Other Parts Discussed in Thread: Z-STACK
Hello everyone,
I've been working on a zigbee network consisting of one coordinator(TI coordinator module) and two router devices, a dimmer and a touch a keypad to control that dimmer, both from same manufacturer(not TI). I'm using Z-Tool v2.0.6 and Z-Stack version is 2.7.1
I'm stuck, so I've some question that I've asked below.
I've also attached the logs.
N/W & IEEE address(Dimmer): 0xDC1D, 0x000D6F000C6B7662
N/W & IEEE address(Keypad): 0x7357, 0x000D6F000207B1D6
Start Time: 2/1/2022 7:38:55 PM
<TX>07:39:28.48 COM7 SYS_OSAL_NV_WRITE (0x2109)
Offset: 0x00
Len: 0x01
Value: . (0x03)
<RX>07:39:28.51 COM7 SYS_OSAL_NV_WRITE_SRSP (0x6109)
Status: SUCCESS (0x0)
<TX>07:39:30.11 COM7 SYS_RESET (0x4100)
Type: 0x01 (SOFT RESET) (0x1)
<RX>07:39:36.7 COM7 SYS_RESET_RESPONSE (0x4180)
Reason: 0x02
TransportRev: 0x02
Product: 0x00
MajorRel: 0x02
MinorRel: 0x06
HwRev: 0x03
<TX>07:41:34 COM7 SYS_OSAL_NV_WRITE (0x2109)
Offset: 0x00
Len: 0x01
Value: . (0x01)
<RX>07:41:34.01 COM7 SYS_OSAL_NV_WRITE_SRSP (0x6109)
<TX>07:41:45.09 COM7 ZB_START_REQUEST (0x2600)
<RX>07:41:45.85 COM7 ZB_START_REQUEST_RSP (0x6600)
<RX>07:41:45.85 COM7 ZDO_STATE_CHANGE_IND (0x45C0)
State: 8 (0x8)
<RX>07:41:46.35 COM7 ZDO_STATE_CHANGE_IND (0x45C0)
State: 8 (0x8)
<RX>07:41:46.86 COM7 ZDO_STATE_CHANGE_IND (0x45C0)
State: 8 (0x8)
<RX>07:41:47.38 COM7 ZDO_STATE_CHANGE_IND (0x45C0)
State: 8 (0x8)
<RX>07:41:48.4 COM7 ZDO_STATE_CHANGE_IND (0x45C0)
State: 9 (0x9)
>>>>>>>>>> I gave the JOIN(as stated on the remote key) command to both the routers from the remote provided by the manufacturer and both the device(router) joins the network. Below are the logs that shows the indication.
(Also, the coordinator receives some messages, when I now press the keys on keypad, but could not show it since I've not registered the AF on coordinator)
Q 1: Are these devices got binded to the coordinator or they just joined the zigbee network?
*** WARNING ***
Unsupported or unformatted message received. Raw data:
0C 45 CA 57 73 D6 B1 07 02 00 6F 0D 00 00 00
<RX>07:42:14.66 COM7 ZDO_END_DEVICE_ANNCE_IND (0x45C1)
SrcAddr: 0x7357
NwkAddr: 0x7357
IEEEAddr: 0x000D6F000207B1D6
Capabilities: 0x8E
*** WARNING ***
0C 45 CA 1D DC 62 76 6B 0C 00 6F 0D 00 00 00
<RX>07:42:17.76 COM7 ZDO_END_DEVICE_ANNCE_IND (0x45C1)
SrcAddr: 0xDC1D
NwkAddr: 0xDC1D
IEEEAddr: 0x000D6F000C6B7662
Capabilities: 0x8E
>>>>>>>>>>> Below are the logs to show the forum the active EPs and Simple Descriptor of all those EPs of both the router devices.
<TX>07:42:48.51 COM7 ZDO_ACTIVE_EP_REQ (0x2505)
DstAddr: 0x7357
NWKAddrOfInterest: 0x7357
<RX>07:42:48.53 COM7 ZDO_ACTIVE_EP_REQ_SRSP (0x6505)
Status: afStatus_SUCCESS (0x0)
<RX>07:42:48.54 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0x7357
Relay Count: 0x00
Relay List
<RX>07:42:48.6 COM7 ZDO_ACTIVE_EP_RSP (0x4585)
SrcAddr: 0x7357
Status: ZDP_SUCCESS (0x0)
NwkAddr: 0x7357
ActiveEPCount: 0x03
ActiveEPList: ... (0x01, 0x02, 0xC4)
<TX>07:43:10.37 COM7 ZDO_ACTIVE_EP_REQ (0x2505)
DstAddr: 0xDC1D
NWKAddrOfInterest: 0xDC1D
<RX>07:43:10.39 COM7 ZDO_ACTIVE_EP_REQ_SRSP (0x6505)
<RX>07:43:10.41 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0xDC1D
Relay Count: 0x00
Relay List
<RX>07:43:10.45 COM7 ZDO_ACTIVE_EP_RSP (0x4585)
SrcAddr: 0xDC1D
NwkAddr: 0xDC1D
ActiveEPCount: 0x03
<TX>07:43:46.44 COM7 ZDO_SIMPLE_DESC_REQ (0x2504)
DstAddr: 0x7357
Endpoint: 0x01
<RX>07:43:46.46 COM7 ZDO_SIMPLE_DESC_REQ_SRSP (0x6504)
<RX>07:43:46.47 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0x7357
Relay Count: 0x00
Relay List
<RX>07:43:46.52 COM7 ZDO_SIMPLE_DESC_RSP (0x4584)
SrcAddr: 0x7357
NwkAddr: 0x7357
Len: 0x0A
Endpoint: 0x01
ProfileID: 0x0104
DeviceID: 0x0101
DeviceVersion: VER_100 (0x0)
NumInClusters: 0x00
InClusterList
NumOutClusters: 0x01
OutClusterList: 0x0019
<TX>07:43:53.05 COM7 ZDO_SIMPLE_DESC_REQ (0x2504)
DstAddr: 0x7357
Endpoint: 0x02
<RX>07:43:53.06 COM7 ZDO_SIMPLE_DESC_REQ_SRSP (0x6504)
<RX>07:43:53.08 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0x7357
Relay Count: 0x00
Relay List
<RX>07:43:53.13 COM7 ZDO_SIMPLE_DESC_RSP (0x4584)
SrcAddr: 0x7357
NwkAddr: 0x7357
Len: 0x0A
Endpoint: 0x02
ProfileID: 0xC25D
DeviceID: 0x0001
NumInClusters: 0x01
InClusterList: 0x0001
NumOutClusters: 0x00
OutClusterList
<TX>07:43:58.68 COM7 ZDO_SIMPLE_DESC_REQ (0x2504)
DstAddr: 0x7357
Endpoint: 0xC4
<RX>07:43:58.7 COM7 ZDO_SIMPLE_DESC_REQ_SRSP (0x6504)
<RX>07:43:58.71 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0x7357
Relay Count: 0x00
Relay List
<RX>07:43:58.76 COM7 ZDO_SIMPLE_DESC_RSP (0x4584)
SrcAddr: 0x7357
NwkAddr: 0x7357
Len: 0x0A
Endpoint: 0xC4
ProfileID: 0xC25D
DeviceID: 0x0001
NumInClusters: 0x01
OutClusterList
<TX>07:44:19.14 COM7 ZDO_SIMPLE_DESC_REQ (0x2504)
DstAddr: 0xDC1D
Endpoint: 0x01
<RX>07:44:19.15 COM7 ZDO_SIMPLE_DESC_REQ_SRSP (0x6504)
<RX>07:44:19.17 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0xDC1D
Relay Count: 0x00
Relay List
<RX>07:44:19.22 COM7 ZDO_SIMPLE_DESC_RSP (0x4584)
SrcAddr: 0xDC1D
NwkAddr: 0xDC1D
Len: 0x0A
Endpoint: 0x01
ProfileID: 0x0104
DeviceID: 0x0101
NumInClusters: 0x00
InClusterList
<TX>07:44:25.7 COM7 ZDO_SIMPLE_DESC_REQ (0x2504)
DstAddr: 0xDC1D
Endpoint: 0x02
<RX>07:44:25.71 COM7 ZDO_SIMPLE_DESC_REQ_SRSP (0x6504)
<RX>07:44:25.73 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0xDC1D
Relay Count: 0x00
Relay List
<RX>07:44:25.77 COM7 ZDO_SIMPLE_DESC_RSP (0x4584)
SrcAddr: 0xDC1D
NwkAddr: 0xDC1D
Len: 0x0A
Endpoint: 0x02
ProfileID: 0xC25D
DeviceID: 0x0001
NumInClusters: 0x01
OutClusterList
<TX>07:44:40.92 COM7 ZDO_SIMPLE_DESC_REQ (0x2504)
DstAddr: 0xDC1D
Endpoint: 0xC4
<RX>07:44:40.93 COM7 ZDO_SIMPLE_DESC_REQ_SRSP (0x6504)
<RX>07:44:40.95 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0xDC1D
Relay Count: 0x00
Relay List
<RX>07:44:41 COM7 ZDO_SIMPLE_DESC_RSP (0x4584)
SrcAddr: 0xDC1D
NwkAddr: 0xDC1D
Len: 0x0A
Endpoint: 0xC4
ProfileID: 0xC25D
DeviceID: 0x0001
NumInClusters: 0x01
OutClusterList
>>>>>> Sending AF-REGISTER to coordinator to see the received messages on the Z-Tool screen whenever I press the keypad.
Also FYI, whenever I want to control the dimmer(control bulb's brightness) or keypad(key press through commands) through coordinator, I need to send messages to EP 2 on both the devices but , when i receive messages from keypad or dimmer the messages shows the the source and dest EP as 1(shown in logs below).
Q2: WHY SO??
Also, when I send control commands from coordinator, the cluster ID that I pass is 0x009A(because only that cluster id could control the dimmer and keypad and the AF_INCOMING_MSG also shows the ClusterID =0x009A).
<TX>07:45:04.07 COM7 AF_REGISTER (0x2400)
EndPoint: 0x01
AppProfID: 0x0104
AppDeviceId: 0x0000
AppDevVer: 0x00
LatencyReq: NO_LATENCY_REQS (0x0)
AppNumInClusters: 0x09
AppInClusterList: 0x0000, 0x0001, 0x0003, 0x0006, 0x0008, 0x009A, 0x0004, 0x0005, 0x0007
AppNumOutClusters: 0x09
AppOutClusterList: 0x0000, 0x0001, 0x0003, 0x0006, 0x0008, 0x009A, 0x0004, 0x0005, 0x0007
<RX>07:45:04.08 COM7 AF_REGISTER_SRSP (0x6400)
<TX>07:45:08.74 COM7 AF_REGISTER (0x2400)
EndPoint: 0x02
AppProfID: 0x0104
AppDeviceId: 0x0000
AppDevVer: 0x00
<RX>07:45:08.76 COM7 AF_REGISTER_SRSP (0x6400)
>>>>>> Now I want to control the dimmer through keypad, so in my opinion I should bind the EP2 on keypad to EP2 on dimmer(since the communication occurs on EP2 on both devices when i send the control commands from coordinator). But, when I try to bind the EP on both the devices, only EP1 on keypad gets binded to EP2 on dimmer(Binding EP2 on both does not shows ZDP_SUCCESS), and still I cannot control the dimmer from the keypad.
Q3: Can anybody please guide me on where I'm wrong. I'm stuck, please help.
<TX>07:46:04.19 COM7 ZDO_BIND_REQ (0x2521)
DstAddr: 0x7357
SrcAddress: 0x000D6F000207B1D6
SrcEndpoint: 0x01
ClusterID: 0x0001
BindAddrMode: 0x03 (ADDRESS_64_BIT) (0x3)
BindAddr: bvk..o.. (0x62, 0x76, 0x6B, 0x0C, 0x00, 0x6F, 0x0D, 0x00)
BindEndpoint: 0x02
<RX>07:46:04.21 COM7 ZDO_BIND_REQ_SRSP (0x6521)
<RX>07:46:04.22 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0x7357
Relay Count: 0x00
Relay List
<RX>07:46:04.28 COM7 ZDO_BIND_RSP (0x45A1)
SrcAddr: 0x7357
<RX>07:46:08.57 COM7 ZDO_SRC_RTG_IND (0x45C4)
DstAddr: 0x7357
Relay Count: 0x00
Relay List
<RX>07:46:23.78 COM7 AF_INCOMING_MSG (0x4481)
GroupID: 0x0000
ClusterID: 0x009A
SrcAddr: 0x7357
SrcEndpoint: 0x01
DstEndpoint: 0x01
WasBroadcast: 0x00
LinkQuality: 0x9C
SecurityUse: 0x00
Timestamp: 0x00137620
TransSeqNumber: 0x00
Len: 0x05
Data: .x... (0x11, 0x78, 0xCF, 0x06, 0x00)
I just want to know if I'm wrong anywhere or there is something wrong with the dimmer and keypad.
I would be thankful to anybody who could be of any help.
