SonOff dongle CC2562P doesn't enter in bootloader mode.
Other Parts Discussed in Thread: UNIFLASH, CCSTUDIO
I've bought a SonOff ZigBee 3.0 Dongle with a CC2562P that has a Silicon Labs UART to USB Bridge.
It used to be working correctly, flashing on it without any problem but from the last time I flashed it (with the correct firmware), it doesn't enter in bootloading mode anymore ( I've tried holding that damn BOOT button many times)
I've tried to mass erase the dongle using Flash Programmer 2 but can't seem to erase it, can't even connect to it.
Don't know what to do.
>Initiate access to target: COM3 using 2-pin cJTAG.
>No response from device. Device may not be in bootloader mode. Reset device and try again.
If problem persists, check connection and baud rate.
>Connecting over serial bootloader failed: No response from device. Device may not be in bootloader mode. Reset device and try again.
>Failed to create device object.
