Part Number: CC2652R7
I am trying to build and run chip-tool application from Raspberry Pi 4, with Ubuntu 22.04 Desktop version as the operating system. I followed the steps from here https://github.com/project-chip/connectedhomeip/blob/master/docs/guides/chip_tool_guide.md#multi-admin-scenario .but when i try to run this command ./scripts/examples/gn_build_example.sh examples/chip-tool BUILD_PATH i get the following error:
Activating environment (setting environment variables):
Setting environment variables for CIPD package manager...done
Setting environment variables for Python environment.....done
Setting environment variables for pw packages............skipped
Setting environment variables for Host tools.............done
Checking the environment:
20230307 15:33:01 INF Environment passes all checks!
Environment looks good, you are ready to go!
+ env
SHELL=/bin/bash
SESSION_MANAGER=local/resi-matter-desktop:@/tmp/.ICE-unix/2302,unix/resi-matter-desktop:/tmp/.ICE-unix/2302
QT_ACCESSIBILITY=1
COLORTERM=truecolor
XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/etc/xdg
SSH_AGENT_LAUNCHER=gnome-keyring
XDG_MENU_PREFIX=gnome-
GNOME_DESKTOP_SESSION_ID=this-is-deprecated
LANGUAGE=en_IN:en
GNOME_SHELL_SESSION_MODE=ubuntu
SSH_AUTH_SOCK=/run/user/1000/keyring/ssh
PW_PROJECT_ROOT=/home/resi_matter/Desktop/Clone1/connectedhomeip
XMODIFIERS=@im=ibus
DESKTOP_SESSION=ubuntu
PW_ZAP_CIPD_INSTALL_DIR=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/zap
GTK_MODULES=gail:atk-bridge
PWD=/home/resi_matter/Desktop/Clone1/connectedhomeip
XDG_SESSION_DESKTOP=ubuntu
LOGNAME=resi_matter
XDG_SESSION_TYPE=wayland
SYSTEMD_EXEC_PID=3118
XAUTHORITY=/run/user/1000/.mutter-Xwaylandauth.YES901
PW_ROOT=/home/resi_matter/Desktop/Clone1/connectedhomeip/third_party/pigweed/repo
HOME=/home/resi_matter
USERNAME=resi_matter
IM_CONFIG_PHASE=1
LANG=en_IN
LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:mi=00:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arc=01;31:*.arj=01;31:*.taz=01;31:*.lha=01;31:*.lz4=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.tzo=01;31:*.t7z=01;31:*.zip=01;31:*.z=01;31:*.dz=01;31:*.gz=01;31:*.lrz=01;31:*.lz=01;31:*.lzo=01;31:*.xz=01;31:*.zst=01;31:*.tzst=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.alz=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.cab=01;31:*.wim=01;31:*.swm=01;31:*.dwm=01;31:*.esd=01;31:*.jpg=01;35:*.jpeg=01;35:*.mjpg=01;35:*.mjpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.webp=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.m4a=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.oga=00;36:*.opus=00;36:*.spx=00;36:*.xspf=00;36:
XDG_CURRENT_DESKTOP=ubuntu:GNOME
VIRTUAL_ENV=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/pigweed-venv
VTE_VERSION=6800
WAYLAND_DISPLAY=wayland-0
GNOME_TERMINAL_SCREEN=/org/gnome/Terminal/screen/609b86c0_f978_47ea_9c67_c14b633c55bf
PW_PYTHON_CIPD_INSTALL_DIR=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/python
_PW_ROSETTA=0
GNOME_SETUP_DISPLAY=:1
LESSCLOSE=/usr/bin/lesspipe %s %s
XDG_SESSION_CLASS=user
TERM=xterm-256color
LESSOPEN=| /usr/bin/lesspipe %s
USER=resi_matter
GNOME_TERMINAL_SERVICE=:1.103
DISPLAY=:0
SHLVL=2
QT_IM_MODULE=ibus
PW_PACKAGE_ROOT=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/packages
PW_ENVIRONMENT_ROOT=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment
_PW_ENVIRONMENT_CONFIG_FILE=/home/resi_matter/Desktop/Clone1/connectedhomeip/scripts/setup/environment.json
XDG_RUNTIME_DIR=/run/user/1000
PW_BRANDING_BANNER=/home/resi_matter/Desktop/Clone1/connectedhomeip/scripts/setup/banner.txt
_PW_ACTUAL_ENVIRONMENT_ROOT=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment
PW_ARM_CIPD_INSTALL_DIR=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/arm
XDG_DATA_DIRS=/usr/share/ubuntu:/usr/local/share/:/usr/share/:/var/lib/snapd/desktop
PATH=/home/resi_matter/Desktop/Clone1/connectedhomeip/third_party/pigweed/repo/out/host/host_tools:/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/pigweed-venv/bin:/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/arm/bin:/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/arm:/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/pigweed/bin:/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/pigweed:/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin
GDMSESSION=ubuntu
DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
PW_PIGWEED_CIPD_INSTALL_DIR=/home/resi_matter/Desktop/Clone1/connectedhomeip/.environment/cipd/packages/pigweed
OLDPWD=/home/resi_matter/Desktop/Clone1
_=/usr/bin/env
+ gn gen --check --fail-on-unused-args --root=examples/chip-tool BUILD_PATH --args=
Done. Made 232 targets from 210 files in 1657ms
+ ninja -C BUILD_PATH
ninja: Entering directory `BUILD_PATH'
[32/591] ACTION //third_party/connectedhomeip/src/controller/data_model:data_model_zapgen_zap_pregen(//third_party/connectedhomeip/build/toolchain/linux:linux_arm64_gcc)
FAILED: gen/third_party/connectedhomeip/src/controller/data_model/zap_pregen/zap-generated/access.h gen/third_party/connectedhomeip/src/controller/data_model/zap_pregen/zap-generated/gen_config.h gen/third_party/connectedhomeip/src/controller/data_model/zap_pregen/zap-generated/endpoint_config.h gen/third_party/connectedhomeip/src/controller/data_model/zap_pregen/zap-generated/CHIPClientCallbacks.h gen/third_party/connectedhomeip/src/controller/data_model/zap_pregen/zap-generated/CHIPClusters.h gen/third_party/connectedhomeip/src/controller/data_model/zap_pregen/zap-generated/IMClusterCommandHandler.cpp
python ../examples/chip-tool/third_party/connectedhomeip/third_party/pigweed/repo/pw_build/py/pw_build/python_runner.py --gn-root ../examples/chip-tool/ --current-path ../examples/chip-tool/third_party/connectedhomeip/src/controller/data_model --default-toolchain=//third_party/connectedhomeip/build/toolchain/linux:linux_arm64_gcc --current-toolchain=//third_party/connectedhomeip/build/toolchain/linux:linux_arm64_gcc --capture-output --python-dep-list-files gen/third_party/connectedhomeip/src/controller/data_model/data_model_zapgen_zap_pregen_metadata_path_list.txt -- ../examples/chip-tool/third_party/connectedhomeip/scripts/tools/zap/generate.py --no-prettify-output --templates /home/resi_matter/Desktop/Clone1/connectedhomeip/examples/chip-tool/third_party/connectedhomeip/src/app/zap-templates/app-templates.json --output-dir /home/resi_matter/Desktop/Clone1/connectedhomeip/BUILD_PATH/gen/third_party/connectedhomeip/src/controller/data_model/zap_pregen/zap-generated --lock-file /home/resi_matter/Desktop/Clone1/connectedhomeip/BUILD_PATH/zap_gen.lock --parallel /home/resi_matter/Desktop/Clone1/connectedhomeip/examples/chip-tool/third_party/connectedhomeip/src/controller/data_model/controller-clusters.zap
Searching for zcl file from /home/resi_matter/Desktop/Clone1/connectedhomeip/examples/chip-tool/third_party/connectedhomeip/src/controller/data_model/controller-clusters.zap
FAILED TO EXECUTE ZAP GENERATION: No such file or directory - "zap-cli"
* You may need to install zap. Please ensure one of these applies:
* - `zap-cli` is in $PATH. Install from github.com/.../releases
* see docs/guides/BUILDING.md for details
* - `zap-cli` is in $ZAP_INSTALL_PATH. Use this option if you
* installed zap but do not want to update $PATH
* - Point $ZAP_DEVELOPMENT_PATH to your local copy of zap that you
* develop on (to use a developer build of zap)
[37/591] ACTION //third_party/connectedhomeip/src/controller/data_model:data_model_codegen_codegen(//third_party/connectedhomeip/build/toolchain/linux:linux_arm64_gcc)
ninja: build stopped: subcommand failed.
Please let me know how to solve this issue.
Rajesh Krishnan
