CCS/CC3220S-LAUNCHXL: Modifying the linker script for CC3220S
Part Number: CC3220S-LAUNCHXL
I'm running pretty tight on RAM.  The .lds file appears to have all the linker instructions, so do I just directly modify this file or does it get blown away because it is just auto generated by another tool?  Also, can I move .data to SRAM0?  Are there an implications of doing so?  .data is ~10k right now so it appears that it will fit.
Is it really just as simple as changing REGION_ALIAS("REGION_DATA", SRAM); to REGION_ALIAS("REGION_DATA", SRAM0);
 * Copyright (c) 2016, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== CC3220S_LAUNCHXL_TIRTOS.lds ========
 *  Define the memory block start/length for the MSP_EXP432P401R M4
STACKSIZE = 1024;
HEAPSIZE  = 0x8000;  /* Size of heap buffer used by HeapMem */
MEMORY
    SRAM0     (RWX) : ORIGIN = 0x20000000, LENGTH = 0x00004000
    SRAM      (RWX) : ORIGIN = 0x20004000, LENGTH = 0x0003c000
REGION_ALIAS("REGION_RAM_VECS", SRAM0);
REGION_ALIAS("REGION_TEXT", SRAM);
REGION_ALIAS("REGION_BSS", SRAM);
REGION_ALIAS("REGION_STACK", SRAM);
REGION_ALIAS("REGION_HEAP", SRAM);
REGION_ALIAS("REGION_ARM_EXIDX", SRAM);
REGION_ALIAS("REGION_ARM_EXTAB", SRAM);
SECTIONS {
    PROVIDE (_vtable_base_address =
        DEFINED(_vtable_base_address) ? _vtable_base_address : 0x20000000);
    .vtable (_vtable_base_address) (NOLOAD) : {
        KEEP (*(.vtable))
    } > REGION_RAM_VECS
    PROVIDE (_intvecs_base_address =
        DEFINED(_intvecs_base_address) ? _intvecs_base_address : 0x20004000);
    .intvecs (_intvecs_base_address) : AT (_intvecs_base_address) {
        KEEP (*(.intvecs))
    } > REGION_TEXT
    .text : {
        CREATE_OBJECT_SYMBOLS
        *(.text)
        *(.text.*)
        . = ALIGN(0x4);
        KEEP (*(.ctors))
        . = ALIGN(0x4);
        KEEP (*(.dtors))
        . = ALIGN(0x4);
        __init_array_start = .;
        KEEP (*(.init_array*))
        __init_array_end = .;
        *(.init)
        *(.fini*)
    } > REGION_TEXT AT> REGION_TEXT
    PROVIDE (__etext = .);
    PROVIDE (_etext = .);
    PROVIDE (etext = .);
    .rodata : {
        *(.rodata)
        *(.rodata*)
    .data : ALIGN (4) {
        __data_load__ = LOADADDR (.data);
        __data_start__ = .;
        *(.data)
        *(.data*)
        . = ALIGN (4);
        __data_end__ = .;
    } > REGION_DATA AT> REGION_TEXT
    .ARM.exidx : {
        __exidx_start = .;
        *(.ARM.exidx* .gnu.linkonce.armexidx.*)
        __exidx_end = .;
    } > REGION_ARM_EXIDX AT> REGION_ARM_EXIDX
    .ARM.extab : {
        *(.ARM.extab* .gnu.linkonce.armextab.*)
    } > REGION_ARM_EXTAB AT> REGION_ARM_EXTAB
    .bss : {
        __bss_start__ = .;
        *(.shbss)
        *(.bss)
        *(.bss.*)
        *(COMMON)
        . = ALIGN (4);
        __bss_end__ = .;
    } > REGION_BSS AT> REGION_BSS
    .heap : {
        __heap_start__ = .;
        end = __heap_start__;
        _end = end;
        __end = end;
        KEEP (*(.heap))
        __heap_end__ = .;
        __HeapLimit = __heap_end__;
    } > REGION_HEAP AT> REGION_HEAP
    /* Heap buffer used by HeapMem */
    .priheap : {
        . = ALIGN (8);
        __primary_heap_start__ = .;
        . += HEAPSIZE;
        __primary_heap_end__ = .;
    .stack (NOLOAD) : ALIGN(0x8) {
        _stack = .;
        __stack = .;
        KEEP (*(.stack))
        . += STACKSIZE;
    } > REGION_STACK AT> REGION_STACK
