CC2530: Cannot erase/unlock the chip, shows some signs of life though (custom board with E18-MS1-IPX)
Part Number: CC2530
Dear community,
I have a custom board based on E18-MS1-IPX (datasheet) and a programming adapter based on the circuit in chapter 4 of the datasheet. When using cc-tool (OSX), I am able to show the target and board info, read eeprom data and seemingly write a hex file.
$ ./cc-tool -t
  Programmer: CC Debugger
  Target: CC2530
  Device info:
   Debugger ID: 4263
   Version: 0x05CC
   Revision: 0x0044
  Target info:
   Revision: 0x24
   Internal ID: 0xA5
   Flash size: 256 KB
   Flash page size: 2
   RAM size: 8 KB
   Lock data size: 16 B
$ ./cc-tool -i
  Target: CC2530
  Reading info page...
  Completed (0.96 s.)
  Information page (2048 B):
C4FBFFA52FFFFFFF010101012BF71D27004B1200FFFFFFFFFFFFFFFF96175880321757D07FFC6C34
5070FAFA16AC64C015185E44000506FA00020689FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5001FDFF52EEFDDF571E6D9F52E2CDE
D52EFFCEB52E3CC4952ED1B6752EEFAB552EBC9C352E418A152E277CFFFFFFFFFFFFFFFFFFFFFFFF
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
FFFFFFFF89711DFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E9AFFFF1828C55C
3201A35EAA55AA55
The cc-tool refuses to validate and fails when I'm trying to erase the chip:
$ ./cc-tool -e -w ~/Downloads/CC2531_DEFAULT_20211115/CC2531ZNP-Prod.bin -v
  Target: CC2530
  Erasing flash...
  Completed
  Writing flash (234 KB)...
  Completed (16.42 s.)
  Verifying flash...
  Failed
$ ./cc-tool -e
  Target: CC2530
  Target is locked.
  Erasing flash...
  Failed
  Unit is still locked after erasing
When searching this forum, I found few possible causes
  1. the power - I am powering the module using 3.3V on pins 1 and 2, not from the debugger
  2. pullup on DD - tried with 1K and without it, same results
  3. filter on RST - haven't tried yet, it was mentioned for other CCs though
I may try to scope the DC and DD lines and show these to you guys if it helps.
I'm also not sure about the module, I was reflowing it several times until soldered properly, so I might have destroyed it - looks intact to me though and it responds to some commands, so should not be dead, or?
So I wonder whether some of you have experience with the E18-MS1 board specifically, it may require some extra care?
-jp
