Other Parts Discussed in Thread: CC3220SF
- CoreTigo is deploying WIFI based IOT sensors throughout south America
- The connectivity technology used in the sensors is TI CC3220SF asic , using the “simplelink” SDK OTA library
- The chosen cloud solution for FW upgrade is dropbox
- The sensors are querying CoreTigo’s dropbox account for checking new FW version and upgrade
- For the last year or so the FW upgrade through the dropbox account was working well
- In the last week we are experiencing failures – sensors are failing to load new FW exists in the dropbox folder:
- The start of the process looks ok – the dropbox token looks OK and the folder is accessed successfully, from the sensor logs:
OtaConfig: call OTA_set EXTLIB_OTA_SET_OPT_SERVER_INFO, ServerName=api.dropboxapi.com
OtaConfig: call OTA_set EXTLIB_OTA_SET_OPT_VENDOR_ID, VendorDir=RabbitMQ_Migration_Phase2
- The new FW file is seen properly by the sensor, the file name can be seen clearly, from the sensor logs:
OtaRunStep: CurrentVersion=00000000000000, NewVersion=20210118231832, Start download ...
- However, after download start there seem to be a connectivity issue in the socket level, from the sensor logs:
SL_SOCKET_ASYNC_EVENT socket event 2, do restart
OtaRunStep: WARNING Ota_run, Status=20006, continue for next OTA retry
- The API and content servers use certificates signed by different top level Digicert CAs. We have the high assurance CA certificate used by the API servers, while the content servers use the DigiCert Global Root CA.
Since these are self-signed root certificates there is no chain between them. As a result, the TLS on CC is unable to authenticate the certificate - There is some change in dropbox certificate, so the IOT devices certification process fails: "Root CA configured is wrong - please install DigiCert Global Root CA" (It appears the new certificates on the content servers were issues towards the end of the 2020).
- Checked 2 different dropbox accounts and few different folders - Still Failed
- Upgraded the dropbox account to “professional” – Worked once and then Fails every time since then
- Simulated FW download by python like the sensor does - with the script it works
