I am trying to merge the MQTT client code with Open Box application. I have created separate thread fro mqtt client and initialize mqtt connection after connecting to the AP and getting ip address. I am able to connect to the mqtt broker by running the separate code, But after merging the code MQTT client is not working. Here I have attached my mqtt code file. Main objective of merging this code is to start the mqtt connection after configuring wifi network.
* Copyright (c) 2016, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Application Name - Getting started with OUT_OF_BOX
Application Overview - This application demonstrates the Out of Box
Experience with CC32xx LaunchPad.
It highlights the following features:
1. easy and straight-forward provisioning methods
2. easy access to CC32xx Using internal HTTP server
3. attractive Demos showing LAN communication
Application Details - Refer to 'Out of box' README.html
//! \addtogroup out_of_box
/* Example/Board Header files */
#include "out_of_box.h"
#include "provisioning_task.h"
#include "link_local_task.h"
#include "ota_task.h"
/* TI-DRIVERS Header files */
#include <ti/drivers/net/wifi/simplelink.h>
#include <ti/drivers/SPI.h>
#include <ti_drivers_config.h>
/* driverlib Header files */
#include <ti/devices/cc32xx/inc/hw_types.h>
#include <ti/devices/cc32xx/inc/hw_memmap.h>
#include <ti/devices/cc32xx/driverlib/rom.h>
#include <ti/devices/cc32xx/driverlib/rom_map.h>
#include <ti/devices/cc32xx/driverlib/prcm.h>
/* POSIX Header files */
#include <mqueue.h>
int wifi_flag = 0; // check the wifi connection
//************************************MQTT Files***************************************
#include <unistd.h>
#include <stdint.h>
#include <stddef.h>
#include <stdlib.h>
#include <pthread.h>
/* TI Driver Includes */
#include <ti/drivers/GPIO.h>
/* Application Headers */
//#include "network_if.h"
#include "mqtt_if.h"
#include "debug_if.h"
/* Driver configuration */
#include "ti_drivers_config.h"
#define MQTT_MODULE_TASK_PRIORITY 9
#define MQTT_MODULE_TASK_STACK_SIZE 4096
#define MQTT_WILL_TOPIC "cc32xx_will_topic"
#define MQTT_WILL_MSG "will_msg_works"
#define MQTT_WILL_QOS MQTT_QOS_0
#define MQTT_WILL_RETAIN false
#define MQTT_CLIENT_PASSWORD NULL
#define MQTT_CLIENT_USERNAME NULL
#define MQTT_CLIENT_KEEPALIVE 0
#define MQTT_CLIENT_CLEAN_CONNECT true
#define MQTT_CLIENT_MQTT_V3_1 false
#define MQTT_CLIENT_BLOCKING_SEND true
#define MQTT_CONNECTION_FLAGS MQTTCLIENT_NETCONN_URL | MQTTCLIENT_NETCONN_SEC //|MQTTCLIENT_NETCONN_SKIP_CERTIFICATE_CATALOG_VERIFICATION |MQTTCLIENT_NETCONN_SKIP_DOMAIN_NAME_VERIFICATION //MQTTCLIENT_NETCONN_URL | MQTTCLIENT_NETCONN_SEC // MQTTCLIENT_NETCONN_IP4 | MQTTCLIENT_NETCONN_SEC
#define MQTT_CONNECTION_ADDRESS "test.mosquitto.org"
#define MQTT_CONNECTION_PORT_NUMBER 1883
#define SL_TASKSTACKSIZE 2048
#define SPAWN_TASK_PRIORITY 9
char ClientId[13] = {'piggy'};
MQTT_IF_InitParams_t mqttInitParams =
MQTT_MODULE_TASK_STACK_SIZE, // stack size for mqtt module
MQTT_MODULE_TASK_PRIORITY // thread priority for MQTT
MQTTClient_Will mqttWillParams =
MQTT_WILL_TOPIC, // will topic
MQTT_WILL_MSG, // will message
MQTT_WILL_QOS, // will QoS
MQTT_WILL_RETAIN // retain flag
MQTT_IF_ClientParams_t mqttClientParams =
ClientId, // client ID
MQTT_CLIENT_USERNAME, // user name
MQTT_CLIENT_PASSWORD, // password
MQTT_CLIENT_KEEPALIVE, // keep-alive time
MQTT_CLIENT_CLEAN_CONNECT, // clean connect flag
MQTT_CLIENT_MQTT_V3_1, // true = 3.1, false = 3.1.1
MQTT_CLIENT_BLOCKING_SEND, // blocking send flag
&mqttWillParams // will parameters
MQTTClient_ConnParams mqttConnParams =
MQTT_CONNECTION_FLAGS, // connection flags
MQTT_CONNECTION_ADDRESS, // server address
MQTT_CONNECTION_PORT_NUMBER, // port number of MQTT server
0, // method for secure socket
0, // cipher for secure socket
0, // number of files for secure connection
NULL // secure files
int32_t SetClientIdNamefromMacAddress()
int32_t ret = 0;
uint8_t Client_Mac_Name[2];
uint8_t Index;
uint16_t macAddressLen = SL_MAC_ADDR_LEN;
uint8_t macAddress[SL_MAC_ADDR_LEN];
/*Get the device Mac address */
ret = sl_NetCfgGet(SL_NETCFG_MAC_ADDRESS_GET, 0, &macAddressLen,
&macAddress[0]);
/*When ClientID isn't set, use the mac address as ClientID */
if(ClientId[0] == '\0')
/*6 bytes is the length of the mac address */
for(Index = 0; Index < SL_MAC_ADDR_LEN; Index++)
/*Each mac address byte contains two hexadecimal characters */
/*Copy the 4 MSB - the most significant character */
Client_Mac_Name[0] = (macAddress[Index] >> 4) & 0xf;
/*Copy the 4 LSB - the least significant character */
Client_Mac_Name[1] = macAddress[Index] & 0xf;
if(Client_Mac_Name[0] > 9)
/*Converts and copies from number that is greater than 9 in */
/*hexadecimal representation (a to f) into ascii character */
ClientId[2 * Index] = Client_Mac_Name[0] + 'a' - 10;
else
/*Converts and copies from number 0 - 9 in hexadecimal */
/*representation into ascii character */
ClientId[2 * Index] = Client_Mac_Name[0] + '0';
if(Client_Mac_Name[1] > 9)
ClientId[2 * Index + 1] = Client_Mac_Name[1] + 'a' - 10;
else
ClientId[2 * Index + 1] = Client_Mac_Name[1] + '0';
return(ret);
void MQTT_EventCallback(int32_t event)
switch(event){
case MQTT_EVENT_CONNACK:
LOG_INFO("MQTT_EVENT_CONNACK\r\n");
break;
case MQTT_EVENT_CLIENT_DISCONNECT:
LOG_INFO("MQTT_EVENT_CLIENT_DISCONNECT\r\n");
break;
case MQTT_EVENT_SERVER_DISCONNECT:
LOG_INFO("MQTT_EVENT_SERVER_DISCONNECT\r\n");
break;
case MQTT_EVENT_DESTROY:
LOG_INFO("MQTT_EVENT_DESTROY\r\n");
break;
default:
LOG_INFO("Unknown MQTT event\r\n");
break;
#define SSID_NAME "katahdin"
#define SECURITY_KEY "civicfortunercrvdiscovery"
/* Security type (OPEN or WEP or WPA) */
#define SECURITY_TYPE SL_WLAN_SEC_TYPE_WPA_WPA2
int WifiInit(){
int32_t ret;
SlWlanSecParams_t security_params;
pthread_t spawn_thread = (pthread_t) NULL;
pthread_attr_t pattrs_spawn;
struct sched_param pri_param;
pthread_attr_init(&pattrs_spawn);
pri_param.sched_priority = SPAWN_TASK_PRIORITY;
ret = pthread_attr_setschedparam(&pattrs_spawn, &pri_param);
ret |= pthread_attr_setstacksize(&pattrs_spawn, SL_TASKSTACKSIZE);
ret |= pthread_attr_setdetachstate(&pattrs_spawn, PTHREAD_CREATE_DETACHED);
ret = pthread_create(&spawn_thread, &pattrs_spawn, sl_Task, NULL);
if(ret != 0){
LOG_ERROR("could not create simplelink task\n\r");
while(1);
/* Network_IF_ResetMCUStateMachine();
Network_IF_DeInitDriver();
ret = Network_IF_InitDriver(ROLE_STA);
if(ret < 0){
LOG_ERROR("Failed to start SimpleLink Device\n\r");
while(1);
SetClientIdNamefromMacAddress();
/*security_params.Key = (signed char*)SECURITY_KEY;
security_params.KeyLen = strlen(SECURITY_KEY);
security_params.Type = SECURITY_TYPE;
ret = Network_IF_ConnectAP(SSID_NAME, security_params);
if(ret < 0){
LOG_ERROR("Connection to an AP failed\n\r");
else{
ret = sl_WlanProfileAdd((signed char*)SSID_NAME, strlen(SSID_NAME), 0, &security_params, NULL, 7, 0);
if(ret < 0){
LOG_ERROR("failed to add profile %s\r\n", SSID_NAME);
else{
LOG_INFO("profile added %s\r\n", SSID_NAME);
return ret;
LOCAL FUNCTION PROTOTYPES
//! Application Boarders display on UART
//! \param ch - Character to be displayed , n - number of time to display
//! \return none
void printBorder(char ch,
int n);
//! Application startup display on UART
//! \param none
//! \return none
int32_t DisplayBanner(char * AppName,
char * AppVer);
//! This function initializes the application variables
//! \param None
//! \return None
static void InitializeAppVariables(void);
//! This function clears and enables a GPIO pin interrupt flag
//! \param index - GPIO index
//! \return None
static void GPIO_clearAndEnable(uint8_t index);
GLOBAL VARIABLES
pthread_t gProvisioningThread = (pthread_t)NULL;
pthread_t gLinklocalThread = (pthread_t)NULL;
pthread_t gControlThread = (pthread_t)NULL;
pthread_t gOtaThread = (pthread_t)NULL;
pthread_t gSpawnThread = (pthread_t)NULL;
pthread_t mq_thread = (pthread_t)NULL;
pthread_t aws_thread = (pthread_t)NULL;
/* message queue for control messages */
mqd_t controlMQueue;
OutOfBox_CB OutOfBox_ControlBlock;
Callback Functions
//! The Function Handles WLAN Events
//! \param[in] pWlanEvent - Pointer to WLAN Event Info
//! \return None
void SimpleLinkWlanEventHandler(SlWlanEvent_t *pWlanEvent)
switch(pWlanEvent->Id)
case SL_WLAN_EVENT_CONNECT:
SET_STATUS_BIT(OutOfBox_ControlBlock.status, AppStatusBits_Connection);
CLR_STATUS_BIT(OutOfBox_ControlBlock.status, AppStatusBits_IpAcquired);
AppStatusBits_Ipv6lAcquired);
AppStatusBits_Ipv6gAcquired);
Information about the connected AP (like name, MAC etc) will be
available in 'slWlanConnectAsyncResponse_t'-Applications
can use it if required:
slWlanConnectAsyncResponse_t *pEventData = NULL;
pEventData = &pWlanEvent->EventData.STAandP2PModeWlanConnected;
/* Copy new connection SSID and BSSID to global parameters */
memcpy(OutOfBox_ControlBlock.connectionSSID,
pWlanEvent->Data.Connect.SsidName,
pWlanEvent->Data.Connect.SsidLen);
OutOfBox_ControlBlock.ssidLen = pWlanEvent->Data.Connect.SsidLen;
memcpy(OutOfBox_ControlBlock.connectionBSSID,
pWlanEvent->Data.Connect.Bssid,
SL_WLAN_BSSID_LENGTH);
UART_PRINT(
"[WLAN EVENT] STA Connected to the AP: %s ,"
"BSSID: %x:%x:%x:%x:%x:%x\n\r",
OutOfBox_ControlBlock.connectionBSSID[0],
OutOfBox_ControlBlock.connectionBSSID[1],
OutOfBox_ControlBlock.connectionBSSID[2],
OutOfBox_ControlBlock.connectionBSSID[3],
OutOfBox_ControlBlock.connectionBSSID[4],
OutOfBox_ControlBlock.connectionBSSID[5]);
wifi_flag = 1;
sem_post(&Provisioning_ControlBlock.connectionAsyncEvent);
break;
case SL_WLAN_EVENT_DISCONNECT:
SlWlanEventDisconnect_t* pEventData = NULL;
CLR_STATUS_BIT(OutOfBox_ControlBlock.status, AppStatusBits_Connection);
pEventData = &pWlanEvent->Data.Disconnect;
/* If the user has initiated 'Disconnect' request,
'reason_code' is SL_WLAN_DISCONNECT_USER_INITIATED.
if(SL_WLAN_DISCONNECT_USER_INITIATED == pEventData->ReasonCode)
UART_PRINT(
"[WLAN EVENT]Device disconnected from the "
"AP: %s, BSSID: %x:%x:%x:%x:%x:%x "
"on application's request \n\r",
else
UART_PRINT(
"[WLAN ERROR]Device disconnected from the AP AP: %s,"
"BSSID: %x:%x:%x:%x:%x:%x on an ERROR..!! \n\r",
memset(OutOfBox_ControlBlock.connectionSSID, 0,
sizeof(OutOfBox_ControlBlock.connectionSSID));
memset(OutOfBox_ControlBlock.connectionBSSID, 0,
sizeof(OutOfBox_ControlBlock.connectionBSSID));
break;
case SL_WLAN_EVENT_STA_ADDED:
UART_PRINT(
"[WLAN EVENT] External Station connected to SimpleLink AP\r\n");
UART_PRINT("[WLAN EVENT] STA BSSID: %02x:%02x:%02x:%02x:%02x:%02x\r\n",
pWlanEvent->Data.STAAdded.Mac[0],
pWlanEvent->Data.STAAdded.Mac[1],
pWlanEvent->Data.STAAdded.Mac[2],
pWlanEvent->Data.STAAdded.Mac[3],
pWlanEvent->Data.STAAdded.Mac[4],
pWlanEvent->Data.STAAdded.Mac[5]);
break;
case SL_WLAN_EVENT_STA_REMOVED:
UART_PRINT(
"[WLAN EVENT] External Station disconnected from SimpleLink AP\r\n");
break;
case SL_WLAN_EVENT_PROVISIONING_PROFILE_ADDED:
UART_PRINT("[WLAN EVENT] Profile Added\r\n");
break;
case SL_WLAN_EVENT_PROVISIONING_STATUS:
uint16_t status =
pWlanEvent->Data.ProvisioningStatus.ProvisioningStatus;
switch(status)
case SL_WLAN_PROVISIONING_GENERAL_ERROR:
case SL_WLAN_PROVISIONING_ERROR_ABORT:
UART_PRINT("[WLAN EVENT] Provisioning Error status=%d\r\n",status);
SignalProvisioningEvent(PrvnEvent_Error);
break;
case SL_WLAN_PROVISIONING_ERROR_ABORT_INVALID_PARAM:
case SL_WLAN_PROVISIONING_ERROR_ABORT_HTTP_SERVER_DISABLED:
case SL_WLAN_PROVISIONING_ERROR_ABORT_PROFILE_LIST_FULL:
SignalProvisioningEvent(PrvnEvent_StartFailed);
break;
case SL_WLAN_PROVISIONING_ERROR_ABORT_PROVISIONING_ALREADY_STARTED:
UART_PRINT("[WLAN EVENT] Provisioning already started");
break;
case SL_WLAN_PROVISIONING_CONFIRMATION_STATUS_FAIL_NETWORK_NOT_FOUND:
UART_PRINT("[WLAN EVENT] Confirmation fail: network not found\r\n");
SignalProvisioningEvent(PrvnEvent_ConfirmationFailed);
break;
case SL_WLAN_PROVISIONING_CONFIRMATION_STATUS_FAIL_CONNECTION_FAILED:
UART_PRINT("[WLAN EVENT] Confirmation fail: Connection failed\r\n");
break;
case
SL_WLAN_PROVISIONING_CONFIRMATION_STATUS_CONNECTION_SUCCESS_IP_NOT_ACQUIRED
UART_PRINT(
"[WLAN EVENT] Confirmation fail: IP address not acquired\r\n");
break;
case SL_WLAN_PROVISIONING_CONFIRMATION_STATUS_SUCCESS_FEEDBACK_FAILED:
UART_PRINT(
"[WLAN EVENT] Connection Success "
"(feedback to Smartphone app failed)\r\n");
break;
case SL_WLAN_PROVISIONING_CONFIRMATION_STATUS_SUCCESS:
UART_PRINT("[WLAN EVENT] Confirmation Success!\r\n");
SignalProvisioningEvent(PrvnEvent_ConfirmationSuccess);
break;
case SL_WLAN_PROVISIONING_AUTO_STARTED:
UART_PRINT("[WLAN EVENT] Auto-Provisioning Started\r\n");
/* stop auto provisioning -
may trigger in case of returning to default */
SignalProvisioningEvent(PrvnEvent_Stopped);
break;
case SL_WLAN_PROVISIONING_STOPPED:
UART_PRINT("[WLAN EVENT] Provisioning stopped\r\n");
if(ROLE_STA == pWlanEvent->Data.ProvisioningStatus.Role)
UART_PRINT(" [WLAN EVENT] - WLAN Connection Status:%d\r\n",
pWlanEvent->Data.ProvisioningStatus.WlanStatus);
if(SL_WLAN_STATUS_CONNECTED ==
UART_PRINT(" [WLAN EVENT] - Connected to SSID:%s\r\n",
pWlanEvent->Data.ProvisioningStatus.Ssid);
memcpy (OutOfBox_ControlBlock.connectionSSID,
pWlanEvent->Data.ProvisioningStatus.Ssid,
pWlanEvent->Data.ProvisioningStatus.Ssidlen);
pWlanEvent->Data.ProvisioningStatus.Ssidlen;
/* Provisioning is stopped by the device and
provisioning is done successfully */
break;
else
/* Provisioning is stopped by the device and provisioning
is not done yet, still need to connect to AP */
SignalProvisioningEvent(PrvnEvent_WaitForConn);
break;
break;
case SL_WLAN_PROVISIONING_SMART_CONFIG_SYNCED:
UART_PRINT("[WLAN EVENT] Smart Config Synced!\r\n");
break;
case SL_WLAN_PROVISIONING_CONFIRMATION_WLAN_CONNECT:
UART_PRINT("[WLAN EVENT] Connection to AP succeeded\r\n");
break;
case SL_WLAN_PROVISIONING_CONFIRMATION_IP_ACQUIRED:
UART_PRINT("[WLAN EVENT] IP address acquired\r\n");
wifi_flag = 1;
break;
case SL_WLAN_PROVISIONING_SMART_CONFIG_SYNC_TIMEOUT:
UART_PRINT("[WLAN EVENT] Smart Config Sync timeout\r\n");
break;
default:
UART_PRINT("[WLAN EVENT] Unknown Provisioning Status: %d\r\n",
pWlanEvent->Data.ProvisioningStatus.ProvisioningStatus);
break;
break;
default:
UART_PRINT("[WLAN EVENT] Unexpected event [0x%x]\n\r",
pWlanEvent->Id);
break;
//! The Function Handles the Fatal errors
//! \param[in] slFatalErrorEvent - Pointer to Fatal Error Event info
//! \return None
void SimpleLinkFatalErrorEventHandler(SlDeviceFatal_t *slFatalErrorEvent)
uint8_t msg = 4;
int32_t msgqRetVal;
switch(slFatalErrorEvent->Id)
case SL_DEVICE_EVENT_FATAL_DEVICE_ABORT:
UART_PRINT("[ERROR] - FATAL ERROR: Abort NWP event detected: "
"AbortType=%d, AbortData=0x%x\n\r",
slFatalErrorEvent->Data.DeviceAssert.Code,
slFatalErrorEvent->Data.DeviceAssert.Value);
break;
case SL_DEVICE_EVENT_FATAL_DRIVER_ABORT:
UART_PRINT("[ERROR] - FATAL ERROR: Driver Abort detected. \n\r");
break;
case SL_DEVICE_EVENT_FATAL_NO_CMD_ACK:
UART_PRINT("[ERROR] - FATAL ERROR: No Cmd Ack detected "
"[cmd opcode = 0x%x] \n\r",
slFatalErrorEvent->Data.NoCmdAck.Code);
break;
case SL_DEVICE_EVENT_FATAL_SYNC_LOSS:
UART_PRINT("[ERROR] - FATAL ERROR: Sync loss detected n\r");
break;
case SL_DEVICE_EVENT_FATAL_CMD_TIMEOUT:
UART_PRINT("[ERROR] - FATAL ERROR: Async event timeout detected "
"[event opcode =0x%x] \n\r",
slFatalErrorEvent->Data.CmdTimeout.Code);
break;
default:
UART_PRINT("[ERROR] - FATAL ERROR: Unspecified error detected \n\r");
break;
msgqRetVal = mq_send(controlMQueue, (char *)&msg, 1, 0);
if(msgqRetVal < 0)
UART_PRINT("[Control task] could not send element to msg queue\n\r");
while(1)
//! This function handles network events such as IP acquisition, IP
//! leased, IP released etc.
//! \param[in] pNetAppEvent - Pointer to NetApp Event Info
//! \return None
void SimpleLinkNetAppEventHandler(SlNetAppEvent_t *pNetAppEvent)
SlNetAppEventData_u *pNetAppEventData = NULL;
if(NULL == pNetAppEvent)
return;
pNetAppEventData = &pNetAppEvent->Data;
switch(pNetAppEvent->Id)
case SL_NETAPP_EVENT_IPV4_ACQUIRED:
SlIpV4AcquiredAsync_t *pEventData = NULL;
SET_STATUS_BIT(OutOfBox_ControlBlock.status, AppStatusBits_IpAcquired);
/* Ip Acquired Event Data */
pEventData = &pNetAppEvent->Data.IpAcquiredV4;
/* Gateway IP address */
OutOfBox_ControlBlock.gatewayIP = pEventData->Gateway;
UART_PRINT("[NETAPP EVENT] IP Acquired: IP=%d.%d.%d.%d , "
"Gateway=%d.%d.%d.%d\n\r",
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Ip,3),
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Ip,2),
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Ip,1),
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Ip,0),
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Gateway,3),
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Gateway,2),
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Gateway,1),
SL_IPV4_BYTE(pNetAppEvent->Data.IpAcquiredV4.Gateway,0));
break;
case SL_NETAPP_EVENT_IPV6_ACQUIRED:
if(!GET_STATUS_BIT(OutOfBox_ControlBlock.status,
AppStatusBits_Ipv6lAcquired))
UART_PRINT("[NETAPP EVENT] Local IPv6 Acquired\n\r");
else
UART_PRINT("[NETAPP EVENT] Global IPv6 Acquired\n\r");
break;
case SL_NETAPP_EVENT_DHCPV4_LEASED:
SET_STATUS_BIT(OutOfBox_ControlBlock.status, AppStatusBits_IpLeased);
UART_PRINT(
"[NETAPP EVENT] IPv4 leased %d.%d.%d.%d for "
"device %02x:%02x:%02x:%02x:%02x:%02x\n\r", \
(uint8_t)SL_IPV4_BYTE(pNetAppEventData->IpLeased.IpAddress,3), \
(uint8_t)SL_IPV4_BYTE(pNetAppEventData->IpLeased.IpAddress,2), \
(uint8_t)SL_IPV4_BYTE(pNetAppEventData->IpLeased.IpAddress,1), \
(uint8_t)SL_IPV4_BYTE(pNetAppEventData->IpLeased.IpAddress,0), \
pNetAppEventData->IpLeased.Mac[0], \
pNetAppEventData->IpLeased.Mac[1], \
pNetAppEventData->IpLeased.Mac[2], \
pNetAppEventData->IpLeased.Mac[3], \
pNetAppEventData->IpLeased.Mac[4], \
pNetAppEventData->IpLeased.Mac[5]);
break;
case SL_NETAPP_EVENT_DHCPV4_RELEASED:
CLR_STATUS_BIT(OutOfBox_ControlBlock.status, AppStatusBits_IpLeased);
UART_PRINT(
"[NETAPP EVENT] IPv4 released %d.%d.%d.%d for "
(uint8_t)SL_IPV4_BYTE(pNetAppEventData->IpReleased.IpAddress,
3), \
2), \
1), \
0), \
pNetAppEventData->IpReleased.Mac[0], \
pNetAppEventData->IpReleased.Mac[1], \
pNetAppEventData->IpReleased.Mac[2], \
pNetAppEventData->IpReleased.Mac[3], \
pNetAppEventData->IpReleased.Mac[4], \
pNetAppEventData->IpReleased.Mac[5]);
UART_PRINT("Reason: ");
switch(pNetAppEventData->IpReleased.Reason)
case SL_IP_LEASE_PEER_RELEASE: UART_PRINT("Peer released\n\r");
break;
case SL_IP_LEASE_PEER_DECLINE: UART_PRINT("Peer declined\n\r");
break;
case SL_IP_LEASE_EXPIRED: UART_PRINT("Lease expired\n\r");
break;
break;
case SL_NETAPP_EVENT_DHCP_IPV4_ACQUIRE_TIMEOUT:
UART_PRINT("[NETAPP EVENT] DHCP IPv4 Acquire timeout\n\r");
break;
default:
UART_PRINT("[NETAPP EVENT] Unexpected event [0x%x] \n\r",
pNetAppEvent->Id);
break;
//! This function handles HTTP server events
//! \param[in] pServerEvent - Contains the relevant event information
//! \param[in] pServerResponse - Should be filled by the user with the
//! relevant response information
//! \return None
void SimpleLinkHttpServerEventHandler(SlNetAppHttpServerEvent_t *pHttpEvent,
SlNetAppHttpServerResponse_t *
pHttpResponse)
/* Unused in this application */
UART_PRINT("[HTTP SERVER EVENT] Unexpected HTTP server event \n\r");
//! This function handles General Events
//! \param[in] pDevEvent - Pointer to General Event Info
//! \return None
void SimpleLinkGeneralEventHandler(SlDeviceEvent_t *pDevEvent)
uint8_t msg = 4;
int32_t msgqRetVal;
Most of the general errors are not FATAL are are to be handled
appropriately by the application.
if(NULL == pDevEvent)
return;
switch(pDevEvent->Id)
case SL_DEVICE_EVENT_RESET_REQUEST:
UART_PRINT("[GENERAL EVENT] Reset Request Event\r\n");
break;
default:
UART_PRINT("[GENERAL EVENT] - ID=[%d] Sender=[%d]\n\n",
pDevEvent->Data.Error.Code,
pDevEvent->Data.Error.Source);
if(msgqRetVal < 0)
while(1)
break;
//! This function handles socket events indication
//! \param[in] pSock - Pointer to Socket Event Info
//! \return None
void SimpleLinkSockEventHandler(SlSockEvent_t *pSock)
if(SL_SOCKET_ASYNC_EVENT == pSock->Event)
UART_PRINT("[SOCK ERROR] an event received on socket %d\r\n",
pSock->SocketAsyncEvent.SockAsyncData.Sd);
switch(pSock->SocketAsyncEvent.SockAsyncData.Type)
case SL_SSL_NOTIFICATION_CONNECTED_SECURED:
UART_PRINT("[SOCK ERROR] SSL handshake done");
break;
case SL_SSL_NOTIFICATION_HANDSHAKE_FAILED:
UART_PRINT("[SOCK ERROR] SSL handshake failed with error %d\r\n",
pSock->SocketAsyncEvent.SockAsyncData.Val);
break;
case SL_SSL_ACCEPT:
UART_PRINT(
"[SOCK ERROR] Recoverable error occurred "
"during the handshake %d\r\n",
break;
case SL_OTHER_SIDE_CLOSE_SSL_DATA_NOT_ENCRYPTED:
UART_PRINT("[SOCK ERROR] Other peer terminated the SSL layer.\r\n");
break;
case SL_SSL_NOTIFICATION_WRONG_ROOT_CA:
UART_PRINT("[SOCK ERROR] Used wrong CA to verify the peer.\r\n");
break;
default:
break;
/* This application doesn't work w/ socket - Events are not expected */
switch(pSock->Event)
case SL_SOCKET_TX_FAILED_EVENT:
switch(pSock->SocketAsyncEvent.SockTxFailData.Status)
case SL_ERROR_BSD_ECLOSE:
UART_PRINT("[SOCK ERROR] - close socket (%d) operation "
"failed to transmit all queued packets\n\r",
pSock->SocketAsyncEvent.SockTxFailData.Sd);
break;
default:
UART_PRINT("[SOCK ERROR] - TX FAILED : socket %d , "
"reason (%d) \n\n",
pSock->SocketAsyncEvent.SockTxFailData.Sd,
pSock->SocketAsyncEvent.SockTxFailData.Status);
break;
break;
default:
UART_PRINT("[SOCK EVENT] - Unexpected Event [%x0x]\n\n",pSock->Event);
break;
void SimpleLinkNetAppRequestMemFreeEventHandler(uint8_t *buffer)
//! \brief Push Button Handler1(GPIOSW2).
//! Press push button2 whenever user wants to
//! switch to AP mode. Write message into message queue indicating
//! switching to AP mode.
//! \param[in] none
//! return none
void pushButtonInterruptHandler2(uint_least8_t index)
int32_t msgqRetVal;
struct timespec ts;
/* Disable the SW2 interrupt */
GPIO_disableInt(CONFIG_GPIO_BUTTON_0); // SW2
/* see ControlMessageType. msg=2 applies to ControlMessageType_Switch2 */
uint8_t msg = 2;
/* timeout is 0 to send the message immediatelly */
ts.tv_sec = 0;
ts.tv_nsec = 0;
msgqRetVal = mq_timedsend(controlMQueue, (char *)&msg, 1, 0, &ts);
if(msgqRetVal < 0)
while(1)
Local Functions
//! \return none
int n)
int i = 0;
for(i = 0; i < n; i++)
putch(ch);
//! \param none
//! \return none
char * AppVer)
int32_t ret = 0;
uint16_t ConfigSize = 0;
uint8_t ConfigOpt = SL_DEVICE_GENERAL_VERSION;
SlDeviceVersion_t ver = {0};
char lineBreak[] = "\n\r";
ConfigSize = sizeof(SlDeviceVersion_t);
/* Print device version info. */
ret =
sl_DeviceGet(SL_DEVICE_GENERAL, &ConfigOpt, &ConfigSize,
(uint8_t*)(&ver));
ASSERT_ON_ERROR(ret);
/* Print device Mac address */
&macAddress[0]);
UART_PRINT(lineBreak);
UART_PRINT("\t");
printBorder('=', 44);
UART_PRINT("\t %s Example Ver: %s",AppName, AppVer);
UART_PRINT("\t");
UART_PRINT("\t CHIP: 0x%x",ver.ChipId);
UART_PRINT("\t MAC: %d.%d.%d.%d",ver.FwVersion[0],ver.FwVersion[1],
ver.FwVersion[2],
ver.FwVersion[3]);
UART_PRINT("\t PHY: %d.%d.%d.%d",ver.PhyVersion[0],ver.PhyVersion[1],
ver.PhyVersion[2],
ver.PhyVersion[3]);
UART_PRINT("\t NWP: %d.%d.%d.%d",ver.NwpVersion[0],ver.NwpVersion[1],
ver.NwpVersion[2],
ver.NwpVersion[3]);
UART_PRINT("\t ROM: %d",ver.RomVersion);
UART_PRINT("\t HOST: %s", SL_DRIVER_VERSION);
UART_PRINT("\t MAC address: %02x:%02x:%02x:%02x:%02x:%02x", macAddress[0],
macAddress[1], macAddress[2], macAddress[3], macAddress[4],
macAddress[5]);
UART_PRINT("\t");
return(ret);
//! \return None
GPIO_clearInt(index);
GPIO_enableInt(index);
//! \param None
//! \return None
OutOfBox_ControlBlock.gatewayIP = 0;
OutOfBox_ControlBlock.status = 0;
Main Functions
//! \brief control task. Create switches handlers and waits for
//! invokations on those switches.
//! Additinally, activate watchdog timer to validate the application code
//! \param[in] None
//! \return None
void * controlTask(void *pvParameters)
ControlMessageType queueMsg;
int32_t retVal;
uint32_t ocpRegVal;
mq_attr attr;
struct timespec ts;
/* initializes mailbox for http messages */
attr.mq_maxmsg = 10; // queue size
attr.mq_msgsize = sizeof(ControlMessageType); // Size of message
controlMQueue = mq_open("control msg q", O_CREAT, 0, &attr);
if(((int)controlMQueue) <= 0)
UART_PRINT("[Control task] could not create msg queue\n\r");
while(1)
/* enable interrupt for the GPIO 22 (email trigger) */
GPIO_setCallback(CONFIG_GPIO_BUTTON_0, pushButtonInterruptHandler2);
GPIO_enableInt(CONFIG_GPIO_BUTTON_0);
while(1)
queueMsg = ControlMessageType_ControlMessagesMax;
clock_gettime(CLOCK_REALTIME, &ts);
ts.tv_sec += 2;
retVal =
mq_timedreceive(controlMQueue, (char *)&queueMsg,
sizeof(ControlMessageType),
NULL,
&ts);
switch(queueMsg)
case ControlMessageType_ControlMessagesMax:
break;
case ControlMessageType_Switch2:
UART_PRINT("[Control task] switching to AP mode\n\r");
/* SW2 is used to revert to AP mode and stop provisioning
(if running) so device can be connected and controlled adhoc */
retVal = provisioningStop();
// intermmediate phase, need to push AP switch again
if(retVal == SL_RET_CODE_DEV_NOT_STARTED)
UART_PRINT(
"[Control task] device is not started yet, please press SW2 "
"button again\n\r");
/* Clear and enable again the SW2 interrupt */
GPIO_clearAndEnable(CONFIG_GPIO_BUTTON_0);
break;
// should not happen
if((retVal == SL_RET_CODE_DEV_LOCKED) || (retVal == SL_API_ABORTED))
UART_PRINT(
"[Control task] device cannot start in AP mode, please "
"reset the board\n\r");
break;
/* set AP mode regardless of the current mode */
retVal = sl_WlanSetMode(ROLE_AP);
/* Check if switching to AP command is successful */
if(retVal == 0)
UART_PRINT(
"[Control task] device started in AP role, rebooting "
"device...\n\r");
/* indicate AP role on OCP register */
ocpRegVal = MAP_PRCMOCRRegisterRead(OCP_REGISTER_INDEX);
ocpRegVal |= (1 << OCP_REGISTER_OFFSET);
MAP_PRCMOCRRegisterWrite(OCP_REGISTER_INDEX, ocpRegVal);
mcuReboot();
else
UART_PRINT("[Control task] device not started in AP role\n\r");
break;
case ControlMessageType_ResetRequired:
UART_PRINT("[Control task] platform reboot is required\n\r");
mcuReboot();
break;
default:
break;
//! \brief This function reboot the M4 host processor
//! \param[in] none
//! \return none
void mcuReboot(void)
/* stop network processor activities before reseting the MCU */
sl_Stop(SL_STOP_TIMEOUT);
UART_PRINT("[Common] CC32xx MCU reset request\r\n");
/* Reset the MCU in order to test the bundle */
PRCMHibernateCycleTrigger();
void *mqtt_data(void *arg0){
while(1){
UART_PRINT("mqtt\n");
// LOG_INFO("MQTT_EVENT_CONNACK\r\n");
sleep(5);
void *aws_data(void *arg0){
while(wifi_flag != 1){
UART_PRINT("WiFi Connecting\n");
sleep(3);
sleep(10);
int32_t ret;
// UART_Handle uartHandle;
MQTTClient_Handle mqttClientHandle;
// uartHandle = InitTerm();
// UART_control(uartHandle, UART_CMD_RXDISABLE, NULL);
ret = ti_net_SlNet_initConfig();
if(0 != ret)
UART_PRINT("Failed to initialize SlNetSock\n\r");
ret = WifiInit();
if(ret < 0){
while(1);
UART_PRINT("mqtt Connecting\n");
ret = MQTT_IF_Init(mqttInitParams);
if(ret < 0){
while(1);
UART_PRINT("mqtt Connected\n");
mqttClientHandle = MQTT_IF_Connect(mqttClientParams, mqttConnParams, MQTT_EventCallback);
if(mqttClientHandle < 0){
UART_PRINT("mqtt not Connected\n");
while(1);
while(1){
UART_PRINT("aws\n");
MQTT_IF_Publish(mqttClientHandle,
"MQTTDemo",
"hello from TI\r\n",
strlen("hello from TI\r\n"),
MQTT_QOS_0);
sleep(5);
void * mainThread(void *arg)
int32_t RetVal;
pthread_attr_t pAttrs;
pthread_attr_t pAttrs_spawn;
pthread_attr_t mq_pAttrs;
struct sched_param priParam;
struct timespec ts = {0};
GPIO_init();
SPI_init();
// I2C_init();
/* init Terminal, and print App name */
InitTerm();
/* initialize the realtime clock */
clock_settime(CLOCK_REALTIME, &ts);
InitializeAppVariables();
/* Switch off all LEDs on boards */
GPIO_write(CONFIG_GPIO_LED_0, CONFIG_GPIO_LED_OFF);
/* initializes signals for all tasks */
sem_init(&Provisioning_ControlBlock.connectionAsyncEvent, 0, 0);
sem_init(&Provisioning_ControlBlock.provisioningDoneSignal, 0, 0);
sem_init(&Provisioning_ControlBlock.provisioningConnDoneToOtaServerSignal,
0,
0);
sem_init(&LinkLocal_ControlBlock.otaReportServerStartSignal, 0, 0);
sem_init(&LinkLocal_ControlBlock.otaReportServerStopSignal, 0, 0);
/* create the sl_Task */
pthread_attr_init(&pAttrs_spawn);
priParam.sched_priority = SPAWN_TASK_PRIORITY;
RetVal = pthread_attr_setschedparam(&pAttrs_spawn, &priParam);
RetVal |= pthread_attr_setstacksize(&pAttrs_spawn, TASK_STACK_SIZE);
RetVal = pthread_create(&gSpawnThread, &pAttrs_spawn, sl_Task, NULL);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to create sl_Task thread \n");
while(1)
RetVal = sl_Start(0, 0, 0);
if(RetVal >= 0)
DisplayBanner(APPLICATION_NAME, APPLICATION_VERSION);
RetVal = sl_Stop(SL_STOP_TIMEOUT);
if(RetVal < 0)
/* Handle Error */
UART_PRINT("\n sl_Stop failed\n");
while(1)
else if((RetVal < 0) && (RetVal != SL_ERROR_RESTORE_IMAGE_COMPLETE))
/* Handle Error */
UART_PRINT("\n sl_Start failed\n");
UART_PRINT("\n %s Example Ver. %s\n",APPLICATION_NAME,
while(1)
pthread_attr_init(&pAttrs);
priParam.sched_priority = 1;
RetVal = pthread_attr_setschedparam(&pAttrs, &priParam);
RetVal |= pthread_attr_setstacksize(&pAttrs, TASK_STACK_SIZE);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to configure provisioningTask thread parameters \n");
while(1)
RetVal = pthread_create(&gProvisioningThread, &pAttrs, provisioningTask,
NULL);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to create provisioningTask thread \n");
while(1)
pthread_attr_init(&mq_pAttrs);
RetVal = pthread_attr_setschedparam(&mq_pAttrs, &priParam);
RetVal |= pthread_attr_setstacksize(&mq_pAttrs, TASK_STACK_SIZE);
// uart thread to read data from STM32
pthread_create(&mq_thread, &mq_pAttrs, mqtt_data, NULL);
pthread_attr_t aws_pAttrs;
// struct sched_param priParam;
pthread_attr_init(&aws_pAttrs);
pthread_attr_setschedparam(&aws_pAttrs, &priParam);
pthread_attr_setstacksize(&aws_pAttrs, 4096);
pthread_create(&aws_thread, &aws_pAttrs, aws_data, NULL);
// pthread_attr_t aws_pAttrs;
// pthread_attr_init(&aws_pAttrs);
// pthread_create(&aws_thread, &aws_pAttrs, aws_data, NULL);
RetVal |= pthread_attr_setstacksize(&pAttrs, LINKLOCAL_STACK_SIZE);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to configure linkLocalTask thread parameters \n");
while(1)
RetVal = pthread_create(&gLinklocalThread, &pAttrs, linkLocalTask, NULL);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to create linkLocalTask thread \n");
while(1)
#if 0
RetVal |= pthread_attr_setstacksize(&pAttrs, CONTROL_STACK_SIZE);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to configure controlTask thread parameters \n");
while(1)
RetVal = pthread_create(&gControlThread, &pAttrs, controlTask, NULL);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to create controlTask thread \n");
while(1)
priParam.sched_priority = 5;
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to configure otaTask thread parameters \n");
while(1)
RetVal = pthread_create(&gOtaThread, &pAttrs, otaTask, NULL);
if(RetVal)
/* Handle Error */
UART_PRINT("Unable to create otaTask thread \n");
while(1)
#endif
return(0);
