Tx output power?
Other Parts Discussed in Thread: Z-STACK, CC2530
Is it possible to change Tx output power dynamically while my network application is running?
Necdet
  • Hi Necdet,
    The answer for your question should be "yes", but, since you'r using an older version
    of Z-stack, I'm not sure hat the answer is positive. I think that you have "Z-stack API.pdf"
    document in z-stack documentation folder, there should be an API for such things.
    For example "Z-stack API.pdf" in Z-stack 2.5.0 (for cc253x) provides a function called
    ZMacSetTransmitPower(). I know for sure that there was a bug in this function in previous
    versions of Z-stack.
    One more way, very undesired and highly risky, is to apply a brute force, that is by writing
    some valid value directly to TXPOWER register.
  • Thanks again Igor,
    I'm going to move my work to CC2530 very soon. It's good to hear that solution is possible at least with cc253x.
    Necdet
