LP-CC2652RB: Trouble reporting attributes
Part Number: LP-CC2652RB
Other Parts Discussed in Thread: SYSCONFIG, Z-STACK
my device is supposed to periodically report measurements, just like the temperature sensor. I have configured the cluster in Z-Stack sysconfig, and I have a routine that periodically takes correct measurements. In this routine I have copied the report code that is used in the temperature example. However there are no ZCL report packets coming from the device.
This is the code I use for reporting:
// Read Temperature
sensor_TemperatureMeasurement_MeasuredValue = Temperature_getTemperature() * 100;
// report temperature
zstack_bdbRepChangedAttrValueReq_t tempReq;
tempReq.attrID = ATTRID_TEMPERATURE_MEASUREMENT_MEASURED_VALUE;
tempReq.cluster = ZCL_CLUSTER_ID_MS_TEMPERATURE_MEASUREMENT;
tempReq.endpoint = SENSOR_ENDPOINT;
Zstackapi_bdbRepChangedAttrValueReq(sensor_serviceTaskId,&tempReq);
I am quite sure there is something simple I am missing ... thank you!
