CC3100MOD: Timeout on wrong SSID
Part Number: CC3100MOD
Other Parts Discussed in Thread: CC3100
Hi Team,
Can you provide answer to the below questions.
(a) how to connect from cc3100 to router when router ssid is configured as hidden that means it will not broadcast. If I try to pass directly the correct ssid and password to Wlan_connect api, It will successfully establish the connection but if I pass wrong SSID to Wlan_connect api, it will give timeout after a long time(observed 5 min) since it is not available in the network.
can we get the timeout within minimum time period which is not noticeable?.
(b) "sl_WlanGetNetworkList" this function will search for the devices which are available in the network but in this case device is hidden so how to establish connection in this situation.
Likhitha
