Other Parts Discussed in Thread: WL1831, WL1835
I am migrating from WL1831 to WL1835 wifi so config file for both WL1831 and WL1835 same or anything we need to change ? (Only SIDO mode used and select only 2.4Ghz antenna).
Thanks.
Curious why you are moving to the WL1835 if you aren't using MIMO and two 2.4Ghz antennas? That is the advantage of that device over the WL1831. In either case, they share the same .ini/config output and would give the same performance given the same board.
Travis
