Zigbee intercom
Is it possible to transfer the real time audio by using the Zigbee? Do you have any solution to achieve this? Thank you!
  • Hello Li,
    Zigbee is not intended for audio streaming.  The 250 Kbps throughput could be fast enough in theory, but practically the packet sequencing and transfer latency will not allow for reliable audio delivery.  I suppose it also depends on the quality of audio you are attempting to transfer in real time.  You can at any rate consider BLE to accomplish your needs.
    Ryan
  • If you have to use Zigbee, maybe try to use opus code to encode audio instead of sending raw audio data.
