Part Number: LAUNCHXL-CC1352R1
Other Parts Discussed in Thread: CC1352R
I am trying to build a cc1352r project using CMake and GCC since CMake support was sort of added in simplelink sdk v6. However, I can't avoid getting the following error:#error "When compiling with TI-POSIX, you must define -std=c99 (or later). You must not define _POSIX_SOURCE or _POSIX_C_SOURCE."
In the attachment, you can find a full build log output. Any ideas on how to solve this?
Aleksa
aleksa@aleksa:~/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/examples/nortos/CC1352R1_LAUNCHXL/drivers/cmake_sample/uart2echo_rtos/build$ make
[ 33%] Building C object CMakeFiles/uart2echo.elf.dir/tirtos7/main_tirtos.c.o
In file included from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/pthread.h:47:0,
from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/examples/nortos/CC1352R1_LAUNCHXL/drivers/cmake_sample/uart2echo_rtos/tirtos7/main_tirtos.c:40:
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:73:2: error: #error "When compiling with TI-POSIX, you must define -std=c99 (or later). You must not define _POSIX_SOURCE or _POSIX_C_SOURCE."
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:92:3: error: conflicting types for 'pthread_attr_t'
} pthread_attr_t;
In file included from /home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/types.h:239:0,
from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:49,
from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/pthread.h:47,
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:75:3: note: previous declaration of 'pthread_attr_t' was here
} pthread_attr_t;
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:95:18: error: conflicting types for 'pthread_condattr_t'
typedef uint32_t pthread_condattr_t;
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:186:3: note: previous declaration of 'pthread_condattr_t' was here
} pthread_condattr_t; /* a condition attribute object */
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:97:15: error: conflicting types for 'pthread_key_t'
typedef void *pthread_key_t;
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:190:20: note: previous declaration of 'pthread_key_t' was here
typedef __uint32_t pthread_key_t; /* thread-specific data keys */
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:103:3: error: conflicting types for 'pthread_mutexattr_t'
} pthread_mutexattr_t;
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:169:3: note: previous declaration of 'pthread_mutexattr_t' was here
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:107:15: error: conflicting types for 'pthread_t'
typedef void *pthread_t;
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:32:20: note: previous declaration of 'pthread_t' was here
typedef __uint32_t pthread_t; /* identify a thread */
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:117:3: error: conflicting types for 'pthread_cond_t'
} pthread_cond_t;
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:176:20: note: previous declaration of 'pthread_cond_t' was here
typedef __uint32_t pthread_cond_t; /* identify a condition variable */
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:122:3: error: conflicting types for 'pthread_mutex_t'
} pthread_mutex_t;
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:154:20: note: previous declaration of 'pthread_mutex_t' was here
typedef __uint32_t pthread_mutex_t; /* identify a mutex */
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sys/types.h:124:18: error: conflicting types for 'pthread_once_t'
typedef uint32_t pthread_once_t;
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:195:3: note: previous declaration of 'pthread_once_t' was here
} pthread_once_t; /* dynamic package initialization */
In file included from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/time.h:51:0,
from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/pthread.h:48,
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/signal.h:76:7: error: redefinition of 'union sigval'
union sigval {
In file included from /home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/signal.h:6:0,
from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/signal.h:48,
from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/time.h:51,
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/signal.h:42:7: note: originally defined here
union sigval {
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/signal.h:90:8: error: redefinition of 'struct sigevent'
struct sigevent {
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/signal.h:47:8: note: originally defined here
struct sigevent {
In file included from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/pthread.h:49:0,
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/sched.h:71:8: error: redefinition of 'struct sched_param'
struct sched_param {
In file included from /home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:23:0,
from /home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/types.h:239,
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/sched.h:48:8: note: originally defined here
In file included from /home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/examples/nortos/CC1352R1_LAUNCHXL/drivers/cmake_sample/uart2echo_rtos/tirtos7/main_tirtos.c:40:0:
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/pthread.h:57:0: warning: "PTHREAD_CREATE_JOINABLE" redefined
#define PTHREAD_CREATE_JOINABLE 0
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:47:0: note: this is the location of the previous definition
#define PTHREAD_CREATE_JOINABLE 1
/home/aleksa/ti/simplelink_cc13xx_cc26xx_sdk_6_40_00_13/source/ti/posix/gcc/pthread.h:58:0: warning: "PTHREAD_CREATE_DETACHED" redefined
#define PTHREAD_CREATE_DETACHED 1
/home/aleksa/ti/ccs1040/ccs/tools/compiler/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/sys/_pthreadtypes.h:46:0: note: this is the location of the previous definition
#define PTHREAD_CREATE_DETACHED 0
make[2]: *** [CMakeFiles/uart2echo.elf.dir/build.make:76: CMakeFiles/uart2echo.elf.dir/tirtos7/main_tirtos.c.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:83: CMakeFiles/uart2echo.elf.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
