I am trying to build a project that makes two boards communicate with each others using P2P mode and the data exchanged between them is using the MAC address only, I established the connection between the two boards successfully, one as a client and the other as a group owner. Now I am in the phase of exchanging data between them, I followed the steps shown in the related thread (https://e2e.ti.com/support/wireless-connectivity/wifi/f/968/t/845693#), but the code does not return from the sl_Recv function and I do not know what is the issue?
the code for the client and the group owner is shown below:
Group Owner:
#define ARP_ETHIP_LEN 20 /* base ARP message length */ #define ARP_HRD_ETH 0x0001 /* ethernet hardware */ #define ARP_PRO_IP 0x0800 /* IP protocol */ #define ETH_ADDR_LEN 6 #define IP_ADDR_LEN 4 #define ARP_OP_REQUEST 1 /* request to resolve ha given pa */ struct arp_hdr { uint16_t ar_hrd; /* format of hardware address */ uint16_t ar_pro; /* format of protocol address */ uint8_t ar_hln; /* length of hardware address (ETH_ADDR_LEN) */ uint8_t ar_pln; /* length of protocol address (IP_ADDR_LEN) */ uint16_t ar_op; /* operation */ }arp_hdr; struct arp_ethip { uint8_t ar_sha[ETH_ADDR_LEN]; /* sender hardware address */ uint8_t ar_spa[IP_ADDR_LEN]; /* sender protocol address */ uint8_t ar_tha[ETH_ADDR_LEN]; /* target hardware address */ uint8_t ar_tpa[IP_ADDR_LEN]; /* target protocol address */ }arp_ethip; struct arp_eth_hdr { uint8_t dst_mac[ETH_ADDR_LEN]; uint8_t src_mac[ETH_ADDR_LEN]; uint8_t type[2]; }arp_eth_hdr; #define ARP_HDR_LEN sizeof(arp_hdr) #define ETH_HDR_LEN sizeof(arp_eth_hdr) void Wireless_Build_Arp_Packet(char* buf) { struct arp_hdr* arp1; struct arp_ethip* ethip; struct arp_eth_hdr* ethhdr1; unsigned char mac[6]; memcpy(mac, app_CB.CON_CB.srcBSSID, ETH_ADDR_LEN); unsigned char src_ip[4]; // unsigned char src_ip[4] = {0xc0, 0xa8, 0x2b, 0xda}; memcpy(src_ip, app_CB.CON_CB.IpAddr, 4); unsigned char dest_mac[6] = {0XFF, 0XFF, 0XFF, 0XFF, 0XFF, 0XFF}; unsigned char dest_ip[4]; // unsigned char dest_ip[4] = {0xc0, 0xa8, 0x2b, 0x25}; memcpy(dest_ip, app_CB.CON_CB.DestinationIp, 4); unsigned char eth_type[2] = {0x08, 0x06}; ethhdr1 = (struct arp_eth_hdr*)buf; memcpy(ethhdr1->dst_mac, dest_mac, ETH_ADDR_LEN); memcpy(ethhdr1->src_mac, mac, ETH_ADDR_LEN); memcpy(ethhdr1->type, eth_type, 2); arp1 = (struct arp_hdr*)(buf+ ETH_HDR_LEN); arp1->ar_hrd = sl_Htons(ARP_HRD_ETH); arp1->ar_pro = sl_Htons(ARP_PRO_IP); arp1->ar_hln = ETH_ADDR_LEN; arp1->ar_pln = IP_ADDR_LEN; arp1->ar_op = sl_Htons(ARP_HRD_ETH); ethip = (struct arp_ethip*)(buf + ARP_HDR_LEN + ETH_HDR_LEN); memcpy(ethip->ar_sha, mac, ETH_ADDR_LEN); memcpy(ethip->ar_spa, src_ip, IP_ADDR_LEN); memcpy(ethip->ar_tha, dest_mac, ETH_ADDR_LEN); memcpy(ethip->ar_tpa, dest_ip, IP_ADDR_LEN); } void Wireless_Decode_Arp_Packet(char* buf){ struct arp_hdr* arp1; struct arp_ethip* ethip; struct arp_eth_hdr* ethhdr1; ethhdr1 = (struct arp_eth_hdr*)buf; arp1 = (struct arp_hdr*)(buf+ ETH_HDR_LEN); ethip = (struct arp_ethip*)(buf + ARP_HDR_LEN + ETH_HDR_LEN); UART_PRINT("\n\rGot ARP response!\n\r"); UART_PRINT("\n\rIP addr %i.%i.%i.%i ",ethip->ar_spa[0],ethip->ar_spa[1],ethip->ar_spa[2],ethip->ar_spa[3]); UART_PRINT("maps to MAC addr %x:%x:%x:%x:%x:%x!\n\r",ethip->ar_sha[0],ethip->ar_sha[1],ethip->ar_sha[2],ethip->ar_sha[3],ethip->ar_sha[4],ethip->ar_sha[5]); } int32_t setP2Pparams(void) { int32_t ret ; int32_t Mode; uint8_t channels[4] = {0}; uint8_t nameLen = 0; /* Sets role negotiations: P2P intent and negotiation initiator */ ret = sl_WlanPolicySet(SL_WLAN_POLICY_P2P, SL_WLAN_P2P_POLICY( SL_WLAN_P2P_ROLE_GROUP_OWNER, SL_WLAN_P2P_NEG_INITIATOR_ACTIVE), NULL, 0); ASSERT_ON_ERROR(ret, WLAN_ERROR); /* Set the P2P device type, * which is a part of the discovery process. Default is 1-0050F204-1 */ ret = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, SL_WLAN_P2P_OPT_DEV_TYPE, strlen(P2P_DEVICE_TYPE), (const uint8_t *)P2P_DEVICE_TYPE); ASSERT_ON_ERROR(ret, WLAN_ERROR); /* Configure device listen and operation channels */ channels[0] = LISTEN_CHANNEL; channels[1] = LISTEN_REGULATORY_CLASS; channels[2] = OPRA_CHANNEL; channels[3] = OPRA_REGULATORY_CLASS; ret = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, SL_WLAN_P2P_OPT_CHANNEL_N_REGS, sizeof(channels), channels); ASSERT_ON_ERROR(ret, WLAN_ERROR); nameLen = sizeof(app_CB.P2P_CB.p2pDeviceName); sl_NetAppSet (SL_NETAPP_DEVICE_ID,SL_NETAPP_DEVICE_URN, strlen(P2P_DEVICE_NAME), (_u8 *)P2P_DEVICE_NAME); /* Print the device's name */ ret = sl_NetAppGet(SL_NETAPP_DEVICE_ID, SL_NETAPP_DEVICE_URN, &nameLen, (uint8_t*)&app_CB.P2P_CB.p2pDeviceName[0]); ASSERT_ON_ERROR(ret, NETAPP_ERROR); UART_PRINT("\n\r[p2pstart] : Starting NWP in P2P role..\n\r"); UART_PRINT("\n\rDevice name: %s\n\r", &app_CB.P2P_CB.p2pDeviceName); /* Set role to P2P and perform NWP reset */ ret = sl_WlanSetMode(ROLE_P2P); ASSERT_ON_ERROR(ret, WLAN_ERROR); ret = sl_Stop(SL_STOP_TIMEOUT); ASSERT_ON_ERROR(ret, DEVICE_ERROR); Mode = sl_Start(0, 0, 0); if(Mode != ROLE_P2P) { UART_PRINT( "\r\n[p2pstart] : Failed to configure device to P2P mode...\r\n"); ASSERT_ON_ERROR(Mode, DEVICE_ERROR); return(-1); } else { app_CB.P2P_CB.P2PsecParams.Key = (signed char *)""; app_CB.P2P_CB.P2PsecParams.KeyLen = strlen( (const char*)app_CB.P2P_CB.P2PsecParams.Key); app_CB.P2P_CB.P2PsecParams.Type = SL_WLAN_SEC_TYPE_P2P_PBC; app_CB.Role = ROLE_P2P; } return(ret); } void * mainThread(void *arg) { int32_t RetVal ; pthread_attr_t pAttrs_spawn; struct sched_param priParam; struct timespec ts = {0}; int32_t ret; int fd, len; uint32_t header = 1; char buf[100]; /* Initializes the SPI interface to the Network Processor and peripheral SPI (if defined in the board file) */ SPI_init(); GPIO_init(); /* Init Application variables */ RetVal = initAppVariables(); /* Init Terminal UART */ InitTerm(); /* initialize the realtime clock */ clock_settime(CLOCK_REALTIME, &ts); /* Switch off all LEDs on boards */ GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_OFF); GPIO_write(CONFIG_GPIO_LED_1, CONFIG_GPIO_LED_OFF); GPIO_write(CONFIG_GPIO_LED_2, CONFIG_GPIO_LED_OFF); /* Create the sl_Task internal spawn thread */ pthread_attr_init(&pAttrs_spawn); priParam.sched_priority = SPAWN_TASK_PRIORITY; RetVal = pthread_attr_setschedparam(&pAttrs_spawn, &priParam); RetVal |= pthread_attr_setstacksize(&pAttrs_spawn, TASK_STACK_SIZE); /* The SimpleLink host driver architecture mandate spawn thread to be created prior to calling Sl_start (turning the NWP on). */ /* The purpose of this thread is to handle asynchronous events sent from the NWP. * Every event is classified and later handled by the Host driver event handlers. */ RetVal = pthread_create(&gSpawn_thread, &pAttrs_spawn, sl_Task, NULL); if(RetVal != 0) { /* Handle Error */ UART_PRINT("Network Terminal - Unable to create spawn thread \n"); return(NULL); } /* Before turning on the NWP on, reset any previously configured parameters */ /* IMPORTANT NOTE - This is an example reset function, user must update this function to match the application settings. */ RetVal = sl_WifiConfig(); if(RetVal < 0) { /* Handle Error */ UART_PRINT("Network Terminal - Couldn't configure Network Processor - %d\n",RetVal); return(NULL); } /* Turn NWP on */ RetVal = sl_Start(NULL, NULL, NULL); if(RetVal < 0) { /* Handle Error */ UART_PRINT("sl_start failed - %d\n",RetVal); return(NULL); } /* sl_Start returns on success the role that device started on */ app_CB.Role = RetVal; /* Output device information to the UART terminal */ RetVal = DisplayAppBanner(APPLICATION_NAME, APPLICATION_VERSION); if(RetVal < 0) { /* Handle Error */ UART_PRINT( "Network Terminal - Unable to retrieve device information \n"); return(NULL); } ret = setP2Pparams(); if(ret < 0) { UART_PRINT("\n\r[p2pstart] : Failed to configure P2P parameters.\n\r"); return(NULL); } ret = sl_WlanPolicySet(SL_WLAN_POLICY_CONNECTION,SL_WLAN_CONNECTION_POLICY(0,0,1,0),NULL,0); if(ret < 0) { UART_PRINT("\n\rwlan policy set error.\n\r"); return(NULL); } UART_PRINT( "\n\r[p2pstart] : User can stop the P2P connection process by typing" " 'p2pstop' command.\n\r"); /* This would cause the NWP to send P2P probes, and listen on channel 6 */ ret = sl_WlanConnect((int8_t*)P2P_REMOTE_DEVICE, strlen( P2P_REMOTE_DEVICE), 0,&app_CB.P2P_CB.P2PsecParams, 0); if(ret < 0) { SHOW_WARNING(ret, WLAN_ERROR); return (NULL); } UART_PRINT("\n\r[p2pstart] : Waiting for device to be found ...\n\r"); UART_PRINT(cmdPromptStr); ret = sem_wait(&app_CB.P2P_CB.DeviceFound); if(ret < 0) { SHOW_WARNING(ret, OS_ERROR); return (NULL); } /* Replay with connection request */ UART_PRINT("\n\r[p2pstart] : Connecting ...\n\r"); // /* Remote's SSID known - Establish connection */ ret = sl_WlanConnect((signed char*)&app_CB.P2P_CB.p2pPeerDeviceName[0], strlen( (char*)&app_CB.P2P_CB.p2pPeerDeviceName[0]), 0, &(app_CB.P2P_CB.P2PsecParams), 0); /* Wait for connect event */ ret = sem_wait(&app_CB.P2P_CB.RcvConReq); if(ret < 0) { SHOW_WARNING(ret, OS_ERROR); return (NULL); } SET_STATUS_BIT(app_CB.Status, STATUS_BIT_CONNECTION); int rc; SlNetCfgIpV4Args_t ipAddr = {0}; SlWlanRxFilterIdMask_t FilterIdMask; len = sizeof(SlWlanRxFilterIdMask_t); _i16 RawPacketSD; SlWlanSecParams_t secParams; memset(&ipAddr, 0, sizeof(SlNetCfgIpV4Args_t)); rc= sl_NetCfgSet(SL_NETCFG_IPV4_AP_ADDR_MODE, SL_NETCFG_ADDR_STATIC, sizeof(SlNetCfgIpV4Args_t),(_u8 *)&ipAddr); if(rc < 0){ UART_PRINT("\n\r error in seting IP to 0.0.0.0\n\r"); } // disable network applications rc = sl_NetAppStop(SL_NETAPP_HTTP_SERVER_ID | SL_NETAPP_DHCP_SERVER_ID | SL_NETAPP_MDNS_ID); if(rc < 0){ UART_PRINT("\n\r error in disabling network applications\n\r"); } // restart NWP by calling stop then start to init with static IP 0.0.0.0 rc = sl_Stop(1000); if(rc < 0){ UART_PRINT("\n\r error in start to init with static IP 0.0.0.0\n\r"); } rc = sl_Start(NULL, NULL, NULL); if(rc < 0){ UART_PRINT("\n\r error starting NWP\n\r"); // error starting NWP } // open RAW socket RawPacketSD = sl_Socket(SL_AF_PACKET,SL_SOCK_RAW, 0); if(RawPacketSD < 0){ UART_PRINT("\n\r error opening raw socket\n\r"); // error opening raw socket } Wireless_Build_Arp_Packet(buf); len = ARP_HDR_LEN + ARP_ETHIP_LEN + ETH_HDR_LEN; ret = sl_Send(RawPacketSD, buf, len, 0); ret = sl_Recv(RawPacketSD, buf, 40,0); Wireless_Decode_Arp_Packet(buf); UART_PRINT( "\n\r:" " BSSID: %x:%x:%x:%x:%x:%x\n\r", app_CB.CON_CB.ConnectionBSSID[0], app_CB.CON_CB.ConnectionBSSID[1], app_CB.CON_CB.ConnectionBSSID[2], app_CB.CON_CB.ConnectionBSSID[3], app_CB.CON_CB.ConnectionBSSID[4], app_CB.CON_CB.ConnectionBSSID[5]); UART_PRINT( "\n\r:" " ConnectionSSID: %x:%x:%x:%x:%x:%x\n\r", app_CB.CON_CB.srcBSSID[0], app_CB.CON_CB.srcBSSID[1], app_CB.CON_CB.srcBSSID[2], app_CB.CON_CB.srcBSSID[3], app_CB.CON_CB.srcBSSID[4], app_CB.CON_CB.srcBSSID[5]); UART_PRINT( "\n\r:" " DestinationIp: %x\n\r", app_CB.CON_CB.DestinationIp); UART_PRINT( "\n\r:" " IpAddr: %x\n\r", app_CB.CON_CB.IpAddr); return(0); }
Client:
#define ARP_ETHIP_LEN 20 /* base ARP message length */ #define ARP_HRD_ETH 0x0001 /* ethernet hardware */ #define ARP_PRO_IP 0x0800 /* IP protocol */ #define ETH_ADDR_LEN 6 #define IP_ADDR_LEN 4 #define ARP_OP_REQUEST 1 /* request to resolve ha given pa */ struct arp_hdr { uint16_t ar_hrd; /* format of hardware address */ uint16_t ar_pro; /* format of protocol address */ uint8_t ar_hln; /* length of hardware address (ETH_ADDR_LEN) */ uint8_t ar_pln; /* length of protocol address (IP_ADDR_LEN) */ uint16_t ar_op; /* operation */ }arp_hdr; struct arp_ethip { uint8_t ar_sha[ETH_ADDR_LEN]; /* sender hardware address */ uint8_t ar_spa[IP_ADDR_LEN]; /* sender protocol address */ uint8_t ar_tha[ETH_ADDR_LEN]; /* target hardware address */ uint8_t ar_tpa[IP_ADDR_LEN]; /* target protocol address */ }arp_ethip; struct arp_eth_hdr { uint8_t dst_mac[ETH_ADDR_LEN]; uint8_t src_mac[ETH_ADDR_LEN]; uint8_t type[2]; }arp_eth_hdr; #define ARP_HDR_LEN sizeof(arp_hdr) #define ETH_HDR_LEN sizeof(arp_eth_hdr) void Wireless_Build_Arp_Packet(char* buf) { struct arp_hdr* arp1; struct arp_ethip* ethip; struct arp_eth_hdr* ethhdr1; unsigned char mac[6]; memcpy(mac, app_CB.CON_CB.srcBSSID, ETH_ADDR_LEN); unsigned char src_ip[4]; // unsigned char src_ip[4] = {0xc0, 0xa8, 0x2b, 0xda}; memcpy(src_ip, app_CB.CON_CB.IpAddr, 4); unsigned char dest_mac[6] = {0XFF, 0XFF, 0XFF, 0XFF, 0XFF, 0XFF}; // unsigned char dest_ip[4] = {0xc0, 0xa8, 0x2b, 0x25}; unsigned char dest_ip[4]; memcpy(dest_ip, app_CB.CON_CB.DestinationIp, 4); unsigned char eth_type[2] = {0x08, 0x06}; ethhdr1 = (struct arp_eth_hdr*)buf; memcpy(ethhdr1->dst_mac, dest_mac, ETH_ADDR_LEN); memcpy(ethhdr1->src_mac, mac, ETH_ADDR_LEN); memcpy(ethhdr1->type, eth_type, 2); arp1 = (struct arp_hdr*)(buf+ ETH_HDR_LEN); arp1->ar_hrd = sl_Htons(ARP_HRD_ETH); arp1->ar_pro = sl_Htons(ARP_PRO_IP); arp1->ar_hln = ETH_ADDR_LEN; arp1->ar_pln = IP_ADDR_LEN; arp1->ar_op = sl_Htons(ARP_HRD_ETH); ethip = (struct arp_ethip*)(buf + ARP_HDR_LEN + ETH_HDR_LEN); memcpy(ethip->ar_sha, mac, ETH_ADDR_LEN); memcpy(ethip->ar_spa, src_ip, IP_ADDR_LEN); memcpy(ethip->ar_tha, dest_mac, ETH_ADDR_LEN); memcpy(ethip->ar_tpa, dest_ip, IP_ADDR_LEN); } void Wireless_Decode_Arp_Packet(char* buf){ struct arp_hdr* arp1; struct arp_ethip* ethip; struct arp_eth_hdr* ethhdr1; ethhdr1 = (struct arp_eth_hdr*)buf; arp1 = (struct arp_hdr*)(buf+ ETH_HDR_LEN); ethip = (struct arp_ethip*)(buf + ARP_HDR_LEN + ETH_HDR_LEN); UART_PRINT("\n\rGot ARP response!\n\r"); UART_PRINT("\n\rIP addr %i.%i.%i.%i ",ethip->ar_spa[0],ethip->ar_spa[1],ethip->ar_spa[2],ethip->ar_spa[3]); UART_PRINT("maps to MAC addr %x:%x:%x:%x:%x:%x!\n\r",ethip->ar_sha[0],ethip->ar_sha[1],ethip->ar_sha[2],ethip->ar_sha[3],ethip->ar_sha[4],ethip->ar_sha[5]); } int32_t setP2Pparams(void) { int32_t ret ; int32_t Mode; uint8_t channels[4] = {0}; uint8_t nameLen = 0; /* Sets role negotiations: P2P intent and negotiation initiator */ ret = sl_WlanPolicySet(SL_WLAN_POLICY_P2P, SL_WLAN_P2P_POLICY( SL_WLAN_P2P_ROLE_CLIENT, SL_WLAN_P2P_NEG_INITIATOR_PASSIVE), NULL, 0); ASSERT_ON_ERROR(ret, WLAN_ERROR); /* Set the P2P device type, * which is a part of the discovery process. Default is 1-0050F204-1 */ ret = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, SL_WLAN_P2P_OPT_DEV_TYPE, strlen(P2P_DEVICE_TYPE), (const uint8_t *)P2P_DEVICE_TYPE); ASSERT_ON_ERROR(ret, WLAN_ERROR); /* Configure device listen and operation channels */ channels[0] = LISTEN_CHANNEL; channels[1] = LISTEN_REGULATORY_CLASS; channels[2] = OPRA_CHANNEL; channels[3] = OPRA_REGULATORY_CLASS; ret = sl_WlanSet(SL_WLAN_CFG_P2P_PARAM_ID, SL_WLAN_P2P_OPT_CHANNEL_N_REGS, sizeof(channels), channels); ASSERT_ON_ERROR(ret, WLAN_ERROR); nameLen = sizeof(app_CB.P2P_CB.p2pDeviceName); sl_NetAppSet (SL_NETAPP_DEVICE_ID,SL_NETAPP_DEVICE_URN, strlen(P2P_DEVICE_NAME), (_u8 *)P2P_DEVICE_NAME); /* Print the device's name */ ret = sl_NetAppGet(SL_NETAPP_DEVICE_ID, SL_NETAPP_DEVICE_URN, &nameLen, (uint8_t*)&app_CB.P2P_CB.p2pDeviceName[0]); ASSERT_ON_ERROR(ret, NETAPP_ERROR); UART_PRINT("\n\r[p2pstart] : Starting NWP in P2P role..\n\r"); UART_PRINT("\n\rDevice name: %s\n\r", &app_CB.P2P_CB.p2pDeviceName); /* Set role to P2P and perform NWP reset */ ret = sl_WlanSetMode(ROLE_P2P); ASSERT_ON_ERROR(ret, WLAN_ERROR); ret = sl_Stop(SL_STOP_TIMEOUT); ASSERT_ON_ERROR(ret, DEVICE_ERROR); Mode = sl_Start(0, 0, 0); if(Mode != ROLE_P2P) { UART_PRINT( "\r\n[p2pstart] : Failed to configure device to P2P mode...\r\n"); ASSERT_ON_ERROR(Mode, DEVICE_ERROR); return(-1); } else { app_CB.P2P_CB.P2PsecParams.Key = (signed char *)""; app_CB.P2P_CB.P2PsecParams.KeyLen = strlen( (const char*)app_CB.P2P_CB.P2PsecParams.Key); app_CB.P2P_CB.P2PsecParams.Type = SL_WLAN_SEC_TYPE_P2P_PBC; app_CB.Role = ROLE_P2P; } return(ret); } void * mainThread(void *arg) { int32_t RetVal ; pthread_attr_t pAttrs_spawn; struct sched_param priParam; struct timespec ts = {0}; int32_t ret; int fd, len; uint32_t header = 1; char buf[100]; /* Initializes the SPI interface to the Network Processor and peripheral SPI (if defined in the board file) */ SPI_init(); GPIO_init(); /* Init Application variables */ RetVal = initAppVariables(); /* Init Terminal UART */ InitTerm(); /* initialize the realtime clock */ clock_settime(CLOCK_REALTIME, &ts); /* Switch off all LEDs on boards */ GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_OFF); GPIO_write(CONFIG_GPIO_LED_1, CONFIG_GPIO_LED_OFF); GPIO_write(CONFIG_GPIO_LED_2, CONFIG_GPIO_LED_OFF); /* Create the sl_Task internal spawn thread */ pthread_attr_init(&pAttrs_spawn); priParam.sched_priority = SPAWN_TASK_PRIORITY; RetVal = pthread_attr_setschedparam(&pAttrs_spawn, &priParam); RetVal |= pthread_attr_setstacksize(&pAttrs_spawn, TASK_STACK_SIZE); /* The SimpleLink host driver architecture mandate spawn thread to be created prior to calling Sl_start (turning the NWP on). */ /* The purpose of this thread is to handle asynchronous events sent from the NWP. * Every event is classified and later handled by the Host driver event handlers. */ RetVal = pthread_create(&gSpawn_thread, &pAttrs_spawn, sl_Task, NULL); if(RetVal != 0) { /* Handle Error */ UART_PRINT("Network Terminal - Unable to create spawn thread \n"); return(NULL); } /* Before turning on the NWP on, reset any previously configured parameters */ /* IMPORTANT NOTE - This is an example reset function, user must update this function to match the application settings. */ RetVal = sl_WifiConfig(); if(RetVal < 0) { /* Handle Error */ UART_PRINT("Network Terminal - Couldn't configure Network Processor - %d\n",RetVal); return(NULL); } /* Turn NWP on */ RetVal = sl_Start(NULL, NULL, NULL); if(RetVal < 0) { /* Handle Error */ UART_PRINT("sl_start failed - %d\n",RetVal); return(NULL); } /* sl_Start returns on success the role that device started on */ app_CB.Role = RetVal; /* Output device information to the UART terminal */ RetVal = DisplayAppBanner(APPLICATION_NAME, APPLICATION_VERSION); if(RetVal < 0) { /* Handle Error */ UART_PRINT( "Network Terminal - Unable to retrieve device information \n"); return(NULL); } ret = setP2Pparams(); if(ret < 0) { UART_PRINT("\n\r[p2pstart] : Failed to configure P2P parameters.\n\r"); return(-1); } ret = sl_WlanPolicySet(SL_WLAN_POLICY_CONNECTION,SL_WLAN_CONNECTION_POLICY(0,0,1,0),NULL,0); if(ret < 0) { UART_PRINT("\n\rwlan policy set error.\n\r"); return(NULL); } UART_PRINT( "\n\r[p2pstart] : User can stop the P2P connection process by typing" " 'p2pstop' command.\n\r"); /* This would cause the NWP to send P2P probes, and listen on channel 6 */ ret = sl_WlanConnect((int8_t*)P2P_REMOTE_DEVICE, strlen( P2P_REMOTE_DEVICE), 0,&app_CB.P2P_CB.P2PsecParams, 0); if(ret < 0) { SHOW_WARNING(ret, WLAN_ERROR); return (NULL); } UART_PRINT("\n\r[p2pstart] : Waiting for device to be found ...\n\r"); UART_PRINT(cmdPromptStr); ret = sem_wait(&app_CB.P2P_CB.DeviceFound); if(ret < 0) { SHOW_WARNING(ret, OS_ERROR); return (NULL); } UART_PRINT("\n\r[p2pstart] : Waiting for Negotiation request ...\n\r"); UART_PRINT(cmdPromptStr); ret = sem_wait(&app_CB.P2P_CB.RcvNegReq); if(ret < 0) { SHOW_WARNING(ret, OS_ERROR); return (NULL); } /* Wait for connect event */ ret = sem_wait(&app_CB.P2P_CB.RcvConReq); if(ret < 0) { SHOW_WARNING(ret, OS_ERROR); return (NULL); } SET_STATUS_BIT(app_CB.Status, STATUS_BIT_CONNECTION); int rc; SlNetCfgIpV4Args_t ipAddr = {0}; SlWlanRxFilterIdMask_t FilterIdMask; len = sizeof(SlWlanRxFilterIdMask_t); _i16 RawPacketSD; SlWlanSecParams_t secParams; memset(&ipAddr, 0, sizeof(SlNetCfgIpV4Args_t)); rc= sl_NetCfgSet(SL_NETCFG_IPV4_STA_ADDR_MODE, SL_NETCFG_ADDR_STATIC, sizeof(SlNetCfgIpV4Args_t), (_u8 *)&ipAddr); if(rc < 0) { UART_PRINT("\n\r error in seting IP to 0.0.0.0\n\r"); } // disable network applications rc = sl_NetAppStop(SL_NETAPP_HTTP_SERVER_ID | SL_NETAPP_DHCP_SERVER_ID | SL_NETAPP_MDNS_ID); if(rc < 0){ UART_PRINT("\n\r error in disabling network applications\n\r"); } // restart NWP by calling stop then start to init with static IP 0.0.0.0 rc = sl_Stop(1000); if(rc < 0){ UART_PRINT("\n\r error in start to init with static IP 0.0.0.0\n\r"); } rc = sl_Start(NULL, NULL, NULL); if(rc < 0){ UART_PRINT("\n\r error starting NWP\n\r"); // error starting NWP } // open RAW socket RawPacketSD = sl_Socket(SL_AF_PACKET,SL_SOCK_RAW, 0); if(RawPacketSD < 0){ UART_PRINT("\n\r error opening raw socket\n\r"); // error opening raw socket } ret = sl_Recv(RawPacketSD, buf, 40,0); Wireless_Decode_Arp_Packet(buf); Wireless_Build_Arp_Packet(buf); len = ARP_HDR_LEN + ARP_ETHIP_LEN + ETH_HDR_LEN; ret = sl_Send(RawPacketSD, buf, len, 0); UART_PRINT( "\n\r:" " BSSID: %x:%x:%x:%x:%x:%x\n\r", app_CB.CON_CB.ConnectionBSSID[0], app_CB.CON_CB.ConnectionBSSID[1], app_CB.CON_CB.ConnectionBSSID[2], app_CB.CON_CB.ConnectionBSSID[3], app_CB.CON_CB.ConnectionBSSID[4], app_CB.CON_CB.ConnectionBSSID[5]); UART_PRINT( "\n\r:" " ConnectionSSID: %x:%x:%x:%x:%x:%x\n\r", app_CB.CON_CB.srcBSSID[0], app_CB.CON_CB.srcBSSID[1], app_CB.CON_CB.srcBSSID[2], app_CB.CON_CB.srcBSSID[3], app_CB.CON_CB.srcBSSID[4], app_CB.CON_CB.srcBSSID[5]); UART_PRINT( "\n\r:" " DestinationIp: %x\n\r", app_CB.CON_CB.DestinationIp); UART_PRINT( "\n\r:" " IpAddr: %x\n\r", app_CB.CON_CB.IpAddr); return(0); }
