Part Number: LAUNCHXL-CC1352P
Other Parts Discussed in Thread: SIMPLELINK-CC13X2-26X2-SDK
Is there a sample configuration file tor using the launch kit to run wake up on RF then directly run either transmit or receive in ZigBee mode?
Hi Ben,
You can use Z-Tool (included in the SIMPLELINK-CC13X2-26X2-SDK) or create a python script based on MT commands to control a Zigbee node with ZNP firmware. Please further explain your use case if this does not fit your application needs and reference the Z-Stack User's Guide for more information.
Ryan
You can try to refer to rfWakeOnRx/rfWakeOnTx example at dev.ti.com/.../node
