Dear people,
I am novice to this technology and actually stuck with this problem.
I've got CC2530ZNP Mini Kit and decided to make my first familiarity with this kit by
following instructions from Quick Start Guide. Steps 1, 2 and 3 have run without any problem
coordinator worked perfectly and end devices were joining networks and was registered on Hyper Terminal.
After that i came to STEP 5 of Guide - "Using IAR Embedded Workbench for programming/debugging"
So i downloaded and installed IAR Embedded Workbench for MSP430 and started as recommended
with Hardware Interface Examples - Button Blink.
And after that "disaster strikes" - coordinator ceased functioning. So i tried repeat this example
over and over again - but with the same result. Using IAR i clicked "erase memory" hoping to get
rid from code i downloaded into board - but result was the same.
So coordinator does not start networks - regardless of pushing button on board .
My problem is that i can not get help except this forum. I orded this kit and it came to me from another country
and now i am left with this problem and i don't have the slightest clue how to reset coordinator.
I just tried examples recommended i manual and hope didn't damage device or erased memory with
code of coordinator.
It is my second post - please if somebody can give me advice i would be very grateful for it.
My hope is just with answer on this forum - i have no other options.
Thank you in advance
Edward S.
