Part Number: CC2538
Other Parts Discussed in Thread: CC2592, Z-STACK
Hi team,
Here's an issue from the customer may need your help:
Board: CC2538+CC2592
After entering PM3 mode, the data is sent by waking up with a key, but the data is not received by the coordinator. The same program, without POWER_SAVING, everything works. Confirm that the data has indeed been sent. Z-Stack 3.0.2 is used.
Compile Options:
BDB_REPORTING
ewarm
CC2538_USE_ALTERNATE_INTERRUPT_MAP=1
FEATURE_RESET_MACRO
SECURE=1
TC_LINKKEY_JOIN
NV_INIT
NV_RESTORE
POWER_SAVING
NWK_AUTO_POLL
xZTOOL_P1
xMT_TASK
xMT_APP_FUNC
xMT_SYS_FUNC
xMT_ZDO_FUNC
xMT_APP_CNF_FUNC
xLCD_SUPPORTED=DEBUG
MULTICAST_ENABLED=FALSE
ZCL_READ
ZCL_DISCOVER
ZCL_WRITE
ZCL_BASIC
ZCL_IDENTIFY
ZCL_ON_OFF
ZCL_GROUPS
Configuration:
-DRFD_RCVC_ALWAYS_ON=FALSE
-DPOLL_RATE=0
-DQUEUED_POLL_RATE=0
-DRESPONSE_POLL_RATE=0
The customer would like to know if using the power-save mode for the terminal, what modifications does the coordinator need to make? How to configure the code?
Could you help check this case? Thanks.
Cherry
