Part Number: CC2652R
Tool/software: Linux
Hi Team,
How to run ZIGBEE-LINUX-SENSOR-TO-CLOUD_1.0.0 on ubuntu 16.04 x64 bit?
How to modify ZIGBEE-LINUX-SENSOR-TO-CLOUD_1.0.0?
Hi Team,
Hi YiKai,
yes, It can run on x86 platform. Due to my Ubuntu software environment, it run setup.sh produce some error.
Thanks for reply . I will download a new Ubuntu 16.04 x64 or Ubuntu 18.04. Did you update Protobuf?
My built binary will appear "NPL_Lnx_x86_Server is missing " and "ZLSZNP_X86 is missing". Do your built binary work well?
I suppose you can change ""mqtt": "~1.0.10"," to ""mqtt": "1.13.0"," in package.json under /source/Projects/node/node_zb_gateway to fix your issue.
Hi YK,
Now it compiler well. Do node mqtt version cause this issue?
Merry Christmas
Alvin Chen I find if I connect LAUNCHXL-CC26x2R1 to test ZIGBEE-LINUX-SENSOR-TO-CLOUD_1.0.0 on my Ubuntu VM. I always see the following error. Do you see the same problem?
[13:17:33.754,768] [NWK_MGR/MAIN] UNMSKBL:
[13:17:33.758,759] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[13:17:33.759,054] [NWK_MGR/MAIN] UNMSKBL: * Network Manager Server v1.0.2d *
[13:17:33.759,328] [NWK_MGR/MAIN] UNMSKBL: ************************************************
[13:17:33.759,653] [NWK_MGR/MAIN] UNMSKBL:
[13:17:35.734,912] [Z_STACK/MAIN] ERROR : SRSP Cond Wait timed out!
[13:17:35.734,929] [Z_STACK/MAIN] ERROR : apicSendSynchData() failed getting response
[13:17:35.761,017] [NWK_MGR/MAIN] ERROR : SRSP Cond Wait timed out!
[13:17:35.761,068] [NWK_MGR/MAIN] ERROR : apicSendSynchData() failed getting response
[13:17:35.761,251] [NWK_MGR/MAIN] ERROR : Reading Local Network Information Failed
[13:17:35.761,267] [NWK_MGR/MAIN] UNMSKBL: Initialization failed. Quitting now.
Startup phase 3 failed
Yes, I use "sudo ./start_local.sh" command. The followings are my build log:
yk@yk-VirtualBox:~/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source$ sudo ./setup.sh
******************* BEGIN SETUP! ********************
This setup script will:
- make all necessary scripts executable
- ensure necessary files have UNIX line endings
- remove prebuilt directories
- install Node Modules for Node.js Zigbee Gateway
- build Linux Zigbee Gateway
- extract Linux Zigbee Gateway binaries
Entered /Projets/node Directory
Make the gateway scripts executable
SUCCESS - gateway scripts executable
/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source
Remove ERROR__out or out Directory if present
Removed Previous built package.
Convert all files from dos2unix
SUCCESS: Converted Scripts to Unix Line endings
Entered /Projets/node/nodejs_zb_gateway Directory
Installing Node Modules
- nan@1.4.3 node_modules/mqtt/node_modules/nan
- through2@0.6.5 node_modules/mqtt/node_modules/through2
- ws@0.7.2 node_modules/mqtt/node_modules/websocket-stream/node_modules/ws
nodejs_zb_gateway@1.0.0 /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway
└─┬ mqtt@1.13.0
└─┬ websocket-stream@3.3.3
└── ws@1.1.5
npm WARN nodejs_zb_gateway@1.0.0 No repository field.
SUCCESS: Installed all Node Modules Successfully
Make build_all executable
SUCCESS: build_all script is now executable
Make scripts/ executable
SUCCESS: scripts/ folder is now executable
Run ./build_all
./package_builder: line 22: svnversion: command not found
SVN Version =
Main project\'s base directory: GATEWAY=/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source (leave blank to use the detault)
Project output subdirectory: PKGS_OUTPUT_DIR=/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/out (leave blank to use the detault)
Building RUNTIME package for x86 platform
Cleaning all
if test -d out; then rm -rf out; fi
rm -f project_file_list.txt
Check existance of output folder
if test ! -d out; then mkdir out; fi
COMPILING NPI SERVER FOR x86
make[1]: Entering directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost'
Compiling ipclib/server/npi_lnx_ipc.c ...
Compiling ipclib/server/npi_lnx_uart.c ...
Compiling ipclib/server/npi_lnx_spi.c ...
Compiling ipclib/server/npi_lnx_i2c.c ...
Compiling ipclib/server/hal_gpio.c ...
Compiling ipclib/server/hal_i2c.c ...
Compiling ../../../../srvwrapper/trace.c ...
Compiling ipclib/server/hal_spi.c ...
Compiling ../../../../srvwrapper/configparser.c ...
Building target out/NPI_lnx_x86_server ...
make[1]: Leaving directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/RemoTI-Linux-master/Projects/tools/LinuxHost'
Cleaning up osal_zstack_server_znp.o ../source/zmain.o znp_af.o znp_misc.o znp_zdo.o ../zstackpb/zstack.pb-c.o ../zstackpb/zstackpb.o ../srvwrapper/api_client.o ../srvwrapper/trace.o ../srvwrapper/main.o ../srvwrapper/api_server.o ../srvwrapper/configparser.o ../linux_osal/common/OSAL_Memory.o ../linux_osal/common/OSAL_PwrMgr.o ../linux_osal/common/OSAL_Timers.o ../linux_osal/common/OSAL.o ../../../../Components/services/saddr/saddr.o ../source/OnBoard.o ../hal/hal_timer.o ../source/pb_utils.o ../zstackserverznp/zstack_pb_ctrl.o out/*
Building ZLSZNP_x86
Compiler: gcc
Targer platform: x86
Compiling osal_zstack_server_znp.c
Compiling ../source/zmain.c
Compiling znp_af.c
znp_af.c: In function ‘sendGpSecRsp’:
znp_af.c:525:14: warning: variable ‘status’ set but not used [-Wunused-but-set-variable]
afStatus_t status;
Compiling znp_misc.c
znp_misc.c: In function ‘processAFIncomingMsgInd’:
znp_misc.c:706:18: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
leftover = (uint32)pPtr % 4;
Compiling znp_zdo.c
Compiling ../zstackpb/zstack.pb-c.c
Compiling ../zstackpb/zstackpb.c
Compiling ../srvwrapper/api_client.c
../srvwrapper/api_client.c: In function ‘SISreadThreadFunc’:
../srvwrapper/api_client.c:1149:17: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
(unsigned int)pMsg,
../srvwrapper/api_client.c:1153:17: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
(unsigned int)pMsg );
../srvwrapper/api_client.c: In function ‘SIShandleThreadFunc’:
../srvwrapper/api_client.c:1283:11: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
(unsigned int)searchList );
../srvwrapper/api_client.c:1300:11: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
../srvwrapper/api_client.c:1306:11: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
(unsigned int) searchList,
../srvwrapper/api_client.c: In function ‘asynchMsgCback’:
../srvwrapper/api_client.c:1365:11: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
(unsigned int)(pMsg + 1) );
Compiling ../srvwrapper/trace.c
Compiling ../srvwrapper/main.c
Compiling ../srvwrapper/api_server.c
Compiling ../srvwrapper/configparser.c
Compiling ../linux_osal/common/OSAL_Memory.c
Compiling ../linux_osal/common/OSAL_PwrMgr.c
Compiling ../linux_osal/common/OSAL_Timers.c
../linux_osal/common/OSAL_Timers.c: In function ‘osal_start_timerEx’:
../linux_osal/common/OSAL_Timers.c:278:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
halIntState_t intState;
../linux_osal/common/OSAL_Timers.c: In function ‘osal_start_reload_timer’:
../linux_osal/common/OSAL_Timers.c:344:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL_Timers.c: In function ‘osal_stop_timerEx’:
../linux_osal/common/OSAL_Timers.c:412:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL_Timers.c: In function ‘osal_timer_num_active’:
../linux_osal/common/OSAL_Timers.c:456:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
Compiling ../linux_osal/common/OSAL.c
../linux_osal/common/OSAL.c: In function ‘osal_msg_receive’:
../linux_osal/common/OSAL.c:515:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_msg_find’:
../linux_osal/common/OSAL.c:592:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_msg_enqueue’:
../linux_osal/common/OSAL.c:630:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_msg_dequeue’:
../linux_osal/common/OSAL.c:670:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_msg_push’:
../linux_osal/common/OSAL.c:705:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_msg_extract’:
../linux_osal/common/OSAL.c:734:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_msg_enqueue_max’:
../linux_osal/common/OSAL.c:774:17: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_set_event’:
../linux_osal/common/OSAL.c:827:19: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_clear_event’:
../linux_osal/common/OSAL.c:860:19: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
../linux_osal/common/OSAL.c: In function ‘osal_run_system’:
../linux_osal/common/OSAL.c:1040:19: warning: variable ‘intState’ set but not used [-Wunused-but-set-variable]
Compiling ../../../../Components/services/saddr/saddr.c
Compiling ../source/OnBoard.c
Compiling ../hal/hal_timer.c
Compiling ../source/pb_utils.c
../source/pb_utils.c: In function ‘print_unpacked_pb_msg’:
../source/pb_utils.c:207:21: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
sub_message = (uint8_t *)LITTLE_ENDIAN_STREAM_TO_UINT32(pBuf);
../source/pb_utils.c:227:24: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
binary_data_ptr = (uint8_t *)LITTLE_ENDIAN_STREAM_TO_UINT32(pBuf);
In file included from ../source/pb_utils.h:46:0,
from ../source/pb_utils.c:48:
../source/pb_utils.c: In function ‘print_pb_msg’:
../source/pb_utils.c:394:27: warning: format ‘%X’ expects argument of type ‘unsigned int’, but argument 4 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
STRING_ADD(hex_line, "%02X:%02X:%02X:%02X", len & 0xFF, (len >> 8) & 0xFF, _subsystemId, commandId);
../../../../Projects/zstack/linux/srvwrapper/trace.h:159:95: note: in definition of macro ‘STRING_ADD’
#define STRING_ADD(str, format, ...) snprintf((str) + strlen(str), sizeof(str) - strlen(str), format, ##__VA_ARGS__)
../source/pb_utils.c:394:27: warning: format ‘%X’ expects argument of type ‘unsigned int’, but argument 5 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
../source/pb_utils.c:398:27: warning: format ‘%X’ expects argument of type ‘unsigned int’, but argument 4 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
STRING_ADD(hex_line, "%02X:%02X:%02X", len, _subsystemId, commandId);
../../../../Projects/zstack/linux/srvwrapper/trace.h:77:16: warning: format ‘%d’ expects argument of type ‘int’, but argument 6 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
#define RED "\x1B[31m"
../source/pb_utils.c:430:38: note: in expansion of macro ‘RED’
STRING_ADD(description_string, RED " failed unpacking: subsystemId=%d, commandId=%d, len=%d", subsystemId, commandId, len);
../source/pb_utils.c:430:97: note: format string is defined here
%ld
Compiling ../zstackserverznp/zstack_pb_ctrl.c
Linking ZLSZNP_x86
Cleaning all
/bin/rm -f project_file_list.txt
/bin/rm -f actual_standard_project_file_list.txt
/bin/rm -f actual_specific_project_file_list.txt
COMPILING APP FOR x86
make[1]: Entering directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/nwkmgr'
Compiling ../srvepconfig/serverep.c ...
Compiling nwkmgrsrv.c ...
Compiling nwkmgrdatabase.c ...
Compiling ../srvwrapper/trace.c ...
Compiling ../sdb/SimpleDB.c ...
Compiling ../sdb/SimpleDBTxt.c ...
Compiling nwkmgrservices.c ...
Compiling nwkmgrp2p.c ...
Compiling nwkmgr.pb-c.c ...
Compiling ../zstackpb/zstack.pb-c.c ...
Compiling ../serverpb/server.pb-c.c ...
Compiling ../srvwrapper/api_client.c ...
(unsigned int)pMsg,
Compiling ../srvwrapper/main.c ...
Compiling ../srvwrapper/api_server.c ...
Compiling ../srvwrapper/configparser.c ...
Compiling ../source/pb_utils.c ...
%ld
Compiling ../zstackserverznp/zstack_pb_ctrl.c ...
Compiling ../nwkmgr/nwkmgr_pb_ctrl.c ...
Compiling ../serverpb/server_pb_ctrl.c ...
Building target out/NWKMGR_SRVR_x86 ...
make[1]: Leaving directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/nwkmgr'
Cleaning all
make[1]: Entering directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/hagateway'
Compiling gatewaysrvr.c ...
gatewaysrvr.c: In function ‘processGwGetDeviceAttributeListReq’:
gatewaysrvr.c:2686:56: warning: passing argument 5 of ‘gwServices_ConvertPbClusterList’ from incompatible pointer type [-Wincompatible-pointer-types]
&attrListRsp.n_clusterlist );
In file included from gatewaysrvr.c:53:0:
gatewayservices.h:140:26: note: expected ‘uint32 * {aka unsigned int *}’ but argument is of type ‘size_t * {aka long unsigned int *}’
extern GwClusterListT ** gwServices_ConvertPbClusterList( int attrCount, zclAttrRec_t *pAttrRecord,
Compiling gatewayservices.c ...
Compiling ../serverpb/gatewayp2p.c ...
Compiling gateway.pb-c.c ...
(unsigned int)pMsg,
Compiling ../../../../Components/stack/gp/gp_common.c ...
Compiling ../../../../Components/stack/gp/gp_proxyTbl.c ...
Compiling ../../../../Components/stack/zcl/zcl_green_power.c ...
Compiling ../../../../Components/stack/zcl/zcl_general.c ...
Compiling ../../../../Components/stack/zcl/zcl_poll_control.c ...
Compiling ../../../../Components/stack/zcl/zcl_lighting.c ...
Compiling ../../../../Components/stack/zcl/zcl_closures.c ...
Compiling ../../../../Components/stack/zcl/zcl_hvac.c ...
Compiling ../../../../Components/stack/zcl/zcl_ss.c ...
Compiling ../../../../Components/stack/zcl/zcl.c ...
Compiling aps_groups.c ...
Compiling zcl_port.c ...
%ld
Compiling ../hagateway/gateway_pb_ctrl.c ...
Compiling ../nwkmgr/nwkmgr.pb-c.c ...
Building target out/GATEWAY_SRVR_x86 ...
make[1]: Leaving directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/hagateway'
Cleaning all
export ARCH=x86
make[1]: Entering directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/otaserver'
Compiling zcl_ota.c ...
(unsigned int)pMsg,
Compiling zcl_otaserver_lnx.c ...
Compiling OtaServer.c ...
Compiling OtaServer_db.c ...
Compiling ota_common.c ...
Compiling otasrvr.c ...
Compiling otasrvr.pb-c.c ...
%ld
Compiling ../otaserver/otasrvr_pb_ctrl.c ...
Building target out/OTA_SRVR_x86 ...
make[1]: Leaving directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/otaserver'
Cleaning up main.o polling.o timer_utils.o socket_interface.o tcp_client.o user_interface.o data_structures.o network_info_engine.o device_list_engine.o sensor_engine.o state_reflector.o attribute_engine.o actions_engine.o commissioning_engine.o system_engine.o ota_engine.o nwkmgr.pb-c.o gateway.pb-c.o otasrvr.pb-c.o group_scene_engine.o macros.o pb_utils.o nwkmgr_pb_ctrl.o gateway_pb_ctrl.o otasrvr_pb_ctrl.o trace.o configparser.o ./out/*
/bin/rm -f main.bin main.o polling.o timer_utils.o socket_interface.o tcp_client.o user_interface.o data_structures.o network_info_engine.o device_list_engine.o sensor_engine.o state_reflector.o attribute_engine.o actions_engine.o commissioning_engine.o system_engine.o ota_engine.o nwkmgr.pb-c.o gateway.pb-c.o otasrvr.pb-c.o group_scene_engine.o macros.o pb_utils.o nwkmgr_pb_ctrl.o gateway_pb_ctrl.o otasrvr_pb_ctrl.o trace.o configparser.o ./out/*
/bin/rm -rf ./out
VPATH is .:./../framework:./../engines:./../../nwkmgr:./../../hagateway:./../../otaserver:./../../source:./../../srvwrapper
if test ! -d ./out; then mkdir ./out; fi
Compiling main.c into main.o
Compiling ./../framework/polling.c into polling.o
Compiling ./../framework/timer_utils.c into timer_utils.o
Compiling ./../framework/socket_interface.c into socket_interface.o
In file included from ./../framework/socket_interface.c:51:0:
./../framework/socket_interface.c: In function ‘si_register_idle_callback’:
./../framework/socket_interface.c:159:94: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
UI_PRINT_LOG("Created new idle_cb entry (#%d) for func (%08x), arg (%08X)", idle_cb_count, (int)IDLE_CB, (int)IDLE_CB_ARG);
./../framework/user_interface.h:86:89: note: in definition of macro ‘UI_PRINT_LOG_EX’
#define UI_PRINT_LOG_EX(trace_group, fmt, ...) do {_ui_print_log(trace_group, (fmt), ##__VA_ARGS__);} while (0)
./../framework/socket_interface.c:159:3: note: in expansion of macro ‘UI_PRINT_LOG’
./../framework/socket_interface.c:159:108: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
./../framework/socket_interface.c:163:98: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
UI_PRINT_LOG("ERROR: Failed to create new idle_cb entry (#%d) for func (%08x)", idle_cb_count, (int)IDLE_CB);
./../framework/socket_interface.c:163:3: note: in expansion of macro ‘UI_PRINT_LOG’
./../framework/socket_interface.c: In function ‘si_unregister_idle_callback’:
./../framework/socket_interface.c:174:53: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
UI_PRINT_LOG("Unregistering state machine (%08x)", (int)IDLE_CB);
./../framework/socket_interface.c:174:2: note: in expansion of macro ‘UI_PRINT_LOG’
Compiling ./../framework/tcp_client.c into tcp_client.o
Compiling ./../framework/user_interface.c into user_interface.o
./../framework/user_interface.c: In function ‘ui_redraw_actions’:
./../framework/user_interface.c:2386:18: warning: field precision specifier ‘.*’ expects argument of type ‘int’, but argument 3 has type ‘long int’ [-Wformat=]
printf("%s[%.*s"UNDERSCORE"%c"NO_UNDERSCORE"%s:%03d] ", (i == current_action ? LIGHT_YELLOW : DARK_YELLOW), strchr(ACTION_NAMES[i],'&') - ACTION_NAMES[i], ACTION_NAMES[i], strchr(ACTION_NAMES[i],'&')[1], strchr(ACTION_NAMES[i],'&') + 2, action_value[i]);
./../framework/user_interface.c:2389:18: warning: field precision specifier ‘.*’ expects argument of type ‘int’, but argument 3 has type ‘long int’ [-Wformat=]
printf("%s[%.*s"UNDERSCORE"%c"NO_UNDERSCORE"%s] ", (i == current_action ? LIGHT_YELLOW : DARK_YELLOW), strchr(ACTION_NAMES[i],'&') - ACTION_NAMES[i], ACTION_NAMES[i], strchr(ACTION_NAMES[i],'&')[1], strchr(ACTION_NAMES[i],'&') + 2);
./../framework/user_interface.c:2396:18: warning: field precision specifier ‘.*’ expects argument of type ‘int’, but argument 3 has type ‘long int’ [-Wformat=]
printf("%s%.*s"UNDERSCORE"%c"NO_UNDERSCORE"%s",
./../framework/user_interface.c:2398:7:
strchr(ACTION_SUBNAMES[i][j],'&') - ACTION_SUBNAMES[i][j],
Compiling ./../framework/data_structures.c into data_structures.o
Compiling ./../engines/network_info_engine.c into network_info_engine.o
Compiling ./../engines/device_list_engine.c into device_list_engine.o
Compiling ./../engines/sensor_engine.c into sensor_engine.o
In file included from ../framework/user_interface.h:51:0,
from ./../engines/sensor_engine.c:50:
./../engines/sensor_engine.c: In function ‘snsr_process_zone_status_change_ind’:
./../engines/sensor_engine.c:355:26: warning: format ‘%LX’ expects argument of type ‘long long unsigned int’, but argument 4 has type ‘uint64_t {aka long unsigned int}’ [-Wformat=]
STRING_ADD(log_string, "addr = %08LX,", msg->srcaddress->ieeeaddr);
../../srvwrapper/trace.h:159:95: note: in definition of macro ‘STRING_ADD’
Compiling ./../engines/state_reflector.c into state_reflector.o
Compiling ./../engines/attribute_engine.c into attribute_engine.o
./../engines/attribute_engine.c: In function ‘attr_write_response_indication_handler’:
./../engines/attribute_engine.c:269:77: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
tu_set_timer(&identify_timer, 1000, true, attr_identify_timer_handler, (void *)msg->srcaddress->endpointid);
./../engines/attribute_engine.c: In function ‘attr_identify_timer_handler’:
./../engines/attribute_engine.c:944:30: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
uint8_t endpoint = (uint8_t)(uint32_t)arg;
Compiling ./../engines/actions_engine.c into actions_engine.o
Compiling ./../engines/commissioning_engine.c into commissioning_engine.o
Compiling ./../engines/system_engine.c into system_engine.o
Compiling ./../engines/ota_engine.c into ota_engine.o
./../engines/ota_engine.c: In function ‘upgrade_apply_image_cnf’:
./../engines/ota_engine.c:322:14: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
int index = (int )cbarg;
./../engines/ota_engine.c: In function ‘upgrade_process_regis_cnf’:
./../engines/ota_engine.c:361:14: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
./../engines/ota_engine.c: In function ‘register_single_file’:
./../engines/ota_engine.c:481:85: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
if (si_send_packet(pkt, (confirmation_processing_cb_t)&upgrade_process_regis_cnf, (void *)i) != 0)
Compiling ./../../nwkmgr/nwkmgr.pb-c.c into nwkmgr.pb-c.o
Compiling ./../../hagateway/gateway.pb-c.c into gateway.pb-c.o
Compiling ./../../otaserver/otasrvr.pb-c.c into otasrvr.pb-c.o
Compiling ./../engines/group_scene_engine.c into group_scene_engine.o
Compiling ./../framework/macros.c into macros.o
Compiling ./../../source/pb_utils.c into pb_utils.o
./../../source/pb_utils.c: In function ‘print_unpacked_pb_msg’:
./../../source/pb_utils.c:207:21: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
./../../source/pb_utils.c:227:24: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
In file included from ./../../source/pb_utils.h:46:0,
from ./../../source/pb_utils.c:48:
./../../source/pb_utils.c: In function ‘print_pb_msg’:
./../../source/pb_utils.c:394:27: warning: format ‘%X’ expects argument of type ‘unsigned int’, but argument 4 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
./../../source/pb_utils.c:394:27: warning: format ‘%X’ expects argument of type ‘unsigned int’, but argument 5 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
./../../source/pb_utils.c:398:27: warning: format ‘%X’ expects argument of type ‘unsigned int’, but argument 4 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
../../srvwrapper/trace.h:77:16: warning: format ‘%d’ expects argument of type ‘int’, but argument 6 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
./../../source/pb_utils.c:430:38: note: in expansion of macro ‘RED’
./../../source/pb_utils.c:430:97: note: format string is defined here
%ld
Compiling ./../../nwkmgr/nwkmgr_pb_ctrl.c into nwkmgr_pb_ctrl.o
Compiling ./../../hagateway/gateway_pb_ctrl.c into gateway_pb_ctrl.o
Compiling ./../../otaserver/otasrvr_pb_ctrl.c into otasrvr_pb_ctrl.o
Compiling ./../../srvwrapper/trace.c into trace.o
In file included from ./../../srvwrapper/trace.c:52:0:
./../../srvwrapper/trace.c: In function ‘trace_init_thread’:
./../../srvwrapper/trace.h:198:44: warning: right-hand operand of comma expression has no effect [-Wunused-value]
#define PTHREAD_SETSPECIFIC(A,B) ((A) = (B), 0)
./../../srvwrapper/trace.c:187:3: note: in expansion of macro ‘PTHREAD_SETSPECIFIC’
PTHREAD_SETSPECIFIC(thread_name_key, NULL);
Compiling ./../../srvwrapper/configparser.c into configparser.o
Building main.bin...
mv main.o polling.o timer_utils.o socket_interface.o tcp_client.o user_interface.o data_structures.o network_info_engine.o device_list_engine.o sensor_engine.o state_reflector.o attribute_engine.o actions_engine.o commissioning_engine.o system_engine.o ota_engine.o nwkmgr.pb-c.o gateway.pb-c.o otasrvr.pb-c.o group_scene_engine.o macros.o pb_utils.o nwkmgr_pb_ctrl.o gateway_pb_ctrl.o otasrvr_pb_ctrl.o trace.o configparser.o ./out
rm -rf *.o sbl_tool.bin
gcc -Wall -DVERSION_NUMBER="0.1" -D_GNU_SOURCE -DxHAL_UART_SPI -c -o main.o ../Source/main.c
gcc -Wall -DVERSION_NUMBER="0.1" -D_GNU_SOURCE -DxHAL_UART_SPI -c -o zbSocCmd.o ../Source/zbSocCmd.c
In file included from ../Source/zbSocCmd.c:60:0:
../Source/zbSocCmd.c: In function ‘config_read_pair’:
../Source/zbSocCmd.c:606:70: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
debug_printf("config_read_pair: section=%s, context=%u\n", section, (unsigned int)context);
../Source/zbSocCmd.h:100:67: note: in definition of macro ‘debug_printf’
#define debug_printf(...) do {if (uartDebugPrintsEnabled) {printf(__VA_ARGS__);}} while (0)
../Source/zbSocCmd.c:611:16: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘size_t {aka long unsigned int}’ [-Wformat=]
debug_printf("config_read_pair: seeking to: %d\n", *context);
gcc -Wall -DVERSION_NUMBER="0.1" -D_GNU_SOURCE -DxHAL_UART_SPI -c -o zbSocTransportUart.o ../Source/zbSocTransportUart.c
../Source/zbSocTransportUart.c: In function ‘zbSocTransportWrite’:
../Source/zbSocTransportUart.c:72:11: warning: format ‘%d’ expects argument of type ‘int’, but argument 2 has type ‘ssize_t {aka long int}’ [-Wformat=]
printf("write=%d\n",write((fd),(rpcBuff),(rpcLen))); \
../Source/zbSocTransportUart.c:173:2: note: in expansion of macro ‘socWrite’
socWrite(serialPortFd, buf, len);
gcc -Wall -DVERSION_NUMBER="0.1" main.o zbSocCmd.o zbSocTransportUart.o -L.../usr/lib/ -o sbl_tool.bin
rm -rf *.o gw_soc_fw_version_query.bin
../Source/zbSocTransportUart.c:178:2: note: in expansion of macro ‘socWrite’
gcc -Wall -DVERSION_NUMBER="0.1" main.o zbSocCmd.o zbSocTransportUart.o -L.../usr/lib/ -o gw_soc_fw_version_query.bin
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/scripts/hagateway/reset/x86/soc_reset_hold': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/scripts/hagateway/reset/x86/soc_reset_release': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/protobuf-c/lib/x86/libprotobuf-c.so.0.0.0': No such file or directory
Package verification results:
ERROR: 2 error(s) occured during make
ERROR: 89 warning(s) occured during make
sort: cannot read: /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/scripts/package_builder_expected_content_RUNTIME_x86.txt: No such file or directory
diff /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/out/content.txt /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/out/expected_content.txt
1,29d0
< ./content.txt
< ./Precompiled
< ./Precompiled/app
< ./Precompiled/app/main.bin
< ./Precompiled/misc
< ./Precompiled/misc/CC2531-GW-ZNP_39203.bin
< ./Precompiled/misc/ota_sample_images
< ./Precompiled/misc/ota_sample_images/5678-1234-0000AAAA.zigbee
< ./Precompiled/misc/ota_sample_images/5678-1234-0000BBBB.zigbee
< ./Precompiled/protobuf
< ./Precompiled/servers
< ./Precompiled/servers/config.ini
< ./Precompiled/servers/gateway_config.ini
< ./Precompiled/servers/gateway_config.tlg
< ./Precompiled/servers/GATEWAY_SRVR_x86
< ./Precompiled/servers/NPI_Gateway.cfg
< ./Precompiled/servers/NPI_lnx_x86_server
< ./Precompiled/servers/nwkmgr_config.ini
< ./Precompiled/servers/NWKMGR_SRVR_x86
< ./Precompiled/servers/OTA_SRVR_x86
< ./Precompiled/servers/sample_app_ota.cfg
< ./Precompiled/servers/start_application
< ./Precompiled/servers/track_servers
< ./Precompiled/servers/zigbeeHAgw
< ./Precompiled/servers/ZLSZNP_x86
< ./Precompiled/tools
< ./Precompiled/tools/gw_soc_fw_version_query.bin
< ./Precompiled/tools/sbl_tool.bin
ERROR: Content verification failed
ERROR: RUNTIME package for x86 creation failed. See details above. Output folder/tar name prefixed with "ERROR_."
SUCCESS: build_all finished.
Entered Precompiled directory.
tar: z-stack_linux_gateway_arm_binaries_.tar: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
app/
app/main.bin
misc/
protobuf/
servers/
servers/zigbeeHAgw
servers/config.ini
servers/ZLSZNP_x86
tools/
tools/sbl_tool.bin
SUCCESS: Extracted binaries
Entered servers/ directory
Make apps exe, copy protobuf files
SUCCESS: Made servers and applications executable
SUCCESS: Made /tools/ folder executable
Copy Protobuf Files to /usr/lib directory
cp: cannot stat '../protobuf/libprotobuf-c.so.0': No such file or directory
cp: cannot stat '../protobuf/libprotobuf-c.so.0.0.0': No such file or directory
Protobuf files not found
****** SETUP FAILED! *****
Out of curiosity, is the same customer from this thread involved? e2e.ti.com/.../753714
I've only tested on the BeagleBone Black with the Debian 9.x 32-bit OS, the User Guide and other documents state that the Linus Gateway software only supports x86 so 64-bit operation may not be available. I can reach out to Software Development for further insight but responses will be delayed due to the holiday season. I would recommend that you continue using a 32-bit OS for now.
Ryan
Please reproduce the error and add the verbose debug data to the log. That extra information will be helpful to follow up the issue.
Yes I have the linux gateway running on Ubuntu 18.04 x64 and everything works as expected out-of-the-box, the only thing that I had to change was the name of the folder suggested by Ryan:
from
/Projects/zstack/linux/protobuf-c/lib/arm
to
My best guess from the error that you have is that your ZNP has the bootloader which was used for legacy versions of zstack. Z-Stack for zigbee 3.0 doesn't use a boot-loader so you need to have a ZNP without the boot-loader included. Just flash a ZNP project that doesn't have SBL built in. In my case I sued a CC2531-Debug from Z-Stack 3.0.2, so try it like that and share how it goes.
Can’ I use prebuilt ZNP hex for CC2531EMK come with ZIGBEE-LINUX-SENSOR-TO-CLOUD_1.0.0 installation? By the way, I see some npm packages build problem as Alvin and I post in the beginning of this thread, don’t you see it when you build ZIGBEE-LINUX-SENSOR-TO-CLOUD_1.0.0 on your ubuntu 16.04 x64 bit setup?
Jose Maria AlvarezI try to setup a new Ubuntu 18.04 x64 on VirtualBox and change /Projects/zstack/linux/protobuf-c/lib/arm to /Projects/zstack/linux/protobuf-c/lib/x86. However, I still see the following build errors. I suppose you setup something but forget them. Can you try a brand new Ubuntu 18.04 x64 on VirtualBox to verify this? It's easy to reproduce.
> bufferutil@1.1.0 install /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/bufferutil
> node-gyp rebuild
make: Entering directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/bufferutil/build'
CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
In file included from ../../nan/nan.h:82:0,
from ../src/bufferutil.cc:16:
../../nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Int32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
../../nan/nan_new.h:34:64: warning: ‘v8::Local<v8::Int32> v8::Value::ToInt32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
To<v8::Int32>(v8::Handle<v8::Integer> i) { return i->ToInt32(); }
In file included from ../src/bufferutil.cc:7:0:
/usr/include/nodejs/deps/v8/include/v8.h:9796:14: note: declared here
Local<Int32> Value::ToInt32() const {
../../nan/nan_new.h: In function ‘v8::Local<T> NanIntern::To(v8::Handle<v8::Integer>) [with T = v8::Uint32; v8::Handle<v8::Integer> = v8::Local<v8::Integer>]’:
../../nan/nan_new.h:39:65: warning: ‘v8::Local<v8::Uint32> v8::Value::ToUint32() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
To<v8::Uint32>(v8::Handle<v8::Integer> i) { return i->ToUint32(); }
/usr/include/nodejs/deps/v8/include/v8.h:9790:15: note: declared here
Local<Uint32> Value::ToUint32() const {
In file included from ../../nan/nan_new.h:189:0,
from ../../nan/nan.h:82,
../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::BooleanObject>::return_t NanIntern::Factory<v8::BooleanObject>::New(bool)’:
../../nan/nan_implementation_12_inl.h:49:38: warning: ‘static v8::Local<v8::Value> v8::BooleanObject::New(bool)’ is deprecated: Pass an isolate [-Wdeprecated-declarations]
return v8::BooleanObject::New(value).As<v8::BooleanObject>();
In file included from /usr/include/nodejs/deps/v8/include/v8.h:26:0,
/usr/include/nodejs/deps/v8/include/v8.h:4845:56: note: declared here
V8_DEPRECATED("Pass an isolate", static Local<Value> New(bool value));
/usr/include/nodejs/deps/v8/include/v8config.h:318:3: note: in definition of macro ‘V8_DEPRECATED’
declarator __attribute__((deprecated(message)))
../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>)’:
../../nan/nan_implementation_12_inl.h:166:69: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &src);
/usr/include/nodejs/deps/v8/include/v8.h:1425:21: note: declared here
Local<Script> Compile(Isolate* isolate, Source* source,
../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::Script>::return_t NanIntern::Factory<v8::Script>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
../../nan/nan_implementation_12_inl.h:173:69: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(const uint8_t*, int)’:
../../nan/nan_implementation_12_inl.h:206:42: warning: ‘static v8::Local<v8::String> v8::String::NewFromOneByte(v8::Isolate*, const uint8_t*, v8::String::NewStringType, int)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
v8::String::kNormalString, length);
/usr/include/nodejs/deps/v8/include/v8.h:2681:21: note: declared here
Local<String> NewFromOneByte(Isolate* isolate, const uint8_t* data,
../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::String>::return_t NanIntern::Factory<v8::String>::New(v8::String::ExternalStringResource*)’:
../../nan/nan_implementation_12_inl.h:217:66: warning: ‘static v8::Local<v8::String> v8::String::NewExternal(v8::Isolate*, v8::String::ExternalStringResource*)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return v8::String::NewExternal(v8::Isolate::GetCurrent(), value);
/usr/include/nodejs/deps/v8/include/v8.h:2719:38: note: declared here
Local<String> NewExternal(
../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>)’:
../../nan/nan_implementation_12_inl.h:237:30: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return v8::ScriptCompiler::CompileUnbound(v8::Isolate::GetCurrent(), &src);
/usr/include/nodejs/deps/v8/include/v8.h:1405:45: note: declared here
Local<UnboundScript> CompileUnbound(
../../nan/nan_implementation_12_inl.h:237:76: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../../nan/nan_implementation_12_inl.h: In static member function ‘static NanIntern::FactoryBase<v8::UnboundScript>::return_t NanIntern::Factory<v8::UnboundScript>::New(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
../../nan/nan_implementation_12_inl.h:244:30: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../../nan/nan_implementation_12_inl.h:244:76: warning: ‘static v8::Local<v8::UnboundScript> v8::ScriptCompiler::CompileUnbound(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
In file included from ../src/bufferutil.cc:16:0:
../../nan/nan.h: At global scope:
../../nan/nan.h:261:25: error: redefinition of ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Local<T>)’
NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Local<T> val) {
../../nan/nan.h:256:25: note: ‘template<class T> v8::Local<T> _NanEnsureLocal(v8::Handle<T>)’ previously declared here
NAN_INLINE v8::Local<T> _NanEnsureLocal(v8::Handle<T> val) {
../../nan/nan.h: In function ‘bool NanIdleNotification(int)’:
../../nan/nan.h:289:71: warning: ‘bool v8::Isolate::IdleNotification(int)’ is deprecated: use IdleNotificationDeadline() [-Wdeprecated-declarations]
return v8::Isolate::GetCurrent()->IdleNotification(idle_time_in_ms);
/usr/include/nodejs/deps/v8/include/v8.h:7482:22: note: declared here
bool IdleNotification(int idle_time_in_ms));
../../nan/nan.h:473:20: error: variable or field ‘NanAddGCEpilogueCallback’ declared void
v8::Isolate::GCEpilogueCallback callback
../../nan/nan.h:473:20: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
../../nan/nan.h:474:18: error: expected primary-expression before ‘gc_type_filter’
, v8::GCType gc_type_filter = v8::kGCTypeAll) {
../../nan/nan.h:479:20: error: variable or field ‘NanRemoveGCEpilogueCallback’ declared void
v8::Isolate::GCEpilogueCallback callback) {
../../nan/nan.h:479:20: error: ‘GCEpilogueCallback’ is not a member of ‘v8::Isolate’
../../nan/nan.h:484:20: error: variable or field ‘NanAddGCPrologueCallback’ declared void
v8::Isolate::GCPrologueCallback callback
../../nan/nan.h:484:20: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
../../nan/nan.h:485:18: error: expected primary-expression before ‘gc_type_filter’
../../nan/nan.h:490:20: error: variable or field ‘NanRemoveGCPrologueCallback’ declared void
v8::Isolate::GCPrologueCallback callback) {
../../nan/nan.h:490:20: error: ‘GCPrologueCallback’ is not a member of ‘v8::Isolate’
../../nan/nan.h:569:15: error: ‘WeakCallbackData’ in namespace ‘v8’ does not name a template type
const v8::WeakCallbackData<T, _NanWeakCallbackInfo<T, P> > &data) {
../../nan/nan.h:569:31: error: expected ‘,’ or ‘...’ before ‘<’ token
../../nan/nan.h: In function ‘void _NanWeakCallbackDispatcher(int)’:
../../nan/nan.h:570:42: error: ‘data’ was not declared in this scope
_NanWeakCallbackInfo<T, P> *info = data.GetParameter();
../../nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared
, node::smalloc::FreeCallback callback
../../nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’
../../nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(char*, size_t, int)’:
../../nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
v8::Isolate::GetCurrent(), data, length, callback, hint);
../../nan/nan.h:665:50: note: suggested alternative: ‘calloc’
calloc
../../nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
../../nan/nan.h:665:60: note: suggested alternative: ‘uint’
uint
../../nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(const char*, uint32_t)’:
../../nan/nan.h:672:67: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
In file included from ../src/bufferutil.cc:10:0:
/usr/include/nodejs/src/node_buffer.h:67:40: note: initializing argument 2 of ‘v8::MaybeLocal<v8::Object> node::Buffer::New(v8::Isolate*, char*, size_t)’
NODE_EXTERN v8::MaybeLocal<v8::Object> New(v8::Isolate* isolate,
../../nan/nan.h:672:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((char*)data), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
../../nan/nan.h: In function ‘v8::Local<v8::Object> NanNewBufferHandle(uint32_t)’:
../../nan/nan.h:676:29: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::Object>’ to ‘v8::Local<v8::Object>’
return node::Buffer::New(v8::Isolate::GetCurrent(), size);
../../nan/nan.h: In function ‘v8::Local<v8::Object> NanBufferUse(char*, uint32_t)’:
../../nan/nan.h:683:26: error: ‘Use’ is not a member of ‘node::Buffer’
return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
../../nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>, const v8::ScriptOrigin&)’:
../../nan/nan.h:710:74: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
return v8::ScriptCompiler::Compile(v8::Isolate::GetCurrent(), &source);
../../nan/nan.h: In function ‘v8::Local<v8::Script> NanCompileScript(v8::Local<v8::String>)’:
../../nan/nan.h:717:74: warning: ‘static v8::Local<v8::Script> v8::ScriptCompiler::Compile(v8::Isolate*, v8::ScriptCompiler::Source*, v8::ScriptCompiler::CompileOptions)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../src/bufferutil.cc: In static member function ‘static void BufferUtil::Initialize(v8::Handle<v8::Object>)’:
../src/bufferutil.cc:30:52: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [7], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
NODE_SET_METHOD(t, "unmask", BufferUtil::Unmask);
In file included from ../src/bufferutil.cc:8:0:
/usr/include/nodejs/src/node.h:278:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Template>, const char*, v8::FunctionCallback)
inline void NODE_SET_METHOD(v8::Local<v8::Template> recv,
/usr/include/nodejs/src/node.h:291:13: note: candidate: void node::NODE_SET_METHOD(v8::Local<v8::Object>, const char*, v8::FunctionCallback)
inline void NODE_SET_METHOD(v8::Local<v8::Object> recv,
../src/bufferutil.cc:31:48: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [5], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
NODE_SET_METHOD(t, "mask", BufferUtil::Mask);
../src/bufferutil.cc:32:50: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [6], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
NODE_SET_METHOD(t, "merge", BufferUtil::Merge);
bufferutil.target.mk:97: recipe for target 'Release/obj.target/bufferutil/src/bufferutil.o' failed
make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1
make: Leaving directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/bufferutil/build'
gyp ERR! build error
gyp ERR! stack Error: `make` failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/share/node-gyp/lib/build.js:258:23)
gyp ERR! stack at emitTwo (events.js:126:13)
gyp ERR! stack at ChildProcess.emit (events.js:214:7)
gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
gyp ERR! System Linux 4.15.0-29-generic
gyp ERR! command "/usr/bin/node" "/usr/bin/node-gyp" "rebuild"
gyp ERR! cwd /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/bufferutil
gyp ERR! node -v v8.10.0
gyp ERR! node-gyp -v v3.6.2
gyp ERR! not ok
npm WARN install:bufferutil@1.1.0 bufferutil@1.1.0 install: `node-gyp rebuild`
npm WARN install:bufferutil@1.1.0 Exit status 1
> utf-8-validate@1.1.0 install /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/utf-8-validate
> node-gyp rebuild
make: Entering directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/utf-8-validate/build'
CXX(target) Release/obj.target/validation/src/validation.o
from ../src/validation.cc:15:
In file included from ../src/validation.cc:7:0:
In file included from ../src/validation.cc:15:0:
calloc
uint
In file included from ../src/validation.cc:10:0:
../src/validation.cc: In static member function ‘static void Validation::Initialize(v8::Handle<v8::Object>)’:
../src/validation.cc:112:62: error: call of overloaded ‘NODE_SET_METHOD(v8::Local<v8::FunctionTemplate>&, const char [12], void (&)(const v8::FunctionCallbackInfo<v8::Value>&))’ is ambiguous
NODE_SET_METHOD(t, "isValidUTF8", Validation::IsValidUTF8);
In file included from ../src/validation.cc:8:0:
../src/validation.cc: In function ‘int is_valid_utf8(size_t, char*)’:
../src/validation.cc:82:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
case 5 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:83:7: note: here
case 4 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:83:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:84:7: note: here
case 3 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:84:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:85:7: note: here
case 2 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:85:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:86:7: note: here
case 1 : ch += (uint8_t) value[i++]; ch <<= 6;
../src/validation.cc:86:47: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:87:7: note: here
case 0 : ch += (uint8_t) value[i];
../src/validation.cc: In function ‘int isLegalUTF8(const uint8_t*, int)’:
../src/validation.cc:51:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
case 4: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
../src/validation.cc:52:3: note: here
case 3: if ((a = (*--srcptr)) < 0x80 || a > 0xBF) return 0;
../src/validation.cc:52:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
../src/validation.cc:53:3: note: here
case 2: if ((a = (*--srcptr)) > 0xBF) return 0;
../src/validation.cc:60:18: warning: this statement may fall through [-Wimplicit-fallthrough=]
default: if (a < 0x80) return 0;
../src/validation.cc:63:3: note: here
case 1: if (*source >= 0x80 && *source < 0xC2) return 0;
validation.target.mk:97: recipe for target 'Release/obj.target/validation/src/validation.o' failed
make: *** [Release/obj.target/validation/src/validation.o] Error 1
make: Leaving directory '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/utf-8-validate/build'
gyp ERR! cwd /home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node/nodejs_zb_gateway/node_modules/utf-8-validate
gyp ERR! not ok
npm WARN install:utf-8-validate@1.1.0 utf-8-validate@1.1.0 install: `node-gyp rebuild`
npm WARN install:utf-8-validate@1.1.0 Exit status 1
Run ./build_all
SVN Version =
Building RUNTIME package for BEAGLEBONE_BLACK platform
Cleaning all
COMPILING SERVER FOR ARM BEAGLE BONE
make[1]: arm-linux-gnueabihf-gcc: Command not found
makefile:210: recipe for target 'out/npi_lnx_ipc.o' failed
make[1]: *** [out/npi_lnx_ipc.o] Error 127
makefile:96: recipe for target 'arch-all-arm' failed
make: *** [arch-all-arm] Error 2
Building ZLSZNP_arm
Compiler: arm-linux-gnueabihf-gcc
Targer platform: arm
make: arm-linux-gnueabihf-gcc: Command not found
Makefile:131: recipe for target 'osal_zstack_server_znp.o' failed
make: *** [osal_zstack_server_znp.o] Error 127
Cleaning all
COMPILING APP FOR ARM
Makefile:225: recipe for target 'out/serverep.o' failed
make[1]: *** [out/serverep.o] Error 127
Makefile:130: recipe for target 'arch-all-arm' failed
Cleaning all
Makefile:241: recipe for target 'out/serverep.o' failed
Makefile:152: recipe for target 'arch-all-arm' failed
Cleaning all
export ARCH=arm
Makefile:196: recipe for target 'out/zstack.pb-c.o' failed
make[1]: *** [out/zstack.pb-c.o] Error 127
Makefile:133: recipe for target 'arch-all-arm' failed
/bin/rm -rf ./out
makefile:45: recipe for target 'main.o' failed
make: *** [main.o] Error 127
arm-linux-gnueabihf-gcc -Wall -DVERSION_NUMBER="0.1" -D_GNU_SOURCE -DxHAL_UART_SPI -c -o main.o ../Source/main.c
/bin/sh: 1: arm-linux-gnueabihf-gcc: not found
Makefile:24: recipe for target 'main.o' failed
Cleaning up ../source/bbb_usbreset.o ./out/*
/bin/rm -f bbb_usbreset.bin ../source/bbb_usbreset.o ./out/*
/bin/rm -f *project_file_list.txt
VPATH is .
Compiling ../source/bbb_usbreset.c into ../source/bbb_usbreset.o
arm-linux-gnueabihf-gcc -c -Wall -std=gnu99 -I. ../source/bbb_usbreset.c -o ../source/bbb_usbreset.o
makefile:42: recipe for target '../source/bbb_usbreset.o' failed
make: *** [../source/bbb_usbreset.o] Error 127
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/RemoTI-Linux-master//Projects/tools/LinuxHost/out/NPI_lnx_arm_server': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/nwkmgr/out/NWKMGR_SRVR_arm': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/hagateway/out/GATEWAY_SRVR_arm': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/otaserver/out/OTA_SRVR_arm': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/demo/project/main.bin': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/sbl_tool/project/sbl_tool.bin': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/version_query_minitool/project/gw_soc_fw_version_query.bin': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/bbb_usbreset/project/bbb_usbreset.bin': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/protobuf-c/lib/arm/libprotobuf-c.so.0': No such file or directory
ERROR: 13 error(s) occured during make
4a5
10a12
> ./Precompiled/protobuf/libprotobuf-c.so.0
14a17
> ./Precompiled/servers/GATEWAY_SRVR_arm
15a19
> ./Precompiled/servers/NPI_lnx_arm_server
16a21,22
> ./Precompiled/servers/NWKMGR_SRVR_arm
> ./Precompiled/servers/OTA_SRVR_arm
22a29,31
> ./Precompiled/tools/bbb_usbreset.bin
ERROR: RUNTIME package for arm creation failed. See details above. Output folder/tar name prefixed with "ERROR_."
app/
misc/
protobuf/
servers/
servers/zigbeeHAgw
servers/config.ini
servers/ZLSZNP_arm
tools/
tools/soc_reset_hold
tools/soc_reset_release
Sorry that I forget this step. After I change TARGET_PLATFORM to x86, it can build. However, I see the following errors when I run "sudo ./start_gateway.sh"
yk@yk-VirtualBox:~/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node$ sudo ./start_gateway.sh
Start the Linux Zigbee Gateway
yk@yk-VirtualBox:~/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/node$ Platform type selected automatically as x86.
To override this selection, please stop this script, and then run it again,
specifying the desired platform type at the command line:
./zigbeeHAgw [help | bbb | x86 ]
running ./zigbeeHAgw on an x86
file ZLSZNP_x86 is missing
file GATEWAY_SRVR_x86 is missing
file NWKMGR_SRVR_x86 is missing
file OTA_SRVR_x86 is missing
there are 4 missing files!
exiting ./zigbeeHAgw
Ryan Brown1 Jose Maria AlvarezThe followings are my latest build log. As you can see, it complains about "/usr/bin/ld: skipping incompatible ../protobuf-c/lib/x86/libprotobuf-c.so when searching for -lprotobuf-c","/usr/bin/ld: skipping incompatible ../protobuf-c/lib/x86/libprotobuf-c.a when searching for -lprotobuf-c", "/usr/bin/ld: cannot find -lprotobuf-c".
/protobuf/stubs/stringpiece.h google/protobuf/stubs/strutil.h google/protobuf/stubs/template_util.h '/usr/local/include/google/protobuf/stubs'
/bin/mkdir -p '/usr/local/include/google/protobuf'
/usr/bin/install -c -m 644 google/protobuf/repeated_field.h google/protobuf/service.h google/protobuf/source_context.pb.h google/protobuf/struct.pb.h google/protobuf/text_format.h google/protobuf/timestamp.pb.h google/protobuf/type.pb.h google/protobuf/unknown_field_set.h google/protobuf/wire_format.h google/protobuf/wire_format_lite.h google/protobuf/wire_format_lite_inl.h google/protobuf/wrappers.pb.h '/usr/local/include/google/protobuf'
/bin/mkdir -p '/usr/local/include/google/protobuf/compiler/objectivec'
/usr/bin/install -c -m 644 google/protobuf/compiler/objectivec/objectivec_generator.h google/protobuf/compiler/objectivec/objectivec_helpers.h '/usr/local/include/google/protobuf/compiler/objectivec'
/bin/mkdir -p '/usr/local/include/google/protobuf/compiler'
/usr/bin/install -c -m 644 google/protobuf/compiler/code_generator.h google/protobuf/compiler/command_line_interface.h google/protobuf/compiler/importer.h google/protobuf/compiler/parser.h google/protobuf/compiler/plugin.h google/protobuf/compiler/plugin.pb.h '/usr/local/include/google/protobuf/compiler'
make[2]: Leaving directory '/home/yk/protobuf/src'
make[1]: Leaving directory '/home/yk/protobuf/src'
yk@yk-VirtualBox:~/protobuf$ sudo ldconfig
yk@yk-VirtualBox:~/protobuf$ cd ~/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/
yk@yk-VirtualBox:~/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source$ clear
> node-gyp rebuild
calloc
uint
gyp ERR! not ok
> node-gyp rebuild
calloc
uint
gyp ERR! not ok
Run ./build_all
SVN Version =
Cleaning all
Building ZLSZNP_x86
Compiler: gcc
Compiling znp_af.c
afStatus_t status;
Compiling znp_zdo.c
(unsigned int)pMsg,
%ld
Linking ZLSZNP_x86
collect2: error: ld returned 1 exit status
Makefile:121: recipe for target 'ZLSZNP_x86' failed
make: *** [ZLSZNP_x86] Error 1
Cleaning all
(unsigned int)pMsg,
%ld
Makefile:180: recipe for target 'out/NWKMGR_SRVR_x86' failed
make[1]: *** [out/NWKMGR_SRVR_x86] Error 1
Makefile:125: recipe for target 'arch-all-x86' failed
make: *** [arch-all-x86] Error 2
Cleaning all
(unsigned int)pMsg,
%ld
Makefile:194: recipe for target 'out/GATEWAY_SRVR_x86' failed
make[1]: *** [out/GATEWAY_SRVR_x86] Error 1
Makefile:147: recipe for target 'arch-all-x86' failed
Cleaning all
export ARCH=x86
(unsigned int)pMsg,
%ld
Makefile:186: recipe for target 'out/OTA_SRVR_x86' failed
make[1]: *** [out/OTA_SRVR_x86] Error 1
Makefile:127: recipe for target 'arch-all-x86' failed
/bin/rm -rf ./out
gcc: error: main.o: No such file or directory
gcc: error: pb_utils.o: No such file or directory
gcc: error: trace.o: No such file or directory
gcc: error: configparser.o: No such file or directory
makefile:37: recipe for target 'main.bin' failed
make: *** [main.bin] Error 1
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/zstackserverznp/ZLSZNP_x86': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/nwkmgr/out/NWKMGR_SRVR_x86': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/hagateway/out/GATEWAY_SRVR_x86': No such file or directory
cp: cannot stat '/home/yk/ti/Zigbee_3_0_Linux_Gateway_1_0_0/source/Projects/zstack/linux/otaserver/out/OTA_SRVR_x86': No such file or directory
ERROR: 18 error(s) occured during make
ERROR: 82 warning(s) occured during make
1,25d0
< ./content.txt
< ./Precompiled
< ./Precompiled/app
< ./Precompiled/protobuf/libprotobuf-c.so.0.0.0
app/
misc/
protobuf/
servers/
servers/zigbeeHAgw
servers/config.ini
tools/
tools/sbl_tool.bin
SUCCESS: Copied Protobuf Files
********** SETUP SUCCESSFUL! **********
--------- Getting Started Tips -----------
Navigate to Node Scripts ==> cd Projects/node
Start Linux Zigbee Gateway and Node.js Zigbee Local Gateway ==> sudo ./start_local.sh
Start Linux Zigbee Gateway and Node.js IBM Gateway ==> sudo ./start_ibm.sh
Start Linux Zigbee Gateway Only ==> sudo ./start_gateway.sh
Kill All Gateways ==> sudo ./end.sh
Hi YiKai,
No. I think "GATEWAY_SRVR_x86 is missing" due to path issue .When increase /Projects/zstack/linux/protobuf-c/lib/x86/, run " ./zigbeeHAgw " reproduce same issue.
I reproduce compiler error like your capture. I think important issue is protobuf version. I try use local compiler path in Makefile.
If I do this successfully, will update in post.
