Part Number: CC2652R7
Other Parts Discussed in Thread: Z-STACK
I am developing an sample application based on zclSampleThermostat, I have created an new event in this which is having a mask of 0x8000, i was surprise even I am not setting the event my code under zclSampleThermostat_process_loop come across the event that matches with bit mask 0x8000.
i thought it was may be memory corruption in appServiceTaskEvents variable, but that was not the case, an method "OsalPort_msgReceive" is setting this event as it was also using event mask 0x8000 for OsalPort_SYS_EVENT_MSG.
i want to understand the usage of this, and by it is overlapped with application event mask.
can i give it a new value that will be 0x80000000.
#define OsalPort_SYS_EVENT_MSG 0x80000000 // in place of 0x8000
jagdish K
