CC2340R5: VREF accuracy
Part Number: CC2340R5
Other Parts Discussed in Thread: CC2674R10, CC2652R7, ,
What is the internal VREF accuracy in % ?
Geoffrey
    Same question for CC2652R7 and CC2674R10 please
    Geoffrey
  • Hi Geoffrey,
    You can infer the accuracy information you need from the provided reference plots in each of the data sheets. Please note that the plots are not inserted into the CC2340R5 data sheet as of today (they will be soon). For the time being you can use the CC2340R5-Q1 data sheet which has the performance data. For example:
    From these plots you should be able to determine if the accuracy is sufficient for your use case. Similarly for the other parts referenced there are similar plots in each of those data sheets.
    Jake
