[CC2652R7] example on TI git hub can't work (lighting-app)
Other Parts Discussed in Thread: LP-CC2652R7, CC2652R7
Hi TI,
 I am trying to let LP-CC2652R7 become an end device. My final goal list as below
  1. LP-CC2652R7 become an end device (lighting-app)
  2. UART Console shows the matter QR Code which use for join the thread.
I refer the TI GitHub and try to build the lighting-app example but console shows nothing after I flash the code
Is this example ready now? or do you have any suggest example which can reach my goal?
BR,
Mike
  • Hi Mike,
    I have verified that the LP-CC2652R7 lighting-app example works as expected.  Please be sure to erase all device memory and load the chip-LP_CC2652R7-lighting-example-bim.hex file from the out/debug folder since OTA is enabled by default (chip_enable_ota_requestor is true in the args.gni file).  Attached is the default example image which works on my LP-CC2652R7.
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/158/chip_2D00_LP_5F00_CC2652R7_2D00_lighting_2D00_example_2D00_bim.hex
    Ryan
  • Hi Ryan,
     Thanks for your reply. The code I build works  as expected now.
     I think the root cause is I didn't erase all device memory.
    BR,
    Mike
