Hi Support,
When operating in transceiver mode, is there any way to get the current channel's rssi or get the value used to compare against the cca requirement?
Thanks!
Hi Support,
Thanks!
No. You can read RSSI for a received packet and average RSSI (with the RX statistics), but you can't perform the channel assessment according to the spec.
You can use the SL_SOCK_DGRAM transceiver type that enables CCA.
sl_Socket(SL_AF_RF, SL_SOCK_DGRAM, channel);
Br,
Kobi
