hi,
i want to know how to realize the low-power consumption?
for example,i want the enddevice to collect temperature information every 10 second,so during the period,i can make the enddevice to sleep,what should i do,could you give me some help?
hi,
hi,
thank you for your reply, i am confused by the low-power consumption.
i have enabled the POWER_SAVING, however, i don't know the meaning of POLL_RATE, and so i don't know set the POLL_RATE to what value, 50 or 100?could you show me some details?
what's more,there some compile options,like
NWK_AUTO_POLL
ZTOOL_P1
MT_TASK
MT_SYS_FUNC
MT_ZDO_FUNC
xLCD_SUPPORTED=DEBUG
POWER_SAVING
could i disable all the MT_ headed compile options,because i don't use the MT funtions,could you give me some help/
thanks very much,
best regards,
POLL_RATE means the period that an end device wakes up and polls from it parent node to see if its parent has any message for it. I suggest you can set it to 2 seconds and it should be enough for power saving. For ZTOOL_P1/MT_TASK/MT_SYS_FUNC/MT_ZDO_FUNC, you definitely can disable them since you don's use them. These definitions are nothing to do with power consumption but code size.
Regards!
YK Chen
