 10 12 13 08 3c bf 10 1c a1 f2 bd ..Q......<......
    16:48:23.529 00e0: 61 00 eb 50 12 13 08 3c bf 10 1c a1 f2 6b 31 00 a..P...<.....k1.
    16:48:23.529 00f0: eb 90 12 13 08 3c bf 10 1c .....<...
    16:48:23.560 Incoming Dump:
    16:48:23.560 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.560 --
    16:48:23.560 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.560 Parameters:
    16:48:23.560 | Number HCI commands : 0x01
    16:48:23.560 | Command Opcode : 0xff05
    16:48:23.560 | Status : 0x00 (Success)
    16:48:23.560 --
    16:48:23.560 --
    16:48:23.560 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.560 | Address : 0x20003de0
    16:48:23.560 | Size : 0xf0
    16:48:23.560 | Values : "A1:F2:B9:11:00:EB:D0:12:13:08:3C:BF:10:1C:DD:39:C0:F1:00:40:A1:EB:D0:31:08:46:70:47:40:42:0F:00:10:E0:00:E0:35:40:01:20:CC:01:01:20:30:B5:38:4B:19:78:01:F0:0F:01:0C:29:08:D0:1A:88:42:F0:0F:02:1A:80:1A:88:22:F0:0F:02:11:43:19:80:32:4C:31:4B:01:28:11:D0:03:28:28:D1:00:25:A0:8C:83:F8:A0:52:1F:FA:90:F0:FF:F7:8A:FE:83:F8:30:51:A1:8C:4F:F6:FC:70:1D:70:08:40:17:E0:A0:8C:01:21:C0:F3:80:00:18:70:A0:8C:83:F8:34:11:C0:F3:00:10:83:F8:A0:02:A0:8C:C0:F3:C0:00:83:F8:F0:14:83:F8:30:01:A0:8C:20:F0:01:00:40:F0:02:00:A0:84:30:BD:00:B5:FF:F7:61:FF:00:EB:80:00:C0:12:00:B2:00:BD:16:49:01:F1:02:01:09:88:49:B9:28:28:B9:BF:00:F2:B1:40:40:00:40:00:00:F6:13:10:80:B2:70:47:08:46:70:47:00:F0:01:01:28:22:40:1A:A0:F6:62:10:01:FB:02:F1:00:EB"
    16:48:23.560 --
    16:48:23.560 Outgoing Dump:
    16:48:23.560 0000: 01 05 ff f5 e0 3d 00 20 f0 a1 f2 b9 11 00 eb d0 .....=. ........
    16:48:23.560 0010: 12 13 08 3c bf 10 1c dd 39 c0 f1 00 40 a1 eb d0 ...<....9...@...
    16:48:23.560 0020: 31 08 46 70 47 40 42 0f 00 10 e0 00 e0 35 40 01 1.FpG@B......5@.
    16:48:23.560 0030: 20 cc 01 01 20 30 b5 38 4b 19 78 01 f0 0f 01 0c ... 0.8K.x.....
    16:48:23.560 0040: 29 08 d0 1a 88 42 f0 0f 02 1a 80 1a 88 22 f0 0f )....B......."..
    16:48:23.560 0050: 02 11 43 19 80 32 4c 31 4b 01 28 11 d0 03 28 28 ..C..2L1K.(...((
    16:48:23.560 0060: d1 00 25 a0 8c 83 f8 a0 52 1f fa 90 f0 ff f7 8a ..%.....R.......
    16:48:23.560 0070: fe 83 f8 30 51 a1 8c 4f f6 fc 70 1d 70 08 40 17 ...0Q..O..p.p.@.
    16:48:23.560 0080: e0 a0 8c 01 21 c0 f3 80 00 18 70 a0 8c 83 f8 34 ....!.....p....4
    16:48:23.560 0090: 11 c0 f3 00 10 83 f8 a0 02 a0 8c c0 f3 c0 00 83 ................
    16:48:23.560 00a0: f8 f0 14 83 f8 30 01 a0 8c 20 f0 01 00 40 f0 02 .....0... ...@..
    16:48:23.560 00b0: 00 a0 84 30 bd 00 b5 ff f7 61 ff 00 eb 80 00 c0 ...0.....a......
    16:48:23.560 00c0: 12 00 b2 00 bd 16 49 01 f1 02 01 09 88 49 b9 28 ......I......I.(
    16:48:23.560 00d0: 28 b9 bf 00 f2 b1 40 40 00 40 00 00 f6 13 10 80 (.....@@.@......
    16:48:23.560 00e0: b2 70 47 08 46 70 47 00 f0 01 01 28 22 40 1a a0 .pG.FpG....("@..
    16:48:23.560 00f0: f6 62 10 01 fb 02 f1 00 eb .b.......
    16:48:23.591 Incoming Dump:
    16:48:23.591 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.591 --
    16:48:23.591 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.591 Parameters:
    16:48:23.591 | Number HCI commands : 0x01
    16:48:23.591 | Command Opcode : 0xff05
    16:48:23.591 | Status : 0x00 (Success)
    16:48:23.591 --
    16:48:23.591 --
    16:48:23.591 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.591 | Address : 0x20003ed0
    16:48:23.591 | Size : 0xf0
    16:48:23.591 | Values : "D0:70:01:EB:60:01:C8:B2:70:47:C0:46:2C:40:01:20:86:02:01:20:F4:83:04:00:F0:B2:FF:FF:41:34:01:00:06:F2:01:20:D0:40:3E:22:50:02:01:20:10:B5:A3:48:00:68:80:4C:00:08:06:D3:20:46:22:30:02:78:00:21:52:20:FF:F7:47:FE:21:46:4F:F0:00:00:7A:4C:02:46:A4:F2:25:13:1A:80:98:70:18:71:98:71:34:F8:E3:3C:81:F8:24:00:DB:B2:24:F8:E3:3C:74:4B:18:70:74:4B:1A:81:5A:81:34:F8:67:2C:22:F0:03:02:24:F8:67:2C:8A:6A:1A:60:CA:6A:5A:60:91:F8:3D:20:84:F8:E7:2F:91:F8:3C:20:84:F8:E8:2F:0A:6B:09:6C:C4:F8:FB:2F:C4:F8:FF:1F:86:4C:21:78:31:B9:01:21:21:70:00:F0:D1:FA:64:49:20:20:08:80:94:F8:29:10:31:B1:49:1E:01:20:80:4A:88:40:11:88:81:43:11:80:10:BD:2D:E9:F0:43:DF:F8:74:81:5D:4D:4F:F0:06:0C:00:23:4F:22:A8:F1:01:01:11:F8:01:4F:9C:42:A8:BF:23:1C:52:1E"
    16:48:23.591 --
    16:48:23.591 Outgoing Dump:
    16:48:23.591 0000: 01 05 ff f5 d0 3e 00 20 f0 d0 70 01 eb 60 01 c8 .....>. ..p..`..
    16:48:23.591 0010: b2 70 47 c0 46 2c 40 01 20 86 02 01 20 f4 83 04 .pG.F,@. ... ...
    16:48:23.591 0020: 00 f0 b2 ff ff 41 34 01 00 06 f2 01 20 d0 40 3e .....A4..... .@>
    16:48:23.591 0030: 22 50 02 01 20 10 b5 a3 48 00 68 80 4c 00 08 06 "P.. ...H.h.L...
    16:48:23.591 0040: d3 20 46 22 30 02 78 00 21 52 20 ff f7 47 fe 21 . F"0.x.!R ..G.!
    16:48:23.591 0050: 46 4f f0 00 00 7a 4c 02 46 a4 f2 25 13 1a 80 98 FO...zL.F..%....
    16:48:23.591 0060: 70 18 71 98 71 34 f8 e3 3c 81 f8 24 00 db b2 24 p.q.q4..<..$...$
    16:48:23.591 0070: f8 e3 3c 74 4b 18 70 74 4b 1a 81 5a 81 34 f8 67 ..<tK.ptK..Z.4.g
    16:48:23.591 0080: 2c 22 f0 03 02 24 f8 67 2c 8a 6a 1a 60 ca 6a 5a ,"...$.g,.j.`.jZ
    16:48:23.591 0090: 60 91 f8 3d 20 84 f8 e7 2f 91 f8 3c 20 84 f8 e8 `..= .../..< ...
    16:48:23.591 00a0: 2f 0a 6b 09 6c c4 f8 fb 2f c4 f8 ff 1f 86 4c 21 /.k.l.../.....L!
    16:48:23.591 00b0: 78 31 b9 01 21 21 70 00 f0 d1 fa 64 49 20 20 08 x1..!!p....dI .
    16:48:23.591 00c0: 80 94 f8 29 10 31 b1 49 1e 01 20 80 4a 88 40 11 ...).1.I.. .J.@.
    16:48:23.591 00d0: 88 81 43 11 80 10 bd 2d e9 f0 43 df f8 74 81 5d ..C....-..C..t.]
    16:48:23.591 00e0: 4d 4f f0 06 0c 00 23 4f 22 a8 f1 01 01 11 f8 01 MO....#O".......
    16:48:23.591 00f0: 4f 9c 42 a8 bf 23 1c 52 1e O.B..#.R.
    16:48:23.622 Incoming Dump:
    16:48:23.622 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.622 --
    16:48:23.622 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.622 Parameters:
    16:48:23.622 | Number HCI commands : 0x01
    16:48:23.622 | Command Opcode : 0xff05
    16:48:23.622 | Status : 0x00 (Success)
    16:48:23.622 --
    16:48:23.622 --
    16:48:23.622 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.622 | Address : 0x20003fc0
    16:48:23.622 | Size : 0xf0
    16:48:23.622 | Values : "F8:D1:B5:F8:24:11:B5:F8:22:21:03:FB:02:11:01:F5:80:71:0C:13:95:F8:E0:10:A1:42:A8:BF:0C:1C:95:F8:E1:10:A1:42:B4:BF:1F:FA:84:FE:8E:46:45:49:50:31:09:78:00:23:06:46:C1:46:01:EB:C1:01:69:18:F0:31:0A:78:9A:42:12:BF:A2:B2:72:46:49:1C:19:F8:01:7B:BA:42:CC:BF:00:22:01:22:5B:1C:37:78:4F:2B:02:FA:0C:F2:42:EA:07:02:06:F8:01:2B:E9:D3:BC:F1:01:0C:A8:F1:50:08:BA:D5:BD:E8:F0:83:2D:E9:F8:4F:37:49:4F:F0:00:0A:D6:46:91:F8:E3:70:91:F8:E2:90:4F:F0:01:0C:40:1E:D0:46:72:46:76:46:73:46:51:46:00:91:10:F8:01:4F:01:2C:20:D0:40:2C:1E:D0:E5:43:D3:46:15:F0:1E:0F:08:D0:15:F0:3C:0F:05:D0:15:F0:0F:0F:1C:BF:15:F0:78:0F:E3:46:00:2C:5D:46:0E:BF:54:46:0C:EB:05:14:E4:B2:E3:46:B8:F1:00:0F:04:70:02:D1:04:B1:05:B1:D3:46:D8:46:01:E0:80:F8:00:A0:1A:B1"
    16:48:23.622 --
    16:48:23.622 Outgoing Dump:
    16:48:23.622 0000: 01 05 ff f5 c0 3f 00 20 f0 f8 d1 b5 f8 24 11 b5 .....?. .....$..
    16:48:23.622 0010: f8 22 21 03 fb 02 11 01 f5 80 71 0c 13 95 f8 e0 ."!.......q.....
    16:48:23.622 0020: 10 a1 42 a8 bf 0c 1c 95 f8 e1 10 a1 42 b4 bf 1f ..B.........B...
    16:48:23.622 0030: fa 84 fe 8e 46 45 49 50 31 09 78 00 23 06 46 c1 ....FEIP1.x.#.F.
    16:48:23.622 0040: 46 01 eb c1 01 69 18 f0 31 0a 78 9a 42 12 bf a2 F....i..1.x.B...
    16:48:23.622 0050: b2 72 46 49 1c 19 f8 01 7b ba 42 cc bf 00 22 01 .rFI....{.B...".
    16:48:23.622 0060: 22 5b 1c 37 78 4f 2b 02 fa 0c f2 42 ea 07 02 06 "[.7xO+....B....
    16:48:23.622 0070: f8 01 2b e9 d3 bc f1 01 0c a8 f1 50 08 ba d5 bd ..+........P....
    16:48:23.622 0080: e8 f0 83 2d e9 f8 4f 37 49 4f f0 00 0a d6 46 91 ...-..O7IO....F.
    16:48:23.622 0090: f8 e3 70 91 f8 e2 90 4f f0 01 0c 40 1e d0 46 72 ..p....O...@..Fr
    16:48:23.622 00a0: 46 76 46 73 46 51 46 00 91 10 f8 01 4f 01 2c 20 FvFsFQF.....O.,
    16:48:23.622 00b0: d0 40 2c 1e d0 e5 43 d3 46 15 f0 1e 0f 08 d0 15 .@,...C.F.......
    16:48:23.622 00c0: f0 3c 0f 05 d0 15 f0 0f 0f 1c bf 15 f0 78 0f e3 .<...........x..
    16:48:23.622 00d0: 46 00 2c 5d 46 0e bf 54 46 0c eb 05 14 e4 b2 e3 F.,]F..TF.......
    16:48:23.622 00e0: 46 b8 f1 00 0f 04 70 02 d1 04 b1 05 b1 d3 46 d8 F.....p.......F.
    16:48:23.622 00f0: 46 01 e0 80 f8 00 a0 1a b1 F........
    16:48:23.654 Incoming Dump:
    16:48:23.654 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.654 --
    16:48:23.654 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.654 Parameters:
    16:48:23.654 | Number HCI commands : 0x01
    16:48:23.654 | Command Opcode : 0xff05
    16:48:23.654 | Status : 0x00 (Success)
    16:48:23.654 --
    16:48:23.654 --
    16:48:23.654 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.654 | Address : 0x200040b0
    16:48:23.654 | Size : 0xf0
    16:48:23.654 | Values : "04:78:1C:B9:03:F1:01:03:04:78:44:B1:11:2C:08:BF:49:1C:52:1C:9F:42:02:D9:59:18:9A:18:53:46:4F:2E:18:BF:9F:42:0C:D1:91:45:05:D3:91:42:05:D1:0A:B1:CD:F8:00:C0:01:E0:4F:F0:10:0E:53:46:51:46:52:46:76:1C:50:2E:B4:D3:00:98:00:EB:C8:10:70:44:C0:B2:BD:E8:F8:8F:80:08:01:20:3D:A1:01:20:4C:0C:34:22:1C:80:01:20:1E:40:01:20:30:08:01:20:50:02:01:20:2D:E9:F0:47:AD:F5:8C:7D:DF:F8:64:90:52:4F:99:F8:29:00:4F:F0:01:04:3C:72:30:B1:16:49:40:1E:0A:88:04:FA:00:F0:10:43:08:80:10:48:00:68:C0:0F:04:D3:BA:79:00:21:4B:20:FF:F7:25:FD:48:4D:4F:F0:00:06:68:7A:89:F8:00:60:18:B9:AE:81:EE:72:AE:72:2E:72:38:78:01:28:03:D1:95:F8:3B:00:FF:F7:EF:FC:DF:F8:04:A1:DF:F8:FC:80:37:46:07:E0:C0:46:B0:01:01:20:CC:00:01:20:04:F0:0E:20:7F:1C:29:78:B9:42:4C:D9"
    16:48:23.654 --
    16:48:23.654 Outgoing Dump:
    16:48:23.654 0000: 01 05 ff f5 b0 40 00 20 f0 04 78 1c b9 03 f1 01 .....@. ..x.....
    16:48:23.654 0010: 03 04 78 44 b1 11 2c 08 bf 49 1c 52 1c 9f 42 02 ..xD..,..I.R..B.
    16:48:23.654 0020: d9 59 18 9a 18 53 46 4f 2e 18 bf 9f 42 0c d1 91 .Y...SFO....B...
    16:48:23.654 0030: 45 05 d3 91 42 05 d1 0a b1 cd f8 00 c0 01 e0 4f E...B..........O
    16:48:23.654 0040: f0 10 0e 53 46 51 46 52 46 76 1c 50 2e b4 d3 00 ...SFQFRFv.P....
    16:48:23.654 0050: 98 00 eb c8 10 70 44 c0 b2 bd e8 f8 8f 80 08 01 .....pD.........
    16:48:23.654 0060: 20 3d a1 01 20 4c 0c 34 22 1c 80 01 20 1e 40 01 =.. L.4"... .@.
    16:48:23.654 0070: 20 30 08 01 20 50 02 01 20 2d e9 f0 47 ad f5 8c 0.. P.. -..G...
    16:48:23.654 0080: 7d df f8 64 90 52 4f 99 f8 29 00 4f f0 01 04 3c }..d.RO..).O...<
    16:48:23.654 0090: 72 30 b1 16 49 40 1e 0a 88 04 fa 00 f0 10 43 08 r0..I@........C.
    16:48:23.654 00a0: 80 10 48 00 68 c0 0f 04 d3 ba 79 00 21 4b 20 ff ..H.h.....y.!K .
    16:48:23.654 00b0: f7 25 fd 48 4d 4f f0 00 06 68 7a 89 f8 00 60 18 .%.HMO...hz...`.
    16:48:23.654 00c0: b9 ae 81 ee 72 ae 72 2e 72 38 78 01 28 03 d1 95 ....r.r.r8x.(...
    16:48:23.654 00d0: f8 3b 00 ff f7 ef fc df f8 04 a1 df f8 fc 80 37 .;.............7
    16:48:23.654 00e0: 46 07 e0 c0 46 b0 01 01 20 cc 00 01 20 04 f0 0e F...F... ... ...
    16:48:23.654 00f0: 20 7f 1c 29 78 b9 42 4c d9 ..)x.BL.
    16:48:23.685 Incoming Dump:
    16:48:23.685 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.685 --
    16:48:23.685 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.685 Parameters:
    16:48:23.685 | Number HCI commands : 0x01
    16:48:23.685 | Command Opcode : 0xff05
    16:48:23.685 | Status : 0x00 (Success)
    16:48:23.685 --
    16:48:23.685 --
    16:48:23.685 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.685 | Address : 0x200041a0
    16:48:23.685 | Size : 0xf0
    16:48:23.685 | Values : "32:AA:50:21:1E:AB:03:F8:01:6B:49:1E:02:F8:01:6B:F9:D1:14:AB:0A:AA:69:46:03:20:FE:F7:9B:FB:98:F8:00:00:4F:F4:0C:72:51:46:00:F0:AA:FD:08:20:FF:F7:27:FD:02:20:0A:AA:69:46:14:AB:FE:F7:8B:FB:30:46:00:F0:A0:F9:32:A8:FF:F7:DA:FE:98:F8:00:10:50:46:4F:F4:0C:72:00:F0:94:FD:1E:A8:FF:F7:D0:FE:1E:A8:FF:F7:1B:FF:A8:71:32:A8:FF:F7:17:FF:A9:79:2B:7A:01:43:CA:B2:69:7A:49:1C:69:72:02:F0:01:01:C9:18:AB:7A:29:72:C2:F3:00:11:C9:18:A9:72:E9:7A:E8:71:01:EB:E2:11:E9:72:51:09:AE:D2:68:78:02:F0:01:03:00:F0:04:01:19:43:00:EA:22:13:03:F0:01:03:00:EA:A2:10:0B:43:20:F0:01:00:18:43:08:BF:02:24:02:D0:A8:89:40:1C:A8:81:08:49:20:20:89:F8:00:40:46:B0:08:80:BD:E8:F0:87:C0:46:9C:08:01:20:2E:03:01:20:08:83:00:00:50:06:01:20:1E:40:01:20:2D:E9:F0:41"
    16:48:23.685 --
    16:48:23.685 Outgoing Dump:
    16:48:23.685 0000: 01 05 ff f5 a0 41 00 20 f0 32 aa 50 21 1e ab 03 .....A. .2.P!...
    16:48:23.685 0010: f8 01 6b 49 1e 02 f8 01 6b f9 d1 14 ab 0a aa 69 ..kI....k......i
    16:48:23.685 0020: 46 03 20 fe f7 9b fb 98 f8 00 00 4f f4 0c 72 51 F. ........O..rQ
    16:48:23.685 0030: 46 00 f0 aa fd 08 20 ff f7 27 fd 02 20 0a aa 69 F..... ..'.. ..i
    16:48:23.685 0040: 46 14 ab fe f7 8b fb 30 46 00 f0 a0 f9 32 a8 ff F......0F....2..
    16:48:23.685 0050: f7 da fe 98 f8 00 10 50 46 4f f4 0c 72 00 f0 94 .......PFO..r...
    16:48:23.685 0060: fd 1e a8 ff f7 d0 fe 1e a8 ff f7 1b ff a8 71 32 ..............q2
    16:48:23.685 0070: a8 ff f7 17 ff a9 79 2b 7a 01 43 ca b2 69 7a 49 ......y+z.C..izI
    16:48:23.685 0080: 1c 69 72 02 f0 01 01 c9 18 ab 7a 29 72 c2 f3 00 .ir.......z)r...
    16:48:23.685 0090: 11 c9 18 a9 72 e9 7a e8 71 01 eb e2 11 e9 72 51 ....r.z.q.....rQ
    16:48:23.685 00a0: 09 ae d2 68 78 02 f0 01 03 00 f0 04 01 19 43 00 ...hx.........C.
    16:48:23.685 00b0: ea 22 13 03 f0 01 03 00 ea a2 10 0b 43 20 f0 01 ."..........C ..
    16:48:23.685 00c0: 00 18 43 08 bf 02 24 02 d0 a8 89 40 1c a8 81 08 ..C...$....@....
    16:48:23.685 00d0: 49 20 20 89 f8 00 40 46 b0 08 80 bd e8 f0 87 c0 I ...@F........
    16:48:23.685 00e0: 46 9c 08 01 20 2e 03 01 20 08 83 00 00 50 06 01 F... ... ....P..
    16:48:23.685 00f0: 20 1e 40 01 20 2d e9 f0 41 .@. -..A
    16:48:23.716 Incoming Dump:
    16:48:23.716 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.716 --
    16:48:23.716 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.716 Parameters:
    16:48:23.716 | Number HCI commands : 0x01
    16:48:23.716 | Command Opcode : 0xff05
    16:48:23.716 | Status : 0x00 (Success)
    16:48:23.716 --
    16:48:23.716 --
    16:48:23.716 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.716 | Address : 0x20004290
    16:48:23.716 | Size : 0xf0
    16:48:23.716 | Values : "94:48:00:78:30:B1:40:1E:01:21:93:4A:81:40:10:88:01:43:11:80:91:48:DF:F8:5C:82:00:68:00:08:06:D3:40:46:35:38:02:78:00:21:54:20:FF:F7:73:FC:8C:49:08:88:40:08:04:D3:8B:4A:10:68:40:F0:80:70:10:60:B1:F8:78:00:88:4F:C0:F3:03:24:38:78:00:F0:0F:00:0F:28:02:D1:85:48:00:78:A8:B1:85:4D:28:78:01:28:04:D0:01:20:28:70:20:46:FF:F7:30:FC:01:26:20:46:2E:71:FF:F7:2B:FC:2E:72:20:46:FF:F7:27:FC:2E:73:20:46:FF:F7:23:FC:00:20:01:21:A7:F8:2C:01:40:46:01:70:BD:E8:F0:81:2D:E9:F0:4F:77:4F:75:4C:78:6E:C0:0F:06:D3:20:46:35:38:02:78:00:21:4D:20:FF:F7:31:FC:DF:F8:C8:A1:38:88:0A:F1:64:0B:DA:F8:30:20:DF:F8:C0:91:DF:F8:B8:81:BB:F8:78:C0:57:3C:C0:F3:02:15:00:F0:03:06:0C:EA:A2:01:89:08:57:D3:94:F8:4A:30:00:F0:03:01:99:42:42:D0:00:29:40:D0:01:09"
    16:48:23.716 --
    16:48:23.716 Outgoing Dump:
    16:48:23.716 0000: 01 05 ff f5 90 42 00 20 f0 94 48 00 78 30 b1 40 .....B. ..H.x0.@
    16:48:23.716 0010: 1e 01 21 93 4a 81 40 10 88 01 43 11 80 91 48 df ..!.J.@...C...H.
    16:48:23.716 0020: f8 5c 82 00 68 00 08 06 d3 40 46 35 38 02 78 00 .\..h....@F58.x.
    16:48:23.716 0030: 21 54 20 ff f7 73 fc 8c 49 08 88 40 08 04 d3 8b !T ..s..I..@....
    16:48:23.716 0040: 4a 10 68 40 f0 80 70 10 60 b1 f8 78 00 88 4f c0 J.h@..p.`..x..O.
    16:48:23.716 0050: f3 03 24 38 78 00 f0 0f 00 0f 28 02 d1 85 48 00 ..$8x.....(...H.
    16:48:23.716 0060: 78 a8 b1 85 4d 28 78 01 28 04 d0 01 20 28 70 20 x...M(x.(... (p
    16:48:23.716 0070: 46 ff f7 30 fc 01 26 20 46 2e 71 ff f7 2b fc 2e F..0..& F.q..+..
    16:48:23.716 0080: 72 20 46 ff f7 27 fc 2e 73 20 46 ff f7 23 fc 00 r F..'..s F..#..
    16:48:23.716 0090: 20 01 21 a7 f8 2c 01 40 46 01 70 bd e8 f0 81 2d .!..,.@F.p....-
    16:48:23.716 00a0: e9 f0 4f 77 4f 75 4c 78 6e c0 0f 06 d3 20 46 35 ..OwOuLxn.... F5
    16:48:23.716 00b0: 38 02 78 00 21 4d 20 ff f7 31 fc df f8 c8 a1 38 8.x.!M ..1.....8
    16:48:23.716 00c0: 88 0a f1 64 0b da f8 30 20 df f8 c0 91 df f8 b8 ...d...0 .......
    16:48:23.716 00d0: 81 bb f8 78 c0 57 3c c0 f3 02 15 00 f0 03 06 0c ...x.W<.........
    16:48:23.716 00e0: ea a2 01 89 08 57 d3 94 f8 4a 30 00 f0 03 01 99 .....W...J0.....
    16:48:23.716 00f0: 42 42 d0 00 29 40 d0 01 09 BB..)@...
    16:48:23.747 Incoming Dump:
    16:48:23.747 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.747 --
    16:48:23.747 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.747 Parameters:
    16:48:23.747 | Number HCI commands : 0x01
    16:48:23.747 | Command Opcode : 0xff05
    16:48:23.747 | Status : 0x00 (Success)
    16:48:23.747 --
    16:48:23.747 --
    16:48:23.747 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.747 | Address : 0x20004380
    16:48:23.747 | Size : 0xf0
    16:48:23.747 | Values : "3E:D2:E1:6C:C8:F8:80:90:B1:FB:F6:F1:21:60:31:46:49:1E:07:D0:49:1E:03:D0:49:1E:08:BF:0A:20:02:E0:03:20:00:E0:02:20:B7:F8:4E:10:5B:4A:01:F0:1F:01:03:29:05:D0:11:88:21:F0:0F:01:08:43:10:80:06:E0:B2:F8:00:18:21:F0:0F:01:08:43:A2:F8:00:08:00:20:FF:F7:C4:FB:FB:F7:AB:FE:94:F8:50:10:01:20:88:43:84:F8:50:00:78:6E:40:0C:05:D3:94:F8:4A:10:32:46:34:20:FF:F7:D7:FB:C8:F8:00:90:84:F8:4A:60:0A:E0:79:6E:C9:0C:0B:D3:9E:42:09:D0:C0:F3:C0:02:31:46:36:20:FF:F7:C7:FB:50:46:B0:F8:DC:C0:02:6B:0C:EA:62:00:C0:08:29:D3:94:F8:4B:20:95:42:1C:D0:02:2D:1A:DB:04:2D:18:DA:46:46:38:4A:29:01:C6:F8:80:90:10:88:10:39:20:F0:70:00:01:43:78:6E:80:0C:11:80:05:D3:94:F8:4B:10:2A:46:35:20:FF:F7:A3:FB:C6:F8:00:90:84:F8:4B:50:08:E0:78:6E:00:0D:05:D3:95:42"
    16:48:23.747 --
    16:48:23.747 Outgoing Dump:
    16:48:23.747 0000: 01 05 ff f5 80 43 00 20 f0 3e d2 e1 6c c8 f8 80 .....C. .>..l...
    16:48:23.747 0010: 90 b1 fb f6 f1 21 60 31 46 49 1e 07 d0 49 1e 03 .....!`1FI...I..
    16:48:23.747 0020: d0 49 1e 08 bf 0a 20 02 e0 03 20 00 e0 02 20 b7 .I.... ... ... .
    16:48:23.747 0030: f8 4e 10 5b 4a 01 f0 1f 01 03 29 05 d0 11 88 21 .N.[J.....)....!
    16:48:23.747 0040: f0 0f 01 08 43 10 80 06 e0 b2 f8 00 18 21 f0 0f ....C........!..
    16:48:23.747 0050: 01 08 43 a2 f8 00 08 00 20 ff f7 c4 fb fb f7 ab ..C..... .......
    16:48:23.747 0060: fe 94 f8 50 10 01 20 88 43 84 f8 50 00 78 6e 40 ...P.. .C..P.xn@
    16:48:23.747 0070: 0c 05 d3 94 f8 4a 10 32 46 34 20 ff f7 d7 fb c8 .....J.2F4 .....
    16:48:23.747 0080: f8 00 90 84 f8 4a 60 0a e0 79 6e c9 0c 0b d3 9e .....J`..yn.....
    16:48:23.747 0090: 42 09 d0 c0 f3 c0 02 31 46 36 20 ff f7 c7 fb 50 B......1F6 ....P
    16:48:23.747 00a0: 46 b0 f8 dc c0 02 6b 0c ea 62 00 c0 08 29 d3 94 F.....k..b...)..
    16:48:23.747 00b0: f8 4b 20 95 42 1c d0 02 2d 1a db 04 2d 18 da 46 .K .B...-...-..F
    16:48:23.747 00c0: 46 38 4a 29 01 c6 f8 80 90 10 88 10 39 20 f0 70 F8J)........9 .p
    16:48:23.747 00d0: 00 01 43 78 6e 80 0c 11 80 05 d3 94 f8 4b 10 2a ..Cxn........K.*
    16:48:23.747 00e0: 46 35 20 ff f7 a3 fb c6 f8 00 90 84 f8 4b 50 08 F5 ..........KP.
    16:48:23.747 00f0: e0 78 6e 00 0d 05 d3 95 42 .xn.....B
    16:48:23.779 Incoming Dump:
    16:48:23.779 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.779 --
    16:48:23.779 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.779 Parameters:
    16:48:23.779 | Number HCI commands : 0x01
    16:48:23.779 | Command Opcode : 0xff05
    16:48:23.779 | Status : 0x00 (Success)
    16:48:23.779 --
    16:48:23.779 --
    16:48:23.779 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.779 | Address : 0x20004470
    16:48:23.779 | Size : 0xf0
    16:48:23.779 | Values : "03:D0:29:46:37:20:FF:F7:95:FB:BB:F8:00:00:40:08:04:D3:1C:49:08:68:20:F0:80:70:08:60:01:20:24:49:1B:4A:08:80:00:21:11:73:00:BF:00:BF:00:BF:00:BF:00:BF:11:72:00:BF:00:BF:00:BF:00:BF:00:BF:11:71:00:BF:00:BF:00:BF:00:BF:00:BF:BB:F9:20:30:9B:08:02:D3:94:F8:51:30:03:B9:11:70:84:F8:57:10:05:49:09:78:29:B1:49:1E:04:4A:88:40:11:88:81:43:11:80:BD:E8:F0:8F:F6:00:01:20:04:F0:0E:20:B0:01:01:20:B4:02:01:20:90:40:01:20:08:B0:01:20:80:26:36:22:00:01:36:22:D7:08:01:20:4C:01:01:20:50:02:01:20:00:E1:00:E0:0C:C0:28:00:12:24:0C:20:02:F1:01:20:34:B1:01:20:2D:E9:FF:4F:01:90:84:48:85:4D:00:68:00:08:06:D3:28:46:40:1D:01:99:02:78:51:20:FF:F7:31:FB:4F:F0:01:08:7E:48:29:78:80:F8:08:80:80:F8:28:80:80:F8:00:80:09:B9:80:F8:20:80:7B:4A:7A:49"
    16:48:23.779 --
    16:48:23.779 Outgoing Dump:
    16:48:23.779 0000: 01 05 ff f5 70 44 00 20 f0 03 d0 29 46 37 20 ff ....pD. ...)F7 .
    16:48:23.779 0010: f7 95 fb bb f8 00 00 40 08 04 d3 1c 49 08 68 20 .......@....I.h
    16:48:23.779 0020: f0 80 70 08 60 01 20 24 49 1b 4a 08 80 00 21 11 ..p.`. $I.J...!.
    16:48:23.779 0030: 73 00 bf 00 bf 00 bf 00 bf 00 bf 11 72 00 bf 00 s...........r...
    16:48:23.779 0040: bf 00 bf 00 bf 00 bf 11 71 00 bf 00 bf 00 bf 00 ........q.......
    16:48:23.779 0050: bf 00 bf bb f9 20 30 9b 08 02 d3 94 f8 51 30 03 ..... 0......Q0.
    16:48:23.779 0060: b9 11 70 84 f8 57 10 05 49 09 78 29 b1 49 1e 04 ..p..W..I.x).I..
    16:48:23.779 0070: 4a 88 40 11 88 81 43 11 80 bd e8 f0 8f f6 00 01 J.@...C.........
    16:48:23.779 0080: 20 04 f0 0e 20 b0 01 01 20 b4 02 01 20 90 40 01 ... ... ... .@.
    16:48:23.779 0090: 20 08 b0 01 20 80 26 36 22 00 01 36 22 d7 08 01 ... .&6"..6"...
    16:48:23.779 00a0: 20 4c 01 01 20 50 02 01 20 00 e1 00 e0 0c c0 28 L.. P.. ......(
    16:48:23.779 00b0: 00 12 24 0c 20 02 f1 01 20 34 b1 01 20 2d e9 ff ..$. ... 4.. -..
    16:48:23.779 00c0: 4f 01 90 84 48 85 4d 00 68 00 08 06 d3 28 46 40 O...H.M.h....(F@
    16:48:23.779 00d0: 1d 01 99 02 78 51 20 ff f7 31 fb 4f f0 01 08 7e ....xQ ..1.O...~
    16:48:23.779 00e0: 48 29 78 80 f8 08 80 80 f8 28 80 80 f8 00 80 09 H)x......(......
    16:48:23.779 00f0: b9 80 f8 20 80 7b 4a 7a 49 ... .{JzI
    16:48:23.810 Incoming Dump:
    16:48:23.810 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.810 --
    16:48:23.810 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.810 Parameters:
    16:48:23.810 | Number HCI commands : 0x01
    16:48:23.810 | Command Opcode : 0xff05
    16:48:23.810 | Status : 0x00 (Success)
    16:48:23.810 --
    16:48:23.810 --
    16:48:23.810 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.810 | Address : 0x20004560
    16:48:23.810 | Size : 0xf0
    16:48:23.810 | Values : "00:24:10:20:81:F8:1D:01:82:F8:FF:47:C8:8B:20:F4:40:70:C8:83:82:F8:FF:4F:81:F8:42:41:B1:F8:5C:02:A2:F2:0D:20:80:F8:00:80:80:F8:4C:40:08:88:20:F4:80:70:40:F4:00:70:08:80:DF:F8:B4:91:82:F8:CF:4B:40:F2:11:10:82:F8:0F:4C:C1:F8:62:02:B9:F8:97:02:A1:F8:1A:41:FF:F7:84:FB:FC:F7:06:FC:FC:F7:1E:FC:A5:F1:1D:05:02:94:63:4E:95:F8:51:00:30:B1:28:7F:20:B9:68:7F:10:B9:FB:F7:21:FE:04:E0:A6:F8:47:40:03:20:FF:F7:BB:FA:99:F8:87:00:5B:49:DF:F8:7C:B1:08:70:01:98:B0:B9:B9:F8:79:00:98:B1:95:F8:22:00:80:B9:58:46:80:1D:00:88:40:08:0B:D3:02:98:FB:F7:C7:FE:03:90:01:98:6A:46:0D:F1:01:01:FB:F7:44:FD:CD:F8:08:80:69:7E:4D:48:6F:F4:80:73:20:F8:B9:4C:29:B1:6C:76:4A:4A:29:7E:11:70:E9:8A:C1:52:49:4F:87:F8:3C:40:B0:F8:FF:1F:21:F0:70:01:A0:F8:FF:1F"
    16:48:23.810 --
    16:48:23.810 Outgoing Dump:
    16:48:23.810 0000: 01 05 ff f5 60 45 00 20 f0 00 24 10 20 81 f8 1d ....`E. ..$. ...
    16:48:23.810 0010: 01 82 f8 ff 47 c8 8b 20 f4 40 70 c8 83 82 f8 ff ....G.. .@p.....
    16:48:23.810 0020: 4f 81 f8 42 41 b1 f8 5c 02 a2 f2 0d 20 80 f8 00 O..BA..\.... ...
    16:48:23.810 0030: 80 80 f8 4c 40 08 88 20 f4 80 70 40 f4 00 70 08 ...L@.. ..p@..p.
    16:48:23.810 0040: 80 df f8 b4 91 82 f8 cf 4b 40 f2 11 10 82 f8 0f ........K@......
    16:48:23.810 0050: 4c c1 f8 62 02 b9 f8 97 02 a1 f8 1a 41 ff f7 84 L..b........A...
    16:48:23.810 0060: fb fc f7 06 fc fc f7 1e fc a5 f1 1d 05 02 94 63 ...............c
    16:48:23.810 0070: 4e 95 f8 51 00 30 b1 28 7f 20 b9 68 7f 10 b9 fb N..Q.0.(. .h....
    16:48:23.810 0080: f7 21 fe 04 e0 a6 f8 47 40 03 20 ff f7 bb fa 99 .!.....G@. .....
    16:48:23.810 0090: f8 87 00 5b 49 df f8 7c b1 08 70 01 98 b0 b9 b9 ...[I..|..p.....
    16:48:23.810 00a0: f8 79 00 98 b1 95 f8 22 00 80 b9 58 46 80 1d 00 .y....."...XF...
    16:48:23.810 00b0: 88 40 08 0b d3 02 98 fb f7 c7 fe 03 90 01 98 6a .@.............j
    16:48:23.810 00c0: 46 0d f1 01 01 fb f7 44 fd cd f8 08 80 69 7e 4d F......D.....i~M
    16:48:23.810 00d0: 48 6f f4 80 73 20 f8 b9 4c 29 b1 6c 76 4a 4a 29 Ho..s ..L).lvJJ)
    16:48:23.810 00e0: 7e 11 70 e9 8a c1 52 49 4f 87 f8 3c 40 b0 f8 ff ~.p...RIO..<@...
    16:48:23.810 00f0: 1f 21 f0 70 01 a0 f8 ff 1f .!.p.....
    16:48:23.841 Incoming Dump:
    16:48:23.841 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.841 --
    16:48:23.841 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.841 Parameters:
    16:48:23.841 | Number HCI commands : 0x01
    16:48:23.841 | Command Opcode : 0xff05
    16:48:23.841 | Status : 0x00 (Success)
    16:48:23.841 --
    16:48:23.841 --
    16:48:23.841 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.841 | Address : 0x20004650
    16:48:23.841 | Size : 0xf0
    16:48:23.841 | Values : "3C:70:3C:71:FC:F7:E4:FA:08:20:FF:F7:E1:FA:42:49:87:F8:34:40:08:88:85:F8:48:40:20:F0:3F:00:08:80:87:F8:B0:80:01:98:78:B1:99:F8:00:00:60:B1:58:46:81:8C:82:8C:01:F0:01:01:85:F8:49:10:4F:F6:FE:71:01:EA:02:01:81:84:01:E0:85:F8:49:40:95:F8:22:00:DF:F8:CC:A0:E8:B9:58:46:00:F1:0E:00:01:88:C1:B1:01:99:B1:B9:51:46:22:46:47:F6:FF:7C:7F:27:A0:39:81:F8:58:70:81:F8:68:40:07:2A:81:F8:60:40:3C:BF:05:EB:42:03:A3:F8:08:C0:52:1C:49:1C:08:2A:EF:D3:04:80:02:98:38:B1:01:98:9D:F8:01:10:9D:F8:00:20:03:9B:FB:F7:19:FE:EC:76:85:F8:53:40:A6:F8:1F:40:2C:77:85:F8:54:40:34:70:A9:F8:11:40:68:7F:85:F8:55:40:B4:70:85:F8:56:40:08:B9:34:70:B4:70:50:46:00:78:38:B1:40:1E:41:46:12:4A:01:FA:00:F0:11:88:81:43:11:80:00:90:BD:E8:FF:8F:C0:46:B0:01:01:20"
    16:48:23.841 --
    16:48:23.841 Outgoing Dump:
    16:48:23.841 0000: 01 05 ff f5 50 46 00 20 f0 3c 70 3c 71 fc f7 e4 ....PF. .<p<q...
    16:48:23.841 0010: fa 08 20 ff f7 e1 fa 42 49 87 f8 34 40 08 88 85 .. ....BI..4@...
    16:48:23.841 0020: f8 48 40 20 f0 3f 00 08 80 87 f8 b0 80 01 98 78 .H@ .?.........x
    16:48:23.841 0030: b1 99 f8 00 00 60 b1 58 46 81 8c 82 8c 01 f0 01 .....`.XF.......
    16:48:23.841 0040: 01 85 f8 49 10 4f f6 fe 71 01 ea 02 01 81 84 01 ...I.O..q.......
    16:48:23.841 0050: e0 85 f8 49 40 95 f8 22 00 df f8 cc a0 e8 b9 58 ...I@..".......X
    16:48:23.841 0060: 46 00 f1 0e 00 01 88 c1 b1 01 99 b1 b9 51 46 22 F............QF"
    16:48:23.841 0070: 46 47 f6 ff 7c 7f 27 a0 39 81 f8 58 70 81 f8 68 FG..|.'.9..Xp..h
    16:48:23.841 0080: 40 07 2a 81 f8 60 40 3c bf 05 eb 42 03 a3 f8 08 @.*..`@<...B....
    16:48:23.841 0090: c0 52 1c 49 1c 08 2a ef d3 04 80 02 98 38 b1 01 .R.I..*......8..
    16:48:23.841 00a0: 98 9d f8 01 10 9d f8 00 20 03 9b fb f7 19 fe ec ........ .......
    16:48:23.841 00b0: 76 85 f8 53 40 a6 f8 1f 40 2c 77 85 f8 54 40 34 v..S@...@,w..T@4
    16:48:23.841 00c0: 70 a9 f8 11 40 68 7f 85 f8 55 40 b4 70 85 f8 56 p...@h...U@.p..V
    16:48:23.841 00d0: 40 08 b9 34 70 b4 70 50 46 00 78 38 b1 40 1e 41 @..4p.pPF.x8.@.A
    16:48:23.841 00e0: 46 12 4a 01 fa 00 f0 11 88 81 43 11 80 00 90 bd F.J.......C.....
    16:48:23.841 00f0: e8 ff 8f c0 46 b0 01 01 20 ....F...
    16:48:23.873 Incoming Dump:
    16:48:23.873 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.873 --
    16:48:23.873 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.873 Parameters:
    16:48:23.873 | Number HCI commands : 0x01
    16:48:23.873 | Command Opcode : 0xff05
    16:48:23.873 | Status : 0x00 (Success)
    16:48:23.873 --
    16:48:23.873 --
    16:48:23.873 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.873 | Address : 0x20004740
    16:48:23.873 | Size : 0xf0
    16:48:23.873 | Values : "24:11:28:22:9D:08:01:20:4A:80:01:20:31:0B:30:22:A1:02:01:20:4D:40:01:20:58:B5:01:20:19:A1:01:20:C0:1A:34:22:30:20:3E:22:00:F1:01:20:00:00:01:20:F0:00:01:20:04:F0:0E:20:2D:E9:F0:43:84:4F:97:F8:2F:00:30:B1:40:1E:01:21:82:4A:81:40:10:88:01:43:11:80:81:48:4F:F0:00:08:04:68:80:4E:80:4D:DF:F8:0C:92:C7:F8:00:80:40:46:78:71:03:21:86:F8:36:00:E8:89:86:F8:37:10:40:08:0F:D3:7A:48:00:68:04:42:0B:D0:4B:20:FF:F7:CA:F9:77:48:01:79:00:29:40:F0:C8:80:01:78:00:29:40:F0:C4:80:A2:B2:1F:FA:A4:F1:01:20:FF:F7:DF:F9:60:08:05:D3:03:F0:A3:FB:38:68:40:F0:01:00:38:60:20:09:05:D3:03:F0:57:F9:38:68:40:F0:08:00:38:60:20:0A:05:D3:03:F0:49:FA:38:68:40:F0:80:00:38:60:E0:09:05:D3:03:F0:5B:FD:38:68:40:F0:40:00:38:60:A0:08:05:D3:03:F0:B1:FA:38:68"
    16:48:23.873 --
    16:48:23.873 Outgoing Dump:
    16:48:23.873 0000: 01 05 ff f5 40 47 00 20 f0 24 11 28 22 9d 08 01 ....@G. .$.("...
    16:48:23.873 0010: 20 4a 80 01 20 31 0b 30 22 a1 02 01 20 4d 40 01 J.. 1.0"... M@.
    16:48:23.873 0020: 20 58 b5 01 20 19 a1 01 20 c0 1a 34 22 30 20 3e X.. ... ..4"0 >
    16:48:23.873 0030: 22 00 f1 01 20 00 00 01 20 f0 00 01 20 04 f0 0e "... ... ... ...
    16:48:23.873 0040: 20 2d e9 f0 43 84 4f 97 f8 2f 00 30 b1 40 1e 01 -..C.O../.0.@..
    16:48:23.873 0050: 21 82 4a 81 40 10 88 01 43 11 80 81 48 4f f0 00 !.J.@...C...HO..
    16:48:23.873 0060: 08 04 68 80 4e 80 4d df f8 0c 92 c7 f8 00 80 40 ..h.N.M........@
    16:48:23.873 0070: 46 78 71 03 21 86 f8 36 00 e8 89 86 f8 37 10 40 Fxq.!..6.....7.@
    16:48:23.873 0080: 08 0f d3 7a 48 00 68 04 42 0b d0 4b 20 ff f7 ca ...zH.h.B..K ...
    16:48:23.873 0090: f9 77 48 01 79 00 29 40 f0 c8 80 01 78 00 29 40 .wH.y.)@....x.)@
    16:48:23.873 00a0: f0 c4 80 a2 b2 1f fa a4 f1 01 20 ff f7 df f9 60 .......... ....`
    16:48:23.873 00b0: 08 05 d3 03 f0 a3 fb 38 68 40 f0 01 00 38 60 20 .......8h@...8`
    16:48:23.873 00c0: 09 05 d3 03 f0 57 f9 38 68 40 f0 08 00 38 60 20 .....W.8h@...8`
    16:48:23.873 00d0: 0a 05 d3 03 f0 49 fa 38 68 40 f0 80 00 38 60 e0 .....I.8h@...8`.
    16:48:23.873 00e0: 09 05 d3 03 f0 5b fd 38 68 40 f0 40 00 38 60 a0 .....[.8h@.@.8`.
    16:48:23.873 00f0: 08 05 d3 03 f0 b1 fa 38 68 .......8h
    16:48:23.904 Incoming Dump:
    16:48:23.904 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.904 --
    16:48:23.904 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.904 Parameters:
    16:48:23.904 | Number HCI commands : 0x01
    16:48:23.904 | Command Opcode : 0xff05
    16:48:23.904 | Status : 0x00 (Success)
    16:48:23.904 --
    16:48:23.904 --
    16:48:23.904 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.919 Parameters:
    16:48:23.919 | Address : 0x20004830
    16:48:23.919 | Size : 0xf0
    16:48:23.919 | Values : "40:F0:02:00:38:60:E0:08:19:D3:28:6B:01:0A:08:D2:03:F0:2E:FA:38:68:40:F0:80:00:38:60:28:46:30:30:00:68:C0:09:05:D2:03:F0:3D:FD:38:68:40:F0:40:00:38:60:03:F0:87:FC:38:68:40:F0:04:00:38:60:E0:0A:05:D3:03:F0:47:FD:38:68:40:F4:80:60:38:60:A0:0C:05:D3:03:F0:05:F8:38:68:40:F4:00:30:38:60:60:09:05:D3:01:F0:C3:FE:38:68:40:F0:10:00:38:60:A0:09:08:D3:40:46:02:F0:1A:FC:78:79:18:B9:38:68:40:F0:20:00:38:60:E0:0B:08:D3:01:20:02:F0:0F:FC:78:79:18:B9:38:68:40:F4:80:40:38:60:20:0C:05:D3:78:79:18:B9:38:68:40:F4:00:40:38:60:60:0A:05:D3:03:F0:10:F8:38:68:40:F4:80:70:38:60:A0:0A:05:D3:02:F0:C9:FD:38:68:40:F4:00:70:38:60:20:0B:05:D3:03:F0:DD:FB:38:68:40:F4:00:60:38:60:60:0B:05:D3:02:F0:5D:F9:38:68:40:F4:80:50:38:60:A0:0B:05:D3:03:F0"
    16:48:23.919 --
    16:48:23.919 Outgoing Dump:
    16:48:23.919 0000: 01 05 ff f5 30 48 00 20 f0 40 f0 02 00 38 60 e0 ....0H. .@...8`.
    16:48:23.919 0010: 08 19 d3 28 6b 01 0a 08 d2 03 f0 2e fa 38 68 40 ...(k........8h@
    16:48:23.919 0020: f0 80 00 38 60 28 46 30 30 00 68 c0 09 05 d2 03 ...8`(F00.h.....
    16:48:23.919 0030: f0 3d fd 38 68 40 f0 40 00 38 60 03 f0 87 fc 38 .=.8h@.@.8`....8
    16:48:23.919 0040: 68 40 f0 04 00 38 60 e0 0a 05 d3 03 f0 47 fd 38 h@...8`......G.8
    16:48:23.919 0050: 68 40 f4 80 60 38 60 a0 0c 05 d3 03 f0 05 f8 38 h@..`8`........8
    16:48:23.919 0060: 68 40 f4 00 30 38 60 60 09 05 d3 01 f0 c3 fe 38 h@..08``.......8
    16:48:23.919 0070: 68 40 f0 10 00 38 60 a0 09 08 d3 40 46 02 f0 1a h@...8`....@F...
    16:48:23.919 0080: fc 78 79 18 b9 38 68 40 f0 20 00 38 60 e0 0b 08 .xy..8h@. .8`...
    16:48:23.919 0090: d3 01 20 02 f0 0f fc 78 79 18 b9 38 68 40 f4 80 .. ....xy..8h@..
    16:48:23.919 00a0: 40 38 60 20 0c 05 d3 78 79 18 b9 38 68 40 f4 00 @8` ...xy..8h@..
    16:48:23.919 00b0: 40 38 60 60 0a 05 d3 03 f0 10 f8 38 68 40 f4 80 @8``.......8h@..
    16:48:23.919 00c0: 70 38 60 a0 0a 05 d3 02 f0 c9 fd 38 68 40 f4 00 p8`........8h@..
    16:48:23.919 00d0: 70 38 60 20 0b 05 d3 03 f0 dd fb 38 68 40 f4 00 p8` .......8h@..
    16:48:23.919 00e0: 60 38 60 60 0b 05 d3 02 f0 5d f9 38 68 40 f4 80 `8``.....].8h@..
    16:48:23.919 00f0: 50 38 60 a0 0b 05 d3 03 f0 P8`......
    16:48:23.935 Incoming Dump:
    16:48:23.935 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.935 --
    16:48:23.935 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.935 Parameters:
    16:48:23.935 | Number HCI commands : 0x01
    16:48:23.935 | Command Opcode : 0xff05
    16:48:23.935 | Status : 0x00 (Success)
    16:48:23.935 --
    16:48:23.951 --
    16:48:23.951 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.951 Parameters:
    16:48:23.951 | Address : 0x20004920
    16:48:23.951 | Size : 0xf0
    16:48:23.951 | Values : "F2:FC:38:68:40:F4:00:50:38:60:60:0C:03:D3:38:68:40:F4:80:30:38:60:E0:0C:05:D3:03:F0:57:FB:38:68:40:F4:80:20:38:60:20:0D:05:D3:03:F0:94:FC:38:68:40:F4:00:20:38:60:29:6B:38:68:4C:46:08:43:28:63:12:E0:01:79:01:27:02:78:37:70:41:20:77:70:FF:F7:19:F9:4C:46:69:89:40:46:84:F8:31:70:01:29:08:BF:38:1C:F0:71:FE:F7:9C:FC:08:20:20:80:BD:E8:F0:83:C8:00:01:20:04:F0:0E:20:08:00:01:20:9B:08:01:20:50:02:01:20:C4:01:01:20:88:13:28:22:1E:40:01:20:70:B5:6D:4C:84:F8:B8:0F:02:20:FF:F7:CF:F8:6B:4E:01:25:02:20:35:70:FF:F7:C9:F8:00:20:30:70:02:20:FF:F7:C4:F8:20:88:20:F0:20:00:40:F0:10:00:20:80:06:20:FF:F7:BB:F8:20:88:20:F0:10:00:40:F0:20:00:20:80:28:46:FF:F7:B2:F8:20:88:20:F0:30:00:20:80:0A:20:B4:F8:4C:40:FF:F7:A9:F8:20:46:70:BD:2D:E9"
    16:48:23.951 --
    16:48:23.951 Outgoing Dump:
    16:48:23.951 0000: 01 05 ff f5 20 49 00 20 f0 f2 fc 38 68 40 f4 00 .... I. ...8h@..
    16:48:23.951 0010: 50 38 60 60 0c 03 d3 38 68 40 f4 80 30 38 60 e0 P8``...8h@..08`.
    16:48:23.951 0020: 0c 05 d3 03 f0 57 fb 38 68 40 f4 80 20 38 60 20 .....W.8h@.. 8`
    16:48:23.951 0030: 0d 05 d3 03 f0 94 fc 38 68 40 f4 00 20 38 60 29 .......8h@.. 8`)
    16:48:23.951 0040: 6b 38 68 4c 46 08 43 28 63 12 e0 01 79 01 27 02 k8hLF.C(c...y.'.
    16:48:23.951 0050: 78 37 70 41 20 77 70 ff f7 19 f9 4c 46 69 89 40 x7pA wp....LFi.@
    16:48:23.951 0060: 46 84 f8 31 70 01 29 08 bf 38 1c f0 71 fe f7 9c F..1p.)..8..q...
    16:48:23.951 0070: fc 08 20 20 80 bd e8 f0 83 c8 00 01 20 04 f0 0e .. ........ ...
    16:48:23.951 0080: 20 08 00 01 20 9b 08 01 20 50 02 01 20 c4 01 01 ... ... P.. ...
    16:48:23.951 0090: 20 88 13 28 22 1e 40 01 20 70 b5 6d 4c 84 f8 b8 ..(".@. p.mL...
    16:48:23.951 00a0: 0f 02 20 ff f7 cf f8 6b 4e 01 25 02 20 35 70 ff .. ....kN.%. 5p.
    16:48:23.951 00b0: f7 c9 f8 00 20 30 70 02 20 ff f7 c4 f8 20 88 20 .... 0p. .... .
    16:48:23.951 00c0: f0 20 00 40 f0 10 00 20 80 06 20 ff f7 bb f8 20 . .@... .. ....
    16:48:23.951 00d0: 88 20 f0 10 00 40 f0 20 00 20 80 28 46 ff f7 b2 . ...@. . .(F...
    16:48:23.951 00e0: f8 20 88 20 f0 30 00 20 80 0a 20 b4 f8 4c 40 ff . . .0. .. ..L@.
    16:48:23.951 00f0: f7 a9 f8 20 46 70 bd 2d e9 ... Fp.-.
    16:48:23.982 Incoming Dump:
    16:48:23.982 0000: 04 0e 04 01 05 ff 00 .......
    16:48:23.982 --
    16:48:23.982 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:23.982 Parameters:
    16:48:23.982 | Number HCI commands : 0x01
    16:48:23.982 | Command Opcode : 0xff05
    16:48:23.982 | Status : 0x00 (Success)
    16:48:23.982 --
    16:48:23.982 --
    16:48:23.982 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:23.982 | Address : 0x20004a10
    16:48:23.982 | Size : 0xf0
    16:48:23.982 | Values : "FC:4F:57:48:57:49:00:88:58:4E:4F:F0:01:0B:56:4C:AD:F8:00:00:41:F6:82:50:08:80:70:78:A4:F8:88:B0:4F:F0:00:08:01:90:40:46:86:F8:01:B0:02:28:30:70:4B:DA:DF:F8:3C:A1:81:46:40:46:FD:F7:73:FA:0A:20:FF:F7:84:F8:30:78:1D:F8:00:50:28:46:FF:F7:A8:FF:07:46:60:8A:B8:42:05:DB:A0:8A:B8:42:C8:BF:4F:F0:FF:39:00:E0:D9:46:31:78:3A:46:40:20:FF:F7:92:F8:0F:E0:09:EB:05:00:C5:B2:28:46:FF:F7:91:FF:07:46:DA:F8:00:00:40:0E:04:D3:3A:46:29:46:3F:20:FF:F7:81:F8:0F:2D:06:DA:2D:B1:60:8A:B8:42:E9:DB:A0:8A:B8:42:E6:DC:3A:46:29:46:3F:20:FF:F7:73:F8:30:78:20:18:05:74:00:F0:62:F8:0A:20:FF:F7:47:F8:30:78:40:1C:C0:B2:30:70:02:28:B6:DB:01:98:A4:F8:88:80:70:70:BD:E8:FC:8F:26:48:0C:38:00:88:C0:F3:01:21:01:29:14:BF:07:22:0B:22:1F:4B:D8:8A:20:F4:F8:40"
    16:48:23.982 --
    16:48:23.982 Outgoing Dump:
    16:48:23.982 0000: 01 05 ff f5 10 4a 00 20 f0 fc 4f 57 48 57 49 00 .....J. ..OWHWI.
    16:48:23.982 0010: 88 58 4e 4f f0 01 0b 56 4c ad f8 00 00 41 f6 82 .XNO...VL....A..
    16:48:23.982 0020: 50 08 80 70 78 a4 f8 88 b0 4f f0 00 08 01 90 40 P..px....O.....@
    16:48:23.982 0030: 46 86 f8 01 b0 02 28 30 70 4b da df f8 3c a1 81 F.....(0pK...<..
    16:48:23.982 0040: 46 40 46 fd f7 73 fa 0a 20 ff f7 84 f8 30 78 1d F@F..s.. ....0x.
    16:48:23.982 0050: f8 00 50 28 46 ff f7 a8 ff 07 46 60 8a b8 42 05 ..P(F.....F`..B.
    16:48:23.982 0060: db a0 8a b8 42 c8 bf 4f f0 ff 39 00 e0 d9 46 31 ....B..O..9...F1
    16:48:23.982 0070: 78 3a 46 40 20 ff f7 92 f8 0f e0 09 eb 05 00 c5 x:F@ ...........
    16:48:23.982 0080: b2 28 46 ff f7 91 ff 07 46 da f8 00 00 40 0e 04 .(F.....F....@..
    16:48:23.982 0090: d3 3a 46 29 46 3f 20 ff f7 81 f8 0f 2d 06 da 2d .:F)F? .....-..-
    16:48:23.982 00a0: b1 60 8a b8 42 e9 db a0 8a b8 42 e6 dc 3a 46 29 .`..B.....B..:F)
    16:48:23.982 00b0: 46 3f 20 ff f7 73 f8 30 78 20 18 05 74 00 f0 62 F? ..s.0x ..t..b
    16:48:23.982 00c0: f8 0a 20 ff f7 47 f8 30 78 40 1c c0 b2 30 70 02 .. ..G.0x@...0p.
    16:48:23.982 00d0: 28 b6 db 01 98 a4 f8 88 80 70 70 bd e8 fc 8f 26 (........pp....&
    16:48:23.982 00e0: 48 0c 38 00 88 c0 f3 01 21 01 29 14 bf 07 22 0b H.8.....!.)...".
    16:48:23.982 00f0: 22 1f 4b d8 8a 20 f4 f8 40 ".K.. ..@
    16:48:24.013 Incoming Dump:
    16:48:24.013 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.013 --
    16:48:24.013 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.013 Parameters:
    16:48:24.013 | Number HCI commands : 0x01
    16:48:24.013 | Command Opcode : 0xff05
    16:48:24.013 | Status : 0x00 (Success)
    16:48:24.013 --
    16:48:24.013 --
    16:48:24.013 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.013 | Address : 0x20004b00
    16:48:24.013 | Size : 0xf0
    16:48:24.013 | Values : "40:EA:82:20:D8:82:5C:20:FF:F7:4C:B8:1C:4B:5C:3B:18:78:01:28:26:D1:93:F8:53:10:1B:4A:19:48:04:29:13:DB:0A:29:08:DA:12:88:01:88:52:10:21:F4:F0:61:02:F4:F0:62:0A:43:0C:E0:11:88:02:88:01:F0:F0:01:22:F4:F0:62:42:EA:C1:02:03:E0:11:88:02:88:61:F3:CA:12:02:80:02:88:93:F8:53:10:20:20:02:F4:F0:62:FF:F7:20:B8:70:47:C0:46:60:A0:01:20:98:0C:34:22:94:50:00:00:00:00:01:20:50:02:01:20:9E:08:01:20:B0:01:01:20:1C:B0:01:20:6A:02:01:20:2D:E9:F0:4F:53:48:00:68:DF:F8:58:B1:00:08:07:D3:51:48:01:78:58:46:08:30:02:78:4F:20:FE:F7:FC:FF:4E:48:4F:F0:01:08:80:F8:00:80:DF:F8:54:91:80:F8:20:80:4B:48:4C:4F:80:F8:00:80:B7:F8:5A:00:50:B9:04:20:FF:F7:77:F8:00:21:48:46:44:38:01:80:41:F2:08:00:FF:F7:1F:F8:00:24:44:4E:97:F8:AA:00:44:4D:34:84:85:F8"
    16:48:24.013 --
    16:48:24.013 Outgoing Dump:
    16:48:24.013 0000: 01 05 ff f5 00 4b 00 20 f0 40 ea 82 20 d8 82 5c .....K. .@.. ..\
    16:48:24.013 0010: 20 ff f7 4c b8 1c 4b 5c 3b 18 78 01 28 26 d1 93 ..L..K\;.x.(&..
    16:48:24.013 0020: f8 53 10 1b 4a 19 48 04 29 13 db 0a 29 08 da 12 .S..J.H.)...)...
    16:48:24.013 0030: 88 01 88 52 10 21 f4 f0 61 02 f4 f0 62 0a 43 0c ...R.!..a...b.C.
    16:48:24.013 0040: e0 11 88 02 88 01 f0 f0 01 22 f4 f0 62 42 ea c1 ........."..bB..
    16:48:24.013 0050: 02 03 e0 11 88 02 88 61 f3 ca 12 02 80 02 88 93 .......a........
    16:48:24.013 0060: f8 53 10 20 20 02 f4 f0 62 ff f7 20 b8 70 47 c0 .S. ...b.. .pG.
    16:48:24.013 0070: 46 60 a0 01 20 98 0c 34 22 94 50 00 00 00 00 01 F`.. ..4".P.....
    16:48:24.013 0080: 20 50 02 01 20 9e 08 01 20 b0 01 01 20 1c b0 01 P.. ... ... ...
    16:48:24.013 0090: 20 6a 02 01 20 2d e9 f0 4f 53 48 00 68 df f8 58 j.. -..OSH.h..X
    16:48:24.013 00a0: b1 00 08 07 d3 51 48 01 78 58 46 08 30 02 78 4f .....QH.xXF.0.xO
    16:48:24.013 00b0: 20 fe f7 fc ff 4e 48 4f f0 01 08 80 f8 00 80 df ....NHO........
    16:48:24.013 00c0: f8 54 91 80 f8 20 80 4b 48 4c 4f 80 f8 00 80 b7 .T... .KHLO.....
    16:48:24.013 00d0: f8 5a 00 50 b9 04 20 ff f7 77 f8 00 21 48 46 44 .Z.P.. ..w..!HFD
    16:48:24.013 00e0: 38 01 80 41 f2 08 00 ff f7 1f f8 00 24 44 4e 97 8..A........$DN.
    16:48:24.013 00f0: f8 aa 00 44 4d 34 84 85 f8 ...DM4...
    16:48:24.044 Incoming Dump:
    16:48:24.044 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.044 --
    16:48:24.044 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.044 Parameters:
    16:48:24.044 | Number HCI commands : 0x01
    16:48:24.044 | Command Opcode : 0xff05
    16:48:24.044 | Status : 0x00 (Success)
    16:48:24.044 --
    16:48:24.044 --
    16:48:24.044 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.044 | Address : 0x20004bf0
    16:48:24.044 | Size : 0xf0
    16:48:24.044 | Values : "30:05:43:49:86:F8:00:80:9B:F8:00:00:05:F8:1F:4C:85:F8:E8:40:81:F8:03:07:3E:48:DF:F8:FC:A0:04:70:3F:48:8A:F8:70:43:8A:F8:74:43:00:88:20:F4:C0:60:A9:F8:CC:0F:3B:48:8A:F8:60:43:04:70:89:F8:A6:4F:08:46:89:F8:A4:4F:80:F8:FF:46:B7:F9:56:00:80:08:89:F8:00:40:05:D3:9B:F8:37:00:10:B1:4F:F0:03:00:68:85:38:78:28:72:78:78:68:72:FB:F7:E1:FF:8A:F8:50:83:8A:F8:00:40:B9:F8:E2:0F:20:F4:40:60:A9:F8:E2:0F:24:48:80:F8:A4:40:28:88:8B:F8:01:40:20:F0:06:00:28:80:19:48:8A:F8:0C:47:80:F8:48:40:B5:F8:F0:00:8B:F8:02:40:20:F0:70:00:A5:F8:F0:00:13:48:80:F8:3C:40:16:48:04:70:34:70:F0:69:BC:86:20:F4:80:30:F0:61:18:48:8B:F8:2E:40:00:78:26:F8:08:4C:06:F8:27:4C:06:F8:25:4C:38:B1:40:1E:41:46:13:4A:01:FA:00:F0:11:88:81:43:11:80:BD:E8:F0:8F:C0:46"
    16:48:24.044 --
    16:48:24.044 Outgoing Dump:
    16:48:24.044 0000: 01 05 ff f5 f0 4b 00 20 f0 30 05 43 49 86 f8 00 .....K. .0.CI...
    16:48:24.044 0010: 80 9b f8 00 00 05 f8 1f 4c 85 f8 e8 40 81 f8 03 ........L...@...
    16:48:24.044 0020: 07 3e 48 df f8 fc a0 04 70 3f 48 8a f8 70 43 8a .>H.....p?H..pC.
    16:48:24.044 0030: f8 74 43 00 88 20 f4 c0 60 a9 f8 cc 0f 3b 48 8a .tC.. ..`....;H.
    16:48:24.044 0040: f8 60 43 04 70 89 f8 a6 4f 08 46 89 f8 a4 4f 80 .`C.p...O.F...O.
    16:48:24.044 0050: f8 ff 46 b7 f9 56 00 80 08 89 f8 00 40 05 d3 9b ..F..V......@...
    16:48:24.044 0060: f8 37 00 10 b1 4f f0 03 00 68 85 38 78 28 72 78 .7...O...h.8x(rx
    16:48:24.044 0070: 78 68 72 fb f7 e1 ff 8a f8 50 83 8a f8 00 40 b9 xhr......P....@.
    16:48:24.044 0080: f8 e2 0f 20 f4 40 60 a9 f8 e2 0f 24 48 80 f8 a4 ... .@`....$H...
    16:48:24.044 0090: 40 28 88 8b f8 01 40 20 f0 06 00 28 80 19 48 8a @(....@ ...(..H.
    16:48:24.044 00a0: f8 0c 47 80 f8 48 40 b5 f8 f0 00 8b f8 02 40 20 ..G..H@.......@
    16:48:24.044 00b0: f0 70 00 a5 f8 f0 00 13 48 80 f8 3c 40 16 48 04 .p......H..<@.H.
    16:48:24.044 00c0: 70 34 70 f0 69 bc 86 20 f4 80 30 f0 61 18 48 8b p4p.i.. ..0.a.H.
    16:48:24.044 00d0: f8 2e 40 00 78 26 f8 08 4c 06 f8 27 4c 06 f8 25 ..@.x&..L..'L..%
    16:48:24.044 00e0: 4c 38 b1 40 1e 41 46 13 4a 01 fa 00 f0 11 88 81 L8.@.AF.J.......
    16:48:24.044 00f0: 43 11 80 bd e8 f0 8f c0 46 C.......F
    16:48:24.076 Incoming Dump:
    16:48:24.076 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.076 --
    16:48:24.076 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.076 Parameters:
    16:48:24.076 | Number HCI commands : 0x01
    16:48:24.076 | Command Opcode : 0xff05
    16:48:24.076 | Status : 0x00 (Success)
    16:48:24.076 --
    16:48:24.076 --
    16:48:24.076 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.076 | Address : 0x20004ce0
    16:48:24.076 | Size : 0xf0
    16:48:24.076 | Values : "B0:01:01:20:E2:08:01:20:28:11:28:22:24:20:3E:22:9A:08:01:20:7E:02:01:20:74:40:01:20:28:B0:01:20:01:F1:01:20:80:22:36:22:40:05:34:22:78:90:01:20:44:A0:01:20:14:07:3F:22:F2:00:01:20:04:F0:0E:20:00:2A:4A:D0:5F:EA:00:0C:8B:07:1C:D1:83:07:22:D1:10:2A:08:D3:70:B4:10:3A:78:C9:78:C0:10:3A:FB:D2:70:BC:10:32:38:D0:04:2A:2C:D3:08:2A:05:D3:0C:2A:24:BF:08:C9:08:C0:08:C9:08:C0:08:C9:08:C0:92:07:2A:D0:92:0F:22:E0:0B:78:03:70:49:1C:40:1C:52:1E:22:D0:8B:07:F7:D1:C3:07:14:D1:83:07:D8:D0:12:1F:12:D3:08:C9:03:80:1B:0C:43:80:00:1D:12:1F:F8:D2:0A:E0:08:C9:03:70:1B:0A:43:70:1B:0A:83:70:1B:0A:C3:70:00:1D:12:1F:F4:D2:12:1D:05:D0:0B:78:03:70:49:1C:40:1C:52:1E:F9:D1:60:46:70:47:70:B5:19:4D:1B:4C:E8:79:A0:B9:26:46:17:48:2F:3E:01:68:30:68"
    16:48:24.076 --
    16:48:24.076 Outgoing Dump:
    16:48:24.076 0000: 01 05 ff f5 e0 4c 00 20 f0 b0 01 01 20 e2 08 01 .....L. .... ...
    16:48:24.076 0010: 20 28 11 28 22 24 20 3e 22 9a 08 01 20 7e 02 01 (.("$ >"... ~..
    16:48:24.076 0020: 20 74 40 01 20 28 b0 01 20 01 f1 01 20 80 22 36 t@. (.. ... ."6
    16:48:24.076 0030: 22 40 05 34 22 78 90 01 20 44 a0 01 20 14 07 3f "@.4"x.. D.. ..?
    16:48:24.076 0040: 22 f2 00 01 20 04 f0 0e 20 00 2a 4a d0 5f ea 00 "... ... .*J._..
    16:48:24.076 0050: 0c 8b 07 1c d1 83 07 22 d1 10 2a 08 d3 70 b4 10 ......."..*..p..
    16:48:24.076 0060: 3a 78 c9 78 c0 10 3a fb d2 70 bc 10 32 38 d0 04 :x.x..:..p..28..
    16:48:24.076 0070: 2a 2c d3 08 2a 05 d3 0c 2a 24 bf 08 c9 08 c0 08 *,..*...*$......
    16:48:24.076 0080: c9 08 c0 08 c9 08 c0 92 07 2a d0 92 0f 22 e0 0b .........*..."..
    16:48:24.076 0090: 78 03 70 49 1c 40 1c 52 1e 22 d0 8b 07 f7 d1 c3 x.pI.@.R."......
    16:48:24.076 00a0: 07 14 d1 83 07 d8 d0 12 1f 12 d3 08 c9 03 80 1b ................
    16:48:24.076 00b0: 0c 43 80 00 1d 12 1f f8 d2 0a e0 08 c9 03 70 1b .C............p.
    16:48:24.076 00c0: 0a 43 70 1b 0a 83 70 1b 0a c3 70 00 1d 12 1f f4 .Cp...p...p.....
    16:48:24.076 00d0: d2 12 1d 05 d0 0b 78 03 70 49 1c 40 1c 52 1e f9 ......x.pI.@.R..
    16:48:24.076 00e0: d1 60 46 70 47 70 b5 19 4d 1b 4c e8 79 a0 b9 26 .`FpGp..M.L.y..&
    16:48:24.076 00f0: 46 17 48 2f 3e 01 68 30 68 F.H/>.h0h
    16:48:24.107 Incoming Dump:
    16:48:24.107 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.107 --
    16:48:24.107 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.107 Parameters:
    16:48:24.107 | Number HCI commands : 0x01
    16:48:24.107 | Command Opcode : 0xff05
    16:48:24.107 | Status : 0x00 (Success)
    16:48:24.107 --
    16:48:24.107 --
    16:48:24.107 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.107 | Address : 0x20004dd0
    16:48:24.107 | Size : 0xca
    16:48:24.107 | Values : "81:42:81:EA:00:02:06:BF:44:20:0A:1C:47:20:1F:FA:A2:F1:92:B2:FE:F7:DE:FE:71:79:61:B1:46:20:06:E0:28:78:40:B9:68:78:30:B9:0C:48:01:78:45:20:41:F2:11:12:FE:F7:CF:FE:4F:F0:00:00:21:78:28:70:68:70:31:B1:49:1E:01:20:07:4A:88:40:11:88:81:43:11:80:70:BD:C0:46:9B:08:01:20:08:00:01:20:E2:08:01:20:F7:00:01:20:04:F0:0E:20:00:0C:01:20:5F:F8:08:00:85:46:07:48:01:78:4F:F0:00:02:02:70:00:29:7E:F4:DF:AA:FE:F7:17:FB:FE:F7:05:FB:FE:F7:D9:FA:00:00:50:02:01:20:01:48:02:49:01:60:FE:E7:0C:ED:00:E0:01:00:FA:05:5F:F8:40:00:85:46:FE:F7:C9:FA:43:F2:0A:00:4F:F0:02:01:06:9A:FE:F7:8C:FE:FE:E7:01:20:FD:F7:50:B8:01:20:FC:F7:CD:B8"
    16:48:24.107 --
    16:48:24.107 Outgoing Dump:
    16:48:24.107 0000: 01 05 ff cf d0 4d 00 20 ca 81 42 81 ea 00 02 06 .....M. ..B.....
    16:48:24.107 0010: bf 44 20 0a 1c 47 20 1f fa a2 f1 92 b2 fe f7 de .D ..G .........
    16:48:24.107 0020: fe 71 79 61 b1 46 20 06 e0 28 78 40 b9 68 78 30 .qya.F ..(x@.hx0
    16:48:24.107 0030: b9 0c 48 01 78 45 20 41 f2 11 12 fe f7 cf fe 4f ..H.xE A.......O
    16:48:24.107 0040: f0 00 00 21 78 28 70 68 70 31 b1 49 1e 01 20 07 ...!x(php1.I.. .
    16:48:24.107 0050: 4a 88 40 11 88 81 43 11 80 70 bd c0 46 9b 08 01 J.@...C..p..F...
    16:48:24.107 0060: 20 08 00 01 20 e2 08 01 20 f7 00 01 20 04 f0 0e ... ... ... ...
    16:48:24.107 0070: 20 00 0c 01 20 5f f8 08 00 85 46 07 48 01 78 4f ... _....F.H.xO
    16:48:24.107 0080: f0 00 02 02 70 00 29 7e f4 df aa fe f7 17 fb fe ....p.)~........
    16:48:24.107 0090: f7 05 fb fe f7 d9 fa 00 00 50 02 01 20 01 48 02 .........P.. .H.
    16:48:24.107 00a0: 49 01 60 fe e7 0c ed 00 e0 01 00 fa 05 5f f8 40 I.`.........._.@
    16:48:24.107 00b0: 00 85 46 fe f7 c9 fa 43 f2 0a 00 4f f0 02 01 06 ..F....C...O....
    16:48:24.107 00c0: 9a fe f7 8c fe fe e7 01 20 fd f7 50 b8 01 20 fc ........ ..P.. .
    16:48:24.107 00d0: f7 cd b8 ...
    16:48:24.138 Incoming Dump:
    16:48:24.138 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.138 --
    16:48:24.138 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.138 Parameters:
    16:48:24.138 | Number HCI commands : 0x01
    16:48:24.138 | Command Opcode : 0xff05
    16:48:24.138 | Status : 0x00 (Success)
    16:48:24.138 --
    16:48:24.138 --
    16:48:24.138 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.138 | Address : 0x20004e9c
    16:48:24.138 | Size : 0xf0
    16:48:24.138 | Values : "01:00:00:00:E1:08:01:20:00:C0:46:C0:01:00:00:00:E2:08:01:20:00:C0:46:C0:01:00:00:00:E3:08:01:20:00:C0:46:C0:01:00:00:00:E4:08:01:20:00:C0:46:C0:90:01:00:00:70:5E:00:00:45:13:F0:EE:0F:32:54:55:34:01:FF:FF:10:11:01:FF:FF:10:11:01:FF:FF:00:09:00:32:54:55:34:01:DE:BC:BB:DC:0F:21:11:F0:FF:0F:11:11:F0:FF:0F:11:11:00:F7:03:45:13:F0:EE:0F:32:54:55:55:55:45:13:E0:CD:BB:CB:FD:10:12:01:FF:FF:00:09:00:32:54:55:55:55:45:13:F0:FE:0F:11:11:F0:FF:0F:11:11:F0:FF:0F:11:11:00:00:00:CB:FD:10:12:01:FF:FF:10:11:01:FF:FF:10:43:55:55:55:55:34:01:FF:FF:00:3B:00:11:11:F0:FF:0F:32:54:55:34:01:FF:FF:10:11:01:FF:FF:10:11:01:FF:FF:00:09:00:32:54:55:34:01:EF:FE:20:43:55:45:13:E0:CD:BB:CB:FD:10:12:01:FF:FF:00:FF:03:21:11:F0:FF:0F:11:11:F0:FF"
    16:48:24.138 --
    16:48:24.138 Outgoing Dump:
    16:48:24.138 0000: 01 05 ff f5 9c 4e 00 20 f0 01 00 00 00 e1 08 01 .....N. ........
    16:48:24.138 0010: 20 00 c0 46 c0 01 00 00 00 e2 08 01 20 00 c0 46 ..F........ ..F
    16:48:24.138 0020: c0 01 00 00 00 e3 08 01 20 00 c0 46 c0 01 00 00 ........ ..F....
    16:48:24.138 0030: 00 e4 08 01 20 00 c0 46 c0 90 01 00 00 70 5e 00 .... ..F.....p^.
    16:48:24.138 0040: 00 45 13 f0 ee 0f 32 54 55 34 01 ff ff 10 11 01 .E....2TU4......
    16:48:24.138 0050: ff ff 10 11 01 ff ff 00 09 00 32 54 55 34 01 de ..........2TU4..
    16:48:24.138 0060: bc bb dc 0f 21 11 f0 ff 0f 11 11 f0 ff 0f 11 11 ....!...........
    16:48:24.138 0070: 00 f7 03 45 13 f0 ee 0f 32 54 55 55 55 45 13 e0 ...E....2TUUUE..
    16:48:24.138 0080: cd bb cb fd 10 12 01 ff ff 00 09 00 32 54 55 55 ............2TUU
    16:48:24.138 0090: 55 45 13 f0 fe 0f 11 11 f0 ff 0f 11 11 f0 ff 0f UE..............
    16:48:24.138 00a0: 11 11 00 00 00 cb fd 10 12 01 ff ff 10 11 01 ff ................
    16:48:24.138 00b0: ff 10 43 55 55 55 55 34 01 ff ff 00 3b 00 11 11 ..CUUUU4....;...
    16:48:24.138 00c0: f0 ff 0f 32 54 55 34 01 ff ff 10 11 01 ff ff 10 ...2TU4.........
    16:48:24.138 00d0: 11 01 ff ff 00 09 00 32 54 55 34 01 ef fe 20 43 .......2TU4... C
    16:48:24.138 00e0: 55 45 13 e0 cd bb cb fd 10 12 01 ff ff 00 ff 03 UE..............
    16:48:24.138 00f0: 21 11 f0 ff 0f 11 11 f0 ff !........
    16:48:24.169 Incoming Dump:
    16:48:24.169 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.169 --
    16:48:24.169 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.169 Parameters:
    16:48:24.169 | Number HCI commands : 0x01
    16:48:24.169 | Command Opcode : 0xff05
    16:48:24.169 | Status : 0x00 (Success)
    16:48:24.169 --
    16:48:24.169 --
    16:48:24.169 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.169 | Address : 0x20004f8c
    16:48:24.169 | Size : 0xf0
    16:48:24.169 | Values : "0F:11:11:F0:FF:0F:11:11:F0:FF:0F:11:11:00:00:00:45:13:E0:CD:BB:BB:BB:BB:DC:0F:32:54:55:34:01:FF:FF:10:11:01:FF:FF:00:10:00:45:13:F0:FF:0F:11:11:F0:FF:0F:32:54:55:34:01:FF:FF:10:11:01:FF:FF:00:18:00:32:54:55:34:01:EF:FE:20:43:55:45:13:F0:FF:0F:11:11:F0:FF:0F:11:11:00:22:00:21:12:E0:CD:BB:CB:FD:10:12:01:FF:FF:10:11:01:FF:FF:10:11:01:FF:FF:00:00:00:32:54:55:34:01:DE:BC:BB:DC:0F:32:54:55:34:01:FF:FF:10:11:01:FF:FF:00:10:00:32:54:55:34:01:EF:FE:20:43:55:45:13:F0:FF:0F:11:11:F0:FF:0F:11:11:00:22:00:EF:FF:10:12:01:DE:BC:BB:BB:BB:CB:FD:20:43:55:45:13:F0:FF:0F:11:11:00:F8:03:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:00:00:00:DD:08:01:20:00:C0:46:C0:01:00:00:00:E0:08:01:20:00:00:00:00"
    16:48:24.169 --
    16:48:24.169 Outgoing Dump:
    16:48:24.169 0000: 01 05 ff f5 8c 4f 00 20 f0 0f 11 11 f0 ff 0f 11 .....O. ........
    16:48:24.169 0010: 11 f0 ff 0f 11 11 00 00 00 45 13 e0 cd bb bb bb .........E......
    16:48:24.169 0020: bb dc 0f 32 54 55 34 01 ff ff 10 11 01 ff ff 00 ...2TU4.........
    16:48:24.169 0030: 10 00 45 13 f0 ff 0f 11 11 f0 ff 0f 32 54 55 34 ..E.........2TU4
    16:48:24.169 0040: 01 ff ff 10 11 01 ff ff 00 18 00 32 54 55 34 01 ...........2TU4.
    16:48:24.169 0050: ef fe 20 43 55 45 13 f0 ff 0f 11 11 f0 ff 0f 11 .. CUE..........
    16:48:24.169 0060: 11 00 22 00 21 12 e0 cd bb cb fd 10 12 01 ff ff ..".!...........
    16:48:24.169 0070: 10 11 01 ff ff 10 11 01 ff ff 00 00 00 32 54 55 .............2TU
    16:48:24.169 0080: 34 01 de bc bb dc 0f 32 54 55 34 01 ff ff 10 11 4......2TU4.....
    16:48:24.169 0090: 01 ff ff 00 10 00 32 54 55 34 01 ef fe 20 43 55 ......2TU4... CU
    16:48:24.169 00a0: 45 13 f0 ff 0f 11 11 f0 ff 0f 11 11 00 22 00 ef E............"..
    16:48:24.169 00b0: ff 10 12 01 de bc bb bb bb cb fd 20 43 55 45 13 ........... CUE.
    16:48:24.169 00c0: f0 ff 0f 11 11 00 f8 03 00 00 00 00 00 00 00 00 ................
    16:48:24.169 00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:24.169 00e0: 00 01 00 00 00 dd 08 01 20 00 c0 46 c0 01 00 00 ........ ..F....
    16:48:24.169 00f0: 00 e0 08 01 20 00 00 00 00 .... ....
    16:48:24.201 Incoming Dump:
    16:48:24.201 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.201 --
    16:48:24.201 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.201 Parameters:
    16:48:24.201 | Number HCI commands : 0x01
    16:48:24.201 | Command Opcode : 0xff05
    16:48:24.201 | Status : 0x00 (Success)
    16:48:24.201 --
    16:48:24.201 --
    16:48:24.201 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.201 | Address : 0x2000507c
    16:48:24.201 | Size : 0x1a
    16:48:24.201 | Values : "00:00:00:00:89:09:6E:09:A3:09:C0:46:00:F4:0C:00:2C:37:40:4A:0C:03:00:00:06:06"
    16:48:24.201 --
    16:48:24.201 Outgoing Dump:
    16:48:24.201 0000: 01 05 ff 1f 7c 50 00 20 1a 00 00 00 00 89 09 6e ....|P. .......n
    16:48:24.201 0010: 09 a3 09 c0 46 00 f4 0c 00 2c 37 40 4a 0c 03 00 ....F....,7@J...
    16:48:24.201 0020: 00 06 06 ...
    16:48:24.216 Incoming Dump:
    16:48:24.216 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.216 --
    16:48:24.216 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.216 Parameters:
    16:48:24.216 | Number HCI commands : 0x01
    16:48:24.216 | Command Opcode : 0xff05
    16:48:24.216 | Status : 0x00 (Success)
    16:48:24.216 --
    16:48:24.216 --
    16:48:24.216 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.216 | Address : 0x20006300
    16:48:24.216 | Size : 0xf0
    16:48:24.216 | Values : "83:00:0B:00:03:00:03:00:03:00:03:01:13:00:03:00:03:00:03:00:03:01:13:00:03:00:03:00:03:00:03:01:13:00:03:00:03:00:03:00:03:01:13:00:03:00:03:00:03:00:03:01:13:00:03:00:03:00:03:00:03:01:13:00:03:00:03:00:03:00:03:02:23:00:03:00:03:00:03:00:03:02:23:00:03:00:03:00:03:00:03:02:23:00:03:00:03:00:03:00:03:02:23:00:03:00:03:00:03:00:03:02:23:00:03:00:03:00:03:00:03:04:43:00:03:00:03:00:03:00:03:04:43:00:03:00:03:00:03:00:03:04:43:00:03:00:03:00:03:00:03:04:43:00:03:00:03:00:03:00:11:11:01:01:01:22:22:02:02:02:22:22:02:02:02:22:22:02:02:02:22:22:02:02:02:22:22:02:02:02:22:22:02:02:02:44:44:04:04:04:44:44:04:04:04:44:44:04:04:04:44:44:04:04:04:44:44:04:04:04:88:88:08:08:08:88:88:08:08:08:88:88:08:08:08:88:88:08:08:08"
    16:48:24.216 --
    16:48:24.216 Outgoing Dump:
    16:48:24.216 0000: 01 05 ff f5 00 63 00 20 f0 83 00 0b 00 03 00 03 .....c. ........
    16:48:24.216 0010: 00 03 00 03 01 13 00 03 00 03 00 03 00 03 01 13 ................
    16:48:24.216 0020: 00 03 00 03 00 03 00 03 01 13 00 03 00 03 00 03 ................
    16:48:24.216 0030: 00 03 01 13 00 03 00 03 00 03 00 03 01 13 00 03 ................
    16:48:24.216 0040: 00 03 00 03 00 03 01 13 00 03 00 03 00 03 00 03 ................
    16:48:24.216 0050: 02 23 00 03 00 03 00 03 00 03 02 23 00 03 00 03 .#.........#....
    16:48:24.216 0060: 00 03 00 03 02 23 00 03 00 03 00 03 00 03 02 23 .....#.........#
    16:48:24.216 0070: 00 03 00 03 00 03 00 03 02 23 00 03 00 03 00 03 .........#......
    16:48:24.216 0080: 00 03 04 43 00 03 00 03 00 03 00 03 04 43 00 03 ...C.........C..
    16:48:24.216 0090: 00 03 00 03 00 03 04 43 00 03 00 03 00 03 00 03 .......C........
    16:48:24.216 00a0: 04 43 00 03 00 03 00 03 00 11 11 01 01 01 22 22 .C............""
    16:48:24.216 00b0: 02 02 02 22 22 02 02 02 22 22 02 02 02 22 22 02 ...""...""..."".
    16:48:24.216 00c0: 02 02 22 22 02 02 02 22 22 02 02 02 44 44 04 04 ..""...""...DD..
    16:48:24.216 00d0: 04 44 44 04 04 04 44 44 04 04 04 44 44 04 04 04 .DD...DD...DD...
    16:48:24.216 00e0: 44 44 04 04 04 88 88 08 08 08 88 88 08 08 08 88 DD..............
    16:48:24.216 00f0: 88 08 08 08 88 88 08 08 08 .........
    16:48:24.247 Incoming Dump:
    16:48:24.247 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.247 --
    16:48:24.247 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.247 Parameters:
    16:48:24.247 | Number HCI commands : 0x01
    16:48:24.247 | Command Opcode : 0xff05
    16:48:24.247 | Status : 0x00 (Success)
    16:48:24.247 --
    16:48:24.247 --
    16:48:24.247 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.247 | Address : 0x200063f0
    16:48:24.247 | Size : 0xf0
    16:48:24.247 | Values : "01:01:11:11:11:02:02:22:22:22:02:02:22:22:22:02:02:22:22:22:02:02:22:22:22:02:02:22:22:22:02:02:22:22:22:04:04:44:44:44:04:04:44:44:44:04:04:44:44:44:04:04:44:44:44:04:04:44:44:44:08:08:88:88:88:08:08:88:88:88:08:08:88:88:88:08:08:88:88:88:16:16:16:0B:0B:14:14:14:0A:0A:14:14:14:0A:0A:14:14:14:0A:0A:12:12:12:09:09:12:12:12:09:09:12:12:12:09:09:10:10:10:08:08:10:10:10:08:08:10:10:10:08:08:0E:0E:0E:07:07:0E:0E:0E:07:07:0E:0E:0E:07:07:0C:0C:0C:06:06:0C:0C:0C:06:06:0C:0C:0C:06:06:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4:A4"
    16:48:24.247 --
    16:48:24.247 Outgoing Dump:
    16:48:24.247 0000: 01 05 ff f5 f0 63 00 20 f0 01 01 11 11 11 02 02 .....c. ........
    16:48:24.247 0010: 22 22 22 02 02 22 22 22 02 02 22 22 22 02 02 22 """.."""..""".."
    16:48:24.247 0020: 22 22 02 02 22 22 22 02 02 22 22 22 04 04 44 44 ""..""".."""..DD
    16:48:24.247 0030: 44 04 04 44 44 44 04 04 44 44 44 04 04 44 44 44 D..DDD..DDD..DDD
    16:48:24.247 0040: 04 04 44 44 44 08 08 88 88 88 08 08 88 88 88 08 ..DDD...........
    16:48:24.247 0050: 08 88 88 88 08 08 88 88 88 16 16 16 0b 0b 14 14 ................
    16:48:24.247 0060: 14 0a 0a 14 14 14 0a 0a 14 14 14 0a 0a 12 12 12 ................
    16:48:24.247 0070: 09 09 12 12 12 09 09 12 12 12 09 09 10 10 10 08 ................
    16:48:24.247 0080: 08 10 10 10 08 08 10 10 10 08 08 0e 0e 0e 07 07 ................
    16:48:24.247 0090: 0e 0e 0e 07 07 0e 0e 0e 07 07 0c 0c 0c 06 06 0c ................
    16:48:24.247 00a0: 0c 0c 06 06 0c 0c 0c 06 06 a4 a4 a4 a4 a4 a4 a4 ................
    16:48:24.247 00b0: a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 ................
    16:48:24.247 00c0: a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 ................
    16:48:24.247 00d0: a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 ................
    16:48:24.247 00e0: a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 a4 ................
    16:48:24.247 00f0: a4 a4 a4 a4 a4 a4 a4 a4 a4 .........
    16:48:24.279 Incoming Dump:
    16:48:24.279 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.279 --
    16:48:24.279 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.279 Parameters:
    16:48:24.279 | Number HCI commands : 0x01
    16:48:24.279 | Command Opcode : 0xff05
    16:48:24.279 | Status : 0x00 (Success)
    16:48:24.279 --
    16:48:24.279 --
    16:48:24.279 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.279 | Address : 0x200064e0
    16:48:24.279 | Size : 0xf0
    16:48:24.279 | Values : "04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:04:01:01:01:01:01:01:01:01:00:00:00:00:00:00:00:00:00:C0:46:C0:09:09:0A:0B:0C:0D:0E:0F:10:11:12:13:14:15:16:16:08:0A:0A:0E:0F:01:08:0A:0C:0E:09:0B:0D:0F:0F:09:0B:0D:0F:0F:08:0B:0D:0F:0F:08:0C:0F:0F:0F:06:0B:0F:0F:0F:0A:0D:0F:0F:0F:09:0D:0F:0F:0F:08:0C:0F:0F:0F:04:0B:0F:0F:0F:0A:0E:0F:0F:0F:0B:0F:0F:0F:0F:08:0F:0F:0F:0F:04:0F:0F:0F:0F:0D:0F:0F:0F:0F:0D:0E:0F:0D:0E:0E:0D:0C:0D:0E:0F:0D:0C:0D:0E:0F:0F:0F:0B:0C:0D:0E:0E:0E:0A:0B:0C:0D:0D:0D:09:0A:0B:0B:0B:0B:08:09:0A:0A:0A:0A:08:09"
    16:48:24.279 --
    16:48:24.279 Outgoing Dump:
    16:48:24.279 0000: 01 05 ff f5 e0 64 00 20 f0 04 04 04 04 04 04 04 .....d. ........
    16:48:24.279 0010: 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 ................
    16:48:24.279 0020: 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 ................
    16:48:24.279 0030: 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 ................
    16:48:24.279 0040: 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 04 ................
    16:48:24.279 0050: 04 04 04 04 04 04 04 04 04 01 01 01 01 01 01 01 ................
    16:48:24.279 0060: 01 00 00 00 00 00 00 00 00 00 c0 46 c0 09 09 0a ...........F....
    16:48:24.279 0070: 0b 0c 0d 0e 0f 10 11 12 13 14 15 16 16 08 0a 0a ................
    16:48:24.279 0080: 0e 0f 01 08 0a 0c 0e 09 0b 0d 0f 0f 09 0b 0d 0f ................
    16:48:24.279 0090: 0f 08 0b 0d 0f 0f 08 0c 0f 0f 0f 06 0b 0f 0f 0f ................
    16:48:24.279 00a0: 0a 0d 0f 0f 0f 09 0d 0f 0f 0f 08 0c 0f 0f 0f 04 ................
    16:48:24.279 00b0: 0b 0f 0f 0f 0a 0e 0f 0f 0f 0b 0f 0f 0f 0f 08 0f ................
    16:48:24.279 00c0: 0f 0f 0f 04 0f 0f 0f 0f 0d 0f 0f 0f 0f 0d 0e 0f ................
    16:48:24.279 00d0: 0d 0e 0e 0d 0c 0d 0e 0f 0d 0c 0d 0e 0f 0f 0f 0b ................
    16:48:24.279 00e0: 0c 0d 0e 0e 0e 0a 0b 0c 0d 0d 0d 09 0a 0b 0b 0b ................
    16:48:24.279 00f0: 0b 08 09 0a 0a 0a 0a 08 09 .........
    16:48:24.310 Incoming Dump:
    16:48:24.310 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.310 --
    16:48:24.310 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.310 Parameters:
    16:48:24.310 | Number HCI commands : 0x01
    16:48:24.310 | Command Opcode : 0xff05
    16:48:24.310 | Status : 0x00 (Success)
    16:48:24.310 --
    16:48:24.310 --
    16:48:24.310 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.310 | Address : 0x200065d0
    16:48:24.310 | Size : 0xf0
    16:48:24.310 | Values : "0A:0A:0A:0A:07:08:09:09:09:09:06:07:08:08:08:08:05:06:07:07:07:07:05:06:07:07:07:07:04:05:05:05:05:05:03:04:04:04:04:04:02:03:03:03:03:03:02:03:03:03:03:03:03:03:02:02:01:01:00:00:03:04:04:05:05:06:06:07:05:06:07:08:09:0A:0B:0C:2D:E9:F0:4F:6E:48:00:88:C0:F3:43:04:6C:48:C5:79:21:46:2A:46:1F:20:FD:F7:B7:FA:A2:46:08:2C:4F:F0:00:00:11:DA:06:2C:C4:F1:07:0A:01:D1:07:2D:16:DA:05:2C:01:D1:0A:2D:12:DA:04:2C:01:D1:0B:2D:0E:DA:03:2C:01:D1:0D:2D:0A:DA:0C:B9:0A:2D:07:DA:08:2C:01:D1:0C:2D:03:DA:0C:2C:02:D1:0B:2D:00:DB:01:20:9C:49:4E:5D:04:23:00:21:DF:F8:78:B2:5A:46:5B:1E:A2:F1:60:02:56:54:01:F1:04:01:F5:D1:4F:EA:4A:01:4F:F0:00:06:9A:4A:4F:F0:03:0C:01:EB:CA:01:33:46:0A:44:32:F8:02:1F:28:B1:02:2B:03:D2:C9:1E:0C:EB:61:01:89:B2"
    16:48:24.310 --
    16:48:24.310 Outgoing Dump:
    16:48:24.310 0000: 01 05 ff f5 d0 65 00 20 f0 0a 0a 0a 0a 07 08 09 .....e. ........
    16:48:24.310 0010: 09 09 09 06 07 08 08 08 08 05 06 07 07 07 07 05 ................
    16:48:24.310 0020: 06 07 07 07 07 04 05 05 05 05 05 03 04 04 04 04 ................
    16:48:24.310 0030: 04 02 03 03 03 03 03 02 03 03 03 03 03 03 03 02 ................
    16:48:24.310 0040: 02 01 01 00 00 03 04 04 05 05 06 06 07 05 06 07 ................
    16:48:24.310 0050: 08 09 0a 0b 0c 2d e9 f0 4f 6e 48 00 88 c0 f3 43 .....-..OnH....C
    16:48:24.310 0060: 04 6c 48 c5 79 21 46 2a 46 1f 20 fd f7 b7 fa a2 .lH.y!F*F. .....
    16:48:24.310 0070: 46 08 2c 4f f0 00 00 11 da 06 2c c4 f1 07 0a 01 F.,O......,.....
    16:48:24.310 0080: d1 07 2d 16 da 05 2c 01 d1 0a 2d 12 da 04 2c 01 ..-...,...-...,.
    16:48:24.310 0090: d1 0b 2d 0e da 03 2c 01 d1 0d 2d 0a da 0c b9 0a ..-...,...-.....
    16:48:24.310 00a0: 2d 07 da 08 2c 01 d1 0c 2d 03 da 0c 2c 02 d1 0b -...,...-...,...
    16:48:24.310 00b0: 2d 00 db 01 20 9c 49 4e 5d 04 23 00 21 df f8 78 -... .IN].#.!..x
    16:48:24.310 00c0: b2 5a 46 5b 1e a2 f1 60 02 56 54 01 f1 04 01 f5 .ZF[...`.VT.....
    16:48:24.310 00d0: d1 4f ea 4a 01 4f f0 00 06 9a 4a 4f f0 03 0c 01 .O.J.O....JO....
    16:48:24.310 00e0: eb ca 01 33 46 0a 44 32 f8 02 1f 28 b1 02 2b 03 ...3F.D2...(..+.
    16:48:24.310 00f0: d2 c9 1e 0c eb 61 01 89 b2 .....a...
    16:48:24.341 Incoming Dump:
    16:48:24.341 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.341 --
    16:48:24.341 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.341 Parameters:
    16:48:24.341 | Number HCI commands : 0x01
    16:48:24.341 | Command Opcode : 0xff05
    16:48:24.341 | Status : 0x00 (Success)
    16:48:24.341 --
    16:48:24.341 --
    16:48:24.341 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.341 | Address : 0x200066c0
    16:48:24.341 | Size : 0xf0
    16:48:24.341 | Values : "5F:46:5B:1C:FF:1C:05:2B:B9:53:06:F1:0C:06:EE:D3:8F:4F:4F:F0:00:03:0A:EB:8A:08:1A:46:08:EB:02:01:79:5C:00:B1:49:10:5E:46:52:1C:76:1D:05:2A:F1:54:03:F1:0C:03:F2:D3:94:4F:4F:F0:00:03:1A:46:08:EB:02:01:79:5C:00:B1:49:10:5E:46:52:1C:B6:1D:05:2A:F1:54:03:F1:0C:03:F2:D3:07:2C:4F:F0:00:07:01:D1:0C:2D:26:DA:06:2C:01:D1:0A:2D:22:DA:05:2C:01:D1:0C:2D:1E:DA:04:2C:01:D1:0D:2D:1A:DA:03:2C:01:D1:09:2D:16:DA:02:2C:01:D1:0C:2D:12:DA:0C:B9:0A:2D:0F:DA:08:2C:01:D1:0C:2D:0B:DA:0A:2C:01:D1:08:2D:07:DA:0B:2C:01:D1:0C:2D:03:DA:0D:2C:02:D1:08:2D:00:DB:01:27:DF:F8:D4:C1:00:26:33:46:08:EB:03:01:1C:F8:01:10:03:2B:02:D3:27:B1:49:1C:01:E0:0F:B1:89:1C:C9:B2:0B:EB:06:0E:5B:1C:BE:F8:00:20:05:2B:06:F1:0C:06:22:F0:1F:02:41:EA:02:01:AE:F8:00:10"
    16:48:24.341 --
    16:48:24.341 Outgoing Dump:
    16:48:24.341 0000: 01 05 ff f5 c0 66 00 20 f0 5f 46 5b 1c ff 1c 05 .....f. ._F[....
    16:48:24.341 0010: 2b b9 53 06 f1 0c 06 ee d3 8f 4f 4f f0 00 03 0a +.S.......OO....
    16:48:24.341 0020: eb 8a 08 1a 46 08 eb 02 01 79 5c 00 b1 49 10 5e ....F....y\..I.^
    16:48:24.341 0030: 46 52 1c 76 1d 05 2a f1 54 03 f1 0c 03 f2 d3 94 FR.v..*.T.......
    16:48:24.341 0040: 4f 4f f0 00 03 1a 46 08 eb 02 01 79 5c 00 b1 49 OO....F....y\..I
    16:48:24.341 0050: 10 5e 46 52 1c b6 1d 05 2a f1 54 03 f1 0c 03 f2 .^FR....*.T.....
    16:48:24.341 0060: d3 07 2c 4f f0 00 07 01 d1 0c 2d 26 da 06 2c 01 ..,O......-&..,.
    16:48:24.341 0070: d1 0a 2d 22 da 05 2c 01 d1 0c 2d 1e da 04 2c 01 ..-"..,...-...,.
    16:48:24.341 0080: d1 0d 2d 1a da 03 2c 01 d1 09 2d 16 da 02 2c 01 ..-...,...-...,.
    16:48:24.341 0090: d1 0c 2d 12 da 0c b9 0a 2d 0f da 08 2c 01 d1 0c ..-.....-...,...
    16:48:24.341 00a0: 2d 0b da 0a 2c 01 d1 08 2d 07 da 0b 2c 01 d1 0c -...,...-...,...
    16:48:24.341 00b0: 2d 03 da 0d 2c 02 d1 08 2d 00 db 01 27 df f8 d4 -...,...-...'...
    16:48:24.341 00c0: c1 00 26 33 46 08 eb 03 01 1c f8 01 10 03 2b 02 ..&3F.........+.
    16:48:24.341 00d0: d3 27 b1 49 1c 01 e0 0f b1 89 1c c9 b2 0b eb 06 .'.I............
    16:48:24.341 00e0: 0e 5b 1c be f8 00 20 05 2b 06 f1 0c 06 22 f0 1f .[.... .+...."..
    16:48:24.341 00f0: 02 41 ea 02 01 ae f8 00 10 .A.......
    16:48:24.372 Incoming Dump:
    16:48:24.372 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.372 --
    16:48:24.372 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.372 Parameters:
    16:48:24.372 | Number HCI commands : 0x01
    16:48:24.372 | Command Opcode : 0xff05
    16:48:24.372 | Status : 0x00 (Success)
    16:48:24.372 --
    16:48:24.372 --
    16:48:24.372 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.372 | Address : 0x200067b0
    16:48:24.372 | Size : 0xf0
    16:48:24.372 | Values : "E4:D3:DF:F8:A0:C1:DF:F8:98:E1:00:27:3E:46:08:EB:06:02:1E:F8:02:10:1C:F8:02:20:02:F0:0F:03:AB:42:06:DC:B5:EB:22:1F:05:DB:89:1C:02:E0:A0:01:01:20:89:1E:C9:B2:5A:46:52:1C:76:1C:D2:19:13:88:05:2E:07:F1:0C:07:23:F0:1C:03:43:EA:81:03:13:80:DE:D3:55:49:11:F8:0A:10:02:2C:01:D1:08:2D:06:DB:01:2C:01:D1:0C:2D:02:DB:34:B9:0E:2D:04:DA:4F:F0:00:02:01:B9:01:22:11:46:DF:F8:34:C1:07:2C:8C:F8:E8:10:4F:F0:01:01:01:D1:0D:2D:04:DA:06:2C:01:D1:0E:2D:00:DA:00:21:DF:F8:1C:91:45:4A:5B:46:8E:46:05:26:C2:F3:57:11:1F:0F:49:01:76:1E:03:F1:0C:03:02:F5:C0:72:01:EB:07:71:09:F8:01:E0:F1:D1:3E:4B:00:21:08:EB:01:02:9A:5C:AA:42:04:DC:0F:2A:02:D0:49:1C:05:29:F5:D3:4F:EA:4A:02:02:EB:8A:02:89:18:37:4A:51:5C:05:27:00:23:4F:EA:81:1E:5A:46:D6:18:31:88"
    16:48:24.372 --
    16:48:24.372 Outgoing Dump:
    16:48:24.372 0000: 01 05 ff f5 b0 67 00 20 f0 e4 d3 df f8 a0 c1 df .....g. ........
    16:48:24.372 0010: f8 98 e1 00 27 3e 46 08 eb 06 02 1e f8 02 10 1c ....'>F.........
    16:48:24.372 0020: f8 02 20 02 f0 0f 03 ab 42 06 dc b5 eb 22 1f 05 .. .....B...."..
    16:48:24.372 0030: db 89 1c 02 e0 a0 01 01 20 89 1e c9 b2 5a 46 52 ........ ....ZFR
    16:48:24.372 0040: 1c 76 1c d2 19 13 88 05 2e 07 f1 0c 07 23 f0 1c .v...........#..
    16:48:24.372 0050: 03 43 ea 81 03 13 80 de d3 55 49 11 f8 0a 10 02 .C.......UI.....
    16:48:24.372 0060: 2c 01 d1 08 2d 06 db 01 2c 01 d1 0c 2d 02 db 34 ,...-...,...-..4
    16:48:24.372 0070: b9 0e 2d 04 da 4f f0 00 02 01 b9 01 22 11 46 df ..-..O......".F.
    16:48:24.372 0080: f8 34 c1 07 2c 8c f8 e8 10 4f f0 01 01 01 d1 0d .4..,....O......
    16:48:24.372 0090: 2d 04 da 06 2c 01 d1 0e 2d 00 da 00 21 df f8 1c -...,...-...!...
    16:48:24.372 00a0: 91 45 4a 5b 46 8e 46 05 26 c2 f3 57 11 1f 0f 49 .EJ[F.F.&..W...I
    16:48:24.372 00b0: 01 76 1e 03 f1 0c 03 02 f5 c0 72 01 eb 07 71 09 .v........r...q.
    16:48:24.372 00c0: f8 01 e0 f1 d1 3e 4b 00 21 08 eb 01 02 9a 5c aa .....>K.!.....\.
    16:48:24.372 00d0: 42 04 dc 0f 2a 02 d0 49 1c 05 29 f5 d3 4f ea 4a B...*..I..)..O.J
    16:48:24.372 00e0: 02 02 eb 8a 02 89 18 37 4a 51 5c 05 27 00 23 4f .......7JQ\.'.#O
    16:48:24.372 00f0: ea 81 1e 5a 46 d6 18 31 88 ...ZF..1.
    16:48:24.404 Incoming Dump:
    16:48:24.404 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.404 --
    16:48:24.404 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.404 Parameters:
    16:48:24.404 | Number HCI commands : 0x01
    16:48:24.404 | Command Opcode : 0xff05
    16:48:24.404 | Status : 0x00 (Success)
    16:48:24.404 --
    16:48:24.404 --
    16:48:24.404 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.404 | Address : 0x200068a0
    16:48:24.404 | Size : 0xf0
    16:48:24.404 | Values : "7F:1E:03:F1:0C:03:21:F4:70:71:4E:EA:01:01:31:80:F4:D1:32:49:5B:46:2E:4A:49:89:49:3B:C1:F3:83:01:56:5C:B3:F8:8C:10:21:F0:0F:01:0E:43:29:49:0A:88:2A:49:02:F0:1F:02:89:88:A3:F8:8C:60:11:F0:03:01:10:D0:49:1E:06:D0:49:1E:14:D1:AA:42:06:DD:0B:E0:44:65:00:00:AA:42:D8:BF:0C:20:0C:DD:06:20:0A:E0:BD:B0:01:20:AA:42:05:DD:04:20:04:E0:FE:62:00:00:A0:63:00:00:08:20:18:49:18:70:68:10:08:5C:02:2C:58:70:01:D1:08:2D:0A:DB:01:2C:01:D1:0C:2D:06:DB:0C:B9:0E:2D:03:DB:08:2C:B8:BF:01:20:00:DB:00:20:8C:F8:00:00:BD:E8:F0:8F:F0:63:00:00:40:64:00:00:E0:64:00:00:90:64:00:00:30:65:00:00:78:0E:36:22:A0:17:36:00:14:00:00:02:54:65:00:00:A4:65:00:00:04:66:00:00:3C:03:01:20:14:66:00:00:A0:01:01:20:61:01:1F:02:42:01:E5:01:28:01:B5:01:13:01:8E:01"
    16:48:24.404 --
    16:48:24.404 Outgoing Dump:
    16:48:24.404 0000: 01 05 ff f5 a0 68 00 20 f0 7f 1e 03 f1 0c 03 21 .....h. .......!
    16:48:24.404 0010: f4 70 71 4e ea 01 01 31 80 f4 d1 32 49 5b 46 2e .pqN...1...2I[F.
    16:48:24.404 0020: 4a 49 89 49 3b c1 f3 83 01 56 5c b3 f8 8c 10 21 JI.I;....V\....!
    16:48:24.404 0030: f0 0f 01 0e 43 29 49 0a 88 2a 49 02 f0 1f 02 89 ....C)I..*I.....
    16:48:24.404 0040: 88 a3 f8 8c 60 11 f0 03 01 10 d0 49 1e 06 d0 49 ....`......I...I
    16:48:24.404 0050: 1e 14 d1 aa 42 06 dd 0b e0 44 65 00 00 aa 42 d8 ....B....De...B.
    16:48:24.404 0060: bf 0c 20 0c dd 06 20 0a e0 bd b0 01 20 aa 42 05 .. ... ..... .B.
    16:48:24.404 0070: dd 04 20 04 e0 fe 62 00 00 a0 63 00 00 08 20 18 .. ...b...c... .
    16:48:24.404 0080: 49 18 70 68 10 08 5c 02 2c 58 70 01 d1 08 2d 0a I.ph..\.,Xp...-.
    16:48:24.404 0090: db 01 2c 01 d1 0c 2d 06 db 0c b9 0e 2d 03 db 08 ..,...-.....-...
    16:48:24.404 00a0: 2c b8 bf 01 20 00 db 00 20 8c f8 00 00 bd e8 f0 ,... ... .......
    16:48:24.404 00b0: 8f f0 63 00 00 40 64 00 00 e0 64 00 00 90 64 00 ..c..@d...d...d.
    16:48:24.404 00c0: 00 30 65 00 00 78 0e 36 22 a0 17 36 00 14 00 00 .0e..x.6"..6....
    16:48:24.404 00d0: 02 54 65 00 00 a4 65 00 00 04 66 00 00 3c 03 01 .Te...e...f..<..
    16:48:24.404 00e0: 20 14 66 00 00 a0 01 01 20 61 01 1f 02 42 01 e5 .f..... a...B..
    16:48:24.404 00f0: 01 28 01 b5 01 13 01 8e 01 .(.......
    16:48:24.435 Incoming Dump:
    16:48:24.435 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.435 --
    16:48:24.435 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.435 Parameters:
    16:48:24.435 | Number HCI commands : 0x01
    16:48:24.435 | Command Opcode : 0xff05
    16:48:24.435 | Status : 0x00 (Success)
    16:48:24.435 --
    16:48:24.435 --
    16:48:24.435 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.435 | Address : 0x20006990
    16:48:24.435 | Size : 0xf0
    16:48:24.435 | Values : "01:01:6E:01:F2:00:53:01:E6:00:3D:01:DC:00:2A:01:D3:00:1B:01:CC:00:0E:01:C7:00:04:01:C2:00:FA:00:BE:00:F3:00:BB:00:ED:00:B9:00:E8:00:B7:00:E4:00:2D:E9:F0:41:7C:4C:4F:F0:01:08:20:46:0B:38:80:F8:00:80:0A:20:FD:F7:C2:F8:20:46:08:30:01:88:00:25:20:46:01:80:0A:30:00:88:0C:3C:2E:46:E0:81:10:27:84:F8:00:80:08:20:FD:F7:B1:F8:21:8B:4D:19:61:8B:7F:1E:0E:44:F4:D1:30:09:29:09:80:B2:89:B2:00:EB:40:00:09:02:91:FB:F0:F0:80:B2:BD:E8:F0:81:2D:E9:FF:4F:82:46:65:48:00:88:AD:F8:00:00:65:48:00:88:88:46:64:21:B0:FB:F1:F1:4F:EA:48:00:00:EB:81:00:5F:49:08:5A:B8:F1:01:0F:4F:F0:04:05:4F:F0:00:09:4F:F0:10:04:01:90:93:46:CD:F8:08:90:04:D1:BA:F1:03:0F:B4:BF:01:26:02:26:8E:4B:4F:EA:CA:07:DA:19:11:88:B0:01:21:F0:C0:01:01:43:11:80:11:88:21:F0"
    16:48:24.435 --
    16:48:24.435 Outgoing Dump:
    16:48:24.435 0000: 01 05 ff f5 90 69 00 20 f0 01 01 6e 01 f2 00 53 .....i. ...n...S
    16:48:24.435 0010: 01 e6 00 3d 01 dc 00 2a 01 d3 00 1b 01 cc 00 0e ...=...*........
    16:48:24.435 0020: 01 c7 00 04 01 c2 00 fa 00 be 00 f3 00 bb 00 ed ................
    16:48:24.435 0030: 00 b9 00 e8 00 b7 00 e4 00 2d e9 f0 41 7c 4c 4f .........-..A|LO
    16:48:24.435 0040: f0 01 08 20 46 0b 38 80 f8 00 80 0a 20 fd f7 c2 ... F.8..... ...
    16:48:24.435 0050: f8 20 46 08 30 01 88 00 25 20 46 01 80 0a 30 00 . F.0...% F...0.
    16:48:24.435 0060: 88 0c 3c 2e 46 e0 81 10 27 84 f8 00 80 08 20 fd ..<.F...'..... .
    16:48:24.435 0070: f7 b1 f8 21 8b 4d 19 61 8b 7f 1e 0e 44 f4 d1 30 ...!.M.a....D..0
    16:48:24.435 0080: 09 29 09 80 b2 89 b2 00 eb 40 00 09 02 91 fb f0 .).......@......
    16:48:24.435 0090: f0 80 b2 bd e8 f0 81 2d e9 ff 4f 82 46 65 48 00 .......-..O.FeH.
    16:48:24.435 00a0: 88 ad f8 00 00 65 48 00 88 88 46 64 21 b0 fb f1 .....eH...Fd!...
    16:48:24.435 00b0: f1 4f ea 48 00 00 eb 81 00 5f 49 08 5a b8 f1 01 .O.H....._I.Z...
    16:48:24.435 00c0: 0f 4f f0 04 05 4f f0 00 09 4f f0 10 04 01 90 93 .O...O...O......
    16:48:24.435 00d0: 46 cd f8 08 90 04 d1 ba f1 03 0f b4 bf 01 26 02 F.............&.
    16:48:24.435 00e0: 26 8e 4b 4f ea ca 07 da 19 11 88 b0 01 21 f0 c0 &.KO.........!..
    16:48:24.435 00f0: 01 01 43 11 80 11 88 21 f0 ..C....!.
    16:48:24.466 Incoming Dump:
    16:48:24.466 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.466 --
    16:48:24.466 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.466 Parameters:
    16:48:24.466 | Number HCI commands : 0x01
    16:48:24.466 | Command Opcode : 0xff05
    16:48:24.466 | Status : 0x00 (Success)
    16:48:24.466 --
    16:48:24.466 --
    16:48:24.466 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.466 | Address : 0x20006a80
    16:48:24.466 | Size : 0xf0
    16:48:24.466 | Values : "C0:01:08:43:10:80:18:F8:0D:00:03:90:B8:F1:00:0F:0C:D1:50:46:81:00:01:EB:C0:01:82:48:48:30:40:18:A1:00:41:F0:80:01:01:80:44:80:06:E0:7D:48:04:F0:1F:01:80:1C:C0:19:01:70:01:71:FF:F7:81:FF:DD:F8:04:C0:BC:EB:00:0C:54:BF:01:21:4F:F0:FF:31:01:9A:80:1A:54:BF:02:1C:62:46:03:9B:93:42:3A:DA:02:9A:3A:B1:02:9A:8A:42:08:D0:05:EB:D5:75:6A:10:55:42:03:E0:2A:B2:02:FB:01:F2:55:B2:2A:19:02:91:94:B2:20:2C:02:DA:1F:2C:01:D0:02:E0:1F:24:01:29:03:D0:F4:B9:B1:F1:FF:3F:1B:D1:1F:2C:08:BF:B9:F1:00:0F:04:D0:59:EA:04:01:15:D1:76:1E:00:E0:76:1C:5D:49:76:B2:C9:19:0B:88:B2:01:23:F0:C0:03:13:43:0B:80:0B:88:10:24:4F:F0:01:09:23:F0:C0:03:1A:43:0A:80:00:2D:9B:D1:1C:49:09:68:49:0D:07:D3:00:28:48:BF:60:46:82:B2:51:46:1D:20:FD:F7:1C:F8:B8:F1:01:0F"
    16:48:24.466 --
    16:48:24.466 Outgoing Dump:
    16:48:24.466 0000: 01 05 ff f5 80 6a 00 20 f0 c0 01 08 43 10 80 18 .....j. ....C...
    16:48:24.466 0010: f8 0d 00 03 90 b8 f1 00 0f 0c d1 50 46 81 00 01 ...........PF...
    16:48:24.466 0020: eb c0 01 82 48 48 30 40 18 a1 00 41 f0 80 01 01 ....HH0@...A....
    16:48:24.466 0030: 80 44 80 06 e0 7d 48 04 f0 1f 01 80 1c c0 19 01 .D...}H.........
    16:48:24.466 0040: 70 01 71 ff f7 81 ff dd f8 04 c0 bc eb 00 0c 54 p.q............T
    16:48:24.466 0050: bf 01 21 4f f0 ff 31 01 9a 80 1a 54 bf 02 1c 62 ..!O..1....T...b
    16:48:24.466 0060: 46 03 9b 93 42 3a da 02 9a 3a b1 02 9a 8a 42 08 F...B:...:....B.
    16:48:24.466 0070: d0 05 eb d5 75 6a 10 55 42 03 e0 2a b2 02 fb 01 ....uj.UB..*....
    16:48:24.466 0080: f2 55 b2 2a 19 02 91 94 b2 20 2c 02 da 1f 2c 01 .U.*..... ,...,.
    16:48:24.466 0090: d0 02 e0 1f 24 01 29 03 d0 f4 b9 b1 f1 ff 3f 1b ....$.).......?.
    16:48:24.466 00a0: d1 1f 2c 08 bf b9 f1 00 0f 04 d0 59 ea 04 01 15 ..,........Y....
    16:48:24.466 00b0: d1 76 1e 00 e0 76 1c 5d 49 76 b2 c9 19 0b 88 b2 .v...v.]Iv......
    16:48:24.466 00c0: 01 23 f0 c0 03 13 43 0b 80 0b 88 10 24 4f f0 01 .#....C.....$O..
    16:48:24.466 00d0: 09 23 f0 c0 03 1a 43 0a 80 00 2d 9b d1 1c 49 09 .#....C...-...I.
    16:48:24.466 00e0: 68 49 0d 07 d3 00 28 48 bf 60 46 82 b2 51 46 1d hI....(H.`F..QF.
    16:48:24.466 00f0: 20 fd f7 1c f8 b8 f1 01 0f ........
    16:48:24.497 Incoming Dump:
    16:48:24.497 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.497 --
    16:48:24.497 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.497 Parameters:
    16:48:24.497 | Number HCI commands : 0x01
    16:48:24.497 | Command Opcode : 0xff05
    16:48:24.497 | Status : 0x00 (Success)
    16:48:24.497 --
    16:48:24.497 --
    16:48:24.497 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.497 | Address : 0x20006b70
    16:48:24.497 | Size : 0xf0
    16:48:24.497 | Values : "1F:D1:04:F0:1F:04:5B:F8:07:10:20:04:07:EB:0B:02:21:F4:F8:11:01:43:4B:F8:07:10:51:68:06:F0:03:06:21:F4:F8:11:08:43:50:60:5B:F8:07:10:B0:01:21:F0:C0:01:01:43:4B:F8:07:10:51:68:21:F0:C0:01:08:43:50:60:00:90:BD:E8:FF:8F:24:80:01:20:90:50:00:00:28:69:00:00:BE:02:01:20:B0:01:01:20:2D:E9:F0:4F:AD:F1:80:0D:A7:4E:34:46:4E:3C:94:F8:B6:00:1A:90:D4:F8:CA:00:A1:4D:1B:90:55:F8:02:0C:A0:4F:1C:90:D5:F8:02:00:DF:F8:AC:A0:1D:90:B8:88:40:22:51:46:1E:90:0A:A8:FE:F7:8C:F8:B9:1C:1F:91:B8:88:20:F0:03:00:40:F0:01:00:48:80:4F:F4:A0:70:08:80:00:20:FA:F7:08:FA:37:46:BF:1F:43:F6:03:40:38:80:B8:80:37:F8:02:0C:40:F0:30:00:27:F8:02:0C:30:46:00:1F:00:88:00:22:05:23:4F:F0:04:08:4F:F0:44:09:4F:F0:20:0B:EE:46:0D:F1:14:0C:40:F0:30:00:78:80:C0:20"
    16:48:24.497 --
    16:48:24.497 Outgoing Dump:
    16:48:24.497 0000: 01 05 ff f5 70 6b 00 20 f0 1f d1 04 f0 1f 04 5b ....pk. .......[
    16:48:24.497 0010: f8 07 10 20 04 07 eb 0b 02 21 f4 f8 11 01 43 4b ... .....!....CK
    16:48:24.497 0020: f8 07 10 51 68 06 f0 03 06 21 f4 f8 11 08 43 50 ...Qh....!....CP
    16:48:24.497 0030: 60 5b f8 07 10 b0 01 21 f0 c0 01 01 43 4b f8 07 `[.....!....CK..
    16:48:24.497 0040: 10 51 68 21 f0 c0 01 08 43 50 60 00 90 bd e8 ff .Qh!....CP`.....
    16:48:24.497 0050: 8f 24 80 01 20 90 50 00 00 28 69 00 00 be 02 01 .$.. .P..(i.....
    16:48:24.497 0060: 20 b0 01 01 20 2d e9 f0 4f ad f1 80 0d a7 4e 34 ... -..O.....N4
    16:48:24.497 0070: 46 4e 3c 94 f8 b6 00 1a 90 d4 f8 ca 00 a1 4d 1b FN<...........M.
    16:48:24.497 0080: 90 55 f8 02 0c a0 4f 1c 90 d5 f8 02 00 df f8 ac .U....O.........
    16:48:24.497 0090: a0 1d 90 b8 88 40 22 51 46 1e 90 0a a8 fe f7 8c .....@"QF.......
    16:48:24.497 00a0: f8 b9 1c 1f 91 b8 88 20 f0 03 00 40 f0 01 00 48 ....... ...@...H
    16:48:24.497 00b0: 80 4f f4 a0 70 08 80 00 20 fa f7 08 fa 37 46 bf .O..p... ....7F.
    16:48:24.497 00c0: 1f 43 f6 03 40 38 80 b8 80 37 f8 02 0c 40 f0 30 .C..@8...7...@.0
    16:48:24.497 00d0: 00 27 f8 02 0c 30 46 00 1f 00 88 00 22 05 23 4f .'...0F.....".#O
    16:48:24.497 00e0: f0 04 08 4f f0 44 09 4f f0 20 0b ee 46 0d f1 14 ...O.D.O. ..F...
    16:48:24.497 00f0: 0c 40 f0 30 00 78 80 c0 20 .@.0.x..
    16:48:24.529 Incoming Dump:
    16:48:24.529 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.529 --
    16:48:24.529 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.529 Parameters:
    16:48:24.529 | Number HCI commands : 0x01
    16:48:24.529 | Command Opcode : 0xff05
    16:48:24.529 | Status : 0x00 (Success)
    16:48:24.529 --
    16:48:24.529 --
    16:48:24.529 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.529 | Address : 0x20006c60
    16:48:24.529 | Size : 0xf0
    16:48:24.529 | Values : "84:49:89:18:0E:68:4E:F8:04:6B:4E:68:4C:F8:04:6B:0E:88:0E:80:0E:88:0E:80:0E:88:26:F4:70:66:46:F4:80:56:0E:80:0E:88:0E:80:A1:F8:04:B0:81:F8:06:90:10:26:81:F8:07:80:0C:32:08:81:5B:1E:4E:81:DF:D1:02:E0:C0:46:7C:B0:01:20:73:48:00:26:06:70:80:F8:20:60:64:20:28:70:28:88:20:F4:00:60:40:F4:E0:60:28:80:28:88:20:F4:40:50:28:80:6C:48:10:21:06:70:3E:20:A8:70:E9:70:2F:21:29:71:2C:21:69:71:4F:F0:01:0B:84:F8:B7:60:DF:F8:98:81:84:F8:B6:B0:34:F8:1E:1C:21:F4:40:71:24:F8:1E:1C:88:F8:00:60:24:F8:1C:6C:88:F8:7C:63:1C:21:88:F8:90:63:85:F8:5E:11:5A:49:81:F8:7C:B2:88:F8:70:B4:88:F8:6C:B4:21:88:41:F0:03:01:21:80:21:88:41:F0:0C:01:21:80:4F:F0:22:09:84:F8:B8:60:84:F8:B9:90:0A:AA:85:F8:61:61:31:46:85:F8:60:01:07:20:84:F8:CB:00:03:20:84:F8"
    16:48:24.529 --
    16:48:24.529 Outgoing Dump:
    16:48:24.529 0000: 01 05 ff f5 60 6c 00 20 f0 84 49 89 18 0e 68 4e ....`l. ..I...hN
    16:48:24.529 0010: f8 04 6b 4e 68 4c f8 04 6b 0e 88 0e 80 0e 88 0e ..kNhL..k.......
    16:48:24.529 0020: 80 0e 88 26 f4 70 66 46 f4 80 56 0e 80 0e 88 0e ...&.pfF..V.....
    16:48:24.529 0030: 80 a1 f8 04 b0 81 f8 06 90 10 26 81 f8 07 80 0c ..........&.....
    16:48:24.529 0040: 32 08 81 5b 1e 4e 81 df d1 02 e0 c0 46 7c b0 01 2..[.N......F|..
    16:48:24.529 0050: 20 73 48 00 26 06 70 80 f8 20 60 64 20 28 70 28 sH.&.p.. `d (p(
    16:48:24.529 0060: 88 20 f4 00 60 40 f4 e0 60 28 80 28 88 20 f4 40 . ..`@..`(.(. .@
    16:48:24.529 0070: 50 28 80 6c 48 10 21 06 70 3e 20 a8 70 e9 70 2f P(.lH.!.p> .p.p/
    16:48:24.529 0080: 21 29 71 2c 21 69 71 4f f0 01 0b 84 f8 b7 60 df !)q,!iqO......`.
    16:48:24.529 0090: f8 98 81 84 f8 b6 b0 34 f8 1e 1c 21 f4 40 71 24 .......4...!.@q$
    16:48:24.529 00a0: f8 1e 1c 88 f8 00 60 24 f8 1c 6c 88 f8 7c 63 1c ......`$..l..|c.
    16:48:24.529 00b0: 21 88 f8 90 63 85 f8 5e 11 5a 49 81 f8 7c b2 88 !...c..^.ZI..|..
    16:48:24.529 00c0: f8 70 b4 88 f8 6c b4 21 88 41 f0 03 01 21 80 21 .p...l.!.A...!.!
    16:48:24.529 00d0: 88 41 f0 0c 01 21 80 4f f0 22 09 84 f8 b8 60 84 .A...!.O."....`.
    16:48:24.529 00e0: f8 b9 90 0a aa 85 f8 61 61 31 46 85 f8 60 01 07 .......aa1F..`..
    16:48:24.529 00f0: 20 84 f8 cb 00 03 20 84 f8 ..... ..
    16:48:24.560 Incoming Dump:
    16:48:24.560 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.560 --
    16:48:24.560 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.560 Parameters:
    16:48:24.560 | Number HCI commands : 0x01
    16:48:24.560 | Command Opcode : 0xff05
    16:48:24.560 | Status : 0x00 (Success)
    16:48:24.560 --
    16:48:24.560 --
    16:48:24.560 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.560 | Address : 0x20006d50
    16:48:24.560 | Size : 0xf0
    16:48:24.560 | Values : "CC:00:FF:F7:64:FE:78:8E:5F:FA:80:FC:B8:8E:42:4F:33:46:C2:B2:03:2B:0B:D0:99:00:00:2B:01:EB:C3:01:0C:BF:0C:F0:7F:00:60:46:78:52:3E:48:0A:30:42:52:5B:1C:05:2B:EE:DB:88:F8:70:64:84:F8:B8:90:37:46:B1:46:84:F8:B9:60:0A:EB:07:01:84:F8:CB:90:08:88:20:F0:30:00:08:80:88:88:20:F0:30:00:88:80:08:88:20:F4:70:60:08:80:88:88:10:2F:20:F4:70:60:88:80:4F:F0:10:00:85:F8:61:01:4F:F0:30:00:85:F8:60:01:CC:BF:02:20:03:20:0A:AA:84:F8:CB:90:59:46:84:F8:CC:00:5F:FA:89:F0:FF:F7:1A:FE:08:37:09:F1:01:09:40:2F:D0:DB:30:46:FD:F7:95:FB:84:F8:B8:60:84:F8:B9:60:1E:48:88:F8:70:64:88:F8:6C:64:80:F8:7C:62:1A:98:84:F8:B6:00:1B:98:C4:F8:CA:00:1C:98:45:F8:02:0C:1D:98:C5:F8:02:00:1E:99:1F:98:40:22:41:80:0A:A9:50:46:FD:F7:74:FF:05:AF:32:46:05:23:EC:46"
    16:48:24.560 --
    16:48:24.560 Outgoing Dump:
    16:48:24.560 0000: 01 05 ff f5 50 6d 00 20 f0 cc 00 ff f7 64 fe 78 ....Pm. .....d.x
    16:48:24.560 0010: 8e 5f fa 80 fc b8 8e 42 4f 33 46 c2 b2 03 2b 0b ._.....BO3F...+.
    16:48:24.560 0020: d0 99 00 00 2b 01 eb c3 01 0c bf 0c f0 7f 00 60 ....+..........`
    16:48:24.560 0030: 46 78 52 3e 48 0a 30 42 52 5b 1c 05 2b ee db 88 FxR>H.0BR[..+...
    16:48:24.560 0040: f8 70 64 84 f8 b8 90 37 46 b1 46 84 f8 b9 60 0a .pd....7F.F...`.
    16:48:24.560 0050: eb 07 01 84 f8 cb 90 08 88 20 f0 30 00 08 80 88 ......... .0....
    16:48:24.560 0060: 88 20 f0 30 00 88 80 08 88 20 f4 70 60 08 80 88 . .0..... .p`...
    16:48:24.560 0070: 88 10 2f 20 f4 70 60 88 80 4f f0 10 00 85 f8 61 ../ .p`..O.....a
    16:48:24.560 0080: 01 4f f0 30 00 85 f8 60 01 cc bf 02 20 03 20 0a .O.0...`.... . .
    16:48:24.560 0090: aa 84 f8 cb 90 59 46 84 f8 cc 00 5f fa 89 f0 ff .....YF...._....
    16:48:24.560 00a0: f7 1a fe 08 37 09 f1 01 09 40 2f d0 db 30 46 fd ....7....@/..0F.
    16:48:24.560 00b0: f7 95 fb 84 f8 b8 60 84 f8 b9 60 1e 48 88 f8 70 ......`...`.H..p
    16:48:24.560 00c0: 64 88 f8 6c 64 80 f8 7c 62 1a 98 84 f8 b6 00 1b d..ld..|b.......
    16:48:24.560 00d0: 98 c4 f8 ca 00 1c 98 45 f8 02 0c 1d 98 c5 f8 02 .......E........
    16:48:24.560 00e0: 00 1e 99 1f 98 40 22 41 80 0a a9 50 46 fd f7 74 .....@"A...PF..t
    16:48:24.560 00f0: ff 05 af 32 46 05 23 ec 46 ...2F.#.F
    16:48:24.591 Incoming Dump:
    16:48:24.591 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.591 --
    16:48:24.591 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.591 Parameters:
    16:48:24.591 | Number HCI commands : 0x01
    16:48:24.591 | Command Opcode : 0xff05
    16:48:24.591 | Status : 0x00 (Success)
    16:48:24.591 --
    16:48:24.591 --
    16:48:24.591 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.591 | Address : 0x20006e40
    16:48:24.591 | Size : 0xf0
    16:48:24.591 | Values : "0C:49:5C:F8:04:5B:8C:18:25:60:57:F8:04:5B:0C:32:5B:1E:65:60:F5:D1:31:46:0E:20:0A:46:FC:F7:A2:FE:20:B0:BD:E8:F0:8F:C0:46:C4:B0:01:20:1E:80:01:20:00:00:01:20:BC:B0:01:20:80:03:30:22:84:2C:30:22:04:0A:36:22:2D:E9:F0:4F:AD:F1:24:0D:07:46:4F:F0:20:0A:00:92:7D:00:47:F6:FF:76:00:24:01:91:D1:46:02:95:05:EB:C1:05:51:46:03:96:20:46:04:90:4F:F0:01:0B:05:90:02:29:63:DB:09:EB:04:00:41:10:C9:B2:06:91:04:99:00:2F:51:44:4F:EA:61:01:5F:FA:81:F8:14:BF:06:98:00:F0:FE:00:7B:49:00:2F:48:55:12:BF:40:46:4F:EA:48:00:C0:B2:78:49:48:55:74:49:05:98:08:70:FC:F7:33:FE:72:48:80:F8:00:B0:07:20:FC:F7:2D:FE:73:48:80:F8:00:B0:58:46:FC:F7:27:FE:6D:48:00:88:C0:00:01:B2:6B:48:40:88:C0:00:02:B2:08:46:00:28:B8:BF:40:42:03:9B:83:42:03:DD:00:B2:03:90"
    16:48:24.591 --
    16:48:24.591 Outgoing Dump:
    16:48:24.591 0000: 01 05 ff f5 40 6e 00 20 f0 0c 49 5c f8 04 5b 8c ....@n. ..I\..[.
    16:48:24.591 0010: 18 25 60 57 f8 04 5b 0c 32 5b 1e 65 60 f5 d1 31 .%`W..[.2[.e`..1
    16:48:24.591 0020: 46 0e 20 0a 46 fc f7 a2 fe 20 b0 bd e8 f0 8f c0 F. .F.... ......
    16:48:24.591 0030: 46 c4 b0 01 20 1e 80 01 20 00 00 01 20 bc b0 01 F... ... ... ...
    16:48:24.591 0040: 20 80 03 30 22 84 2c 30 22 04 0a 36 22 2d e9 f0 ..0".,0"..6"-..
    16:48:24.591 0050: 4f ad f1 24 0d 07 46 4f f0 20 0a 00 92 7d 00 47 O..$..FO. ...}.G
    16:48:24.591 0060: f6 ff 76 00 24 01 91 d1 46 02 95 05 eb c1 05 51 ..v.$...F......Q
    16:48:24.591 0070: 46 03 96 20 46 04 90 4f f0 01 0b 05 90 02 29 63 F.. F..O......)c
    16:48:24.591 0080: db 09 eb 04 00 41 10 c9 b2 06 91 04 99 00 2f 51 .....A......../Q
    16:48:24.591 0090: 44 4f ea 61 01 5f fa 81 f8 14 bf 06 98 00 f0 fe DO.a._..........
    16:48:24.591 00a0: 00 7b 49 00 2f 48 55 12 bf 40 46 4f ea 48 00 c0 .{I./HU..@FO.H..
    16:48:24.591 00b0: b2 78 49 48 55 74 49 05 98 08 70 fc f7 33 fe 72 .xIHUtI...p..3.r
    16:48:24.591 00c0: 48 80 f8 00 b0 07 20 fc f7 2d fe 73 48 80 f8 00 H..... ..-.sH...
    16:48:24.591 00d0: b0 58 46 fc f7 27 fe 6d 48 00 88 c0 00 01 b2 6b .XF..'.mH......k
    16:48:24.591 00e0: 48 40 88 c0 00 02 b2 08 46 00 28 b8 bf 40 42 03 H@......F.(..@B.
    16:48:24.591 00f0: 9b 83 42 03 dd 00 b2 03 90 ..B......
    16:48:24.638 Incoming Dump:
    16:48:24.638 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.638 --
    16:48:24.638 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.638 Parameters:
    16:48:24.638 | Number HCI commands : 0x01
    16:48:24.638 | Command Opcode : 0xff05
    16:48:24.638 | Status : 0x00 (Success)
    16:48:24.638 --
    16:48:24.638 --
    16:48:24.638 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.638 | Address : 0x20006f30
    16:48:24.638 | Size : 0xf0
    16:48:24.638 | Values : "06:98:07:90:10:46:00:28:B8:BF:40:42:86:42:C4:BF:06:B2:CD:F8:20:80:3F:B9:00:29:D4:BF:06:9C:DD:F8:18:90:00:2A:07:DD:09:E0:00:29:54:BF:06:9C:DD:F8:18:90:00:2A:02:D4:CD:F8:10:80:00:E0:C2:46:04:98:AA:EB:00:00:C1:B2:A9:EB:04:00:C0:B2:02:28:99:DA:00:2F:18:BF:07:98:02:D1:07:98:40:00:C0:B2:4E:49:00:2F:48:55:18:BF:08:98:03:D1:08:98:4F:EA:40:00:C0:B2:4A:49:48:55:01:98:9D:4D:00:BB:DF:F8:24:81:44:46:B0:3C:D4:F8:B0:00:81:0E:07:D3:01:98:2A:78:81:B2:0D:20:FC:F7:EE:FD:D4:F8:B0:00:C1:0E:07:D3:03:98:07:99:82:B2:3C:20:FC:F7:E4:FD:40:46:00:68:00:0F:04:D3:08:99:B2:B2:3D:20:FC:F7:DB:FD:01:99:58:46:00:FA:01:F2:9D:49:09:68:0A:42:3C:D0:00:99:00:29:39:D0:A8:49:DF:F8:9C:E2:2D:78:09:78:9E:F8:00:30:00:29:30:D0:C7:F1:02:01:08:9A:07:9C:02:FB"
    16:48:24.638 --
    16:48:24.638 Outgoing Dump:
    16:48:24.638 0000: 01 05 ff f5 30 6f 00 20 f0 06 98 07 90 10 46 00 ....0o. ......F.
    16:48:24.638 0010: 28 b8 bf 40 42 86 42 c4 bf 06 b2 cd f8 20 80 3f (..@B.B...... .?
    16:48:24.638 0020: b9 00 29 d4 bf 06 9c dd f8 18 90 00 2a 07 dd 09 ..).........*...
    16:48:24.638 0030: e0 00 29 54 bf 06 9c dd f8 18 90 00 2a 02 d4 cd ..)T........*...
    16:48:24.638 0040: f8 10 80 00 e0 c2 46 04 98 aa eb 00 00 c1 b2 a9 ......F.........
    16:48:24.638 0050: eb 04 00 c0 b2 02 28 99 da 00 2f 18 bf 07 98 02 ......(.../.....
    16:48:24.638 0060: d1 07 98 40 00 c0 b2 4e 49 00 2f 48 55 18 bf 08 ...@...NI./HU...
    16:48:24.638 0070: 98 03 d1 08 98 4f ea 40 00 c0 b2 4a 49 48 55 01 .....O.@...JIHU.
    16:48:24.638 0080: 98 9d 4d 00 bb df f8 24 81 44 46 b0 3c d4 f8 b0 ..M....$.DF.<...
    16:48:24.638 0090: 00 81 0e 07 d3 01 98 2a 78 81 b2 0d 20 fc f7 ee .......*x... ...
    16:48:24.638 00a0: fd d4 f8 b0 00 c1 0e 07 d3 03 98 07 99 82 b2 3c ...............<
    16:48:24.638 00b0: 20 fc f7 e4 fd 40 46 00 68 00 0f 04 d3 08 99 b2 ....@F.h.......
    16:48:24.638 00c0: b2 3d 20 fc f7 db fd 01 99 58 46 00 fa 01 f2 9d .= ......XF.....
    16:48:24.638 00d0: 49 09 68 0a 42 3c d0 00 99 00 29 39 d0 a8 49 df I.h.B<....)9..I.
    16:48:24.638 00e0: f8 9c e2 2d 78 09 78 9e f8 00 30 00 29 30 d0 c7 ...-x.x...0.)0..
    16:48:24.638 00f0: f1 02 01 08 9a 07 9c 02 fb .........
    16:48:24.669 Incoming Dump:
    16:48:24.669 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.669 --
    16:48:24.669 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.669 Parameters:
    16:48:24.669 | Number HCI commands : 0x01
    16:48:24.669 | Command Opcode : 0xff05
    16:48:24.669 | Status : 0x00 (Success)
    16:48:24.669 --
    16:48:24.669 --
    16:48:24.669 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.669 | Address : 0x20007020
    16:48:24.669 | Size : 0xf0
    16:48:24.669 | Values : "01:F2:4F:EA:02:22:04:FB:01:21:02:9A:8C:B2:4F:EA:C5:01:01:EB:45:11:01:EB:83:01:0A:44:26:49:8C:52:9A:4A:12:78:9A:B1:03:26:88:46:4F:EA:83:0C:41:19:B1:FB:F6:F2:72:43:40:1C:89:1A:CA:00:02:EB:41:12:02:99:03:28:11:44:61:44:28:F8:01:40:EF:D3:01:2F:02:D1:5B:1C:70:46:03:70:09:B0:BD:E8:F0:8F:70:B5:04:46:A5:48:A5:4D:01:26:20:21:04:70:0E:48:2E:70:00:EB:C4:00:01:70:41:70:10:21:81:70:00:22:C1:70:21:46:30:46:FF:F7:EE:FE:00:20:32:46:21:46:28:70:FF:F7:E8:FE:30:46:21:46:02:46:FF:F7:E3:FE:70:BD:84:2C:30:22:14:80:01:20:3C:B1:01:20:3D:B1:01:20:00:02:30:22:B0:01:01:20:E0:5B:00:00:2D:E9:F0:4F:AD:F1:2C:0D:8E:49:0A:68:6B:46:1A:60:8A:88:9A:80:8C:4A:13:88:02:A9:0B:80:93:78:8B:70:8A:4C:00:25:A4:F8:68:50:B4:F8:6A:10:B4:F8:6C:20:09:04:08:34"
    16:48:24.669 --
    16:48:24.669 Outgoing Dump:
    16:48:24.669 0000: 01 05 ff f5 20 70 00 20 f0 01 f2 4f ea 02 22 04 .... p. ...O..".
    16:48:24.669 0010: fb 01 21 02 9a 8c b2 4f ea c5 01 01 eb 45 11 01 ..!....O.....E..
    16:48:24.669 0020: eb 83 01 0a 44 26 49 8c 52 9a 4a 12 78 9a b1 03 ....D&I.R.J.x...
    16:48:24.669 0030: 26 88 46 4f ea 83 0c 41 19 b1 fb f6 f2 72 43 40 &.FO...A.....rC@
    16:48:24.669 0040: 1c 89 1a ca 00 02 eb 41 12 02 99 03 28 11 44 61 .......A....(.Da
    16:48:24.669 0050: 44 28 f8 01 40 ef d3 01 2f 02 d1 5b 1c 70 46 03 D(..@.../..[.pF.
    16:48:24.669 0060: 70 09 b0 bd e8 f0 8f 70 b5 04 46 a5 48 a5 4d 01 p......p..F.H.M.
    16:48:24.669 0070: 26 20 21 04 70 0e 48 2e 70 00 eb c4 00 01 70 41 & !.p.H.p.....pA
    16:48:24.669 0080: 70 10 21 81 70 00 22 c1 70 21 46 30 46 ff f7 ee p.!.p.".p!F0F...
    16:48:24.669 0090: fe 00 20 32 46 21 46 28 70 ff f7 e8 fe 30 46 21 .. 2F!F(p....0F!
    16:48:24.669 00a0: 46 02 46 ff f7 e3 fe 70 bd 84 2c 30 22 14 80 01 F.F....p..,0"...
    16:48:24.669 00b0: 20 3c b1 01 20 3d b1 01 20 00 02 30 22 b0 01 01 <.. =.. ..0"...
    16:48:24.669 00c0: 20 e0 5b 00 00 2d e9 f0 4f ad f1 2c 0d 8e 49 0a .[..-..O..,..I.
    16:48:24.669 00d0: 68 6b 46 1a 60 8a 88 9a 80 8c 4a 13 88 02 a9 0b hkF.`.....J.....
    16:48:24.669 00e0: 80 93 78 8b 70 8a 4c 00 25 a4 f8 68 50 b4 f8 6a ..x.p.L.%..hP..j
    16:48:24.669 00f0: 10 b4 f8 6c 20 09 04 08 34 ...l ...4
    16:48:24.701 Incoming Dump:
    16:48:24.701 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.701 --
    16:48:24.701 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.701 Parameters:
    16:48:24.701 | Number HCI commands : 0x01
    16:48:24.701 | Command Opcode : 0xff05
    16:48:24.701 | Status : 0x00 (Success)
    16:48:24.701 --
    16:48:24.701 --
    16:48:24.701 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.701 | Address : 0x20007110
    16:48:24.701 | Size : 0xf0
    16:48:24.701 | Values : "B4:F8:64:30:8A:18:C9:18:54:4B:2E:46:19:60:01:21:13:46:2A:46:01:FA:06:F7:3B:42:03:D0:7F:4F:BE:54:52:1C:D2:B2:76:1C:20:2E:F4:DB:77:4E:22:88:76:1E:03:92:32:78:04:92:94:F9:4A:20:05:92:78:4A:13:79:06:93:78:4B:1B:78:DF:F8:E0:B1:07:93:93:1C:08:93:92:88:01:28:22:F0:03:02:42:F0:01:02:5A:80:04:D0:88:46:8B:F8:4D:50:08:46:03:E0:88:46:8B:F8:4D:80:02:20:8B:F8:4E:00:26:48:2A:46:05:70:09:92:0A:92:44:48:02:AF:4F:F0:03:0A:05:70:4F:F4:C8:70:20:80:6F:F0:45:00:84:F8:4A:00:1D:48:00:78:01:28:0D:EB:40:01:0C:BF:4F:F0:FF:32:42:46:09:88:97:F9:00:00:12:B2:02:FB:00:F0:40:18:40:1E:1F:FA:80:F9:48:46:FC:F7:75:FE:08:99:80:01:08:80:28:46:F9:F7:2A:FF:28:46:FD:F7:9F:F9:40:46:FC:F7:B8:FC:9B:F8:1D:00:00:28:5D:D1:86:F8:00:80:25:80:05:98:84:F8:4A:00"
    16:48:24.701 --
    16:48:24.701 Outgoing Dump:
    16:48:24.701 0000: 01 05 ff f5 10 71 00 20 f0 b4 f8 64 30 8a 18 c9 .....q. ...d0...
    16:48:24.701 0010: 18 54 4b 2e 46 19 60 01 21 13 46 2a 46 01 fa 06 .TK.F.`.!.F*F...
    16:48:24.701 0020: f7 3b 42 03 d0 7f 4f be 54 52 1c d2 b2 76 1c 20 .;B...O.TR...v.
    16:48:24.701 0030: 2e f4 db 77 4e 22 88 76 1e 03 92 32 78 04 92 94 ...wN".v...2x...
    16:48:24.701 0040: f9 4a 20 05 92 78 4a 13 79 06 93 78 4b 1b 78 df .J ..xJ.y..xK.x.
    16:48:24.701 0050: f8 e0 b1 07 93 93 1c 08 93 92 88 01 28 22 f0 03 ............("..
    16:48:24.701 0060: 02 42 f0 01 02 5a 80 04 d0 88 46 8b f8 4d 50 08 .B...Z....F..MP.
    16:48:24.701 0070: 46 03 e0 88 46 8b f8 4d 80 02 20 8b f8 4e 00 26 F...F..M.. ..N.&
    16:48:24.701 0080: 48 2a 46 05 70 09 92 0a 92 44 48 02 af 4f f0 03 H*F.p....DH..O..
    16:48:24.701 0090: 0a 05 70 4f f4 c8 70 20 80 6f f0 45 00 84 f8 4a ..pO..p .o.E...J
    16:48:24.701 00a0: 00 1d 48 00 78 01 28 0d eb 40 01 0c bf 4f f0 ff ..H.x.(..@...O..
    16:48:24.701 00b0: 32 42 46 09 88 97 f9 00 00 12 b2 02 fb 00 f0 40 2BF............@
    16:48:24.701 00c0: 18 40 1e 1f fa 80 f9 48 46 fc f7 75 fe 08 99 80 .@.....HF..u....
    16:48:24.701 00d0: 01 08 80 28 46 f9 f7 2a ff 28 46 fd f7 9f f9 40 ...(F..*.(F....@
    16:48:24.701 00e0: 46 fc f7 b8 fc 9b f8 1d 00 00 28 5d d1 86 f8 00 F.........(]....
    16:48:24.701 00f0: 80 25 80 05 98 84 f8 4a 00 .%.....J.
    16:48:24.732 Incoming Dump:
    16:48:24.732 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.732 --
    16:48:24.732 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.732 Parameters:
    16:48:24.732 | Number HCI commands : 0x01
    16:48:24.732 | Command Opcode : 0xff05
    16:48:24.732 | Status : 0x00 (Success)
    16:48:24.732 --
    16:48:24.732 --
    16:48:24.732 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.732 | Address : 0x20007200
    16:48:24.732 | Size : 0xf0
    16:48:24.732 | Values : "09:F1:01:00:80:B2:FC:F7:5A:FE:08:99:80:01:08:80:28:46:F9:F7:0F:FF:24:48:00:78:C0:B9:02:E0:C0:46:DF:08:01:20:B4:F8:CE:00:77:69:C0:F3:42:10:B0:75:B4:F8:CE:00:C0:F3:82:00:70:75:28:46:FF:F7:1F:FF:B0:69:CB:F8:00:00:77:61:17:48:80:F8:00:80:09:98:70:B9:FF:E7:15:48:2F:46:80:F8:00:80:38:46:FF:F7:0E:FF:7F:1C:20:2F:F9:DB:0D:E0:C0:46:D8:08:01:20:0E:48:0A:27:DF:F8:B4:90:05:70:19:F8:01:0B:FF:F7:FE:FE:7F:1E:F9:D1:2E:48:01:78:40:46:88:40:0A:99:40:18:C0:B2:0A:90:35:70:28:46:FD:F7:43:F9:40:46:09:90:0B:E0:DC:08:01:20:E0:08:01:20:DD:08:01:20:BA:F1:01:0A:07:F1:01:07:7F:F4:6F:AF:20:48:00:78:1F:49:40:1C:C0:B2:03:28:08:70:FF:F6:61:AF:09:99:1A:48:00:29:08:BF:80:F8:00:80:05:D0:B4:F8:60:10:41:F0:01:01:A4:F8:60:10:00:78:41:46:0A:9A:81:43"
    16:48:24.732 --
    16:48:24.732 Outgoing Dump:
    16:48:24.732 0000: 01 05 ff f5 00 72 00 20 f0 09 f1 01 00 80 b2 fc .....r. ........
    16:48:24.732 0010: f7 5a fe 08 99 80 01 08 80 28 46 f9 f7 0f ff 24 .Z.......(F....$
    16:48:24.732 0020: 48 00 78 c0 b9 02 e0 c0 46 df 08 01 20 b4 f8 ce H.x.....F... ...
    16:48:24.732 0030: 00 77 69 c0 f3 42 10 b0 75 b4 f8 ce 00 c0 f3 82 .wi..B..u.......
    16:48:24.732 0040: 00 70 75 28 46 ff f7 1f ff b0 69 cb f8 00 00 77 .pu(F.....i....w
    16:48:24.732 0050: 61 17 48 80 f8 00 80 09 98 70 b9 ff e7 15 48 2f a.H......p....H/
    16:48:24.732 0060: 46 80 f8 00 80 38 46 ff f7 0e ff 7f 1c 20 2f f9 F....8F...... /.
    16:48:24.732 0070: db 0d e0 c0 46 d8 08 01 20 0e 48 0a 27 df f8 b4 ....F... .H.'...
    16:48:24.732 0080: 90 05 70 19 f8 01 0b ff f7 fe fe 7f 1e f9 d1 2e ..p.............
    16:48:24.732 0090: 48 01 78 40 46 88 40 0a 99 40 18 c0 b2 0a 90 35 H.x@F.@..@.....5
    16:48:24.732 00a0: 70 28 46 fd f7 43 f9 40 46 09 90 0b e0 dc 08 01 p(F..C.@F.......
    16:48:24.732 00b0: 20 e0 08 01 20 dd 08 01 20 ba f1 01 0a 07 f1 01 ... ... .......
    16:48:24.732 00c0: 07 7f f4 6f af 20 48 00 78 1f 49 40 1c c0 b2 03 ...o. H.x.I@....
    16:48:24.732 00d0: 28 08 70 ff f6 61 af 09 99 1a 48 00 29 08 bf 80 (.p..a....H.)...
    16:48:24.732 00e0: f8 00 80 05 d0 b4 f8 60 10 41 f0 01 01 a4 f8 60 .......`.A.....`
    16:48:24.732 00f0: 10 00 78 41 46 0a 9a 81 43 ..xAF...C
    16:48:24.763 Incoming Dump:
    16:48:24.763 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.763 --
    16:48:24.763 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.763 Parameters:
    16:48:24.763 | Number HCI commands : 0x01
    16:48:24.763 | Command Opcode : 0xff05
    16:48:24.763 | Status : 0x00 (Success)
    16:48:24.763 --
    16:48:24.763 --
    16:48:24.763 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.763 | Address : 0x200072f0
    16:48:24.763 | Size : 0xf0
    16:48:24.763 | Values : "19:20:FC:F7:57:FC:04:98:30:70:03:98:20:80:08:98:06:99:41:80:0B:49:07:98:08:80:28:46:FD:F7:0A:F9:0B:B0:BD:E8:F0:8F:C0:46:25:B1:01:20:74:0E:36:22:80:50:00:00:88:50:00:00:50:02:01:20:58:5C:00:00:00:00:01:20:4A:01:01:20:84:08:01:20:CD:00:01:20:DF:08:01:20:2D:E9:F0:4F:67:4E:8B:46:31:88:4B:4F:01:25:21:F0:01:01:41:F0:02:01:31:80:4F:F4:80:51:87:F8:90:55:41:FA:00:F8:3D:70:92:46:26:F8:08:8C:58:46:87:F8:B0:54:FC:F7:F1:FB:B7:4C:20:88:20:F4:E0:60:40:F4:00:70:20:80:50:46:FC:F7:E7:FB:C8:F1:00:00:D4:F8:40:90:26:F8:08:0C:58:46:87:F8:B0:54:FC:F7:DC:FB:20:88:20:F4:40:70:40:F4:80:60:20:80:50:46:FC:F7:D3:FB:4F:F0:00:08:D4:F8:40:A0:26:F8:08:8C:28:46:87:F8:B0:54:FC:F7:C8:FB:DF:F8:B0:B0:28:46:8B:F8:00:80:FC:F7:C1:FB:30:88:20:F0:03:00"
    16:48:24.763 --
    16:48:24.763 Outgoing Dump:
    16:48:24.763 0000: 01 05 ff f5 f0 72 00 20 f0 19 20 fc f7 57 fc 04 .....r. .. ..W..
    16:48:24.763 0010: 98 30 70 03 98 20 80 08 98 06 99 41 80 0b 49 07 .0p.. .....A..I.
    16:48:24.763 0020: 98 08 80 28 46 fd f7 0a f9 0b b0 bd e8 f0 8f c0 ...(F...........
    16:48:24.763 0030: 46 25 b1 01 20 74 0e 36 22 80 50 00 00 88 50 00 F%.. t.6".P...P.
    16:48:24.763 0040: 00 50 02 01 20 58 5c 00 00 00 00 01 20 4a 01 01 .P.. X\..... J..
    16:48:24.763 0050: 20 84 08 01 20 cd 00 01 20 df 08 01 20 2d e9 f0 ... ... ... -..
    16:48:24.763 0060: 4f 67 4e 8b 46 31 88 4b 4f 01 25 21 f0 01 01 41 OgN.F1.KO.%!...A
    16:48:24.763 0070: f0 02 01 31 80 4f f4 80 51 87 f8 90 55 41 fa 00 ...1.O..Q...UA..
    16:48:24.763 0080: f8 3d 70 92 46 26 f8 08 8c 58 46 87 f8 b0 54 fc .=p.F&...XF...T.
    16:48:24.763 0090: f7 f1 fb b7 4c 20 88 20 f4 e0 60 40 f4 00 70 20 ....L . ..`@..p
    16:48:24.763 00a0: 80 50 46 fc f7 e7 fb c8 f1 00 00 d4 f8 40 90 26 .PF..........@.&
    16:48:24.763 00b0: f8 08 0c 58 46 87 f8 b0 54 fc f7 dc fb 20 88 20 ...XF...T.... .
    16:48:24.763 00c0: f4 40 70 40 f4 80 60 20 80 50 46 fc f7 d3 fb 4f .@p@..` .PF....O
    16:48:24.763 00d0: f0 00 08 d4 f8 40 a0 26 f8 08 8c 28 46 87 f8 b0 .....@.&...(F...
    16:48:24.763 00e0: 54 fc f7 c8 fb df f8 b0 b0 28 46 8b f8 00 80 fc T........(F.....
    16:48:24.763 00f0: f7 c1 fb 30 88 20 f0 03 00 ...0. ...
    16:48:24.794 Incoming Dump:
    16:48:24.794 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.794 --
    16:48:24.794 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.794 Parameters:
    16:48:24.794 | Number HCI commands : 0x01
    16:48:24.794 | Command Opcode : 0xff05
    16:48:24.794 | Status : 0x00 (Success)
    16:48:24.794 --
    16:48:24.794 --
    16:48:24.794 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.794 | Address : 0x200073e0
    16:48:24.794 | Size : 0xf0
    16:48:24.794 | Values : "30:80:28:46:87:F8:90:55:FC:F7:B8:FB:87:F8:00:80:8B:F8:00:50:20:88:A9:EB:0A:09:20:F4:E0:60:20:80:48:46:BD:E8:F0:8F:00:B5:14:22:20:21:06:20:FF:F7:99:FF:00:F5:80:60:00:11:00:BD:30:B5:8E:4D:28:88:20:F4:C0:40:40:F4:80:50:28:80:20:20:FC:F7:96:FB:28:88:20:F4:E0:40:40:F4:00:50:28:80:14:20:FC:F7:8D:FB:2C:6C:28:88:20:F4:80:40:40:F4:40:50:28:80:20:20:FC:F7:83:FB:28:88:20:F4:40:50:40:F4:80:40:28:80:14:20:FC:F7:7A:FB:29:6C:64:1A:28:88:04:F5:80:74:20:F4:E0:40:28:80:60:12:30:BD:10:00:3F:22:4C:0C:34:22:2D:E9:F0:4F:AD:F1:3C:0D:94:48:00:68:94:49:00:90:91:F8:C6:00:6F:4C:05:90:20:46:0C:30:00:78:06:90:10:48:07:90:28:38:07:90:00:78:DF:F8:38:82:08:90:01:20:A1:F8:88:00:20:46:0D:30:00:88:20:F0:07:00:40:F0:08:00:A4:F8:0D:00:08:20:20:73"
    16:48:24.794 --
    16:48:24.794 Outgoing Dump:
    16:48:24.794 0000: 01 05 ff f5 e0 73 00 20 f0 30 80 28 46 87 f8 90 .....s. .0.(F...
    16:48:24.794 0010: 55 fc f7 b8 fb 87 f8 00 80 8b f8 00 50 20 88 a9 U...........P ..
    16:48:24.794 0020: eb 0a 09 20 f4 e0 60 20 80 48 46 bd e8 f0 8f 00 ... ..` .HF.....
    16:48:24.794 0030: b5 14 22 20 21 06 20 ff f7 99 ff 00 f5 80 60 00 .." !. .......`.
    16:48:24.794 0040: 11 00 bd 30 b5 8e 4d 28 88 20 f4 c0 40 40 f4 80 ...0..M(. ..@@..
    16:48:24.794 0050: 50 28 80 20 20 fc f7 96 fb 28 88 20 f4 e0 40 40 P(. ....(. ..@@
    16:48:24.794 0060: f4 00 50 28 80 14 20 fc f7 8d fb 2c 6c 28 88 20 ..P(.. ....,l(.
    16:48:24.794 0070: f4 80 40 40 f4 40 50 28 80 20 20 fc f7 83 fb 28 ..@@.@P(. ....(
    16:48:24.794 0080: 88 20 f4 40 50 40 f4 80 40 28 80 14 20 fc f7 7a . .@P@..@(.. ..z
    16:48:24.794 0090: fb 29 6c 64 1a 28 88 04 f5 80 74 20 f4 e0 40 28 .)ld.(....t ..@(
    16:48:24.794 00a0: 80 60 12 30 bd 10 00 3f 22 4c 0c 34 22 2d e9 f0 .`.0...?"L.4"-..
    16:48:24.794 00b0: 4f ad f1 3c 0d 94 48 00 68 94 49 00 90 91 f8 c6 O..<..H.h.I.....
    16:48:24.794 00c0: 00 6f 4c 05 90 20 46 0c 30 00 78 06 90 10 48 07 .oL.. F.0.x...H.
    16:48:24.794 00d0: 90 28 38 07 90 00 78 df f8 38 82 08 90 01 20 a1 .(8...x..8.... .
    16:48:24.794 00e0: f8 88 00 20 46 0d 30 00 88 20 f0 07 00 40 f0 08 ... F.0.. ...@..
    16:48:24.794 00f0: 00 a4 f8 0d 00 08 20 20 73 ...... s
    16:48:24.826 Incoming Dump:
    16:48:24.826 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.826 --
    16:48:24.826 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.826 Parameters:
    16:48:24.826 | Number HCI commands : 0x01
    16:48:24.826 | Command Opcode : 0xff05
    16:48:24.826 | Status : 0x00 (Success)
    16:48:24.826 --
    16:48:24.826 --
    16:48:24.826 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.826 | Address : 0x200074d0
    16:48:24.826 | Size : 0xf0
    16:48:24.826 | Values : "01:20:88:F8:01:00:00:20:02:46:02:2A:88:F8:00:00:80:F2:E8:80:02:E0:C0:46:2C:F8:01:20:40:F2:FA:30:09:90:A0:F1:21:00:00:21:09:90:40:F2:3D:10:0A:90:00:F1:32:00:0A:90:0B:91:0C:90:00:F1:62:00:0C:90:00:25:AB:46:00:2D:0C:BF:01:20:02:20:00:26:71:49:AD:F1:01:09:37:46:A1:F8:C2:00:30:46:0D:90:00:20:0E:90:19:F8:01:AF:6D:49:4F:EA:CA:10:40:F0:02:00:08:80:00:20:FA:F7:F6:FC:20:88:20:F0:20:00:40:F0:10:00:20:80:06:20:FC:F7:01:FB:20:88:20:F0:10:00:40:F0:20:00:20:80:01:20:FC:F7:F8:FA:20:88:20:F0:30:00:4F:EA:4A:01:20:80:B4:F8:4C:00:01:F6:13:11:4F:EA:00:40:B0:FB:F1:F0:06:44:98:F8:00:00:68:B9:FF:F7:39:FF:0D:EB:87:01:48:60:FF:F7:3E:FF:0D:9A:0B:99:0E:9B:12:18:4B:41:0E:93:0D:92:FD:F7:EE:FA:7F:1C:04:2F:BD:DB:98:F8:00:00:00:28:55:D1:01:99"
    16:48:24.826 --
    16:48:24.826 Outgoing Dump:
    16:48:24.826 0000: 01 05 ff f5 d0 74 00 20 f0 01 20 88 f8 01 00 00 .....t. .. .....
    16:48:24.826 0010: 20 02 46 02 2a 88 f8 00 00 80 f2 e8 80 02 e0 c0 .F.*...........
    16:48:24.826 0020: 46 2c f8 01 20 40 f2 fa 30 09 90 a0 f1 21 00 00 F,.. @..0....!..
    16:48:24.826 0030: 21 09 90 40 f2 3d 10 0a 90 00 f1 32 00 0a 90 0b !..@.=.....2....
    16:48:24.826 0040: 91 0c 90 00 f1 62 00 0c 90 00 25 ab 46 00 2d 0c .....b....%.F.-.
    16:48:24.826 0050: bf 01 20 02 20 00 26 71 49 ad f1 01 09 37 46 a1 .. . .&qI....7F.
    16:48:24.826 0060: f8 c2 00 30 46 0d 90 00 20 0e 90 19 f8 01 af 6d ...0F... ......m
    16:48:24.826 0070: 49 4f ea ca 10 40 f0 02 00 08 80 00 20 fa f7 f6 IO...@...... ...
    16:48:24.826 0080: fc 20 88 20 f0 20 00 40 f0 10 00 20 80 06 20 fc . . . .@... .. .
    16:48:24.826 0090: f7 01 fb 20 88 20 f0 10 00 40 f0 20 00 20 80 01 ... . ...@. . ..
    16:48:24.826 00a0: 20 fc f7 f8 fa 20 88 20 f0 30 00 4f ea 4a 01 20 .... . .0.O.J.
    16:48:24.826 00b0: 80 b4 f8 4c 00 01 f6 13 11 4f ea 00 40 b0 fb f1 ...L.....O..@...
    16:48:24.826 00c0: f0 06 44 98 f8 00 00 68 b9 ff f7 39 ff 0d eb 87 ..D....h...9....
    16:48:24.826 00d0: 01 48 60 ff f7 3e ff 0d 9a 0b 99 0e 9b 12 18 4b .H`..>.........K
    16:48:24.826 00e0: 41 0e 93 0d 92 fd f7 ee fa 7f 1c 04 2f bd db 98 A.........../...
    16:48:24.826 00f0: f8 00 00 00 28 55 d1 01 99 ....(U...
    16:48:24.857 Incoming Dump:
    16:48:24.857 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.857 --
    16:48:24.857 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.857 Parameters:
    16:48:24.857 | Number HCI commands : 0x01
    16:48:24.857 | Command Opcode : 0xff05
    16:48:24.857 | Status : 0x00 (Success)
    16:48:24.857 --
    16:48:24.857 --
    16:48:24.857 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.857 | Address : 0x200075c0
    16:48:24.857 | Size : 0xf0
    16:48:24.857 | Values : "02:98:40:18:03:99:09:18:04:98:40:18:81:08:0D:98:87:08:0E:98:80:07:07:43:45:48:1F:FA:8B:F3:89:46:B0:FB:F1:F0:82:B2:19:46:15:20:FC:F7:DB:FA:78:00:1F:FA:8B:F1:00:EB:C7:00:1F:FA:90:F2:16:20:FC:F7:D1:FA:38:48:28:44:00:F1:AE:00:3D:BB:02:99:4F:F4:8E:72:01:9B:40:F2:FA:3C:DD:F8:0C:E0:DD:F8:24:90:4A:43:0C:FB:03:22:40:F2:3D:1C:0C:FB:1E:22:DD:F8:10:C0:09:FB:1C:22:4F:F4:DA:79:09:FB:01:F1:4F:F4:61:79:09:FB:03:11:37:23:03:FB:0E:11:0A:9B:D2:09:03:FB:1C:11:89:0A:03:E0:60:A0:01:20:00:22:49:46:07:80:82:80:01:81:98:F8:00:00:0B:EB:40:00:81:B2:0C:98:B6:08:4F:F4:7A:72:70:43:B0:FB:F2:F0:82:B2:3B:20:FC:F7:8F:FA:98:F8:00:00:05:EB:80:01:AD:1C:14:48:0B:F1:01:0B:04:2D:08:44:A0:F8:A6:60:FF:F6:39:AF:98:F8:00:00:40:1C:C0:B2:02:28:88:F8:00:00"
    16:48:24.857 --
    16:48:24.857 Outgoing Dump:
    16:48:24.857 0000: 01 05 ff f5 c0 75 00 20 f0 02 98 40 18 03 99 09 .....u. ...@....
    16:48:24.857 0010: 18 04 98 40 18 81 08 0d 98 87 08 0e 98 80 07 07 ...@............
    16:48:24.857 0020: 43 45 48 1f fa 8b f3 89 46 b0 fb f1 f0 82 b2 19 CEH.....F.......
    16:48:24.857 0030: 46 15 20 fc f7 db fa 78 00 1f fa 8b f1 00 eb c7 F. ....x........
    16:48:24.857 0040: 00 1f fa 90 f2 16 20 fc f7 d1 fa 38 48 28 44 00 ...... ....8H(D.
    16:48:24.857 0050: f1 ae 00 3d bb 02 99 4f f4 8e 72 01 9b 40 f2 fa ...=...O..r..@..
    16:48:24.857 0060: 3c dd f8 0c e0 dd f8 24 90 4a 43 0c fb 03 22 40 <......$.JC..."@
    16:48:24.857 0070: f2 3d 1c 0c fb 1e 22 dd f8 10 c0 09 fb 1c 22 4f .=...."......."O
    16:48:24.857 0080: f4 da 79 09 fb 01 f1 4f f4 61 79 09 fb 03 11 37 ..y....O.ay....7
    16:48:24.857 0090: 23 03 fb 0e 11 0a 9b d2 09 03 fb 1c 11 89 0a 03 #...............
    16:48:24.857 00a0: e0 60 a0 01 20 00 22 49 46 07 80 82 80 01 81 98 .`.. ."IF.......
    16:48:24.857 00b0: f8 00 00 0b eb 40 00 81 b2 0c 98 b6 08 4f f4 7a .....@.......O.z
    16:48:24.857 00c0: 72 70 43 b0 fb f2 f0 82 b2 3b 20 fc f7 8f fa 98 rpC......; .....
    16:48:24.857 00d0: f8 00 00 05 eb 80 01 ad 1c 14 48 0b f1 01 0b 04 ..........H.....
    16:48:24.857 00e0: 2d 08 44 a0 f8 a6 60 ff f6 39 af 98 f8 00 00 40 -.D...`..9.....@
    16:48:24.857 00f0: 1c c0 b2 02 28 88 f8 00 00 ....(....
    16:48:24.888 Incoming Dump:
    16:48:24.888 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.888 --
    16:48:24.888 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.888 Parameters:
    16:48:24.888 | Number HCI commands : 0x01
    16:48:24.888 | Command Opcode : 0xff05
    16:48:24.888 | Status : 0x00 (Success)
    16:48:24.888 --
    16:48:24.888 --
    16:48:24.888 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.888 | Address : 0x200076b0
    16:48:24.888 | Size : 0xf0
    16:48:24.888 | Values : "FF:F6:2E:AF:00:20:0B:49:88:F8:01:00:05:98:81:F8:C6:00:06:98:20:73:08:99:07:98:01:70:05:49:00:20:A1:F8:88:00:0F:B0:A1:F8:C2:00:BD:E8:F0:8F:C0:46:8C:50:00:00:50:02:01:20:9E:08:01:20:00:00:01:20:8A:A9:31:00:03:46:48:10:01:21:40:1C:91:40:18:40:49:1E:40:42:18:43:08:40:70:47:2D:E9:F8:41:07:46:10:68:8E:46:00:F0:07:06:C5:10:00:F0:07:04:9E:19:05:F0:03:01:08:2E:04:DD:C6:10:06:F0:03:06:03:2E:1E:D0:C9:19:0F:78:18:18:B5:EB:E0:0F:0E:D0:E0:18:11:F8:01:5F:01:26:08:38:C4:F1:08:01:84:46:06:FA:01:F1:49:1E:39:40:81:40:08:46:29:E0:C4:F1:08:04:01:26:E4:1A:9E:40:27:41:76:1E:06:EA:07:00:2B:E0:E0:18:01:26:F9:78:A0:F1:08:0C:6D:1C:C4:F1:08:00:06:FA:00:F0:40:1E:08:40:DE:F8:00:10:05:F0:03:05:00:91:8E:46:DD:F8:1C:80:1D:F8:05:50:D8:F8:00:10"
    16:48:24.888 --
    16:48:24.888 Outgoing Dump:
    16:48:24.888 0000: 01 05 ff f5 b0 76 00 20 f0 ff f6 2e af 00 20 0b .....v. ...... .
    16:48:24.888 0010: 49 88 f8 01 00 05 98 81 f8 c6 00 06 98 20 73 08 I............ s.
    16:48:24.888 0020: 99 07 98 01 70 05 49 00 20 a1 f8 88 00 0f b0 a1 ....p.I. .......
    16:48:24.888 0030: f8 c2 00 bd e8 f0 8f c0 46 8c 50 00 00 50 02 01 ........F.P..P..
    16:48:24.888 0040: 20 9e 08 01 20 00 00 01 20 8a a9 31 00 03 46 48 ... ... ..1..FH
    16:48:24.888 0050: 10 01 21 40 1c 91 40 18 40 49 1e 40 42 18 43 08 ..!@..@.@I.@B.C.
    16:48:24.888 0060: 40 70 47 2d e9 f8 41 07 46 10 68 8e 46 00 f0 07 @pG-..A.F.h.F...
    16:48:24.888 0070: 06 c5 10 00 f0 07 04 9e 19 05 f0 03 01 08 2e 04 ................
    16:48:24.888 0080: dd c6 10 06 f0 03 06 03 2e 1e d0 c9 19 0f 78 18 ..............x.
    16:48:24.888 0090: 18 b5 eb e0 0f 0e d0 e0 18 11 f8 01 5f 01 26 08 ............_.&.
    16:48:24.888 00a0: 38 c4 f1 08 01 84 46 06 fa 01 f1 49 1e 39 40 81 8.....F....I.9@.
    16:48:24.888 00b0: 40 08 46 29 e0 c4 f1 08 04 01 26 e4 1a 9e 40 27 @.F)......&...@'
    16:48:24.888 00c0: 41 76 1e 06 ea 07 00 2b e0 e0 18 01 26 f9 78 a0 Av.....+....&.x.
    16:48:24.888 00d0: f1 08 0c 6d 1c c4 f1 08 00 06 fa 00 f0 40 1e 08 ...m.........@..
    16:48:24.888 00e0: 40 de f8 00 10 05 f0 03 05 00 91 8e 46 dd f8 1c @...........F...
    16:48:24.888 00f0: 80 1d f8 05 50 d8 f8 00 10 ....P....
    16:48:24.919 Incoming Dump:
    16:48:24.919 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.919 --
    16:48:24.919 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.919 Parameters:
    16:48:24.919 | Number HCI commands : 0x01
    16:48:24.919 | Command Opcode : 0xff05
    16:48:24.919 | Status : 0x00 (Success)
    16:48:24.919 --
    16:48:24.919 --
    16:48:24.919 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.919 | Address : 0x200077a0
    16:48:24.919 | Size : 0xf0
    16:48:24.919 | Values : "C7:F8:00:E0:00:FA:0C:F0:00:B2:09:1D:C8:F8:00:10:C3:F1:08:01:09:1B:08:31:0D:41:06:FA:0C:F1:9E:40:49:1E:76:1E:29:40:08:43:11:68:5B:18:00:B2:13:60:31:46:10:22:FF:F7:8E:FF:00:B2:BD:E8:F8:81:F0:B5:AD:F1:14:0D:07:46:01:91:08:68:03:90:01:98:00:1D:9D:F8:0D:10:01:90:00:68:9D:F8:0E:30:04:90:9D:F8:0C:00:41:EA:00:21:9D:F8:0F:00:0A:B2:FE:26:27:F8:04:1B:40:EA:03:20:00:B2:04:46:27:F8:04:0B:80:1A:05:B2:20:20:02:90:02:98:10:F0:1F:0F:06:D1:01:98:01:68:03:91:00:1D:01:90:00:68:04:90:01:A8:00:90:02:23:02:AA:04:A9:03:A8:FF:F7:5F:FF:10:F1:02:0F:12:D1:02:98:10:F0:1F:0F:06:D1:01:98:01:68:03:91:00:1D:01:90:00:68:04:90:01:A8:00:90:08:23:02:AA:04:A9:03:A8:FF:F7:49:FF:41:19:0D:B2:76:1E:05:EB:04:01:27:F8:04:1B:0C:B2:CD:D1:01:98:05:B0:F0:BD"
    16:48:24.919 --
    16:48:24.919 Outgoing Dump:
    16:48:24.919 0000: 01 05 ff f5 a0 77 00 20 f0 c7 f8 00 e0 00 fa 0c .....w. ........
    16:48:24.919 0010: f0 00 b2 09 1d c8 f8 00 10 c3 f1 08 01 09 1b 08 ................
    16:48:24.919 0020: 31 0d 41 06 fa 0c f1 9e 40 49 1e 76 1e 29 40 08 1.A.....@I.v.)@.
    16:48:24.919 0030: 43 11 68 5b 18 00 b2 13 60 31 46 10 22 ff f7 8e C.h[....`1F."...
    16:48:24.919 0040: ff 00 b2 bd e8 f8 81 f0 b5 ad f1 14 0d 07 46 01 ..............F.
    16:48:24.919 0050: 91 08 68 03 90 01 98 00 1d 9d f8 0d 10 01 90 00 ..h.............
    16:48:24.919 0060: 68 9d f8 0e 30 04 90 9d f8 0c 00 41 ea 00 21 9d h...0......A..!.
    16:48:24.919 0070: f8 0f 00 0a b2 fe 26 27 f8 04 1b 40 ea 03 20 00 ......&'...@.. .
    16:48:24.919 0080: b2 04 46 27 f8 04 0b 80 1a 05 b2 20 20 02 90 02 ..F'....... ...
    16:48:24.919 0090: 98 10 f0 1f 0f 06 d1 01 98 01 68 03 91 00 1d 01 ..........h.....
    16:48:24.919 00a0: 90 00 68 04 90 01 a8 00 90 02 23 02 aa 04 a9 03 ..h.......#.....
    16:48:24.919 00b0: a8 ff f7 5f ff 10 f1 02 0f 12 d1 02 98 10 f0 1f ..._............
    16:48:24.919 00c0: 0f 06 d1 01 98 01 68 03 91 00 1d 01 90 00 68 04 ......h.......h.
    16:48:24.919 00d0: 90 01 a8 00 90 08 23 02 aa 04 a9 03 a8 ff f7 49 ......#........I
    16:48:24.919 00e0: ff 41 19 0d b2 76 1e 05 eb 04 01 27 f8 04 1b 0c .A...v.....'....
    16:48:24.919 00f0: b2 cd d1 01 98 05 b0 f0 bd .........
    16:48:24.951 Incoming Dump:
    16:48:24.951 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.951 --
    16:48:24.951 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.951 Parameters:
    16:48:24.951 | Number HCI commands : 0x01
    16:48:24.951 | Command Opcode : 0xff05
    16:48:24.951 | Status : 0x00 (Success)
    16:48:24.951 --
    16:48:24.951 --
    16:48:24.951 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.951 | Address : 0x20007890
    16:48:24.951 | Size : 0xf0
    16:48:24.951 | Values : "30:B5:10:48:00:78:04:28:04:DB:0A:28:AC:BF:02:21:01:21:00:E0:00:21:0C:02:1C:20:22:46:FC:F7:7A:F9:09:4D:0A:49:01:20:09:19:09:4C:28:70:20:46:80:1E:FF:F7:8D:FF:01:46:20:46:FF:F7:89:FF:00:20:28:70:30:BD:C0:46:A7:01:01:20:C0:00:3F:22:00:60:00:00:02:FC:01:20:02:46:08:46:11:46:67:4A:13:68:67:4A:12:68:A2:FB:03:23:1B:02:12:0E:1A:43:80:1A:0A:60:70:47:2D:E9:FF:4F:01:21:61:48:62:4A:A0:F8:88:10:41:F6:82:51:11:80:5C:4E:5F:49:B0:F8:70:20:82:46:4F:F0:00:08:47:46:45:46:44:46:51:43:01:91:41:46:02:91:00:F1:72:0B:03:91:B4:3E:86:F8:02:80:00:2F:86:F8:00:80:0C:BF:01:20:02:20:AA:F8:C2:00:40:46:FA:F7:F0:FA:B6:F8:44:00:20:F0:0F:00:A6:F8:44:00:FF:20:86:F8:48:00:05:20:FC:F7:F8:F8:86:F8:48:80:01:99:68:46:FF:F7:B6:FF:4F:F0:06:09:02:46:00:2A"
    16:48:24.951 --
    16:48:24.951 Outgoing Dump:
    16:48:24.951 0000: 01 05 ff f5 90 78 00 20 f0 30 b5 10 48 00 78 04 .....x. .0..H.x.
    16:48:24.951 0010: 28 04 db 0a 28 ac bf 02 21 01 21 00 e0 00 21 0c (...(...!.!...!.
    16:48:24.951 0020: 02 1c 20 22 46 fc f7 7a f9 09 4d 0a 49 01 20 09 .. "F..z..M.I. .
    16:48:24.951 0030: 19 09 4c 28 70 20 46 80 1e ff f7 8d ff 01 46 20 ..L(p F.......F
    16:48:24.951 0040: 46 ff f7 89 ff 00 20 28 70 30 bd c0 46 a7 01 01 F..... (p0..F...
    16:48:24.951 0050: 20 c0 00 3f 22 00 60 00 00 02 fc 01 20 02 46 08 ..?".`..... .F.
    16:48:24.951 0060: 46 11 46 67 4a 13 68 67 4a 12 68 a2 fb 03 23 1b F.FgJ.hgJ.h...#.
    16:48:24.951 0070: 02 12 0e 1a 43 80 1a 0a 60 70 47 2d e9 ff 4f 01 ....C...`pG-..O.
    16:48:24.951 0080: 21 61 48 62 4a a0 f8 88 10 41 f6 82 51 11 80 5c !aHbJ....A..Q..\
    16:48:24.951 0090: 4e 5f 49 b0 f8 70 20 82 46 4f f0 00 08 47 46 45 N_I..p .FO...GFE
    16:48:24.951 00a0: 46 44 46 51 43 01 91 41 46 02 91 00 f1 72 0b 03 FDFQC..AF....r..
    16:48:24.951 00b0: 91 b4 3e 86 f8 02 80 00 2f 86 f8 00 80 0c bf 01 ..>...../.......
    16:48:24.951 00c0: 20 02 20 aa f8 c2 00 40 46 fa f7 f0 fa b6 f8 44 . ....@F......D
    16:48:24.951 00d0: 00 20 f0 0f 00 a6 f8 44 00 ff 20 86 f8 48 00 05 . .....D.. ..H..
    16:48:24.951 00e0: 20 fc f7 f8 f8 86 f8 48 80 01 99 68 46 ff f7 b6 ......H...hF...
    16:48:24.951 00f0: ff 4f f0 06 09 02 46 00 2a .O....F.*
    16:48:24.982 Incoming Dump:
    16:48:24.982 0000: 04 0e 04 01 05 ff 00 .......
    16:48:24.982 --
    16:48:24.982 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:24.982 Parameters:
    16:48:24.982 | Number HCI commands : 0x01
    16:48:24.982 | Command Opcode : 0xff05
    16:48:24.982 | Status : 0x00 (Success)
    16:48:24.982 --
    16:48:24.982 --
    16:48:24.982 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:24.982 | Address : 0x20007980
    16:48:24.982 | Size : 0xf0
    16:48:24.982 | Values : "B8:BF:52:42:45:49:91:42:27:DA:45:49:49:08:89:18:43:4A:00:28:91:FB:F2:F1:BA:B2:4C:BF:61:1A:21:44:06:20:4C:B2:A1:B2:FC:F7:FD:F8:10:2C:05:DA:14:F1:10:0F:05:DA:6F:F0:0F:04:00:E0:0F:24:01:20:02:90:B4:70:05:20:86:F8:E2:40:FC:F7:C8:F8:01:99:68:46:FF:F7:88:FF:B9:F1:01:09:D0:D1:4F:F0:06:09:02:46:00:2A:B8:BF:52:42:2F:49:91:42:26:DA:2E:49:49:08:89:18:2D:4A:00:28:91:FB:F2:F1:49:B2:BA:B2:4C:BF:69:1A:29:44:07:20:4D:B2:A9:B2:FC:F7:CB:F8:10:2D:05:DA:15:F1:10:0F:05:DA:6F:F0:0F:05:00:E0:0F:25:01:20:03:90:35:70:05:20:FC:F7:98:F8:01:99:68:46:FF:F7:58:FF:B9:F1:01:09:D1:D1:E8:B2:40:EA:04:20:2B:F8:02:0B:02:98:20:B1:BA:B2:A1:B2:0F:20:FC:F7:A9:F8:03:98:20:B1:BA:B2:A9:B2:10:20:FC:F7:A2:F8:86:F8:02:80:86:F8:00:80:FD:F7:90:F8:7F:1C:45:46"
    16:48:24.982 --
    16:48:24.982 Outgoing Dump:
    16:48:24.982 0000: 01 05 ff f5 80 79 00 20 f0 b8 bf 52 42 45 49 91 .....y. ...RBEI.
    16:48:24.982 0010: 42 27 da 45 49 49 08 89 18 43 4a 00 28 91 fb f2 B'.EII...CJ.(...
    16:48:24.982 0020: f1 ba b2 4c bf 61 1a 21 44 06 20 4c b2 a1 b2 fc ...L.a.!D. L....
    16:48:24.982 0030: f7 fd f8 10 2c 05 da 14 f1 10 0f 05 da 6f f0 0f ....,........o..
    16:48:24.982 0040: 04 00 e0 0f 24 01 20 02 90 b4 70 05 20 86 f8 e2 ....$. ...p. ...
    16:48:24.982 0050: 40 fc f7 c8 f8 01 99 68 46 ff f7 88 ff b9 f1 01 @......hF.......
    16:48:24.982 0060: 09 d0 d1 4f f0 06 09 02 46 00 2a b8 bf 52 42 2f ...O....F.*..RB/
    16:48:24.982 0070: 49 91 42 26 da 2e 49 49 08 89 18 2d 4a 00 28 91 I.B&..II...-J.(.
    16:48:24.982 0080: fb f2 f1 49 b2 ba b2 4c bf 69 1a 29 44 07 20 4d ...I...L.i.)D. M
    16:48:24.982 0090: b2 a9 b2 fc f7 cb f8 10 2d 05 da 15 f1 10 0f 05 ........-.......
    16:48:24.982 00a0: da 6f f0 0f 05 00 e0 0f 25 01 20 03 90 35 70 05 .o......%. ..5p.
    16:48:24.982 00b0: 20 fc f7 98 f8 01 99 68 46 ff f7 58 ff b9 f1 01 ......hF..X....
    16:48:24.982 00c0: 09 d1 d1 e8 b2 40 ea 04 20 2b f8 02 0b 02 98 20 .....@.. +.....
    16:48:24.982 00d0: b1 ba b2 a1 b2 0f 20 fc f7 a9 f8 03 98 20 b1 ba ...... ...... ..
    16:48:24.982 00e0: b2 a9 b2 10 20 fc f7 a2 f8 86 f8 02 80 86 f8 00 .... ...........
    16:48:24.982 00f0: 80 fd f7 90 f8 7f 1c 45 46 .......EF
    16:48:25.013 Incoming Dump:
    16:48:25.013 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.013 --
    16:48:25.013 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.013 Parameters:
    16:48:25.013 | Number HCI commands : 0x01
    16:48:25.013 | Command Opcode : 0xff05
    16:48:25.013 | Status : 0x00 (Success)
    16:48:25.013 --
    16:48:25.013 --
    16:48:25.013 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.013 | Address : 0x20007a70
    16:48:25.013 | Size : 0xf0
    16:48:25.013 | Values : "AA:F8:C2:80:44:46:AA:F8:88:80:02:2F:FF:F6:5D:AF:00:90:BD:E8:FF:8F:C0:46:D0:A0:01:20:80:08:01:20:50:02:01:20:00:00:01:20:40:42:0F:00:60:07:0B:01:40:78:7D:01:E0:67:35:00:40:4B:4C:00:2D:E9:F8:4F:F8:F7:3D:FB:F8:F7:55:FB:4E:49:10:20:08:70:4E:48:00:21:80:F8:50:10:C1:6C:4C:48:00:22:88:42:16:D2:4B:48:88:42:10:D2:4B:48:88:42:08:D2:46:49:01:20:4F:F0:03:0E:4F:F0:04:09:81:F8:50:00:0A:E0:4F:F0:02:0E:4F:F0:03:09:05:E0:4F:F0:02:0E:01:E0:4F:F0:01:0E:F1:46:3C:48:F4:46:3B:49:90:F8:50:00:E1:45:00:F0:01:00:81:F8:50:00:62:DB:08:46:4C:30:00:68:DF:F8:F4:B0:00:90:A9:EB:0C:00:00:F1:01:08:39:48:00:99:35:4B:B1:FB:FC:F6:B3:42:4F:F0:00:01:2E:D8:32:4B:B3:FB:F6:F3:5B:1C:9B:B2:06:FB:03:F5:30:4B:AB:42:24:D9:B5:FB:FB:F3:DF:F8:C0:A0:9F:B2:0B:FB"
    16:48:25.013 --
    16:48:25.013 Outgoing Dump:
    16:48:25.013 0000: 01 05 ff f5 70 7a 00 20 f0 aa f8 c2 80 44 46 aa ....pz. .....DF.
    16:48:25.013 0010: f8 88 80 02 2f ff f6 5d af 00 90 bd e8 ff 8f c0 ..../..]........
    16:48:25.013 0020: 46 d0 a0 01 20 80 08 01 20 50 02 01 20 00 00 01 F... ... P.. ...
    16:48:25.013 0030: 20 40 42 0f 00 60 07 0b 01 40 78 7d 01 e0 67 35 @B..`...@x}..g5
    16:48:25.013 0040: 00 40 4b 4c 00 2d e9 f8 4f f8 f7 3d fb f8 f7 55 .@KL.-..O..=...U
    16:48:25.013 0050: fb 4e 49 10 20 08 70 4e 48 00 21 80 f8 50 10 c1 .NI. .pNH.!..P..
    16:48:25.013 0060: 6c 4c 48 00 22 88 42 16 d2 4b 48 88 42 10 d2 4b lLH.".B..KH.B..K
    16:48:25.013 0070: 48 88 42 08 d2 46 49 01 20 4f f0 03 0e 4f f0 04 H.B..FI. O...O..
    16:48:25.013 0080: 09 81 f8 50 00 0a e0 4f f0 02 0e 4f f0 03 09 05 ...P...O...O....
    16:48:25.013 0090: e0 4f f0 02 0e 01 e0 4f f0 01 0e f1 46 3c 48 f4 .O.....O....F<H.
    16:48:25.013 00a0: 46 3b 49 90 f8 50 00 e1 45 00 f0 01 00 81 f8 50 F;I..P..E......P
    16:48:25.013 00b0: 00 62 db 08 46 4c 30 00 68 df f8 f4 b0 00 90 a9 .b..FL0.h.......
    16:48:25.013 00c0: eb 0c 00 00 f1 01 08 39 48 00 99 35 4b b1 fb fc .......9H..5K...
    16:48:25.013 00d0: f6 b3 42 4f f0 00 01 2e d8 32 4b b3 fb f6 f3 5b ..BO.....2K....[
    16:48:25.013 00e0: 1c 9b b2 06 fb 03 f5 30 4b ab 42 24 d9 b5 fb fb .......0K.B$....
    16:48:25.013 00f0: f3 df f8 c0 a0 9f b2 0b fb .........
    16:48:25.044 Incoming Dump:
    16:48:25.044 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.044 --
    16:48:25.044 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.044 Parameters:
    16:48:25.044 | Number HCI commands : 0x01
    16:48:25.044 | Command Opcode : 0xff05
    16:48:25.044 | Status : 0x00 (Success)
    16:48:25.044 --
    16:48:25.044 --
    16:48:25.044 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.044 | Address : 0x20007b60
    16:48:25.044 | Size : 0xf0
    16:48:25.044 | Values : "17:57:5C:1C:BA:45:07:D9:17:46:07:EB:C7:07:62:3B:F0:37:CF:19:49:1C:C3:55:A7:B2:5B:46:7B:43:5B:1B:57:46:9F:42:07:D9:13:46:03:EB:C3:03:62:3C:F0:33:CB:18:49:1C:C4:54:1E:4B:75:19:AB:42:DA:D8:08:29:0A:D2:13:46:03:EB:C3:03:5D:18:04:46:49:1C:FF:26:F0:34:08:29:66:55:F7:D3:0C:F1:01:01:52:1C:B8:F1:01:08:5F:FA:81:FC:D2:B2:B2:D1:F1:45:08:D1:00:F1:F0:01:0A:68:F9:30:02:60:4A:68:42:60:0A:7A:02:72:05:48:00:68:1F:FA:A0:F1:82:B2:38:20:FB:F7:DA:FF:BD:E8:F8:8F:02:F1:01:20:80:08:01:20:40:78:7D:01:C0:FC:9B:01:00:00:EE:02:80:96:98:00:80:9C:2B:8F:40:0E:E1:93:50:02:01:20:40:42:0F:00:28:E7:09:00:A6:A6:A6:A6:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:0A:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00"
    16:48:25.044 --
    16:48:25.044 Outgoing Dump:
    16:48:25.044 0000: 01 05 ff f5 60 7b 00 20 f0 17 57 5c 1c ba 45 07 ....`{. ..W\..E.
    16:48:25.044 0010: d9 17 46 07 eb c7 07 62 3b f0 37 cf 19 49 1c c3 ..F....b;.7..I..
    16:48:25.044 0020: 55 a7 b2 5b 46 7b 43 5b 1b 57 46 9f 42 07 d9 13 U..[F{C[.WF.B...
    16:48:25.044 0030: 46 03 eb c3 03 62 3c f0 33 cb 18 49 1c c4 54 1e F....b<.3..I..T.
    16:48:25.044 0040: 4b 75 19 ab 42 da d8 08 29 0a d2 13 46 03 eb c3 Ku..B...)...F...
    16:48:25.044 0050: 03 5d 18 04 46 49 1c ff 26 f0 34 08 29 66 55 f7 .]..FI..&.4.)fU.
    16:48:25.044 0060: d3 0c f1 01 01 52 1c b8 f1 01 08 5f fa 81 fc d2 .....R....._....
    16:48:25.044 0070: b2 b2 d1 f1 45 08 d1 00 f1 f0 01 0a 68 f9 30 02 ....E.......h.0.
    16:48:25.044 0080: 60 4a 68 42 60 0a 7a 02 72 05 48 00 68 1f fa a0 `JhB`.z.r.H.h...
    16:48:25.044 0090: f1 82 b2 38 20 fb f7 da ff bd e8 f8 8f 02 f1 01 ...8 ...........
    16:48:25.044 00a0: 20 80 08 01 20 40 78 7d 01 c0 fc 9b 01 00 00 ee ... @x}........
    16:48:25.044 00b0: 02 80 96 98 00 80 9c 2b 8f 40 0e e1 93 50 02 01 .......+.@...P..
    16:48:25.044 00c0: 20 40 42 0f 00 28 e7 09 00 a6 a6 a6 a6 0a 0a 0a @B..(..........
    16:48:25.044 00d0: 0a 0a 0a 0a 0a 0a 0a 0a 0a 0a 0a 0a 0a 0a 0a 0a ................
    16:48:25.044 00e0: 0a 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.044 00f0: 00 00 00 00 00 00 00 00 00 .........
    16:48:25.076 Incoming Dump:
    16:48:25.076 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.076 --
    16:48:25.076 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.076 Parameters:
    16:48:25.076 | Number HCI commands : 0x01
    16:48:25.076 | Command Opcode : 0xff05
    16:48:25.076 | Status : 0x00 (Success)
    16:48:25.076 --
    16:48:25.076 --
    16:48:25.076 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.076 | Address : 0x20007c50
    16:48:25.076 | Size : 0xf0
    16:48:25.076 | Values : "00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:4E:4E:4E:4E:4C:4C:4C:4C:4B:4B:4B:4B:4A:4A:4A:4A:49:49:49:49:46:46:46:46:46:46:46:46:45:45:45:45:44:44:44:44:43:43:43:43:42:42:42:42:42:42:42:42:41:41:41:41:41:41:41:41:40:40:40:40:40:40:40:40:2D:E9:F0:43:DF:F8:D4:C0:BC:F8:00:10:9C:F9:07:00:C1:F3:43:01:0A:46:08:2A:13:DA:07:2A:C2:F1:07:01:0C:D0:06:2A:07:D0:05:2A:05:D0:04:2A:03:D0:03:2A:18:BF:02:2A:05:D1:4F:F0:01:06:04:E0:4F:F0:02:06:01:E0:4F:F0:00:06:DF:F8:9C:80:27:4F:DF:F8:90:90:4F:EA:81:0E:4F:F0:00:03:0E:EB:03:02:19:F8:02:10:18:F8:02:20:34:46:94:B1:64:1E:0B:D0:64:1E:0F:D1:01:F0:0F:04:84:42:03:DC:B0:EB:21:1F:04:DA:06:E0:52:1E:02:E0:81:42:02:DC:52:1C:D5:B2:00:E0:15:46:FD:54:5B:1C:04:2B:DF:D3:3A:78:14:49:0A:70:3A:78"
    16:48:25.076 --
    16:48:25.076 Outgoing Dump:
    16:48:25.076 0000: 01 05 ff f5 50 7c 00 20 f0 00 00 00 00 00 00 00 ....P|. ........
    16:48:25.076 0010: 00 00 00 00 00 00 00 00 00 4e 4e 4e 4e 4c 4c 4c .........NNNNLLL
    16:48:25.076 0020: 4c 4b 4b 4b 4b 4a 4a 4a 4a 49 49 49 49 46 46 46 LKKKKJJJJIIIIFFF
    16:48:25.076 0030: 46 46 46 46 46 45 45 45 45 44 44 44 44 43 43 43 FFFFFEEEEDDDDCCC
    16:48:25.076 0040: 43 42 42 42 42 42 42 42 42 41 41 41 41 41 41 41 CBBBBBBBBAAAAAAA
    16:48:25.076 0050: 41 40 40 40 40 40 40 40 40 2d e9 f0 43 df f8 d4 A@@@@@@@@-..C...
    16:48:25.076 0060: c0 bc f8 00 10 9c f9 07 00 c1 f3 43 01 0a 46 08 ...........C..F.
    16:48:25.076 0070: 2a 13 da 07 2a c2 f1 07 01 0c d0 06 2a 07 d0 05 *...*.......*...
    16:48:25.076 0080: 2a 05 d0 04 2a 03 d0 03 2a 18 bf 02 2a 05 d1 4f *...*...*...*..O
    16:48:25.076 0090: f0 01 06 04 e0 4f f0 02 06 01 e0 4f f0 00 06 df .....O.....O....
    16:48:25.076 00a0: f8 9c 80 27 4f df f8 90 90 4f ea 81 0e 4f f0 00 ...'O....O...O..
    16:48:25.076 00b0: 03 0e eb 03 02 19 f8 02 10 18 f8 02 20 34 46 94 ............ 4F.
    16:48:25.076 00c0: b1 64 1e 0b d0 64 1e 0f d1 01 f0 0f 04 84 42 03 .d...d........B.
    16:48:25.076 00d0: dc b0 eb 21 1f 04 da 06 e0 52 1e 02 e0 81 42 02 ...!.....R....B.
    16:48:25.076 00e0: dc 52 1c d5 b2 00 e0 15 46 fd 54 5b 1c 04 2b df .R......F.T[..+.
    16:48:25.076 00f0: d3 3a 78 14 49 0a 70 3a 78 .:x.I.p:x
    16:48:25.107 Incoming Dump:
    16:48:25.107 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.107 --
    16:48:25.107 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.107 Parameters:
    16:48:25.107 | Number HCI commands : 0x01
    16:48:25.107 | Command Opcode : 0xff05
    16:48:25.107 | Status : 0x00 (Success)
    16:48:25.107 --
    16:48:25.107 --
    16:48:25.107 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.107 | Address : 0x20007d40
    16:48:25.107 | Size : 0xf0
    16:48:25.107 | Values : "8A:70:7A:78:4A:70:7A:78:CA:70:BC:F8:04:20:C2:F3:01:22:01:2A:0F:D1:0A:28:0D:DB:08:78:40:1D:80:B2:4F:28:A8:BF:4F:20:08:70:48:78:40:1D:80:B2:4F:28:A8:BF:4F:20:48:70:BD:E8:F0:83:C0:46:A0:01:01:20:20:7C:00:00:60:7C:00:00:30:B0:01:20:7C:02:01:20:2D:E9:F8:4F:55:4D:00:26:EE:81:AE:81:B5:F8:06:B0:6E:81:51:4F:2E:81:4B:F0:03:00:E8:80:E8:88:3E:70:00:09:0C:D2:97:F8:29:00:4D:49:00:90:08:88:20:F0:70:00:40:F0:20:00:08:80:03:20:87:F8:29:00:49:4C:41:F6:82:50:4F:F0:01:09:DF:F8:1C:81:20:80:A5:F8:52:90:88:F8:00:90:30:46:88:F8:00:60:FA:F7:A2:F8:A5:F8:52:60:FB:F7:D0:FE:A8:81:FC:F7:C7:FE:FB:F7:CB:FE:E8:81:68:89:29:89:40:1A:28:30:28:80:68:89:28:30:AA:89:81:B2:E8:89:80:1A:82:B2:22:20:FB:F7:C1:FE:4F:F4:6C:60:B5:F8:32:A0:60:80:A0:88:6E:81"
    16:48:25.107 --
    16:48:25.107 Outgoing Dump:
    16:48:25.107 0000: 01 05 ff f5 40 7d 00 20 f0 8a 70 7a 78 4a 70 7a ....@}. ..pzxJpz
    16:48:25.107 0010: 78 ca 70 bc f8 04 20 c2 f3 01 22 01 2a 0f d1 0a x.p... ...".*...
    16:48:25.107 0020: 28 0d db 08 78 40 1d 80 b2 4f 28 a8 bf 4f 20 08 (...x@...O(..O .
    16:48:25.107 0030: 70 48 78 40 1d 80 b2 4f 28 a8 bf 4f 20 48 70 bd pHx@...O(..O Hp.
    16:48:25.107 0040: e8 f0 83 c0 46 a0 01 01 20 20 7c 00 00 60 7c 00 ....F... |..`|.
    16:48:25.107 0050: 00 30 b0 01 20 7c 02 01 20 2d e9 f8 4f 55 4d 00 .0.. |.. -..OUM.
    16:48:25.107 0060: 26 ee 81 ae 81 b5 f8 06 b0 6e 81 51 4f 2e 81 4b &........n.QO..K
    16:48:25.107 0070: f0 03 00 e8 80 e8 88 3e 70 00 09 0c d2 97 f8 29 .......>p......)
    16:48:25.107 0080: 00 4d 49 00 90 08 88 20 f0 70 00 40 f0 20 00 08 .MI.... .p.@. ..
    16:48:25.107 0090: 80 03 20 87 f8 29 00 49 4c 41 f6 82 50 4f f0 01 .. ..).ILA..PO..
    16:48:25.107 00a0: 09 df f8 1c 81 20 80 a5 f8 52 90 88 f8 00 90 30 ..... ...R.....0
    16:48:25.107 00b0: 46 88 f8 00 60 fa f7 a2 f8 a5 f8 52 60 fb f7 d0 F...`......R`...
    16:48:25.107 00c0: fe a8 81 fc f7 c7 fe fb f7 cb fe e8 81 68 89 29 .............h.)
    16:48:25.107 00d0: 89 40 1a 28 30 28 80 68 89 28 30 aa 89 81 b2 e8 .@.(0(.h.(0.....
    16:48:25.107 00e0: 89 80 1a 82 b2 22 20 fb f7 c1 fe 4f f4 6c 60 b5 ....." ....O.l`.
    16:48:25.107 00f0: f8 32 a0 60 80 a0 88 6e 81 .2.`...n.
    16:48:25.138 Incoming Dump:
    16:48:25.138 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.138 --
    16:48:25.138 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.138 Parameters:
    16:48:25.138 | Number HCI commands : 0x01
    16:48:25.138 | Command Opcode : 0xff05
    16:48:25.138 | Status : 0x00 (Success)
    16:48:25.138 --
    16:48:25.138 --
    16:48:25.138 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.138 | Address : 0x20007e30
    16:48:25.138 | Size : 0xf0
    16:48:25.138 | Values : "20:F0:03:00:A0:80:4A:F0:01:00:34:46:68:86:08:E0:88:F8:00:90:30:46:88:F8:00:60:F9:F7:F3:F8:64:1C:E4:B2:68:89:20:B9:03:2C:F2:DB:40:F2:F1:30:68:81:87:F8:00:90:FB:F7:98:FE:A8:81:30:46:FC:F7:5A:FB:FB:F7:92:FE:E8:81:68:89:29:89:40:1A:68:80:E8:89:AA:89:69:89:3E:70:80:1A:82:B2:23:20:FB:F7:8A:FE:FB:F7:82:FE:28:81:FC:F7:46:FA:FB:F7:7D:FE:68:81:FC:F7:F4:F9:FB:F7:78:FE:A8:81:6A:89:29:89:80:1A:51:1A:89:B2:82:B2:56:20:FB:F7:74:FE:E8:88:A5:F8:32:A0:00:09:0A:D2:00:9B:09:49:1A:01:08:88:10:3A:20:F0:70:00:87:F8:29:30:02:43:0A:80:4B:F0:04:00:E8:80:BD:E8:F8:8F:C0:46:A2:08:01:20:86:02:01:20:02:F1:01:20:00:00:01:20:34:40:01:20:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:02:08:02"
    16:48:25.138 --
    16:48:25.138 Outgoing Dump:
    16:48:25.138 0000: 01 05 ff f5 30 7e 00 20 f0 20 f0 03 00 a0 80 4a ....0~. . .....J
    16:48:25.138 0010: f0 01 00 34 46 68 86 08 e0 88 f8 00 90 30 46 88 ...4Fh.......0F.
    16:48:25.138 0020: f8 00 60 f9 f7 f3 f8 64 1c e4 b2 68 89 20 b9 03 ..`....d...h. ..
    16:48:25.138 0030: 2c f2 db 40 f2 f1 30 68 81 87 f8 00 90 fb f7 98 ,..@..0h........
    16:48:25.138 0040: fe a8 81 30 46 fc f7 5a fb fb f7 92 fe e8 81 68 ...0F..Z.......h
    16:48:25.138 0050: 89 29 89 40 1a 68 80 e8 89 aa 89 69 89 3e 70 80 .).@.h.....i.>p.
    16:48:25.138 0060: 1a 82 b2 23 20 fb f7 8a fe fb f7 82 fe 28 81 fc ...# ........(..
    16:48:25.138 0070: f7 46 fa fb f7 7d fe 68 81 fc f7 f4 f9 fb f7 78 .F...}.h.......x
    16:48:25.138 0080: fe a8 81 6a 89 29 89 80 1a 51 1a 89 b2 82 b2 56 ...j.)...Q.....V
    16:48:25.138 0090: 20 fb f7 74 fe e8 88 a5 f8 32 a0 00 09 0a d2 00 ..t.....2......
    16:48:25.138 00a0: 9b 09 49 1a 01 08 88 10 3a 20 f0 70 00 87 f8 29 ..I.....: .p...)
    16:48:25.138 00b0: 30 02 43 0a 80 4b f0 04 00 e8 80 bd e8 f8 8f c0 0.C..K..........
    16:48:25.138 00c0: 46 a2 08 01 20 86 02 01 20 02 f1 01 20 00 00 01 F... ... ... ...
    16:48:25.138 00d0: 20 34 40 01 20 00 00 00 00 00 00 00 00 00 00 00 4@. ...........
    16:48:25.138 00e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.138 00f0: 00 00 00 00 00 00 02 08 02 .........
    16:48:25.169 Incoming Dump:
    16:48:25.169 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.169 --
    16:48:25.169 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.169 Parameters:
    16:48:25.169 | Number HCI commands : 0x01
    16:48:25.169 | Command Opcode : 0xff05
    16:48:25.169 | Status : 0x00 (Success)
    16:48:25.169 --
    16:48:25.169 --
    16:48:25.169 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.169 | Address : 0x20007f20
    16:48:25.169 | Size : 0xf0
    16:48:25.169 | Values : "00:42:40:42:00:01:04:06:00:02:40:02:00:01:20:01:00:21:20:21:F0:B5:27:4C:40:F2:2E:20:2E:22:02:21:20:80:00:20:FB:F7:2E:FE:4C:F6:D3:60:A4:F8:8C:00:4D:F2:D9:30:00:22:A4:F8:8E:00:87:20:84:F8:80:00:01:21:84:F8:81:00:69:20:84:F8:7E:00:78:20:84:F8:7F:00:19:48:19:4C:C2:80:19:4E:C1:81:B4:F8:6C:30:B4:F8:6A:00:03:EB:00:43:10:46:05:46:01:FA:05:F7:3B:42:02:D0:35:54:40:1C:C0:B2:6D:1C:20:2D:F5:DB:10:48:00:88:C0:F3:05:21:0E:29:03:D3:42:20:FB:F7:F9:FD:08:E0:80:11:0C:49:00:F0:FC:00:09:18:09:68:04:F1:D8:00:01:60:94:F8:5E:00:00:09:01:D3:F8:F7:FD:FC:F0:BD:50:00:01:20:00:00:01:20:50:02:01:20:58:5C:00:00:9A:01:01:20:FC:7E:00:00:32:4B:31:4A:B3:F8:B6:00:32:F8:28:1C:00:F0:0F:00:21:F0:3E:01:41:EA:40:01:22:F8:28:1C:B3:F8:B6:10:32:F8:24:0C"
    16:48:25.169 --
    16:48:25.169 Outgoing Dump:
    16:48:25.169 0000: 01 05 ff f5 20 7f 00 20 f0 00 42 40 42 00 01 04 .... .. ..B@B...
    16:48:25.169 0010: 06 00 02 40 02 00 01 20 01 00 21 20 21 f0 b5 27 ...@... ..! !..'
    16:48:25.169 0020: 4c 40 f2 2e 20 2e 22 02 21 20 80 00 20 fb f7 2e L@.. .".! .. ...
    16:48:25.169 0030: fe 4c f6 d3 60 a4 f8 8c 00 4d f2 d9 30 00 22 a4 .L..`....M..0.".
    16:48:25.169 0040: f8 8e 00 87 20 84 f8 80 00 01 21 84 f8 81 00 69 .... .....!....i
    16:48:25.169 0050: 20 84 f8 7e 00 78 20 84 f8 7f 00 19 48 19 4c c2 ..~.x .....H.L.
    16:48:25.169 0060: 80 19 4e c1 81 b4 f8 6c 30 b4 f8 6a 00 03 eb 00 ..N....l0..j....
    16:48:25.169 0070: 43 10 46 05 46 01 fa 05 f7 3b 42 02 d0 35 54 40 C.F.F....;B..5T@
    16:48:25.169 0080: 1c c0 b2 6d 1c 20 2d f5 db 10 48 00 88 c0 f3 05 ...m. -...H.....
    16:48:25.169 0090: 21 0e 29 03 d3 42 20 fb f7 f9 fd 08 e0 80 11 0c !.)..B .........
    16:48:25.169 00a0: 49 00 f0 fc 00 09 18 09 68 04 f1 d8 00 01 60 94 I.......h.....`.
    16:48:25.169 00b0: f8 5e 00 00 09 01 d3 f8 f7 fd fc f0 bd 50 00 01 .^...........P..
    16:48:25.169 00c0: 20 00 00 01 20 50 02 01 20 58 5c 00 00 9a 01 01 ... P.. X\.....
    16:48:25.169 00d0: 20 fc 7e 00 00 32 4b 31 4a b3 f8 b6 00 32 f8 28 .~..2K1J....2.(
    16:48:25.169 00e0: 1c 00 f0 0f 00 21 f0 3e 01 41 ea 40 01 22 f8 28 .....!.>.A.@.".(
    16:48:25.169 00f0: 1c b3 f8 b6 10 32 f8 24 0c .....2.$.
    16:48:25.201 Incoming Dump:
    16:48:25.201 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.201 --
    16:48:25.201 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.201 Parameters:
    16:48:25.201 | Number HCI commands : 0x01
    16:48:25.201 | Command Opcode : 0xff05
    16:48:25.201 | Status : 0x00 (Success)
    16:48:25.201 --
    16:48:25.201 --
    16:48:25.201 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.201 | Address : 0x20008010
    16:48:25.201 | Size : 0xf0
    16:48:25.201 | Values : "C9:11:01:F0:1E:01:20:F0:3E:00:01:43:22:F8:24:1C:B3:F8:B8:10:32:F8:08:0C:61:F3:86:00:B3:F8:B8:10:49:10:22:F8:08:0C:32:F8:04:0C:01:F4:60:71:20:F4:60:70:01:43:22:F8:04:1C:B3:F8:B8:10:49:10:32:F8:04:0C:01:F4:E0:51:20:F4:E0:50:01:43:B3:F8:B8:00:22:F8:04:1C:32:F8:04:1C:61:F3:0D:00:B3:F8:BA:10:22:F8:04:0C:10:88:61:F3:03:00:B3:F8:BA:10:C9:10:10:80:10:88:01:F4:F0:71:20:F4:F0:70:01:43:11:80:B3:F8:BE:10:10:88:61:F3:4C:20:10:80:B3:F8:BE:00:C0:F3:12:10:01:01:10:88:6F:F3:5F:30:40:EA:41:20:10:80:70:47:38:B5:01:20:00:01:01:20:2D:E9:F0:4F:2A:4F:B7:F8:D4:02:00:01:80:B2:FB:F7:09:FE:28:4D:95:F8:A7:10:49:10:05:EB:41:01:B1:F8:84:10:A1:F2:19:31:8E:B2:B7:F8:D6:12:7F:35:07:F2:22:28:03:09:4F:F4:80:3A:49:00:89:B2:27:27:4A:05:B2:FB:F3:F2"
    16:48:25.201 --
    16:48:25.201 Outgoing Dump:
    16:48:25.201 0000: 01 05 ff f5 10 80 00 20 f0 c9 11 01 f0 1e 01 20 ....... .......
    16:48:25.201 0010: f0 3e 00 01 43 22 f8 24 1c b3 f8 b8 10 32 f8 08 .>..C".$.....2..
    16:48:25.201 0020: 0c 61 f3 86 00 b3 f8 b8 10 49 10 22 f8 08 0c 32 .a.......I."...2
    16:48:25.201 0030: f8 04 0c 01 f4 60 71 20 f4 60 70 01 43 22 f8 04 .....`q .`p.C"..
    16:48:25.201 0040: 1c b3 f8 b8 10 49 10 32 f8 04 0c 01 f4 e0 51 20 .....I.2......Q
    16:48:25.201 0050: f4 e0 50 01 43 b3 f8 b8 00 22 f8 04 1c 32 f8 04 ..P.C...."...2..
    16:48:25.201 0060: 1c 61 f3 0d 00 b3 f8 ba 10 22 f8 04 0c 10 88 61 .a.......".....a
    16:48:25.201 0070: f3 03 00 b3 f8 ba 10 c9 10 10 80 10 88 01 f4 f0 ................
    16:48:25.201 0080: 71 20 f4 f0 70 01 43 11 80 b3 f8 be 10 10 88 61 q ..p.C........a
    16:48:25.201 0090: f3 4c 20 10 80 b3 f8 be 00 c0 f3 12 10 01 01 10 .L .............
    16:48:25.201 00a0: 88 6f f3 5f 30 40 ea 41 20 10 80 70 47 38 b5 01 .o._0@.A ..pG8..
    16:48:25.201 00b0: 20 00 01 01 20 2d e9 f0 4f 2a 4f b7 f8 d4 02 00 ... -..O*O.....
    16:48:25.201 00c0: 01 80 b2 fb f7 09 fe 28 4d 95 f8 a7 10 49 10 05 .......(M....I..
    16:48:25.201 00d0: eb 41 01 b1 f8 84 10 a1 f2 19 31 8e b2 b7 f8 d6 .A........1.....
    16:48:25.201 00e0: 12 7f 35 07 f2 22 28 03 09 4f f4 80 3a 49 00 89 ..5.."(..O..:I..
    16:48:25.201 00f0: b2 27 27 4a 05 b2 fb f3 f2 .''J.....
    16:48:25.232 Incoming Dump:
    16:48:25.232 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.232 --
    16:48:25.232 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.232 Parameters:
    16:48:25.232 | Number HCI commands : 0x01
    16:48:25.232 | Command Opcode : 0xff05
    16:48:25.232 | Status : 0x00 (Success)
    16:48:25.232 --
    16:48:25.232 --
    16:48:25.232 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.232 | Address : 0x20008100
    16:48:25.232 | Size : 0xf0
    16:48:25.232 | Values : "52:09:94:B2:61:1A:1F:FA:81:FB:07:F0:07:01:07:29:15:D1:17:2F:05:D1:06:F2:19:31:A4:EB:0B:04:8E:B2:A4:B2:95:F9:00:10:C9:01:B1:42:BC:BF:70:1A:4F:F0:00:09:09:DB:89:1B:1F:FA:81:F9:61:10:0B:E0:95:F9:00:00:A6:EB:C0:10:48:44:80:B2:FB:F7:C9:FD:01:09:01:FB:04:A1:49:0C:A8:F8:00:10:7F:1E:A5:F1:01:05:A8:F1:02:08:D1:D5:BD:E8:F0:8F:C0:46:50:02:01:20:00:01:01:20:2D:E9:F0:47:28:49:4F:F4:0C:60:48:80:DF:F8:94:80:88:88:20:F0:03:00:40:F0:01:00:88:80:00:20:F8:F7:4F:FF:22:4F:00:26:02:20:3E:70:FB:F7:DD:FC:20:49:0C:46:A4:1E:20:88:4F:F0:0F:09:20:F4:E0:60:20:80:84:F8:00:90:08:88:20:F0:0F:00:40:F0:03:00:08:80:20:88:6F:F3:1F:30:20:80:03:20:20:71:4F:F0:01:0A:A6:81:87:F8:00:A0:FB:F7:BF:FC:45:46:14:27:20:7A:08:F8:01:0B:50:46:FB:F7:B7:FC:7F:1E"
    16:48:25.232 --
    16:48:25.232 Outgoing Dump:
    16:48:25.232 0000: 01 05 ff f5 00 81 00 20 f0 52 09 94 b2 61 1a 1f ....... .R...a..
    16:48:25.232 0010: fa 81 fb 07 f0 07 01 07 29 15 d1 17 2f 05 d1 06 ........).../...
    16:48:25.232 0020: f2 19 31 a4 eb 0b 04 8e b2 a4 b2 95 f9 00 10 c9 ..1.............
    16:48:25.232 0030: 01 b1 42 bc bf 70 1a 4f f0 00 09 09 db 89 1b 1f ..B..p.O........
    16:48:25.232 0040: fa 81 f9 61 10 0b e0 95 f9 00 00 a6 eb c0 10 48 ...a...........H
    16:48:25.232 0050: 44 80 b2 fb f7 c9 fd 01 09 01 fb 04 a1 49 0c a8 D............I..
    16:48:25.232 0060: f8 00 10 7f 1e a5 f1 01 05 a8 f1 02 08 d1 d5 bd ................
    16:48:25.232 0070: e8 f0 8f c0 46 50 02 01 20 00 01 01 20 2d e9 f0 ....FP.. ... -..
    16:48:25.232 0080: 47 28 49 4f f4 0c 60 48 80 df f8 94 80 88 88 20 G(IO..`H.......
    16:48:25.232 0090: f0 03 00 40 f0 01 00 88 80 00 20 f8 f7 4f ff 22 ...@...... ..O."
    16:48:25.232 00a0: 4f 00 26 02 20 3e 70 fb f7 dd fc 20 49 0c 46 a4 O.&. >p.... I.F.
    16:48:25.232 00b0: 1e 20 88 4f f0 0f 09 20 f4 e0 60 20 80 84 f8 00 . .O... ..` ....
    16:48:25.232 00c0: 90 08 88 20 f0 0f 00 40 f0 03 00 08 80 20 88 6f ... ...@..... .o
    16:48:25.232 00d0: f3 1f 30 20 80 03 20 20 71 4f f0 01 0a a6 81 87 ..0 .. qO......
    16:48:25.232 00e0: f8 00 a0 fb f7 bf fc 45 46 14 27 20 7a 08 f8 01 .......EF.' z...
    16:48:25.232 00f0: 0b 50 46 fb f7 b7 fc 7f 1e .PF......
    16:48:25.263 Incoming Dump:
    16:48:25.263 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.263 --
    16:48:25.263 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.263 Parameters:
    16:48:25.263 | Number HCI commands : 0x01
    16:48:25.263 | Command Opcode : 0xff05
    16:48:25.263 | Status : 0x00 (Success)
    16:48:25.263 --
    16:48:25.263 --
    16:48:25.263 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.263 | Address : 0x200081f0
    16:48:25.263 | Size : 0xf0
    16:48:25.263 | Values : "F7:D1:05:27:29:88:6A:88:14:20:FB:F7:D3:FC:2D:1D:7F:1E:F7:D1:30:46:FC:F7:8D:F9:26:80:1C:20:84:F8:02:90:20:71:BD:E8:F0:87:58:00:01:20:00:00:01:20:D0:40:3E:22:06:F2:01:20:70:47:10:B5:00:F1:10:02:01:23:D1:B2:C1:F3:43:04:A3:40:01:F0:01:01:02:F0:01:02:5C:1E:41:EA:44:01:5B:1E:1E:4C:42:EA:43:02:21:80:92:B2:81:B2:5B:20:FB:F7:A4:FC:10:BD:00:F1:10:02:18:49:02:F0:1F:02:89:1C:0A:70:81:B2:5A:20:FB:F7:98:BC:70:47:70:B5:13:4E:01:20:00:24:14:4D:12:49:A6:F8:88:00:A6:F8:C2:00:6C:60:41:F6:82:50:08:80:2C:60:20:46:F9:F7:4D:FE:0A:20:FB:F7:5E:FC:2D:6F:68:0D:40:B2:C0:10:FF:F7:D9:FF:68:0B:40:B2:C0:10:FF:F7:BA:FF:FC:F7:69:FC:A6:F8:C2:40:A6:F8:88:40:70:BD:4C:B0:01:20:50:02:01:20:00:00:01:20:18:A0:01:20:10:B5:09:4C:E0:89:01:09:02:D3:FC:F7"
    16:48:25.263 --
    16:48:25.263 Outgoing Dump:
    16:48:25.263 0000: 01 05 ff f5 f0 81 00 20 f0 f7 d1 05 27 29 88 6a ....... ....').j
    16:48:25.263 0010: 88 14 20 fb f7 d3 fc 2d 1d 7f 1e f7 d1 30 46 fc .. ....-.....0F.
    16:48:25.263 0020: f7 8d f9 26 80 1c 20 84 f8 02 90 20 71 bd e8 f0 ...&.. .... q...
    16:48:25.279 0030: 87 58 00 01 20 00 00 01 20 d0 40 3e 22 06 f2 01 .X.. ... .@>"...
    16:48:25.279 0040: 20 70 47 10 b5 00 f1 10 02 01 23 d1 b2 c1 f3 43 pG.......#....C
    16:48:25.279 0050: 04 a3 40 01 f0 01 01 02 f0 01 02 5c 1e 41 ea 44 ..@........\.A.D
    16:48:25.279 0060: 01 5b 1e 1e 4c 42 ea 43 02 21 80 92 b2 81 b2 5b .[..LB.C.!.....[
    16:48:25.279 0070: 20 fb f7 a4 fc 10 bd 00 f1 10 02 18 49 02 f0 1f ...........I...
    16:48:25.279 0080: 02 89 1c 0a 70 81 b2 5a 20 fb f7 98 bc 70 47 70 ....p..Z ....pGp
    16:48:25.279 0090: b5 13 4e 01 20 00 24 14 4d 12 49 a6 f8 88 00 a6 ..N. .$.M.I.....
    16:48:25.279 00a0: f8 c2 00 6c 60 41 f6 82 50 08 80 2c 60 20 46 f9 ...l`A..P..,` F.
    16:48:25.279 00b0: f7 4d fe 0a 20 fb f7 5e fc 2d 6f 68 0d 40 b2 c0 .M.. ..^.-oh.@..
    16:48:25.279 00c0: 10 ff f7 d9 ff 68 0b 40 b2 c0 10 ff f7 ba ff fc .....h.@........
    16:48:25.279 00d0: f7 69 fc a6 f8 c2 40 a6 f8 88 40 70 bd 4c b0 01 .i....@...@p.L..
    16:48:25.279 00e0: 20 50 02 01 20 00 00 01 20 18 a0 01 20 10 b5 09 P.. ... ... ...
    16:48:25.279 00f0: 4c e0 89 01 09 02 d3 fc f7 L........
    16:48:25.310 Incoming Dump:
    16:48:25.310 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.310 --
    16:48:25.310 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.310 Parameters:
    16:48:25.310 | Number HCI commands : 0x01
    16:48:25.310 | Command Opcode : 0xff05
    16:48:25.310 | Status : 0x00 (Success)
    16:48:25.310 --
    16:48:25.310 --
    16:48:25.310 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.310 | Address : 0x200082e0
    16:48:25.310 | Size : 0x28
    16:48:25.310 | Values : "02:FC:E0:89:81:08:04:D3:FC:F7:91:FB:04:48:0C:38:00:88:C0:08:01:D3:FC:F7:09:FC:10:BD:50:02:01:20:6A:02:01:20:70:47:70:47"
    16:48:25.310 --
    16:48:25.310 Outgoing Dump:
    16:48:25.310 0000: 01 05 ff 2d e0 82 00 20 28 02 fc e0 89 81 08 04 ...-... (.......
    16:48:25.310 0010: d3 fc f7 91 fb 04 48 0c 38 00 88 c0 08 01 d3 fc ......H.8.......
    16:48:25.310 0020: f7 09 fc 10 bd 50 02 01 20 6a 02 01 20 70 47 70 .....P.. j.. pGp
    16:48:25.310 0030: 47 G
    16:48:25.326 Incoming Dump:
    16:48:25.326 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.326 --
    16:48:25.326 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.326 Parameters:
    16:48:25.326 | Number HCI commands : 0x01
    16:48:25.326 | Command Opcode : 0xff05
    16:48:25.326 | Status : 0x00 (Success)
    16:48:25.326 --
    16:48:25.326 --
    16:48:25.326 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.326 | Address : 0x20009800
    16:48:25.326 | Size : 0x04
    16:48:25.326 | Values : "00:00:00:00"
    16:48:25.326 --
    16:48:25.326 Outgoing Dump:
    16:48:25.326 0000: 01 05 ff 09 00 98 00 20 04 00 00 00 00 ....... .....
    16:48:25.341 Incoming Dump:
    16:48:25.341 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.341 --
    16:48:25.341 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.341 Parameters:
    16:48:25.341 | Number HCI commands : 0x01
    16:48:25.341 | Command Opcode : 0xff05
    16:48:25.341 | Status : 0x00 (Success)
    16:48:25.341 --
    16:48:25.341 --
    16:48:25.341 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.341 | Address : 0x20010250
    16:48:25.341 | Size : 0xf0
    16:48:25.341 | Values : "00:00:00:00:03:00:58:02:00:00:01:00:00:00:0F:00:06:06:0F:04:70:03:EC:1C:90:31:56:08:05:00:C4:00:90:01:C8:00:80:00:00:00:03:00:00:00:00:00:00:00:00:00:00:00:00:00:C2:01:84:03:0D:0A:01:00:00:00:00:00:00:00:00:00:03:00:03:01:13:07:00:00:00:00:28:00:AB:94:00:00:00:00:00:00:00:00:13:07:1B:09:01:00:00:00:01:00:11:9C:00:00:03:03:07:07:B8:0B:77:09:00:00:00:00:00:00:00:00:00:00:DA:00:3E:03:3E:03:00:00:01:00:B0:00:00:00:03:00:01:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:70:75:70:75:70:75:70:75:DB:0C:DB:0C:00:00:00:00:B8:B2:B8:B2:00:00:00:00:02:00:92:97:00:00:0C:0C:10:0C:9C:9C:01:00:06:02:03:01:05:00:C4:C2:00:61:00:01:00:00:00:00:0F:02:01:03:04:05:08:04:00:00:00:00:00:00:00:00:03:00:01:00"
    16:48:25.341 --
    16:48:25.341 Outgoing Dump:
    16:48:25.341 0000: 01 05 ff f5 50 02 01 20 f0 00 00 00 00 03 00 58 ....P.. .......X
    16:48:25.341 0010: 02 00 00 01 00 00 00 0f 00 06 06 0f 04 70 03 ec .............p..
    16:48:25.341 0020: 1c 90 31 56 08 05 00 c4 00 90 01 c8 00 80 00 00 ..1V............
    16:48:25.341 0030: 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 c2 ................
    16:48:25.341 0040: 01 84 03 0d 0a 01 00 00 00 00 00 00 00 00 00 03 ................
    16:48:25.341 0050: 00 03 01 13 07 00 00 00 00 28 00 ab 94 00 00 00 .........(......
    16:48:25.341 0060: 00 00 00 00 00 13 07 1b 09 01 00 00 00 01 00 11 ................
    16:48:25.341 0070: 9c 00 00 03 03 07 07 b8 0b 77 09 00 00 00 00 00 .........w......
    16:48:25.341 0080: 00 00 00 00 00 da 00 3e 03 3e 03 00 00 01 00 b0 .......>.>......
    16:48:25.341 0090: 00 00 00 03 00 01 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.341 00a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 ...............p
    16:48:25.341 00b0: 75 70 75 70 75 70 75 db 0c db 0c 00 00 00 00 b8 upupupu.........
    16:48:25.341 00c0: b2 b8 b2 00 00 00 00 02 00 92 97 00 00 0c 0c 10 ................
    16:48:25.341 00d0: 0c 9c 9c 01 00 06 02 03 01 05 00 c4 c2 00 61 00 ..............a.
    16:48:25.341 00e0: 01 00 00 00 00 0f 02 01 03 04 05 08 04 00 00 00 ................
    16:48:25.341 00f0: 00 00 00 00 00 03 00 01 00 .........
    16:48:25.373 Incoming Dump:
    16:48:25.373 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.373 --
    16:48:25.373 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.373 Parameters:
    16:48:25.373 | Number HCI commands : 0x01
    16:48:25.373 | Command Opcode : 0xff05
    16:48:25.373 | Status : 0x00 (Success)
    16:48:25.373 --
    16:48:25.373 --
    16:48:25.373 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.373 | Address : 0x20010340
    16:48:25.373 | Size : 0xf0
    16:48:25.373 | Values : "FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:FF:00:00:00:00:00:00:00:00:03:00:01:00:00:00:00:00:00:00:00:00:00:00:14:14:78:00:D2:00:FB:03:9F:1F:E8:03:14:12:DC:05:00:08:42:04:08:0D:45:1F:0F:19:0A:0C:EE:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:02:02:02:02:C5:05:C5:05:C5:05:96:06:C9:09:55:05:96:06:13:03:02:1F:22:1F:52:15:9F:0F:9F:0E:95:0E:91:11:90:11:10:10:10:10:10:10:18:18:06:06:00:00:1E:1E:19:19:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:87:00:47:00:00:01:87:00:90:14:70:39:80:31:11:06:11:05:14:02:00:00:73:32:73:A0:04:00:40:00:00:00:00:00:00:00:06:00:0B:00:14:00:22:00:40:00:72:00"
    16:48:25.373 --
    16:48:25.373 Outgoing Dump:
    16:48:25.373 0000: 01 05 ff f5 40 03 01 20 f0 ff ff ff ff ff ff ff ....@.. ........
    16:48:25.373 0010: ff ff ff ff ff ff ff ff ff ff ff 00 00 00 00 00 ................
    16:48:25.373 0020: 00 00 00 03 00 01 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.373 0030: 00 14 14 78 00 d2 00 fb 03 9f 1f e8 03 14 12 dc ...x............
    16:48:25.373 0040: 05 00 08 42 04 08 0d 45 1f 0f 19 0a 0c ee 02 00 ...B...E........
    16:48:25.373 0050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.373 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.373 0070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.373 0080: 00 00 00 00 00 02 02 02 02 c5 05 c5 05 c5 05 96 ................
    16:48:25.373 0090: 06 c9 09 55 05 96 06 13 03 02 1f 22 1f 52 15 9f ...U.......".R..
    16:48:25.373 00a0: 0f 9f 0e 95 0e 91 11 90 11 10 10 10 10 10 10 18 ................
    16:48:25.373 00b0: 18 06 06 00 00 1e 1e 19 19 00 00 00 00 00 00 00 ................
    16:48:25.373 00c0: 00 00 00 00 00 00 00 00 01 87 00 47 00 00 01 87 ...........G....
    16:48:25.373 00d0: 00 90 14 70 39 80 31 11 06 11 05 14 02 00 00 73 ...p9.1........s
    16:48:25.373 00e0: 32 73 a0 04 00 40 00 00 00 00 00 00 00 06 00 0b 2s...@..........
    16:48:25.373 00f0: 00 14 00 22 00 40 00 72 00 ...".@.r.
    16:48:25.404 Incoming Dump:
    16:48:25.404 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.404 --
    16:48:25.404 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.404 Parameters:
    16:48:25.404 | Number HCI commands : 0x01
    16:48:25.404 | Command Opcode : 0xff05
    16:48:25.404 | Status : 0x00 (Success)
    16:48:25.404 --
    16:48:25.404 --
    16:48:25.404 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.404 | Address : 0x20010430
    16:48:25.404 | Size : 0xf0
    16:48:25.404 | Values : "C0:00:6A:01:06:00:0B:00:14:00:22:00:40:00:72:00:C0:00:6A:01:06:00:0B:00:14:00:22:00:40:00:72:00:C0:00:6A:01:07:00:0D:00:17:00:28:00:48:00:80:00:E4:00:96:01:07:00:0D:00:17:00:28:00:48:00:80:00:E4:00:96:01:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:09:00:35:00:81:00:36:01:86:01:3A:35:09:23:1B:14:04:00:3A:00:52:01:E0:00:E0:00:69:00:6C:00:94:FF:1A:00:1A:00:9A:01:41:00:04:00:13:00:AD:00:50:01:EE:00:EE:00:83:00:00:00:00:00:64:00:09:00:35:00:81:00:52:01:E0:00:E0:00:69:00:6C:00:94:FF:9A:01:01:00:00:00:01:00:05:00:02:00:05:00:AA:00:FA:00:28:36:08:13:09:13:02:00:32:00:1A:00:1A:00:66:00:12:08:01:00:02:00:02:00:02:00:02:00:05:00:0A:00:28:00:4C:00:F8:0F:00:00:00:00:EF:02:B6:04:14:06"
    16:48:25.404 --
    16:48:25.404 Outgoing Dump:
    16:48:25.404 0000: 01 05 ff f5 30 04 01 20 f0 c0 00 6a 01 06 00 0b ....0.. ...j....
    16:48:25.404 0010: 00 14 00 22 00 40 00 72 00 c0 00 6a 01 06 00 0b ...".@.r...j....
    16:48:25.404 0020: 00 14 00 22 00 40 00 72 00 c0 00 6a 01 07 00 0d ...".@.r...j....
    16:48:25.404 0030: 00 17 00 28 00 48 00 80 00 e4 00 96 01 07 00 0d ...(.H..........
    16:48:25.404 0040: 00 17 00 28 00 48 00 80 00 e4 00 96 01 00 00 00 ...(.H..........
    16:48:25.404 0050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.404 0060: 00 00 00 00 00 00 00 00 00 09 00 35 00 81 00 36 ...........5...6
    16:48:25.404 0070: 01 86 01 3a 35 09 23 1b 14 04 00 3a 00 52 01 e0 ...:5.#....:.R..
    16:48:25.404 0080: 00 e0 00 69 00 6c 00 94 ff 1a 00 1a 00 9a 01 41 ...i.l.........A
    16:48:25.404 0090: 00 04 00 13 00 ad 00 50 01 ee 00 ee 00 83 00 00 .......P........
    16:48:25.404 00a0: 00 00 00 64 00 09 00 35 00 81 00 52 01 e0 00 e0 ...d...5...R....
    16:48:25.404 00b0: 00 69 00 6c 00 94 ff 9a 01 01 00 00 00 01 00 05 .i.l............
    16:48:25.404 00c0: 00 02 00 05 00 aa 00 fa 00 28 36 08 13 09 13 02 .........(6.....
    16:48:25.404 00d0: 00 32 00 1a 00 1a 00 66 00 12 08 01 00 02 00 02 .2.....f........
    16:48:25.404 00e0: 00 02 00 02 00 05 00 0a 00 28 00 4c 00 f8 0f 00 .........(.L....
    16:48:25.404 00f0: 00 00 00 ef 02 b6 04 14 06 .........
    16:48:25.435 Incoming Dump:
    16:48:25.435 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.435 --
    16:48:25.435 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.435 Parameters:
    16:48:25.435 | Number HCI commands : 0x01
    16:48:25.435 | Command Opcode : 0xff05
    16:48:25.435 | Status : 0x00 (Success)
    16:48:25.435 --
    16:48:25.435 --
    16:48:25.435 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.435 | Address : 0x20010520
    16:48:25.435 | Size : 0xf0
    16:48:25.435 | Values : "D5:02:D5:02:00:00:FF:01:AA:00:08:00:07:00:04:00:03:00:32:0F:28:19:32:0A:07:00:06:00:01:00:4C:00:44:00:10:0A:18:18:00:00:0F:0F:00:00:00:00:00:00:B2:00:9E:00:78:00:9A:00:B2:00:72:00:87:00:C6:00:C6:00:82:00:A0:00:9A:00:9A:00:78:00:9E:00:C6:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:B4:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:CC:CC:0C:EC:CC:ED:00:F4:21:12:00:06:21:43:04:0D:DD:DD:0D:F3:EE:FE:00:F8:10:11:00:03:10:22:02:08:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01"
    16:48:25.435 --
    16:48:25.435 Outgoing Dump:
    16:48:25.435 0000: 01 05 ff f5 20 05 01 20 f0 d5 02 d5 02 00 00 ff .... .. ........
    16:48:25.435 0010: 01 aa 00 08 00 07 00 04 00 03 00 32 0f 28 19 32 ...........2.(.2
    16:48:25.435 0020: 0a 07 00 06 00 01 00 4c 00 44 00 10 0a 18 18 00 .......L.D......
    16:48:25.435 0030: 00 0f 0f 00 00 00 00 00 00 b2 00 9e 00 78 00 9a .............x..
    16:48:25.435 0040: 00 b2 00 72 00 87 00 c6 00 c6 00 82 00 a0 00 9a ...r............
    16:48:25.435 0050: 00 9a 00 78 00 9e 00 c6 00 b4 00 b4 00 b4 00 b4 ...x............
    16:48:25.435 0060: 00 b4 00 b4 00 b4 00 b4 00 b4 00 b4 00 b4 00 b4 ................
    16:48:25.435 0070: 00 b4 00 b4 00 b4 00 b4 00 00 00 00 00 00 00 00 ................
    16:48:25.435 0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.435 0090: 00 00 00 00 00 00 00 00 00 cc cc 0c ec cc ed 00 ................
    16:48:25.435 00a0: f4 21 12 00 06 21 43 04 0d dd dd 0d f3 ee fe 00 .!...!C.........
    16:48:25.435 00b0: f8 10 11 00 03 10 22 02 08 00 00 00 00 00 00 00 ......".........
    16:48:25.435 00c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.435 00d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    16:48:25.435 00e0: 00 00 00 00 00 00 00 00 00 01 01 01 01 01 01 01 ................
    16:48:25.435 00f0: 01 01 01 01 01 01 01 01 01 .........
    16:48:25.466 Incoming Dump:
    16:48:25.466 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.466 --
    16:48:25.466 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.466 Parameters:
    16:48:25.466 | Number HCI commands : 0x01
    16:48:25.466 | Command Opcode : 0xff05
    16:48:25.466 | Status : 0x00 (Success)
    16:48:25.466 --
    16:48:25.466 --
    16:48:25.466 Packet "HCI_VS_Write_Memory_Block", Opcode 0xff05
    16:48:25.466 | Address : 0x20010610
    16:48:25.466 | Size : 0x40
    16:48:25.466 | Values : "01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01:01"
    16:48:25.466 --
    16:48:25.466 Outgoing Dump:
    16:48:25.466 0000: 01 05 ff 45 10 06 01 20 40 01 01 01 01 01 01 01 ...E... @.......
    16:48:25.466 0010: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 ................
    16:48:25.466 0020: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 ................
    16:48:25.466 0030: 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 ................
    16:48:25.466 0040: 01 01 01 01 01 01 01 01 01 .........
    16:48:25.482 Incoming Dump:
    16:48:25.482 0000: 04 0e 04 01 05 ff 00 .......
    16:48:25.482 --
    16:48:25.482 Packet "HCI_Command_Complete_VS_Write_Memory_Block_Event", Opcode 0xff05
    16:48:25.482 Parameters:
    16:48:25.482 | Number HCI commands : 0x01
    16:48:25.482 | Command Opcode : 0xff05
    16:48:25.482 | Status : 0x00 (Success)
    16:48:25.482 --
    16:48:25.482 --
    16:48:25.482 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.482 | Address : 0x20018260
    16:48:25.482 | Type : 0x04
    16:48:25.482 | Value : 0x00367700
    16:48:25.482 --
    16:48:25.482 Outgoing Dump:
    16:48:25.482 0000: 01 03 ff 09 60 82 01 20 04 00 77 36 00 ....`.. ..w6.
    16:48:25.498 Incoming Dump:
    16:48:25.498 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.498 --
    16:48:25.498 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.498 Parameters:
    16:48:25.498 | Number HCI commands : 0x01
    16:48:25.498 | Command Opcode : 0xff03
    16:48:25.498 | Status : 0x00 (Success)
    16:48:25.498 --
    16:48:25.498 --
    16:48:25.498 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.498 | Address : 0x2001a044
    16:48:25.498 | Type : 0x04
    16:48:25.498 | Value : 0xffe0407c
    16:48:25.498 --
    16:48:25.498 Outgoing Dump:
    16:48:25.498 0000: 01 03 ff 09 44 a0 01 20 04 7c 40 e0 ff ....D.. .|@..
    16:48:25.513 Incoming Dump:
    16:48:25.513 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.513 --
    16:48:25.513 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.513 Parameters:
    16:48:25.513 | Number HCI commands : 0x01
    16:48:25.513 | Command Opcode : 0xff03
    16:48:25.513 | Status : 0x00 (Success)
    16:48:25.513 --
    16:48:25.513 --
    16:48:25.513 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.513 | Address : 0x2001a0b0
    16:48:25.513 | Type : 0x04
    16:48:25.513 | Value : 0x7f001000
    16:48:25.513 --
    16:48:25.513 Outgoing Dump:
    16:48:25.513 0000: 01 03 ff 09 b0 a0 01 20 04 00 10 00 7f ....... .....
    16:48:25.529 Incoming Dump:
    16:48:25.529 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.529 --
    16:48:25.529 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.529 Parameters:
    16:48:25.529 | Number HCI commands : 0x01
    16:48:25.529 | Command Opcode : 0xff03
    16:48:25.529 | Status : 0x00 (Success)
    16:48:25.529 --
    16:48:25.529 --
    16:48:25.529 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.529 | Address : 0x2001b158
    16:48:25.529 | Type : 0x04
    16:48:25.529 | Value : 0x01030200
    16:48:25.529 --
    16:48:25.529 Outgoing Dump:
    16:48:25.529 0000: 01 03 ff 09 58 b1 01 20 04 00 02 03 01 ....X.. .....
    16:48:25.544 Incoming Dump:
    16:48:25.544 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.544 --
    16:48:25.544 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.544 Parameters:
    16:48:25.544 | Number HCI commands : 0x01
    16:48:25.544 | Command Opcode : 0xff03
    16:48:25.544 | Status : 0x00 (Success)
    16:48:25.544 --
    16:48:25.544 --
    16:48:25.544 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.544 | Address : 0x2001b160
    16:48:25.544 | Type : 0x04
    16:48:25.544 | Value : 0x01030300
    16:48:25.544 --
    16:48:25.544 Outgoing Dump:
    16:48:25.544 0000: 01 03 ff 09 60 b1 01 20 04 00 03 03 01 ....`.. .....
    16:48:25.560 Incoming Dump:
    16:48:25.560 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.560 --
    16:48:25.560 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.560 Parameters:
    16:48:25.560 | Number HCI commands : 0x01
    16:48:25.560 | Command Opcode : 0xff03
    16:48:25.560 | Status : 0x00 (Success)
    16:48:25.560 --
    16:48:25.560 --
    16:48:25.560 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.560 | Address : 0x2001b168
    16:48:25.560 | Type : 0x04
    16:48:25.560 | Value : 0x01030400
    16:48:25.560 --
    16:48:25.560 Outgoing Dump:
    16:48:25.560 0000: 01 03 ff 09 68 b1 01 20 04 00 04 03 01 ....h.. .....
    16:48:25.576 Incoming Dump:
    16:48:25.576 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.576 --
    16:48:25.576 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.576 Parameters:
    16:48:25.576 | Number HCI commands : 0x01
    16:48:25.576 | Command Opcode : 0xff03
    16:48:25.576 | Status : 0x00 (Success)
    16:48:25.576 --
    16:48:25.576 --
    16:48:25.576 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.576 | Address : 0x2001b170
    16:48:25.576 | Type : 0x04
    16:48:25.576 | Value : 0x01030500
    16:48:25.576 --
    16:48:25.576 Outgoing Dump:
    16:48:25.576 0000: 01 03 ff 09 70 b1 01 20 04 00 05 03 01 ....p.. .....
    16:48:25.591 Incoming Dump:
    16:48:25.591 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.591 --
    16:48:25.591 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.591 Parameters:
    16:48:25.591 | Number HCI commands : 0x01
    16:48:25.591 | Command Opcode : 0xff03
    16:48:25.591 | Status : 0x00 (Success)
    16:48:25.591 --
    16:48:25.591 --
    16:48:25.591 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.591 | Address : 0x2001b178
    16:48:25.591 | Type : 0x04
    16:48:25.591 | Value : 0x01030600
    16:48:25.591 --
    16:48:25.591 Outgoing Dump:
    16:48:25.591 0000: 01 03 ff 09 78 b1 01 20 04 00 06 03 01 ....x.. .....
    16:48:25.607 Incoming Dump:
    16:48:25.607 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.607 --
    16:48:25.607 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.607 Parameters:
    16:48:25.607 | Number HCI commands : 0x01
    16:48:25.607 | Command Opcode : 0xff03
    16:48:25.607 | Status : 0x00 (Success)
    16:48:25.607 --
    16:48:25.607 --
    16:48:25.607 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.607 | Address : 0x2001b180
    16:48:25.607 | Type : 0x04
    16:48:25.607 | Value : 0x01030700
    16:48:25.607 --
    16:48:25.607 Outgoing Dump:
    16:48:25.607 0000: 01 03 ff 09 80 b1 01 20 04 00 07 03 01 ....... .....
    16:48:25.622 Incoming Dump:
    16:48:25.622 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.622 --
    16:48:25.622 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.622 Parameters:
    16:48:25.622 | Number HCI commands : 0x01
    16:48:25.622 | Command Opcode : 0xff03
    16:48:25.622 | Status : 0x00 (Success)
    16:48:25.622 --
    16:48:25.622 --
    16:48:25.622 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.622 | Address : 0x2001b188
    16:48:25.622 | Type : 0x04
    16:48:25.622 | Value : 0x01030601
    16:48:25.622 --
    16:48:25.622 Outgoing Dump:
    16:48:25.622 0000: 01 03 ff 09 88 b1 01 20 04 01 06 03 01 ....... .....
    16:48:25.638 Incoming Dump:
    16:48:25.638 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.638 --
    16:48:25.638 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.638 Parameters:
    16:48:25.638 | Number HCI commands : 0x01
    16:48:25.638 | Command Opcode : 0xff03
    16:48:25.638 | Status : 0x00 (Success)
    16:48:25.638 --
    16:48:25.638 --
    16:48:25.638 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.638 | Address : 0x2001b190
    16:48:25.638 | Type : 0x04
    16:48:25.638 | Value : 0x01030701
    16:48:25.638 --
    16:48:25.638 Outgoing Dump:
    16:48:25.638 0000: 01 03 ff 09 90 b1 01 20 04 01 07 03 01 ....... .....
    16:48:25.654 Incoming Dump:
    16:48:25.654 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.654 --
    16:48:25.654 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.654 Parameters:
    16:48:25.654 | Number HCI commands : 0x01
    16:48:25.654 | Command Opcode : 0xff03
    16:48:25.654 | Status : 0x00 (Success)
    16:48:25.654 --
    16:48:25.654 --
    16:48:25.654 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.654 | Address : 0x2001b198
    16:48:25.654 | Type : 0x04
    16:48:25.654 | Value : 0x01030602
    16:48:25.654 --
    16:48:25.654 Outgoing Dump:
    16:48:25.654 0000: 01 03 ff 09 98 b1 01 20 04 02 06 03 01 ....... .....
    16:48:25.669 Incoming Dump:
    16:48:25.669 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.669 --
    16:48:25.669 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.669 Parameters:
    16:48:25.669 | Number HCI commands : 0x01
    16:48:25.669 | Command Opcode : 0xff03
    16:48:25.669 | Status : 0x00 (Success)
    16:48:25.669 --
    16:48:25.669 --
    16:48:25.669 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.669 | Address : 0x2001b1a0
    16:48:25.669 | Type : 0x04
    16:48:25.669 | Value : 0x01030702
    16:48:25.669 --
    16:48:25.669 Outgoing Dump:
    16:48:25.669 0000: 01 03 ff 09 a0 b1 01 20 04 02 07 03 01 ....... .....
    16:48:25.685 Incoming Dump:
    16:48:25.685 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.685 --
    16:48:25.685 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.685 Parameters:
    16:48:25.685 | Number HCI commands : 0x01
    16:48:25.685 | Command Opcode : 0xff03
    16:48:25.685 | Status : 0x00 (Success)
    16:48:25.685 --
    16:48:25.685 --
    16:48:25.685 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.685 | Address : 0x2001b1a8
    16:48:25.685 | Type : 0x04
    16:48:25.685 | Value : 0x01030503
    16:48:25.685 --
    16:48:25.685 Outgoing Dump:
    16:48:25.685 0000: 01 03 ff 09 a8 b1 01 20 04 03 05 03 01 ....... .....
    16:48:25.701 Incoming Dump:
    16:48:25.701 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.701 --
    16:48:25.701 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.701 Parameters:
    16:48:25.701 | Number HCI commands : 0x01
    16:48:25.701 | Command Opcode : 0xff03
    16:48:25.701 | Status : 0x00 (Success)
    16:48:25.701 --
    16:48:25.701 --
    16:48:25.701 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.701 | Address : 0x2001b1b0
    16:48:25.701 | Type : 0x04
    16:48:25.701 | Value : 0x01030703
    16:48:25.701 --
    16:48:25.701 Outgoing Dump:
    16:48:25.701 0000: 01 03 ff 09 b0 b1 01 20 04 03 07 03 01 ....... .....
    16:48:25.716 Incoming Dump:
    16:48:25.716 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.716 --
    16:48:25.716 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.716 Parameters:
    16:48:25.716 | Number HCI commands : 0x01
    16:48:25.716 | Command Opcode : 0xff03
    16:48:25.716 | Status : 0x00 (Success)
    16:48:25.716 --
    16:48:25.716 --
    16:48:25.716 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.716 | Address : 0x2001b1e0
    16:48:25.716 | Type : 0x04
    16:48:25.716 | Value : 0x01030202
    16:48:25.716 --
    16:48:25.716 Outgoing Dump:
    16:48:25.716 0000: 01 03 ff 09 e0 b1 01 20 04 02 02 03 01 ....... .....
    16:48:25.732 Incoming Dump:
    16:48:25.732 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.732 --
    16:48:25.732 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.732 Parameters:
    16:48:25.732 | Number HCI commands : 0x01
    16:48:25.732 | Command Opcode : 0xff03
    16:48:25.732 | Status : 0x00 (Success)
    16:48:25.732 --
    16:48:25.732 --
    16:48:25.732 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.732 | Address : 0x2001b1e8
    16:48:25.732 | Type : 0x04
    16:48:25.732 | Value : 0x01030302
    16:48:25.732 --
    16:48:25.732 Outgoing Dump:
    16:48:25.732 0000: 01 03 ff 09 e8 b1 01 20 04 02 03 03 01 ....... .....
    16:48:25.747 Incoming Dump:
    16:48:25.747 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.747 --
    16:48:25.747 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.747 Parameters:
    16:48:25.747 | Number HCI commands : 0x01
    16:48:25.747 | Command Opcode : 0xff03
    16:48:25.747 | Status : 0x00 (Success)
    16:48:25.747 --
    16:48:25.747 --
    16:48:25.747 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.747 | Address : 0x2001b1f0
    16:48:25.747 | Type : 0x04
    16:48:25.747 | Value : 0x01030402
    16:48:25.747 --
    16:48:25.747 Outgoing Dump:
    16:48:25.747 0000: 01 03 ff 09 f0 b1 01 20 04 02 04 03 01 ....... .....
    16:48:25.763 Incoming Dump:
    16:48:25.763 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.763 --
    16:48:25.763 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.763 Parameters:
    16:48:25.763 | Number HCI commands : 0x01
    16:48:25.763 | Command Opcode : 0xff03
    16:48:25.763 | Status : 0x00 (Success)
    16:48:25.763 --
    16:48:25.763 --
    16:48:25.763 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.763 | Address : 0x2001b1f8
    16:48:25.763 | Type : 0x04
    16:48:25.763 | Value : 0x01030502
    16:48:25.763 --
    16:48:25.763 Outgoing Dump:
    16:48:25.763 0000: 01 03 ff 09 f8 b1 01 20 04 02 05 03 01 ....... .....
    16:48:25.779 Incoming Dump:
    16:48:25.779 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.779 --
    16:48:25.779 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.779 Parameters:
    16:48:25.779 | Number HCI commands : 0x01
    16:48:25.779 | Command Opcode : 0xff03
    16:48:25.779 | Status : 0x00 (Success)
    16:48:25.779 --
    16:48:25.779 --
    16:48:25.779 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.779 | Address : 0x2001b200
    16:48:25.779 | Type : 0x04
    16:48:25.779 | Value : 0x01030602
    16:48:25.779 --
    16:48:25.779 Outgoing Dump:
    16:48:25.779 0000: 01 03 ff 09 00 b2 01 20 04 02 06 03 01 ....... .....
    16:48:25.794 Incoming Dump:
    16:48:25.794 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.794 --
    16:48:25.794 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.794 Parameters:
    16:48:25.794 | Number HCI commands : 0x01
    16:48:25.794 | Command Opcode : 0xff03
    16:48:25.794 | Status : 0x00 (Success)
    16:48:25.794 --
    16:48:25.794 --
    16:48:25.794 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.794 | Address : 0x2001b208
    16:48:25.794 | Type : 0x04
    16:48:25.794 | Value : 0x01030702
    16:48:25.794 --
    16:48:25.794 Outgoing Dump:
    16:48:25.794 0000: 01 03 ff 09 08 b2 01 20 04 02 07 03 01 ....... .....
    16:48:25.810 Incoming Dump:
    16:48:25.810 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.810 --
    16:48:25.810 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.810 Parameters:
    16:48:25.810 | Number HCI commands : 0x01
    16:48:25.810 | Command Opcode : 0xff03
    16:48:25.810 | Status : 0x00 (Success)
    16:48:25.810 --
    16:48:25.810 --
    16:48:25.810 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.810 | Address : 0x2001b230
    16:48:25.810 | Type : 0x04
    16:48:25.810 | Value : 0x01030703
    16:48:25.810 --
    16:48:25.810 Outgoing Dump:
    16:48:25.810 0000: 01 03 ff 09 30 b2 01 20 04 03 07 03 01 ....0.. .....
    16:48:25.826 Incoming Dump:
    16:48:25.826 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.826 --
    16:48:25.826 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.826 Parameters:
    16:48:25.826 | Number HCI commands : 0x01
    16:48:25.826 | Command Opcode : 0xff03
    16:48:25.826 | Status : 0x00 (Success)
    16:48:25.826 --
    16:48:25.826 --
    16:48:25.826 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.826 | Address : 0x2001b50c
    16:48:25.826 | Type : 0x04
    16:48:25.826 | Value : 0x00000001
    16:48:25.826 --
    16:48:25.826 Outgoing Dump:
    16:48:25.826 0000: 01 03 ff 09 0c b5 01 20 04 01 00 00 00 ....... .....
    16:48:25.841 Incoming Dump:
    16:48:25.841 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.841 --
    16:48:25.841 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.841 Parameters:
    16:48:25.841 | Number HCI commands : 0x01
    16:48:25.841 | Command Opcode : 0xff03
    16:48:25.841 | Status : 0x00 (Success)
    16:48:25.841 --
    16:48:25.841 --
    16:48:25.841 Packet "HCI_VS_Write_Memory", Opcode 0xff03
    16:48:25.841 | Address : 0x2008feb4
    16:48:25.841 | Type : 0x04
    16:48:25.841 | Value : 0x00000001
    16:48:25.841 --
    16:48:25.841 Outgoing Dump:
    16:48:25.841 0000: 01 03 ff 09 b4 fe 08 20 04 01 00 00 00 ....... .....
    16:48:25.857 Incoming Dump:
    16:48:25.857 0000: 04 0e 04 01 03 ff 00 .......
    16:48:25.857 --
    16:48:25.857 Packet "HCI_Command_Complete_VS_Write_Memory_Event", Opcode 0xff03
    16:48:25.857 Parameters:
    16:48:25.857 | Number HCI commands : 0x01
    16:48:25.857 | Command Opcode : 0xff03
    16:48:25.857 | Status : 0x00 (Success)
    16:48:25.857 --
    16:48:25.857 --
    16:48:25.857 Packet "HCI_VS_Stop_VS_Lock", Opcode 0xfe38
    16:48:25.857 --
    16:48:25.857 Outgoing Dump:
    16:48:25.857 0000: 01 38 fe 00 .8..
    16:48:25.873 Incoming Dump:
    16:48:25.873 0000: 04 0e 04 01 38 fe 00 ....8..
    16:48:25.873 --
    16:48:25.873 Packet "HCI_Command_Complete_VS_Stop_VS_Lock_Event", Opcode 0xfe38
    16:48:25.873 Parameters:
    16:48:25.873 | Number HCI commands : 0x01
    16:48:25.873 | Command Opcode : 0xfe38
    16:48:25.873 | Status : 0x00 (Success)
    16:48:25.873 --
    16:48:25.873 --
    16:48:25.873 Packet "HCI_VS_Write_CODEC_Config", Opcode 0xfd06
    16:48:25.873 | PCM clock rate : 0x0200
    16:48:25.873 | PCM direction/role : 0x00 (Master)
    16:48:25.873 | Frame sync frequency : 0x00003e80
    16:48:25.873 | Frame sync duty cycle : 0x0001
    16:48:25.873 | Frame sync edge : 0x01 (Falling Edge)
    16:48:25.873 | Frame sync polarity : 0x01
    16:48:25.873 | Reserved : 0x00
    16:48:25.873 | CH1 data out size : 0x0010
    16:48:25.873 | CH1 data out offset : 0x0001
    16:48:25.873 | CH1 out_edge : 0x01 (Falling Edge)
    16:48:25.873 | CH1 data in size : 0x0010
    16:48:25.873 | CH1 data in offset : 0x0001
    16:48:25.873 | CH1 in_edge : 0x00 (Rising Edge)
    16:48:25.873 | CH2 data out size : 0x0010
    16:48:25.873 | CH2 data out offset : 0x0011
    16:48:25.873 | CH2 out_edge : 0x01 (Falling Edge)
    16:48:25.873 | CH2 data in size : 0x0010
    16:48:25.873 | CH2 data in offset : 0x0011
    16:48:25.873 | CH2 in_edge : 0x00 (Rising Edge)
    16:48:25.873 --
    16:48:25.873 Outgoing Dump:
    16:48:25.873 0000: 01 06 fd 22 00 02 00 80 3e 00 00 01 00 01 01 00 ..."....>.......
    16:48:25.873 0010: 10 00 01 00 01 10 00 01 00 00 00 10 00 11 00 01 ................
    16:48:25.873 0020: 10 00 11 00 00 00 ......
    16:48:26.029 Incoming Dump:
    16:48:26.029 0000: 04 0e 04 01 06 fd 00 .......
    16:48:26.029 --
    16:48:26.029 Packet "HCI_Command_Complete_VS_Write_CODEC_Config_Event", Opcode 0xfd06
    16:48:26.029 Parameters:
    16:48:26.029 | Number HCI commands : 0x01
    16:48:26.029 | Command Opcode : 0xfd06
    16:48:26.029 | Status : 0x00 (Success)
    16:48:26.029 --
    16:48:26.029 --
    16:48:26.029 Packet "HCI_VS_Sleep_Mode_Configurations", Opcode 0xfd0c
    16:48:26.029 | Reserved : 0x00
    16:48:26.029 | Deep Sleep Enable : 0x00
    16:48:26.029 | Deep Sleep Mode : 0xff (Don't Change)
    16:48:26.029 | Output IO Select : 0xff
    16:48:26.029 | Output Pull Enable : 0xff
    16:48:26.029 | Input Pull Enable : 0xff
    16:48:26.029 | Input io Select : 0xff (0xFF - Dont Change)
    16:48:26.029 | BORNEO Deassertion Timout : 0x0064
    16:48:26.029 --
    16:48:26.029 Outgoing Dump:
    16:48:26.029 0000: 01 0c fd 09 00 00 ff ff ff ff ff 64 00 ...........d.
    16:48:26.044 Incoming Dump:
    16:48:26.044 0000: 04 0e 04 01 0c fd 00 .......
    16:48:26.044 --
    16:48:26.044 Packet "HCI_Command_Complete_VS_Sleep_Mode_Configurations_Event", Opcode 0xfd0c
    16:48:26.044 Parameters:
    16:48:26.044 | Number HCI commands : 0x01
    16:48:26.044 | Command Opcode : 0xfd0c
    16:48:26.044 | Status : 0x00 (Success)
    16:48:26.044 --
    16:48:26.044 --
    16:48:26.044 *** Script End ***
    16:48:26.044 --
    16:48:58.408 *** Script Started: "C:\Users\szhang\ScanTest.txt" ***
    16:48:58.408 --
    16:48:58.408 Packet "HCI_Enable_Device_Under_Test_Mode", Opcode 0x1803
    16:48:58.408 --
    16:48:58.408 Outgoing Dump:
    16:48:58.408 0000: 01 03 18 00 ....
    16:48:58.424 Incoming Dump:
    16:48:58.424 0000: 04 0e 04 01 03 18 00 .......
    16:48:58.424 --
    16:48:58.424 Packet "HCI_Command_Complete_Enable_Device_Under_Test_Mode_Event", Opcode 0x1803
    16:48:58.424 Parameters:
    16:48:58.424 | Number HCI commands : 0x01
    16:48:58.424 | Command Opcode : 0x1803
    16:48:58.424 | Status : 0x00 (Success)
    16:48:58.424 --
    16:48:58.424 --
    16:48:58.424 Packet "HCI_Set_Event_Filter", Opcode 0x0c05
    16:48:58.424 | Filter type : 0x0C05
    16:48:58.424 | Result Filter Type : 0x02 (Specific BD Address)
    16:48:58.424 | BD Address of the device : "0x00"
    16:48:58.424 --
    16:48:58.424 ERROR - File: "C:\Users\szhang\ScanTest.txt", Line: 6
    16:48:58.424 ERROR - Invalid argument value: "0x00"
    16:48:58.424 ERRORed Line (6): Send_HCI_Set_Event_Filter 0x0C05, 0x02, 0x00, 0x03
    16:48:58.424 --
    16:48:58.424 *** Script End ***
    16:48:58.424 --
    This error is caused by the incorrect syntax of the HCI_Set_Event_Filter in the HCITester. Please use the following in your script.
    Send_HCI_Set_Event_Filter 0x02, 0x00, 0x03
    Wait_HCI_Command_Complete_Set_Event_Filter_Event 5000, any, HCI_Set_Event_Filter, 0x00
    Vihang
  • It works this way, thanks Vihang.
    Shengchu
