Other Parts Discussed in Thread: Z-STACK
Is there any problem if two close network have the same network key like possibly happen that a device joins the other network, or it doesn't cause any problem?
Hi Luca,
Device associations and packet processing are based on Pan ID filtering so although not recommended for security purposes, having two nearby networks on the same channel using the same network key should not be an issue.
Ryan
Thank you so much Ryan.
I imagine Z-Stack has some sort of PAN-ID conflict algorithm. I don't this is possible for two, close-by, network devices to have Same PAN-ID.
This is covered in the pan-id-conflict section of the Z-Stack User's Guide.
Ryan
