Hey,
I'm trying to use cloud ota example and have some problems about connection, i have the issue called 20006(could not to connect file server) in the ota.h
Needed to check forums and figured the information below. Is that meaning i can not update my code using dropbox never, or i can update for a demo? What is the meaning of "real-life" ?
Thanks!
Haydar
Dear Vladimir -
if you see Section 3.2 of this guide:
dev.ti.com/.../Over_The_Air_Update_Guide.html
you will see the dummy certificate for this is located in this folder: C:\ti\simplelink_cc32xx_sdk_1_50_00_06\tools\cc32xx_tools\ota-example-cert
this is used to test that this is working in your applicaiton, but not for use in "real life"
then you can buy the certificate from the vendor, for your production use:
for example ==> www.digicert.com/.../order-1.php
BR-
Josh
