WL1801MOD: FW loading failed
Part Number: WL1801MOD
Other Parts Discussed in Thread: WL1801,
In one of us devices has been mentioned a problem with FW loading (see dmesg_Dev25.log):
[    8.134717] wl18xx_driver wl18xx.0.auto: loading /lib/firmware/ti-connectivity/wl18xx-fw-4.bin failed with error -13
Could you please give as more info about this error?
What should be changed?
Best regards
Jiri
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.14.78-imx-hcm+g66620c3d281c (oe-user@oe-host) (gcc version 7.3.0 (GCC)) #1 SMP PREEMPT Fri Mar 29 01:01:58 UTC 2019
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: PES-HCM C1-Sample
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0xaa000000, size 320 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] On node 0 totalpages: 261888
[    0.000000] free_area_init_node: node 0, pgdat 80d53840, node_mem_map bf657000
[    0.000000]   Normal zone: 2046 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 261888 pages, LIFO batch:31
[    0.000000] percpu: Embedded 16 pages/cpu @bf62b000 s35852 r8192 d21492 u65536
[    0.000000] pcpu-alloc: s35852 r8192 d21492 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 259842
[    0.000000] Kernel command line: uart_from_osc console=ttymxc0,115200 rootrw=/dev/mmcblk3p9 init=/init rootrwoptions=rw root=/dev/mmcblk3p5 rootwait rw rootrwreset=no
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 696936K/1047552K available (8192K kernel code, 338K rwdata, 2400K rodata, 1024K init, 420K bss, 22936K reserved, 327680K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xc0000000 - 0xff800000   (1016 MB)
                   lowmem  : 0x80000000 - 0xbff00000   (1023 MB)
                   pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
                   modules : 0x7f000000 - 0x7fe00000   (  14 MB)
                     .text : 0x80008000 - 0x80900000   (9184 kB)
                     .init : 0x80c00000 - 0x80d00000   (1024 kB)
                     .data : 0x80d00000 - 0x80d54920   ( 339 kB)
                      .bss : 0x80d56000 - 0x80dbf0e0   ( 421 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[    0.000000] 	Tasks RCU enabled.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C-310 erratum 769419 enabled
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[    0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[    0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76430001
[    0.000000] Switching to timer-based delay loop, resolution 333ns
[    0.000007] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[    0.000021] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[    0.001649] Console: colour dummy device 80x30
[    0.001670] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[    0.001683] pid_max: default: 32768 minimum: 301
[    0.001801] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001815] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002347] CPU: Testing write buffer coherency: ok
[    0.002383] CPU0: Spectre v2: using BPIALL workaround
[    0.002619] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.040237] Setting up static identity map for 0x80100000 - 0x80100060
[    0.060242] Hierarchical SRCU implementation.
[    0.100334] smp: Bringing up secondary CPUs ...
[    0.100344] smp: Brought up 1 node, 1 CPU
[    0.100351] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[    0.100359] CPU: All CPU(s) started in SVC mode.
[    0.101201] devtmpfs: initialized
[    0.107270] random: get_random_u32 called from bucket_table_alloc+0x114/0x23c with crng_init=0
[    0.107437] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.107715] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.107732] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.125368] pinctrl core: initialized pinctrl subsystem
[    0.126208] NET: Registered protocol family 16
[    0.137311] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.138148] cpuidle: using governor menu
[    0.145670] vdd1p1: supplied by regulator-dummy
[    0.146199] vdd3p0: supplied by regulator-dummy
[    0.146688] vdd2p5: supplied by regulator-dummy
[    0.147187] vddarm: supplied by regulator-dummy
[    0.147679] vddpcie-phy: supplied by regulator-dummy
[    0.148172] vddsoc: supplied by regulator-dummy
[    0.158346] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.158355] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.159901] imx6sx-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[    0.162441] MU is ready for cross core communication!
[    0.191422] GPIO line 1 (pg3_8V) hogged as input
[    0.202752] SCSI subsystem initialized
[    0.210907] libata version 3.00 loaded.
[    0.211115] usbcore: registered new interface driver usbfs
[    0.211174] usbcore: registered new interface driver hub
[    0.211262] usbcore: registered new device driver usb
[    0.211502] usb_phy_generic 2000000.aips-bus:usbphy_nop1: 2000000.aips-bus:usbphy_nop1 supply vcc not found, using dummy regulator
[    0.212502] i2c i2c-0: IMX I2C adapter registered
[    0.212517] i2c i2c-0: can't use DMA, using PIO instead.
[    0.213133] i2c i2c-1: IMX I2C adapter registered
[    0.213147] i2c i2c-1: can't use DMA, using PIO instead.
[    0.213627] pps_core: LinuxPPS API ver. 1 registered
[    0.213634] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.213654] PTP clock support registered
[    0.214779] MIPI CSI2 driver module loaded
[    0.215455] MU is ready for cross core communication!
[    0.215672] platform 2200000.aips-bus: coherent DMA mask is unset
[    0.216774] virtio_rpmsg_bus virtio0: rpmsg host is online
[    0.216918] imx rpmsg driver is registered.
[    0.231218] clocksource: Switched to clocksource mxc_timer1
[    0.231350] VFS: Disk quotas dquot_6.6.0
[    0.231413] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.240300] NET: Registered protocol family 2
[    0.240886] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.241025] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.241154] TCP: Hash tables configured (established 8192 bind 8192)
[    0.241305] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.241345] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.241525] NET: Registered protocol family 1
[    0.242117] hw perfevents: no interrupt-affinity property for /soc/pmu, guessing.
[    0.242283] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[    0.244232] Bus freq driver module loaded
[    0.245559] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[    0.249554] ntfs: driver 2.1.32 [Flags: R/W].
[    0.249732] jffs2: version 2.2. (NAND) \xc2\xa9 2001-2006 Red Hat, Inc.
[    0.250190] fuse init (API version 7.26)
[    0.259366] io scheduler noop registered
[    0.259375] io scheduler deadline registered
[    0.259538] io scheduler cfq registered (default)
[    0.259545] io scheduler mq-deadline registered
[    0.259551] io scheduler kyber registered
[    0.260194] imx-weim 21b8000.weim: Driver registered.
[    0.266044] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[    0.266552] imx-sdma 20ec000.sdma: Falling back to user helper
[    0.270255] mxs-dma 1804000.dma-apbh: initialized
[    0.271851] imx-gpc 20dc000.gpc: 20dc000.gpc supply pu not found, using dummy regulator
[    0.274312] pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
[    0.274975] pfuze100-regulator 1-0008: FAB: 0, FIN: 0
[    0.274984] pfuze100-regulator 1-0008: pfuze200 found.
[    0.296819] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 23, base_baud = 1500000) is a IMX
[    0.296909] console [ttymxc0] enabled
[    0.300055] imx sema4 driver is registered.
[    0.309335] brd: module loaded
[    0.317665] loop: module loaded
[    0.322479] spi_imx 200c000.ecspi: probed
[    0.323399] libphy: Fixed MDIO Bus: probed
[    0.323408] CAN device driver interface
[    0.323726] flexcan 2090000.can: 2090000.can supply xceiver not found, using dummy regulator
[    0.323985] flexcan 2090000.can: registering netdev failed
[    0.328425] flexcan: probe of 2090000.can failed with error -110
[    0.330372] fec 2188000.ethernet: 2188000.ethernet supply phy not found, using dummy regulator
[    0.344677] pps pps0: new PPS source ptp0
[    0.346182] fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[    0.354897] fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: ee:04:72:25:b7:64
[    0.355651] libphy: fec_enet_mii_bus: probed
[    0.368097] fec 2188000.ethernet eth0: registered PHC device 0
[    0.368938] fec 21b4000.ethernet: 21b4000.ethernet supply phy not found, using dummy regulator
[    0.383463] pps pps1: new PPS source ptp1
[    0.384885] fec 21b4000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
[    0.393675] fec 21b4000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: be:b1:16:85:e5:88
[    0.394910] fec 21b4000.ethernet eth1: registered PHC device 1
[    0.395431] qcaspi spi1.0: reset precedure entry.
[    0.511253] qcaspi spi1.0: wait time:100
[    0.631250] qcaspi spi1.0: reset precedure exit
[    0.634492] qcaspi spi1.0: ver=0.2.7-i, clkspeed=8000000, burst_len=5000, pluggable=0
[    0.635472] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.635480] ehci-mxc: Freescale On-Chip EHCI Host driver
[    0.635636] usbcore: registered new interface driver usb-storage
[    0.636833] usbmisc_imx 2184800.usbmisc: 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[    0.641286] ci_hdrc ci_hdrc.0: EHCI Host Controller
[    0.641335] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[    0.671278] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[    0.671515] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.671526] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.671535] usb usb1: Product: EHCI Host Controller
[    0.671544] usb usb1: Manufacturer: Linux 4.14.78-imx-hcm+g66620c3d281c ehci_hcd
[    0.671550] usb usb1: SerialNumber: ci_hdrc.0
[    0.672190] hub 1-0:1.0: USB hub found
[    0.672242] hub 1-0:1.0: 1 port detected
[    0.686732] ci_hdrc ci_hdrc.1: EHCI Host Controller
[    0.686767] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[    0.711248] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[    0.711466] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    0.711477] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.711486] usb usb2: Product: EHCI Host Controller
[    0.711494] usb usb2: Manufacturer: Linux 4.14.78-imx-hcm+g66620c3d281c ehci_hcd
[    0.711501] usb usb2: SerialNumber: ci_hdrc.1
[    0.712116] hub 2-0:1.0: USB hub found
[    0.712171] hub 2-0:1.0: 1 port detected
[    0.724263] input: 20cc000.snvs:snvs-powerkey as /devices/soc0/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
[    0.725575] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-rtc-lp as rtc0
[    0.725952] i2c /dev entries driver
[    0.728027] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[    0.728848] device-mapper: ioctl: 4.37.0-ioctl (2017-09-20) initialised: dm-devel@redhat.com
[    0.739939] sdhci: Secure Digital Host Controller Interface driver
[    0.739946] sdhci: Copyright(c) Pierre Ossman
[    0.739950] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.831258] mmc2: Switching to 3.3V failed because flag is not set.
[    0.831273] mmc2: Initial signal voltage of 1.8v
[    0.891289] mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[    0.898184] sdhci-esdhc-imx 2198000.usdhc: card claims to support voltages below defined range
[    0.905807] random: fast init done
[    0.913827] mmc3: Initial signal voltage of 3.3v
[    0.916747] mmc2: new high speed SDIO card at address 0001
[    0.928148] wl18xx_driver wl18xx.0.auto: Falling back to user helper
[    0.971303] mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
[    0.972985] caam 2100000.caam: can't identify CAAM ipg clk: -2
[    0.977539] caam: probe of 2100000.caam failed with error -2
[    0.978665] caam-snvs 20cc000.caam-snvs: can't get snvs clock
[    0.983417] caam-snvs 20cc000.caam-snvs: violation handlers armed - init state
[    0.990128] NET: Registered protocol family 26
[    0.990771] NET: Registered protocol family 10
[    1.002070] Segment Routing with IPv6
[    1.002143] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    1.002765] NET: Registered protocol family 17
[    1.002786] can: controller area network core (rev 20170425 abi 9)
[    1.002863] NET: Registered protocol family 29
[    1.002872] can: raw protocol (rev 20170425)
[    1.002877] can: broadcast manager protocol (rev 20170425 t)
[    1.002888] can: netlink gateway (rev 20170425) max_hops=1
[    1.003012] 8021q: 802.1Q VLAN Support v1.8
[    1.003057] Key type dns_resolver registered
[    1.065347] A9-M4 sema4 num 6, A9-M4 magic number 0x12345678 - 0xd22a4833.
[    1.068644] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[    1.068887] imx_thermal 2000000.aips-bus:tempmon: Extended Commercial CPU temperature grade - max:105C critical:100C passive:95C
[    1.072386] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[    1.072670] snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:00 UTC (0)
[    1.073432] wlcore-en-regulator: disabling
[    1.073671] mmc3: Switching to 1.8V failed because flag is not set.
[    1.073893] Waiting for root device /dev/mmcblk3p5...
[    1.082453] mmc3: new DDR MMC card at address 0001
[    1.083162] mmcblk3: mmc3:0001 R1J55A 7.28 GiB
[    1.083785] mmcblk3boot0: mmc3:0001 R1J55A partition 1 8.00 MiB
[    1.084422] mmcblk3boot1: mmc3:0001 R1J55A partition 2 8.00 MiB
[    1.085086] mmcblk3rpmb: mmc3:0001 R1J55A partition 3 4.00 MiB
[    1.100405]  mmcblk3: p1 p2 p3 p4 < p5 p6 p7 p8 p9 p10 p11 p12 >
[    1.152035] EXT4-fs (mmcblk3p5): mounted filesystem with ordered data mode. Opts: (null)
[    1.152120] VFS: Mounted root (ext4 filesystem) on device 179:5.
[    1.157171] devtmpfs: mounted
[    1.159271] Freeing unused kernel memory: 1024K
[    1.489782] EXT4-fs (mmcblk3p5): re-mounted. Opts: data=ordered
[    1.574259] EXT4-fs (mmcblk3p9): recovery complete
[    1.574755] EXT4-fs (mmcblk3p9): mounted filesystem with ordered data mode. Opts: (null)
[    1.748395] systemd[1]: System time before build time, advancing clock.
[    1.774432] systemd[1]: systemd 237 running in system mode. (-PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    1.774964] systemd[1]: Detected architecture arm.
[    1.802590] systemd[1]: Set hostname to <mx6sxhcm-c2>.
[    1.983464] systemd[1]: File /lib/systemd/system/systemd-journald.service:35 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    1.983485] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    2.075596] systemd[1]: Configuration file /lib/systemd/system/php-fpm.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    2.225415] systemd[1]: Unnecessary job for /dev/mmcblk3p5 was removed.
[    2.225471] systemd[1]: Unnecessary job for /dev/mmcblk3p9 was removed.
[    2.227670] random: systemd: uninitialized urandom read (16 bytes read)
[    2.227764] systemd[1]: Reached target Remote File Systems.
[    2.251509] random: systemd: uninitialized urandom read (16 bytes read)
[    2.251609] systemd[1]: Reached target Swap.
[    2.282463] random: systemd: uninitialized urandom read (16 bytes read)
[    2.681198] cryptodev: loading out-of-tree module taints kernel.
[    2.692654] cryptodev: driver 1.9 loaded.
[    2.694853] RPMSG: Init function was called.
[    3.451965] systemd-journald[148]: Received request to flush runtime journal from PID 1
[    4.178775] evbug: Connected device: input0 (20cc000.snvs:snvs-powerkey at snvs-pwrkey/input0)
[    4.178789] evbug: Connected device: input1 (gpio-keys at gpio-keys/input0)
[    4.538032] imx-sdma 20ec000.sdma: loaded firmware 3.4
[    4.629227] Reset precedure entry.
[    4.651311] Reset precedure exit
[    4.651321] Hmiboard_Probe: Finished
[    4.651478] Hmiboard_LedDriverInit: Finished
[    4.669541] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.715617] Generic PHY 2188000.ethernet-1:00: attached PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
[    4.716860] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.732608] mmc2: Switching to 3.3V failed because flag is not set.
[    4.732624] mmc2: Initial signal voltage of 1.8v
[    5.081926] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[    5.087602] wlcore: loaded
[    6.803595] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    6.803624] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    7.699448] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    7.821331] mmc2: Switching to 3.3V failed because flag is not set.
[    7.821344] mmc2: Initial signal voltage of 1.8v
[    8.060844] EXT4-fs (mmcblk3p11): recovery complete
[    8.060863] EXT4-fs (mmcblk3p11): mounted filesystem with ordered data mode. Opts: (null)
[    8.082950] EXT4-fs (mmcblk3p12): recovery complete
[    8.082972] EXT4-fs (mmcblk3p12): mounted filesystem with ordered data mode. Opts: (null)
[    8.134744] wl18xx_driver wl18xx.0.auto: Falling back to user helper
[    8.278801] wlcore: PHY firmware version: Rev 8.2.0.0.242
[    8.324490] wlcore: firmware booted (Rev 8.9.0.0.79)
[    8.356300] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[    9.901163] qcaspi spi1.0 eth2: SPI thread created
[   14.331273] random: crng init done
[   14.331284] random: 7 urandom warning(s) missed due to ratelimiting
[   19.734282] virtio_rpmsg_bus virtio0: creating channel rpmsg-openamp-demo-channel addr 0x0
[   19.734969] RPMSG: Probe function was called.
[   19.735022] hcm_rpmsg virtio0.rpmsg-openamp-demo-channel.-1.0: new channel: 0x400 -> 0x0!
[   97.351420] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[   97.553716] usb 2-1: New USB device found, idVendor=0781, idProduct=5575
[   97.553766] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   97.553800] usb 2-1: Product: Cruzer Glide
[   97.553830] usb 2-1: Manufacturer: SanDisk
[   97.553858] usb 2-1: SerialNumber: 4C530000230720115295
[   97.572715] usb-storage 2-1:1.0: USB Mass Storage device detected
[   97.586235] scsi host0: usb-storage 2-1:1.0
[   98.643717] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Glide     1.00 PQ: 0 ANSI: 6
[   98.660642] sd 0:0:0:0: [sda] 31260672 512-byte logical blocks: (16.0 GB/14.9 GiB)
[   98.664050] sd 0:0:0:0: [sda] Write Protect is off
[   98.664062] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[   98.664764] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   98.673737]  sda: sda1
[   98.676907] sd 0:0:0:0: [sda] Attached SCSI removable disk
[15486.032516] wlan0: authenticate with 74:da:da:e3:98:2a
[15486.038015] wlan0: send auth to 74:da:da:e3:98:2a (try 1/3)
[15486.055726] wlan0: authenticated
[15486.063070] wlan0: associate with 74:da:da:e3:98:2a (try 1/3)
[15486.072935] wlan0: RX AssocResp from 74:da:da:e3:98:2a (capab=0x411 status=0 aid=10)
[15486.083862] wlcore: Association completed.
[15486.098559] wlan0: associated
[137020.926264] wlcore: WARNING corrupted packet in RX: status: 0x1 len: 60
[568991.339848] wlcore: WARNING corrupted packet in RX: status: 0x1 len: 60
