Other Parts Discussed in Thread: CC2530
I need to make security sensors using the CC2530 modules.
The question is, if I have an analog signal ranging from 4mV to 200mV will it be sufficient for ADC to get proper values?
Or will you suggest a pre-amp to lift these voltages?
I guess amplifying the signal will just give me a better resolution and lead to less errors? SInce the gaps between voltages and digital values will be bigger?
Do I understand this right?
Thank you
