Part Number: CC2340R5
I am having trouble making zb_nvram_write_dataset work in ZBOSS. I followed ZBOSS user's guide as well as some demo code in Nordic's document to create callbacks for NVRAM and register the callback.
https://docs.nordicsemi.com/bundle/nrf5_sdk_thread_zigbee/page/group_zboss_nvram.html
However, the program does not return after zb_osif_nvram_write() is called in the write callback.
Please find my on_off_switch.c as below:
Group: CMCU LPRF
Target Device: cc23xx
Copyright (c) 2024-2025, Texas Instruments Incorporated
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
its contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/***** Trace related defines *****/
#define ZB_TRACE_FILE_ID 40124
/****** Application defines ******/
#define ZB_SWITCH_ENDPOINT 10
#include <ti/log/Log.h>
#include "ti_zigbee_config.h"
#include "zboss_api.h"
#include "zb_led_button.h"
#include <ti/devices/DeviceFamily.h>
#include DeviceFamily_constructPath(inc/hw_fcfg.h)
#include DeviceFamily_constructPath(inc/hw_memmap.h)
/* for button handling */
#include <ti/drivers/GPIO.h>
#include "ti_drivers_config.h"
#ifdef ZB_CONFIGURABLE_MEM
#include "zb_mem_config_lprf3.h"
#endif
#if !defined ZB_ED_FUNC
#error define ZB_ED_ROLE to compile the tests
#endif
/****** Application variables declarations ******/
/* IEEE address of the device */
zb_bool_t cmd_in_progress = ZB_FALSE;
zb_bool_t perform_factory_reset = ZB_FALSE;
/****** Application function declarations ******/
zb_uint8_t zcl_specific_cluster_cmd_handler(zb_uint8_t param);
void on_off_read_attr_resp_handler(zb_bufid_t cmd_buf);
void send_toggle_req(zb_uint8_t param);
void button_press_handler(zb_uint8_t param);
/****** Cluster declarations ******/
/* Switch config cluster attributes */
zb_uint8_t attr_switch_type =
ZB_ZCL_ON_OFF_SWITCH_CONFIGURATION_SWITCH_TYPE_TOGGLE;
zb_uint8_t attr_switch_actions =
ZB_ZCL_ON_OFF_SWITCH_CONFIGURATION_SWITCH_ACTIONS_DEFAULT_VALUE;
ZB_ZCL_DECLARE_ON_OFF_SWITCH_CONFIGURATION_ATTRIB_LIST(switch_cfg_attr_list,
&attr_switch_type,
&attr_switch_actions);
/* Basic cluster attributes */
zb_uint8_t attr_zcl_version = ZB_ZCL_BASIC_ZCL_VERSION_DEFAULT_VALUE;
zb_uint8_t attr_power_source = ZB_ZCL_BASIC_POWER_SOURCE_DEFAULT_VALUE;
ZB_ZCL_DECLARE_BASIC_ATTRIB_LIST(basic_attr_list, &attr_zcl_version, &attr_power_source);
/* Identify cluster attributes */
zb_uint16_t attr_identify_time = 0;
ZB_ZCL_DECLARE_IDENTIFY_ATTRIB_LIST(identify_attr_list, &attr_identify_time);
/* Declare cluster list for the device */
ZB_HA_DECLARE_ON_OFF_SWITCH_CLUSTER_LIST(on_off_switch_clusters,
basic_attr_list,
identify_attr_list);
/* Declare endpoint */
ZB_HA_DECLARE_ON_OFF_SWITCH_EP(on_off_switch_ep, ZB_SWITCH_ENDPOINT, on_off_switch_clusters);
/* Declare application's device context for single-endpoint device */
ZB_HA_DECLARE_ON_OFF_SWITCH_CTX(on_off_switch_ctx, on_off_switch_ep);
void my_main_loop()
while (1)
/* ... User code ... */
zboss_main_loop_iteration();
void module_zigbee_nvram_read_app_data(zb_uint8_t page, zb_uint32_t pos, zb_uint16_t payload_length)
zb_uint8_t buf[1] = {0};
zb_osif_nvram_read(page, pos, buf, payload_length);
Log_printf(LogModule_Zigbee_App, Log_INFO, "module_zigbee_nvram_read_app_data, buf[0] = 0x%x", buf[0]);
zb_uint8_t writeBuf[1] = {0x55};
zb_ret_t module_zigbee_nvram_write_app_data(zb_uint8_t page, zb_uint32_t pos)
zb_ret_t ret;
// zb_uint8_t buf[1] = {0x55};
zb_uint16_t len = 1;
ret = zb_osif_nvram_write(page, pos, writeBuf, len);
Log_printf(LogModule_Zigbee_App, Log_INFO, "module_zigbee_nvram_write_app_data, ret = %d", ret);
return ret;
zb_uint16_t module_get_nvram_data_size(void)
return 1;
MAIN()
ARGV_UNUSED;
/* Global ZBOSS initialization */
ZB_INIT("on_off_switch");
#ifdef ZB_LONG_ADDR
// use the address that the customer set in the pre-defined symbols tab
zb_ieee_addr_t g_long_addr = ZB_LONG_ADDR;
zb_set_long_address(g_long_addr);
#else
/* Set the device's long address to the IEEE address pulling from the FCFG of the device */
zb_ieee_addr_t ieee_mac_addr;
ZB_MEMCPY(ieee_mac_addr, fcfg->deviceInfo.macAddr, 8);
zb_set_long_address(ieee_mac_addr);
#endif // ZB_LONG_ADDR
#ifdef ZB_COORDINATOR_ROLE
zb_set_network_coordinator_role(DEFAULT_CHANLIST);
#ifdef DEFAULT_NWK_KEY
zb_uint8_t nwk_key[16] = DEFAULT_NWK_KEY;
zb_secur_setup_nwk_key(nwk_key, 0);
#endif //DEFAULT_NWK_KEY
zb_set_max_children(MAX_CHILDREN);
#elif defined ZB_ROUTER_ROLE && !defined ZB_COORDINATOR_ROLE
zb_set_network_router_role(DEFAULT_CHANLIST);
#elif defined ZB_ED_ROLE
zb_set_network_ed_role(DEFAULT_CHANLIST);
/* Set end-device configuration parameters */
zb_set_ed_timeout(ED_TIMEOUT_VALUE);
zb_set_rx_on_when_idle(ED_RX_ALWAYS_ON);
#if ( ED_RX_ALWAYS_ON == ZB_FALSE )
zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(ED_POLL_RATE));
#ifdef DISABLE_TURBO_POLL
// Disable turbo poll feature
zb_zdo_pim_permit_turbo_poll(ZB_FALSE);
zb_zdo_pim_set_long_poll_interval(ED_POLL_RATE);
#endif // DISABLE_TURBO_POLL
#endif // ED_RX_ALWAYS_ON
#endif //ZB_ED_ROLE
zb_set_nvram_erase_at_start(ZB_FALSE);
/* Register application callback for reading application data from NVRAM */
zb_nvram_register_app1_read_cb(module_zigbee_nvram_read_app_data);
/* Register application callback for writing application data to NVRAM */
zb_nvram_register_app1_write_cb(module_zigbee_nvram_write_app_data, module_get_nvram_data_size);
// zb_nvram_write_dataset(ZB_NVRAM_APP_DATA1);
// Log_printf(LogModule_Zigbee_App, Log_INFO, "write ZB_NVRAM_APP_DATA1");
/* Register device ZCL context */
ZB_AF_REGISTER_DEVICE_CTX(&on_off_switch_ctx);
/* Register cluster commands handler for a specific endpoint */
ZB_AF_SET_ENDPOINT_HANDLER(ZB_SWITCH_ENDPOINT, zcl_specific_cluster_cmd_handler);
/* Initiate the stack start without starting the commissioning */
if (zboss_start_no_autostart() != RET_OK)
Log_printf(LogModule_Zigbee_App, Log_ERROR, "zboss_start failed");
else
GPIO_setConfig(CONFIG_GPIO_BTN1, GPIO_CFG_IN_PU);
GPIO_setConfig(CONFIG_GPIO_BTN2, GPIO_CFG_IN_PU);
// if either button 1 or button 2 gets pressed
zb_bool_t sideButtonPressed = ((GPIO_read((zb_uint8_t)CONFIG_GPIO_BTN1) == 0U) || (GPIO_read((zb_uint8_t)CONFIG_GPIO_BTN2) == 0U));
// then perform a factory reset
if (sideButtonPressed)
perform_factory_reset = ZB_TRUE;
Log_printf(LogModule_Zigbee_App, Log_INFO, "perform factory reset");
/* Call the application-specific main loop */
my_main_loop();
MAIN_RETURN(0);
static zb_bool_t finding_binding_cb(zb_int16_t status,
zb_ieee_addr_t addr,
zb_uint8_t ep,
zb_uint16_t cluster)
/* Unused without trace. */
ZVUNUSED(status);
ZVUNUSED(addr);
ZVUNUSED(ep);
ZVUNUSED(cluster);
Log_printf(LogModule_Zigbee_App, Log_INFO, "finding_binding_cb status %d addr %x ep %d cluster %d",
status, ((zb_uint32_t *)addr)[0], ep, cluster);
return ZB_TRUE;
zb_zcl_parsed_hdr_t *cmd_info = ZB_BUF_GET_PARAM(param, zb_zcl_parsed_hdr_t);
zb_bool_t unknown_cmd_received = ZB_TRUE;
Log_printf(LogModule_Zigbee_App, Log_INFO, "> zcl_specific_cluster_cmd_handler %i", param);
Log_printf(LogModule_Zigbee_App, Log_INFO, "payload size: %i", zb_buf_len(param));
if (cmd_info->cmd_direction == ZB_ZCL_FRAME_DIRECTION_TO_CLI)
if (cmd_info->cmd_id == ZB_ZCL_CMD_DEFAULT_RESP)
unknown_cmd_received = ZB_FALSE;
zb_buf_free(param);
Log_printf(LogModule_Zigbee_App, Log_INFO, "< zcl_specific_cluster_cmd_handler %i", param);
return ! unknown_cmd_received;
zb_uint16_t addr = 0;
ZB_ASSERT(param);
if (ZB_JOINED() && !cmd_in_progress)
cmd_in_progress = ZB_TRUE;
Log_printf(LogModule_Zigbee_App, Log_INFO, "send_toggle_req %d - send toggle", param);
/* Destination address and endpoint are unknown; command will be sent via binding */
ZB_ZCL_ON_OFF_SEND_TOGGLE_REQ(
param,
addr,
ZB_APS_ADDR_MODE_DST_ADDR_ENDP_NOT_PRESENT,
0,
ZB_SWITCH_ENDPOINT,
ZB_AF_HA_PROFILE_ID,
ZB_FALSE, NULL);
else
Log_printf(LogModule_Zigbee_App, Log_INFO, "send_toggle_req %d - not joined", param);
zb_buf_free(param);
if (!param)
/* Button is pressed, gets buffer for outgoing command */
zb_buf_get_out_delayed(button_press_handler);
else
Log_printf(LogModule_Zigbee_App, Log_INFO, "button_press_handler %d", param);
send_toggle_req(param);
#ifndef ZB_USE_BUTTONS
/* Do not have buttons in simulator - just start periodic on/off sending */
ZB_SCHEDULE_APP_ALARM(button_press_handler, 0, 7 * ZB_TIME_ONE_SECOND);
#endif
void permit_joining_cb(zb_uint8_t param)
Log_printf(LogModule_Zigbee_App, Log_INFO, "permit joining done");
zb_buf_free(param);
void start_finding_binding(zb_uint8_t param)
ZVUNUSED(param);
Log_printf(LogModule_Zigbee_App, Log_INFO, "Successful steering, start f&b initiator");
zb_bdb_finding_binding_initiator(ZB_SWITCH_ENDPOINT, finding_binding_cb);
void zboss_signal_handler(zb_uint8_t param)
zb_zdo_app_signal_hdr_t *sg_p = NULL;
zb_zdo_app_signal_type_t sig = zb_get_app_signal(param, &sg_p);
zb_bufid_t buf;
zb_bufid_t req_buf = 0;
zb_zdo_mgmt_permit_joining_req_param_t *req_param;
#ifdef ZB_USE_BUTTONS
/* Now register handlers for buttons */
zb_int32_t i;
for (i = 0; i < ZB_N_BUTTONS; ++i)
zb_button_register_handler(i, 0, button_press_handler);
#endif
if (ZB_GET_APP_SIGNAL_STATUS(param) == 0)
switch(sig)
case ZB_ZDO_SIGNAL_SKIP_STARTUP:
#ifndef ZB_MACSPLIT_HOST
Log_printf(LogModule_Zigbee_App, Log_INFO, "ZB_ZDO_SIGNAL_SKIP_STARTUP: boot, not started yet");
zboss_start_continue();
#endif /* ZB_MACSPLIT_HOST */
break;
#ifdef ZB_MACSPLIT_HOST
case ZB_MACSPLIT_DEVICE_BOOT:
Log_printf(LogModule_Zigbee_App, Log_INFO, "ZB_MACSPLIT_DEVICE_BOOT: boot, not started yet");
break;
case ZB_BDB_SIGNAL_DEVICE_FIRST_START:
Log_printf(LogModule_Zigbee_App, Log_INFO, "FIRST_START: start steering");
if (perform_factory_reset)
// passing in 0 as the parameter means that a buffer will be allocated automatically for the reset
zb_bdb_reset_via_local_action(0);
bdb_start_top_level_commissioning(ZB_BDB_NETWORK_STEERING);
buf = zb_buf_get_out();
if (!buf)
Log_printf(LogModule_Zigbee_App, Log_WARNING, "no buffer available");
break;
req_param = ZB_BUF_GET_PARAM(buf, zb_zdo_mgmt_permit_joining_req_param_t);
req_param->dest_addr = 0xfffc;
req_param->permit_duration = 0;
req_param->tc_significance = 1;
zb_zdo_mgmt_permit_joining_req(buf, permit_joining_cb);
break;
case ZB_BDB_SIGNAL_DEVICE_REBOOT:
Log_printf(LogModule_Zigbee_App, Log_INFO, "Device RESTARTED OK");
Log_printf(LogModule_Zigbee_App, Log_INFO, "Performing a factory reset.");
ZB_SCHEDULE_APP_ALARM_CANCEL(button_press_handler, ZB_ALARM_ANY_PARAM);
#endif
break;
case ZB_ZDO_SIGNAL_DEVICE_ANNCE:
#else
case ZB_BDB_SIGNAL_TC_REJOIN_DONE:
Log_printf(LogModule_Zigbee_App, Log_INFO, "TC rejoin is completed successfully");
case ZB_BDB_SIGNAL_STEERING:
#endif
zb_nwk_device_type_t device_type = ZB_NWK_DEVICE_TYPE_NONE;
device_type = zb_get_device_type();
ZVUNUSED(device_type);
Log_printf(LogModule_Zigbee_App, Log_INFO, "Device (%d) STARTED OK", device_type);
ZB_SCHEDULE_APP_ALARM(start_finding_binding, 0, 3 * ZB_TIME_ONE_SECOND);
break;
case ZB_BDB_SIGNAL_FINDING_AND_BINDING_INITIATOR_FINISHED:
Log_printf(LogModule_Zigbee_App, Log_INFO, "Finding&binding done");
#endif
break;
case ZB_ZDO_SIGNAL_LEAVE:
break;
case ZB_COMMON_SIGNAL_CAN_SLEEP:
#ifdef ZB_USE_SLEEP
zb_sleep_now();
#endif
break;
case ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY:
Log_printf(LogModule_Zigbee_App, Log_INFO, "Production config is ready");
break;
default:
Log_printf(LogModule_Zigbee_App, Log_WARNING, "Unknown signal %d, do nothing", sig);
else
switch (sig)
Log_printf(LogModule_Zigbee_App, Log_WARNING, "Device can not find any network on start, so try to perform network steering");
break; /* ZB_BDB_SIGNAL_DEVICE_FIRST_START */
Log_printf(LogModule_Zigbee_App, Log_WARNING, "Device can not find any network on restart");
if (zb_bdb_is_factory_new())
/* Device tried to perform TC rejoin after reboot and lost its authentication flag.
* Do nothing here and wait for ZB_BDB_SIGNAL_TC_REJOIN_DONE to handle TC rejoin error */
Log_printf(LogModule_Zigbee_App, Log_WARNING, "Device lost authentication flag");
else
/* Device tried to perform secure rejoin, but didn't found any networks or can't decrypt Rejoin Response
* (it is possible when Trust Center changes network key when ZED is powered off) */
Log_printf(LogModule_Zigbee_App, Log_WARNING, "Device is still authenticated, try to perform TC rejoin");
ZB_SCHEDULE_APP_ALARM(zb_bdb_initiate_tc_rejoin, 0, ZB_TIME_ONE_SECOND);
break; /* ZB_BDB_SIGNAL_DEVICE_REBOOT */
Log_printf(LogModule_Zigbee_App, Log_INFO, "Production config is not present or invalid");
break; /* ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY */
Log_printf(LogModule_Zigbee_App, Log_WARNING, "TC rejoin failed, so try it again with interval");
ZB_SCHEDULE_APP_ALARM(zb_bdb_initiate_tc_rejoin, 0, 3 * ZB_TIME_ONE_SECOND);
break; /* ZB_BDB_SIGNAL_TC_REJOIN_DONE */
default:
Log_printf(LogModule_Zigbee_App, Log_WARNING, "Unknown signal %hd with error status, do nothing", sig);
break;
if (param)
zb_buf_free(param);
Please help review the code for errors and it's better if there is a demo for NVRAM write and read.
Shuyang
