structure of each NV Items ?
Other Parts Discussed in Thread: Z-STACK
Hello.
I want to know the structure of each NV Items ?
Where the structure is defined?
I need your help, please.
For example,
osal_nv_read(ZCD_NV_DEVICE_LIST, 0, buflen, buf )
read data (buf)
 01 00 6F 79 00 00 01 04 00 70 79 01 00 01 04 00 71 79 02 00 01 04 00 72 79 03 00 01 04 00 73 79 04 00 01 04 00 74 79 05 00 01 04 00 75 79 06 00 01 04 01 76 79 07 00 01 04 00 77 79 08 00 01 04 00 78 79 09 00 01 04 00 7A 79 0B 00 01 04 00 7B 79 0C 00 01 04 00 7C 79 0D 00 01 04 00 7C 79 0D 00 01 04 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
I don't know the structure.
    Have a look at the following document that should have come in the documentation folder when you downloaded Z-Stack.  OSAL API_F8W-2003-0002_.pdf    Note the name might be slightly different depending on what Z-Stack version you are using.    In a typical install it can be found here (this example for 1.4.3)
    C:\Texas Instruments\ZStack-1.4.3-1.2.1\Documents
    Have a look there.  Hope this helps.
    Cheers,
    Yoda
  • Hi    Yoda
    I know the OSAL API_F8W-2003-0002_.pdf.
    I want to know the structure of the data NV Items
    NV Item : ZCD_NV_DEVICE_LIST
    Read Data : Below
