CC2531: Network Backup java
Part Number: CC2531
Other Parts Discussed in Thread: Z-STACK, CC2652P, CC1350
Hi, i'm trying to build some java code to backup the dongle CC2531, in particular the state of the network. If a lose the key or it breaks, I want to restore it without making the pairing step of each device again.
I've spotted the library "com.zsmartsystems.zigbee", I want to try the console as explained in the doc of the library on github because it contains maybe the script to do what I want, but I'm not able to run it. When I start the console it breaks because the library sends some unknown packet to the dongle.
Here my logs
Initialising ZigBee console...
17:07:09.423  DEBUG  Default: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
17:07:09.423  DEBUG  Broadcast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=2, interTransactionDelay=4000, maxRetries=0]
17:07:09.423  DEBUG  Multicast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=3, interTransactionDelay=1200, maxRetries=0]
17:07:09.566  DEBUG  ZigBeeNetworkManager initialize: networkState=UNINITIALISED
17:07:09.566  DEBUG  Network state is updated to INITIALISING
ZigBee network state updated to INITIALISING
17:07:09.569  DEBUG  CC2531 transport initialize
17:07:09.569  DEBUG  Opening port COM60 at 115200 baud with FLOWCONTROL_OUT_NONE.
17:07:10.078  DEBUG  ->  SYS_RESET (Packet: subsystem=null, length=1, apiId=41 00, data=FE 01 41 00 01 41, checksum=41, error=false)
17:07:10.084  DEBUG  Discarded stream: expected start byte but received 00
17:07:11.654  DEBUG  <-- SYS_RESET_RESPONSE (FE 06 41 80 00 02 01 02 07 01 C0)
17:07:11.654  DEBUG  Received Async Cmd: Packet: subsystem=null, length=6, apiId=41 80, data=FE 06 41 80 00 02 01 02 07 01 C0, checksum=C0, error=false
17:07:11.655  DEBUG  ->  SYS_VERSION (Packet: subsystem=null, length=0, apiId=21 02, data=FE 00 21 02 23, checksum=23, error=false)
17:07:11.661  DEBUG  <-  SYS_VERSION_RESPONSE (FE 0A 61 02 02 01 02 07 01 14 64 34 01 00 2B)
17:07:11.661  DEBUG  CC2531 version is Software=2.7 Product=1 Hardware=1 Transport=2
17:07:11.662  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 01 20, checksum=20, error=false)
17:07:11.667  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:12.666  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:12.666  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 1]
17:07:13.682  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 01 20, checksum=20, error=false)
17:07:13.686  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:14.698  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:14.698  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 2]
17:07:15.717  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 01 20, checksum=20, error=false)
17:07:15.722  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:16.726  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:16.726  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 3]
17:07:16.726  WARN   Failed getDeviceInfo for 1 due to null value
networkManager.initialize returned SUCCESS
17:07:16.728  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 06 27, checksum=27, error=false)
17:07:16.733  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:17.729  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:17.729  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 1]
17:07:18.741  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 06 27, checksum=27, error=false)
17:07:18.746  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:19.751  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:19.751  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 2]
17:07:20.765  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 06 27, checksum=27, error=false)
17:07:20.770  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:21.765  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:21.765  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 3]
17:07:21.765  WARN   Failed getDeviceInfo for 6 due to null value
PAN ID          = 65535
17:07:21.765  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 07 26, checksum=26, error=false)
17:07:21.770  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:22.775  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:22.775  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 1]
17:07:23.777  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 07 26, checksum=26, error=false)
17:07:23.781  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:24.791  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:24.791  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 2]
17:07:25.804  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 07 26, checksum=26, error=false)
17:07:25.809  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:26.812  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:26.812  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 3]
17:07:26.812  WARN   Failed getDeviceInfo for 7 due to null value
Extended PAN ID = 0000000000000000
17:07:26.815  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 05 24, checksum=24, error=false)
17:07:26.821  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:27.824  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:27.824  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 1]
17:07:28.841  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 05 24, checksum=24, error=false)
17:07:28.845  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:29.857  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:29.857  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 2]
17:07:30.868  DEBUG  ->  ZB_GET_DEVICE_INFO (Packet: subsystem=null, length=1, apiId=26 06, data=FE 01 26 06 05 24, checksum=24, error=false)
17:07:30.873  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 06 42)
17:07:31.872  DEBUG  ZB_GET_DEVICE_INFO executed and timed out while waiting for response.
17:07:31.872  DEBUG  Failed to send ZB_GET_DEVICE_INFO [attempt 3]
17:07:31.872  WARN   Failed getDeviceInfo for 5 due to null value
Channel         = UNKNOWN
17:07:31.874  DEBUG  Default profile ID set to 0104 [ZIGBEE_HOME_AUTOMATION]
17:07:31.877  DEBUG  Unsupported configuration option "TRUST_CENTRE_JOIN_MODE" in CC2531 dongle
17:07:31.877  DEBUG  ->  SYS_SET_TX_POWER (Packet: subsystem=null, length=1, apiId=21 14, data=FE 01 21 14 03 37, checksum=37, error=false)
17:07:31.882  DEBUG  <-  ZToolPacket (FE 01 61 14 00 74)
17:07:31.883  DEBUG  Unsupported configuration option "TRUST_CENTRE_LINK_KEY" in CC2531 dongle
17:07:31.885  DEBUG  Adding supported client cluster 0500
17:07:31.887  DEBUG  ClusterMatcher starting for endpoint 1 with profile ID 0104 (ZIGBEE_HOME_AUTOMATION)
17:07:31.888  DEBUG  ClusterMatcher adding client cluster 0500
17:07:31.889  DEBUG  Adding supported server cluster 0019
17:07:31.889  DEBUG  ClusterMatcher adding server cluster 0019
17:07:31.891  DEBUG  Adding supported server cluster 0000
17:07:31.892  DEBUG  ClusterMatcher adding server cluster 0000
17:07:31.946  DEBUG  Adding supported client cluster 0000
17:07:31.947  DEBUG  ClusterMatcher adding client cluster 0000
17:07:31.947  DEBUG  Adding supported client cluster 0001
17:07:31.947  DEBUG  ClusterMatcher adding client cluster 0001
17:07:31.947  DEBUG  Adding supported client cluster 0003
17:07:31.947  DEBUG  ClusterMatcher adding client cluster 0003
17:07:31.947  DEBUG  Adding supported client cluster 0004
17:07:31.947  DEBUG  ClusterMatcher adding client cluster 0004
17:07:31.947  DEBUG  Adding supported client cluster 0005
17:07:31.947  DEBUG  ClusterMatcher adding client cluster 0005
17:07:31.948  DEBUG  Adding supported client cluster 0006
17:07:31.948  DEBUG  ClusterMatcher adding client cluster 0006
17:07:31.948  DEBUG  Adding supported client cluster 0008
17:07:31.948  DEBUG  ClusterMatcher adding client cluster 0008
17:07:31.948  DEBUG  Adding supported client cluster 000F
17:07:31.948  DEBUG  ClusterMatcher adding client cluster 000F
17:07:31.948  DEBUG  Adding supported client cluster 0019
17:07:31.948  DEBUG  ClusterMatcher adding client cluster 0019
17:07:31.948  DEBUG  Adding supported client cluster 0020
17:07:31.949  DEBUG  ClusterMatcher adding client cluster 0020
17:07:31.949  DEBUG  Adding supported client cluster 0102
17:07:31.949  DEBUG  ClusterMatcher adding client cluster 0102
17:07:31.949  DEBUG  Adding supported client cluster 0201
17:07:31.949  DEBUG  ClusterMatcher adding client cluster 0201
17:07:31.949  DEBUG  Adding supported client cluster 0300
17:07:31.949  DEBUG  ClusterMatcher adding client cluster 0300
17:07:31.949  DEBUG  Adding supported client cluster 0301
17:07:31.949  DEBUG  ClusterMatcher adding client cluster 0301
17:07:31.949  DEBUG  Adding supported client cluster 03E8
17:07:31.950  DEBUG  ClusterMatcher adding client cluster 03E8
17:07:31.950  DEBUG  Adding supported client cluster 0402
17:07:31.950  DEBUG  ClusterMatcher adding client cluster 0402
17:07:31.950  DEBUG  Adding supported client cluster 0403
17:07:31.950  DEBUG  ClusterMatcher adding client cluster 0403
17:07:31.950  DEBUG  Adding supported client cluster 0500
17:07:31.950  DEBUG  ClusterMatcher adding client cluster 0500
17:07:31.951  DEBUG  Adding supported client cluster 0702
17:07:31.951  DEBUG  ClusterMatcher adding client cluster 0702
17:07:31.951  DEBUG  Adding supported client cluster 0B04
17:07:31.951  DEBUG  ClusterMatcher adding client cluster 0B04
17:07:31.951  DEBUG  Adding supported client cluster 0B05
17:07:31.951  DEBUG  ClusterMatcher adding client cluster 0B05
17:07:31.952  DEBUG  Adding supported server cluster 0000
17:07:31.952  DEBUG  ClusterMatcher adding server cluster 0000
17:07:31.952  DEBUG  Adding supported server cluster 0001
17:07:31.952  DEBUG  ClusterMatcher adding server cluster 0001
17:07:31.953  DEBUG  Adding supported server cluster 0003
17:07:31.953  DEBUG  ClusterMatcher adding server cluster 0003
17:07:31.953  DEBUG  Adding supported server cluster 0004
17:07:31.953  DEBUG  ClusterMatcher adding server cluster 0004
17:07:31.953  DEBUG  Adding supported server cluster 0005
17:07:31.953  DEBUG  ClusterMatcher adding server cluster 0005
17:07:31.953  DEBUG  Adding supported server cluster 0006
17:07:31.954  DEBUG  ClusterMatcher adding server cluster 0006
17:07:31.954  DEBUG  Adding supported server cluster 0008
17:07:31.954  DEBUG  ClusterMatcher adding server cluster 0008
17:07:31.954  DEBUG  Adding supported server cluster 000F
17:07:31.954  DEBUG  ClusterMatcher adding server cluster 000F
17:07:31.954  DEBUG  Adding supported server cluster 0019
17:07:31.954  DEBUG  ClusterMatcher adding server cluster 0019
17:07:31.954  DEBUG  Adding supported server cluster 0020
17:07:31.955  DEBUG  ClusterMatcher adding server cluster 0020
17:07:31.955  DEBUG  Adding supported server cluster 0102
17:07:31.955  DEBUG  ClusterMatcher adding server cluster 0102
17:07:31.955  DEBUG  Adding supported server cluster 0300
17:07:31.955  DEBUG  ClusterMatcher adding server cluster 0300
17:07:31.955  DEBUG  Adding supported server cluster 0301
17:07:31.955  DEBUG  ClusterMatcher adding server cluster 0301
17:07:31.955  DEBUG  Adding supported server cluster 03E8
17:07:31.956  DEBUG  ClusterMatcher adding server cluster 03E8
17:07:31.956  DEBUG  Adding supported server cluster 0402
17:07:31.956  DEBUG  ClusterMatcher adding server cluster 0402
17:07:31.956  DEBUG  Adding supported server cluster 0403
17:07:31.956  DEBUG  ClusterMatcher adding server cluster 0403
17:07:31.956  DEBUG  Adding supported server cluster 0500
17:07:31.956  DEBUG  ClusterMatcher adding server cluster 0500
17:07:31.956  DEBUG  Adding supported server cluster 0702
17:07:31.956  DEBUG  ClusterMatcher adding server cluster 0702
17:07:31.957  DEBUG  Adding supported server cluster 0B04
17:07:31.957  DEBUG  ClusterMatcher adding server cluster 0B04
17:07:31.957  DEBUG  Adding supported server cluster 0B05
17:07:31.957  DEBUG  ClusterMatcher adding server cluster 0B05
17:07:31.957  DEBUG  ZigBeeNetworkManager startup: reinitialize=false, networkState=INITIALISING
17:07:31.957  DEBUG  CC2531 transport startup
17:07:31.958  DEBUG  Creating network as Coordinator
17:07:31.958  DEBUG  ->  ZDO_MSG_CB_REGISTER (Packet: subsystem=null, length=2, apiId=25 3E, data=FE 02 25 3E FF FF 19, checksum=19, error=false)
17:07:31.962  DEBUG  <-  ZDO_MSG_CB_REGISTER_SRSP (FE 01 65 3E 00 5A)
17:07:31.963  DEBUG  ->  ZB_WRITE_CONFIGURATION (Packet: subsystem=null, length=3, apiId=26 05, data=FE 03 26 05 8F 01 01 AF, checksum=AF, error=false)
17:07:31.967  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 05 41)
17:07:32.973  DEBUG  ZB_WRITE_CONFIGURATION executed and timed out while waiting for response.
17:07:32.973  DEBUG  Failed to send ZB_WRITE_CONFIGURATION [attempt 1]
17:07:33.985  DEBUG  ->  ZB_WRITE_CONFIGURATION (Packet: subsystem=null, length=3, apiId=26 05, data=FE 03 26 05 8F 01 01 AF, checksum=AF, error=false)
17:07:33.990  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 05 41)
17:07:34.991  DEBUG  ZB_WRITE_CONFIGURATION executed and timed out while waiting for response.
17:07:34.991  DEBUG  Failed to send ZB_WRITE_CONFIGURATION [attempt 2]
17:07:36.018  DEBUG  ->  ZB_WRITE_CONFIGURATION (Packet: subsystem=null, length=3, apiId=26 05, data=FE 03 26 05 8F 01 01 AF, checksum=AF, error=false)
17:07:36.022  DEBUG  <-  SYS_RPC_ERROR (FE 03 60 00 01 26 05 41)
17:07:37.019  DEBUG  ZB_WRITE_CONFIGURATION executed and timed out while waiting for response.
17:07:37.019  DEBUG  Failed to send ZB_WRITE_CONFIGURATION [attempt 3]
17:07:37.019  ERROR  Failed to start zigbee network.
17:07:37.020  INFO   Serial port 'COM60' closed.
Could someone help me ?
  • Which Z-Stack version do you run on CC2531? If you don’t use Z-Stack 3.0.2, I would suggest you to use it to test again.
  • Hi Morgan,
    The CC2531 device seems to be in a faulty state given that every command after SYS_VERSION fails.  Consider clearing all device memory and make sure you are using a valid ZNP image.  Please contact the com.zsmartsystems.zigbee Github community as this is a third-party solution not developed or maintained by TI.  You can further evaluate the ZNP using Z-Tool as provided in CC253X Z-Stack software package installations.
    Ryan
  • I'm not sure about the z-stack version i'm running, I've tried the dongle in  "com.zsmartsystems.zigbee", first with the default firmware as per fabric and then with the firmware of tosmota CC1352P2_CC2652P_launchpad_coordinator_20230507.hex, because i've made also some test with zigbee2mqtt (other purposes). Now i've downloaded the 3.0.2 as you said, but i'm not able to flash the dongle with this firmware.
    I've tried in two ways, first with the python script
    C:> python cc2538-bsl.py -ewv -p COM22 --bootloader-sonoff-usb ./CC2531ZNP-with-SBL.hex
    hello
    sonoff
    Opening port COM22, baud 500000
    Reading data from ./CC2531ZNP-with-SBL.hex
    Your firmware looks like an Intel Hex file
    Connecting to target...
    CC1350 PG2.0 (7x7mm): 352KB Flash, 20KB SRAM, CCFG.BL_CONFIG at 0x00057FD8
    Primary IEEE Address: 00:12:4B:00:2A:1A:FE:8F
        Performing mass erase
    Erasing all main bank flash sectors
        Erase done
    Writing 262129 bytes starting at address 0x00000000
    ERROR: Invalid data size: 262129. Size must be a multiple of 4.
    but there is this error due to memory space. Then i've tried with SMARTRF Flash programmer 2.
    here instead, the program doesn't show the CC2531, I used CC2652P just to try, putting the key in boot mode manually as explained in the guide. The flash of the key goes well, but "com.zsmartsystems.zigbee" gives me this:
    10:46:57.036  DEBUG  Default: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=1, interTransactionDelay=50, maxRetries=2]
    10:46:57.037  DEBUG  Broadcast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=2, interTransactionDelay=4000, maxRetries=0]
    10:46:57.037  DEBUG  Multicast: Set profile to ZigBeeTransactionProfile [maxOutstandingTransactions=3, interTransactionDelay=1200, maxRetries=0]
    10:46:57.181  DEBUG  ZigBeeNetworkManager initialize: networkState=UNINITIALISED
    10:46:57.181  DEBUG  Network state is updated to INITIALISING
    10:46:57.184  DEBUG  CC2531 transport initialize
    10:46:57.185  DEBUG  Opening port COM22 at 115200 baud with FLOWCONTROL_OUT_NONE.
    10:46:57.585  DEBUG  ->  SYS_RESET (Packet: subsystem=null, length=1, apiId=41 00, data=FE 01 41 00 01 41, checksum=41, error=false)
    10:47:02.600  WARN   Dongle reset failed. Assuming bootloader is running and sending magic byte 0xef.
    10:47:07.605  WARN   Attempt to get out from bootloader failed.
    10:47:07.606  INFO   Serial port 'COM22' closed.
    Is there a standard way to correctly flash CC2531 ?
  • Thanks Ryan for the suggestion, but I don't think the problem is the faulty state, just because the key is working in other environments correctly. I'll contact the  com.zsmartsystems.zigbee Github community of course.
    Thank you again
    Morgan
  • Hi Morgan,
    A CC2538/CC13XX/CC26XX bootloader solution cannot be used for a CC2531, and requires for the correct device to be selected in order to know the memory layout.  A CC2531 image likewise cannot be programmed into a CC2652P device and operate as intended. Sonoff dongles use the CC2652P in case you were not aware.  Since Flash Programmer 2 recognizes the CC2652P I recommend that you confirm the target device you are attempting to program.
    Ryan
  • Thanks Rian
    Actually I just found that the dongle I've working on is the CC2652P, not the CC2531 (little error in my company) .
    Also I didn't found any documentation on "com.zsmartsystems.zigbee" github about this key. Probably they didn't support it.
    So my question is... is there a known way to backup the dongle and its state ? Maybe the list of z-stack commands to give to the key?
    Morgan
  • Cloning Z-Stack Network Properties Using the SimpleLink Wireless MCU Family https://www.ti.com/lit/swra671
    Ryan
