Enhancement of the Z-stack Location Engine Application example
Other Parts Discussed in Thread: Z-STACK
I am using the Z-stack and the Location Engine application.  I am thinking of using it inside a ship where some rooms can be  "Faraday cages" for the radio signal. Thus, a mixed network  cable/radio is required. The wired-nodes could simply work as transparent relays, hearing the message transmitted by the blind node(a mobile target whose position is desired)  and forwarding it as many hops as neccessary through the wired nodes  to reach the first Router/Reference node in the Location network.
I wonder if any application example is valid to form a simple relay node hearing the O-T-A message and re-transmitting it  by using the Uart port.
Any ideas to deploy this mixed network ...?
Thanks in advance.
Ralf.
