Other Parts Discussed in Thread: UNIFLASH, CC3100
With regard to public security certificates that I'll need to store on the [CC3220SF] device (and along with it the associated device Certificate Catalog), I've been seeing some conflicting information that makes me want to double check that I can indeed create my own company specific private key (using openssl tools) and my own company specific self signed [der format] root-ca certificate (using openssl tools) that I then store into the CC3220SF's OTP (One Time Programming) portion of flash (using UniFlash GUI tool or the UniFlash dslite.sh command line tool). And along with this to create my own company specific device Certificate Catalog (using TI UniFlash tools). In this arrangement my company specific self-signed root-ca can then be used by the TI system (under the hood) infrastructure to authenticate an MCU image retrieved from a DropBox folder (or Git Server) using the TI supplied example OTA (Over The Air) programming logic that's been integrated to my company specific CC3220SF application? If my only intent is to authenticate MCU images delivered via OTA can I get by with just the single public certificate (root-ca) stored in the OTP or do I need to also store an additional company specific public certificate on the device (trusted-ca) that resides in normal flash (top level directory) and which itself is signed by the private key associated with the company specific public root-ca stored in OTP? If this [two certificate chain] is needed, then I assume the MCU is authenticated by the trusted-ca and the certificate filename of the trusted-ca is itemized in the ota.cmd file as part of the block of lines describing the MCU image. But if it's actually ok to skip the second certificate in the chain (e.g. skip the the trusted-ca) and instead have the MCU authenticated via the single OTP based root-ca then how is that certificate itemized in the ota.cmd file? Is there a special filename for the certificate located in OTP? I want the minimal configuration required to authenticate MCU images received via OTA and I don't want a public root-ca purchased (and signed) from a well-known CA. Our product will not implement an HTTPS server so I'm thinking that we can do the self-signed company specific root-ca stored in OTP -- the only HTTPS operations our product will be doing is as a client connecting to a remote HTTPS server for reaching out to the DropBox server during OTA retrievals of a new MCU image; for that we'll have the DropBox public certificate copied over (as either a *.der for a *.pem) and installed on the device filesystem (top level directory) with the same filename as referenced by the OTA_SERVER_ROOT_CA_CERT define of otauser.h. I've really tried hard to search through all the documents and study things before asking this question but for some reason I'm still missing something and will appreciate some clarification. Thanks in advance!
I have studied the following documents:
SWPU332A SimpleLink™ Wi-Fi®CertificatesHandling
www.ti.com/.../swpu332a.pdf
SWRU547A VendorDeviceAuthenticationWithSimpleLink™ WiFi®Devices
www.ti.com/.../swru547a.pdf
SWRU558 SimpleLink™ Wi-Fi®CC3100,CC3200UniFlash
www.ti.com/.../swru558.pdf
SWRU469G UniFlashCC3x20,CC3x35SimpleLink™ Wi-Fi®and Internet-on-achip™ SolutionImageCreatorandProgrammingTool
www.ti.com/.../swru469h.pdf
