CC2530: CC2530 6db minimum 500 kHz Bandwidth
Part Number: CC2530
Other Parts Discussed in Thread: CC2592
Looking to get some insight into configuring the cc2530 to fulfill the FCC 15.247 requirement ". The minimum 6 dB bandwidth of such systems is 500 kHz" . We are measuring a bandwidth of 156 kHz. From other forums (see reference), it appears this can be changed via a register setting? We are using a cc2530 with a cc2592 range extender. Any insight would be greatly appreciated.
Thank you,
    Can you share the screen shots of the measurements?
    The data chip rate of CC2530 is 2 MHz so 156kHz BW at 6dB down is suspect.
    regards,
  • Agreed. The 156 kHz bandwidth was a conducted captured when transmitting a packet ~30 bytes every 1 second.
    With our own spectrum analyzer, under a constant carrier transmission mode, we were measuring the following:
    The ANSI C63 recommends the settings for one of the methods of DTS bandwidth measurement as follows:
    RBW = 100kHz
    VBW >= 3 * RBW
    Detector = Peak
    Trace = Max hold
    Sweep = auto
    " Measure the maximum width of the emission that is constrained by the frequencies associated
    with the two outermost amplitude points (upper and lower frequencies) that are attenuated by
    6 dB relative to the maximum level measured in the fundamental emission."
    you can set the device (CC2530) to transmit a continuous modulated carrier.
    regards
  • We are consistently seeing a < 500kHz bandwidth even with continuous modulated carrier transmission.
    Is there something within cc2530 configuration that would produce this issue? Are there registers that I am setting incorrectly?
    Please see if your radio settings are consistent with the SmartRF studio settings for CC2530.
    Following is the 6dB BW plot of one of our CC2530 EM modules.
    We have been using SmartRF Studio settings for the CC2530 with CC2592 range extender and we still see the same result under the continuous unmodulated tx. With the continuous modulated tx... i believe we are seeing better results. See below:
    NOTE: I have to adjust the following registers in order to get an output transmission from the RF studio:
    RFC_OBS_CTRL0 = 0x68
    RFC_OBS_CTRL1 = 0x6a
    OBSSEL2 = 0xfb
    OBSSEL3 = 0xfc
    I believe this is a result of the GPIO interface with the cc2592.
    Are there any other registers I should pay particular close attention to? All other registers appear to have same values.
    When I change transmission from unmodulated continuous to modulated continuous, we get the following result:
  • Thank you yes we were already using those register values in the app note provided.
    I was able to increase the bandwidth by adjusting the following registers:
    MDMCTRL0 = 0x85; MDMCTRL1 = 0x14; MDMTEST0 = 0xb1; MDMTEST1 = 0x08;
    From the image above, you can see the bandwidth is now ~2MHz. Is it possible to adjust the bandwidth closer to 500 kHz? Would the MDMCTRL/MDMTEST registers be the only place to adjust this? Or should I not be adjusting these register values.
    Thank you for your help,
    I think this is the best you can do with the settings ( which are already optimal).
    You could try to set MDMCTRL0.TX_FILTER = 0x0 which will enable normal IEEE filtering but it will also degrade out-of-band emissions.
    regards
