RTOS/CC3220SF: Multi-thread program not working
Part Number: CC3220SF
Tool/software: TI-RTOS
I'm working for the first time with TI-RTOS.  I'm creating simple multi-level thread program with "simplelink cc32xx sdk; Version :2_20_00_10".
I referred the examples in "simplelink_cc32xx_sdk_2_20_00_10\examples\rtos\CC3220SF_LAUNCHXL\drivers"  and created the "main thread".
Inside the mainThread, i'm creating another thread(DU_ControlThread) using POSIX thread functions. Inside the thread i'm calling a simple function inside infinite while loop which will update a temperature value in HMI via UART . But this function is not updating properly.
If i call the same function from the mainThread itself, then it is working fine.
I've attached the code for your ref.
Can anyone help me  what is going wrong
Black
 * Copyright (c) 2016-2018, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== main_tirtos.c ========
#include <stdint.h>
/* POSIX Header files */
#include <pthread.h>
/* RTOS header files */
#include <ti/sysbios/BIOS.h>
/* Example/Board Header files */
#include "Board.h"
extern void *mainThread(void *arg0);
/* Stack size in bytes */
#define THREADSTACKSIZE    1024*4
 *  ======== main ========
int main(void)
    pthread_t           thread;
    pthread_attr_t      attrs;
    struct sched_param  priParam;
    int                 retc;
    int                 detachState;
    /* Call driver init functions */
    Board_initGeneral();
    /* Set priority and stack size attributes */
    pthread_attr_init(&attrs);
    priParam.sched_priority = 1;
    detachState = PTHREAD_CREATE_DETACHED;
    retc = pthread_attr_setdetachstate(&attrs, detachState);
    if (retc != 0) {
        /* pthread_attr_setdetachstate() failed */
        while (1);
    pthread_attr_setschedparam(&attrs, &priParam);
    retc |= pthread_attr_setstacksize(&attrs, THREADSTACKSIZE);
    if (retc != 0) {
        /* pthread_attr_setstacksize() failed */
        while (1);
    retc = pthread_create(&thread, &attrs, mainThread, NULL);
    if (retc != 0) {
        /* pthread_create() failed */
        while (1);
    BIOS_start();
    return (0);
 * DU_Thread.c
 *  Created on: Mar 9, 2019
 *      Author: KarikalanKabilan
#include "DU_Common.h"
#include "hmi_StateMachine/hmiNextionCfg.h"
extern eHMIScreen g_eHMIScreenState;
extern Display_Handle display;
extern void *hmiThread(void *arg0);
extern void DU_ThermoControlThread();
extern void DU_pHControlThread();
void *DU_ControlThread(void *arg0)
    while(1)
        sleep(1);
      //  DU_pHControlThread();
    pthread_t hmiThreadId;
    pthread_t DU_ControlThreadId;
    GPIO_init();
    DU_UartInit();
    DU_AdcInit();
    g_eHMIScreenState = MainScreen;
 //   pthread_create(&hmiThreadId, NULL, hmiThread, NULL);
   pthread_create(&DU_ControlThreadId, NULL, DU_ControlThread, NULL);
 //   pthread_join(hmiThreadId, NULL);
   pthread_join(DU_ControlThreadId, NULL);
 * DU_Thread.c
    // while(1)
        // sleep(1);
        // DU_ThermoControlThread();
      // //  DU_pHControlThread();
    GPIO_init();
    DU_UartInit();
    DU_AdcInit();
 //  pthread_create(&DU_ControlThreadId, NULL, DU_ControlThread, NULL);
	while(1)
        sleep(1);
  // pthread_join(DU_ControlThreadId, NULL);
  • Hello Black,
    I don't see where you initializing thread attributes (ie: pthread_attr_init()) or setting a stack size using pthread_attr_setstacksize(). You should check the return code of your function calls as they give give insight to what your problem is.
    Jesu
  • Hi Jesu:
    Thanks for your response.
    Yes you're right, i missed to initializing thread attributes and setting a stack size. After including the same, it is working fine.
    Black.
