Other Parts Discussed in Thread: Z-STACK
HI,
I met a problem here.
there is a definition in the z-stack. Just take the following description as the example.I can not understand what the endPoint means here.
Would you help me? I would like to find the answer . Thanks for your help....
/**************problem begins******************/
typedef struct
byte endPoint;
byte *task_id; // Pointer to location of the Application task ID.
SimpleDescriptionFormat_t *simpleDesc;
afNetworkLatencyReq_t latencyReq;
} endPointDesc_t;
// "#define SAMPLEAPP_ENDPOINT 20" // The definition "20 " represents what ???
//SampleApp_epDesc.endPoint = SAMPLEAPP_ENDPOINT;
//endPointDesc_t SampleApp_epDesc;
/******************problem ends***************/
Br.
Qian
