a e t
Scan was not started. Verify scan parametrs or SME mode
.../scAn> Start, sTop, Wextstart, configApp/, configpEriodic/, configPolicy/
.../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP
ERROR - IPC_STA_Private_Send - error sending Wext private IOCTL to STA driver (ioctl_cmd = 8021503, res = -1, errno = 95)
\> Driver/, Connection/, Management/, Show/, Privacy/, scAn/, roaminG/, qOs/, poWer/, eVents/, Bt coexsistance/, Report/, dEbug/, biT/, aboUt, Quit a e .../scAn> Start, sTop, Wextstart, configApp/, configpEriodic/, configPolicy/ .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP g -90 0 2 0 1 3 10 3 1 5 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 0 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 1 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 2 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 3 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 4 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 5 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 6 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 7 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 8 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP i 9 5000 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP c 0 0 1 1 30 80 150 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP c 1 0 3 1 30 80 150 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP c 2 0 6 1 30 80 150 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP c 3 0 10 1 30 80 150 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP c 4 0 11 1 30 80 150 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP s 0 0 TCL_ROUTER .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP s 1 0 MotoDemo1 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP s 2 0 M-Wireless .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP d Application Periodic Scan parameters: RSSI Threshold: -90, SNR Threshold: 0, Report Threshold: 2 Number of cycles: 10 Terminate on Report: False, BSS type: Infrastructure, Probe Request Number: 3 Intervals (msec): 5000 5000 5000 5000 5000 5000 5000 5000 5000 5000 0 0 0 0 0 0 SSIDs: TCL_ROUTER (Public), MotoDemo1 (Public), M-Wireless (Public), SSID List Filter Enabled: 1 Channels: Band Channel Scan type Min dwell time Max dwell time Power level (dBm*10) ---------------------------------------------------------------------------------------------------- 2.4 GHz 1 Active Normal Scan 30 80 150 2.4 GHz 3 Active Normal Scan 30 80 150 2.4 GHz 6 Active Normal Scan 30 80 150 2.4 GHz 10 Active Normal Scan 30 80 150 2.4 GHz 11 Active Normal Scan 30 80 150 .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP / \> Driver/, Connection/, Management/, Show/, Privacy/, scAn/, roaminG/, qOs/, poWer/, eVents/, Bt coexsistance/, Report/, dEbug/, biT/, aboUt, Quit \> Driver/, Connection/, Management/, Show/, Privacy/, scAn/, roaminG/, qOs/, poWer/, eVents/, Bt coexsistance/, Report/, dEbug/, biT/, aboUt, Quit m d 1 .../Management> connect moDe, Channel, Rate, Mode, Frag, rTs, Preamble, sLot, rAdio on/off, Info, siGnal, snr ratiO, tX_power_table, tx_power_dBm_div10, tx_poWer_level, 802_11d_h/, beacoN/, adVanced/ .../Management> connect moDe, Channel, Rate, Mode, Frag, rTs, Preamble, sLot, rAdio on/off, Info, siGnal, snr ratiO, tX_power_table, tx_power_dBm_div10, tx_poWer_level, 802_11d_h/, beacoN/, adVanced/ d Current mode = SME Manual 0 - SME Auto, 1 - SME Manual .../Management> connect moDe, Channel, Rate, Mode, Frag, rTs, Preamble, sLot, rAdio on/off, Info, siGnal, snr ratiO, tX_power_table, tx_power_dBm_div10, tx_poWer_level, 802_11d_h/, beacoN/, adVanced/ / \> Driver/, Connection/, Management/, Show/, Privacy/, scAn/, roaminG/, qOs/, poWer/, eVents/, Bt coexsistance/, Report/, dEbug/, biT/, aboUt, Quit \> Driver/, Connection/, Management/, Show/, Privacy/, scAn/, roaminG/, qOs/, poWer/, eVents/, Bt coexsistance/, Report/, dEbug/, biT/, aboUt, Quit a e t Scan was not started. Verify scan parametrs or SME mode .../scAn> Start, sTop, Wextstart, configApp/, configpEriodic/, configPolicy/ .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP ERROR - IPC_STA_Private_Send - error sending Wext private IOCTL to STA driver (ioctl_cmd = 8021503, res = -1, errno = 95) .../configpEriodic> Global, Interval, Ssid, Channel, cLear, Display, sTart, stoP
