Part Number: CC2530
Other Parts Discussed in Thread: Z-STACK
Hi team,
Here's 2 issues from the customer may need your help:
zstack version: 2.5.1a. And the attached message is as follows:
1. When will the NWK route request message be sent? The coordinator's NWK link status message has the routing table entries for both terminals 0x0001 and 0x584a, but the coordinator is still sending the router request to both terminals. Is there a problem with the stack setup? (Using another manufacturer's coordinator, the data is good, and the packet grab found no router request message.)
2. From the upper application, both 0x0001 and 0x584a terminals do not respond to the Route reply message. However, the upper 0x584a terminal data shows good and the 0x0001 terminal does not interact properly with the coordinator data. (The coordinator is always sending the router request to both of them)
Could you help check this case? Thanks.
Cherry
