Other Parts Discussed in Thread: WL1837
Dear Sir,
We have used the above mentioned WiFi/BT module in the IoT gateway design. The gateway will go for Compliance/certification testing.
During compliance/certification testing, the test enginner need to control the Transmit Power, the Channel no. and also the modulation.
Can you pls. share the AT commands required.
If AT commands are not used, can you pls. let us know the method to control the above mentioned parameters.
Best Regards
SK Mohanty
